Pull request: u-boot-sunxi/master fixes for 2022.01
Hi Tom,
please pull those two fixes from the sunxi tree. This fixes two regressions: eMMC operation on boards with WiFi (so using three MMC devices), and a repeated wrong error message in USB gadget mode (fastboot, ums).
Thanks, Andre
=========================== The following changes since commit 558002a0f2230bedf6b38716f3ed86a92fc9010b:
Merge https://source.denx.de/u-boot/custodians/u-boot-riscv (2021-12-03 09:02:49 -0500)
https://source.denx.de/u-boot/custodians/u-boot-sunxi.git master
for you to fetch changes up to fbd9207e7fe3712b372ca9889a2a82402161fd27:
sunxi: Remove misleading USB-OTG charger message (2021-12-08 23:07:15 +0000)
---------------------------------------------------------------- Andre Przywara (2): sunxi: dts: Fix typoed eMMC check sunxi: Remove misleading USB-OTG charger message
arch/arm/dts/sunxi-u-boot.dtsi | 2 +- board/sunxi/board.c | 8 +------- 2 files changed, 2 insertions(+), 8 deletions(-)
On Thu, Dec 09, 2021 at 12:06:50AM +0000, Andre Przywara wrote:
Hi Tom,
Thanks, Andre
Andre Przywara
