[PATCH] fs/erofs: Introduce new features including ztailpacking, fragments and dedupe
This patch updates erofs driver code to catch up with the latest code of erofs_utils (commit e4939f9eaa177e05d697ace85d8dc283e25dc2ed).
LZMA will be supported in the separate patch later.
Signed-off-by: Yifan Zhao zhaoyifan@sjtu.edu.cn --- CI result here: https://github.com/u-boot/u-boot/pull/344
fs/erofs/data.c | 165 ++++++++++++++--------- fs/erofs/decompress.c | 32 ++++- fs/erofs/decompress.h | 3 + fs/erofs/erofs_fs.h | 301 +++++++++++++++++++++++------------------- fs/erofs/fs.c | 12 +- fs/erofs/internal.h | 119 ++++++++++++++--- fs/erofs/namei.c | 44 +++--- fs/erofs/super.c | 33 ++--- fs/erofs/zmap.c | 277 +++++++++++++++++++++++++------------- 9 files changed, 642 insertions(+), 344 deletions(-)
diff --git a/fs/erofs/data.c b/fs/erofs/data.c index 761896054c..f4b21d7917 100644 --- a/fs/erofs/data.c +++ b/fs/erofs/data.c @@ -12,23 +12,23 @@ static int erofs_map_blocks_flatmode(struct erofs_inode *inode, struct erofs_inode *vi = inode; bool tailendpacking = (vi->datalayout == EROFS_INODE_FLAT_INLINE);
- nblocks = DIV_ROUND_UP(inode->i_size, EROFS_BLKSIZ); + nblocks = BLK_ROUND_UP(inode->i_size); lastblk = nblocks - tailendpacking;
/* there is no hole in flatmode */ map->m_flags = EROFS_MAP_MAPPED;
- if (offset < blknr_to_addr(lastblk)) { - map->m_pa = blknr_to_addr(vi->u.i_blkaddr) + map->m_la; - map->m_plen = blknr_to_addr(lastblk) - offset; + if (offset < erofs_pos(lastblk)) { + map->m_pa = erofs_pos(vi->u.i_blkaddr) + map->m_la; + map->m_plen = erofs_pos(lastblk) - offset; } else if (tailendpacking) { /* 2 - inode inline B: inode, [xattrs], inline last blk... */ map->m_pa = iloc(vi->nid) + vi->inode_isize + vi->xattr_isize + erofs_blkoff(map->m_la); map->m_plen = inode->i_size - offset;
- /* inline data should be located in one meta block */ - if (erofs_blkoff(map->m_pa) + map->m_plen > PAGE_SIZE) { + /* inline data should be located in the same meta block */ + if (erofs_blkoff(map->m_pa) + map->m_plen > erofs_blksiz()) { erofs_err("inline data cross block boundary @ nid %" PRIu64, vi->nid); DBG_BUGON(1); @@ -55,7 +55,7 @@ int erofs_map_blocks(struct erofs_inode *inode, { struct erofs_inode *vi = inode; struct erofs_inode_chunk_index *idx; - u8 buf[EROFS_BLKSIZ]; + u8 buf[EROFS_MAX_BLOCK_SIZE]; u64 chunknr; unsigned int unit; erofs_off_t pos; @@ -87,7 +87,7 @@ int erofs_map_blocks(struct erofs_inode *inode,
map->m_la = chunknr << vi->u.chunkbits; map->m_plen = min_t(erofs_off_t, 1UL << vi->u.chunkbits, - roundup(inode->i_size - map->m_la, EROFS_BLKSIZ)); + roundup(inode->i_size - map->m_la, erofs_blksiz()));
/* handle block map */ if (!(vi->u.chunkformat & EROFS_CHUNK_FORMAT_INDEXES)) { @@ -96,7 +96,7 @@ int erofs_map_blocks(struct erofs_inode *inode, if (le32_to_cpu(*blkaddr) == EROFS_NULL_ADDR) { map->m_flags = 0; } else { - map->m_pa = blknr_to_addr(le32_to_cpu(*blkaddr)); + map->m_pa = erofs_pos(le32_to_cpu(*blkaddr)); map->m_flags = EROFS_MAP_MAPPED; } goto out; @@ -110,7 +110,7 @@ int erofs_map_blocks(struct erofs_inode *inode, default: map->m_deviceid = le16_to_cpu(idx->device_id) & sbi.device_id_mask; - map->m_pa = blknr_to_addr(le32_to_cpu(idx->blkaddr)); + map->m_pa = erofs_pos(le32_to_cpu(idx->blkaddr)); map->m_flags = EROFS_MAP_MAPPED; break; } @@ -119,23 +119,23 @@ out: return err; }
-int erofs_map_dev(struct erofs_sb_info *sbi, struct erofs_map_dev *map) +int erofs_map_dev(struct erofs_map_dev *map) { struct erofs_device_info *dif; int id;
if (map->m_deviceid) { - if (sbi->extra_devices < map->m_deviceid) + if (sbi.extra_devices < map->m_deviceid) return -ENODEV; - } else if (sbi->extra_devices) { - for (id = 0; id < sbi->extra_devices; ++id) { + } else if (sbi.extra_devices) { + for (id = 0; id < sbi.extra_devices; ++id) { erofs_off_t startoff, length;
- dif = sbi->devs + id; + dif = sbi.devs + id; if (!dif->mapped_blkaddr) continue; - startoff = blknr_to_addr(dif->mapped_blkaddr); - length = blknr_to_addr(dif->blocks); + startoff = erofs_pos(dif->mapped_blkaddr); + length = erofs_pos(dif->blocks);
if (map->m_pa >= startoff && map->m_pa < startoff + length) { @@ -147,19 +147,38 @@ int erofs_map_dev(struct erofs_sb_info *sbi, struct erofs_map_dev *map) return 0; }
+int erofs_read_one_data(struct erofs_map_blocks *map, char *buffer, u64 offset, + size_t len) +{ + struct erofs_map_dev mdev; + int ret; + + mdev = (struct erofs_map_dev) { + .m_deviceid = map->m_deviceid, + .m_pa = map->m_pa, + }; + ret = erofs_map_dev(&mdev); + if (ret) + return ret; + + ret = erofs_dev_read(mdev.m_deviceid, buffer, mdev.m_pa + offset, len); + if (ret < 0) + return -EIO; + return 0; +} + static int erofs_read_raw_data(struct erofs_inode *inode, char *buffer, erofs_off_t size, erofs_off_t offset) { struct erofs_map_blocks map = { .index = UINT_MAX, }; - struct erofs_map_dev mdev; int ret; erofs_off_t ptr = offset;
while (ptr < offset + size) { char *const estart = buffer + ptr - offset; - erofs_off_t eend; + erofs_off_t eend, moff = 0;
map.m_la = ptr; ret = erofs_map_blocks(inode, &map, 0); @@ -168,14 +187,6 @@ static int erofs_read_raw_data(struct erofs_inode *inode, char *buffer,
DBG_BUGON(map.m_plen != map.m_llen);
- mdev = (struct erofs_map_dev) { - .m_deviceid = map.m_deviceid, - .m_pa = map.m_pa, - }; - ret = erofs_map_dev(&sbi, &mdev); - if (ret) - return ret; - /* trim extent */ eend = min(offset + size, map.m_la + map.m_llen); DBG_BUGON(ptr < map.m_la); @@ -193,19 +204,73 @@ static int erofs_read_raw_data(struct erofs_inode *inode, char *buffer, }
if (ptr > map.m_la) { - mdev.m_pa += ptr - map.m_la; + moff = ptr - map.m_la; map.m_la = ptr; }
- ret = erofs_dev_read(mdev.m_deviceid, estart, mdev.m_pa, - eend - map.m_la); - if (ret < 0) - return -EIO; + ret = erofs_read_one_data(&map, estart, moff, eend - map.m_la); + if (ret) + return ret; ptr = eend; } return 0; }
+int z_erofs_read_one_data(struct erofs_inode *inode, + struct erofs_map_blocks *map, char *raw, char *buffer, + erofs_off_t skip, erofs_off_t length, bool trimmed) +{ + struct erofs_map_dev mdev; + int ret = 0; + + if (map->m_flags & EROFS_MAP_FRAGMENT) { + struct erofs_inode packed_inode = { + .nid = sbi.packed_nid, + }; + + ret = erofs_read_inode_from_disk(&packed_inode); + if (ret) { + erofs_err("failed to read packed inode from disk"); + return ret; + } + + return erofs_pread(&packed_inode, buffer, length - skip, + inode->fragmentoff + skip); + } + + /* no device id here, thus it will always succeed */ + mdev = (struct erofs_map_dev) { + .m_pa = map->m_pa, + }; + ret = erofs_map_dev(&mdev); + if (ret) { + DBG_BUGON(1); + return ret; + } + + ret = erofs_dev_read(mdev.m_deviceid, raw, mdev.m_pa, map->m_plen); + if (ret < 0) + return ret; + + ret = z_erofs_decompress(&(struct z_erofs_decompress_req) { + .in = raw, + .out = buffer, + .decodedskip = skip, + .interlaced_offset = + map->m_algorithmformat == Z_EROFS_COMPRESSION_INTERLACED ? + erofs_blkoff(map->m_la) : 0, + .inputsize = map->m_plen, + .decodedlength = length, + .alg = map->m_algorithmformat, + .partial_decoding = trimmed ? true : + !(map->m_flags & EROFS_MAP_FULL_MAPPED) || + (map->m_flags & EROFS_MAP_PARTIAL_REF), + }); + if (ret < 0) + return ret; + return 0; +} + static int z_erofs_read_data(struct erofs_inode *inode, char *buffer, erofs_off_t size, erofs_off_t offset) { @@ -213,8 +278,7 @@ static int z_erofs_read_data(struct erofs_inode *inode, char *buffer, struct erofs_map_blocks map = { .index = UINT_MAX, }; - struct erofs_map_dev mdev; - bool partial; + bool trimmed; unsigned int bufsize = 0; char *raw = NULL; int ret = 0; @@ -227,27 +291,17 @@ static int z_erofs_read_data(struct erofs_inode *inode, char *buffer, if (ret) break;
- /* no device id here, thus it will always succeed */ - mdev = (struct erofs_map_dev) { - .m_pa = map.m_pa, - }; - ret = erofs_map_dev(&sbi, &mdev); - if (ret) { - DBG_BUGON(1); - break; - } - /* * trim to the needed size if the returned extent is quite * larger than requested, and set up partial flag as well. */ if (end < map.m_la + map.m_llen) { length = end - map.m_la; - partial = true; + trimmed = true; } else { DBG_BUGON(end != map.m_la + map.m_llen); length = map.m_llen; - partial = !(map.m_flags & EROFS_MAP_FULL_MAPPED); + trimmed = false; }
if (map.m_la < offset) { @@ -272,19 +326,10 @@ static int z_erofs_read_data(struct erofs_inode *inode, char *buffer, break; } } - ret = erofs_dev_read(mdev.m_deviceid, raw, mdev.m_pa, map.m_plen); - if (ret < 0) - break;
- ret = z_erofs_decompress(&(struct z_erofs_decompress_req) { - .in = raw, - .out = buffer + end - offset, - .decodedskip = skip, - .inputsize = map.m_plen, - .decodedlength = length, - .alg = map.m_algorithmformat, - .partial_decoding = partial - }); + ret = z_erofs_read_one_data(inode, &map, raw, + buffer + end - offset, skip, length, + trimmed); if (ret < 0) break; } @@ -301,8 +346,8 @@ int erofs_pread(struct erofs_inode *inode, char *buf, case EROFS_INODE_FLAT_INLINE: case EROFS_INODE_CHUNK_BASED: return erofs_read_raw_data(inode, buf, count, offset); - case EROFS_INODE_FLAT_COMPRESSION_LEGACY: - case EROFS_INODE_FLAT_COMPRESSION: + case EROFS_INODE_COMPRESSED_FULL: + case EROFS_INODE_COMPRESSED_COMPACT: return z_erofs_read_data(inode, buf, count, offset); default: break; diff --git a/fs/erofs/decompress.c b/fs/erofs/decompress.c index 2be3b844cf..e04e5c34a8 100644 --- a/fs/erofs/decompress.c +++ b/fs/erofs/decompress.c @@ -15,8 +15,8 @@ static int z_erofs_decompress_lz4(struct z_erofs_decompress_req *rq) if (erofs_sb_has_lz4_0padding()) { support_0padding = true;
- while (!src[inputmargin & ~PAGE_MASK]) - if (!(++inputmargin & ~PAGE_MASK)) + while (!src[inputmargin & (erofs_blksiz() - 1)]) + if (!(++inputmargin & (erofs_blksiz() - 1))) break;
if (inputmargin >= rq->inputsize) @@ -40,6 +40,9 @@ static int z_erofs_decompress_lz4(struct z_erofs_decompress_req *rq) rq->decodedlength);
if (ret != (int)rq->decodedlength) { + erofs_err("failed to %s decompress %d in[%u, %u] out[%u]", + rq->partial_decoding ? "partial" : "full", + ret, rq->inputsize, inputmargin, rq->decodedlength); ret = -EIO; goto out; } @@ -58,13 +61,30 @@ out:
int z_erofs_decompress(struct z_erofs_decompress_req *rq) { - if (rq->alg == Z_EROFS_COMPRESSION_SHIFTED) { - if (rq->inputsize != EROFS_BLKSIZ) + if (rq->alg == Z_EROFS_COMPRESSION_INTERLACED) { + unsigned int count, rightpart, skip; + + /* XXX: should support inputsize >= erofs_blksiz() later */ + if (rq->inputsize > erofs_blksiz()) return -EFSCORRUPTED;
- DBG_BUGON(rq->decodedlength > EROFS_BLKSIZ); - DBG_BUGON(rq->decodedlength < rq->decodedskip); + if (rq->decodedlength > erofs_blksiz()) + return -EFSCORRUPTED; + + if (rq->decodedlength < rq->decodedskip) + return -EFSCORRUPTED;
+ count = rq->decodedlength - rq->decodedskip; + skip = erofs_blkoff(rq->interlaced_offset + rq->decodedskip); + rightpart = min(erofs_blksiz() - skip, count); + memcpy(rq->out, rq->in + skip, rightpart); + memcpy(rq->out + rightpart, rq->in, count - rightpart); + return 0; + } else if (rq->alg == Z_EROFS_COMPRESSION_SHIFTED) { + if (rq->decodedlength > rq->inputsize) + return -EFSCORRUPTED; + + DBG_BUGON(rq->decodedlength < rq->decodedskip); memcpy(rq->out, rq->in + rq->decodedskip, rq->decodedlength - rq->decodedskip); return 0; diff --git a/fs/erofs/decompress.h b/fs/erofs/decompress.h index 81d5fb84f6..4752f77950 100644 --- a/fs/erofs/decompress.h +++ b/fs/erofs/decompress.h @@ -14,6 +14,9 @@ struct z_erofs_decompress_req { unsigned int decodedskip; unsigned int inputsize, decodedlength;
+ /* cut point of interlaced uncompressed data */ + unsigned int interlaced_offset; + /* indicate the algorithm will be used for decompression */ unsigned int alg; bool partial_decoding; diff --git a/fs/erofs/erofs_fs.h b/fs/erofs/erofs_fs.h index 6b62c7a4f5..158e2c68a1 100644 --- a/fs/erofs/erofs_fs.h +++ b/fs/erofs/erofs_fs.h @@ -3,7 +3,7 @@ * EROFS (Enhanced ROM File System) on-disk format definition * * Copyright (C) 2017-2018 HUAWEI, Inc. - * http://www.huawei.com/ + * https://www.huawei.com/ * Copyright (C) 2021, Alibaba Cloud */ #ifndef __EROFS_FS_H @@ -18,33 +18,41 @@ #define EROFS_SUPER_MAGIC_V1 0xE0F5E1E2 #define EROFS_SUPER_OFFSET 1024
-#define EROFS_FEATURE_COMPAT_SB_CHKSUM 0x00000001 +#define EROFS_FEATURE_COMPAT_SB_CHKSUM 0x00000001 +#define EROFS_FEATURE_COMPAT_MTIME 0x00000002
/* * Any bits that aren't in EROFS_ALL_FEATURE_INCOMPAT should * be incompatible with this kernel version. */ -#define EROFS_FEATURE_INCOMPAT_LZ4_0PADDING 0x00000001 +#define EROFS_FEATURE_INCOMPAT_ZERO_PADDING 0x00000001 #define EROFS_FEATURE_INCOMPAT_COMPR_CFGS 0x00000002 #define EROFS_FEATURE_INCOMPAT_BIG_PCLUSTER 0x00000002 #define EROFS_FEATURE_INCOMPAT_CHUNKED_FILE 0x00000004 #define EROFS_FEATURE_INCOMPAT_DEVICE_TABLE 0x00000008 +#define EROFS_FEATURE_INCOMPAT_COMPR_HEAD2 0x00000008 +#define EROFS_FEATURE_INCOMPAT_ZTAILPACKING 0x00000010 +#define EROFS_FEATURE_INCOMPAT_FRAGMENTS 0x00000020 +#define EROFS_FEATURE_INCOMPAT_DEDUPE 0x00000020 +#define EROFS_FEATURE_INCOMPAT_XATTR_PREFIXES 0x00000040 #define EROFS_ALL_FEATURE_INCOMPAT \ - (EROFS_FEATURE_INCOMPAT_LZ4_0PADDING | \ + (EROFS_FEATURE_INCOMPAT_ZERO_PADDING | \ EROFS_FEATURE_INCOMPAT_COMPR_CFGS | \ EROFS_FEATURE_INCOMPAT_BIG_PCLUSTER | \ EROFS_FEATURE_INCOMPAT_CHUNKED_FILE | \ - EROFS_FEATURE_INCOMPAT_DEVICE_TABLE) + EROFS_FEATURE_INCOMPAT_DEVICE_TABLE | \ + EROFS_FEATURE_INCOMPAT_COMPR_HEAD2 | \ + EROFS_FEATURE_INCOMPAT_ZTAILPACKING | \ + EROFS_FEATURE_INCOMPAT_FRAGMENTS | \ + EROFS_FEATURE_INCOMPAT_DEDUPE | \ + EROFS_FEATURE_INCOMPAT_XATTR_PREFIXES)
#define EROFS_SB_EXTSLOT_SIZE 16
struct erofs_deviceslot { - union { - u8 uuid[16]; /* used for device manager later */ - u8 userdata[64]; /* digest(sha256), etc. */ - } u; - __le32 blocks; /* total fs blocks of this device */ - __le32 mapped_blkaddr; /* map starting at mapped_blkaddr */ + u8 tag[64]; /* digest(sha256), etc. */ + __le32 blocks; /* total fs blocks of this device */ + __le32 mapped_blkaddr; /* map starting at mapped_blkaddr */ u8 reserved[56]; };
