[U-Boot] [PATCH 1/2] pci: imx: Adjust the return value when imx_pcie_addr_valid() fails
When trying to access non-existent/unsupported PCI devices in imx_pcie_read_config(), when imx_pcie_addr_valid() fails it returns error code and fills in the result with 0xffffffff manually. But it really should return zero to upper layer codes.
Reported-by: Fabio Estevam fabio.estevam@nxp.com Signed-off-by: Bin Meng bmeng.cn@gmail.com Tested-by: Fabio Estevam fabio.estevam@nxp.com ---
drivers/pci/pcie_imx.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/pci/pcie_imx.c b/drivers/pci/pcie_imx.c index f1e189e..c14bb0a 100644 --- a/drivers/pci/pcie_imx.c +++ b/drivers/pci/pcie_imx.c @@ -381,7 +381,7 @@ static int imx_pcie_read_config(struct pci_controller *hose, pci_dev_t d, ret = imx_pcie_addr_valid(d); if (ret) { *val = 0xffffffff; - return ret; + return 0; }
va_address = get_bus_address(d, where);
When trying to access non-existent/unsupported PCI devices in ls_pcie_read_config(), when ls_pcie_addr_valid() fails it returns error code and fills in the result with 0xffffffff manually. But it really should return zero to upper layer codes.
Signed-off-by: Bin Meng bmeng.cn@gmail.com ---
drivers/pci/pcie_layerscape.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/pci/pcie_layerscape.c b/drivers/pci/pcie_layerscape.c index 58e88ae..99f9c83 100644 --- a/drivers/pci/pcie_layerscape.c +++ b/drivers/pci/pcie_layerscape.c @@ -314,7 +314,7 @@ static int ls_pcie_read_config(struct pci_controller *hose, pci_dev_t d,
if (ls_pcie_addr_valid(hose, d)) { *val = 0xffffffff; - return -EINVAL; + return 0; }
if (PCI_BUS(d) == hose->first_busno) {
Bin Meng
