[U-Boot] [PATCH] Add "source" command; prepare removal of "autoscr" command
According to the doc/feature-removal-schedule.txt, the "autoscr" command will be replaced by the "source" command in approximately 6 months from now.
This patch prepares this change and starts a 6 month transition period as follows:
- The new "source" command has been added, which implements exactly the same functionlaity as the old "autoscr" command before - The old "autoscr" command name is kept as an alias for compatibility - Command sequences, script files atc. have been adapted to use the new "source" command - Related environment variables ("autoscript", "autoscript_uname") have *not* been adapted yet; these will be renamed resp. removed in a separate patch when the support for the "autoscr" command get's finally dropped.
Signed-off-by: Wolfgang Denk wd@denx.de --- Changes since V1: - add DEPRECATED warning message to "autoscr" help text. - Print DEPRECATED warning message whenever "autoscr" command gets used.
README | 10 +- board/cray/L1/L1.c | 2 +- board/cray/L1/bootscript.hush | 2 +- board/esd/common/cmd_loadpci.c | 6 +- board/pn62/cmd_pn62.c | 7 +- common/Makefile | 4 +- common/cmd_autoscript.c | 241 ----------------------------------- common/cmd_load.c | 7 +- common/cmd_net.c | 7 +- common/cmd_source.c | 256 ++++++++++++++++++++++++++++++++++++++ doc/feature-removal-schedule.txt | 20 ++- include/common.h | 4 +- include/config_cmd_all.h | 2 +- include/config_cmd_default.h | 2 +- include/configs/APC405.h | 14 +- include/configs/CRAYL1.h | 26 ++-- include/configs/DU440.h | 12 +- include/configs/EP1C20.h | 2 +- include/configs/GEN860T.h | 2 +- include/configs/MVBC_P.h | 12 +- include/configs/MVBLM7.h | 12 +- include/configs/NETPHONE.h | 2 +- include/configs/NETTA2.h | 2 +- include/configs/NX823.h | 4 +- include/configs/PN62.h | 6 +- include/configs/TOP860.h | 8 +- include/configs/TQM5200.h | 2 +- include/configs/VoVPN-GW.h | 4 +- include/configs/afeb9260.h | 6 +- include/configs/apollon.h | 2 +- include/configs/at91cap9adk.h | 4 +- include/configs/at91sam9260ek.h | 6 +- include/configs/at91sam9261ek.h | 6 +- include/configs/at91sam9263ek.h | 6 +- include/configs/at91sam9rlek.h | 6 +- include/configs/atngw100.h | 2 +- include/configs/atstk1002.h | 2 +- include/configs/atstk1006.h | 2 +- include/configs/eNET.h | 6 +- include/configs/favr-32-ezkit.h | 2 +- include/configs/grsim.h | 26 ++-- include/configs/grsim_leon2.h | 22 ++-- include/configs/gth2.h | 14 +- include/configs/keymile-common.h | 2 +- include/configs/lwmon.h | 4 +- include/configs/lwmon5.h | 2 +- include/configs/mp2usb.h | 4 +- include/configs/mx1fs2.h | 6 +- include/configs/omap2420h4.h | 2 +- include/configs/omap3_beagle.h | 2 +- include/configs/omap3_evm.h | 2 +- include/configs/omap3_overo.h | 2 +- include/configs/omap3_pandora.h | 2 +- include/configs/omap3_zoom1.h | 2 +- include/configs/sc3.h | 24 ++-- include/configs/scb9328.h | 4 +- include/configs/stxxtc.h | 2 +- include/configs/vct.h | 38 +++--- include/configs/wepep250.h | 6 +- 59 files changed, 458 insertions(+), 436 deletions(-) delete mode 100644 common/cmd_autoscript.c create mode 100644 common/cmd_source.c
diff --git a/README b/README index 32d9acd..fcc4d7c 100644 --- a/README +++ b/README @@ -593,7 +593,6 @@ The following options need to be configured: except those marked below with a "*".
CONFIG_CMD_ASKENV * ask for env variable - CONFIG_CMD_AUTOSCRIPT Autoscript Support CONFIG_CMD_BDI bdinfo CONFIG_CMD_BEDBUG * Include BedBug Debugger CONFIG_CMD_BMP * BMP support @@ -654,6 +653,7 @@ The following options need to be configured: (requires CONFIG_CMD_I2C) CONFIG_CMD_SETGETDCR Support for DCR Register access (4xx only) + CONFIG_CMD_SOURCE "source" command Support CONFIG_CMD_SPI * SPI serial bus support CONFIG_CMD_USB * USB support CONFIG_CMD_VFD * VFD support (TRAB) @@ -1789,7 +1789,7 @@ The following options need to be configured:
Note: overly (ab)use of the default environment is discouraged. Make sure to check other ways to preset - the environment like the autoscript function or the + the environment like the "source" command or the boot command first.
- DataFlash Support: @@ -1948,8 +1948,8 @@ Legacy uImage format: 81 common/cmd_net.c NetLoop() back without error -82 common/cmd_net.c size == 0 (File with size 0 loaded) 82 common/cmd_net.c trying automatic boot - 83 common/cmd_net.c running autoscript - -83 common/cmd_net.c some error in automatic boot or autoscript + 83 common/cmd_net.c running "source" command + -83 common/cmd_net.c some error in automatic boot or "source" command 84 common/cmd_net.c end without errors
FIT uImage format: @@ -2952,7 +2952,7 @@ Some configuration options can be set using Environment Variables: autoscript - if set to "yes" commands like "loadb", "loady", "bootp", "tftpb", "rarpboot" and "nfs" will attempt to automatically run script images (by internally - calling "autoscript"). + calling "source").
autoscript_uname - if script image is in a format (FIT) this variable is used to get script subimage unit name. diff --git a/board/cray/L1/L1.c b/board/cray/L1/L1.c index 1c82bdf..8a06ecc 100644 --- a/board/cray/L1/L1.c +++ b/board/cray/L1/L1.c @@ -164,7 +164,7 @@ int misc_init_r (void) setenv ("ethaddr", e); } } - sprintf (bootcmd,"autoscript %X",(unsigned)bootscript); + sprintf (bootcmd,"source %X",(unsigned)bootscript); setenv ("bootcmd", bootcmd); return (0); } diff --git a/board/cray/L1/bootscript.hush b/board/cray/L1/bootscript.hush index ec4839b..f2f78ad 100644 --- a/board/cray/L1/bootscript.hush +++ b/board/cray/L1/bootscript.hush @@ -31,7 +31,7 @@ if printenv bootscript tftp $tftp_addr $bootcript if imi $tftp_addr then - autoscript $tftp_addr + source $tftp_addr fi fi
diff --git a/board/esd/common/cmd_loadpci.c b/board/esd/common/cmd_loadpci.c index 0a6626e..c779f79 100644 --- a/board/esd/common/cmd_loadpci.c +++ b/board/esd/common/cmd_loadpci.c @@ -30,7 +30,7 @@ #if defined(CONFIG_CMD_BSP)
extern int do_bootm (cmd_tbl_t *, int, int, char *[]); -extern int do_autoscript (cmd_tbl_t *, int, int, char *[]); +extern int do_source (cmd_tbl_t *, int, int, char *[]);
#define ADDRMASK 0xfffff000
@@ -98,12 +98,12 @@ int do_loadpci(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[])
case 1: /* - * Boot image via autoscr + * Boot image via "source" command */ printf("executing script at addr 0x%s ...\n", addr); local_args[0] = addr; local_args[1] = NULL; - do_autoscript(cmdtp, 0, 1, local_args); + do_source(cmdtp, 0, 1, local_args); break;
