[U-Boot] [PATCH V4 1/2] mmc: sd: extracting erase related information from sd status
Add function to read SD_STATUS information. According to the information, get erase_timeout/erase_size/erase_offset. Add a structure sd_ssr to include the erase related information.
Signed-off-by: Peng Fan peng.fan@nxp.com Cc: Jaehoon Chung jh80.chung@samsung.com Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Cc: Stefan Wahren stefan.wahren@i2se.com Cc: Clemens Gruber clemens.gruber@pqgruber.com Cc: Kever Yang kever.yang@rock-chips.com Cc: Eric Nelson eric@nelint.com Cc: Stephen Warren swarren@nvidia.com ---
V4: include linux/sizes.h in mmc.h to avoid build break.
I dropped patch [2,3,4]/5 in V2, which is not a must in this optimization case.
V3: No change.
V2: Address Jaehoon's comments for V1 drivers/mmc/mmc.c | 68 +++++++++++++++++++++++++++++++++++++++++++++++++++++++ include/mmc.h | 9 ++++++++ 2 files changed, 77 insertions(+)
diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index 43ea0bb..0312da9 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -21,6 +21,14 @@ #include <div64.h> #include "mmc_private.h"
+static const unsigned int sd_au_size[] = { + 0, SZ_16K / 512, SZ_32K / 512, + SZ_64K / 512, SZ_128K / 512, SZ_256K / 512, + SZ_512K / 512, SZ_1M / 512, SZ_2M / 512, + SZ_4M / 512, SZ_8M / 512, (SZ_8M + SZ_4M) / 512, + SZ_16M / 512, (SZ_16M + SZ_8M) / 512, SZ_32M / 512, SZ_64M / 512, +}; + #ifndef CONFIG_DM_MMC_OPS __weak int board_mmc_getwp(struct mmc *mmc) { @@ -945,6 +953,62 @@ retry_scr: return 0; }
+static int sd_read_ssr(struct mmc *mmc) +{ + int err, i; + struct mmc_cmd cmd; + ALLOC_CACHE_ALIGN_BUFFER(uint, ssr, 16); + struct mmc_data data; + int timeout = 3; + unsigned int au, eo, et, es; + + cmd.cmdidx = MMC_CMD_APP_CMD; + cmd.resp_type = MMC_RSP_R1; + cmd.cmdarg = mmc->rca << 16; + + err = mmc_send_cmd(mmc, &cmd, NULL); + if (err) + return err; + + cmd.cmdidx = SD_CMD_APP_SD_STATUS; + cmd.resp_type = MMC_RSP_R1; + cmd.cmdarg = 0; + +retry_ssr: + data.dest = (char *)ssr; + data.blocksize = 64; + data.blocks = 1; + data.flags = MMC_DATA_READ; + + err = mmc_send_cmd(mmc, &cmd, &data); + if (err) { + if (timeout--) + goto retry_ssr; + + return err; + } + + for (i = 0; i < 16; i++) + ssr[i] = be32_to_cpu(ssr[i]); + + au = (ssr[2] >> 12) & 0xF; + if ((au <= 9) || (mmc->version == SD_VERSION_3)) { + mmc->ssr.au = sd_au_size[au]; + es = (ssr[3] >> 24) & 0xFF; + es |= (ssr[2] & 0xFF) << 8; + et = (ssr[3] >> 18) & 0x3F; + if (es && et) { + eo = (ssr[3] >> 16) & 0x3; + mmc->ssr.erase_timeout = (et * 1000) / es; + mmc->ssr.erase_offset = eo * 1000; + } + } else { + debug("Invalid Allocation Unit Size.\n"); + } + + return 0; +} + /* frequency bases */ /* divided by 10 to be nice to platforms without floating point */ static const int fbase[] = { @@ -1350,6 +1414,10 @@ static int mmc_startup(struct mmc *mmc) mmc_set_bus_width(mmc, 4); }
