[U-Boot] [PATCH 01/11] powerpc/corenet: Move CONFIG_FSL_CORENET out of board header file
Move CONFIG_FSL_CORENET define to config_mpc85xx.h. It is not board specific feature and belongs to SoC header.
Signed-off-by: York Sun yorksun@freescale.com --- arch/powerpc/include/asm/config_mpc85xx.h | 5 +++++ include/configs/B4860QDS.h | 1 - include/configs/P2041RDB.h | 1 - include/configs/corenet_ds.h | 1 - include/configs/t4qds.h | 1 - 5 files changed, 5 insertions(+), 4 deletions(-)
diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index 1009a31..057402b 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -316,6 +316,7 @@
#elif defined(CONFIG_PPC_P2041) /* also supports P2040 */ #define CONFIG_SYS_FSL_QORIQ_CHASSIS1 +#define CONFIG_FSL_CORENET /* Freescale CoreNet platform */ #define CONFIG_MAX_CPUS 4 #define CONFIG_SYS_FSL_NUM_CC_PLLS 2 #define CONFIG_SYS_FSL_NUM_LAWS 32 @@ -350,6 +351,7 @@
#elif defined(CONFIG_PPC_P3041) #define CONFIG_SYS_FSL_QORIQ_CHASSIS1 +#define CONFIG_FSL_CORENET /* Freescale CoreNet platform */ #define CONFIG_MAX_CPUS 4 #define CONFIG_SYS_FSL_NUM_CC_PLLS 2 #define CONFIG_SYS_FSL_NUM_LAWS 32 @@ -384,6 +386,7 @@
#elif defined(CONFIG_PPC_P4080) /* also supports P4040 */ #define CONFIG_SYS_FSL_QORIQ_CHASSIS1 +#define CONFIG_FSL_CORENET /* Freescale CoreNet platform */ #define CONFIG_MAX_CPUS 8 #define CONFIG_SYS_FSL_NUM_CC_PLLS 4 #define CONFIG_SYS_FSL_NUM_LAWS 32 @@ -430,6 +433,7 @@ #elif defined(CONFIG_PPC_P5020) /* also supports P5010 */ #define CONFIG_SYS_PPC64 /* 64-bit core */ #define CONFIG_SYS_FSL_QORIQ_CHASSIS1 +#define CONFIG_FSL_CORENET /* Freescale CoreNet platform */ #define CONFIG_MAX_CPUS 2 #define CONFIG_SYS_FSL_NUM_CC_PLLS 2 #define CONFIG_SYS_FSL_NUM_LAWS 32 @@ -461,6 +465,7 @@ #elif defined(CONFIG_PPC_P5040) #define CONFIG_SYS_PPC64 #define CONFIG_SYS_FSL_QORIQ_CHASSIS1 +#define CONFIG_FSL_CORENET /* Freescale CoreNet platform */ #define CONFIG_MAX_CPUS 4 #define CONFIG_SYS_FSL_NUM_CC_PLLS 3 #define CONFIG_SYS_FSL_NUM_LAWS 32 diff --git a/include/configs/B4860QDS.h b/include/configs/B4860QDS.h index c15bbd8..b5b7d08 100644 --- a/include/configs/B4860QDS.h +++ b/include/configs/B4860QDS.h @@ -40,7 +40,6 @@ #define CONFIG_E500MC /* BOOKE e500mc family */ #define CONFIG_SYS_BOOK3E_HV /* Category E.HV supported */ #define CONFIG_MPC85xx /* MPC85xx/PQ3 platform */ -#define CONFIG_FSL_CORENET /* Freescale CoreNet platform */ #define CONFIG_MP /* support multiple processors */
#ifndef CONFIG_SYS_TEXT_BASE diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index 9cd3a7c..f23b50a 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -53,7 +53,6 @@ #define CONFIG_E500MC /* BOOKE e500mc family */ #define CONFIG_SYS_BOOK3E_HV /* Category E.HV supported */ #define CONFIG_MPC85xx /* MPC85xx/PQ3 platform */ -#define CONFIG_FSL_CORENET /* Freescale CoreNet platform */ #define CONFIG_MP /* support multiple processors */
#ifndef CONFIG_SYS_TEXT_BASE diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index 66c7b4f..590a4bc 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -58,7 +58,6 @@ #define CONFIG_E500MC /* BOOKE e500mc family */ #define CONFIG_SYS_BOOK3E_HV /* Category E.HV supported */ #define CONFIG_MPC85xx /* MPC85xx/PQ3 platform */ -#define CONFIG_FSL_CORENET /* Freescale CoreNet platform */ #define CONFIG_MP /* support multiple processors */
#ifndef CONFIG_SYS_TEXT_BASE diff --git a/include/configs/t4qds.h b/include/configs/t4qds.h index aa90249..1032f12 100644 --- a/include/configs/t4qds.h +++ b/include/configs/t4qds.h @@ -41,7 +41,6 @@ #define CONFIG_E500MC /* BOOKE e500mc family */ #define CONFIG_SYS_BOOK3E_HV /* Category E.HV supported */ #define CONFIG_MPC85xx /* MPC85xx/PQ3 platform */ -#define CONFIG_FSL_CORENET /* Freescale CoreNet platform */ #define CONFIG_MP /* support multiple processors */
FMAN firmware can be in NOR flash, NAND flash, SPI flash, MMC or even remote. In case none of them is defined, set it to null.
Signed-off-by: York Sun yorksun@freescale.com --- drivers/net/fm/fm.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/drivers/net/fm/fm.c b/drivers/net/fm/fm.c index 8d70586..0b1a8e5 100644 --- a/drivers/net/fm/fm.c +++ b/drivers/net/fm/fm.c @@ -409,6 +409,8 @@ int fm_init_common(int index, struct ccsr_fman *reg) } #elif defined(CONFIG_SYS_QE_FMAN_FW_IN_REMOTE) void *addr = (void *)CONFIG_SYS_QE_FMAN_FW_ADDR; +#else + void *addr = NULL; #endif
/* Upload the Fman microcode if it's present */
Prepare for emulator support for mpc85xx parts. Disable DDR training and skip wrlvl_cntl_2 and wrlvl_cntl_3 registers. These two registers improve stability but not supported by emulator. Add CONFIG_FSL_TBCLK_EXTRA_DIV for possible adjustment to time base.
Signed-off-by: York Sun yorksun@freescale.com --- README | 5 +++++ arch/powerpc/cpu/mpc85xx/cpu_init.c | 2 ++ arch/powerpc/cpu/mpc85xx/ddr-gen3.c | 7 +++++++ arch/powerpc/cpu/mpc85xx/fdt.c | 6 +++++- arch/powerpc/cpu/mpc8xxx/ddr/ctrl_regs.c | 5 +++++ 5 files changed, 24 insertions(+), 1 deletion(-)
diff --git a/README b/README index cd0336c..353d016 100644 --- a/README +++ b/README @@ -418,6 +418,11 @@ The following options need to be configured: This is the value to write into CCSR offset 0x18600 according to the A004510 workaround.
+ CONFIG_SYS_FSL_DDR_EMU + + Specify emulator support for DDR. Some DDR features such as deskew training + are not available. + - Generic CPU options: CONFIG_SYS_BIG_ENDIAN, CONFIG_SYS_LITTLE_ENDIAN
diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init.c b/arch/powerpc/cpu/mpc85xx/cpu_init.c index 4067f05..fd19d99 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init.c @@ -545,8 +545,10 @@ skip_l2:
enable_cpc();
+#ifndef CONFIG_SYS_FSL_NO_SERDES /* needs to be in ram since code uses global static vars */ fsl_serdes_init(); +#endif
#ifdef CONFIG_SYS_FSL_ERRATUM_A005871 if (IS_SVR_REV(svr, 1, 0)) { diff --git a/arch/powerpc/cpu/mpc85xx/ddr-gen3.c b/arch/powerpc/cpu/mpc85xx/ddr-gen3.c index c5b4720..3e7a564 100644 --- a/arch/powerpc/cpu/mpc85xx/ddr-gen3.c +++ b/arch/powerpc/cpu/mpc85xx/ddr-gen3.c @@ -123,10 +123,17 @@ void fsl_ddr_set_memctl_regs(const fsl_ddr_cfg_regs_t *regs, out_be32(&ddr->timing_cfg_5, regs->timing_cfg_5); out_be32(&ddr->ddr_zq_cntl, regs->ddr_zq_cntl); out_be32(&ddr->ddr_wrlvl_cntl, regs->ddr_wrlvl_cntl); +#ifndef CONFIG_SYS_FSL_DDR_EMU + /* + * Skip these two registers if running on emulator + * because emulator doesn't have skew between bytes. + */ + if (regs->ddr_wrlvl_cntl_2) out_be32(&ddr->ddr_wrlvl_cntl_2, regs->ddr_wrlvl_cntl_2); if (regs->ddr_wrlvl_cntl_3) out_be32(&ddr->ddr_wrlvl_cntl_3, regs->ddr_wrlvl_cntl_3); +#endif
out_be32(&ddr->ddr_sr_cntr, regs->ddr_sr_cntr); out_be32(&ddr->ddr_sdram_rcw_1, regs->ddr_sdram_rcw_1); diff --git a/arch/powerpc/cpu/mpc85xx/fdt.c b/arch/powerpc/cpu/mpc85xx/fdt.c index 288f7b2..8072235 100644 --- a/arch/powerpc/cpu/mpc85xx/fdt.c +++ b/arch/powerpc/cpu/mpc85xx/fdt.c @@ -620,8 +620,12 @@ void ft_cpu_setup(void *blob, bd_t *bd)
fdt_add_enet_stashing(blob);
+#ifndef CONFIG_FSL_TBCLK_EXTRA_DIV +#define CONFIG_FSL_TBCLK_EXTRA_DIV 1 +#endif do_fixup_by_prop_u32(blob, "device_type", "cpu", 4, - "timebase-frequency", get_tbclk(), 1); + "timebase-frequency", get_tbclk() / CONFIG_FSL_TBCLK_EXTRA_DIV, + 1); do_fixup_by_prop_u32(blob, "device_type", "cpu", 4, "bus-frequency", bd->bi_busfreq, 1); get_sys_info(&sysinfo); diff --git a/arch/powerpc/cpu/mpc8xxx/ddr/ctrl_regs.c b/arch/powerpc/cpu/mpc8xxx/ddr/ctrl_regs.c index 26c42f7..8c95cad 100644 --- a/arch/powerpc/cpu/mpc8xxx/ddr/ctrl_regs.c +++ b/arch/powerpc/cpu/mpc8xxx/ddr/ctrl_regs.c @@ -1641,5 +1641,10 @@ compute_fsl_memctl_config_regs(const memctl_options_t *popts,
set_ddr_sdram_rcw(ddr, popts, common_dimm);
+#ifdef CONFIG_SYS_FSL_DDR_EMU + /* disble DDR training for emulator */ + ddr->debug[2] = 0x00000400; + ddr->debug[4] = 0xff800000; +#endif return check_fsl_memctl_config_regs(ddr); }
CONFIG_PHYS_64BIT is always defined for t4qds. Removed unused #ifdef.