@@ -55,14 +63,14 @@ struct erofs_super_block { __le32 magic; /* file system magic number */ __le32 checksum; /* crc32c(super_block) */ __le32 feature_compat; - __u8 blkszbits; /* support block_size == PAGE_SIZE only */ + __u8 blkszbits; /* filesystem block size in bit shift */ __u8 sb_extslots; /* superblock size = 128 + sb_extslots * 16 */
__le16 root_nid; /* nid of root directory */ __le64 inos; /* total valid ino # (== f_files - f_favail) */
- __le64 build_time; /* inode v1 time derivation */ - __le32 build_time_nsec; /* inode v1 time derivation in nano scale */ + __le64 build_time; /* compact inode time derivation */ + __le32 build_time_nsec; /* compact inode time derivation in ns scale */ __le32 blocks; /* used for statfs */ __le32 meta_blkaddr; /* start block address of metadata area */ __le32 xattr_blkaddr; /* start block address of shared xattr area */ @@ -77,39 +85,38 @@ struct erofs_super_block { } __packed u1; __le16 extra_devices; /* # of devices besides the primary device */ __le16 devt_slotoff; /* startoff = devt_slotoff * devt_slotsize */ - __u8 reserved2[38]; + __u8 dirblkbits; /* directory block size in bit shift */ + __u8 xattr_prefix_count; /* # of long xattr name prefixes */ + __le32 xattr_prefix_start; /* start of long xattr prefixes */ + __le64 packed_nid; /* nid of the special packed inode */ + __u8 reserved2[24]; };
/* - * erofs inode datalayout (i_format in on-disk inode): - * 0 - inode plain without inline data A: - * inode, [xattrs], ... | ... | no-holed data - * 1 - inode VLE compression B (legacy): - * inode, [xattrs], extents ... | ... - * 2 - inode plain with inline data C: - * inode, [xattrs], last_inline_data, ... | ... | no-holed data - * 3 - inode compression D: - * inode, [xattrs], map_header, extents ... | ... - * 4 - inode chunk-based E: - * inode, [xattrs], chunk indexes ... | ... + * EROFS inode datalayout (i_format in on-disk inode): + * 0 - uncompressed flat inode without tail-packing inline data: + * 1 - compressed inode with non-compact indexes: + * 2 - uncompressed flat inode with tail-packing inline data: + * 3 - compressed inode with compact indexes: + * 4 - chunk-based inode with (optional) multi-device support: * 5~7 - reserved */ enum { EROFS_INODE_FLAT_PLAIN = 0, - EROFS_INODE_FLAT_COMPRESSION_LEGACY = 1, + EROFS_INODE_COMPRESSED_FULL = 1, EROFS_INODE_FLAT_INLINE = 2, - EROFS_INODE_FLAT_COMPRESSION = 3, + EROFS_INODE_COMPRESSED_COMPACT = 3, EROFS_INODE_CHUNK_BASED = 4, EROFS_INODE_DATALAYOUT_MAX };
static inline bool erofs_inode_is_data_compressed(unsigned int datamode) { - return datamode == EROFS_INODE_FLAT_COMPRESSION || - datamode == EROFS_INODE_FLAT_COMPRESSION_LEGACY; + return datamode == EROFS_INODE_COMPRESSED_COMPACT || + datamode == EROFS_INODE_COMPRESSED_FULL; }
-/* bit definitions of inode i_advise */ +/* bit definitions of inode i_format */ #define EROFS_I_VERSION_BITS 1 #define EROFS_I_DATALAYOUT_BITS 3
@@ -127,11 +134,30 @@ static inline bool erofs_inode_is_data_compressed(unsigned int datamode) #define EROFS_CHUNK_FORMAT_ALL \ (EROFS_CHUNK_FORMAT_BLKBITS_MASK | EROFS_CHUNK_FORMAT_INDEXES)
+/* 32-byte on-disk inode */ +#define EROFS_INODE_LAYOUT_COMPACT 0 +/* 64-byte on-disk inode */ +#define EROFS_INODE_LAYOUT_EXTENDED 1 + struct erofs_inode_chunk_info { __le16 format; /* chunk blkbits, etc. */ __le16 reserved; };
+union erofs_inode_i_u { + /* total compressed blocks for compressed inodes */ + __le32 compressed_blocks; + + /* block address for uncompressed flat inodes */ + __le32 raw_blkaddr; + + /* for device files, used to indicate old/new device # */ + __le32 rdev; + + /* for chunk-based files, it contains the summary info */ + struct erofs_inode_chunk_info c; +}; + /* 32-byte reduced form of an ondisk inode */ struct erofs_inode_compact { __le16 i_format; /* inode format hints */ @@ -142,28 +168,14 @@ struct erofs_inode_compact { __le16 i_nlink; __le32 i_size; __le32 i_reserved; - union { - /* file total compressed blocks for data mapping 1 */ - __le32 compressed_blocks; - __le32 raw_blkaddr; + union erofs_inode_i_u i_u;
- /* for device files, used to indicate old/new device # */ - __le32 rdev; - - /* for chunk-based files, it contains the summary info */ - struct erofs_inode_chunk_info c; - } i_u; - __le32 i_ino; /* only used for 32-bit stat compatibility */ + __le32 i_ino; /* only used for 32-bit stat compatibility */ __le16 i_uid; __le16 i_gid; __le32 i_reserved2; };
-/* 32 bytes on-disk inode */ -#define EROFS_INODE_LAYOUT_COMPACT 0 -/* 64 bytes on-disk inode */ -#define EROFS_INODE_LAYOUT_EXTENDED 1 - /* 64-byte complete form of an ondisk inode */ struct erofs_inode_extended { __le16 i_format; /* inode format hints */ @@ -173,33 +185,17 @@ struct erofs_inode_extended { __le16 i_mode; __le16 i_reserved; __le64 i_size; - union { - /* file total compressed blocks for data mapping 1 */ - __le32 compressed_blocks; - __le32 raw_blkaddr; - - /* for device files, used to indicate old/new device # */ - __le32 rdev; - - /* for chunk-based files, it contains the summary info */ - struct erofs_inode_chunk_info c; - } i_u; - - /* only used for 32-bit stat compatibility */ - __le32 i_ino; + union erofs_inode_i_u i_u;
+ __le32 i_ino; /* only used for 32-bit stat compatibility */ __le32 i_uid; __le32 i_gid; - __le64 i_ctime; - __le32 i_ctime_nsec; + __le64 i_mtime; + __le32 i_mtime_nsec; __le32 i_nlink; __u8 i_reserved2[16]; };
-#define EROFS_MAX_SHARED_XATTRS (128) -/* h_shared_count between 129 ... 255 are special # */ -#define EROFS_SHARED_XATTR_EXTENT (255) - /* * inline xattrs (n == i_xattr_icount): * erofs_xattr_ibody_header(1) + (n - 1) * 4 bytes @@ -226,6 +222,13 @@ struct erofs_xattr_ibody_header { #define EROFS_XATTR_INDEX_LUSTRE 5 #define EROFS_XATTR_INDEX_SECURITY 6
+/* + * bit 7 of e_name_index is set when it refers to a long xattr name prefix, + * while the remained lower bits represent the index of the prefix. + */ +#define EROFS_XATTR_LONG_PREFIX 0x80 +#define EROFS_XATTR_LONG_PREFIX_MASK 0x7f + /* xattr entry (for both inline & shared xattrs) */ struct erofs_xattr_entry { __u8 e_name_len; /* length of name */ @@ -235,6 +238,12 @@ struct erofs_xattr_entry { char e_name[0]; /* attribute name */ };
+/* long xattr name prefix */ +struct erofs_xattr_long_prefix { + __u8 base_index; /* short xattr name prefix index */ + char infix[0]; /* infix apart from short prefix */ +}; + static inline unsigned int erofs_xattr_ibody_size(__le16 i_xattr_icount) { if (!i_xattr_icount) @@ -265,6 +274,29 @@ struct erofs_inode_chunk_index { __le32 blkaddr; /* start block address of this inode chunk */ };
+/* dirent sorts in alphabet order, thus we can do binary search */ +struct erofs_dirent { + __le64 nid; /* node number */ + __le16 nameoff; /* start offset of file name */ + __u8 file_type; /* file type */ + __u8 reserved; /* reserved */ +} __packed; + +/* file types used in inode_info->flags */ +enum { + EROFS_FT_UNKNOWN, + EROFS_FT_REG_FILE, + EROFS_FT_DIR, + EROFS_FT_CHRDEV, + EROFS_FT_BLKDEV, + EROFS_FT_FIFO, + EROFS_FT_SOCK, + EROFS_FT_SYMLINK, + EROFS_FT_MAX +}; + +#define EROFS_NAME_LEN 255 + /* maximum supported size of a physical compression cluster */ #define Z_EROFS_PCLUSTER_MAX_SIZE (1024 * 1024)
@@ -275,7 +307,7 @@ enum { Z_EROFS_COMPRESSION_MAX };
-#define Z_EROFS_ALL_COMPR_ALGS (1 << (Z_EROFS_COMPRESSION_MAX - 1)) +#define Z_EROFS_ALL_COMPR_ALGS ((1 << Z_EROFS_COMPRESSION_MAX) - 1)
/* 14 bytes (+ length field = 16 bytes) */ struct z_erofs_lz4_cfgs { @@ -290,6 +322,7 @@ struct z_erofs_lzma_cfgs { __le16 format; u8 reserved[8]; } __packed; + #define Z_EROFS_LZMA_MAX_DICT_SIZE (8 * Z_EROFS_PCLUSTER_MAX_SIZE)
/* @@ -298,13 +331,28 @@ struct z_erofs_lzma_cfgs { * (4B) + 2B + (4B) if compacted 2B is on. * bit 1 : HEAD1 big pcluster (0 - off; 1 - on) * bit 2 : HEAD2 big pcluster (0 - off; 1 - on) + * bit 3 : tailpacking inline pcluster (0 - off; 1 - on) + * bit 4 : interlaced plain pcluster (0 - off; 1 - on) + * bit 5 : fragment pcluster (0 - off; 1 - on) */ #define Z_EROFS_ADVISE_COMPACTED_2B 0x0001 #define Z_EROFS_ADVISE_BIG_PCLUSTER_1 0x0002 #define Z_EROFS_ADVISE_BIG_PCLUSTER_2 0x0004 +#define Z_EROFS_ADVISE_INLINE_PCLUSTER 0x0008 +#define Z_EROFS_ADVISE_INTERLACED_PCLUSTER 0x0010 +#define Z_EROFS_ADVISE_FRAGMENT_PCLUSTER 0x0020
+#define Z_EROFS_FRAGMENT_INODE_BIT 7 struct z_erofs_map_header { - __le32 h_reserved1; + union { + /* fragment data offset in the packed inode */ + __le32 h_fragmentoff; + struct { + __le16 h_reserved1; + /* indicates the encoded size of tailpacking data */ + __le16 h_idata_size; + }; + }; __le16 h_advise; /* * bit 0-3 : algorithm type of head 1 (logical cluster type 01); @@ -313,107 +361,85 @@ struct z_erofs_map_header { __u8 h_algorithmtype; /* * bit 0-2 : logical cluster bits - 12, e.g. 0 for 4096; - * bit 3-7 : reserved. + * bit 3-6 : reserved; + * bit 7 : move the whole file into packed inode or not. */ __u8 h_clusterbits; };
-#define Z_EROFS_VLE_LEGACY_HEADER_PADDING 8 - /* - * Fixed-sized output compression ondisk Logical Extent cluster type: - * 0 - literal (uncompressed) cluster - * 1 - compressed cluster (for the head logical cluster) - * 2 - compressed cluster (for the other logical clusters) + * On-disk logical cluster type: + * 0 - literal (uncompressed) lcluster + * 1,3 - compressed lcluster (for HEAD lclusters) + * 2 - compressed lcluster (for NONHEAD lclusters) * * In detail, - * 0 - literal (uncompressed) cluster, + * 0 - literal (uncompressed) lcluster, * di_advise = 0 - * di_clusterofs = the literal data offset of the cluster - * di_blkaddr = the blkaddr of the literal cluster + * di_clusterofs = the literal data offset of the lcluster + * di_blkaddr = the blkaddr of the literal pcluster * - * 1 - compressed cluster (for the head logical cluster) - * di_advise = 1 - * di_clusterofs = the decompressed data offset of the cluster - * di_blkaddr = the blkaddr of the compressed cluster + * 1,3 - compressed lcluster (for HEAD lclusters) + * di_advise = 1 or 3 + * di_clusterofs = the decompressed data offset of the lcluster + * di_blkaddr = the blkaddr of the compressed pcluster * - * 2 - compressed cluster (for the other logical clusters) + * 2 - compressed lcluster (for NONHEAD lclusters) * di_advise = 2 * di_clusterofs = - * the decompressed data offset in its own head cluster - * di_u.delta[0] = distance to its corresponding head cluster - * di_u.delta[1] = distance to its corresponding tail cluster - * (di_advise could be 0, 1 or 2) + * the decompressed data offset in its own HEAD lcluster + * di_u.delta[0] = distance to this HEAD lcluster + * di_u.delta[1] = distance to the next HEAD lcluster */ enum { - Z_EROFS_VLE_CLUSTER_TYPE_PLAIN = 0, - Z_EROFS_VLE_CLUSTER_TYPE_HEAD = 1, - Z_EROFS_VLE_CLUSTER_TYPE_NONHEAD = 2, - Z_EROFS_VLE_CLUSTER_TYPE_RESERVED = 3, - Z_EROFS_VLE_CLUSTER_TYPE_MAX + Z_EROFS_LCLUSTER_TYPE_PLAIN = 0, + Z_EROFS_LCLUSTER_TYPE_HEAD1 = 1, + Z_EROFS_LCLUSTER_TYPE_NONHEAD = 2, + Z_EROFS_LCLUSTER_TYPE_HEAD2 = 3, + Z_EROFS_LCLUSTER_TYPE_MAX };
-#define Z_EROFS_VLE_DI_CLUSTER_TYPE_BITS 2 -#define Z_EROFS_VLE_DI_CLUSTER_TYPE_BIT 0 +#define Z_EROFS_LI_LCLUSTER_TYPE_BITS 2 +#define Z_EROFS_LI_LCLUSTER_TYPE_BIT 0 + +/* (noncompact only, HEAD) This pcluster refers to partial decompressed data */ +#define Z_EROFS_LI_PARTIAL_REF (1 << 15)
/* * D0_CBLKCNT will be marked _only_ at the 1st non-head lcluster to store the * compressed block count of a compressed extent (in logical clusters, aka. * block count of a pcluster). */ -#define Z_EROFS_VLE_DI_D0_CBLKCNT (1 << 11) +#define Z_EROFS_LI_D0_CBLKCNT (1 << 11)
-struct z_erofs_vle_decompressed_index { +struct z_erofs_lcluster_index { __le16 di_advise; - /* where to decompress in the head cluster */ + /* where to decompress in the head lcluster */ __le16 di_clusterofs;
union { - /* for the head cluster */ + /* for the HEAD lclusters */ __le32 blkaddr; /* - * for the rest clusters - * eg. for 4k page-sized cluster, maximum 4K*64k = 256M) - * [0] - pointing to the head cluster - * [1] - pointing to the tail cluster + * for the NONHEAD lclusters + * [0] - distance to its HEAD lcluster + * [1] - distance to the next HEAD lcluster */ __le16 delta[2]; } di_u; };
-#define Z_EROFS_VLE_LEGACY_INDEX_ALIGN(size) \ - (round_up(size, sizeof(struct z_erofs_vle_decompressed_index)) + \ - sizeof(struct z_erofs_map_header) + Z_EROFS_VLE_LEGACY_HEADER_PADDING) - -#define Z_EROFS_VLE_EXTENT_ALIGN(size) round_up(size, \ - sizeof(struct z_erofs_vle_decompressed_index)) - -/* dirent sorts in alphabet order, thus we can do binary search */ -struct erofs_dirent { - __le64 nid; /* node number */ - __le16 nameoff; /* start offset of file name */ - __u8 file_type; /* file type */ - __u8 reserved; /* reserved */ -} __packed; - -/* file types used in inode_info->flags */ -enum { - EROFS_FT_UNKNOWN, - EROFS_FT_REG_FILE, - EROFS_FT_DIR, - EROFS_FT_CHRDEV, - EROFS_FT_BLKDEV, - EROFS_FT_FIFO, - EROFS_FT_SOCK, - EROFS_FT_SYMLINK, - EROFS_FT_MAX -}; - -#define EROFS_NAME_LEN 255 +#define Z_EROFS_FULL_INDEX_ALIGN(end) \ + (round_up(end, 8) + sizeof(struct z_erofs_map_header) + 8)
/* check the EROFS on-disk layout strictly at compile time */ static inline void erofs_check_ondisk_layout_definitions(void) { + const __le64 fmh __maybe_unused = + *(__le64 *)&(struct z_erofs_map_header) { + .h_clusterbits = 1 << Z_EROFS_FRAGMENT_INODE_BIT + }; + BUILD_BUG_ON(sizeof(struct erofs_super_block) != 128); BUILD_BUG_ON(sizeof(struct erofs_inode_compact) != 32); BUILD_BUG_ON(sizeof(struct erofs_inode_extended) != 64); @@ -422,15 +448,18 @@ static inline void erofs_check_ondisk_layout_definitions(void) BUILD_BUG_ON(sizeof(struct erofs_inode_chunk_info) != 4); BUILD_BUG_ON(sizeof(struct erofs_inode_chunk_index) != 8); BUILD_BUG_ON(sizeof(struct z_erofs_map_header) != 8); - BUILD_BUG_ON(sizeof(struct z_erofs_vle_decompressed_index) != 8); + BUILD_BUG_ON(sizeof(struct z_erofs_lcluster_index) != 8); BUILD_BUG_ON(sizeof(struct erofs_dirent) != 12); /* keep in sync between 2 index structures for better extendibility */ BUILD_BUG_ON(sizeof(struct erofs_inode_chunk_index) != - sizeof(struct z_erofs_vle_decompressed_index)); + sizeof(struct z_erofs_lcluster_index)); BUILD_BUG_ON(sizeof(struct erofs_deviceslot) != 128);