+ err = sd_read_ssr(mmc); + if (err) + return err; + if (mmc->card_caps & MMC_MODE_HS) mmc->tran_speed = 50000000; else diff --git a/include/mmc.h b/include/mmc.h index aa6d5d1..e815eb3 100644 --- a/include/mmc.h +++ b/include/mmc.h @@ -11,6 +11,7 @@ #define _MMC_H_
#include <linux/list.h> +#include <linux/sizes.h> #include <linux/compiler.h> #include <part.h>
@@ -102,6 +103,7 @@ #define SD_CMD_SWITCH_UHS18V 11
#define SD_CMD_APP_SET_BUS_WIDTH 6 +#define SD_CMD_APP_SD_STATUS 13 #define SD_CMD_ERASE_WR_BLK_START 32 #define SD_CMD_ERASE_WR_BLK_END 33 #define SD_CMD_APP_SEND_OP_COND 41 @@ -392,6 +394,12 @@ struct mmc_config { unsigned char part_type; };
+struct sd_ssr { + unsigned int au; /* In sectors */ + unsigned int erase_timeout; /* In milliseconds */ + unsigned int erase_offset; /* In milliseconds */ +}; + /* * With CONFIG_DM_MMC enabled, struct mmc can be accessed from the MMC device * with mmc_get_mmc_dev(). @@ -426,6 +434,7 @@ struct mmc { uint write_bl_len; uint erase_grp_size; /* in 512-byte sectors */ uint hc_wp_grp_size; /* in 512-byte sectors */ + struct sd_ssr ssr; /* SD status register */ u64 capacity; u64 capacity_user; u64 capacity_boot;
To SD, there is no erase group, then the value erase_grp_size will be default 1. When erasing SD blocks, the blocks will be erased one by one, which is time consuming.
We use AU_SIZE as a group to speed up the erasing.
Erasing 4MB with a SD2.0 Card with AU_SIZE 4MB. `time mmc erase 0x100000 0x2000` time: 44.856 seconds (before optimization) time: 0.335 seconds (after optimization)
Signed-off-by: Peng Fan peng.fan@nxp.com Cc: Jaehoon Chung jh80.chung@samsung.com Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Cc: Stefan Wahren stefan.wahren@i2se.com Cc: Clemens Gruber clemens.gruber@pqgruber.com Cc: Kever Yang kever.yang@rock-chips.com Cc: Eric Nelson eric@nelint.com Cc: Stephen Warren swarren@nvidia.com --- V4: No change.
V3: No change.
V2: Add test results. drivers/mmc/mmc_write.c | 9 +++++++-- 1 file changed, 7 insertions(+), 2 deletions(-)
diff --git a/drivers/mmc/mmc_write.c b/drivers/mmc/mmc_write.c index 0f8b5c7..2289640 100644 --- a/drivers/mmc/mmc_write.c +++ b/drivers/mmc/mmc_write.c @@ -100,8 +100,13 @@ unsigned long mmc_berase(struct blk_desc *block_dev, lbaint_t start, & ~(mmc->erase_grp_size - 1)) - 1);
while (blk < blkcnt) { - blk_r = ((blkcnt - blk) > mmc->erase_grp_size) ? - mmc->erase_grp_size : (blkcnt - blk); + if (IS_SD(mmc) && mmc->ssr.au) { + blk_r = ((blkcnt - blk) > mmc->ssr.au) ? + mmc->ssr.au : (blkcnt - blk); + } else { + blk_r = ((blkcnt - blk) > mmc->erase_grp_size) ? + mmc->erase_grp_size : (blkcnt - blk); + } err = mmc_erase_t(mmc, start + blk, blk_r); if (err) break;
Hi Peng,
Sorry for late..I'm testing with your patch on my SD-card. After that, I will apply yours. Before applied this, i will check more carefully for not doing previous my mistake.
Best Regards, Jaehoon Chung
V3: No change.