Signed-off-by: York Sun yorksun@freescale.com --- include/configs/t4qds.h | 68 ----------------------------------------------- 1 file changed, 68 deletions(-)
diff --git a/include/configs/t4qds.h b/include/configs/t4qds.h index 1032f12..3f7b82d 100644 --- a/include/configs/t4qds.h +++ b/include/configs/t4qds.h @@ -133,14 +133,9 @@ unsigned long get_board_ddr_clk(void);
#define CONFIG_ENABLE_36BIT_PHYS
-#ifdef CONFIG_PHYS_64BIT #define CONFIG_ADDR_MAP #define CONFIG_SYS_NUM_ADDR_MAP 64 /* number of TLB1 entries */ -#endif
-#if 0 -#define CONFIG_POST CONFIG_SYS_POST_MEMORY /* test POST memory test */ -#endif #define CONFIG_SYS_MEMTEST_START 0x00200000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x00400000 #define CONFIG_SYS_ALT_MEMTEST @@ -151,10 +146,8 @@ unsigned long get_board_ddr_clk(void); */ #define CONFIG_SYS_INIT_L3_ADDR CONFIG_RAMBOOT_TEXT_BASE
-#ifdef CONFIG_PHYS_64BIT #define CONFIG_SYS_DCSRBAR 0xf0000000 #define CONFIG_SYS_DCSRBAR_PHYS 0xf00000000ull -#endif
/* EEPROM */ #define CONFIG_ID_EEPROM @@ -192,11 +185,7 @@ unsigned long get_board_ddr_clk(void); * IFC Definitions */ #define CONFIG_SYS_FLASH_BASE 0xe0000000 -#ifdef CONFIG_PHYS_64BIT #define CONFIG_SYS_FLASH_BASE_PHYS (0xf00000000ull | CONFIG_SYS_FLASH_BASE) -#else -#define CONFIG_SYS_FLASH_BASE_PHYS CONFIG_SYS_FLASH_BASE -#endif
#define CONFIG_SYS_NOR0_CSPR_EXT (0xf) #define CONFIG_SYS_NOR0_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS \ @@ -248,11 +237,7 @@ unsigned long get_board_ddr_clk(void); #define QIXIS_RCFG_CTL_RECONFIG_IDLE 0x20 #define QIXIS_RCFG_CTL_RECONFIG_START 0x21 #define QIXIS_RCFG_CTL_WATCHDOG_ENBLE 0x08 -#ifdef CONFIG_PHYS_64BIT #define QIXIS_BASE_PHYS (0xf00000000ull | QIXIS_BASE) -#else -#define QIXIS_BASE_PHYS QIXIS_BASE -#endif
#define CONFIG_SYS_CSPR3_EXT (0xf) #define CONFIG_SYS_CSPR3 (CSPR_PHYS_ADDR(QIXIS_BASE_PHYS) \ @@ -275,11 +260,7 @@ unsigned long get_board_ddr_clk(void); /* NAND Flash on IFC */ #define CONFIG_NAND_FSL_IFC #define CONFIG_SYS_NAND_BASE 0xff800000 -#ifdef CONFIG_PHYS_64BIT #define CONFIG_SYS_NAND_BASE_PHYS (0xf00000000ull | CONFIG_SYS_NAND_BASE) -#else -#define CONFIG_SYS_NAND_BASE_PHYS CONFIG_SYS_NAND_BASE -#endif
#define CONFIG_SYS_NAND_CSPR_EXT (0xf) #define CONFIG_SYS_NAND_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_NAND_BASE_PHYS) \ @@ -380,18 +361,12 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_L1_INIT_RAM #define CONFIG_SYS_INIT_RAM_LOCK #define CONFIG_SYS_INIT_RAM_ADDR 0xfdd00000 /* Initial L1 address */ -#ifdef CONFIG_PHYS_64BIT #define CONFIG_SYS_INIT_RAM_ADDR_PHYS_HIGH 0xf #define CONFIG_SYS_INIT_RAM_ADDR_PHYS_LOW 0xfe0ec000 /* The assembler doesn't like typecast */ #define CONFIG_SYS_INIT_RAM_ADDR_PHYS \ ((CONFIG_SYS_INIT_RAM_ADDR_PHYS_HIGH * 1ull << 32) | \ CONFIG_SYS_INIT_RAM_ADDR_PHYS_LOW) -#else -#define CONFIG_SYS_INIT_RAM_ADDR_PHYS 0xfe0ec000 /* Initial L1 address */ -#define CONFIG_SYS_INIT_RAM_ADDR_PHYS_HIGH 0 -#define CONFIG_SYS_INIT_RAM_ADDR_PHYS_LOW CONFIG_SYS_INIT_RAM_ADDR_PHYS -#endif #define CONFIG_SYS_INIT_RAM_SIZE 0x00004000
#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ @@ -464,19 +439,11 @@ unsigned long get_board_ddr_clk(void); * RapidIO */ #define CONFIG_SYS_SRIO1_MEM_VIRT 0xa0000000 -#ifdef CONFIG_PHYS_64BIT #define CONFIG_SYS_SRIO1_MEM_PHYS 0xc20000000ull -#else -#define CONFIG_SYS_SRIO1_MEM_PHYS 0xa0000000 -#endif #define CONFIG_SYS_SRIO1_MEM_SIZE 0x10000000 /* 256M */
#define CONFIG_SYS_SRIO2_MEM_VIRT 0xb0000000 -#ifdef CONFIG_PHYS_64BIT #define CONFIG_SYS_SRIO2_MEM_PHYS 0xc30000000ull -#else -#define CONFIG_SYS_SRIO2_MEM_PHYS 0xb0000000 -#endif #define CONFIG_SYS_SRIO2_MEM_SIZE 0x10000000 /* 256M */
/* @@ -524,59 +491,32 @@ unsigned long get_board_ddr_clk(void);
/* controller 1, direct to uli, tgtid 3, Base address 20000 */ #define CONFIG_SYS_PCIE1_MEM_VIRT 0x80000000 -#ifdef CONFIG_PHYS_64BIT #define CONFIG_SYS_PCIE1_MEM_BUS 0xe0000000 #define CONFIG_SYS_PCIE1_MEM_PHYS 0xc00000000ull -#else -#define CONFIG_SYS_PCIE1_MEM_BUS 0x80000000 -#define CONFIG_SYS_PCIE1_MEM_PHYS 0x80000000 -#endif #define CONFIG_SYS_PCIE1_MEM_SIZE 0x20000000 /* 512M */ #define CONFIG_SYS_PCIE1_IO_VIRT 0xf8000000 #define CONFIG_SYS_PCIE1_IO_BUS 0x00000000 -#ifdef CONFIG_PHYS_64BIT #define CONFIG_SYS_PCIE1_IO_PHYS 0xff8000000ull -#else -#define CONFIG_SYS_PCIE1_IO_PHYS 0xf8000000 -#endif #define CONFIG_SYS_PCIE1_IO_SIZE 0x00010000 /* 64k */
/* controller 2, Slot 2, tgtid 2, Base address 201000 */ #define CONFIG_SYS_PCIE2_MEM_VIRT 0xa0000000 -#ifdef CONFIG_PHYS_64BIT #define CONFIG_SYS_PCIE2_MEM_BUS 0xe0000000 #define CONFIG_SYS_PCIE2_MEM_PHYS 0xc20000000ull -#else -#define CONFIG_SYS_PCIE2_MEM_BUS 0xa0000000 -#define CONFIG_SYS_PCIE2_MEM_PHYS 0xa0000000 -#endif #define CONFIG_SYS_PCIE2_MEM_SIZE 0x20000000 /* 512M */ #define CONFIG_SYS_PCIE2_IO_VIRT 0xf8010000 #define CONFIG_SYS_PCIE2_IO_BUS 0x00000000 -#ifdef CONFIG_PHYS_64BIT #define CONFIG_SYS_PCIE2_IO_PHYS 0xff8010000ull -#else -#define CONFIG_SYS_PCIE2_IO_PHYS 0xf8010000 -#endif #define CONFIG_SYS_PCIE2_IO_SIZE 0x00010000 /* 64k */
/* controller 3, Slot 1, tgtid 1, Base address 202000 */ #define CONFIG_SYS_PCIE3_MEM_VIRT 0xc0000000 -#ifdef CONFIG_PHYS_64BIT #define CONFIG_SYS_PCIE3_MEM_BUS 0xe0000000 #define CONFIG_SYS_PCIE3_MEM_PHYS 0xc40000000ull -#else -#define CONFIG_SYS_PCIE3_MEM_BUS 0xc0000000 -#define CONFIG_SYS_PCIE3_MEM_PHYS 0xc0000000 -#endif #define CONFIG_SYS_PCIE3_MEM_SIZE 0x20000000 /* 512M */ #define CONFIG_SYS_PCIE3_IO_VIRT 0xf8020000 #define CONFIG_SYS_PCIE3_IO_BUS 0x00000000 -#ifdef CONFIG_PHYS_64BIT #define CONFIG_SYS_PCIE3_IO_PHYS 0xff8020000ull -#else -#define CONFIG_SYS_PCIE3_IO_PHYS 0xf8020000 -#endif #define CONFIG_SYS_PCIE3_IO_SIZE 0x00010000 /* 64k */
/* controller 4, Base address 203000 */ @@ -592,19 +532,11 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_DPAA_QBMAN /* Support Q/Bman */ #define CONFIG_SYS_BMAN_NUM_PORTALS 50 #define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 -#ifdef CONFIG_PHYS_64BIT #define CONFIG_SYS_BMAN_MEM_PHYS 0xff4000000ull -#else -#define CONFIG_SYS_BMAN_MEM_PHYS CONFIG_SYS_BMAN_MEM_BASE -#endif #define CONFIG_SYS_BMAN_MEM_SIZE 0x02000000 #define CONFIG_SYS_QMAN_NUM_PORTALS 50 #define CONFIG_SYS_QMAN_MEM_BASE 0xf6000000 -#ifdef CONFIG_PHYS_64BIT #define CONFIG_SYS_QMAN_MEM_PHYS 0xff6000000ull -#else -#define CONFIG_SYS_QMAN_MEM_PHYS CONFIG_SYS_QMAN_MEM_BASE -#endif #define CONFIG_SYS_QMAN_MEM_SIZE 0x02000000
#define CONFIG_SYS_DPAA_FMAN
The RCW print is common for all corenet platforms. Not necessary to ducplicate in each board file.