- BUILD_BUG_ON(BIT(Z_EROFS_VLE_DI_CLUSTER_TYPE_BITS) < - Z_EROFS_VLE_CLUSTER_TYPE_MAX - 1); + BUILD_BUG_ON(BIT(Z_EROFS_LI_LCLUSTER_TYPE_BITS) < + Z_EROFS_LCLUSTER_TYPE_MAX - 1); + /* exclude old compiler versions like gcc 7.5.0 */ + BUILD_BUG_ON(__builtin_constant_p(fmh) ? + fmh != cpu_to_le64(1ULL << 63) : 0); }
#endif diff --git a/fs/erofs/fs.c b/fs/erofs/fs.c index 89269750f8..7bd2e8fcfc 100644 --- a/fs/erofs/fs.c +++ b/fs/erofs/fs.c @@ -25,8 +25,8 @@ int erofs_dev_read(int device_id, void *buf, u64 offset, size_t len)
int erofs_blk_read(void *buf, erofs_blk_t start, u32 nblocks) { - return erofs_dev_read(0, buf, blknr_to_addr(start), - blknr_to_addr(nblocks)); + return erofs_dev_read(0, buf, erofs_pos(start), + erofs_pos(nblocks)); }
int erofs_probe(struct blk_desc *fs_dev_desc, @@ -52,7 +52,7 @@ struct erofs_dir_stream { struct fs_dirent dirent;
struct erofs_inode inode; - char dblk[EROFS_BLKSIZ]; + char dblk[EROFS_MAX_BLOCK_SIZE]; unsigned int maxsize, de_end; erofs_off_t pos; }; @@ -125,7 +125,7 @@ int erofs_readdir(struct fs_dir_stream *fs_dirs, struct fs_dirent **dentp) return 1;
if (!dirs->maxsize) { - dirs->maxsize = min_t(unsigned int, EROFS_BLKSIZ, + dirs->maxsize = min_t(unsigned int, EROFS_MAX_BLOCK_SIZE, dirs->inode.i_size - pos);
err = erofs_pread(&dirs->inode, dirs->dblk, @@ -136,7 +136,7 @@ int erofs_readdir(struct fs_dir_stream *fs_dirs, struct fs_dirent **dentp) de = (struct erofs_dirent *)dirs->dblk; dirs->de_end = le16_to_cpu(de->nameoff); if (dirs->de_end < sizeof(struct erofs_dirent) || - dirs->de_end >= EROFS_BLKSIZ) { + dirs->de_end >= EROFS_MAX_BLOCK_SIZE) { erofs_err("invalid de[0].nameoff %u @ nid %llu", dirs->de_end, de->nid | 0ULL); return -EFSCORRUPTED; @@ -183,7 +183,7 @@ int erofs_readdir(struct fs_dir_stream *fs_dirs, struct fs_dirent **dentp)
pos += sizeof(*de); if (erofs_blkoff(pos) >= dirs->de_end) { - pos = blknr_to_addr(erofs_blknr(pos) + 1); + pos = erofs_pos(erofs_blknr(pos) + 1); dirs->maxsize = 0; } dirs->pos = pos; diff --git a/fs/erofs/internal.h b/fs/erofs/internal.h index 4af7c91560..433a3c6c1e 100644 --- a/fs/erofs/internal.h +++ b/fs/erofs/internal.h @@ -2,6 +2,7 @@ #ifndef __EROFS_INTERNAL_H #define __EROFS_INTERNAL_H
+#include "linux/compat.h" #define __packed __attribute__((__packed__))
#include <linux/stat.h> @@ -30,8 +31,9 @@
#define PAGE_MASK (~(PAGE_SIZE - 1))
-#define LOG_BLOCK_SIZE (12) -#define EROFS_BLKSIZ (1U << LOG_BLOCK_SIZE) +#ifndef EROFS_MAX_BLOCK_SIZE +#define EROFS_MAX_BLOCK_SIZE PAGE_SIZE +#endif
#define EROFS_ISLOTBITS 5 #define EROFS_SLOTSIZE (1U << EROFS_ISLOTBITS) @@ -44,11 +46,15 @@ typedef u32 erofs_blk_t; #define NULL_ADDR ((unsigned int)-1) #define NULL_ADDR_UL ((unsigned long)-1)
-#define erofs_blknr(addr) ((addr) / EROFS_BLKSIZ) -#define erofs_blkoff(addr) ((addr) % EROFS_BLKSIZ) -#define blknr_to_addr(nr) ((erofs_off_t)(nr) * EROFS_BLKSIZ) +/* global sbi */ +extern struct erofs_sb_info sbi; + +#define erofs_blksiz() (1u << sbi.blkszbits) +#define erofs_blknr(addr) ((addr) >> sbi.blkszbits) +#define erofs_blkoff(addr) ((addr) & (erofs_blksiz() - 1)) +#define erofs_pos(nr) ((erofs_off_t)(nr) << sbi.blkszbits)
-#define BLK_ROUND_UP(addr) DIV_ROUND_UP(addr, EROFS_BLKSIZ) +#define BLK_ROUND_UP(addr) DIV_ROUND_UP(addr, 1u << sbi.blkszbits)
struct erofs_buffer_head;
@@ -57,6 +63,8 @@ struct erofs_device_info { u32 mapped_blkaddr; };
+#define EROFS_PACKED_NID_UNALLOCATED -1 + struct erofs_sb_info { struct erofs_device_info *devs;
@@ -72,6 +80,7 @@ struct erofs_sb_info { u32 build_time_nsec;
unsigned char islotbits; + unsigned char blkszbits;
/* what we really care is nid, rather than ino.. */ erofs_nid_t root_nid; @@ -79,23 +88,29 @@ struct erofs_sb_info { u64 inos;
u8 uuid[16]; + char volume_name[16];
u16 available_compr_algs; u16 lz4_max_distance; + u32 checksum; u16 extra_devices; union { u16 devt_slotoff; /* used for mkfs */ u16 device_id_mask; /* used for others */ }; + erofs_nid_t packed_nid; + + u32 xattr_prefix_start; + u8 xattr_prefix_count; };
-/* global sbi */ -extern struct erofs_sb_info sbi; +/* make sure that any user of the erofs headers has at least 64bit off_t type */ +extern int erofs_assert_largefile[sizeof(off_t) - 8];
static inline erofs_off_t iloc(erofs_nid_t nid) { - return blknr_to_addr(sbi.meta_blkaddr) + (nid << sbi.islotbits); + return erofs_pos(sbi.meta_blkaddr) + (nid << sbi.islotbits); }
#define EROFS_FEATURE_FUNCS(name, compat, feature) \ @@ -112,11 +127,15 @@ static inline void erofs_sb_clear_##name(void) \ sbi.feature_##compat &= ~EROFS_FEATURE_##feature; \ }
-EROFS_FEATURE_FUNCS(lz4_0padding, incompat, INCOMPAT_LZ4_0PADDING) +EROFS_FEATURE_FUNCS(lz4_0padding, incompat, INCOMPAT_ZERO_PADDING) EROFS_FEATURE_FUNCS(compr_cfgs, incompat, INCOMPAT_COMPR_CFGS) EROFS_FEATURE_FUNCS(big_pcluster, incompat, INCOMPAT_BIG_PCLUSTER) EROFS_FEATURE_FUNCS(chunked_file, incompat, INCOMPAT_CHUNKED_FILE) EROFS_FEATURE_FUNCS(device_table, incompat, INCOMPAT_DEVICE_TABLE) +EROFS_FEATURE_FUNCS(ztailpacking, incompat, INCOMPAT_ZTAILPACKING) +EROFS_FEATURE_FUNCS(fragments, incompat, INCOMPAT_FRAGMENTS) +EROFS_FEATURE_FUNCS(dedupe, incompat, INCOMPAT_DEDUPE) +EROFS_FEATURE_FUNCS(xattr_prefixes, incompat, INCOMPAT_XATTR_PREFIXES) EROFS_FEATURE_FUNCS(sb_chksum, compat, COMPAT_SB_CHKSUM)
#define EROFS_I_EA_INITED (1 << 0) @@ -130,6 +149,8 @@ struct erofs_inode { unsigned int flags; /* (mkfs.erofs) device ID containing source file */ u32 dev; + /* (mkfs.erofs) queued sub-directories blocking dump */ + u32 subdirs_queued; }; unsigned int i_count; struct erofs_inode *i_parent; @@ -140,8 +161,8 @@ struct erofs_inode { u64 i_ino[2]; u32 i_uid; u32 i_gid; - u64 i_ctime; - u32 i_ctime_nsec; + u64 i_mtime; + u32 i_mtime_nsec; u32 i_nlink;
union { @@ -154,20 +175,31 @@ struct erofs_inode { }; } u;
+ char *i_srcpath; + unsigned char datalayout; unsigned char inode_isize; /* inline tail-end packing size */ unsigned short idata_size; + bool compressed_idata; + bool lazy_tailblock;
unsigned int xattr_isize; unsigned int extent_isize;
+ unsigned int xattr_shared_count; + unsigned int *xattr_shared_xattrs; + erofs_nid_t nid; struct erofs_buffer_head *bh; struct erofs_buffer_head *bh_inline, *bh_data;
void *idata;
+ /* (ztailpacking) in order to recover uncompressed EOF data */ + void *eof_tailraw; + unsigned int eof_tailrawsize; + union { void *compressmeta; void *chunkindexes; @@ -176,8 +208,14 @@ struct erofs_inode { uint8_t z_algorithmtype[2]; uint8_t z_logical_clusterbits; uint8_t z_physical_clusterblks; + uint64_t z_tailextent_headlcn; + unsigned int z_idataoff; +#define z_idata_size idata_size }; }; + uint64_t capabilities; + erofs_off_t fragmentoff; + unsigned int fragment_size; };
static inline bool is_inode_layout_compression(struct erofs_inode *inode) @@ -216,6 +254,14 @@ struct erofs_dentry { }; };
+static inline bool is_dot_dotdot_len(const char *name, unsigned int len) +{ + if (len >= 1 && name[0] != '.') + return false; + + return len == 1 || (len == 2 && name[1] == '.'); +} + static inline bool is_dot_dotdot(const char *name) { if (name[0] != '.') @@ -229,6 +275,8 @@ enum { BH_Mapped, BH_Encoded, BH_FullMapped, + BH_Fragment, + BH_Partialref, };
/* Has a disk mapping */ @@ -239,9 +287,13 @@ enum { #define EROFS_MAP_ENCODED (1 << BH_Encoded) /* The length of extent is full */ #define EROFS_MAP_FULL_MAPPED (1 << BH_FullMapped) +/* Located in the special packed inode */ +#define EROFS_MAP_FRAGMENT (1 << BH_Fragment) +/* The extent refers to partial decompressed data */ +#define EROFS_MAP_PARTIAL_REF (1 << BH_Partialref)
struct erofs_map_blocks { - char mpage[EROFS_BLKSIZ]; + char mpage[EROFS_MAX_BLOCK_SIZE];
erofs_off_t m_pa, m_la; u64 m_plen, m_llen; @@ -257,9 +309,12 @@ struct erofs_map_blocks { * approach instead if possible since it's more metadata lightweight.) */ #define EROFS_GET_BLOCKS_FIEMAP 0x0002 +/* Used to map tail extent for tailpacking inline or fragment pcluster */ +#define EROFS_GET_BLOCKS_FINDTAIL 0x0008
enum { Z_EROFS_COMPRESSION_SHIFTED = Z_EROFS_COMPRESSION_MAX, + Z_EROFS_COMPRESSION_INTERLACED, Z_EROFS_COMPRESSION_RUNTIME_MAX };
@@ -274,6 +329,7 @@ int erofs_dev_read(int device_id, void *buf, u64 offset, size_t len);
/* super.c */ int erofs_read_superblock(void); +void erofs_put_super(void);
/* namei.c */ int erofs_read_inode_from_disk(struct erofs_inode *vi); @@ -283,9 +339,40 @@ int erofs_read_inode_from_disk(struct erofs_inode *vi); /* data.c */ int erofs_pread(struct erofs_inode *inode, char *buf, erofs_off_t count, erofs_off_t offset); -int erofs_map_blocks(struct erofs_inode *inode, - struct erofs_map_blocks *map, int flags); -int erofs_map_dev(struct erofs_sb_info *sbi, struct erofs_map_dev *map); +int erofs_map_blocks(struct erofs_inode *inode, struct erofs_map_blocks *map, + int flags); +int erofs_map_dev(struct erofs_map_dev *map); +int erofs_read_one_data(struct erofs_map_blocks *map, char *buffer, u64 offset, + size_t len); +int z_erofs_read_one_data(struct erofs_inode *inode, + struct erofs_map_blocks *map, char *raw, char *buffer, + erofs_off_t skip, erofs_off_t length, bool trimmed); + +static inline int erofs_get_occupied_size(const struct erofs_inode *inode, + erofs_off_t *size) +{ + *size = 0; + switch (inode->datalayout) { + case EROFS_INODE_FLAT_INLINE: + case EROFS_INODE_FLAT_PLAIN: + case EROFS_INODE_CHUNK_BASED: + *size = inode->i_size; + break; + case EROFS_INODE_COMPRESSED_FULL: + case EROFS_INODE_COMPRESSED_COMPACT: + *size = inode->u.i_blocks * erofs_blksiz(); + break; + default: + return -EOPNOTSUPP; + } + return 0; +} + +/* data.c */ +int erofs_getxattr(struct erofs_inode *vi, const char *name, char *buffer, + size_t buffer_size); +int erofs_listxattr(struct erofs_inode *vi, char *buffer, size_t buffer_size); + /* zmap.c */ int z_erofs_fill_inode(struct erofs_inode *vi); int z_erofs_map_blocks_iter(struct erofs_inode *vi, diff --git a/fs/erofs/namei.c b/fs/erofs/namei.c index d1d4757c50..bde995f1bf 100644 --- a/fs/erofs/namei.c +++ b/fs/erofs/namei.c @@ -1,6 +1,15 @@ // SPDX-License-Identifier: GPL-2.0+ #include "internal.h"
+#define makedev(major, minor) ((dev_t)((((major) & 0xfff) << 8) | ((minor) & 0xff))) +static dev_t erofs_new_decode_dev(u32 dev) +{ + const unsigned int major = (dev & 0xfff00) >> 8; + const unsigned int minor = (dev & 0xff) | ((dev >> 12) & 0xfff00); + + return makedev(major, minor); +} + int erofs_read_inode_from_disk(struct erofs_inode *vi) { int ret, ifmt; @@ -26,7 +35,8 @@ int erofs_read_inode_from_disk(struct erofs_inode *vi) case EROFS_INODE_LAYOUT_EXTENDED: vi->inode_isize = sizeof(struct erofs_inode_extended);
- ret = erofs_dev_read(0, buf + sizeof(*dic), inode_loc + sizeof(*dic), + ret = erofs_dev_read(0, buf + sizeof(*dic), + inode_loc + sizeof(*dic), sizeof(*die) - sizeof(*dic)); if (ret < 0) return -EIO; @@ -43,7 +53,8 @@ int erofs_read_inode_from_disk(struct erofs_inode *vi) break; case S_IFCHR: case S_IFBLK: - vi->u.i_rdev = 0; + vi->u.i_rdev = + erofs_new_decode_dev(le32_to_cpu(die->i_u.rdev)); break; case S_IFIFO: case S_IFSOCK: @@ -57,8 +68,8 @@ int erofs_read_inode_from_disk(struct erofs_inode *vi) vi->i_gid = le32_to_cpu(die->i_gid); vi->i_nlink = le32_to_cpu(die->i_nlink);
- vi->i_ctime = le64_to_cpu(die->i_ctime); - vi->i_ctime_nsec = le64_to_cpu(die->i_ctime_nsec); + vi->i_mtime = le64_to_cpu(die->i_mtime); + vi->i_mtime_nsec = le64_to_cpu(die->i_mtime_nsec); vi->i_size = le64_to_cpu(die->i_size); if (vi->datalayout == EROFS_INODE_CHUNK_BASED) /* fill chunked inode summary info */ @@ -77,7 +88,8 @@ int erofs_read_inode_from_disk(struct erofs_inode *vi) break; case S_IFCHR: case S_IFBLK: - vi->u.i_rdev = 0; + vi->u.i_rdev = + erofs_new_decode_dev(le32_to_cpu(dic->i_u.rdev)); break; case S_IFIFO: case S_IFSOCK: @@ -91,8 +103,8 @@ int erofs_read_inode_from_disk(struct erofs_inode *vi) vi->i_gid = le16_to_cpu(dic->i_gid); vi->i_nlink = le16_to_cpu(dic->i_nlink);
- vi->i_ctime = sbi.build_time; - vi->i_ctime_nsec = sbi.build_time_nsec; + vi->i_mtime = sbi.build_time; + vi->i_mtime_nsec = sbi.build_time_nsec;
vi->i_size = le32_to_cpu(dic->i_size); if (vi->datalayout == EROFS_INODE_CHUNK_BASED) @@ -111,10 +123,13 @@ int erofs_read_inode_from_disk(struct erofs_inode *vi) vi->u.chunkformat, vi->nid | 0ULL); return -EOPNOTSUPP; } - vi->u.chunkbits = LOG_BLOCK_SIZE + + vi->u.chunkbits = sbi.blkszbits + (vi->u.chunkformat & EROFS_CHUNK_FORMAT_BLKBITS_MASK); - } else if (erofs_inode_is_data_compressed(vi->datalayout)) - z_erofs_fill_inode(vi); + } else if (erofs_inode_is_data_compressed(vi->datalayout)) { + if (erofs_blksiz() != EROFS_MAX_BLOCK_SIZE) + return -EOPNOTSUPP; + return z_erofs_fill_inode(vi); + } return 0; bogusimode: erofs_err("bogus i_mode (%o) @ nid %llu", vi->i_mode, vi->nid | 0ULL); @@ -163,12 +178,11 @@ struct nameidata { unsigned int ftype; };
-int erofs_namei(struct nameidata *nd, - const char *name, unsigned int len) +int erofs_namei(struct nameidata *nd, const char *name, unsigned int len) { erofs_nid_t nid = nd->nid; int ret; - char buf[EROFS_BLKSIZ]; + char buf[EROFS_MAX_BLOCK_SIZE]; struct erofs_inode vi = { .nid = nid }; erofs_off_t offset;
@@ -179,7 +193,7 @@ int erofs_namei(struct nameidata *nd, offset = 0; while (offset < vi.i_size) { erofs_off_t maxsize = min_t(erofs_off_t, - vi.i_size - offset, EROFS_BLKSIZ); + vi.i_size - offset, erofs_blksiz()); struct erofs_dirent *de = (void *)buf; unsigned int nameoff;
@@ -189,7 +203,7 @@ int erofs_namei(struct nameidata *nd,
nameoff = le16_to_cpu(de->nameoff); if (nameoff < sizeof(struct erofs_dirent) || - nameoff >= PAGE_SIZE) { + nameoff >= erofs_blksiz()) { erofs_err("invalid de[0].nameoff %u @ nid %llu", nameoff, nid | 0ULL); return -EFSCORRUPTED; diff --git a/fs/erofs/super.c b/fs/erofs/super.c index 8277d9b53f..d33926281b 100644 --- a/fs/erofs/super.c +++ b/fs/erofs/super.c @@ -9,7 +9,7 @@ static bool check_layout_compatibility(struct erofs_sb_info *sbi, sbi->feature_incompat = feature;