- 0, SZ_16K / 512, SZ_32K / 512,
- SZ_64K / 512, SZ_128K / 512, SZ_256K / 512,
- SZ_512K / 512, SZ_1M / 512, SZ_2M / 512,
- SZ_4M / 512, SZ_8M / 512, (SZ_8M + SZ_4M) / 512,
- SZ_16M / 512, (SZ_16M + SZ_8M) / 512, SZ_32M / 512, SZ_64M / 512,
- int err, i;
- struct mmc_cmd cmd;
- ALLOC_CACHE_ALIGN_BUFFER(uint, ssr, 16);
- struct mmc_data data;
- int timeout = 3;
- unsigned int au, eo, et, es;
- cmd.cmdidx = MMC_CMD_APP_CMD;
- cmd.resp_type = MMC_RSP_R1;
- cmd.cmdarg = mmc->rca << 16;
- err = mmc_send_cmd(mmc, &cmd, NULL);
- if (err)
return err;
- cmd.cmdidx = SD_CMD_APP_SD_STATUS;
- cmd.cmdarg = 0;
+retry_ssr:
- data.dest = (char *)ssr;
- data.blocksize = 64;
- data.blocks = 1;
- data.flags = MMC_DATA_READ;
- err = mmc_send_cmd(mmc, &cmd, &data);
- if (err) {
if (timeout--)
goto retry_ssr;
return err;
- for (i = 0; i < 16; i++)
- au = (ssr[2] >> 12) & 0xF;
- if ((au <= 9) || (mmc->version == SD_VERSION_3)) {
if (es && et) {
- } else {
if (err)
return err;
- if (mmc->card_caps & MMC_MODE_HS) mmc->tran_speed = 50000000; else
+struct sd_ssr {
- unsigned int au; /* In sectors */
- unsigned int erase_timeout; /* In milliseconds */
- unsigned int erase_offset; /* In milliseconds */
- With CONFIG_DM_MMC enabled, struct mmc can be accessed from the MMC device
- with mmc_get_mmc_dev().
- struct sd_ssr ssr; /* SD status register */ u64 capacity; u64 capacity_user; u64 capacity_boot;
Hi Jaehoon, On Wed, Sep 07, 2016 at 03:52:53PM +0900, Jaehoon Chung wrote:
Hi Peng,
The issue in the previous patch set is that linux/size.h is not included in sandbox.h. In this patchset, I include linux/size.h in mmc.h:)
Thanks, Peng.
V3: No change.
- int err, i;
- int timeout = 3;
- if (err)
return err;
- cmd.cmdarg = 0;
+retry_ssr:
- data.blocks = 1;
- if (err) {
if (timeout--)
goto retry_ssr;
return err;
if (es && et) {
- } else {
if (err)
return err;
+struct sd_ssr {
Hi Peng,
Hi Peng,
Right, i have checked the test of building with your patch. There is no problem..just i want to run your patch for erasing SD-card. Could you wait for one day?
Thanks, Peng.
V3: No change.
- int err, i;
- int timeout = 3;
- if (err)
return err;
- cmd.cmdarg = 0;
+retry_ssr:
- data.blocks = 1;
- if (err) {
if (timeout--)
goto retry_ssr;
return err;
if (es && et) {
- } else {
if (err)
return err;
+struct sd_ssr {
On Thu, Sep 08, 2016 at 10:49:53AM +0900, Jaehoon Chung wrote:
Hi Peng,
Hi Peng,
Yeah. Ok for me :)
Thanks, Peng.
Hi Peng,
Hi Peng,
Hi Peng,
Yeah. Ok for me :)
I have tested with your patch.. (Same command yours "time mmc erase 0x100000 0x2000")
Before applied your patch..it took 18.212 seconds
After applied your patch. 0.548 seconds. Great!
I applied on u-boot-mmc. Thanks!
Thanks, Peng.
Jaehoon Chung
Peng Fan