Signed-off-by: York Sun yorksun@freescale.com --- arch/powerpc/cpu/mpc85xx/cpu.c | 23 +++++++++++++++++++---- board/freescale/b4860qds/b4860qds.c | 15 --------------- board/freescale/corenet_ds/corenet_ds.c | 17 +++-------------- board/freescale/p2041rdb/p2041rdb.c | 15 --------------- board/freescale/t4qds/t4qds.c | 14 -------------- 5 files changed, 22 insertions(+), 62 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/cpu.c b/arch/powerpc/cpu/mpc85xx/cpu.c index 6ce483e..d407373 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu.c +++ b/arch/powerpc/cpu/mpc85xx/cpu.c @@ -60,10 +60,10 @@ int checkcpu (void) uint major, minor; struct cpu_type *cpu; char buf1[32], buf2[32]; -#if (defined(CONFIG_DDR_CLK_FREQ) || \ - defined(CONFIG_FSL_CORENET)) && !defined(CONFIG_SYS_FSL_QORIQ_CHASSIS2) - volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); -#endif /* CONFIG_FSL_CORENET */ +#if defined(CONFIG_DDR_CLK_FREQ) || defined(CONFIG_FSL_CORENET) + ccsr_gur_t __iomem *gur = + (void __iomem *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); +#endif
/* * Cornet platforms use ddr sync bit in RCW to indicate sync vs async @@ -227,6 +227,21 @@ int checkcpu (void)
puts("L1: D-cache 32 kB enabled\n I-cache 32 kB enabled\n");
+#ifdef CONFIG_FSL_CORENET + /* Display the RCW, so that no one gets confused as to what RCW + * we're actually using for this boot. + */ + puts("Reset Configuration Word (RCW):"); + for (i = 0; i < ARRAY_SIZE(gur->rcwsr); i++) { + u32 rcw = in_be32(&gur->rcwsr[i]); + + if ((i % 4) == 0) + printf("\n %08x:", i * 4); + printf(" %08x", rcw); + } + puts("\n"); +#endif + return 0; }
diff --git a/board/freescale/b4860qds/b4860qds.c b/board/freescale/b4860qds/b4860qds.c index a39c17a..8058c78 100644 --- a/board/freescale/b4860qds/b4860qds.c +++ b/board/freescale/b4860qds/b4860qds.c @@ -51,8 +51,6 @@ int checkboard(void) char buf[64]; u8 sw; struct cpu_type *cpu = gd->arch.cpu; - ccsr_gur_t *gur = (void *)CONFIG_SYS_MPC85xx_GUTS_ADDR; - unsigned int i; static const char *const freq[] = {"100", "125", "156.25", "161.13", "122.88", "122.88", "122.88"}; int clock; @@ -77,19 +75,6 @@ int checkboard(void) /* the timestamp string contains "\n" at the end */ printf(" on %s", qixis_read_time(buf));
- /* Display the RCW, so that no one gets confused as to what RCW - * we're actually using for this boot. - */ - puts("Reset Configuration Word (RCW):"); - for (i = 0; i < ARRAY_SIZE(gur->rcwsr); i++) { - u32 rcw = in_be32(&gur->rcwsr[i]); - - if ((i % 4) == 0) - printf("\n %08x:", i * 4); - printf(" %08x", rcw); - } - puts("\n"); - /* * Display the actual SERDES reference clocks as configured by the * dip switches on the board. Note that the SWx registers could diff --git a/board/freescale/corenet_ds/corenet_ds.c b/board/freescale/corenet_ds/corenet_ds.c index 48f7155..22677a9 100644 --- a/board/freescale/corenet_ds/corenet_ds.c +++ b/board/freescale/corenet_ds/corenet_ds.c @@ -43,8 +43,10 @@ int checkboard (void) { u8 sw; struct cpu_type *cpu = gd->arch.cpu; - ccsr_gur_t *gur = (void *)CONFIG_SYS_MPC85xx_GUTS_ADDR; +#if defined(CONFIG_P3041DS) || defined(CONFIG_P5020DS) || \ + defined(CONFIG_P5040DS) unsigned int i; +#endif static const char * const freq[] = {"100", "125", "156.25", "212.5" };
printf("Board: %sDS, ", cpu->name); @@ -63,19 +65,6 @@ int checkboard (void) else printf("invalid setting of SW%u\n", PIXIS_LBMAP_SWITCH);
- /* Display the RCW, so that no one gets confused as to what RCW - * we're actually using for this boot. - */ - puts("Reset Configuration Word (RCW):"); - for (i = 0; i < ARRAY_SIZE(gur->rcwsr); i++) { - u32 rcw = in_be32(&gur->rcwsr[i]); - - if ((i % 4) == 0) - printf("\n %08x:", i * 4); - printf(" %08x", rcw); - } - puts("\n"); - /* Display the actual SERDES reference clocks as configured by the * dip switches on the board. Note that the SWx registers could * technically be set to force the reference clocks to match the diff --git a/board/freescale/p2041rdb/p2041rdb.c b/board/freescale/p2041rdb/p2041rdb.c index 44d3e0c..cc4c6af 100644 --- a/board/freescale/p2041rdb/p2041rdb.c +++ b/board/freescale/p2041rdb/p2041rdb.c @@ -44,7 +44,6 @@ int checkboard(void) { u8 sw; struct cpu_type *cpu = gd->arch.cpu; - ccsr_gur_t *gur = (void *)CONFIG_SYS_MPC85xx_GUTS_ADDR; unsigned int i;
printf("Board: %sRDB, ", cpu->name); @@ -55,20 +54,6 @@ int checkboard(void) printf("vBank: %d\n", sw & 0x1);
/* - * Display the RCW, so that no one gets confused as to what RCW - * we're actually using for this boot. - */ - puts("Reset Configuration Word (RCW):"); - for (i = 0; i < ARRAY_SIZE(gur->rcwsr); i++) { - u32 rcw = in_be32(&gur->rcwsr[i]); - - if ((i % 4) == 0) - printf("\n %08x:", i * 4); - printf(" %08x", rcw); - } - puts("\n"); - - /* * Display the actual SERDES reference clocks as configured by the * dip switches on the board. Note that the SWx registers could * technically be set to force the reference clocks to match the diff --git a/board/freescale/t4qds/t4qds.c b/board/freescale/t4qds/t4qds.c index f0f280b..67de0ea 100644 --- a/board/freescale/t4qds/t4qds.c +++ b/board/freescale/t4qds/t4qds.c @@ -59,7 +59,6 @@ int checkboard(void) char buf[64]; u8 sw; struct cpu_type *cpu = gd->arch.cpu; - ccsr_gur_t *gur = (void *)CONFIG_SYS_MPC85xx_GUTS_ADDR; unsigned int i;
printf("Board: %sQDS, ", cpu->name); @@ -84,19 +83,6 @@ int checkboard(void) /* the timestamp string contains "\n" at the end */ printf(" on %s", qixis_read_time(buf));
Add emulator support for T4240. Emulator has limited peripherals and interfaces. Difference between emulator and T4240QDS includes: ECC for DDR is disabled due the procedure to load images No board FPGA (QIXIS) NOR flash has 32-bit port for higher loading speed IFC and I2C timing don't really matter, so set them fast No ethernet
Signed-off-by: York Sun yorksun@freescale.com --- board/freescale/t4qds/Makefile | 3 +- board/freescale/t4qds/ddr.c | 73 +--- board/freescale/t4qds/ddr.h | 122 ++++++ board/freescale/t4qds/law.c | 2 + board/freescale/t4qds/t4240emu.c | 96 +++++ board/freescale/t4qds/t4240qds.c | 855 ++++++++++++++++++++++++++++++++++++++ board/freescale/t4qds/t4qds.c | 853 ------------------------------------- board/freescale/t4qds/tlb.c | 3 +- boards.cfg | 1 + include/configs/T4240EMU.h | 185 +++++++++ include/configs/T4240QDS.h | 539 ++++++++++++++++++++++++ include/configs/t4qds.h | 482 +-------------------- 12 files changed, 1807 insertions(+), 1407 deletions(-) create mode 100644 board/freescale/t4qds/ddr.h create mode 100644 board/freescale/t4qds/t4240emu.c create mode 100644 board/freescale/t4qds/t4240qds.c delete mode 100644 board/freescale/t4qds/t4qds.c create mode 100644 include/configs/T4240EMU.h
diff --git a/board/freescale/t4qds/Makefile b/board/freescale/t4qds/Makefile index ff09ffa..1923a47 100644 --- a/board/freescale/t4qds/Makefile +++ b/board/freescale/t4qds/Makefile @@ -24,7 +24,8 @@ include $(TOPDIR)/config.mk
LIB = $(obj)lib$(BOARD).o
-COBJS-y += $(BOARD).o +COBJS-$(CONFIG_T4240QDS) += t4240qds.o +COBJS-$(CONFIG_T4240EMU) += t4240emu.o COBJS-y += ddr.o COBJS-$(CONFIG_T4240QDS)+= eth.o COBJS-$(CONFIG_PCI) += pci.o diff --git a/board/freescale/t4qds/ddr.c b/board/freescale/t4qds/ddr.c index 058d625..26ac2a5 100644 --- a/board/freescale/t4qds/ddr.c +++ b/board/freescale/t4qds/ddr.c @@ -13,81 +13,10 @@ #include <asm/fsl_ddr_sdram.h> #include <asm/fsl_ddr_dimm_params.h> #include <asm/fsl_law.h> +#include "ddr.h"
DECLARE_GLOBAL_DATA_PTR;