/* check if current kernel meets all mandatory requirements */ - if (feature & (~EROFS_ALL_FEATURE_INCOMPAT)) { + if (feature & ~EROFS_ALL_FEATURE_INCOMPAT) { erofs_err("unidentified incompatible feature %x, please upgrade kernel version", feature & ~EROFS_ALL_FEATURE_INCOMPAT); return false; @@ -40,14 +40,18 @@ static int erofs_init_devices(struct erofs_sb_info *sbi,
sbi->device_id_mask = roundup_pow_of_two(ondisk_extradevs + 1) - 1; sbi->devs = calloc(ondisk_extradevs, sizeof(*sbi->devs)); + if (!sbi->devs) + return -ENOMEM; pos = le16_to_cpu(dsb->devt_slotoff) * EROFS_DEVT_SLOT_SIZE; for (i = 0; i < ondisk_extradevs; ++i) { struct erofs_deviceslot dis; int ret;
ret = erofs_dev_read(0, &dis, pos, sizeof(dis)); - if (ret < 0) + if (ret < 0) { + free(sbi->devs); return ret; + }
sbi->devs[i].mapped_blkaddr = dis.mapped_blkaddr; sbi->total_blocks += dis.blocks; @@ -58,42 +62,41 @@ static int erofs_init_devices(struct erofs_sb_info *sbi,
int erofs_read_superblock(void) { - char data[EROFS_BLKSIZ]; + u8 data[EROFS_MAX_BLOCK_SIZE]; struct erofs_super_block *dsb; - unsigned int blkszbits; int ret;
- ret = erofs_blk_read(data, 0, 1); + ret = erofs_blk_read(data, 0, erofs_blknr(sizeof(data))); if (ret < 0) { - erofs_dbg("cannot read erofs superblock: %d", ret); + erofs_err("cannot read erofs superblock: %d", ret); return -EIO; } dsb = (struct erofs_super_block *)(data + EROFS_SUPER_OFFSET);
ret = -EINVAL; if (le32_to_cpu(dsb->magic) != EROFS_SUPER_MAGIC_V1) { - erofs_dbg("cannot find valid erofs superblock"); + erofs_err("cannot find valid erofs superblock"); return ret; }
sbi.feature_compat = le32_to_cpu(dsb->feature_compat);
- blkszbits = dsb->blkszbits; - /* 9(512 bytes) + LOG_SECTORS_PER_BLOCK == LOG_BLOCK_SIZE */ - if (blkszbits != LOG_BLOCK_SIZE) { - erofs_err("blksize %u isn't supported on this platform", - 1 << blkszbits); + sbi.blkszbits = dsb->blkszbits; + if (sbi.blkszbits < 9 || + sbi.blkszbits > ilog2(EROFS_MAX_BLOCK_SIZE)) { + erofs_err("blksize %llu isn't supported on this platform", + erofs_blksiz() | 0ULL); return ret; - } - - if (!check_layout_compatibility(&sbi, dsb)) + } else if (!check_layout_compatibility(&sbi, dsb)) { return ret; + }
sbi.primarydevice_blocks = le32_to_cpu(dsb->blocks); sbi.meta_blkaddr = le32_to_cpu(dsb->meta_blkaddr); sbi.xattr_blkaddr = le32_to_cpu(dsb->xattr_blkaddr); sbi.islotbits = EROFS_ISLOTBITS; sbi.root_nid = le16_to_cpu(dsb->root_nid); + sbi.packed_nid = le64_to_cpu(dsb->packed_nid); sbi.inos = le64_to_cpu(dsb->inos); sbi.checksum = le32_to_cpu(dsb->checksum);
diff --git a/fs/erofs/zmap.c b/fs/erofs/zmap.c index be2599ac4f..4f64258b00 100644 --- a/fs/erofs/zmap.c +++ b/fs/erofs/zmap.c @@ -1,14 +1,19 @@ // SPDX-License-Identifier: GPL-2.0+ #include "internal.h"
+static int z_erofs_do_map_blocks(struct erofs_inode *vi, + struct erofs_map_blocks *map, + int flags); + int z_erofs_fill_inode(struct erofs_inode *vi) { if (!erofs_sb_has_big_pcluster() && - vi->datalayout == EROFS_INODE_FLAT_COMPRESSION_LEGACY) { + !erofs_sb_has_ztailpacking() && !erofs_sb_has_fragments() && + vi->datalayout == EROFS_INODE_COMPRESSED_FULL) { vi->z_advise = 0; vi->z_algorithmtype[0] = 0; vi->z_algorithmtype[1] = 0; - vi->z_logical_clusterbits = LOG_BLOCK_SIZE; + vi->z_logical_clusterbits = sbi.blkszbits;
vi->flags |= EROFS_I_Z_INITED; } @@ -25,15 +30,23 @@ static int z_erofs_fill_inode_lazy(struct erofs_inode *vi) if (vi->flags & EROFS_I_Z_INITED) return 0;
- DBG_BUGON(!erofs_sb_has_big_pcluster() && - vi->datalayout == EROFS_INODE_FLAT_COMPRESSION_LEGACY); pos = round_up(iloc(vi->nid) + vi->inode_isize + vi->xattr_isize, 8); - ret = erofs_dev_read(0, buf, pos, sizeof(buf)); if (ret < 0) return -EIO;
h = (struct z_erofs_map_header *)buf; + /* + * if the highest bit of the 8-byte map header is set, the whole file + * is stored in the packed inode. The rest bits keeps z_fragmentoff. + */ + if (h->h_clusterbits >> Z_EROFS_FRAGMENT_INODE_BIT) { + vi->z_advise = Z_EROFS_ADVISE_FRAGMENT_PCLUSTER; + vi->fragmentoff = le64_to_cpu(*(__le64 *)h) ^ (1ULL << 63); + vi->z_tailextent_headlcn = 0; + goto out; + } + vi->z_advise = le16_to_cpu(h->h_advise); vi->z_algorithmtype[0] = h->h_algorithmtype & 15; vi->z_algorithmtype[1] = h->h_algorithmtype >> 4; @@ -44,14 +57,41 @@ static int z_erofs_fill_inode_lazy(struct erofs_inode *vi) return -EOPNOTSUPP; }
- vi->z_logical_clusterbits = LOG_BLOCK_SIZE + (h->h_clusterbits & 7); - if (vi->datalayout == EROFS_INODE_FLAT_COMPRESSION && + vi->z_logical_clusterbits = sbi.blkszbits + (h->h_clusterbits & 7); + if (vi->datalayout == EROFS_INODE_COMPRESSED_COMPACT && !(vi->z_advise & Z_EROFS_ADVISE_BIG_PCLUSTER_1) ^ !(vi->z_advise & Z_EROFS_ADVISE_BIG_PCLUSTER_2)) { erofs_err("big pcluster head1/2 of compact indexes should be consistent for nid %llu", vi->nid * 1ULL); return -EFSCORRUPTED; } + + if (vi->z_advise & Z_EROFS_ADVISE_INLINE_PCLUSTER) { + struct erofs_map_blocks map = { .index = UINT_MAX }; + + vi->idata_size = le16_to_cpu(h->h_idata_size); + ret = z_erofs_do_map_blocks(vi, &map, + EROFS_GET_BLOCKS_FINDTAIL); + if (!map.m_plen || + erofs_blkoff(map.m_pa) + map.m_plen > erofs_blksiz()) { + erofs_err("invalid tail-packing pclustersize %llu", + map.m_plen | 0ULL); + return -EFSCORRUPTED; + } + if (ret < 0) + return ret; + } + if (vi->z_advise & Z_EROFS_ADVISE_FRAGMENT_PCLUSTER && + !(h->h_clusterbits >> Z_EROFS_FRAGMENT_INODE_BIT)) { + struct erofs_map_blocks map = { .index = UINT_MAX }; + + vi->fragmentoff = le32_to_cpu(h->h_fragmentoff); + ret = z_erofs_do_map_blocks(vi, &map, + EROFS_GET_BLOCKS_FINDTAIL); + if (ret < 0) + return ret; + } +out: vi->flags |= EROFS_I_Z_INITED; return 0; } @@ -66,7 +106,9 @@ struct z_erofs_maprecorder { u8 type, headtype; u16 clusterofs; u16 delta[2]; - erofs_blk_t pblk, compressedlcs; + erofs_blk_t pblk, compressedblks; + erofs_off_t nextpackoff; + bool partialref; };
static int z_erofs_reload_indexes(struct z_erofs_maprecorder *m, @@ -93,11 +135,10 @@ static int legacy_load_cluster_from_disk(struct z_erofs_maprecorder *m, { struct erofs_inode *const vi = m->inode; const erofs_off_t ibase = iloc(vi->nid); - const erofs_off_t pos = - Z_EROFS_VLE_LEGACY_INDEX_ALIGN(ibase + vi->inode_isize + - vi->xattr_isize) + - lcn * sizeof(struct z_erofs_vle_decompressed_index); - struct z_erofs_vle_decompressed_index *di; + const erofs_off_t pos = Z_EROFS_FULL_INDEX_ALIGN(ibase + + vi->inode_isize + vi->xattr_isize) + + lcn * sizeof(struct z_erofs_lcluster_index); + struct z_erofs_lcluster_index *di; unsigned int advise, type; int err;
@@ -105,29 +146,32 @@ static int legacy_load_cluster_from_disk(struct z_erofs_maprecorder *m, if (err) return err;
+ m->nextpackoff = pos + sizeof(struct z_erofs_lcluster_index); m->lcn = lcn; di = m->kaddr + erofs_blkoff(pos);
advise = le16_to_cpu(di->di_advise); - type = (advise >> Z_EROFS_VLE_DI_CLUSTER_TYPE_BIT) & - ((1 << Z_EROFS_VLE_DI_CLUSTER_TYPE_BITS) - 1); + type = (advise >> Z_EROFS_LI_LCLUSTER_TYPE_BIT) & + ((1 << Z_EROFS_LI_LCLUSTER_TYPE_BITS) - 1); switch (type) { - case Z_EROFS_VLE_CLUSTER_TYPE_NONHEAD: + case Z_EROFS_LCLUSTER_TYPE_NONHEAD: m->clusterofs = 1 << vi->z_logical_clusterbits; m->delta[0] = le16_to_cpu(di->di_u.delta[0]); - if (m->delta[0] & Z_EROFS_VLE_DI_D0_CBLKCNT) { + if (m->delta[0] & Z_EROFS_LI_D0_CBLKCNT) { if (!(vi->z_advise & Z_EROFS_ADVISE_BIG_PCLUSTER_1)) { DBG_BUGON(1); return -EFSCORRUPTED; } - m->compressedlcs = m->delta[0] & - ~Z_EROFS_VLE_DI_D0_CBLKCNT; + m->compressedblks = m->delta[0] & + ~Z_EROFS_LI_D0_CBLKCNT; m->delta[0] = 1; } m->delta[1] = le16_to_cpu(di->di_u.delta[1]); break; - case Z_EROFS_VLE_CLUSTER_TYPE_PLAIN: - case Z_EROFS_VLE_CLUSTER_TYPE_HEAD: + case Z_EROFS_LCLUSTER_TYPE_PLAIN: + case Z_EROFS_LCLUSTER_TYPE_HEAD1: + if (advise & Z_EROFS_LI_PARTIAL_REF) + m->partialref = true; m->clusterofs = le16_to_cpu(di->di_clusterofs); m->pblk = le32_to_cpu(di->di_u.blkaddr); break; @@ -164,25 +208,25 @@ static int get_compacted_la_distance(unsigned int lclusterbits, lo = decode_compactedbits(lclusterbits, lomask, in, encodebits * i, &type);
- if (type != Z_EROFS_VLE_CLUSTER_TYPE_NONHEAD) + if (type != Z_EROFS_LCLUSTER_TYPE_NONHEAD) return d1; ++d1; } while (++i < vcnt);
- /* vcnt - 1 (Z_EROFS_VLE_CLUSTER_TYPE_NONHEAD) item */ - if (!(lo & Z_EROFS_VLE_DI_D0_CBLKCNT)) + /* vcnt - 1 (Z_EROFS_LCLUSTER_TYPE_NONHEAD) item */ + if (!(lo & Z_EROFS_LI_D0_CBLKCNT)) d1 += lo - 1; return d1; }
static int unpack_compacted_index(struct z_erofs_maprecorder *m, unsigned int amortizedshift, - unsigned int eofs, bool lookahead) + erofs_off_t pos, bool lookahead) { struct erofs_inode *const vi = m->inode; const unsigned int lclusterbits = vi->z_logical_clusterbits; const unsigned int lomask = (1 << lclusterbits) - 1; - unsigned int vcnt, base, lo, encodebits, nblk; + unsigned int vcnt, base, lo, encodebits, nblk, eofs; int i; u8 *in, type; bool big_pcluster; @@ -194,8 +238,12 @@ static int unpack_compacted_index(struct z_erofs_maprecorder *m, else return -EOPNOTSUPP;
+ /* it doesn't equal to round_up(..) */ + m->nextpackoff = round_down(pos, vcnt << amortizedshift) + + (vcnt << amortizedshift); big_pcluster = vi->z_advise & Z_EROFS_ADVISE_BIG_PCLUSTER_1; encodebits = ((vcnt << amortizedshift) - sizeof(__le32)) * 8 / vcnt; + eofs = erofs_blkoff(pos); base = round_down(eofs, vcnt << amortizedshift); in = m->kaddr + base;
@@ -204,20 +252,19 @@ static int unpack_compacted_index(struct z_erofs_maprecorder *m, lo = decode_compactedbits(lclusterbits, lomask, in, encodebits * i, &type); m->type = type; - if (type == Z_EROFS_VLE_CLUSTER_TYPE_NONHEAD) { + if (type == Z_EROFS_LCLUSTER_TYPE_NONHEAD) { m->clusterofs = 1 << lclusterbits;
/* figure out lookahead_distance: delta[1] if needed */ if (lookahead) m->delta[1] = get_compacted_la_distance(lclusterbits, - encodebits, - vcnt, in, i); - if (lo & Z_EROFS_VLE_DI_D0_CBLKCNT) { + encodebits, vcnt, in, i); + if (lo & Z_EROFS_LI_D0_CBLKCNT) { if (!big_pcluster) { DBG_BUGON(1); return -EFSCORRUPTED; } - m->compressedlcs = lo & ~Z_EROFS_VLE_DI_D0_CBLKCNT; + m->compressedblks = lo & ~Z_EROFS_LI_D0_CBLKCNT; m->delta[0] = 1; return 0; } else if (i + 1 != (int)vcnt) { @@ -231,9 +278,9 @@ static int unpack_compacted_index(struct z_erofs_maprecorder *m, */ lo = decode_compactedbits(lclusterbits, lomask, in, encodebits * (i - 1), &type); - if (type != Z_EROFS_VLE_CLUSTER_TYPE_NONHEAD) + if (type != Z_EROFS_LCLUSTER_TYPE_NONHEAD) lo = 0; - else if (lo & Z_EROFS_VLE_DI_D0_CBLKCNT) + else if (lo & Z_EROFS_LI_D0_CBLKCNT) lo = 1; m->delta[0] = lo + 1; return 0; @@ -247,7 +294,7 @@ static int unpack_compacted_index(struct z_erofs_maprecorder *m, --i; lo = decode_compactedbits(lclusterbits, lomask, in, encodebits * i, &type); - if (type == Z_EROFS_VLE_CLUSTER_TYPE_NONHEAD) + if (type == Z_EROFS_LCLUSTER_TYPE_NONHEAD) i -= lo;
if (i >= 0) @@ -259,13 +306,13 @@ static int unpack_compacted_index(struct z_erofs_maprecorder *m, --i; lo = decode_compactedbits(lclusterbits, lomask, in, encodebits * i, &type); - if (type == Z_EROFS_VLE_CLUSTER_TYPE_NONHEAD) { - if (lo & Z_EROFS_VLE_DI_D0_CBLKCNT) { + if (type == Z_EROFS_LCLUSTER_TYPE_NONHEAD) { + if (lo & Z_EROFS_LI_D0_CBLKCNT) { --i; - nblk += lo & ~Z_EROFS_VLE_DI_D0_CBLKCNT; + nblk += lo & ~Z_EROFS_LI_D0_CBLKCNT; continue; } - if (lo == 1) { + if (lo <= 1) { DBG_BUGON(1); /* --i; ++nblk; continue; */ return -EFSCORRUPTED; @@ -289,7 +336,7 @@ static int compacted_load_cluster_from_disk(struct z_erofs_maprecorder *m, const erofs_off_t ebase = round_up(iloc(vi->nid) + vi->inode_isize + vi->xattr_isize, 8) + sizeof(struct z_erofs_map_header); - const unsigned int totalidx = DIV_ROUND_UP(vi->i_size, EROFS_BLKSIZ); + const unsigned int totalidx = BLK_ROUND_UP(vi->i_size); unsigned int compacted_4b_initial, compacted_2b; unsigned int amortizedshift; erofs_off_t pos; @@ -307,7 +354,8 @@ static int compacted_load_cluster_from_disk(struct z_erofs_maprecorder *m, if (compacted_4b_initial == 32 / 4) compacted_4b_initial = 0;
- if (vi->z_advise & Z_EROFS_ADVISE_COMPACTED_2B) + if ((vi->z_advise & Z_EROFS_ADVISE_COMPACTED_2B) && + compacted_4b_initial < totalidx) compacted_2b = rounddown(totalidx - compacted_4b_initial, 16); else compacted_2b = 0; @@ -332,8 +380,7 @@ out: err = z_erofs_reload_indexes(m, erofs_blknr(pos)); if (err) return err; - return unpack_compacted_index(m, amortizedshift, erofs_blkoff(pos), - lookahead); + return unpack_compacted_index(m, amortizedshift, pos, lookahead); }
static int z_erofs_load_cluster_from_disk(struct z_erofs_maprecorder *m, @@ -341,10 +388,10 @@ static int z_erofs_load_cluster_from_disk(struct z_erofs_maprecorder *m, { const unsigned int datamode = m->inode->datalayout;
- if (datamode == EROFS_INODE_FLAT_COMPRESSION_LEGACY) + if (datamode == EROFS_INODE_COMPRESSED_FULL) return legacy_load_cluster_from_disk(m, lcn);
- if (datamode == EROFS_INODE_FLAT_COMPRESSION) + if (datamode == EROFS_INODE_COMPRESSED_COMPACT) return compacted_load_cluster_from_disk(m, lcn, lookahead);
return -EINVAL; @@ -373,7 +420,7 @@ static int z_erofs_extent_lookback(struct z_erofs_maprecorder *m, return err;
switch (m->type) { - case Z_EROFS_VLE_CLUSTER_TYPE_NONHEAD: + case Z_EROFS_LCLUSTER_TYPE_NONHEAD: if (!m->delta[0]) { erofs_err("invalid lookback distance 0 @ nid %llu", (unsigned long long)vi->nid); @@ -381,8 +428,8 @@ static int z_erofs_extent_lookback(struct z_erofs_maprecorder *m, return -EFSCORRUPTED; } return z_erofs_extent_lookback(m, m->delta[0]); - case Z_EROFS_VLE_CLUSTER_TYPE_PLAIN: - case Z_EROFS_VLE_CLUSTER_TYPE_HEAD: + case Z_EROFS_LCLUSTER_TYPE_PLAIN: + case Z_EROFS_LCLUSTER_TYPE_HEAD1: m->headtype = m->type; map->m_la = (lcn << lclusterbits) | m->clusterofs; break; @@ -404,16 +451,17 @@ static int z_erofs_get_extent_compressedlen(struct z_erofs_maprecorder *m, unsigned long lcn; int err;
- DBG_BUGON(m->type != Z_EROFS_VLE_CLUSTER_TYPE_PLAIN && - m->type != Z_EROFS_VLE_CLUSTER_TYPE_HEAD); - if (m->headtype == Z_EROFS_VLE_CLUSTER_TYPE_PLAIN || + DBG_BUGON(m->type != Z_EROFS_LCLUSTER_TYPE_PLAIN && + m->type != Z_EROFS_LCLUSTER_TYPE_HEAD1); + + if (m->headtype == Z_EROFS_LCLUSTER_TYPE_PLAIN || !(vi->z_advise & Z_EROFS_ADVISE_BIG_PCLUSTER_1)) { map->m_plen = 1 << lclusterbits; return 0; }