case 2: diff --git a/board/pn62/cmd_pn62.c b/board/pn62/cmd_pn62.c index 10d0df6..b9f3bdb 100644 --- a/board/pn62/cmd_pn62.c +++ b/board/pn62/cmd_pn62.c @@ -152,12 +152,13 @@ int do_loadpci (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) rcode = do_bootm (cmdtp, 0, 1, local_args); }
-#ifdef CONFIG_AUTOSCRIPT +#ifdef CONFIG_SOURCE if (load_addr) { char *s;
if (((s = getenv("autoscript")) != NULL) && (strcmp(s,"yes") == 0)) { - printf ("Running autoscript at addr 0x%08lX", load_addr); + printf ("Running "source" command at addr 0x%08lX", + load_addr);
s = getenv ("autoscript_uname"); if (s) @@ -165,7 +166,7 @@ int do_loadpci (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) else puts (" ...\n");
- rcode = autoscript (load_addr, s); + rcode = source (load_addr, s); } } #endif diff --git a/common/Makefile b/common/Makefile index 23171ca..eb8e283 100644 --- a/common/Makefile +++ b/common/Makefile @@ -61,8 +61,8 @@ COBJS-$(CONFIG_ENV_IS_NOWHERE) += env_nowhere.o
# command COBJS-$(CONFIG_CMD_AMBAPP) += cmd_ambapp.o -COBJS-$(CONFIG_AUTOSCRIPT) += cmd_autoscript.o -COBJS-$(CONFIG_CMD_AUTOSCRIPT) += cmd_autoscript.o +COBJS-$(CONFIG_SOURCE) += cmd_source.o +COBJS-$(CONFIG_CMD_SOURCE) += cmd_source.o COBJS-$(CONFIG_CMD_BDI) += cmd_bdinfo.o COBJS-$(CONFIG_CMD_BEDBUG) += bedbug.o cmd_bedbug.o COBJS-$(CONFIG_CMD_BMP) += cmd_bmp.o diff --git a/common/cmd_autoscript.c b/common/cmd_autoscript.c deleted file mode 100644 index e5a9bc0..0000000 --- a/common/cmd_autoscript.c +++ /dev/null @@ -1,241 +0,0 @@ -/* - * (C) Copyright 2001 - * Kyle Harris, kharris@nexus-tech.net - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -/* - * autoscript allows a remote host to download a command file and, - * optionally, binary data for automatically updating the target. For - * example, you create a new kernel image and want the user to be - * able to simply download the image and the machine does the rest. - * The kernel image is postprocessed with mkimage, which creates an - * image with a script file prepended. If enabled, autoscript will - * verify the script and contents of the download and execute the - * script portion. This would be responsible for erasing flash, - * copying the new image, and rebooting the machine. - */ - -/* #define DEBUG */ - -#include <common.h> -#include <command.h> -#include <image.h> -#include <malloc.h> -#include <asm/byteorder.h> -#if defined(CONFIG_8xx) -#include <mpc8xx.h> -#endif -#ifdef CONFIG_SYS_HUSH_PARSER -#include <hush.h> -#endif - -int -autoscript (ulong addr, const char *fit_uname) -{ - ulong len; - image_header_t *hdr; - ulong *data; - char *cmd; - int rcode = 0; - int verify; -#if defined(CONFIG_FIT) - const void* fit_hdr; - int noffset; - const void *fit_data; - size_t fit_len; -#endif - - verify = getenv_yesno ("verify"); - - switch (genimg_get_format ((void *)addr)) { - case IMAGE_FORMAT_LEGACY: - hdr = (image_header_t *)addr; - - if (!image_check_magic (hdr)) { - puts ("Bad magic number\n"); - return 1; - } - - if (!image_check_hcrc (hdr)) { - puts ("Bad header crc\n"); - return 1; - } - - if (verify) { - if (!image_check_dcrc (hdr)) { - puts ("Bad data crc\n"); - return 1; - } - } - - if (!image_check_type (hdr, IH_TYPE_SCRIPT)) { - puts ("Bad image type\n"); - return 1; - } - - /* get length of script */ - data = (ulong *)image_get_data (hdr); - - if ((len = uimage_to_cpu (*data)) == 0) { - puts ("Empty Script\n"); - return 1; - } - - /* - * scripts are just multi-image files with one component, seek - * past the zero-terminated sequence of image lengths to get - * to the actual image data - */ - while (*data++); - break; -#if defined(CONFIG_FIT) - case IMAGE_FORMAT_FIT: - if (fit_uname == NULL) { - puts ("No FIT subimage unit name\n"); - return 1; - } - - fit_hdr = (const void *)addr; - if (!fit_check_format (fit_hdr)) { - puts ("Bad FIT image format\n"); - return 1; - } - - /* get script component image node offset */ - noffset = fit_image_get_node (fit_hdr, fit_uname); - if (noffset < 0) { - printf ("Can't find '%s' FIT subimage\n", fit_uname); - return 1; - } - - if (!fit_image_check_type (fit_hdr, noffset, IH_TYPE_SCRIPT)) { - puts ("Not a image image\n"); - return 1; - } - - /* verify integrity */ - if (verify) { - if (!fit_image_check_hashes (fit_hdr, noffset)) { - puts ("Bad Data Hash\n"); - return 1; - } - } - - /* get script subimage data address and length */ - if (fit_image_get_data (fit_hdr, noffset, &fit_data, &fit_len)) { - puts ("Could not find script subimage data\n"); - return 1; - } - - data = (ulong *)fit_data; - len = (ulong)fit_len; - break; -#endif - default: - puts ("Wrong image format for autoscript\n"); - return 1; - } - - debug ("** Script length: %ld\n", len); - - if ((cmd = malloc (len + 1)) == NULL) { - return 1; - } - - /* make sure cmd is null terminated */ - memmove (cmd, (char *)data, len); - *(cmd + len) = 0; - -#ifdef CONFIG_SYS_HUSH_PARSER /*?? */ - rcode = parse_string_outer (cmd, FLAG_PARSE_SEMICOLON); -#else - { - char *line = cmd; - char *next = cmd; - - /* - * break into individual lines, - * and execute each line; - * terminate on error. - */ - while (*next) { - if (*next == '\n') { - *next = '\0'; - /* run only non-empty commands */ - if (*line) { - debug ("** exec: "%s"\n", - line); - if (run_command (line, 0) < 0) { - rcode = 1; - break; - } - } - line = next + 1; - } - ++next; - } - if (rcode == 0 && *line) - rcode = (run_command(line, 0) >= 0); - } -#endif - free (cmd); - return rcode; -} - -/**************************************************/ -#if defined(CONFIG_CMD_AUTOSCRIPT) -int -do_autoscript (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) -{ - ulong addr; - int rcode; - const char *fit_uname = NULL; - - /* Find script image */ - if (argc < 2) { - addr = CONFIG_SYS_LOAD_ADDR; - debug ("* autoscr: default load address = 0x%08lx\n", addr); -#if defined(CONFIG_FIT) - } else if (fit_parse_subimage (argv[1], load_addr, &addr, &fit_uname)) { - debug ("* autoscr: subimage '%s' from FIT image at 0x%08lx\n", - fit_uname, addr); -#endif - } else { - addr = simple_strtoul(argv[1], NULL, 16); - debug ("* autoscr: cmdline image address = 0x%08lx\n", addr); - } - - printf ("## Executing script at %08lx\n", addr); - rcode = autoscript (addr, fit_uname); - return rcode; -} - -U_BOOT_CMD( - autoscr, 2, 0, do_autoscript, - "run script from memory", - "[addr] - run script starting at addr" - " - A valid autoscr header must be present\n" -#if defined(CONFIG_FIT) - "For FIT format uImage addr must include subimage\n" - "unit name in the form of addr:<subimg_uname>\n" -#endif -); -#endif diff --git a/common/cmd_load.c b/common/cmd_load.c index 88fba88..d5eaac7 100644 --- a/common/cmd_load.c +++ b/common/cmd_load.c @@ -513,12 +513,13 @@ int do_load_serial_bin (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) } }
s = getenv ("autoscript_uname"); if (s) @@ -526,7 +527,7 @@ int do_load_serial_bin (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) else puts (" ...\n");