-struct board_specific_parameters { - u32 n_ranks; - u32 datarate_mhz_high; - u32 rank_gb; - u32 clk_adjust; - u32 wrlvl_start; - u32 wrlvl_ctl_2; - u32 wrlvl_ctl_3; - u32 cpo; - u32 write_data_delay; - u32 force_2T; -}; - -/* - * This table contains all valid speeds we want to override with board - * specific parameters. datarate_mhz_high values need to be in ascending order - * for each n_ranks group. - */ -static const struct board_specific_parameters udimm0[] = { - /* - * memory controller 0 - * num| hi| rank| clk| wrlvl | wrlvl | wrlvl | cpo |wrdata|2T - * ranks| mhz| GB |adjst| start | ctl2 | ctl3 | |delay | - */ - {2, 1350, 4, 4, 8, 0x0809090b, 0x0c0c0d0a, 0xff, 2, 0}, - {2, 1350, 0, 5, 7, 0x0709090b, 0x0c0c0d09, 0xff, 2, 0}, - {2, 1666, 4, 4, 8, 0x080a0a0d, 0x0d10100b, 0xff, 2, 0}, - {2, 1666, 0, 5, 7, 0x080a0a0c, 0x0d0d0e0a, 0xff, 2, 0}, - {2, 1900, 0, 4, 8, 0x090a0b0e, 0x0f11120c, 0xff, 2, 0}, - {2, 2140, 0, 4, 8, 0x090a0b0e, 0x0f11120c, 0xff, 2, 0}, - {1, 1350, 0, 5, 8, 0x0809090b, 0x0c0c0d0a, 0xff, 2, 0}, - {1, 1700, 0, 5, 8, 0x080a0a0c, 0x0c0d0e0a, 0xff, 2, 0}, - {1, 1900, 0, 4, 8, 0x080a0a0c, 0x0e0e0f0a, 0xff, 2, 0}, - {1, 2140, 0, 4, 8, 0x090a0b0c, 0x0e0f100b, 0xff, 2, 0}, - {} -}; - -/* - * The three slots have slightly different timing. The center values are good - * for all slots. We use identical speed tables for them. In future use, if - * DIMMs require separated tables, make more entries as needed. - */ -static const struct board_specific_parameters *udimms[] = { - udimm0, -}; - -static const struct board_specific_parameters rdimm0[] = { - /* - * memory controller 0 - * num| hi| rank| clk| wrlvl | wrlvl | wrlvl | cpo |wrdata|2T - * ranks| mhz| GB |adjst| start | ctl2 | ctl3 | |delay | - */ - {4, 1350, 0, 5, 9, 0x08070605, 0x07080805, 0xff, 2, 0}, - {4, 1666, 0, 5, 8, 0x08070605, 0x07080805, 0xff, 2, 0}, - {4, 2140, 0, 5, 8, 0x08070605, 0x07081805, 0xff, 2, 0}, - {2, 1350, 0, 5, 7, 0x0809090b, 0x0c0c0d09, 0xff, 2, 0}, - {2, 1666, 0, 5, 8, 0x080a0a0c, 0x0c0d0e0a, 0xff, 2, 0}, - {2, 2140, 0, 5, 8, 0x090a0b0c, 0x0e0f100b, 0xff, 2, 0}, - {1, 1350, 0, 5, 8, 0x0809090b, 0x0c0c0d0a, 0xff, 2, 0}, - {1, 1700, 0, 5, 8, 0x080a0a0c, 0x0c0d0e0a, 0xff, 2, 0}, - {1, 1900, 0, 4, 8, 0x080a0a0c, 0x0e0e0f0a, 0xff, 2, 0}, - {1, 2140, 0, 4, 8, 0x090a0b0c, 0x0e0f100b, 0xff, 2, 0}, - {} -}; - -/* - * The three slots have slightly different timing. See comments above. - */ -static const struct board_specific_parameters *rdimms[] = { - rdimm0, -}; - void fsl_ddr_board_options(memctl_options_t *popts, dimm_params_t *pdimm, unsigned int ctrl_num) diff --git a/board/freescale/t4qds/ddr.h b/board/freescale/t4qds/ddr.h new file mode 100644 index 0000000..cde0785 --- /dev/null +++ b/board/freescale/t4qds/ddr.h @@ -0,0 +1,122 @@ +/* + * Copyright 2013 Freescale Semiconductor, Inc. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __DDR_H__ +#define __DDR_H__ +struct board_specific_parameters { + u32 n_ranks; + u32 datarate_mhz_high; + u32 rank_gb; + u32 clk_adjust; + u32 wrlvl_start; + u32 wrlvl_ctl_2; + u32 wrlvl_ctl_3; + u32 cpo; + u32 write_data_delay; + u32 force_2T; +}; + +/* + * These tables contain all valid speeds we want to override with board + * specific parameters. datarate_mhz_high values need to be in ascending order + * for each n_ranks group. + */ + +#ifdef CONFIG_T4240QDS +static const struct board_specific_parameters udimm0[] = { + /* + * memory controller 0 + * num| hi| rank| clk| wrlvl | wrlvl | wrlvl | cpo |wrdata|2T + * ranks| mhz| GB |adjst| start | ctl2 | ctl3 | |delay | + */ + {2, 1350, 4, 4, 8, 0x0809090b, 0x0c0c0d0a, 0xff, 2, 0}, + {2, 1350, 0, 5, 7, 0x0709090b, 0x0c0c0d09, 0xff, 2, 0}, + {2, 1666, 4, 4, 8, 0x080a0a0d, 0x0d10100b, 0xff, 2, 0}, + {2, 1666, 0, 5, 7, 0x080a0a0c, 0x0d0d0e0a, 0xff, 2, 0}, + {2, 1900, 0, 4, 8, 0x090a0b0e, 0x0f11120c, 0xff, 2, 0}, + {2, 2140, 0, 4, 8, 0x090a0b0e, 0x0f11120c, 0xff, 2, 0}, + {1, 1350, 0, 5, 8, 0x0809090b, 0x0c0c0d0a, 0xff, 2, 0}, + {1, 1700, 0, 5, 8, 0x080a0a0c, 0x0c0d0e0a, 0xff, 2, 0}, + {1, 1900, 0, 4, 8, 0x080a0a0c, 0x0e0e0f0a, 0xff, 2, 0}, + {1, 2140, 0, 4, 8, 0x090a0b0c, 0x0e0f100b, 0xff, 2, 0}, + {} +}; + +static const struct board_specific_parameters rdimm0[] = { + /* + * memory controller 0 + * num| hi| rank| clk| wrlvl | wrlvl | wrlvl | cpo |wrdata|2T + * ranks| mhz| GB |adjst| start | ctl2 | ctl3 | |delay | + */ + {4, 1350, 0, 5, 9, 0x08070605, 0x07080805, 0xff, 2, 0}, + {4, 1666, 0, 5, 8, 0x08070605, 0x07080805, 0xff, 2, 0}, + {4, 2140, 0, 5, 8, 0x08070605, 0x07081805, 0xff, 2, 0}, + {2, 1350, 0, 5, 7, 0x0809090b, 0x0c0c0d09, 0xff, 2, 0}, + {2, 1666, 0, 5, 8, 0x080a0a0c, 0x0c0d0e0a, 0xff, 2, 0}, + {2, 2140, 0, 5, 8, 0x090a0b0c, 0x0e0f100b, 0xff, 2, 0}, + {1, 1350, 0, 5, 8, 0x0809090b, 0x0c0c0d0a, 0xff, 2, 0}, + {1, 1700, 0, 5, 8, 0x080a0a0c, 0x0c0d0e0a, 0xff, 2, 0}, + {1, 1900, 0, 4, 8, 0x080a0a0c, 0x0e0e0f0a, 0xff, 2, 0}, + {1, 2140, 0, 4, 8, 0x090a0b0c, 0x0e0f100b, 0xff, 2, 0}, + {} +}; + +#else /* CONFIG_T4240EMU */ +static const struct board_specific_parameters udimm0[] = { + /* + * memory controller 0 + * num| hi| rank| clk| wrlvl | wrlvl | wrlvl | cpo |wrdata|2T + * ranks| mhz| GB |adjst| start | ctl2 | ctl3 | |delay | + */ + {2, 2140, 0, 4, 8, 0x0, 0x0, 0xff, 2, 0}, + {1, 2140, 0, 4, 8, 0x0, 0x0, 0xff, 2, 0}, + {} +}; + +static const struct board_specific_parameters rdimm0[] = { + /* + * memory controller 0 + * num| hi| rank| clk| wrlvl | wrlvl | wrlvl | cpo |wrdata|2T + * ranks| mhz| GB |adjst| start | ctl2 | ctl3 | |delay | + */ + {4, 2140, 0, 5, 8, 0x0, 0x0, 0xff, 2, 0}, + {2, 2140, 0, 5, 8, 0x0, 0x0, 0xff, 2, 0}, + {1, 2140, 0, 4, 8, 0x0, 0x0, 0xff, 2, 0}, + {} +}; +#endif /* CONFIG_T4240EMU */ + +/* + * The three slots have slightly different timing. The center values are good + * for all slots. We use identical speed tables for them. In future use, if + * DIMMs require separated tables, make more entries as needed. + */ +static const struct board_specific_parameters *udimms[] = { + udimm0, +}; + +/* + * The three slots have slightly different timing. See comments above. + */ +static const struct board_specific_parameters *rdimms[] = { + rdimm0, +}; + + +#endif diff --git a/board/freescale/t4qds/law.c b/board/freescale/t4qds/law.c index f3848f3..7e41556 100644 --- a/board/freescale/t4qds/law.c +++ b/board/freescale/t4qds/law.c @@ -35,7 +35,9 @@ struct law_entry law_table[] = { #ifdef CONFIG_SYS_QMAN_MEM_PHYS SET_LAW(CONFIG_SYS_QMAN_MEM_PHYS, LAW_SIZE_32M, LAW_TRGT_IF_QMAN), #endif +#ifdef QIXIS_BASE_PHYS SET_LAW(QIXIS_BASE_PHYS, LAW_SIZE_4K, LAW_TRGT_IF_IFC), +#endif #ifdef CONFIG_SYS_DCSRBAR_PHYS /* Limit DCSR to 32M to access NPC Trace Buffer */ SET_LAW(CONFIG_SYS_DCSRBAR_PHYS, LAW_SIZE_32M, LAW_TRGT_IF_DCSR), diff --git a/board/freescale/t4qds/t4240emu.c b/board/freescale/t4qds/t4240emu.c new file mode 100644 index 0000000..589a2ae --- /dev/null +++ b/board/freescale/t4qds/t4240emu.c @@ -0,0 +1,96 @@ +/* + * Copyright 2013 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> +#include <i2c.h> +#include <netdev.h> +#include <linux/compiler.h> +#include <asm/mmu.h> +#include <asm/processor.h> +#include <asm/cache.h> +#include <asm/immap_85xx.h> +#include <asm/fsl_law.h> +#include <asm/fsl_serdes.h> +#include <asm/fsl_portals.h> +#include <asm/fsl_liodn.h> + +DECLARE_GLOBAL_DATA_PTR; + +int checkboard(void) +{ + struct cpu_type *cpu = gd->arch.cpu; + + printf("Board: %sEMU\n", cpu->name); + + return 0; +} + +int board_early_init_r(void) +{ + const unsigned int flashbase = CONFIG_SYS_FLASH_BASE; + const u8 flash_esel = find_tlb_idx((void *)flashbase, 1); + + /* + * Remap Boot flash + PROMJET region to caching-inhibited + * so that flash can be erased properly. + */ + + /* Flush d-cache and invalidate i-cache of any FLASH data */ + flush_dcache(); + invalidate_icache(); + + /* invalidate existing TLB entry for flash */ + disable_tlb(flash_esel); + + set_tlb(1, flashbase, CONFIG_SYS_FLASH_BASE_PHYS, + MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, flash_esel, BOOKE_PAGESZ_256M, 1); + + set_liodns(); +#ifdef CONFIG_SYS_DPAA_QBMAN + setup_portals(); +#endif + + return 0; +} + +int misc_init_r(void) +{ + return 0; +} + +void ft_board_setup(void *blob, bd_t *bd) +{ + phys_addr_t base; + phys_size_t size; + + ft_cpu_setup(blob, bd); + + base = getenv_bootm_low(); + size = getenv_bootm_size(); + + fdt_fixup_memory(blob, (u64)base, (u64)size); + + fdt_fixup_liodn(blob); + fdt_fixup_dr_usb(blob, bd); +} diff --git a/board/freescale/t4qds/t4240qds.c b/board/freescale/t4qds/t4240qds.c new file mode 100644 index 0000000..9a714de --- /dev/null +++ b/board/freescale/t4qds/t4240qds.c @@ -0,0 +1,855 @@ +/* + * Copyright 2009-2012 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> +#include <i2c.h> +#include <netdev.h> +#include <linux/compiler.h> +#include <asm/mmu.h> +#include <asm/processor.h> +#include <asm/cache.h> +#include <asm/immap_85xx.h> +#include <asm/fsl_law.h> +#include <asm/fsl_serdes.h> +#include <asm/fsl_portals.h> +#include <asm/fsl_liodn.h> +#include <fm_eth.h> + +#include "../common/qixis.h" +#include "../common/vsc3316_3308.h" +#include "t4qds.h" +#include "t4240qds_qixis.h" + +DECLARE_GLOBAL_DATA_PTR; + +static