lcn = m->lcn + 1; - if (m->compressedlcs) + if (m->compressedblks) goto out;
err = z_erofs_load_cluster_from_disk(m, lcn, false); @@ -422,28 +470,28 @@ static int z_erofs_get_extent_compressedlen(struct z_erofs_maprecorder *m,
/* * If the 1st NONHEAD lcluster has already been handled initially w/o - * valid compressedlcs, which means at least it mustn't be CBLKCNT, or + * valid compressedblks, which means at least it mustn't be CBLKCNT, or * an internal implemenatation error is detected. * * The following code can also handle it properly anyway, but let's * BUG_ON in the debugging mode only for developers to notice that. */ DBG_BUGON(lcn == initial_lcn && - m->type == Z_EROFS_VLE_CLUSTER_TYPE_NONHEAD); + m->type == Z_EROFS_LCLUSTER_TYPE_NONHEAD);
switch (m->type) { - case Z_EROFS_VLE_CLUSTER_TYPE_PLAIN: - case Z_EROFS_VLE_CLUSTER_TYPE_HEAD: + case Z_EROFS_LCLUSTER_TYPE_PLAIN: + case Z_EROFS_LCLUSTER_TYPE_HEAD1: /* * if the 1st NONHEAD lcluster is actually PLAIN or HEAD type * rather than CBLKCNT, it's a 1 lcluster-sized pcluster. */ - m->compressedlcs = 1; + m->compressedblks = 1 << (lclusterbits - sbi.blkszbits); break; - case Z_EROFS_VLE_CLUSTER_TYPE_NONHEAD: + case Z_EROFS_LCLUSTER_TYPE_NONHEAD: if (m->delta[0] != 1) goto err_bonus_cblkcnt; - if (m->compressedlcs) + if (m->compressedblks) break; /* fallthrough */ default: @@ -453,7 +501,7 @@ static int z_erofs_get_extent_compressedlen(struct z_erofs_maprecorder *m, return -EFSCORRUPTED; } out: - map->m_plen = m->compressedlcs << lclusterbits; + map->m_plen = m->compressedblks << sbi.blkszbits; return 0; err_bonus_cblkcnt: erofs_err("bogus CBLKCNT @ lcn %lu of nid %llu", @@ -481,11 +529,11 @@ static int z_erofs_get_extent_decompressedlen(struct z_erofs_maprecorder *m) if (err) return err;
- if (m->type == Z_EROFS_VLE_CLUSTER_TYPE_NONHEAD) { + if (m->type == Z_EROFS_LCLUSTER_TYPE_NONHEAD) { DBG_BUGON(!m->delta[1] && m->clusterofs != 1 << lclusterbits); - } else if (m->type == Z_EROFS_VLE_CLUSTER_TYPE_PLAIN || - m->type == Z_EROFS_VLE_CLUSTER_TYPE_HEAD) { + } else if (m->type == Z_EROFS_LCLUSTER_TYPE_PLAIN || + m->type == Z_EROFS_LCLUSTER_TYPE_HEAD1) { /* go on until the next HEAD lcluster */ if (lcn != headlcn) break; @@ -504,10 +552,12 @@ static int z_erofs_get_extent_decompressedlen(struct z_erofs_maprecorder *m) return 0; }
-int z_erofs_map_blocks_iter(struct erofs_inode *vi, - struct erofs_map_blocks *map, - int flags) +static int z_erofs_do_map_blocks(struct erofs_inode *vi, + struct erofs_map_blocks *map, + int flags) { + bool ztailpacking = vi->z_advise & Z_EROFS_ADVISE_INLINE_PCLUSTER; + bool fragment = vi->z_advise & Z_EROFS_ADVISE_FRAGMENT_PCLUSTER; struct z_erofs_maprecorder m = { .inode = vi, .map = map, @@ -518,20 +568,8 @@ int z_erofs_map_blocks_iter(struct erofs_inode *vi, unsigned long initial_lcn; unsigned long long ofs, end;
- /* when trying to read beyond EOF, leave it unmapped */ - if (map->m_la >= vi->i_size) { - map->m_llen = map->m_la + 1 - vi->i_size; - map->m_la = vi->i_size; - map->m_flags = 0; - goto out; - } - - err = z_erofs_fill_inode_lazy(vi); - if (err) - goto out; - lclusterbits = vi->z_logical_clusterbits; - ofs = map->m_la; + ofs = flags & EROFS_GET_BLOCKS_FINDTAIL ? vi->i_size - 1 : map->m_la; initial_lcn = ofs >> lclusterbits; endoff = ofs & ((1 << lclusterbits) - 1);
@@ -539,11 +577,14 @@ int z_erofs_map_blocks_iter(struct erofs_inode *vi, if (err) goto out;
+ if (ztailpacking && (flags & EROFS_GET_BLOCKS_FINDTAIL)) + vi->z_idataoff = m.nextpackoff; + map->m_flags = EROFS_MAP_MAPPED | EROFS_MAP_ENCODED; end = (m.lcn + 1ULL) << lclusterbits; switch (m.type) { - case Z_EROFS_VLE_CLUSTER_TYPE_PLAIN: - case Z_EROFS_VLE_CLUSTER_TYPE_HEAD: + case Z_EROFS_LCLUSTER_TYPE_PLAIN: + case Z_EROFS_LCLUSTER_TYPE_HEAD1: if (endoff >= m.clusterofs) { m.headtype = m.type; map->m_la = (m.lcn << lclusterbits) | m.clusterofs; @@ -560,7 +601,7 @@ int z_erofs_map_blocks_iter(struct erofs_inode *vi, map->m_flags |= EROFS_MAP_FULL_MAPPED; m.delta[0] = 1; /* fallthrough */ - case Z_EROFS_VLE_CLUSTER_TYPE_NONHEAD: + case Z_EROFS_LCLUSTER_TYPE_NONHEAD: /* get the correspoinding first chunk */ err = z_erofs_extent_lookback(&m, m.delta[0]); if (err) @@ -572,18 +613,43 @@ int z_erofs_map_blocks_iter(struct erofs_inode *vi, err = -EOPNOTSUPP; goto out; } - + if (m.partialref) + map->m_flags |= EROFS_MAP_PARTIAL_REF; map->m_llen = end - map->m_la; - map->m_pa = blknr_to_addr(m.pblk); - - err = z_erofs_get_extent_compressedlen(&m, initial_lcn); - if (err) - goto out; + if (flags & EROFS_GET_BLOCKS_FINDTAIL) { + vi->z_tailextent_headlcn = m.lcn; + /* for non-compact indexes, fragmentoff is 64 bits */ + if (fragment && vi->datalayout == EROFS_INODE_COMPRESSED_FULL) + vi->fragmentoff |= (u64)m.pblk << 32; + } + if (ztailpacking && m.lcn == vi->z_tailextent_headlcn) { + map->m_flags |= EROFS_MAP_META; + map->m_pa = vi->z_idataoff; + map->m_plen = vi->z_idata_size; + } else if (fragment && m.lcn == vi->z_tailextent_headlcn) { + map->m_flags |= EROFS_MAP_FRAGMENT; + } else { + map->m_pa = erofs_pos(m.pblk); + err = z_erofs_get_extent_compressedlen(&m, initial_lcn); + if (err) + goto out; + }
- if (m.headtype == Z_EROFS_VLE_CLUSTER_TYPE_PLAIN) - map->m_algorithmformat = Z_EROFS_COMPRESSION_SHIFTED; - else + if (m.headtype == Z_EROFS_LCLUSTER_TYPE_PLAIN) { + if (map->m_llen > map->m_plen) { + DBG_BUGON(1); + err = -EFSCORRUPTED; + goto out; + } + if (vi->z_advise & Z_EROFS_ADVISE_INTERLACED_PCLUSTER) + map->m_algorithmformat = + Z_EROFS_COMPRESSION_INTERLACED; + else + map->m_algorithmformat = + Z_EROFS_COMPRESSION_SHIFTED; + } else { map->m_algorithmformat = vi->z_algorithmtype[0]; + }
if (flags & EROFS_GET_BLOCKS_FIEMAP) { err = z_erofs_get_extent_decompressedlen(&m); @@ -595,7 +661,38 @@ out: erofs_dbg("m_la %" PRIu64 " m_pa %" PRIu64 " m_llen %" PRIu64 " m_plen %" PRIu64 " m_flags 0%o", map->m_la, map->m_pa, map->m_llen, map->m_plen, map->m_flags); + return err; +}
+int z_erofs_map_blocks_iter(struct erofs_inode *vi, + struct erofs_map_blocks *map, + int flags) +{ + int err = 0; + + /* when trying to read beyond EOF, leave it unmapped */ + if (map->m_la >= vi->i_size) { + map->m_llen = map->m_la + 1 - vi->i_size; + map->m_la = vi->i_size; + map->m_flags = 0; + goto out; + } + + err = z_erofs_fill_inode_lazy(vi); + if (err) + goto out; + + if ((vi->z_advise & Z_EROFS_ADVISE_FRAGMENT_PCLUSTER) && + !vi->z_tailextent_headlcn) { + map->m_la = 0; + map->m_llen = vi->i_size; + map->m_flags = EROFS_MAP_MAPPED | EROFS_MAP_FULL_MAPPED | + EROFS_MAP_FRAGMENT; + goto out; + } + + err = z_erofs_do_map_blocks(vi, map, flags); +out: DBG_BUGON(err < 0 && err != -ENOMEM); return err; }
在 2023/7/7 23:52, Yifan Zhao 写道:
This patch updates erofs driver code to catch up with the latest code of erofs_utils (commit e4939f9eaa177e05d697ace85d8dc283e25dc2ed).
LZMA will be supported in the separate patch later.
Signed-off-by: Yifan Zhao zhaoyifan@sjtu.edu.cn
Looks good to me.
Reviewed-by: Huang Jianan jnhuang95@gmail.com
Thanks, Jianan
CI result here: https://github.com/u-boot/u-boot/pull/344
fs/erofs/data.c | 165 ++++++++++++++--------- fs/erofs/decompress.c | 32 ++++- fs/erofs/decompress.h | 3 + fs/erofs/erofs_fs.h | 301 +++++++++++++++++++++++------------------- fs/erofs/fs.c | 12 +- fs/erofs/internal.h | 119 ++++++++++++++--- fs/erofs/namei.c | 44 +++--- fs/erofs/super.c | 33 ++--- fs/erofs/zmap.c | 277 +++++++++++++++++++++++++------------- 9 files changed, 642 insertions(+), 344 deletions(-)
diff --git a/fs/erofs/data.c b/fs/erofs/data.c index 761896054c..f4b21d7917 100644 --- a/fs/erofs/data.c +++ b/fs/erofs/data.c @@ -12,23 +12,23 @@ static int erofs_map_blocks_flatmode(struct erofs_inode *inode, struct erofs_inode *vi = inode; bool tailendpacking = (vi->datalayout == EROFS_INODE_FLAT_INLINE);
- nblocks = DIV_ROUND_UP(inode->i_size, EROFS_BLKSIZ);
nblocks = BLK_ROUND_UP(inode->i_size); lastblk = nblocks - tailendpacking;
/* there is no hole in flatmode */ map->m_flags = EROFS_MAP_MAPPED;
- if (offset < blknr_to_addr(lastblk)) {
map->m_pa = blknr_to_addr(vi->u.i_blkaddr) + map->m_la;
map->m_plen = blknr_to_addr(lastblk) - offset;
- if (offset < erofs_pos(lastblk)) {
map->m_pa = erofs_pos(vi->u.i_blkaddr) + map->m_la;
} else if (tailendpacking) { /* 2 - inode inline B: inode, [xattrs], inline last blk... */ map->m_pa = iloc(vi->nid) + vi->inode_isize + vi->xattr_isize + erofs_blkoff(map->m_la); map->m_plen = inode->i_size - offset;map->m_plen = erofs_pos(lastblk) - offset;
/* inline data should be located in one meta block */
if (erofs_blkoff(map->m_pa) + map->m_plen > PAGE_SIZE) {
/* inline data should be located in the same meta block */
if (erofs_blkoff(map->m_pa) + map->m_plen > erofs_blksiz()) { erofs_err("inline data cross block boundary @ nid %" PRIu64, vi->nid); DBG_BUGON(1);
@@ -55,7 +55,7 @@ int erofs_map_blocks(struct erofs_inode *inode, { struct erofs_inode *vi = inode; struct erofs_inode_chunk_index *idx;
- u8 buf[EROFS_BLKSIZ];
- u8 buf[EROFS_MAX_BLOCK_SIZE]; u64 chunknr; unsigned int unit; erofs_off_t pos;
@@ -87,7 +87,7 @@ int erofs_map_blocks(struct erofs_inode *inode,
map->m_la = chunknr << vi->u.chunkbits; map->m_plen = min_t(erofs_off_t, 1UL << vi->u.chunkbits,
roundup(inode->i_size - map->m_la, EROFS_BLKSIZ));
roundup(inode->i_size - map->m_la, erofs_blksiz()));
/* handle block map */ if (!(vi->u.chunkformat & EROFS_CHUNK_FORMAT_INDEXES)) {
@@ -96,7 +96,7 @@ int erofs_map_blocks(struct erofs_inode *inode, if (le32_to_cpu(*blkaddr) == EROFS_NULL_ADDR) { map->m_flags = 0; } else {
map->m_pa = blknr_to_addr(le32_to_cpu(*blkaddr));
} goto out;map->m_pa = erofs_pos(le32_to_cpu(*blkaddr)); map->m_flags = EROFS_MAP_MAPPED;
@@ -110,7 +110,7 @@ int erofs_map_blocks(struct erofs_inode *inode, default: map->m_deviceid = le16_to_cpu(idx->device_id) & sbi.device_id_mask;
map->m_pa = blknr_to_addr(le32_to_cpu(idx->blkaddr));
map->m_flags = EROFS_MAP_MAPPED; break; }map->m_pa = erofs_pos(le32_to_cpu(idx->blkaddr));
@@ -119,23 +119,23 @@ out: return err; }
-int erofs_map_dev(struct erofs_sb_info *sbi, struct erofs_map_dev *map) +int erofs_map_dev(struct erofs_map_dev *map) { struct erofs_device_info *dif; int id;
if (map->m_deviceid) {
if (sbi->extra_devices < map->m_deviceid)
if (sbi.extra_devices < map->m_deviceid) return -ENODEV;
- } else if (sbi->extra_devices) {
for (id = 0; id < sbi->extra_devices; ++id) {
- } else if (sbi.extra_devices) {
for (id = 0; id < sbi.extra_devices; ++id) { erofs_off_t startoff, length;
dif = sbi->devs + id;
dif = sbi.devs + id; if (!dif->mapped_blkaddr) continue;
startoff = blknr_to_addr(dif->mapped_blkaddr);
length = blknr_to_addr(dif->blocks);
startoff = erofs_pos(dif->mapped_blkaddr);
length = erofs_pos(dif->blocks); if (map->m_pa >= startoff && map->m_pa < startoff + length) {
@@ -147,19 +147,38 @@ int erofs_map_dev(struct erofs_sb_info *sbi, struct erofs_map_dev *map) return 0; }
size_t len)
- int ret;
.m_deviceid = map->m_deviceid,
.m_pa = map->m_pa,
- ret = erofs_map_dev(&mdev);
- if (ret)
return ret;
- ret = erofs_dev_read(mdev.m_deviceid, buffer, mdev.m_pa + offset, len);
- if (ret < 0)
return -EIO;
- static int erofs_read_raw_data(struct erofs_inode *inode, char *buffer, erofs_off_t size, erofs_off_t offset) { struct erofs_map_blocks map = { .index = UINT_MAX, };
struct erofs_map_dev mdev; int ret; erofs_off_t ptr = offset;
while (ptr < offset + size) { char *const estart = buffer + ptr - offset;
erofs_off_t eend;
erofs_off_t eend, moff = 0;
map.m_la = ptr; ret = erofs_map_blocks(inode, &map, 0);
@@ -168,14 +187,6 @@ static int erofs_read_raw_data(struct erofs_inode *inode, char *buffer,
DBG_BUGON(map.m_plen != map.m_llen);
mdev = (struct erofs_map_dev) {
.m_deviceid = map.m_deviceid,
.m_pa = map.m_pa,
ret = erofs_map_dev(&sbi, &mdev);
if (ret)
return ret;
- /* trim extent */ eend = min(offset + size, map.m_la + map.m_llen); DBG_BUGON(ptr < map.m_la);
@@ -193,19 +204,73 @@ static int erofs_read_raw_data(struct erofs_inode *inode, char *buffer, }
if (ptr > map.m_la) {
mdev.m_pa += ptr - map.m_la;
}moff = ptr - map.m_la; map.m_la = ptr;
ret = erofs_dev_read(mdev.m_deviceid, estart, mdev.m_pa,
eend - map.m_la);
if (ret < 0)
return -EIO;
ret = erofs_read_one_data(&map, estart, moff, eend - map.m_la);
if (ret)
ptr = eend; } return 0; }return ret;
- struct erofs_map_dev mdev;
- int ret = 0;
- if (map->m_flags & EROFS_MAP_FRAGMENT) {
struct erofs_inode packed_inode = {
.nid = sbi.packed_nid,
ret = erofs_read_inode_from_disk(&packed_inode);
if (ret) {
erofs_err("failed to read packed inode from disk");
return ret;
return erofs_pread(&packed_inode, buffer, length - skip,
inode->fragmentoff + skip);
- /* no device id here, thus it will always succeed */
- mdev = (struct erofs_map_dev) {
.m_pa = map->m_pa,
- if (ret) {
DBG_BUGON(1);
return ret;
- ret = erofs_dev_read(mdev.m_deviceid, raw, mdev.m_pa, map->m_plen);
- if (ret < 0)
return ret;
- ret = z_erofs_decompress(&(struct z_erofs_decompress_req) {
.in = raw,
.out = buffer,
.decodedskip = skip,
.interlaced_offset =
map->m_algorithmformat == Z_EROFS_COMPRESSION_INTERLACED ?
erofs_blkoff(map->m_la) : 0,
.inputsize = map->m_plen,
.decodedlength = length,
.alg = map->m_algorithmformat,
.partial_decoding = trimmed ? true :
!(map->m_flags & EROFS_MAP_FULL_MAPPED) ||
(map->m_flags & EROFS_MAP_PARTIAL_REF),
- if (ret < 0)
return ret;
- static int z_erofs_read_data(struct erofs_inode *inode, char *buffer, erofs_off_t size, erofs_off_t offset) {
@@ -213,8 +278,7 @@ static int z_erofs_read_data(struct erofs_inode *inode, char *buffer, struct erofs_map_blocks map = { .index = UINT_MAX, };
- bool partial;
- bool trimmed; unsigned int bufsize = 0; char *raw = NULL; int ret = 0;
@@ -227,27 +291,17 @@ static int z_erofs_read_data(struct erofs_inode *inode, char *buffer, if (ret) break;
.m_pa = map.m_pa,
if (ret) {
DBG_BUGON(1);
break;
*/ if (end < map.m_la + map.m_llen) { length = end - map.m_la;
- trim to the needed size if the returned extent is quite
- larger than requested, and set up partial flag as well.