- rcode = autoscript (load_addr, s); + rcode = source (load_addr, s); } } #endif diff --git a/common/cmd_net.c b/common/cmd_net.c index a687849..9bef7a2 100644 --- a/common/cmd_net.c +++ b/common/cmd_net.c @@ -222,9 +222,10 @@ netboot_common (proto_t proto, cmd_tbl_t *cmdtp, int argc, char *argv[]) rcode = do_bootm (cmdtp, 0, 1, local_args); }
-#ifdef CONFIG_AUTOSCRIPT +#ifdef CONFIG_SOURCE if (((s = getenv("autoscript")) != NULL) && (strcmp(s,"yes") == 0)) { - printf ("Running autoscript at addr 0x%08lX", load_addr); + printf ("Running "source" command at addr 0x%08lX", + load_addr);
s = getenv ("autoscript_uname"); if (s) @@ -233,7 +234,7 @@ netboot_common (proto_t proto, cmd_tbl_t *cmdtp, int argc, char *argv[]) puts (" ...\n");
show_boot_progress (83); - rcode = autoscript (load_addr, s); + rcode = source (load_addr, s); } #endif if (rcode < 0) diff --git a/common/cmd_source.c b/common/cmd_source.c new file mode 100644 index 0000000..43e1315 --- /dev/null +++ b/common/cmd_source.c @@ -0,0 +1,256 @@ +/* + * (C) Copyright 2001 + * Kyle Harris, kharris@nexus-tech.net + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * The "source" command allows to define "script images", i. e. files + * that contain command sequences that can be executed by the command + * interpreter. It returns the exit status of the last command + * executed from the script. This is very similar to running a shell + * script in a UNIX shell, hence the name for the command. + */ + +/* #define DEBUG */ + +#include <common.h> +#include <command.h> +#include <image.h> +#include <malloc.h> +#include <asm/byteorder.h> +#if defined(CONFIG_8xx) +#include <mpc8xx.h> +#endif +#ifdef CONFIG_SYS_HUSH_PARSER +#include <hush.h> +#endif + +int +source (ulong addr, const char *fit_uname) +{ + ulong len; + image_header_t *hdr; + ulong *data; + char *cmd; + int rcode = 0; + int verify; +#if defined(CONFIG_FIT) + const void* fit_hdr; + int noffset; + const void *fit_data; + size_t fit_len; +#endif + + verify = getenv_yesno ("verify"); + + switch (genimg_get_format ((void *)addr)) { + case IMAGE_FORMAT_LEGACY: + hdr = (image_header_t *)addr; + + if (!image_check_magic (hdr)) { + puts ("Bad magic number\n"); + return 1; + } + + if (!image_check_hcrc (hdr)) { + puts ("Bad header crc\n"); + return 1; + } + + if (verify) { + if (!image_check_dcrc (hdr)) { + puts ("Bad data crc\n"); + return 1; + } + } + + if (!image_check_type (hdr, IH_TYPE_SCRIPT)) { + puts ("Bad image type\n"); + return 1; + } + + /* get length of script */ + data = (ulong *)image_get_data (hdr); + + if ((len = uimage_to_cpu (*data)) == 0) { + puts ("Empty Script\n"); + return 1; + } + + /* + * scripts are just multi-image files with one component, seek + * past the zero-terminated sequence of image lengths to get + * to the actual image data + */ + while (*data++); + break; +#if defined(CONFIG_FIT) + case IMAGE_FORMAT_FIT: + if (fit_uname == NULL) { + puts ("No FIT subimage unit name\n"); + return 1; + } + + fit_hdr = (const void *)addr; + if (!fit_check_format (fit_hdr)) { + puts ("Bad FIT image format\n"); + return 1; + } + + /* get script component image node offset */ + noffset = fit_image_get_node (fit_hdr, fit_uname); + if (noffset < 0) { + printf ("Can't find '%s' FIT subimage\n", fit_uname); + return 1; + } + + if (!fit_image_check_type (fit_hdr, noffset, IH_TYPE_SCRIPT)) { + puts ("Not a image image\n"); + return 1; + } + + /* verify integrity */ + if (verify) { + if (!fit_image_check_hashes (fit_hdr, noffset)) { + puts ("Bad Data Hash\n"); + return 1; + } + } + + /* get script subimage data address and length */ + if (fit_image_get_data (fit_hdr, noffset, &fit_data, &fit_len)) { + puts ("Could not find script subimage data\n"); + return 1; + } + + data = (ulong *)fit_data; + len = (ulong)fit_len; + break; +#endif + default: + puts ("Wrong image format for "source" command\n"); + return 1; + } + + debug ("** Script length: %ld\n", len); + + if ((cmd = malloc (len + 1)) == NULL) { + return 1; + } + + /* make sure cmd is null terminated */ + memmove (cmd, (char *)data, len); + *(cmd + len) = 0; + +#ifdef CONFIG_SYS_HUSH_PARSER /*?? */ + rcode = parse_string_outer (cmd, FLAG_PARSE_SEMICOLON); +#else + { + char *line = cmd; + char *next = cmd; + + /* + * break into individual lines, + * and execute each line; + * terminate on error. + */ + while (*next) { + if (*next == '\n') { + *next = '\0'; + /* run only non-empty commands */ + if (*line) { + debug ("** exec: "%s"\n", + line); + if (run_command (line, 0) < 0) { + rcode = 1; + break; + } + } + line = next + 1; + } + ++next; + } + if (rcode == 0 && *line) + rcode = (run_command(line, 0) >= 0); + } +#endif + free (cmd); + return rcode; +} + +/**************************************************/ +#if defined(CONFIG_CMD_SOURCE) +int +do_source (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + ulong addr; + int rcode; + const char *fit_uname = NULL; + + /* Find script image */ + if (argc < 2) { + addr = CONFIG_SYS_LOAD_ADDR; + debug ("* source: default load address = 0x%08lx\n", addr); +#if defined(CONFIG_FIT) + } else if (fit_parse_subimage (argv[1], load_addr, &addr, &fit_uname)) { + debug ("* source: subimage '%s' from FIT image at 0x%08lx\n", + fit_uname, addr); +#endif + } else { + addr = simple_strtoul(argv[1], NULL, 16); + debug ("* source: cmdline image address = 0x%08lx\n", addr); + } + + printf ("## Executing script at %08lx\n", addr); + rcode = source (addr, fit_uname); + return rcode; +} + +U_BOOT_CMD( + source, 2, 0, do_source, + "run script from memory", + "[addr]\n" + "\t- run script starting at addr\n" + "\t- A valid image header must be present\n" +#if defined(CONFIG_FIT) + "For FIT format uImage addr must include subimage\n" + "unit name in the form of addr:<subimg_uname>\n" +#endif +); + +/* + * Keep for now for backward compatibility; + * remove later when support for "autoscr" goes away. + */ +static int +do_autoscr (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + printf ("\n### WARNING ### " + ""autoscr" is deprecated, use "source" instead ###\n\n"); + return do_source (cmdtp, flag, argc, argv); +} + +U_BOOT_CMD( + autoscr, 2, 0, do_autoscr, + "DEPRECATED - use "source" command instead", + "DEPRECATED - use "source" command instead\n" +); +#endif diff --git a/doc/feature-removal-schedule.txt b/doc/feature-removal-schedule.txt index 9ba7a04..cd429a4 100644 --- a/doc/feature-removal-schedule.txt +++ b/doc/feature-removal-schedule.txt @@ -8,12 +8,20 @@ file. ---------------------------