const int8_t vsc3316_fsm1_tx[8][2] = { {0, 0}, {1, 1}, {6, 6}, {7, 7}, + {8, 8}, {9, 9}, {14, 14}, {15, 15} }; + +static const int8_t vsc3316_fsm2_tx[8][2] = { {2, 2}, {3, 3}, {4, 4}, {5, 5}, + {10, 10}, {11, 11}, {12, 12}, {13, 13} }; + +static const int8_t vsc3316_fsm1_rx[8][2] = { {2, 12}, {3, 13}, {4, 5}, {5, 4}, + {10, 11}, {11, 10}, {12, 2}, {13, 3} }; + +static const int8_t vsc3316_fsm2_rx[8][2] = { {0, 15}, {1, 14}, {6, 7}, {7, 6}, + {8, 9}, {9, 8}, {14, 1}, {15, 0} }; + +int checkboard(void) +{ + char buf[64]; + u8 sw; + struct cpu_type *cpu = gd->arch.cpu; + unsigned int i; + + printf("Board: %sQDS, ", cpu->name); + printf("Sys ID: 0x%02x, Sys Ver: 0x%02x, ", + QIXIS_READ(id), QIXIS_READ(arch)); + + sw = QIXIS_READ(brdcfg[0]); + sw = (sw & QIXIS_LBMAP_MASK) >> QIXIS_LBMAP_SHIFT; + + if (sw < 0x8) + printf("vBank: %d\n", sw); + else if (sw == 0x8) + puts("Promjet\n"); + else if (sw == 0x9) + puts("NAND\n"); + else + printf("invalid setting of SW%u\n", QIXIS_LBMAP_SWITCH); + + printf("FPGA: v%d (%s), build %d", + (int)QIXIS_READ(scver), qixis_read_tag(buf), + (int)qixis_read_minor()); + /* the timestamp string contains "\n" at the end */ + printf(" on %s", qixis_read_time(buf)); + + /* + * Display the actual SERDES reference clocks as configured by the + * dip switches on the board. Note that the SWx registers could + * technically be set to force the reference clocks to match the + * values that the SERDES expects (or vice versa). For now, however, + * we just display both values and hope the user notices when they + * don't match. + */ + puts("SERDES Reference Clocks: "); + sw = QIXIS_READ(brdcfg[2]); + for (i = 0; i < MAX_SERDES; i++) { + static const char * const freq[] = { + "100", "125", "156.25", "161.1328125"}; + unsigned int clock = (sw >> (6 - 2 * i)) & 3; + + printf("SERDES%u=%sMHz ", i+1, freq[clock]); + } + puts("\n"); + + return 0; +} + +int select_i2c_ch_pca9547(u8 ch) +{ + int ret; + + ret = i2c_write(I2C_MUX_PCA_ADDR_PRI, 0, 1, &ch, 1); + if (ret) { + puts("PCA: failed to select proper channel\n"); + return ret; + } + + return 0; +} + +/* + * read_voltage from sensor on I2C bus + * We use average of 4 readings, waiting for 532us befor another reading + */ +#define NUM_READINGS 4 /* prefer to be power of 2 for efficiency */ +#define WAIT_FOR_ADC 532 /* wait for 532 microseconds for ADC */ + +static inline int read_voltage(void) +{ + int i, ret, voltage_read = 0; + u16 vol_mon; + + for (i = 0; i < NUM_READINGS; i++) { + ret = i2c_read(I2C_VOL_MONITOR_ADDR, + I2C_VOL_MONITOR_BUS_V_OFFSET, 1, (void *)&vol_mon, 2); + if (ret) { + printf("VID: failed to read core voltage\n"); + return ret; + } + if (vol_mon & I2C_VOL_MONITOR_BUS_V_OVF) { + printf("VID: Core voltage sensor error\n"); + return -1; + } + debug("VID: bus voltage reads 0x%04x\n", vol_mon); + /* LSB = 4mv */ + voltage_read += (vol_mon >> I2C_VOL_MONITOR_BUS_V_SHIFT) * 4; + udelay(WAIT_FOR_ADC); + } + /* calculate the average */ + voltage_read /= NUM_READINGS; + + return voltage_read; +} + +/* + * We need to calculate how long before the voltage starts to drop or increase + * It returns with the loop count. Each loop takes several readings (532us) + */ +static inline int wait_for_voltage_change(int vdd_last) +{ + int timeout, vdd_current; + + vdd_current = read_voltage(); + /* wait until voltage starts to drop */ + for (timeout = 0; abs(vdd_last - vdd_current) <= 4 && + timeout < 100; timeout++) { + vdd_current = read_voltage(); + } + if (timeout >= 100) { + printf("VID: Voltage adjustment timeout\n"); + return -1; + } + return timeout; +} + +/* + * argument 'wait' is the time we know the voltage difference can be measured + * this function keeps reading the voltage until it is stable + */ +static inline int wait_for_voltage_stable(int wait) +{ + int timeout, vdd_current, vdd_last; + + vdd_last = read_voltage(); + udelay(wait * NUM_READINGS * WAIT_FOR_ADC); + /* wait until voltage is stable */ + vdd_current = read_voltage(); + for (timeout = 0; abs(vdd_last - vdd_current) >= 4 && + timeout < 100; timeout++) { + vdd_last = vdd_current; + udelay(wait * NUM_READINGS * WAIT_FOR_ADC); + vdd_current = read_voltage(); + } + if (timeout >= 100) { + printf("VID: Voltage adjustment timeout\n"); + return -1; + } + + return vdd_current; +} + +static inline int set_voltage(u8 vid) +{ + int wait, vdd_last; + + vdd_last = read_voltage(); + QIXIS_WRITE(brdcfg[6], vid); + wait = wait_for_voltage_change(vdd_last); + if (wait < 0) + return -1; + debug("VID: Waited %d us\n", wait * NUM_READINGS * WAIT_FOR_ADC); + wait = wait ? wait : 1; + + vdd_last = wait_for_voltage_stable(wait); + if (vdd_last < 0) + return -1; + debug("VID: Current voltage is %d mV\n", vdd_last); + + return vdd_last; +} + + +static int adjust_vdd(ulong vdd_override) +{ + int re_enable = disable_interrupts(); + ccsr_gur_t __iomem *gur = + (void __iomem *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + u32 fusesr; + u8 vid, vid_current; + int vdd_target, vdd_current, vdd_last; + int ret; + unsigned long vdd_string_override; + char *vdd_string; + static const uint16_t vdd[32] = { + 0, /* unused */ + 9875, /* 0.9875V */ + 9750, + 9625, + 9500, + 9375, + 9250, + 9125, + 9000, + 8875, + 8750, + 8625, + 8500, + 8375, + 8250, + 8125, + 10000, /* 1.0000V */ + 10125, + 10250, + 10375, + 10500, + 10625, + 10750, + 10875, + 11000, + 0, /* reserved */ + }; + struct vdd_drive { + u8 vid; + unsigned voltage; + }; + + ret = select_i2c_ch_pca9547(I2C_MUX_CH_VOL_MONITOR); + if (ret) { + debug("VID: I2c failed to switch channel\n"); + ret = -1; + goto exit; + } + + /* get the voltage ID from fuse status register */ + fusesr = in_be32(&gur->dcfg_fusesr); + vid = (fusesr >> FSL_CORENET_DCFG_FUSESR_VID_SHIFT) & + FSL_CORENET_DCFG_FUSESR_VID_MASK; + if (vid == FSL_CORENET_DCFG_FUSESR_VID_MASK) { + vid = (fusesr >> FSL_CORENET_DCFG_FUSESR_ALTVID_SHIFT) & + FSL_CORENET_DCFG_FUSESR_ALTVID_MASK; + } + vdd_target = vdd[vid]; + + /* check override variable for overriding VDD */ + vdd_string = getenv("t4240qds_vdd_mv"); + if (vdd_override == 0 && vdd_string && + !strict_strtoul(vdd_string, 10, &vdd_string_override)) + vdd_override = vdd_string_override; + if (vdd_override >= 819 && vdd_override <= 1212) { + vdd_target = vdd_override * 10; /* convert to 1/10 mV */ + debug("VDD override is %lu\n", vdd_override); + } else if (vdd_override != 0) { + printf("Invalid value.\n"); + } + + if (vdd_target == 0) { + debug("VID: VID not used\n"); + ret = 0; + goto exit; + } else { + /* round up and divice by 10 to get a value in mV */ + vdd_target = DIV_ROUND_UP(vdd_target, 10); + debug("VID: vid = %d mV\n", vdd_target); + } + + /* + * Check current board VID setting + * Voltage regulator support output to 6.250mv step + * The highes voltage allowed for this board is (vid=0x40) 1.21250V + * the lowest is (vid=0x7f) 0.81875V + */ + vid_current = QIXIS_READ(brdcfg[6]); + vdd_current = 121250 - (vid_current - 0x40) * 625; + debug("VID: Current vid setting is (0x%x) %d mV\n", + vid_current, vdd_current/100); + + /* + * Read voltage monitor to check real voltage. + * Voltage monitor LSB is 4mv. + */ + vdd_last = read_voltage(); + if (vdd_last < 0) { + printf("VID: Could not read voltage sensor abort VID adjustment\n"); + ret = -1; + goto exit; + } + debug("VID: Core voltage is at %d mV\n", vdd_last); + /* + * Adjust voltage to at or 8mV above target. + * Each step of adjustment is 6.25mV. + * Stepping down too fast may cause over current. + */ + while (vdd_last > 0 && vid_current < 0x80 && + vdd_last > (vdd_target + 8)) { + vid_current++; + vdd_last = set_voltage(vid_current); + } + /* + * Check if we need to step up + * This happens when board voltage switch was set too low + */ + while (vdd_last > 0 && vid_current >= 0x40 && + vdd_last < vdd_target + 2) { + vid_current--; + vdd_last = set_voltage(vid_current); + } + if (vdd_last > 0) + printf("VID: Core voltage %d mV\n", vdd_last); + else + ret = -1; + +exit: + if (re_enable) + enable_interrupts(); + return ret; +} + +/* Configure Crossbar switches for Front-Side SerDes Ports */ +int config_frontside_crossbar_vsc3316(void) +{ + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + u32 srds_prtcl_s1, srds_prtcl_s2; + int ret; + + ret = select_i2c_ch_pca9547(I2C_MUX_CH_VSC3316_FS); + if (ret) + return