partial = true;
} else { DBG_BUGON(end != map.m_la + map.m_llen); length = map.m_llen;trimmed = true;
partial = !(map.m_flags & EROFS_MAP_FULL_MAPPED);
trimmed = false;
if (map.m_la < offset) {
@@ -272,19 +326,10 @@ static int z_erofs_read_data(struct erofs_inode *inode, char *buffer, break; } }
ret = erofs_dev_read(mdev.m_deviceid, raw, mdev.m_pa, map.m_plen);
if (ret < 0)
break;
.in = raw,
.out = buffer + end - offset,
.inputsize = map.m_plen,
.alg = map.m_algorithmformat,
.partial_decoding = partial
ret = z_erofs_read_one_data(inode, &map, raw,
buffer + end - offset, skip, length,
if (ret < 0) break; }trimmed);
@@ -301,8 +346,8 @@ int erofs_pread(struct erofs_inode *inode, char *buf, case EROFS_INODE_FLAT_INLINE: case EROFS_INODE_CHUNK_BASED: return erofs_read_raw_data(inode, buf, count, offset);
- case EROFS_INODE_FLAT_COMPRESSION_LEGACY:
- case EROFS_INODE_FLAT_COMPRESSION:
- case EROFS_INODE_COMPRESSED_FULL:
- case EROFS_INODE_COMPRESSED_COMPACT: return z_erofs_read_data(inode, buf, count, offset); default: break;
diff --git a/fs/erofs/decompress.c b/fs/erofs/decompress.c index 2be3b844cf..e04e5c34a8 100644 --- a/fs/erofs/decompress.c +++ b/fs/erofs/decompress.c @@ -15,8 +15,8 @@ static int z_erofs_decompress_lz4(struct z_erofs_decompress_req *rq) if (erofs_sb_has_lz4_0padding()) { support_0padding = true;
while (!src[inputmargin & ~PAGE_MASK])
if (!(++inputmargin & ~PAGE_MASK))
while (!src[inputmargin & (erofs_blksiz() - 1)])
if (!(++inputmargin & (erofs_blksiz() - 1))) break;
if (inputmargin >= rq->inputsize)
@@ -40,6 +40,9 @@ static int z_erofs_decompress_lz4(struct z_erofs_decompress_req *rq) rq->decodedlength);
if (ret != (int)rq->decodedlength) {
erofs_err("failed to %s decompress %d in[%u, %u] out[%u]",
rq->partial_decoding ? "partial" : "full",
ret = -EIO; goto out; }ret, rq->inputsize, inputmargin, rq->decodedlength);
@@ -58,13 +61,30 @@ out:
int z_erofs_decompress(struct z_erofs_decompress_req *rq) {
- if (rq->alg == Z_EROFS_COMPRESSION_SHIFTED) {
if (rq->inputsize != EROFS_BLKSIZ)
- if (rq->alg == Z_EROFS_COMPRESSION_INTERLACED) {
unsigned int count, rightpart, skip;
/* XXX: should support inputsize >= erofs_blksiz() later */
if (rq->inputsize > erofs_blksiz()) return -EFSCORRUPTED;
DBG_BUGON(rq->decodedlength > EROFS_BLKSIZ);
DBG_BUGON(rq->decodedlength < rq->decodedskip);
if (rq->decodedlength > erofs_blksiz())
if (rq->decodedlength < rq->decodedskip)
count = rq->decodedlength - rq->decodedskip;
skip = erofs_blkoff(rq->interlaced_offset + rq->decodedskip);
rightpart = min(erofs_blksiz() - skip, count);
memcpy(rq->out, rq->in + skip, rightpart);
memcpy(rq->out + rightpart, rq->in, count - rightpart);
} else if (rq->alg == Z_EROFS_COMPRESSION_SHIFTED) {
if (rq->decodedlength > rq->inputsize)
memcpy(rq->out, rq->in + rq->decodedskip, rq->decodedlength - rq->decodedskip); return 0;
diff --git a/fs/erofs/decompress.h b/fs/erofs/decompress.h index 81d5fb84f6..4752f77950 100644 --- a/fs/erofs/decompress.h +++ b/fs/erofs/decompress.h @@ -14,6 +14,9 @@ struct z_erofs_decompress_req { unsigned int decodedskip; unsigned int inputsize, decodedlength;
- /* cut point of interlaced uncompressed data */
- unsigned int interlaced_offset;
- /* indicate the algorithm will be used for decompression */ unsigned int alg; bool partial_decoding;
diff --git a/fs/erofs/erofs_fs.h b/fs/erofs/erofs_fs.h index 6b62c7a4f5..158e2c68a1 100644 --- a/fs/erofs/erofs_fs.h +++ b/fs/erofs/erofs_fs.h @@ -3,7 +3,7 @@
- EROFS (Enhanced ROM File System) on-disk format definition
- Copyright (C) 2017-2018 HUAWEI, Inc.
http://www.huawei.com/
*/ #ifndef __EROFS_FS_H
https://www.huawei.com/
- Copyright (C) 2021, Alibaba Cloud
@@ -18,33 +18,41 @@ #define EROFS_SUPER_MAGIC_V1 0xE0F5E1E2 #define EROFS_SUPER_OFFSET 1024
-#define EROFS_FEATURE_COMPAT_SB_CHKSUM 0x00000001 +#define EROFS_FEATURE_COMPAT_SB_CHKSUM 0x00000001 +#define EROFS_FEATURE_COMPAT_MTIME 0x00000002
- Any bits that aren't in EROFS_ALL_FEATURE_INCOMPAT should
- be incompatible with this kernel version.
*/ -#define EROFS_FEATURE_INCOMPAT_LZ4_0PADDING 0x00000001 +#define EROFS_FEATURE_INCOMPAT_ZERO_PADDING 0x00000001 #define EROFS_FEATURE_INCOMPAT_COMPR_CFGS 0x00000002 #define EROFS_FEATURE_INCOMPAT_BIG_PCLUSTER 0x00000002 #define EROFS_FEATURE_INCOMPAT_CHUNKED_FILE 0x00000004 #define EROFS_FEATURE_INCOMPAT_DEVICE_TABLE 0x00000008 +#define EROFS_FEATURE_INCOMPAT_COMPR_HEAD2 0x00000008 +#define EROFS_FEATURE_INCOMPAT_ZTAILPACKING 0x00000010 +#define EROFS_FEATURE_INCOMPAT_FRAGMENTS 0x00000020 +#define EROFS_FEATURE_INCOMPAT_DEDUPE 0x00000020 +#define EROFS_FEATURE_INCOMPAT_XATTR_PREFIXES 0x00000040 #define EROFS_ALL_FEATURE_INCOMPAT \
- (EROFS_FEATURE_INCOMPAT_LZ4_0PADDING | \
- (EROFS_FEATURE_INCOMPAT_ZERO_PADDING | \ EROFS_FEATURE_INCOMPAT_COMPR_CFGS | \ EROFS_FEATURE_INCOMPAT_BIG_PCLUSTER | \ EROFS_FEATURE_INCOMPAT_CHUNKED_FILE | \
EROFS_FEATURE_INCOMPAT_DEVICE_TABLE)
EROFS_FEATURE_INCOMPAT_DEVICE_TABLE | \
EROFS_FEATURE_INCOMPAT_COMPR_HEAD2 | \
EROFS_FEATURE_INCOMPAT_ZTAILPACKING | \
EROFS_FEATURE_INCOMPAT_FRAGMENTS | \
EROFS_FEATURE_INCOMPAT_DEDUPE | \
EROFS_FEATURE_INCOMPAT_XATTR_PREFIXES)
#define EROFS_SB_EXTSLOT_SIZE 16
struct erofs_deviceslot {
- union {
u8 uuid[16]; /* used for device manager later */
u8 userdata[64]; /* digest(sha256), etc. */
- } u;
- __le32 blocks; /* total fs blocks of this device */
- __le32 mapped_blkaddr; /* map starting at mapped_blkaddr */
- u8 tag[64]; /* digest(sha256), etc. */
- __le32 mapped_blkaddr; /* map starting at mapped_blkaddr */ u8 reserved[56]; };
@@ -55,14 +63,14 @@ struct erofs_super_block { __le32 magic; /* file system magic number */ __le32 checksum; /* crc32c(super_block) */ __le32 feature_compat;
- __u8 blkszbits; /* support block_size == PAGE_SIZE only */
__u8 blkszbits; /* filesystem block size in bit shift */ __u8 sb_extslots; /* superblock size = 128 + sb_extslots * 16 */
__le16 root_nid; /* nid of root directory */ __le64 inos; /* total valid ino # (== f_files - f_favail) */
- __le64 build_time; /* inode v1 time derivation */
- __le32 build_time_nsec; /* inode v1 time derivation in nano scale */
- __le64 build_time; /* compact inode time derivation */
- __le32 build_time_nsec; /* compact inode time derivation in ns scale */ __le32 blocks; /* used for statfs */ __le32 meta_blkaddr; /* start block address of metadata area */ __le32 xattr_blkaddr; /* start block address of shared xattr area */
@@ -77,39 +85,38 @@ struct erofs_super_block { } __packed u1; __le16 extra_devices; /* # of devices besides the primary device */ __le16 devt_slotoff; /* startoff = devt_slotoff * devt_slotsize */
- __u8 reserved2[38];
__u8 dirblkbits; /* directory block size in bit shift */
__u8 xattr_prefix_count; /* # of long xattr name prefixes */
__le32 xattr_prefix_start; /* start of long xattr prefixes */
__le64 packed_nid; /* nid of the special packed inode */
__u8 reserved2[24]; };
- erofs inode datalayout (i_format in on-disk inode):
- 0 - inode plain without inline data A:
- inode, [xattrs], ... | ... | no-holed data
- 1 - inode VLE compression B (legacy):
- inode, [xattrs], extents ... | ...
- 2 - inode plain with inline data C:
- inode, [xattrs], last_inline_data, ... | ... | no-holed data
- 3 - inode compression D:
- inode, [xattrs], map_header, extents ... | ...
- 4 - inode chunk-based E:
- inode, [xattrs], chunk indexes ... | ...
- EROFS inode datalayout (i_format in on-disk inode):
- 0 - uncompressed flat inode without tail-packing inline data:
- 1 - compressed inode with non-compact indexes:
- 2 - uncompressed flat inode with tail-packing inline data:
- 3 - compressed inode with compact indexes:
*/ enum { EROFS_INODE_FLAT_PLAIN = 0,
- 4 - chunk-based inode with (optional) multi-device support:
- 5~7 - reserved
- EROFS_INODE_FLAT_COMPRESSION_LEGACY = 1,
- EROFS_INODE_COMPRESSED_FULL = 1, EROFS_INODE_FLAT_INLINE = 2,
- EROFS_INODE_FLAT_COMPRESSION = 3,
EROFS_INODE_COMPRESSED_COMPACT = 3, EROFS_INODE_CHUNK_BASED = 4, EROFS_INODE_DATALAYOUT_MAX };
static inline bool erofs_inode_is_data_compressed(unsigned int datamode) {
- return datamode == EROFS_INODE_FLAT_COMPRESSION ||
datamode == EROFS_INODE_FLAT_COMPRESSION_LEGACY;
- return datamode == EROFS_INODE_COMPRESSED_COMPACT ||
}datamode == EROFS_INODE_COMPRESSED_FULL;
-/* bit definitions of inode i_advise */ +/* bit definitions of inode i_format */ #define EROFS_I_VERSION_BITS 1 #define EROFS_I_DATALAYOUT_BITS 3
@@ -127,11 +134,30 @@ static inline bool erofs_inode_is_data_compressed(unsigned int datamode) #define EROFS_CHUNK_FORMAT_ALL \ (EROFS_CHUNK_FORMAT_BLKBITS_MASK | EROFS_CHUNK_FORMAT_INDEXES)
+/* 32-byte on-disk inode */ +#define EROFS_INODE_LAYOUT_COMPACT 0 +/* 64-byte on-disk inode */ +#define EROFS_INODE_LAYOUT_EXTENDED 1
- struct erofs_inode_chunk_info { __le16 format; /* chunk blkbits, etc. */ __le16 reserved; };
+union erofs_inode_i_u {
- /* total compressed blocks for compressed inodes */
- __le32 compressed_blocks;
- /* block address for uncompressed flat inodes */
- __le32 raw_blkaddr;
- /* for device files, used to indicate old/new device # */
- __le32 rdev;
- /* for chunk-based files, it contains the summary info */
- struct erofs_inode_chunk_info c;
- /* 32-byte reduced form of an ondisk inode */ struct erofs_inode_compact { __le16 i_format; /* inode format hints */
@@ -142,28 +168,14 @@ struct erofs_inode_compact { __le16 i_nlink; __le32 i_size; __le32 i_reserved;
- union {
/* file total compressed blocks for data mapping 1 */
__le32 raw_blkaddr;
- union erofs_inode_i_u i_u;
__le32 rdev;
- } i_u;
- __le32 i_ino; /* only used for 32-bit stat compatibility */
- __le32 i_ino; /* only used for 32-bit stat compatibility */ __le16 i_uid; __le16 i_gid; __le32 i_reserved2; };
-/* 32 bytes on-disk inode */ -#define EROFS_INODE_LAYOUT_COMPACT 0 -/* 64 bytes on-disk inode */ -#define EROFS_INODE_LAYOUT_EXTENDED 1
- /* 64-byte complete form of an ondisk inode */ struct erofs_inode_extended { __le16 i_format; /* inode format hints */
@@ -173,33 +185,17 @@ struct erofs_inode_extended { __le16 i_mode; __le16 i_reserved; __le64 i_size;
- union {
__le32 raw_blkaddr;
__le32 rdev;
- } i_u;
- /* only used for 32-bit stat compatibility */
- __le32 i_ino;
__le32 i_ino; /* only used for 32-bit stat compatibility */ __le32 i_uid; __le32 i_gid;
- __le64 i_ctime;
- __le32 i_ctime_nsec;
- __le64 i_mtime;
- __le32 i_mtime_nsec; __le32 i_nlink; __u8 i_reserved2[16]; };
-#define EROFS_MAX_SHARED_XATTRS (128) -/* h_shared_count between 129 ... 255 are special # */ -#define EROFS_SHARED_XATTR_EXTENT (255)
- inline xattrs (n == i_xattr_icount):
- erofs_xattr_ibody_header(1) + (n - 1) * 4 bytes
@@ -226,6 +222,13 @@ struct erofs_xattr_ibody_header { #define EROFS_XATTR_INDEX_LUSTRE 5 #define EROFS_XATTR_INDEX_SECURITY 6
- bit 7 of e_name_index is set when it refers to a long xattr name prefix,
- while the remained lower bits represent the index of the prefix.
+#define EROFS_XATTR_LONG_PREFIX 0x80 +#define EROFS_XATTR_LONG_PREFIX_MASK 0x7f
- /* xattr entry (for both inline & shared xattrs) */ struct erofs_xattr_entry { __u8 e_name_len; /* length of name */
@@ -235,6 +238,12 @@ struct erofs_xattr_entry { char e_name[0]; /* attribute name */ };
+/* long xattr name prefix */ +struct erofs_xattr_long_prefix {
- __u8 base_index; /* short xattr name prefix index */
- char infix[0]; /* infix apart from short prefix */
- static inline unsigned int erofs_xattr_ibody_size(__le16 i_xattr_icount) { if (!i_xattr_icount)
@@ -265,6 +274,29 @@ struct erofs_inode_chunk_index { __le32 blkaddr; /* start block address of this inode chunk */ };
+/* dirent sorts in alphabet order, thus we can do binary search */ +struct erofs_dirent {
+} __packed;
+/* file types used in inode_info->flags */ +enum {
- EROFS_FT_UNKNOWN,
- EROFS_FT_DIR,
- EROFS_FT_CHRDEV,
- EROFS_FT_BLKDEV,
- EROFS_FT_FIFO,
- EROFS_FT_SOCK,
- EROFS_FT_SYMLINK,
- EROFS_FT_MAX
+#define EROFS_NAME_LEN 255
- /* maximum supported size of a physical compression cluster */ #define Z_EROFS_PCLUSTER_MAX_SIZE (1024 * 1024)
@@ -275,7 +307,7 @@ enum { Z_EROFS_COMPRESSION_MAX };
-#define Z_EROFS_ALL_COMPR_ALGS (1 << (Z_EROFS_COMPRESSION_MAX - 1)) +#define Z_EROFS_ALL_COMPR_ALGS ((1 << Z_EROFS_COMPRESSION_MAX) - 1)
/* 14 bytes (+ length field = 16 bytes) */ struct z_erofs_lz4_cfgs { @@ -290,6 +322,7 @@ struct z_erofs_lzma_cfgs { __le16 format; u8 reserved[8]; } __packed;
#define Z_EROFS_LZMA_MAX_DICT_SIZE (8 * Z_EROFS_PCLUSTER_MAX_SIZE)
@@ -298,13 +331,28 @@ struct z_erofs_lzma_cfgs {
(4B) + 2B + (4B) if compacted 2B is on.
- bit 1 : HEAD1 big pcluster (0 - off; 1 - on)
- bit 2 : HEAD2 big pcluster (0 - off; 1 - on)
- bit 3 : tailpacking inline pcluster (0 - off; 1 - on)
- bit 4 : interlaced plain pcluster (0 - off; 1 - on)
*/ #define Z_EROFS_ADVISE_COMPACTED_2B 0x0001 #define Z_EROFS_ADVISE_BIG_PCLUSTER_1 0x0002 #define Z_EROFS_ADVISE_BIG_PCLUSTER_2 0x0004
- bit 5 : fragment pcluster (0 - off; 1 - on)
+#define Z_EROFS_ADVISE_INLINE_PCLUSTER 0x0008 +#define Z_EROFS_ADVISE_INTERLACED_PCLUSTER 0x0010 +#define Z_EROFS_ADVISE_FRAGMENT_PCLUSTER 0x0020
+#define Z_EROFS_FRAGMENT_INODE_BIT 7 struct z_erofs_map_header {
- __le32 h_reserved1;
- union {
/* fragment data offset in the packed inode */
__le32 h_fragmentoff;
struct {
__le16 h_reserved1;
/* indicates the encoded size of tailpacking data */
__le16 h_idata_size;
- }; __le16 h_advise; /*
- bit 0-3 : algorithm type of head 1 (logical cluster type 01);
@@ -313,107 +361,85 @@ struct z_erofs_map_header { __u8 h_algorithmtype; /* * bit 0-2 : logical cluster bits - 12, e.g. 0 for 4096;
* bit 3-7 : reserved.
* bit 3-6 : reserved;
*/ __u8 h_clusterbits; };* bit 7 : move the whole file into packed inode or not.
-#define Z_EROFS_VLE_LEGACY_HEADER_PADDING 8
- Fixed-sized output compression ondisk Logical Extent cluster type:
- 0 - literal (uncompressed) cluster
- 1 - compressed cluster (for the head logical cluster)
- 2 - compressed cluster (for the other logical clusters)
- On-disk logical cluster type:
- 0 - literal (uncompressed) lcluster
- 1,3 - compressed lcluster (for HEAD lclusters)
- 2 - compressed lcluster (for NONHEAD lclusters)
- In detail,
- 0 - literal (uncompressed) cluster,
- 0 - literal (uncompressed) lcluster,
di_advise = 0
di_clusterofs = the literal data offset of the cluster
di_blkaddr = the blkaddr of the literal cluster
di_clusterofs = the literal data offset of the lcluster
di_blkaddr = the blkaddr of the literal pcluster
di_advise = 1
di_clusterofs = the decompressed data offset of the cluster
di_blkaddr = the blkaddr of the compressed cluster
di_advise = 1 or 3
di_clusterofs = the decompressed data offset of the lcluster
di_blkaddr = the blkaddr of the compressed pcluster
di_advise = 2
di_clusterofs =
the decompressed data offset in its own head cluster
di_u.delta[0] = distance to its corresponding head cluster
di_u.delta[1] = distance to its corresponding tail cluster
(di_advise could be 0, 1 or 2)
the decompressed data offset in its own HEAD lcluster
di_u.delta[0] = distance to this HEAD lcluster
*/ enum {
di_u.delta[1] = distance to the next HEAD lcluster
- Z_EROFS_VLE_CLUSTER_TYPE_PLAIN = 0,
- Z_EROFS_VLE_CLUSTER_TYPE_HEAD = 1,
- Z_EROFS_VLE_CLUSTER_TYPE_NONHEAD = 2,
- Z_EROFS_VLE_CLUSTER_TYPE_RESERVED = 3,
- Z_EROFS_LCLUSTER_TYPE_PLAIN = 0,
- Z_EROFS_LCLUSTER_TYPE_HEAD1 = 1,
- Z_EROFS_LCLUSTER_TYPE_NONHEAD = 2,
- Z_EROFS_LCLUSTER_TYPE_HEAD2 = 3,
- Z_EROFS_LCLUSTER_TYPE_MAX };
-#define Z_EROFS_VLE_DI_CLUSTER_TYPE_BITS 2 -#define Z_EROFS_VLE_DI_CLUSTER_TYPE_BIT 0 +#define Z_EROFS_LI_LCLUSTER_TYPE_BITS 2 +#define Z_EROFS_LI_LCLUSTER_TYPE_BIT 0
+/* (noncompact only, HEAD) This pcluster refers to partial decompressed data */ +#define Z_EROFS_LI_PARTIAL_REF (1 << 15)
- D0_CBLKCNT will be marked _only_ at the 1st non-head lcluster to store the
- compressed block count of a compressed extent (in logical clusters, aka.