What: "autoscr" command -When: August 2009 -Why: "autosrc" is an ugly and completely non-standard name. The "autoscr" - command is deprecated and will be replaced the "source" command as - used by other shells such as bash. Both commands will be supported - for a transition period of 6 months after which "autoscr" will be - removed. +When: Release 2009-09 + +Why: "autosrc" is an ugly and completely non-standard name. + The "autoscr" command is deprecated and will be replaced by + + the "source" command as used by other shells such as bash. + + Starting with March 2009, both commands will be supported for + a transition period of 6 months after which "autoscr" will be + removed. During the transition period existing scripts and + environment variable names remain untouched for maximum + compatibiltiy; thse will be changed when support for the + "autoscr" command get's finally dropped. + Who: Peter Tyser ptyser@xes-inc.com
--------------------------- diff --git a/include/common.h b/include/common.h index 952ddff..20c058a 100644 --- a/include/common.h +++ b/include/common.h @@ -234,8 +234,8 @@ int mac_read_from_eeprom(void); /* common/flash.c */ void flash_perror (int);
-/* common/cmd_autoscript.c */ -int autoscript (ulong addr, const char *fit_uname); +/* common/cmd_source.c */ +int source (ulong addr, const char *fit_uname);
extern ulong load_addr; /* Default Load Address */
diff --git a/include/config_cmd_all.h b/include/config_cmd_all.h index db1f55c..c5e0d26 100644 --- a/include/config_cmd_all.h +++ b/include/config_cmd_all.h @@ -15,7 +15,6 @@
#define CONFIG_CMD_AMBAPP /* AMBA Plug & Play Bus print utility */ #define CONFIG_CMD_ASKENV /* ask for env variable */ -#define CONFIG_CMD_AUTOSCRIPT /* Autoscript Support */ #define CONFIG_CMD_BDI /* bdinfo */ #define CONFIG_CMD_BEDBUG /* Include BedBug Debugger */ #define CONFIG_CMD_BMP /* BMP support */ @@ -76,6 +75,7 @@ #define CONFIG_CMD_SETEXPR /* setexpr support */ #define CONFIG_CMD_SETGETDCR /* DCR support on 4xx */ #define CONFIG_CMD_SNTP /* SNTP support */ +#define CONFIG_CMD_SOURCE /* "source" command support */ #define CONFIG_CMD_SPI /* SPI utility */ #define CONFIG_CMD_TERMINAL /* built-in Serial Terminal */ #define CONFIG_CMD_UNIVERSE /* Tundra Universe Support */ diff --git a/include/config_cmd_default.h b/include/config_cmd_default.h index 3667602..0376e44 100644 --- a/include/config_cmd_default.h +++ b/include/config_cmd_default.h @@ -16,7 +16,6 @@ * hardware, not fully tested, etc.). */
-#define CONFIG_CMD_AUTOSCRIPT /* Autoscript Support */ #define CONFIG_CMD_BDI /* bdinfo */ #define CONFIG_CMD_BOOTD /* bootd */ #define CONFIG_CMD_CONSOLE /* coninfo */ @@ -37,6 +36,7 @@ #define CONFIG_CMD_NFS /* NFS support */ #define CONFIG_CMD_RUN /* run command in env variable */ #define CONFIG_CMD_SETGETDCR /* DCR support on 4xx */ +#define CONFIG_CMD_SOURCE /* "source" command support */ #define CONFIG_CMD_XIMG /* Load part of Multi Image */
#endif /* _CONFIG_CMD_DEFAULT_H */ diff --git a/include/configs/APC405.h b/include/configs/APC405.h index 7453518..41eaaab 100644 --- a/include/configs/APC405.h +++ b/include/configs/APC405.h @@ -124,19 +124,19 @@ */ #include <config_cmd_default.h>
+#define CONFIG_CMD_DATE #define CONFIG_CMD_DHCP -#define CONFIG_CMD_PCI -#define CONFIG_CMD_IRQ -#define CONFIG_CMD_IDE -#define CONFIG_CMD_FAT +#define CONFIG_CMD_EEPROM #define CONFIG_CMD_ELF -#define CONFIG_CMD_DATE +#define CONFIG_CMD_FAT #define CONFIG_CMD_I2C +#define CONFIG_CMD_IDE +#define CONFIG_CMD_IRQ #define CONFIG_CMD_MII +#define CONFIG_CMD_PCI #define CONFIG_CMD_PING -#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_SOURCE #define CONFIG_CMD_USB -#define CONFIG_CMD_AUTOSCRIPT
#define CONFIG_MAC_PARTITION #define CONFIG_DOS_PARTITION diff --git a/include/configs/CRAYL1.h b/include/configs/CRAYL1.h index 527c846..150bd29 100644 --- a/include/configs/CRAYL1.h +++ b/include/configs/CRAYL1.h @@ -74,32 +74,32 @@ #define CONFIG_SYS_HZ 1000 /* decrementer freq: 1 ms ticks */ #define CONFIG_SYS_HUSH_PARSER 1 #define CONFIG_SYS_PROMPT_HUSH_PS2 "> " -#define CONFIG_AUTOSCRIPT 1 +#define CONFIG_SOURCE 1
/* * Command line configuration. */
+#define CONFIG_CMD_ASKENV #define CONFIG_CMD_BDI -#define CONFIG_CMD_IMI -#define CONFIG_CMD_FLASH -#define CONFIG_CMD_MEMORY -#define CONFIG_CMD_NET -#define CONFIG_CMD_SAVEENV #define CONFIG_CMD_CONSOLE -#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_DATE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_DIAG #define CONFIG_CMD_ECHO +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_FLASH +#define CONFIG_CMD_I2C +#define CONFIG_CMD_IMI #define CONFIG_CMD_IMMAP +#define CONFIG_CMD_MEMORY +#define CONFIG_CMD_NET #define CONFIG_CMD_REGINFO -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_DATE #define CONFIG_CMD_RUN -#define CONFIG_CMD_I2C -#define CONFIG_CMD_EEPROM -#define CONFIG_CMD_DIAG -#define CONFIG_CMD_AUTOSCRIPT +#define CONFIG_CMD_SAVEENV #define CONFIG_CMD_SETGETDCR +#define CONFIG_CMD_SOURCE
/* diff --git a/include/configs/DU440.h b/include/configs/DU440.h index 85c0e61..e6abbdc 100644 --- a/include/configs/DU440.h +++ b/include/configs/DU440.h @@ -290,14 +290,13 @@ int du440_phy_addr(int devnum);
-#define CONFIG_CMD_AUTOSCRIPT -#define CONFIG_CMD_BSP +#define CONFIG_CMD_ASKENV #define CONFIG_CMD_BMP +#define CONFIG_CMD_BSP #define CONFIG_CMD_DATE -#define CONFIG_CMD_ASKENV #define CONFIG_CMD_DHCP -#define CONFIG_CMD_DTT #define CONFIG_CMD_DIAG +#define CONFIG_CMD_DTT #define CONFIG_CMD_EEPROM #define CONFIG_CMD_ELF #define CONFIG_CMD_FAT @@ -309,9 +308,10 @@ int du440_phy_addr(int devnum); #define CONFIG_CMD_NFS #define CONFIG_CMD_PCI #define CONFIG_CMD_PING -#define CONFIG_CMD_USB #define CONFIG_CMD_REGINFO #define CONFIG_CMD_SDRAM +#define CONFIG_CMD_SOURCE +#define CONFIG_CMD_USB
#define CONFIG_SUPPORT_VFAT
@@ -428,7 +428,7 @@ int du440_phy_addr(int devnum); #define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ #endif
