[U-Boot] [PATCH v2 1/3] fdt: fix bcm283x dm-pre-reloc definitions
In commmit 143256b353 ("fdt: update bcm283x device tree sources to Linux 5.1-rc6 state") we delete the label for the node soc. As we don't need the to add the property dm-pre-reloc to this node, we can delete it fomr bcm283x-uboot.dtsi
Signed-off-by: Matthias Brugger mbrugger@suse.com
Changes in v2: - node soc, does not need a label - dm-pre-reloc not needed for node soc
arch/arm/dts/bcm283x-uboot.dtsi | 4 ---- 1 file changed, 4 deletions(-)
diff --git a/arch/arm/dts/bcm283x-uboot.dtsi b/arch/arm/dts/bcm283x-uboot.dtsi index 6cc1aa3f93..36548dad62 100644 --- a/arch/arm/dts/bcm283x-uboot.dtsi +++ b/arch/arm/dts/bcm283x-uboot.dtsi @@ -6,10 +6,6 @@ * (C) Copyright 2016 Fabian Vogt fvogt@suse.com */
-&soc { - u-boot,dm-pre-reloc; -}; - &uart0 { skip-init; u-boot,dm-pre-reloc;
U-Boot support on Raspberry Pi 4 relies on the device-tree provided by the firmware. The blob does not contain the U-Boot specific pre-loc-rel properties. The result is, that the U-Boot banner is not printed.
We fix this by setting the DM_FLAG_PRE_RELOC flag in the driver, if we rely on a device-tree provided by the firmware.
Changes in v2: - add DM_FLAG_PRE_RELOC for RPi4 case
drivers/pinctrl/broadcom/pinctrl-bcm283x.c | 2 +- drivers/serial/serial_bcm283x_mu.c | 2 +- drivers/serial/serial_bcm283x_pl011.c | 2 +- 3 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/pinctrl/broadcom/pinctrl-bcm283x.c b/drivers/pinctrl/broadcom/pinctrl-bcm283x.c index 3be080d29e..1bb91d6eed 100644 --- a/drivers/pinctrl/broadcom/pinctrl-bcm283x.c +++ b/drivers/pinctrl/broadcom/pinctrl-bcm283x.c @@ -148,7 +148,7 @@ U_BOOT_DRIVER(pinctrl_bcm283x) = { .priv_auto_alloc_size = sizeof(struct bcm283x_pinctrl_priv), .ops = &bcm283x_pinctrl_ops, .probe = bcm283x_pinctl_probe, -#if !CONFIG_IS_ENABLED(OF_CONTROL) +#if !CONFIG_IS_ENABLED(OF_CONTROL) || CONFIG_IS_ENABLED(OF_BOARD) .flags = DM_FLAG_PRE_RELOC, #endif }; diff --git a/drivers/serial/serial_bcm283x_mu.c b/drivers/serial/serial_bcm283x_mu.c index bd1d89ec83..a6ffc84b96 100644 --- a/drivers/serial/serial_bcm283x_mu.c +++ b/drivers/serial/serial_bcm283x_mu.c @@ -199,7 +199,7 @@ U_BOOT_DRIVER(serial_bcm283x_mu) = { .platdata_auto_alloc_size = sizeof(struct bcm283x_mu_serial_platdata), .probe = bcm283x_mu_serial_probe, .ops = &bcm283x_mu_serial_ops, -#if !CONFIG_IS_ENABLED(OF_CONTROL) +#if !CONFIG_IS_ENABLED(OF_CONTROL) || CONFIG_IS_ENABLED(OF_BOARD) .flags = DM_FLAG_PRE_RELOC, #endif .priv_auto_alloc_size = sizeof(struct bcm283x_mu_priv), diff --git a/drivers/serial/serial_bcm283x_pl011.c b/drivers/serial/serial_bcm283x_pl011.c index 2527bb8b1c..7d8ab7b716 100644 --- a/drivers/serial/serial_bcm283x_pl011.c +++ b/drivers/serial/serial_bcm283x_pl011.c @@ -90,7 +90,7 @@ U_BOOT_DRIVER(bcm283x_pl011_uart) = { .platdata_auto_alloc_size = sizeof(struct pl01x_serial_platdata), .probe = pl01x_serial_probe, .ops = &bcm283x_pl011_serial_ops, -#if !CONFIG_IS_ENABLED(OF_CONTROL) +#if !CONFIG_IS_ENABLED(OF_CONTROL) || CONFIG_IS_ENABLED(OF_BOARD) .flags = DM_FLAG_PRE_RELOC, #endif .priv_auto_alloc_size = sizeof(struct pl01x_priv),
Tested-by: Tom Rini trini@konsulko.com [RPi 3, 32b and 64b modes]