- block count of a pcluster).
*/ -#define Z_EROFS_VLE_DI_D0_CBLKCNT (1 << 11) +#define Z_EROFS_LI_D0_CBLKCNT (1 << 11)
-struct z_erofs_vle_decompressed_index { +struct z_erofs_lcluster_index { __le16 di_advise;
- /* where to decompress in the head cluster */
/* where to decompress in the head lcluster */ __le16 di_clusterofs;
union {
/* for the head cluster */
__le32 blkaddr; /*/* for the HEAD lclusters */
* for the rest clusters
* eg. for 4k page-sized cluster, maximum 4K*64k = 256M)
* [0] - pointing to the head cluster
* [1] - pointing to the tail cluster
* for the NONHEAD lclusters
* [0] - distance to its HEAD lcluster
*/ __le16 delta[2]; } di_u; };* [1] - distance to the next HEAD lcluster
-#define Z_EROFS_VLE_LEGACY_INDEX_ALIGN(size) \
- (round_up(size, sizeof(struct z_erofs_vle_decompressed_index)) + \
sizeof(struct z_erofs_map_header) + Z_EROFS_VLE_LEGACY_HEADER_PADDING)
-#define Z_EROFS_VLE_EXTENT_ALIGN(size) round_up(size, \
-/* dirent sorts in alphabet order, thus we can do binary search */ -struct erofs_dirent {
- __le64 nid; /* node number */
- __le16 nameoff; /* start offset of file name */
- __u8 file_type; /* file type */
- __u8 reserved; /* reserved */
-} __packed;
-/* file types used in inode_info->flags */ -enum {
- EROFS_FT_UNKNOWN,
- EROFS_FT_REG_FILE,
- EROFS_FT_DIR,
- EROFS_FT_CHRDEV,
- EROFS_FT_BLKDEV,
- EROFS_FT_FIFO,
- EROFS_FT_SOCK,
- EROFS_FT_SYMLINK,
- EROFS_FT_MAX
-#define EROFS_NAME_LEN 255 +#define Z_EROFS_FULL_INDEX_ALIGN(end) \
(round_up(end, 8) + sizeof(struct z_erofs_map_header) + 8)
/* check the EROFS on-disk layout strictly at compile time */ static inline void erofs_check_ondisk_layout_definitions(void) {
const __le64 fmh __maybe_unused =
*(__le64 *)&(struct z_erofs_map_header) {
.h_clusterbits = 1 << Z_EROFS_FRAGMENT_INODE_BIT
BUILD_BUG_ON(sizeof(struct erofs_super_block) != 128); BUILD_BUG_ON(sizeof(struct erofs_inode_compact) != 32); BUILD_BUG_ON(sizeof(struct erofs_inode_extended) != 64);
@@ -422,15 +448,18 @@ static inline void erofs_check_ondisk_layout_definitions(void) BUILD_BUG_ON(sizeof(struct erofs_inode_chunk_info) != 4); BUILD_BUG_ON(sizeof(struct erofs_inode_chunk_index) != 8); BUILD_BUG_ON(sizeof(struct z_erofs_map_header) != 8);
- BUILD_BUG_ON(sizeof(struct z_erofs_vle_decompressed_index) != 8);
- BUILD_BUG_ON(sizeof(struct z_erofs_lcluster_index) != 8); BUILD_BUG_ON(sizeof(struct erofs_dirent) != 12); /* keep in sync between 2 index structures for better extendibility */ BUILD_BUG_ON(sizeof(struct erofs_inode_chunk_index) !=
sizeof(struct z_erofs_vle_decompressed_index));
BUILD_BUG_ON(sizeof(struct erofs_deviceslot) != 128);sizeof(struct z_erofs_lcluster_index));
- BUILD_BUG_ON(BIT(Z_EROFS_VLE_DI_CLUSTER_TYPE_BITS) <
Z_EROFS_VLE_CLUSTER_TYPE_MAX - 1);
BUILD_BUG_ON(BIT(Z_EROFS_LI_LCLUSTER_TYPE_BITS) <
Z_EROFS_LCLUSTER_TYPE_MAX - 1);
/* exclude old compiler versions like gcc 7.5.0 */
BUILD_BUG_ON(__builtin_constant_p(fmh) ?
fmh != cpu_to_le64(1ULL << 63) : 0);
#endif
diff --git a/fs/erofs/fs.c b/fs/erofs/fs.c index 89269750f8..7bd2e8fcfc 100644 --- a/fs/erofs/fs.c +++ b/fs/erofs/fs.c @@ -25,8 +25,8 @@ int erofs_dev_read(int device_id, void *buf, u64 offset, size_t len)
int erofs_blk_read(void *buf, erofs_blk_t start, u32 nblocks) {
- return erofs_dev_read(0, buf, blknr_to_addr(start),
blknr_to_addr(nblocks));
return erofs_dev_read(0, buf, erofs_pos(start),
erofs_pos(nblocks));
int erofs_probe(struct blk_desc *fs_dev_desc,
@@ -52,7 +52,7 @@ struct erofs_dir_stream { struct fs_dirent dirent;
struct erofs_inode inode;
- char dblk[EROFS_BLKSIZ];
- char dblk[EROFS_MAX_BLOCK_SIZE]; unsigned int maxsize, de_end; erofs_off_t pos; };
@@ -125,7 +125,7 @@ int erofs_readdir(struct fs_dir_stream *fs_dirs, struct fs_dirent **dentp) return 1;
if (!dirs->maxsize) {
dirs->maxsize = min_t(unsigned int, EROFS_BLKSIZ,
dirs->maxsize = min_t(unsigned int, EROFS_MAX_BLOCK_SIZE, dirs->inode.i_size - pos);
err = erofs_pread(&dirs->inode, dirs->dblk,
@@ -136,7 +136,7 @@ int erofs_readdir(struct fs_dir_stream *fs_dirs, struct fs_dirent **dentp) de = (struct erofs_dirent *)dirs->dblk; dirs->de_end = le16_to_cpu(de->nameoff); if (dirs->de_end < sizeof(struct erofs_dirent) ||
dirs->de_end >= EROFS_BLKSIZ) {
dirs->de_end >= EROFS_MAX_BLOCK_SIZE) { erofs_err("invalid de[0].nameoff %u @ nid %llu", dirs->de_end, de->nid | 0ULL); return -EFSCORRUPTED;
@@ -183,7 +183,7 @@ int erofs_readdir(struct fs_dir_stream *fs_dirs, struct fs_dirent **dentp)
pos += sizeof(*de); if (erofs_blkoff(pos) >= dirs->de_end) {
pos = blknr_to_addr(erofs_blknr(pos) + 1);
dirs->maxsize = 0; } dirs->pos = pos;pos = erofs_pos(erofs_blknr(pos) + 1);
diff --git a/fs/erofs/internal.h b/fs/erofs/internal.h index 4af7c91560..433a3c6c1e 100644 --- a/fs/erofs/internal.h +++ b/fs/erofs/internal.h @@ -2,6 +2,7 @@ #ifndef __EROFS_INTERNAL_H #define __EROFS_INTERNAL_H
+#include "linux/compat.h" #define __packed __attribute__((__packed__))
#include <linux/stat.h> @@ -30,8 +31,9 @@
#define PAGE_MASK (~(PAGE_SIZE - 1))
-#define LOG_BLOCK_SIZE (12) -#define EROFS_BLKSIZ (1U << LOG_BLOCK_SIZE) +#ifndef EROFS_MAX_BLOCK_SIZE +#define EROFS_MAX_BLOCK_SIZE PAGE_SIZE +#endif
#define EROFS_ISLOTBITS 5 #define EROFS_SLOTSIZE (1U << EROFS_ISLOTBITS) @@ -44,11 +46,15 @@ typedef u32 erofs_blk_t; #define NULL_ADDR ((unsigned int)-1) #define NULL_ADDR_UL ((unsigned long)-1)
-#define erofs_blknr(addr) ((addr) / EROFS_BLKSIZ) -#define erofs_blkoff(addr) ((addr) % EROFS_BLKSIZ) -#define blknr_to_addr(nr) ((erofs_off_t)(nr) * EROFS_BLKSIZ) +/* global sbi */ +extern struct erofs_sb_info sbi;
+#define erofs_blksiz() (1u << sbi.blkszbits) +#define erofs_blknr(addr) ((addr) >> sbi.blkszbits) +#define erofs_blkoff(addr) ((addr) & (erofs_blksiz() - 1)) +#define erofs_pos(nr) ((erofs_off_t)(nr) << sbi.blkszbits)
-#define BLK_ROUND_UP(addr) DIV_ROUND_UP(addr, EROFS_BLKSIZ) +#define BLK_ROUND_UP(addr) DIV_ROUND_UP(addr, 1u << sbi.blkszbits)
struct erofs_buffer_head;
@@ -57,6 +63,8 @@ struct erofs_device_info { u32 mapped_blkaddr; };
+#define EROFS_PACKED_NID_UNALLOCATED -1
- struct erofs_sb_info { struct erofs_device_info *devs;
@@ -72,6 +80,7 @@ struct erofs_sb_info { u32 build_time_nsec;
unsigned char islotbits;
unsigned char blkszbits;
/* what we really care is nid, rather than ino.. */ erofs_nid_t root_nid;
@@ -79,23 +88,29 @@ struct erofs_sb_info { u64 inos;
u8 uuid[16];
char volume_name[16];
u16 available_compr_algs; u16 lz4_max_distance;
u32 checksum; u16 extra_devices; union { u16 devt_slotoff; /* used for mkfs */ u16 device_id_mask; /* used for others */ };
erofs_nid_t packed_nid;
u32 xattr_prefix_start;
u8 xattr_prefix_count; };
-/* global sbi */ -extern struct erofs_sb_info sbi; +/* make sure that any user of the erofs headers has at least 64bit off_t type */ +extern int erofs_assert_largefile[sizeof(off_t) - 8];
static inline erofs_off_t iloc(erofs_nid_t nid) {
- return blknr_to_addr(sbi.meta_blkaddr) + (nid << sbi.islotbits);
return erofs_pos(sbi.meta_blkaddr) + (nid << sbi.islotbits); }
#define EROFS_FEATURE_FUNCS(name, compat, feature) \
@@ -112,11 +127,15 @@ static inline void erofs_sb_clear_##name(void) \ sbi.feature_##compat &= ~EROFS_FEATURE_##feature; \ }
-EROFS_FEATURE_FUNCS(lz4_0padding, incompat, INCOMPAT_LZ4_0PADDING) +EROFS_FEATURE_FUNCS(lz4_0padding, incompat, INCOMPAT_ZERO_PADDING) EROFS_FEATURE_FUNCS(compr_cfgs, incompat, INCOMPAT_COMPR_CFGS) EROFS_FEATURE_FUNCS(big_pcluster, incompat, INCOMPAT_BIG_PCLUSTER) EROFS_FEATURE_FUNCS(chunked_file, incompat, INCOMPAT_CHUNKED_FILE) EROFS_FEATURE_FUNCS(device_table, incompat, INCOMPAT_DEVICE_TABLE) +EROFS_FEATURE_FUNCS(ztailpacking, incompat, INCOMPAT_ZTAILPACKING) +EROFS_FEATURE_FUNCS(fragments, incompat, INCOMPAT_FRAGMENTS) +EROFS_FEATURE_FUNCS(dedupe, incompat, INCOMPAT_DEDUPE) +EROFS_FEATURE_FUNCS(xattr_prefixes, incompat, INCOMPAT_XATTR_PREFIXES) EROFS_FEATURE_FUNCS(sb_chksum, compat, COMPAT_SB_CHKSUM)
#define EROFS_I_EA_INITED (1 << 0) @@ -130,6 +149,8 @@ struct erofs_inode { unsigned int flags; /* (mkfs.erofs) device ID containing source file */ u32 dev;
/* (mkfs.erofs) queued sub-directories blocking dump */
}; unsigned int i_count; struct erofs_inode *i_parent;u32 subdirs_queued;
@@ -140,8 +161,8 @@ struct erofs_inode { u64 i_ino[2]; u32 i_uid; u32 i_gid;
- u64 i_ctime;
- u32 i_ctime_nsec;
u64 i_mtime;
u32 i_mtime_nsec; u32 i_nlink;
union {
@@ -154,20 +175,31 @@ struct erofs_inode { }; } u;
char *i_srcpath;
unsigned char datalayout; unsigned char inode_isize; /* inline tail-end packing size */ unsigned short idata_size;
bool compressed_idata;
bool lazy_tailblock;
unsigned int xattr_isize; unsigned int extent_isize;
unsigned int xattr_shared_count;
unsigned int *xattr_shared_xattrs;
erofs_nid_t nid; struct erofs_buffer_head *bh; struct erofs_buffer_head *bh_inline, *bh_data;
void *idata;
/* (ztailpacking) in order to recover uncompressed EOF data */
void *eof_tailraw;
unsigned int eof_tailrawsize;
union { void *compressmeta; void *chunkindexes;
@@ -176,8 +208,14 @@ struct erofs_inode { uint8_t z_algorithmtype[2]; uint8_t z_logical_clusterbits; uint8_t z_physical_clusterblks;
uint64_t z_tailextent_headlcn;
unsigned int z_idataoff;
+#define z_idata_size idata_size }; };
uint64_t capabilities;
erofs_off_t fragmentoff;
unsigned int fragment_size; };
static inline bool is_inode_layout_compression(struct erofs_inode *inode)
@@ -216,6 +254,14 @@ struct erofs_dentry { }; };
+static inline bool is_dot_dotdot_len(const char *name, unsigned int len) +{
- if (len >= 1 && name[0] != '.')
return false;
- return len == 1 || (len == 2 && name[1] == '.');
- static inline bool is_dot_dotdot(const char *name) { if (name[0] != '.')
@@ -229,6 +275,8 @@ enum { BH_Mapped, BH_Encoded, BH_FullMapped,
BH_Fragment,
BH_Partialref, };
/* Has a disk mapping */
@@ -239,9 +287,13 @@ enum { #define EROFS_MAP_ENCODED (1 << BH_Encoded) /* The length of extent is full */ #define EROFS_MAP_FULL_MAPPED (1 << BH_FullMapped) +/* Located in the special packed inode */ +#define EROFS_MAP_FRAGMENT (1 << BH_Fragment) +/* The extent refers to partial decompressed data */ +#define EROFS_MAP_PARTIAL_REF (1 << BH_Partialref)
struct erofs_map_blocks {
- char mpage[EROFS_BLKSIZ];
char mpage[EROFS_MAX_BLOCK_SIZE];
erofs_off_t m_pa, m_la; u64 m_plen, m_llen;
@@ -257,9 +309,12 @@ struct erofs_map_blocks {
- approach instead if possible since it's more metadata lightweight.)