#define CONFIG_OF_LIBFDT #define CONFIG_OF_BOARD_SETUP diff --git a/include/configs/EP1C20.h b/include/configs/EP1C20.h index a0904d4..8941e4d 100644 --- a/include/configs/EP1C20.h +++ b/include/configs/EP1C20.h @@ -180,7 +180,6 @@ #define CONFIG_CMD_PING #define CONFIG_CMD_SAVES
-#undef CONFIG_CMD_AUTOSCRIPT #undef CONFIG_CMD_BOOTD #undef CONFIG_CMD_CONSOLE #undef CONFIG_CMD_FPGA @@ -188,6 +187,7 @@ #undef CONFIG_CMD_ITEST #undef CONFIG_CMD_NFS #undef CONFIG_CMD_SETGETDCR +#undef CONFIG_CMD_SOURCE #undef CONFIG_CMD_XIMG
diff --git a/include/configs/GEN860T.h b/include/configs/GEN860T.h index a399d22..8f18ab2 100644 --- a/include/configs/GEN860T.h +++ b/include/configs/GEN860T.h @@ -152,7 +152,7 @@
/* * Set default IP stuff just to get bootstrap entries into the - * environment so that we can autoscript the full default environment. + * environment so that we can source the full default environment. */ #define CONFIG_ETHADDR 9a:52:63:15:85:25 #define CONFIG_SERVERIP 10.0.4.201 diff --git a/include/configs/MVBC_P.h b/include/configs/MVBC_P.h index cd910ea..edbc701 100644 --- a/include/configs/MVBC_P.h +++ b/include/configs/MVBC_P.h @@ -73,8 +73,8 @@ #define MV_INITRD_LENGTH 0x00300000 #define MV_SCRATCH_ADDR 0x00000000 #define MV_SCRATCH_LENGTH MV_INITRD_LENGTH -#define MV_AUTOSCR_ADDR 0xff840000 -#define MV_AUTOSCR_ADDR2 0xff850000 +#define MV_SOURCE_ADDR 0xff840000 +#define MV_SOURCE_ADDR2 0xff850000 #define MV_DTB_ADDR 0xfffc0000
#define CONFIG_SHOW_BOOT_PROGRESS 1 @@ -130,8 +130,8 @@ #define CONFIG_RESET_TO_RETRY 1000
#define CONFIG_BOOTCOMMAND "if imi ${autoscr_addr}; \ - then autoscr ${autoscr_addr}; \ - else autoscr ${autoscr_addr2}; \ + then source ${autoscr_addr}; \ + else source ${autoscr_addr2}; \ fi;"
#define CONFIG_BOOTARGS "root=/dev/ram ro rootfstype=squashfs" @@ -149,8 +149,8 @@ "fpga=0\0" \ "fpgadata=" MK_STR(MV_FPGA_DATA) "\0" \ "fpgadatasize=" MK_STR(MV_FPGA_SIZE) "\0" \ - "autoscr_addr=" MK_STR(MV_AUTOSCR_ADDR) "\0" \ - "autoscr_addr2=" MK_STR(MV_AUTOSCR_ADDR2) "\0" \ + "autoscr_addr=" MK_STR(MV_SOURCE_ADDR) "\0" \ + "autoscr_addr2=" MK_STR(MV_SOURCE_ADDR2) "\0" \ "mv_kernel_addr=" MK_STR(MV_KERNEL_ADDR) "\0" \ "mv_kernel_addr_ram=" MK_STR(MV_KERNEL_ADDR_RAM) "\0" \ "mv_initrd_addr=" MK_STR(MV_INITRD_ADDR) "\0" \ diff --git a/include/configs/MVBLM7.h b/include/configs/MVBLM7.h index 4ecf806..3cf3bb2 100644 --- a/include/configs/MVBLM7.h +++ b/include/configs/MVBLM7.h @@ -411,8 +411,8 @@ #define MV_FPGA_SIZE 0x00076ca2 #define MV_KERNEL_ADDR 0xff810000 #define MV_INITRD_ADDR 0xffb00000 -#define MV_AUTOSCR_ADDR 0xff804000 -#define MV_AUTOSCR_ADDR2 0xff806000 +#define MV_SOURCE_ADDR 0xff804000 +#define MV_SOURCE_ADDR2 0xff806000 #define MV_DTB_ADDR 0xff808000 #define MV_INITRD_LENGTH 0x00400000
@@ -423,8 +423,8 @@ #define MV_INITRD_ADDR_RAM 0x01000000
#define CONFIG_BOOTCOMMAND "if imi ${autoscr_addr}; \ - then autoscr ${autoscr_addr}; \ - else autoscr ${autoscr_addr2}; \ + then source ${autoscr_addr}; \ + else source ${autoscr_addr2}; \ fi;" #define CONFIG_BOOTARGS "root=/dev/ram ro rootfstype=squashfs"
@@ -437,8 +437,8 @@ "fpga=0\0" \ "fpgadata=" MK_STR(MV_FPGA_DATA) "\0" \ "fpgadatasize=" MK_STR(MV_FPGA_SIZE) "\0" \ - "autoscr_addr=" MK_STR(MV_AUTOSCR_ADDR) "\0" \ - "autoscr_addr2=" MK_STR(MV_AUTOSCR_ADDR2) "\0" \ + "autoscr_addr=" MK_STR(MV_SOURCE_ADDR) "\0" \ + "autoscr_addr2=" MK_STR(MV_SOURCE_ADDR2) "\0" \ "mv_kernel_addr=" MK_STR(MV_KERNEL_ADDR) "\0" \ "mv_kernel_addr_ram=" MK_STR(MV_KERNEL_ADDR_RAM) "\0" \ "mv_initrd_addr=" MK_STR(MV_INITRD_ADDR) "\0" \ diff --git a/include/configs/NETPHONE.h b/include/configs/NETPHONE.h index 2d04d89..796938a 100644 --- a/include/configs/NETPHONE.h +++ b/include/configs/NETPHONE.h @@ -71,7 +71,7 @@ "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}::off;" \ "bootm"
-#define CONFIG_AUTOSCRIPT +#define CONFIG_SOURCE #define CONFIG_LOADS_ECHO 0 /* echo off for serial download */ #undef CONFIG_SYS_LOADS_BAUD_CHANGE /* don't allow baudrate change */
diff --git a/include/configs/NETTA2.h b/include/configs/NETTA2.h index 4a27027..a14b2dd 100644 --- a/include/configs/NETTA2.h +++ b/include/configs/NETTA2.h @@ -71,7 +71,7 @@ "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}::off; " \ "bootm"
diff --git a/include/configs/NX823.h b/include/configs/NX823.h index 9182223..5054d5e 100644 --- a/include/configs/NX823.h +++ b/include/configs/NX823.h @@ -55,7 +55,7 @@ #define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #undef CONFIG_SYS_LOADS_BAUD_CHANGE /* don't allow baudrate change */ #undef CONFIG_WATCHDOG /* watchdog disabled, for now */ -#define CONFIG_AUTOSCRIPT +#define CONFIG_SOURCE
/* * BOOTP options @@ -72,7 +72,7 @@ */ #include <config_cmd_default.h>
-#define CONFIG_CMD_AUTOSCRIPT +#define CONFIG_CMD_SOURCE
/* call various generic functions */ diff --git a/include/configs/PN62.h b/include/configs/PN62.h index 06c11e6..562c5c3 100644 --- a/include/configs/PN62.h +++ b/include/configs/PN62.h @@ -59,11 +59,11 @@ #define CONFIG_CMD_PCI #define CONFIG_CMD_BSP
-#undef CONFIG_CMD_AUTOSCRIPT -#undef CONFIG_CMD_LOADS -#undef CONFIG_CMD_SAVEENV #undef CONFIG_CMD_FLASH #undef CONFIG_CMD_IMLS +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_SAVEENV +#undef CONFIG_CMD_SOURCE
#define CONFIG_BAUDRATE 19200 /* console baudrate */ diff --git a/include/configs/TOP860.h b/include/configs/TOP860.h index 8c2befb..b9e450d 100644 --- a/include/configs/TOP860.h +++ b/include/configs/TOP860.h @@ -125,7 +125,7 @@ #define CONFIG_CMD_BEDBUG
-#define CONFIG_AUTOSCRIPT 1 +#define CONFIG_SOURCE 1 #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 #undef CONFIG_LOADS_ECHO /* NO echo on for serial download */
@@ -419,15 +419,12 @@
/* * Set default IP stuff just to get bootstrap entries into the - * environment so that we can autoscript the full default environment. + * environment so that we can source the full default environment. */ #define CONFIG_ETHADDR 9a:52:63:15:85:25 #define CONFIG_SERVERIP 10.0.4.200 #define CONFIG_IPADDR 10.0.4.111
-/*----------------------------------------------------------------------- - * Defaults for Autoscript - */ #define CONFIG_SYS_LOAD_ADDR 0x00100000 /* default load address */ #define CONFIG_SYS_TFTP_LOADADDR 0x00100000
@@ -438,5 +435,4 @@ */ #define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */
- #endif /* __CONFIG_H */ diff --git a/include/configs/TQM5200.h b/include/configs/TQM5200.h index d374981..fe1d102 100644 --- a/include/configs/TQM5200.h +++ b/include/configs/TQM5200.h @@ -253,7 +253,7 @@ #define CUSTOM_ENV_SETTINGS \ "bootfile=cam5200/uImage\0" \ "u-boot=cam5200/u-boot.bin\0" \ - "setup=tftp 200000 cam5200/setup.img; autoscr 200000\0" + "setup=tftp 200000 cam5200/setup.img; source 200000\0" #endif