ret; + + srds_prtcl_s1 = in_be32(&gur->rcwsr[4]) & + FSL_CORENET2_RCWSR4_SRDS1_PRTCL; + srds_prtcl_s1 >>= FSL_CORENET2_RCWSR4_SRDS1_PRTCL_SHIFT; + if (srds_prtcl_s1) { + ret = vsc3316_config(VSC3316_FSM_TX_ADDR, vsc3316_fsm1_tx, 8); + if (ret) + return ret; + ret = vsc3316_config(VSC3316_FSM_RX_ADDR, vsc3316_fsm1_rx, 8); + if (ret) + return ret; + } + + srds_prtcl_s2 = in_be32(&gur->rcwsr[4]) & + FSL_CORENET2_RCWSR4_SRDS2_PRTCL; + srds_prtcl_s2 >>= FSL_CORENET2_RCWSR4_SRDS2_PRTCL_SHIFT; + if (srds_prtcl_s2) { + ret = vsc3316_config(VSC3316_FSM_TX_ADDR, vsc3316_fsm2_tx, 8); + if (ret) + return ret; + ret = vsc3316_config(VSC3316_FSM_RX_ADDR, vsc3316_fsm2_rx, 8); + if (ret) + return ret; + } + + return 0; +} + +int config_backside_crossbar_mux(void) +{ + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + u32 srds_prtcl_s3, srds_prtcl_s4; + u8 brdcfg; + + srds_prtcl_s3 = in_be32(&gur->rcwsr[4]) & + FSL_CORENET2_RCWSR4_SRDS3_PRTCL; + srds_prtcl_s3 >>= FSL_CORENET2_RCWSR4_SRDS3_PRTCL_SHIFT; + switch (srds_prtcl_s3) { + case 0: + /* SerDes3 is not enabled */ + break; + case 2: + case 9: + case 10: + /* SD3(0:7) => SLOT5(0:7) */ + brdcfg = QIXIS_READ(brdcfg[12]); + brdcfg &= ~BRDCFG12_SD3MX_MASK; + brdcfg |= BRDCFG12_SD3MX_SLOT5; + QIXIS_WRITE(brdcfg[12], brdcfg); + break; + case 4: + case 6: + case 8: + case 12: + case 14: + case 16: + case 17: + case 19: + case 20: + /* SD3(4:7) => SLOT6(0:3) */ + brdcfg = QIXIS_READ(brdcfg[12]); + brdcfg &= ~BRDCFG12_SD3MX_MASK; + brdcfg |= BRDCFG12_SD3MX_SLOT6; + QIXIS_WRITE(brdcfg[12], brdcfg); + break; + default: + printf("WARNING: unsupported for SerDes3 Protocol %d\n", + srds_prtcl_s3); + return -1; + } + + srds_prtcl_s4 = in_be32(&gur->rcwsr[4]) & + FSL_CORENET2_RCWSR4_SRDS4_PRTCL; + srds_prtcl_s4 >>= FSL_CORENET2_RCWSR4_SRDS4_PRTCL_SHIFT; + switch (srds_prtcl_s4) { + case 0: + /* SerDes4 is not enabled */ + break; + case 2: + /* 10b, SD4(0:7) => SLOT7(0:7) */ + brdcfg = QIXIS_READ(brdcfg[12]); + brdcfg &= ~BRDCFG12_SD4MX_MASK; + brdcfg |= BRDCFG12_SD4MX_SLOT7; + QIXIS_WRITE(brdcfg[12], brdcfg); + break; + case 4: + case 6: + case 8: + /* x1b, SD4(4:7) => SLOT8(0:3) */ + brdcfg = QIXIS_READ(brdcfg[12]); + brdcfg &= ~BRDCFG12_SD4MX_MASK; + brdcfg |= BRDCFG12_SD4MX_SLOT8; + QIXIS_WRITE(brdcfg[12], brdcfg); + break; + case 10: + case 12: + case 14: + case 16: + case 18: + /* 00b, SD4(4:5) => AURORA, SD4(6:7) => SATA */ + brdcfg = QIXIS_READ(brdcfg[12]); + brdcfg &= ~BRDCFG12_SD4MX_MASK; + brdcfg |= BRDCFG12_SD4MX_AURO_SATA; + QIXIS_WRITE(brdcfg[12], brdcfg); + break; + default: + printf("WARNING: unsupported for SerDes4 Protocol %d\n", + srds_prtcl_s4); + return -1; + } + + return 0; +} + +int board_early_init_r(void) +{ + const unsigned int flashbase = CONFIG_SYS_FLASH_BASE; + const u8 flash_esel = find_tlb_idx((void *)flashbase, 1); + + /* + * Remap Boot flash + PROMJET region to caching-inhibited + * so that flash can be erased properly. + */ + + /* Flush d-cache and invalidate i-cache of any FLASH data */ + flush_dcache(); + invalidate_icache(); + + /* invalidate existing TLB entry for flash + promjet */ + disable_tlb(flash_esel); + + set_tlb(1, flashbase, CONFIG_SYS_FLASH_BASE_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, flash_esel, BOOKE_PAGESZ_256M, 1); + + set_liodns(); +#ifdef CONFIG_SYS_DPAA_QBMAN + setup_portals(); +#endif + + /* Disable remote I2C connection to qixis fpga */ + QIXIS_WRITE(brdcfg[5], QIXIS_READ(brdcfg[5]) & ~BRDCFG5_IRE); + + /* + * Adjust core voltage according to voltage ID + * This function changes I2C mux to channel 2. + */ + if (adjust_vdd(0)) + printf("Warning: Adjusting core voltage failed.\n"); + + /* Configure board SERDES ports crossbar */ + config_frontside_crossbar_vsc3316(); + config_backside_crossbar_mux(); + select_i2c_ch_pca9547(I2C_MUX_CH_DEFAULT); + + return 0; +} + +unsigned long get_board_sys_clk(void) +{ + u8 sysclk_conf = QIXIS_READ(brdcfg[1]); +#ifdef CONFIG_FSL_QIXIS_CLOCK_MEASUREMENT + /* use accurate clock measurement */ + int freq = QIXIS_READ(clk_freq[0]) << 8 | QIXIS_READ(clk_freq[1]); + int base = QIXIS_READ(clk_base[0]) << 8 | QIXIS_READ(clk_base[1]); + u32 val; + + val = freq * base; + if (val) { + debug("SYS Clock measurement is: %d\n", val); + return val; + } else { + printf("Warning: SYS clock measurement is invalid, using value from brdcfg1.\n"); + } +#endif + + switch (sysclk_conf & 0x0F) { + case QIXIS_SYSCLK_83: + return 83333333; + case QIXIS_SYSCLK_100: + return 100000000; + case QIXIS_SYSCLK_125: + return 125000000; + case QIXIS_SYSCLK_133: + return 133333333; + case QIXIS_SYSCLK_150: + return 150000000; + case QIXIS_SYSCLK_160: + return 160000000; + case QIXIS_SYSCLK_166: + return 166666666; + } + return 66666666; +} + +unsigned long get_board_ddr_clk(void) +{ + u8 ddrclk_conf = QIXIS_READ(brdcfg[1]); +#ifdef CONFIG_FSL_QIXIS_CLOCK_MEASUREMENT + /* use accurate clock measurement */ + int freq = QIXIS_READ(clk_freq[2]) << 8 | QIXIS_READ(clk_freq[3]); + int base = QIXIS_READ(clk_base[0]) << 8 | QIXIS_READ(clk_base[1]); + u32 val; + + val = freq * base; + if (val) { + debug("DDR Clock measurement is: %d\n", val); + return val; + } else { + printf("Warning: DDR clock measurement is invalid, using value from brdcfg1.\n"); + } +#endif + + switch ((ddrclk_conf & 0x30) >> 4) { + case QIXIS_DDRCLK_100: + return 100000000; + case QIXIS_DDRCLK_125: + return 125000000; + case QIXIS_DDRCLK_133: + return 133333333; + } + return 66666666; +} + +static const char *serdes_clock_to_string(u32 clock) +{ + switch (clock) { + case SRDS_PLLCR0_RFCK_SEL_100: + return "100"; + case SRDS_PLLCR0_RFCK_SEL_125: + return "125"; + case SRDS_PLLCR0_RFCK_SEL_156_25: + return "156.25"; + case SRDS_PLLCR0_RFCK_SEL_161_13: + return "161.1328125"; + default: + return "???"; + } +} + +int misc_init_r(void) +{ + u8 sw; + serdes_corenet_t *srds_regs = + (void *)CONFIG_SYS_FSL_CORENET_SERDES_ADDR; + u32 actual[MAX_SERDES]; + unsigned int i; + + sw = QIXIS_READ(brdcfg[2]); + for (i = 0; i < MAX_SERDES; i++) { + unsigned int clock = (sw >> (6 - 2 * i)) & 3; + switch (clock) { + case 0: + actual[i] = SRDS_PLLCR0_RFCK_SEL_100; + break; + case 1: + actual[i] = SRDS_PLLCR0_RFCK_SEL_125; + break; + case 2: + actual[i] = SRDS_PLLCR0_RFCK_SEL_156_25; + break; + case 3: + actual[i] = SRDS_PLLCR0_RFCK_SEL_161_13; + break; + } + } + + for (i = 0; i < MAX_SERDES; i++) { + u32 pllcr0 = srds_regs->bank[i].pllcr0; + u32 expected = pllcr0 & SRDS_PLLCR0_RFCK_SEL_MASK; + if (expected != actual[i]) { + printf("Warning: SERDES%u expects reference clock" + " %sMHz, but actual is %sMHz\n", i + 1, + serdes_clock_to_string(expected), + serdes_clock_to_string(actual[i])); + } + } + + return 0; +} + +void ft_board_setup(void *blob, bd_t *bd) +{ + phys_addr_t base; + phys_size_t size; + + ft_cpu_setup(blob, bd); + + base = getenv_bootm_low(); + size = getenv_bootm_size(); + + fdt_fixup_memory(blob, (u64)base, (u64)size); + +#ifdef CONFIG_PCI + pci_of_setup(blob, bd); +#endif + + fdt_fixup_liodn(blob); + fdt_fixup_dr_usb(blob, bd); + +#ifdef CONFIG_SYS_DPAA_FMAN + fdt_fixup_fman_ethernet(blob); + fdt_fixup_board_enet(blob); +#endif +} + +/* + * This function is called by bdinfo to print detail board information. + * As an exmaple for future board, we organize the messages into + * several sections. If applicable, the message is in the format of + * <name> = <value> + * It should aligned with normal output of bdinfo command. + * + * Voltage: Core, DDR and another configurable voltages + * Clock : Critical clocks which are not printed already + * RCW : RCW source if not printed already + * Misc : Other important information not in above catagories + */ +void board_detail(void) +{ + int i; + u8 brdcfg[16], dutcfg[16], rst_ctl; + int vdd, rcwsrc; + static const char * const clk[] = {"66.67", "100", "125", "133.33"}; + + for (i = 0; i < 16; i++) { + brdcfg[i] = qixis_read(offsetof(struct qixis, brdcfg[0]) + i); + dutcfg[i] = qixis_read(offsetof(struct qixis, dutcfg[0]) + i); + } + + /* Voltage secion */ + if (!select_i2c_ch_pca9547(I2C_MUX_CH_VOL_MONITOR)) { + vdd = read_voltage(); + if (vdd > 0) + printf("Core voltage= %d mV\n", vdd); + select_i2c_ch_pca9547(I2C_MUX_CH_DEFAULT); + } + + printf("XVDD = 1.