*/ #define EROFS_GET_BLOCKS_FIEMAP 0x0002 +/* Used to map tail extent for tailpacking inline or fragment pcluster */ +#define EROFS_GET_BLOCKS_FINDTAIL 0x0008
enum { Z_EROFS_COMPRESSION_SHIFTED = Z_EROFS_COMPRESSION_MAX,
- Z_EROFS_COMPRESSION_INTERLACED, Z_EROFS_COMPRESSION_RUNTIME_MAX };
@@ -274,6 +329,7 @@ int erofs_dev_read(int device_id, void *buf, u64 offset, size_t len);
/* super.c */ int erofs_read_superblock(void); +void erofs_put_super(void);
/* namei.c */ int erofs_read_inode_from_disk(struct erofs_inode *vi); @@ -283,9 +339,40 @@ int erofs_read_inode_from_disk(struct erofs_inode *vi); /* data.c */ int erofs_pread(struct erofs_inode *inode, char *buf, erofs_off_t count, erofs_off_t offset); -int erofs_map_blocks(struct erofs_inode *inode,
struct erofs_map_blocks *map, int flags);
-int erofs_map_dev(struct erofs_sb_info *sbi, struct erofs_map_dev *map); +int erofs_map_blocks(struct erofs_inode *inode, struct erofs_map_blocks *map,
int flags);
+int erofs_map_dev(struct erofs_map_dev *map); +int erofs_read_one_data(struct erofs_map_blocks *map, char *buffer, u64 offset,
size_t len);
+int z_erofs_read_one_data(struct erofs_inode *inode,
struct erofs_map_blocks *map, char *raw, char *buffer,
erofs_off_t skip, erofs_off_t length, bool trimmed);
+static inline int erofs_get_occupied_size(const struct erofs_inode *inode,
erofs_off_t *size)
- *size = 0;
- switch (inode->datalayout) {
- case EROFS_INODE_FLAT_INLINE:
- case EROFS_INODE_FLAT_PLAIN:
- case EROFS_INODE_CHUNK_BASED:
*size = inode->i_size;
break;
*size = inode->u.i_blocks * erofs_blksiz();
break;
- default:
return -EOPNOTSUPP;
+/* data.c */ +int erofs_getxattr(struct erofs_inode *vi, const char *name, char *buffer,
size_t buffer_size);
+int erofs_listxattr(struct erofs_inode *vi, char *buffer, size_t buffer_size);
- /* zmap.c */ int z_erofs_fill_inode(struct erofs_inode *vi); int z_erofs_map_blocks_iter(struct erofs_inode *vi,
diff --git a/fs/erofs/namei.c b/fs/erofs/namei.c index d1d4757c50..bde995f1bf 100644 --- a/fs/erofs/namei.c +++ b/fs/erofs/namei.c @@ -1,6 +1,15 @@ // SPDX-License-Identifier: GPL-2.0+ #include "internal.h"
+#define makedev(major, minor) ((dev_t)((((major) & 0xfff) << 8) | ((minor) & 0xff))) +static dev_t erofs_new_decode_dev(u32 dev) +{
- const unsigned int major = (dev & 0xfff00) >> 8;
- const unsigned int minor = (dev & 0xff) | ((dev >> 12) & 0xfff00);
- return makedev(major, minor);
- int erofs_read_inode_from_disk(struct erofs_inode *vi) { int ret, ifmt;
@@ -26,7 +35,8 @@ int erofs_read_inode_from_disk(struct erofs_inode *vi) case EROFS_INODE_LAYOUT_EXTENDED: vi->inode_isize = sizeof(struct erofs_inode_extended);
ret = erofs_dev_read(0, buf + sizeof(*dic), inode_loc + sizeof(*dic),
if (ret < 0) return -EIO;inode_loc + sizeof(*dic), sizeof(*die) - sizeof(*dic));
@@ -43,7 +53,8 @@ int erofs_read_inode_from_disk(struct erofs_inode *vi) break; case S_IFCHR: case S_IFBLK:
vi->u.i_rdev = 0;
vi->u.i_rdev =
case S_IFIFO: case S_IFSOCK:erofs_new_decode_dev(le32_to_cpu(die->i_u.rdev)); break;
@@ -57,8 +68,8 @@ int erofs_read_inode_from_disk(struct erofs_inode *vi) vi->i_gid = le32_to_cpu(die->i_gid); vi->i_nlink = le32_to_cpu(die->i_nlink);
vi->i_ctime = le64_to_cpu(die->i_ctime);
vi->i_ctime_nsec = le64_to_cpu(die->i_ctime_nsec);
vi->i_mtime = le64_to_cpu(die->i_mtime);
vi->i_size = le64_to_cpu(die->i_size); if (vi->datalayout == EROFS_INODE_CHUNK_BASED) /* fill chunked inode summary info */vi->i_mtime_nsec = le64_to_cpu(die->i_mtime_nsec);
@@ -77,7 +88,8 @@ int erofs_read_inode_from_disk(struct erofs_inode *vi) break; case S_IFCHR: case S_IFBLK:
vi->u.i_rdev = 0;
vi->u.i_rdev =
case S_IFIFO: case S_IFSOCK:erofs_new_decode_dev(le32_to_cpu(dic->i_u.rdev)); break;
@@ -91,8 +103,8 @@ int erofs_read_inode_from_disk(struct erofs_inode *vi) vi->i_gid = le16_to_cpu(dic->i_gid); vi->i_nlink = le16_to_cpu(dic->i_nlink);
vi->i_ctime = sbi.build_time;
vi->i_ctime_nsec = sbi.build_time_nsec;
vi->i_mtime = sbi.build_time;
vi->i_mtime_nsec = sbi.build_time_nsec;
vi->i_size = le32_to_cpu(dic->i_size); if (vi->datalayout == EROFS_INODE_CHUNK_BASED)
@@ -111,10 +123,13 @@ int erofs_read_inode_from_disk(struct erofs_inode *vi) vi->u.chunkformat, vi->nid | 0ULL); return -EOPNOTSUPP; }
vi->u.chunkbits = LOG_BLOCK_SIZE +
vi->u.chunkbits = sbi.blkszbits + (vi->u.chunkformat & EROFS_CHUNK_FORMAT_BLKBITS_MASK);
- } else if (erofs_inode_is_data_compressed(vi->datalayout))
z_erofs_fill_inode(vi);
- } else if (erofs_inode_is_data_compressed(vi->datalayout)) {
if (erofs_blksiz() != EROFS_MAX_BLOCK_SIZE)
return -EOPNOTSUPP;
return z_erofs_fill_inode(vi);
- } return 0; bogusimode: erofs_err("bogus i_mode (%o) @ nid %llu", vi->i_mode, vi->nid | 0ULL);
@@ -163,12 +178,11 @@ struct nameidata { unsigned int ftype; };
-int erofs_namei(struct nameidata *nd,
+int erofs_namei(struct nameidata *nd, const char *name, unsigned int len) { erofs_nid_t nid = nd->nid; int ret;
- char buf[EROFS_BLKSIZ];
- char buf[EROFS_MAX_BLOCK_SIZE]; struct erofs_inode vi = { .nid = nid }; erofs_off_t offset;
@@ -179,7 +193,7 @@ int erofs_namei(struct nameidata *nd, offset = 0; while (offset < vi.i_size) { erofs_off_t maxsize = min_t(erofs_off_t,
vi.i_size - offset, EROFS_BLKSIZ);
struct erofs_dirent *de = (void *)buf; unsigned int nameoff;vi.i_size - offset, erofs_blksiz());
@@ -189,7 +203,7 @@ int erofs_namei(struct nameidata *nd,
nameoff = le16_to_cpu(de->nameoff); if (nameoff < sizeof(struct erofs_dirent) ||
nameoff >= PAGE_SIZE) {
nameoff >= erofs_blksiz()) { erofs_err("invalid de[0].nameoff %u @ nid %llu", nameoff, nid | 0ULL); return -EFSCORRUPTED;
diff --git a/fs/erofs/super.c b/fs/erofs/super.c index 8277d9b53f..d33926281b 100644 --- a/fs/erofs/super.c +++ b/fs/erofs/super.c @@ -9,7 +9,7 @@ static bool check_layout_compatibility(struct erofs_sb_info *sbi, sbi->feature_incompat = feature;
/* check if current kernel meets all mandatory requirements */
- if (feature & (~EROFS_ALL_FEATURE_INCOMPAT)) {
- if (feature & ~EROFS_ALL_FEATURE_INCOMPAT) { erofs_err("unidentified incompatible feature %x, please upgrade kernel version", feature & ~EROFS_ALL_FEATURE_INCOMPAT); return false;
@@ -40,14 +40,18 @@ static int erofs_init_devices(struct erofs_sb_info *sbi,
sbi->device_id_mask = roundup_pow_of_two(ondisk_extradevs + 1) - 1; sbi->devs = calloc(ondisk_extradevs, sizeof(*sbi->devs));
if (!sbi->devs)
return -ENOMEM;
pos = le16_to_cpu(dsb->devt_slotoff) * EROFS_DEVT_SLOT_SIZE; for (i = 0; i < ondisk_extradevs; ++i) { struct erofs_deviceslot dis; int ret;
ret = erofs_dev_read(0, &dis, pos, sizeof(dis));
if (ret < 0)
if (ret < 0) {
free(sbi->devs); return ret;
sbi->devs[i].mapped_blkaddr = dis.mapped_blkaddr; sbi->total_blocks += dis.blocks;
@@ -58,42 +62,41 @@ static int erofs_init_devices(struct erofs_sb_info *sbi,
int erofs_read_superblock(void) {
- char data[EROFS_BLKSIZ];
- u8 data[EROFS_MAX_BLOCK_SIZE]; struct erofs_super_block *dsb;
unsigned int blkszbits; int ret;
ret = erofs_blk_read(data, 0, 1);
- ret = erofs_blk_read(data, 0, erofs_blknr(sizeof(data))); if (ret < 0) {
erofs_dbg("cannot read erofs superblock: %d", ret);
erofs_err("cannot read erofs superblock: %d", ret);
return -EIO; } dsb = (struct erofs_super_block *)(data + EROFS_SUPER_OFFSET);
ret = -EINVAL; if (le32_to_cpu(dsb->magic) != EROFS_SUPER_MAGIC_V1) {
erofs_dbg("cannot find valid erofs superblock");
erofs_err("cannot find valid erofs superblock");
return ret; }
sbi.feature_compat = le32_to_cpu(dsb->feature_compat);
- blkszbits = dsb->blkszbits;
- /* 9(512 bytes) + LOG_SECTORS_PER_BLOCK == LOG_BLOCK_SIZE */
- if (blkszbits != LOG_BLOCK_SIZE) {
erofs_err("blksize %u isn't supported on this platform",
1 << blkszbits);
- sbi.blkszbits = dsb->blkszbits;
- if (sbi.blkszbits < 9 ||
sbi.blkszbits > ilog2(EROFS_MAX_BLOCK_SIZE)) {
erofs_err("blksize %llu isn't supported on this platform",
return ret;erofs_blksiz() | 0ULL);
- if (!check_layout_compatibility(&sbi, dsb))
} else if (!check_layout_compatibility(&sbi, dsb)) { return ret;
sbi.primarydevice_blocks = le32_to_cpu(dsb->blocks); sbi.meta_blkaddr = le32_to_cpu(dsb->meta_blkaddr); sbi.xattr_blkaddr = le32_to_cpu(dsb->xattr_blkaddr); sbi.islotbits = EROFS_ISLOTBITS; sbi.root_nid = le16_to_cpu(dsb->root_nid);
sbi.packed_nid = le64_to_cpu(dsb->packed_nid); sbi.inos = le64_to_cpu(dsb->inos); sbi.checksum = le32_to_cpu(dsb->checksum);
diff --git a/fs/erofs/zmap.c b/fs/erofs/zmap.c index be2599ac4f..4f64258b00 100644 --- a/fs/erofs/zmap.c +++ b/fs/erofs/zmap.c @@ -1,14 +1,19 @@ // SPDX-License-Identifier: GPL-2.0+ #include "internal.h"
int flags);
- int z_erofs_fill_inode(struct erofs_inode *vi) { if (!erofs_sb_has_big_pcluster() &&
vi->datalayout == EROFS_INODE_FLAT_COMPRESSION_LEGACY) {
!erofs_sb_has_ztailpacking() && !erofs_sb_has_fragments() &&
vi->z_advise = 0; vi->z_algorithmtype[0] = 0; vi->z_algorithmtype[1] = 0;vi->datalayout == EROFS_INODE_COMPRESSED_FULL) {
vi->z_logical_clusterbits = LOG_BLOCK_SIZE;
vi->z_logical_clusterbits = sbi.blkszbits;
vi->flags |= EROFS_I_Z_INITED; }
@@ -25,15 +30,23 @@ static int z_erofs_fill_inode_lazy(struct erofs_inode *vi) if (vi->flags & EROFS_I_Z_INITED) return 0;
DBG_BUGON(!erofs_sb_has_big_pcluster() &&
vi->datalayout == EROFS_INODE_FLAT_COMPRESSION_LEGACY);
pos = round_up(iloc(vi->nid) + vi->inode_isize + vi->xattr_isize, 8);
ret = erofs_dev_read(0, buf, pos, sizeof(buf)); if (ret < 0) return -EIO;
h = (struct z_erofs_map_header *)buf;
* if the highest bit of the 8-byte map header is set, the whole file
* is stored in the packed inode. The rest bits keeps z_fragmentoff.
- if (h->h_clusterbits >> Z_EROFS_FRAGMENT_INODE_BIT) {
vi->z_advise = Z_EROFS_ADVISE_FRAGMENT_PCLUSTER;
vi->fragmentoff = le64_to_cpu(*(__le64 *)h) ^ (1ULL << 63);
vi->z_tailextent_headlcn = 0;
goto out;
- vi->z_advise = le16_to_cpu(h->h_advise); vi->z_algorithmtype[0] = h->h_algorithmtype & 15; vi->z_algorithmtype[1] = h->h_algorithmtype >> 4;
- vi->z_logical_clusterbits = sbi.blkszbits + (h->h_clusterbits & 7);
- if (vi->datalayout == EROFS_INODE_COMPRESSED_COMPACT && !(vi->z_advise & Z_EROFS_ADVISE_BIG_PCLUSTER_1) ^ !(vi->z_advise & Z_EROFS_ADVISE_BIG_PCLUSTER_2)) { erofs_err("big pcluster head1/2 of compact indexes should be consistent for nid %llu", vi->nid * 1ULL); return -EFSCORRUPTED; }
- if (vi->z_advise & Z_EROFS_ADVISE_INLINE_PCLUSTER) {
if (!map.m_plen ||
map.m_plen | 0ULL);
if (ret < 0)
return ret;
- if (vi->z_advise & Z_EROFS_ADVISE_FRAGMENT_PCLUSTER &&
if (ret < 0)
return ret;
bool partialref; };
vi->xattr_isize) +
- const erofs_off_t pos = Z_EROFS_FULL_INDEX_ALIGN(ibase +
- struct z_erofs_lcluster_index *di; unsigned int advise, type; int err;
- type = (advise >> Z_EROFS_LI_LCLUSTER_TYPE_BIT) &
switch (type) {((1 << Z_EROFS_LI_LCLUSTER_TYPE_BITS) - 1);
- case Z_EROFS_LCLUSTER_TYPE_NONHEAD: m->clusterofs = 1 << vi->z_logical_clusterbits; m->delta[0] = le16_to_cpu(di->di_u.delta[0]);
} m->delta[1] = le16_to_cpu(di->di_u.delta[1]); break;~Z_EROFS_LI_D0_CBLKCNT; m->delta[0] = 1;
- case Z_EROFS_LCLUSTER_TYPE_PLAIN:
- case Z_EROFS_LCLUSTER_TYPE_HEAD1:
m->clusterofs = le16_to_cpu(di->di_clusterofs); m->pblk = le32_to_cpu(di->di_u.blkaddr); break;m->partialref = true;
++d1; } while (++i < vcnt);if (type != Z_EROFS_LCLUSTER_TYPE_NONHEAD) return d1;
{ struct erofs_inode *const vi = m->inode; const unsigned int lclusterbits = vi->z_logical_clusterbits; const unsigned int lomask = (1 << lclusterbits) - 1;erofs_off_t pos, bool lookahead)
- unsigned int vcnt, base, lo, encodebits, nblk, eofs; int i; u8 *in, type; bool big_pcluster;
- /* it doesn't equal to round_up(..) */
- m->nextpackoff = round_down(pos, vcnt << amortizedshift) +
big_pcluster = vi->z_advise & Z_EROFS_ADVISE_BIG_PCLUSTER_1; encodebits = ((vcnt << amortizedshift) - sizeof(__le32)) * 8 / vcnt;(vcnt << amortizedshift);
- eofs = erofs_blkoff(pos); base = round_down(eofs, vcnt << amortizedshift); in = m->kaddr + base;
encodebits,
vcnt, in, i);
} else if (i + 1 != (int)vcnt) {m->compressedblks = lo & ~Z_EROFS_LI_D0_CBLKCNT; m->delta[0] = 1; return 0;
m->delta[0] = lo + 1; return 0;else if (lo & Z_EROFS_LI_D0_CBLKCNT) lo = 1;
if (type == Z_EROFS_LCLUSTER_TYPE_NONHEAD) i -= lo; if (i >= 0)
if (lo == 1) {
- const unsigned int totalidx = BLK_ROUND_UP(vi->i_size); unsigned int compacted_4b_initial, compacted_2b; unsigned int amortizedshift; erofs_off_t pos;
- if ((vi->z_advise & Z_EROFS_ADVISE_COMPACTED_2B) &&
compacted_2b = rounddown(totalidx - compacted_4b_initial, 16); else compacted_2b = 0;compacted_4b_initial < totalidx)
lookahead);
- if (datamode == EROFS_INODE_COMPRESSED_FULL) return legacy_load_cluster_from_disk(m, lcn);
return -EINVAL;
switch (m->type) {
- case Z_EROFS_LCLUSTER_TYPE_NONHEAD: if (!m->delta[0]) { erofs_err("invalid lookback distance 0 @ nid %llu", (unsigned long long)vi->nid);
- case Z_EROFS_LCLUSTER_TYPE_HEAD1: m->headtype = m->type; map->m_la = (lcn << lclusterbits) | m->clusterofs; break;
lcn = m->lcn + 1;
- an internal implemenatation error is detected.
- The following code can also handle it properly anyway, but let's
- BUG_ON in the debugging mode only for developers to notice that.
switch (m->type) {
- case Z_EROFS_LCLUSTER_TYPE_HEAD1: /*
- if the 1st NONHEAD lcluster is actually PLAIN or HEAD type
- rather than CBLKCNT, it's a 1 lcluster-sized pcluster.
break;m->compressedblks = 1 << (lclusterbits - sbi.blkszbits);
- case Z_EROFS_LCLUSTER_TYPE_NONHEAD: if (m->delta[0] != 1) goto err_bonus_cblkcnt;
/* fallthrough */ default:if (m->compressedblks) break;
- map->m_plen = m->compressedblks << sbi.blkszbits; return 0; err_bonus_cblkcnt: erofs_err("bogus CBLKCNT @ lcn %lu of nid %llu",
int flags)
{int flags)
- bool ztailpacking = vi->z_advise & Z_EROFS_ADVISE_INLINE_PCLUSTER;
- bool fragment = vi->z_advise & Z_EROFS_ADVISE_FRAGMENT_PCLUSTER; struct z_erofs_maprecorder m = { .inode = vi, .map = map,
map->m_flags = 0;
goto out;
- if (err)
goto out;
- ofs = map->m_la;
- ofs = flags & EROFS_GET_BLOCKS_FINDTAIL ? vi->i_size - 1 : map->m_la; initial_lcn = ofs >> lclusterbits; endoff = ofs & ((1 << lclusterbits) - 1);
- if (ztailpacking && (flags & EROFS_GET_BLOCKS_FINDTAIL))
- map->m_flags = EROFS_MAP_MAPPED | EROFS_MAP_ENCODED; end = (m.lcn + 1ULL) << lclusterbits; switch (m.type) {
- case Z_EROFS_LCLUSTER_TYPE_HEAD1: if (endoff >= m.clusterofs) { m.headtype = m.type; map->m_la = (m.lcn << lclusterbits) | m.clusterofs;
- case Z_EROFS_LCLUSTER_TYPE_NONHEAD: /* get the correspoinding first chunk */ err = z_erofs_extent_lookback(&m, m.delta[0]); if (err)
- if (m.partialref)
map->m_llen = end - map->m_la;map->m_flags |= EROFS_MAP_PARTIAL_REF;
- if (err)
goto out;
- if (flags & EROFS_GET_BLOCKS_FINDTAIL) {
- if (ztailpacking && m.lcn == vi->z_tailextent_headlcn) {
- } else if (fragment && m.lcn == vi->z_tailextent_headlcn) {
- } else {
if (err)
goto out;
- else
DBG_BUGON(1);
goto out;
else
- return err;
int flags)
- int err = 0;
map->m_flags = 0;
goto out;
- if (err)
goto out;
- if ((vi->z_advise & Z_EROFS_ADVISE_FRAGMENT_PCLUSTER) &&
map->m_la = 0;
EROFS_MAP_FRAGMENT;
goto out;
- err = z_erofs_do_map_blocks(vi, map, flags);
Hi Tom,
Could you consider this patch for this merge window? LZMA support needs further work, we will address it separately.
Thanks, Gao Xiang
On Mon, Jul 17, 2023 at 01:27:39PM +0800, Gao Xiang wrote:
Hi Tom,
Yes, but I'm waiting a little bit longer for anyone else to provide feedback, thanks.
Hi Tom,
Thank you! glad to hear that. :-)
Thanks, Gao Xiang
Signed-off-by: Yifan Zhao zhaoyifan@sjtu.edu.cn Reviewed-by: Huang Jianan jnhuang95@gmail.com
Hi folks,
On 7/7/23 09:52, Yifan Zhao wrote:
diff --git a/fs/erofs/internal.h b/fs/erofs/internal.h index 4af7c91560..433a3c6c1e 100644 --- a/fs/erofs/internal.h +++ b/fs/erofs/internal.h +/* make sure that any user of the erofs headers has at least 64bit off_t type */ +extern int erofs_assert_largefile[sizeof(off_t) - 8];
This assertion does not hold true on 32-bit platforms, and as a result this patch prevents building U-Boot on those systems with EROFS support enabled. Did you perhaps mean to use `erofs_off_t` (which is always 64-bit) somewhere that you're using `off_t` instead?
I have had to revert this patch on my target, pending a solution for 32-bit users.
Thanks, Sam
Hi Sam,
On 2023/7/26 05:40, Sam Edwards wrote:
Hi folks,
Thanks for your report.
I think this line could just be removed since it only impacts LFS APIs ["erofs-utils which uses _FILE_OFFSET_BITS=64"] directly: https://git.kernel.org/pub/scm/linux/kernel/git/xiang/erofs-utils.git/commit... https://lore.kernel.org/all/20221215085842.130804-1-raj.khem@gmail.com/
But EROFS userspace internal implementation doesn't use off_t directly (instead it uses erofs_off_t as you said) nor u-boot interfaces (I think).
Yifan, Could you submit a patch to remove this line?
Thanks, Gao Xiang
Thanks, Sam
participants (5)
Gao Xiang
Huang Jianan
Sam Edwards
Yifan Zhao