#if defined(CONFIG_TQM5200_B) diff --git a/include/configs/VoVPN-GW.h b/include/configs/VoVPN-GW.h index 5f9a17f..b2d75e3 100644 --- a/include/configs/VoVPN-GW.h +++ b/include/configs/VoVPN-GW.h @@ -150,11 +150,9 @@ * Command line configuration. */
-#define CONFIG_CMD_AUTOSCRIPT #define CONFIG_CMD_BDI #define CONFIG_CMD_CONSOLE #define CONFIG_CMD_ECHO -#define CONFIG_CMD_SAVEENV #define CONFIG_CMD_FLASH #define CONFIG_CMD_IMI #define CONFIG_CMD_IMLS @@ -164,6 +162,8 @@ #define CONFIG_CMD_NET #define CONFIG_CMD_PING #define CONFIG_CMD_RUN +#define CONFIG_CMD_SAVEENV +#define CONFIG_CMD_SOURCE
/* diff --git a/include/configs/afeb9260.h b/include/configs/afeb9260.h index 33a67ca..fa27119 100644 --- a/include/configs/afeb9260.h +++ b/include/configs/afeb9260.h @@ -69,11 +69,11 @@ */ #include <config_cmd_default.h> #undef CONFIG_CMD_BDI -#undef CONFIG_CMD_IMI -#undef CONFIG_CMD_AUTOSCRIPT #undef CONFIG_CMD_FPGA -#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_IMI #undef CONFIG_CMD_IMLS +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_SOURCE
#define CONFIG_CMD_PING 1 #define CONFIG_CMD_DHCP 1 diff --git a/include/configs/apollon.h b/include/configs/apollon.h index f83dd9c..b0af2a9 100644 --- a/include/configs/apollon.h +++ b/include/configs/apollon.h @@ -127,7 +127,7 @@ #define CONFIG_MTD_PARTITIONS #endif
-#undef CONFIG_CMD_AUTOSCRIPT +#undef CONFIG_CMD_SOURCE
#ifndef CONFIG_SYS_USE_NOR # undef CONFIG_CMD_FLASH diff --git a/include/configs/at91cap9adk.h b/include/configs/at91cap9adk.h index 7e7f124..2ddbd17 100644 --- a/include/configs/at91cap9adk.h +++ b/include/configs/at91cap9adk.h @@ -91,10 +91,10 @@ */ #include <config_cmd_default.h> #undef CONFIG_CMD_BDI -#undef CONFIG_CMD_IMI -#undef CONFIG_CMD_AUTOSCRIPT #undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_IMI #undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_SOURCE
#define CONFIG_CMD_PING 1 #define CONFIG_CMD_DHCP 1 diff --git a/include/configs/at91sam9260ek.h b/include/configs/at91sam9260ek.h index 1fae3a3..1a5f9a4 100644 --- a/include/configs/at91sam9260ek.h +++ b/include/configs/at91sam9260ek.h @@ -86,11 +86,11 @@ */ #include <config_cmd_default.h> #undef CONFIG_CMD_BDI -#undef CONFIG_CMD_IMI -#undef CONFIG_CMD_AUTOSCRIPT #undef CONFIG_CMD_FPGA -#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_IMI #undef CONFIG_CMD_IMLS +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_SOURCE
#define CONFIG_CMD_PING 1 #define CONFIG_CMD_DHCP 1 diff --git a/include/configs/at91sam9261ek.h b/include/configs/at91sam9261ek.h index 752d7e9..4d50932 100644 --- a/include/configs/at91sam9261ek.h +++ b/include/configs/at91sam9261ek.h @@ -90,11 +90,11 @@ */ #include <config_cmd_default.h> #undef CONFIG_CMD_BDI -#undef CONFIG_CMD_IMI -#undef CONFIG_CMD_AUTOSCRIPT #undef CONFIG_CMD_FPGA -#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_IMI #undef CONFIG_CMD_IMLS +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_SOURCE
#define CONFIG_CMD_PING 1 #define CONFIG_CMD_DHCP 1 diff --git a/include/configs/at91sam9263ek.h b/include/configs/at91sam9263ek.h index dd500ca..78e0081 100644 --- a/include/configs/at91sam9263ek.h +++ b/include/configs/at91sam9263ek.h @@ -91,11 +91,11 @@ */ #include <config_cmd_default.h> #undef CONFIG_CMD_BDI -#undef CONFIG_CMD_IMI -#undef CONFIG_CMD_AUTOSCRIPT #undef CONFIG_CMD_FPGA -#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_IMI #undef CONFIG_CMD_IMLS +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_SOURCE
#define CONFIG_CMD_PING 1 #define CONFIG_CMD_DHCP 1 diff --git a/include/configs/at91sam9rlek.h b/include/configs/at91sam9rlek.h index 7a4039c..a48f2cb 100644 --- a/include/configs/at91sam9rlek.h +++ b/include/configs/at91sam9rlek.h @@ -82,12 +82,12 @@ */ #include <config_cmd_default.h> #undef CONFIG_CMD_BDI -#undef CONFIG_CMD_IMI -#undef CONFIG_CMD_AUTOSCRIPT #undef CONFIG_CMD_FPGA -#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_IMI #undef CONFIG_CMD_IMLS +#undef CONFIG_CMD_LOADS #undef CONFIG_CMD_NET +#undef CONFIG_CMD_SOURCE #undef CONFIG_CMD_USB
#define CONFIG_CMD_NAND 1 diff --git a/include/configs/atngw100.h b/include/configs/atngw100.h index c998952..4ed5514 100644 --- a/include/configs/atngw100.h +++ b/include/configs/atngw100.h @@ -117,9 +117,9 @@ #define CONFIG_CMD_SF #define CONFIG_CMD_SPI
-#undef CONFIG_CMD_AUTOSCRIPT #undef CONFIG_CMD_FPGA #undef CONFIG_CMD_SETGETDCR +#undef CONFIG_CMD_SOURCE #undef CONFIG_CMD_XIMG
#define CONFIG_ATMEL_USART 1 diff --git a/include/configs/atstk1002.h b/include/configs/atstk1002.h index 2284277..b258f2d 100644 --- a/include/configs/atstk1002.h +++ b/include/configs/atstk1002.h @@ -142,9 +142,9 @@ #define CONFIG_CMD_JFFS2 #define CONFIG_CMD_MMC
#define CONFIG_ATMEL_USART 1 diff --git a/include/configs/atstk1006.h b/include/configs/atstk1006.h index 8cfa312..f93118e 100644 --- a/include/configs/atstk1006.h +++ b/include/configs/atstk1006.h @@ -142,9 +142,9 @@ #define CONFIG_CMD_JFFS2 #define CONFIG_CMD_MMC
#define CONFIG_ATMEL_USART 1 diff --git a/include/configs/eNET.h b/include/configs/eNET.h index 84e1aef..8169d10 100644 --- a/include/configs/eNET.h +++ b/include/configs/eNET.h @@ -70,16 +70,15 @@ */ #include <config_cmd_default.h>
-#define CONFIG_CMD_AUTOSCRIPT /* Autoscript Support */ #define CONFIG_CMD_BDI /* bdinfo */ #define CONFIG_CMD_BOOTD /* bootd */ #define CONFIG_CMD_CONSOLE /* coninfo */ #define CONFIG_CMD_ECHO /* echo arguments */ -#define CONFIG_CMD_SAVEENV /* saveenv */ #define CONFIG_CMD_FLASH /* flinfo, erase, protect */ #define CONFIG_CMD_FPGA /* FPGA configuration Support */ #define CONFIG_CMD_IMI /* iminfo */ #define CONFIG_CMD_IMLS /* List all found images */ +#define CONFIG_CMD_IRQ /* IRQ Information */ #define CONFIG_CMD_ITEST /* Integer (and string) test */ #define CONFIG_CMD_LOADB /* loadb */ #define CONFIG_CMD_LOADS /* loads */ @@ -88,9 +87,10 @@ #undef CONFIG_CMD_NET /* bootp, tftpboot, rarpboot */ #undef CONFIG_CMD_NFS /* NFS support */ #define CONFIG_CMD_RUN /* run command in env variable */ +#define CONFIG_CMD_SAVEENV /* saveenv */ #define CONFIG_CMD_SETGETDCR /* DCR support on 4xx */ +#define CONFIG_CMD_SOURCE /* "source" command Support */ #define CONFIG_CMD_XIMG /* Load part of Multi Image */ -#define CONFIG_CMD_IRQ /* IRQ Information */
#define CONFIG_BOOTDELAY 15 #define CONFIG_BOOTARGS "root=/dev/mtdblock0 console=ttyS0,9600" diff --git a/include/configs/favr-32-ezkit.h b/include/configs/favr-32-ezkit.h index 21802df..739ff0d 100644 --- a/include/configs/favr-32-ezkit.h +++ b/include/configs/favr-32-ezkit.h @@ -139,9 +139,9 @@ #define CONFIG_CMD_JFFS2 #define CONFIG_CMD_MMC
#define CONFIG_ATMEL_USART 1 diff --git a/include/configs/grsim.h b/include/configs/grsim.h index a9eaa4a..c3f1a31 100644 --- a/include/configs/grsim.h +++ b/include/configs/grsim.h @@ -65,23 +65,23 @@ /* * Supported commands */ -#define CONFIG_CMD_AMBAPP /* AMBA Plyg&Play information */ -#define CONFIG_CMD_AUTOSCRIPT /* Autoscript Support */ -#define CONFIG_CMD_BDI /* bdinfo */ -#define CONFIG_CMD_CONSOLE /* coninfo */ +#define CONFIG_CMD_AMBAPP /* AMBA Plyg&Play information */ +#define CONFIG_CMD_BDI /* bdinfo */ +#define CONFIG_CMD_CONSOLE /* coninfo */ #define CONFIG_CMD_DIAG -#define CONFIG_CMD_ECHO /* echo arguments */ -#define CONFIG_CMD_FPGA /* FPGA configuration Support */ +#define CONFIG_CMD_ECHO /* echo arguments */ +#define CONFIG_CMD_FPGA /* FPGA configuration Support */ #define CONFIG_CMD_IRQ -#define CONFIG_CMD_ITEST /* Integer (and string) test */ -#define CONFIG_CMD_LOADB /* loadb */ -#define CONFIG_CMD_LOADS /* loads */ +#define CONFIG_CMD_ITEST /* Integer (and string) test */ +#define CONFIG_CMD_LOADB /* loadb */ +#define CONFIG_CMD_LOADS /* loads */ #define CONFIG_CMD_MISC /* Misc functions like sleep etc */ -#define CONFIG_CMD_NET /* bootp, tftpboot, rarpboot */ +#define CONFIG_CMD_NET /* bootp, tftpboot, rarpboot */ #define CONFIG_CMD_REGINFO -#define CONFIG_CMD_RUN /* run command in env variable */ -#define CONFIG_CMD_SETGETDCR /* DCR support on 4xx */ -#define CONFIG_CMD_XIMG /* Load part of Multi Image */ +#define CONFIG_CMD_RUN /* run command in env variable */ +#define CONFIG_CMD_SETGETDCR /* DCR support on 4xx */ +#define CONFIG_CMD_SOURCE /* "source" command support */ +#define CONFIG_CMD_XIMG /* Load part of Multi Image */
/* * Autobooting diff --git a/include/configs/grsim_leon2.h b/include/configs/grsim_leon2.h index 58f26fd..7ebbf25 100644 --- a/include/configs/grsim_leon2.h +++ b/include/configs/grsim_leon2.h @@ -64,21 +64,21 @@ /* * Supported commands */ -#define CONFIG_CMD_AUTOSCRIPT /* Autoscript Support */ -#define CONFIG_CMD_BDI /* bdinfo */ -#define CONFIG_CMD_CONSOLE /* coninfo */ +#define CONFIG_CMD_BDI /* bdinfo */ +#define CONFIG_CMD_CONSOLE /* coninfo */ #define CONFIG_CMD_DIAG -#define CONFIG_CMD_ECHO /* echo arguments */ -#define CONFIG_CMD_FPGA /* FPGA configuration Support */ +#define CONFIG_CMD_ECHO /* echo arguments */ +#define CONFIG_CMD_FPGA /* FPGA configuration Support */ #define CONFIG_CMD_IRQ -#define CONFIG_CMD_ITEST /* Integer (and string) test */ -#define CONFIG_CMD_LOADB /* loadb */ -#define CONFIG_CMD_LOADS /* loads */ +#define CONFIG_CMD_ITEST /* Integer (and string) test */ +#define CONFIG_CMD_LOADB /* loadb */ +#define CONFIG_CMD_LOADS /* loads */ #define CONFIG_CMD_MISC /* Misc functions like sleep etc */ #define CONFIG_CMD_REGINFO -#define CONFIG_CMD_RUN /* run command in env variable */ -#define CONFIG_CMD_SETGETDCR /* DCR support on 4xx */ -#define CONFIG_CMD_XIMG /* Load part of Multi Image */ +#define CONFIG_CMD_RUN /* run command in env variable */ +#define CONFIG_CMD_SETGETDCR /* DCR support on 4xx */ +#define CONFIG_CMD_SOURCE /* "source" command support */ +#define CONFIG_CMD_XIMG /* Load part of Multi Image */
/* * Autobooting diff --git a/include/configs/gth2.h b/include/configs/gth2.h index b1b4842..677baea 100644 --- a/include/configs/gth2.h +++ b/include/configs/gth2.h @@ -90,18 +90,18 @@ #define CONFIG_CMD_IDE #define CONFIG_CMD_DHCP
-#undef CONFIG_CMD_SAVEENV +#undef CONFIG_CMD_BDI +#undef CONFIG_CMD_BEDBUG +#undef CONFIG_CMD_ELF #undef CONFIG_CMD_FAT #undef CONFIG_CMD_FLASH #undef CONFIG_CMD_FPGA -#undef CONFIG_CMD_MII -#undef CONFIG_CMD_LOADS #undef CONFIG_CMD_LOADB -#undef CONFIG_CMD_ELF -#undef CONFIG_CMD_BDI -#undef CONFIG_CMD_BEDBUG +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_MII #undef CONFIG_CMD_NFS -#undef CONFIG_CMD_AUTOSCRIPT +#undef CONFIG_CMD_SAVEENV +#undef CONFIG_CMD_SOURCE
/* diff --git a/include/configs/keymile-common.h b/include/configs/keymile-common.h index 58b95f4..b2e37ec 100644 --- a/include/configs/keymile-common.h +++ b/include/configs/keymile-common.h @@ -240,7 +240,7 @@ "new_esw_0x${IVM_BoardId}_0x${IVM_HWKey}.scr \0" \ "new_esw=run set_new_esw_script; " \ "tftp ${autoscr_ws} ${new_esw_script}; " \ - "iminfo ${autoscr_ws}; autoscr ${autoscr_ws} \0" \ + "iminfo ${autoscr_ws}; source ${autoscr_ws} \0" \ "bootlimit=0 \0" \ CONFIG_KM_DEF_ENV_IOMUX \ CONFIG_KM_DEF_ENV_PRIVATE \ diff --git a/include/configs/lwmon.h b/include/configs/lwmon.h index d52a5e0..8f00773 100644 --- a/include/configs/lwmon.h +++ b/include/configs/lwmon.h @@ -93,7 +93,7 @@ * 3 = 0x3C+0x3F = F3 + F6 : enable test mode */
-#define CONFIG_BOOTCOMMAND "autoscr 40040000;saveenv" +#define CONFIG_BOOTCOMMAND "source 40040000;saveenv"
/* "gatewayip=10.8.211.250\0" \ */ #define CONFIG_EXTRA_ENV_SETTINGS \ @@ -108,7 +108,7 @@ "key_magic2=3A+3C\0" \ "key_cmd2=echo *** Entering Update Mode ***;" \ "if fatload ide 0:3 10000 update.scr;" \ - "then autoscr 10000;" \ + "then source 10000;" \ "else echo *** UPDATE FAILED ***;" \ "fi\0" \ "key_magic3=3C+3F\0" \ diff --git a/include/configs/lwmon5.h b/include/configs/lwmon5.h index 05055c8..777a4d6 100644 --- a/include/configs/lwmon5.h +++ b/include/configs/lwmon5.h @@ -313,7 +313,7 @@ "cp.b 200000 FFF80000 80000\0" \ "upd=run load update\0" \ "lwe_env=tftp 200000 /tftpboot.dev/lwmon5/env_uboot.bin;" \ - "autoscr 200000\0" \ + "source 200000\0" \ "" #define CONFIG_BOOTCOMMAND "run flash_self"
diff --git a/include/configs/mp2usb.h b/include/configs/mp2usb.h index 9ac7e9a..edaa174 100644 --- a/include/configs/mp2usb.h +++ b/include/configs/mp2usb.h @@ -163,15 +163,15 @@
#else
- #define CONFIG_CMD_USB #define CONFIG_CMD_CACHE + #define CONFIG_CMD_USB
- #undef CONFIG_CMD_AUTOSCRIPT #undef CONFIG_CMD_BDI #undef CONFIG_CMD_FPGA #undef CONFIG_CMD_IMI #undef CONFIG_CMD_LOADS #undef CONFIG_CMD_MISC + #undef CONFIG_CMD_SOURCE
#endif
diff --git a/include/configs/mx1fs2.h b/include/configs/mx1fs2.h index a19eb78..cba0803 100644 --- a/include/configs/mx1fs2.h +++ b/include/configs/mx1fs2.h @@ -51,12 +51,12 @@
-#undef CONFIG_CMD_LOADS #undef CONFIG_CMD_CONSOLE -#undef CONFIG_CMD_AUTOSCRIPT +#undef CONFIG_CMD_DHCP +#undef CONFIG_CMD_LOADS #undef CONFIG_CMD_NET #undef CONFIG_CMD_PING -#undef CONFIG_CMD_DHCP +#undef CONFIG_CMD_SOURCE
/* diff --git a/include/configs/omap2420h4.h b/include/configs/omap2420h4.h index 983b5f2..13b89ac 100644 --- a/include/configs/omap2420h4.h +++ b/include/configs/omap2420h4.h @@ -135,7 +135,7 @@ #define CONFIG_CMD_I2C #define CONFIG_CMD_JFFS2
- #undef CONFIG_CMD_AUTOSCRIPT + #undef CONFIG_CMD_SOURCE #endif
diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h index 0f9344b..c20981c 100644 --- a/include/configs/omap3_beagle.h +++ b/include/configs/omap3_beagle.h @@ -174,7 +174,7 @@ "rootfstype=jffs2\0" \ "loadbootscript=fatload mmc 0 ${loadaddr} boot.scr\0" \ "bootscript=echo Running bootscript from mmc ...; " \ - "autoscr ${loadaddr}\0" \ + "source ${loadaddr}\0" \ "loaduimage=fatload mmc 0 ${loadaddr} uImage\0" \ "mmcboot=echo Booting from mmc ...; " \ "run mmcargs; " \ diff --git a/include/configs/omap3_evm.h b/include/configs/omap3_evm.h index f4498a9..db82899 100644 --- a/include/configs/omap3_evm.h +++ b/include/configs/omap3_evm.h @@ -167,7 +167,7 @@ "rootfstype=jffs2\0" \ "loadbootscript=fatload mmc 0 ${loadaddr} boot.scr\0" \ "bootscript=echo Running bootscript from mmc ...; " \ - "autoscr ${loadaddr}\0" \ + "source ${loadaddr}\0" \ "loaduimage=fatload mmc 0 ${loadaddr} uImage\0" \ "mmcboot=echo Booting from mmc ...; " \ "run mmcargs; " \ diff --git a/include/configs/omap3_overo.h b/include/configs/omap3_overo.h index dee0417..64cc1c4 100644 --- a/include/configs/omap3_overo.h +++ b/include/configs/omap3_overo.h @@ -161,7 +161,7 @@ "rootfstype=jffs2\0" \ "loadbootscript=fatload mmc 0 ${loadaddr} boot.scr\0" \ "bootscript=echo Running bootscript from mmc ...; " \ - "autoscr ${loadaddr}\0" \ + "source ${loadaddr}\0" \ "loaduimage=fatload mmc 0 ${loadaddr} uImage\0" \ "mmcboot=echo Booting from mmc ...; " \ "run mmcargs; " \ diff --git a/include/configs/omap3_pandora.h b/include/configs/omap3_pandora.h index 00c0374..592ec75 100644 --- a/include/configs/omap3_pandora.h +++ b/include/configs/omap3_pandora.h @@ -163,7 +163,7 @@ "rootfstype=jffs2\0" \ "loadbootscript=fatload mmc 0 ${loadaddr} boot.scr\0" \ "bootscript=echo Running bootscript from mmc ...; " \ - "autoscr ${loadaddr}\0" \ + "source ${loadaddr}\0" \ "loaduimage=fatload mmc 0 ${loadaddr} uImage\0" \ "mmcboot=echo Booting from mmc ...; " \ "run mmcargs; " \ diff --git a/include/configs/omap3_zoom1.h b/include/configs/omap3_zoom1.h index f8ae163..70ec036 100644 --- a/include/configs/omap3_zoom1.h +++ b/include/configs/omap3_zoom1.h @@ -171,7 +171,7 @@ "rootfstype=jffs2\0" \ "loadbootscript=fatload mmc 0 ${loadaddr} boot.scr\0" \ "bootscript=echo Running bootscript from mmc ...; " \ - "autoscr ${loadaddr}\0" \ + "source ${loadaddr}\0" \ "loaduimage=fatload mmc 0 ${loadaddr} uImage\0" \ "mmcboot=echo Booting from mmc ...; " \ "run mmcargs; " \ diff --git a/include/configs/sc3.h b/include/configs/sc3.h index 5b68ef9..97e1da2 100644 --- a/include/configs/sc3.h +++ b/include/configs/sc3.h @@ -122,7 +122,7 @@ "rootpath=/opt/eldk/ppc_4xx\0" \ "bootfile=/tftpboot/sc3/uImage\0" \ "u-boot=/tftpboot/sc3/u-boot.bin\0" \ - "setup=tftp 200000 /tftpboot/sc3/setup.img;autoscr 200000\0" \ + "setup=tftp 200000 /tftpboot/sc3/setup.img;source 200000\0" \ "kernel_addr=FFE08000\0" \ "" #undef CONFIG_BOOTCOMMAND @@ -186,20 +186,20 @@ #include <config_cmd_default.h>
-#define CONFIG_CMD_AUTOSCRIPT -#define CONFIG_CMD_PCI -#define CONFIG_CMD_IRQ -#define CONFIG_CMD_NET -#define CONFIG_CMD_MII -#define CONFIG_CMD_PING -#define CONFIG_CMD_NAND -#define CONFIG_CMD_JFFS2 -#define CONFIG_CMD_I2C -#define CONFIG_CMD_IDE +#define CONFIG_CMD_CACHE #define CONFIG_CMD_DATE #define CONFIG_CMD_DHCP -#define CONFIG_CMD_CACHE #define CONFIG_CMD_ELF +#define CONFIG_CMD_I2C +#define CONFIG_CMD_IDE +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_JFFS2 +#define CONFIG_CMD_MII +#define CONFIG_CMD_NAND +#define CONFIG_CMD_NET +#define CONFIG_CMD_PCI +#define CONFIG_CMD_PING +#define CONFIG_CMD_SOURCE
#undef CONFIG_WATCHDOG /* watchdog disabled */ diff --git a/include/configs/scb9328.h b/include/configs/scb9328.h index 5971df7..a038901 100644 --- a/include/configs/scb9328.h +++ b/include/configs/scb9328.h @@ -53,9 +53,9 @@ #define CONFIG_CMD_PING #define CONFIG_CMD_DHCP
-#undef CONFIG_CMD_LOADS #undef CONFIG_CMD_CONSOLE -#undef CONFIG_CMD_AUTOSCRIPT +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_SOURCE
/* diff --git a/include/configs/stxxtc.h b/include/configs/stxxtc.h index 5a5f772..147233d 100644 --- a/include/configs/stxxtc.h +++ b/include/configs/stxxtc.h @@ -68,7 +68,7 @@ "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}::off; " \ "bootm"
diff --git a/include/configs/vct.h b/include/configs/vct.h index 5371e2d..d202522 100644 --- a/include/configs/vct.h +++ b/include/configs/vct.h @@ -301,38 +301,38 @@ int vct_gpio_get(int pin); * (NOR/OneNAND) usage and Linux kernel booting. */ #if defined(CONFIG_VCT_SMALL_IMAGE) +#undef CONFIG_CMD_ASKENV +#undef CONFIG_CMD_BDI +#undef CONFIG_CMD_BEDBUG +#undef CONFIG_CMD_CACHE +#undef CONFIG_CMD_CONSOLE +#undef CONFIG_CMD_CRC32 +#undef CONFIG_CMD_DHCP +#undef CONFIG_CMD_EEPROM #undef CONFIG_CMD_EEPROM -#undef CONFIG_CMD_I2C -#undef CONFIG_CMD_NET -#undef CONFIG_CMD_PING -#undef CONFIG_CMD_SNTP #undef CONFIG_CMD_ELF -#undef CONFIG_CMD_CONSOLE -#undef CONFIG_CMD_CACHE -#undef CONFIG_CMD_BEDBUG -#undef CONFIG_CMD_AUTOSCRIPT +#undef CONFIG_CMD_FAT +#undef CONFIG_CMD_I2C +#undef CONFIG_CMD_I2C #undef CONFIG_CMD_IRQ #undef CONFIG_CMD_ITEST +#undef CONFIG_CMD_LOADB +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_LOADY #undef CONFIG_CMD_MII #undef CONFIG_CMD_MISC +#undef CONFIG_CMD_NET +#undef CONFIG_CMD_PING #undef CONFIG_CMD_REGINFO +#undef CONFIG_CMD_SNTP +#undef CONFIG_CMD_SOURCE #undef CONFIG_CMD_STRINGS #undef CONFIG_CMD_TERMINAL -#undef CONFIG_CMD_ASKENV -#undef CONFIG_CMD_CRC32 -#undef CONFIG_CMD_DHCP -#undef CONFIG_CMD_EEPROM -#undef CONFIG_CMD_I2C -#undef CONFIG_CMD_LOADB -#undef CONFIG_CMD_LOADS -#undef CONFIG_CMD_LOADY -#undef CONFIG_CMD_BDI #undef CONFIG_CMD_USB -#undef CONFIG_CMD_FAT
#undef CONFIG_DRIVER_SMC911X #undef CONFIG_SOFT_I2C -#undef CONFIG_AUTOSCRIPT +#undef CONFIG_SOURCE #undef CONFIG_SYS_LONGHELP #undef CONFIG_TIMESTAMP #endif /* CONFIG_VCT_SMALL_IMAGE */ diff --git a/include/configs/wepep250.h b/include/configs/wepep250.h index d0afd29..1d529b3 100644 --- a/include/configs/wepep250.h +++ b/include/configs/wepep250.h @@ -49,10 +49,10 @@ */ #include <config_cmd_default.h>
-#undef CONFIG_CMD_NET -#undef CONFIG_CMD_LOADS #undef CONFIG_CMD_CONSOLE -#undef CONFIG_CMD_AUTOSCRIPT +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_NET +#undef CONFIG_CMD_SOURCE
Changes since V1:
Applied.