%d V\n", ((brdcfg[8] & 0xf) - 4) * 5 + 25); + + /* clock section */ + printf("SYSCLK = %s MHz\nDDRCLK = %s MHz\n", + clk[(brdcfg[11] >> 2) & 0x3], clk[brdcfg[11] & 3]); + + /* RCW section */ + rcwsrc = (dutcfg[0] << 1) + (dutcfg[1] & 1); + puts("RCW source = "); + switch (rcwsrc) { + case 0x017: + case 0x01f: + puts("8-bit NOR\n"); + break; + case 0x027: + case 0x02F: + puts("16-bit NOR\n"); + break; + case 0x040: + puts("SDHC/eMMC\n"); + break; + case 0x044: + puts("SPI 16-bit addressing\n"); + break; + case 0x045: + puts("SPI 24-bit addressing\n"); + break; + case 0x048: + puts("I2C normal addressing\n"); + break; + case 0x049: + puts("I2C extended addressing\n"); + break; + case 0x108: + case 0x109: + case 0x10a: + case 0x10b: + puts("8-bit NAND, 2KB\n"); + break; + default: + if ((rcwsrc >= 0x080) && (rcwsrc <= 0x09f)) + puts("Hard-coded RCW\n"); + else if ((rcwsrc >= 0x110) && (rcwsrc <= 0x11f)) + puts("8-bit NAND, 4KB\n"); + else + puts("unknown\n"); + break; + } + + /* Misc section */ + rst_ctl = QIXIS_READ(rst_ctl); + puts("HRESET_REQ = "); + switch (rst_ctl & 0x30) { + case 0x00: + puts("Ignored\n"); + break; + case 0x10: + puts("Assert HRESET\n"); + break; + case 0x30: + puts("Reset system\n"); + break; + default: + puts("N/A\n"); + break; + } +} + +/* + * Reverse engineering switch settings. + * Some bits cannot be figured out. They will be displayed as + * underscore in binary format. mask[] has those bits. + * Some bits are calculated differently than the actual switches + * if booting with overriding by FPGA. + */ +void qixis_dump_switch(void) +{ + int i; + u8 sw[9]; + + /* + * Any bit with 1 means that bit cannot be reverse engineered. + * It will be displayed as _ in binary format. + */ + static const u8 mask[] = {0, 0, 0, 0, 0, 0x1, 0xcf, 0x3f, 0x1f}; + char buf[10]; + u8 brdcfg[16], dutcfg[16]; + + for (i = 0; i < 16; i++) { + brdcfg[i] = qixis_read(offsetof(struct qixis, brdcfg[0]) + i); + dutcfg[i] = qixis_read(offsetof(struct qixis, dutcfg[0]) + i); + } + + sw[0] = dutcfg[0]; + sw[1] = (dutcfg[1] << 0x07) | \ + ((dutcfg[12] & 0xC0) >> 1) | \ + ((dutcfg[11] & 0xE0) >> 3) | \ + ((dutcfg[6] & 0x80) >> 6) | \ + ((dutcfg[1] & 0x80) >> 7); + sw[2] = ((brdcfg[1] & 0x0f) << 4) | \ + ((brdcfg[1] & 0x30) >> 2) | \ + ((brdcfg[1] & 0x40) >> 5) | \ + ((brdcfg[1] & 0x80) >> 7); + sw[3] = brdcfg[2]; + sw[4] = ((dutcfg[2] & 0x01) << 7) | \ + ((dutcfg[2] & 0x06) << 4) | \ + ((~QIXIS_READ(present)) & 0x10) | \ + ((brdcfg[3] & 0x80) >> 4) | \ + ((brdcfg[3] & 0x01) << 2) | \ + ((brdcfg[6] == 0x62) ? 3 : \ + ((brdcfg[6] == 0x5a) ? 2 : \ + ((brdcfg[6] == 0x5e) ? 1 : 0))); + sw[5] = ((brdcfg[0] & 0x0f) << 4) | \ + ((QIXIS_READ(rst_ctl) & 0x30) >> 2) | \ + ((brdcfg[0] & 0x40) >> 5); + sw[6] = (brdcfg[11] & 0x20) | + ((brdcfg[5] & 0x02) << 3); + sw[7] = (((~QIXIS_READ(rst_ctl)) & 0x40) << 1) | \ + ((brdcfg[5] & 0x10) << 2); + sw[8] = ((brdcfg[12] & 0x08) << 4) | \ + ((brdcfg[12] & 0x03) << 5); + + puts("DIP switch (reverse-engineering)\n"); + for (i = 0; i < 9; i++) { + printf("SW%d = 0b%s (0x%02x)\n", + i + 1, byte_to_binary_mask(sw[i], mask[i], buf), sw[i]); + } +} + +static int do_vdd_adjust(cmd_tbl_t *cmdtp, + int flag, int argc, + char * const argv[]) +{ + ulong override; + + if (argc < 2) + return CMD_RET_USAGE; + if (!strict_strtoul(argv[1], 10, &override)) + adjust_vdd(override); /* the value is checked by callee */ + else + return CMD_RET_USAGE; + + return 0; +} + +U_BOOT_CMD( + vdd_override, 2, 0, do_vdd_adjust, + "Override VDD", + "- override with the voltage specified in mV, eg. 1050" +); diff --git a/board/freescale/t4qds/t4qds.c b/board/freescale/t4qds/t4qds.c deleted file mode 100644 index 67de0ea..0000000 --- a/board/freescale/t4qds/t4qds.c +++ /dev/null @@ -1,853 +0,0 @@ -/* - * Copyright 2009-2012 Freescale Semiconductor, Inc. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <command.h> -#include <i2c.h> -#include <netdev.h> -#include <linux/compiler.h> -#include <asm/mmu.h> -#include <asm/processor.h> -#include <asm/cache.h> -#include <asm/immap_85xx.h> -#include <asm/fsl_law.h> -#include <asm/fsl_serdes.h> -#include <asm/fsl_portals.h> -#include <asm/fsl_liodn.h> -#include <fm_eth.h> - -#include "../common/qixis.h" -#include "../common/vsc3316_3308.h" -#include "t4qds.h" -#include "t4240qds_qixis.h" - -DECLARE_GLOBAL_DATA_PTR; - -static const int8_t vsc3316_fsm1_tx[8][2] = { {0, 0}, {1, 1}, {6, 6}, {7, 7}, - {8, 8}, {9, 9}, {14, 14}, {15, 15} }; - -static const int8_t vsc3316_fsm2_tx[8][2] = { {2, 2}, {3, 3}, {4, 4}, {5, 5}, - {10, 10}, {11, 11}, {12, 12}, {13, 13} }; - -static const int8_t vsc3316_fsm1_rx[8][2] = { {2, 12}, {3, 13}, {4, 5}, {5, 4}, - {10, 11}, {11, 10}, {12, 2}, {13, 3} }; - -static const int8_t vsc3316_fsm2_rx[8][2] = { {0, 15}, {1, 14}, {6, 7}, {7, 6}, - {8, 9}, {9, 8}, {14, 1}, {15, 0} }; - -int checkboard(void) -{ - char buf[64]; - u8 sw; - struct cpu_type *cpu = gd->arch.cpu; - unsigned int i; - - printf("Board: %sQDS, ", cpu->name); - printf("Sys ID: 0x%02x, Sys Ver: 0x%02x, ", - QIXIS_READ(id), QIXIS_READ(arch)); - - sw = QIXIS_READ(brdcfg[0]); - sw = (sw & QIXIS_LBMAP_MASK) >> QIXIS_LBMAP_SHIFT; - - if (sw < 0x8) - printf("vBank: %d\n", sw); - else if (sw == 0x8) - puts("Promjet\n"); - else if (sw == 0x9) - puts("NAND\n"); - else - printf("invalid setting of SW%u\n", QIXIS_LBMAP_SWITCH); - - printf("FPGA: v%d (%s), build %d", - (int)QIXIS_READ(scver), qixis_read_tag(buf), - (int)qixis_read_minor()); - /* the timestamp string contains "\n" at the end */ - printf(" on %s", qixis_read_time(buf)); - - /* - * Display the actual SERDES reference clocks as configured by the - * dip switches on the board. Note that the SWx registers could - * technically be set to force the reference clocks to match the - * values that the SERDES expects (or vice versa). For now, however, - * we just display both values and hope the user notices when they - * don't match. - */ - puts("SERDES Reference Clocks: "); - sw = QIXIS_READ(brdcfg[2]); - for (i = 0; i < MAX_SERDES; i++) { - static const char *freq[] = { - "100", "125", "156.25", "161.1328125"}; - unsigned int clock = (sw >> (6 - 2 * i)) & 3; - - printf("SERDES%u=%sMHz ", i+1, freq[clock]); - } - puts("\n"); - - return 0; -} - -int select_i2c_ch_pca9547(u8 ch) -{ - int ret; - - ret = i2c_write(I2C_MUX_PCA_ADDR_PRI, 0, 1, &ch, 1); - if (ret) { - puts("PCA: failed to select proper channel\n"); - return ret; - } - - return 0; -} - -/* - * read_voltage from sensor on I2C bus - * We use average of 4 readings, waiting for 532us befor another reading - */ -#define NUM_READINGS 4 /* prefer to be power of 2 for efficiency */ -#define WAIT_FOR_ADC 532 /* wait for 532 microseconds for ADC */ - -static inline int read_voltage(void) -{ - int i, ret, voltage_read = 0; - u16 vol_mon; - - for (i = 0; i < NUM_READINGS; i++) { - ret = i2c_read(I2C_VOL_MONITOR_ADDR, - I2C_VOL_MONITOR_BUS_V_OFFSET, 1, (void *)&vol_mon, 2); - if (ret) { - printf("VID: failed to read core voltage\n"); - return ret; - } - if (vol_mon & I2C_VOL_MONITOR_BUS_V_OVF) { - printf("VID: Core voltage sensor error\n"); - return -1; - } - debug("VID: bus voltage reads 0x%04x\n", vol_mon); - /* LSB = 4mv */ - voltage_read += (vol_mon >> I2C_VOL_MONITOR_BUS_V_SHIFT) * 4; - udelay(WAIT_FOR_ADC); - } - /* calculate the average */ - voltage_read /= NUM_READINGS; - - return voltage_read; -} - -/* - * We need to calculate how long before the voltage starts to drop or increase - * It returns with the loop count. Each loop takes several readings (532us) - */ -static inline int wait_for_voltage_change(int vdd_last) -{ - int timeout, vdd_current; - - vdd_current = read_voltage(); - /* wait until voltage starts to drop */ - for (timeout = 0; abs(vdd_last - vdd_current) <= 4 && - timeout < 100; timeout++) { - vdd_current = read_voltage(); - } - if (timeout >= 100) { - printf("VID: Voltage adjustment timeout\n"); - return -1; - } - return timeout; -} - -/* - * argument 'wait' is the time we know the voltage difference can be measured - * this function keeps reading the voltage until it is stable - */ -static inline int wait_for_voltage_stable(int wait) -{ - int timeout, vdd_current, vdd_last; - - vdd_last = read_voltage(); - udelay(wait * NUM_READINGS * WAIT_FOR_ADC); - /* wait until voltage is stable */ - vdd_current = read_voltage(); - for (timeout = 0; abs(vdd_last - vdd_current) >= 4 && - timeout < 100; timeout++) { - vdd_last = vdd_current; - udelay(wait * NUM_READINGS * WAIT_FOR_ADC); - vdd_current = read_voltage(); - } - if (timeout >= 100) { - printf("VID: Voltage adjustment timeout\n"); - return -1; - } - - return vdd_current; -} - -static inline int set_voltage(u8 vid) -{ - int wait, vdd_last; - - vdd_last = read_voltage(); - QIXIS_WRITE(brdcfg[6], vid); - wait = wait_for_voltage_change(vdd_last); - if (wait < 0) - return -1; - debug("VID: Waited %d us\n", wait * NUM_READINGS * WAIT_FOR_ADC); - wait = wait ? wait : 1; - - vdd_last = wait_for_voltage_stable(wait); - if (vdd_last < 0) - return -1; - debug("VID: Current voltage is %d mV\n", vdd_last); - - return vdd_last; -} - - -static int adjust_vdd(ulong vdd_override) -{ - int re_enable = disable_interrupts(); - ccsr_gur_t __iomem *gur = - (void __iomem *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); - u32 fusesr; - u8 vid, vid_current; - int vdd_target, vdd_current, vdd_last; - int ret; - unsigned long vdd_string_override; - char *vdd_string; - static const uint16_t vdd[32] = { - 0, /* unused */ - 9875, /* 0.9875V */ - 9750, - 9625, - 9500, - 9375, - 9250, - 9125, - 9000, - 8875, - 8750, - 8625, - 8500, - 8375, - 8250, - 8125, - 10000, /* 1.0000V */ - 10125, - 10250, - 10375, - 10500, - 10625, - 10750, - 10875, - 11000, - 0, /* reserved */ - }; - struct vdd_drive { - u8 vid; - unsigned voltage; - }; - - ret = select_i2c_ch_pca9547(I2C_MUX_CH_VOL_MONITOR); - if (ret) { - debug("VID: I2c failed to switch channel\n"); - ret = -1; - goto exit; - } - - /* get the voltage ID from fuse status register */ - fusesr = in_be32(&gur->dcfg_fusesr); - vid = (fusesr >> FSL_CORENET_DCFG_FUSESR_VID_SHIFT) & - FSL_CORENET_DCFG_FUSESR_VID_MASK; - if (vid == FSL_CORENET_DCFG_FUSESR_VID_MASK) { - vid = (fusesr >> FSL_CORENET_DCFG_FUSESR_ALTVID_SHIFT) & - FSL_CORENET_DCFG_FUSESR_ALTVID_MASK; - } - vdd_target = vdd[vid]; - - /* check override variable for overriding VDD */ - vdd_string = getenv("t4240qds_vdd_mv"); - if (vdd_override == 0 && vdd_string && - !strict_strtoul(vdd_string, 10, &vdd_string_override)) - vdd_override = vdd_string_override; - if (vdd_override >= 819 && vdd_override <= 1212) { - vdd_target = vdd_override * 10; /* convert to 1/10 mV */ - debug("VDD override is %lu\n", vdd_override); - } else if (vdd_override != 0) { - printf("Invalid value.\n"); - } - - if (vdd_target == 0) { - debug("VID: VID not used\n"); - ret = 0; - goto exit; - } else { - /* round up and divice by 10 to get a value in mV */ - vdd_target = DIV_ROUND_UP(vdd_target, 10); - debug("VID: vid = %d mV\n", vdd_target); - } - - /* - * Check current board VID setting - * Voltage regulator support output to 6.250mv step - * The highes voltage allowed for this board is (vid=0x40) 1.21250V - * the lowest is (vid=0x7f) 0.81875V - */ - vid_current = QIXIS_READ(brdcfg[6]); - vdd_current = 121250 - (vid_current - 0x40) * 625; - debug("VID: Current vid setting is (0x%x) %d mV\n", - vid_current, vdd_current/100); - - /* - * Read voltage monitor to check real voltage. - * Voltage monitor LSB is 4mv. - */ - vdd_last = read_voltage(); - if (vdd_last < 0) { - printf("VID: Could not read voltage sensor abort VID adjustment\n"); - ret = -1; - goto exit; - } - debug("VID: Core voltage is at %d mV\n", vdd_last); - /* - * Adjust voltage to at or 8mV above target. - * Each step of adjustment is 6.25mV. - * Stepping down too fast may cause over current. - */ - while (vdd_last > 0 && vid_current < 0x80 && - vdd_last > (vdd_target + 8)) { - vid_current++; - vdd_last = set_voltage(vid_current); - } - /* - * Check if we need to step up - * This happens when board voltage switch was set too low - */ - while (vdd_last > 0 && vid_current >= 0x40 && - vdd_last < vdd_target + 2) { - vid_current--; - vdd_last = set_voltage(vid_current); - } - if (vdd_last > 0) - printf("VID: Core voltage %d mV\n", vdd_last); - else - ret = -1; - -exit: - if (re_enable) - enable_interrupts(); - return ret; -} - -/* Configure Crossbar switches for Front-Side SerDes Ports */ -int config_frontside_crossbar_vsc3316(void) -{ - ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); - u32 srds_prtcl_s1, srds_prtcl_s2; - int ret; - - ret = select_i2c_ch_pca9547(I2C_MUX_CH_VSC3316_FS); - if (ret) - return ret; - - srds_prtcl_s1 = in_be32(&gur->rcwsr[4]) & - FSL_CORENET2_RCWSR4_SRDS1_PRTCL; - srds_prtcl_s1 >>= FSL_CORENET2_RCWSR4_SRDS1_PRTCL_SHIFT; - if (srds_prtcl_s1) { - ret = vsc3316_config(VSC3316_FSM_TX_ADDR, vsc3316_fsm1_tx, 8); - if (ret) - return ret; - ret = vsc3316_config(VSC3316_FSM_RX_ADDR, vsc3316_fsm1_rx, 8); - if (ret) - return ret; - } - - srds_prtcl_s2 = in_be32(&gur->rcwsr[4]) & - FSL_CORENET2_RCWSR4_SRDS2_PRTCL; - srds_prtcl_s2 >>= FSL_CORENET2_RCWSR4_SRDS2_PRTCL_SHIFT; - if (srds_prtcl_s2) { - ret = vsc3316_config(VSC3316_FSM_TX_ADDR, vsc3316_fsm2_tx, 8); - if (ret) - return ret; - ret = vsc3316_config(VSC3316_FSM_RX_ADDR, vsc3316_fsm2_rx, 8); - if (ret) - return ret; - } - - return 0; -} - -int config_backside_crossbar_mux(void) -{ - ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); - u32 srds_prtcl_s3, srds_prtcl_s4; - u8 brdcfg; - - srds_prtcl_s3 = in_be32(&gur->rcwsr[4]) & - FSL_CORENET2_RCWSR4_SRDS3_PRTCL; - srds_prtcl_s3 >>= FSL_CORENET2_RCWSR4_SRDS3_PRTCL_SHIFT; - switch (srds_prtcl_s3) { - case 0: - /* SerDes3 is not enabled */ - break; - case 2: - case 9: - case 10: - /* SD3(0:7) => SLOT5(0:7) */ - brdcfg = QIXIS_READ(brdcfg[12]); - brdcfg &= ~BRDCFG12_SD3MX_MASK; - brdcfg |= BRDCFG12_SD3MX_SLOT5; - QIXIS_WRITE(brdcfg[12], brdcfg); - break; - case 4: - case 6: - case 8: - case 12: - case 14: - case 16: - case 17: - case 19: - case 20: - /* SD3(4:7) => SLOT6(0:3) */ - brdcfg = QIXIS_READ(brdcfg[12]); - brdcfg &= ~BRDCFG12_SD3MX_MASK; - brdcfg |= BRDCFG12_SD3MX_SLOT6; - QIXIS_WRITE(brdcfg[12], brdcfg); - break; - default: - printf("WARNING: unsupported for SerDes3 Protocol %d\n", - srds_prtcl_s3); - return -1; - } - - srds_prtcl_s4 = in_be32(&gur->rcwsr[4]) & - FSL_CORENET2_RCWSR4_SRDS4_PRTCL; - srds_prtcl_s4 >>= FSL_CORENET2_RCWSR4_SRDS4_PRTCL_SHIFT; - switch (srds_prtcl_s4) { - case 0: - /* SerDes4 is not enabled */ - break; - case 2: - /* 10b, SD4(0:7) => SLOT7(0:7) */ - brdcfg = QIXIS_READ(brdcfg[12]); - brdcfg &= ~BRDCFG12_SD4MX_MASK; - brdcfg |= BRDCFG12_SD4MX_SLOT7; - QIXIS_WRITE(brdcfg[12], brdcfg); - break; - case 4: - case 6: - case 8: - /* x1b, SD4(4:7) => SLOT8(0:3) */ - brdcfg = QIXIS_READ(brdcfg[12]); - brdcfg &= ~BRDCFG12_SD4MX_MASK; - brdcfg |= BRDCFG12_SD4MX_SLOT8; - QIXIS_WRITE(brdcfg[12], brdcfg); - break; - case 10: - case 12: - case 14: - case 16: - case 18: - /* 00b, SD4(4:5) => AURORA, SD4(6:7) => SATA */ - brdcfg = QIXIS_READ(brdcfg[12]); - brdcfg &= ~BRDCFG12_SD4MX_MASK; - brdcfg |= BRDCFG12_SD4MX_AURO_SATA; - QIXIS_WRITE(brdcfg[12], brdcfg); - break; - default: - printf("WARNING: unsupported for SerDes4 Protocol %d\n", - srds_prtcl_s4); - return -1; - } - - return 0; -} - -int board_early_init_r(void) -{ - const unsigned int flashbase = CONFIG_SYS_FLASH_BASE; - const u8 flash_esel = find_tlb_idx((void *)flashbase, 1); - - /* - * Remap Boot flash + PROMJET region to caching-inhibited - * so that flash can be erased properly. - */ - - /* Flush d-cache and invalidate i-cache of any FLASH data */ - flush_dcache(); - invalidate_icache(); - - /* invalidate existing TLB entry for flash + promjet */ - disable_tlb(flash_esel); - - set_tlb(1, flashbase, CONFIG_SYS_FLASH_BASE_PHYS, - MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, - 0, flash_esel, BOOKE_PAGESZ_256M, 1); - - set_liodns(); -#ifdef CONFIG_SYS_DPAA_QBMAN - setup_portals(); -#endif - - /* Disable remote I2C connection to qixis fpga */ - QIXIS_WRITE(brdcfg[5], QIXIS_READ(brdcfg[5]) & ~BRDCFG5_IRE); - - /* - * Adjust core voltage according to voltage ID - * This function changes I2C mux to channel 2. - */ - if (adjust_vdd(0)) - printf("Warning: Adjusting core voltage failed.\n"); - - /* Configure board SERDES ports crossbar */ - config_frontside_crossbar_vsc3316(); - config_backside_crossbar_mux(); - select_i2c_ch_pca9547(I2C_MUX_CH_DEFAULT); - - return 0; -} - -unsigned long get_board_sys_clk(void) -{ - u8 sysclk_conf = QIXIS_READ(brdcfg[1]); -#ifdef CONFIG_FSL_QIXIS_CLOCK_MEASUREMENT - /* use accurate clock measurement */ - int freq = QIXIS_READ(clk_freq[0]) << 8 | QIXIS_READ(clk_freq[1]); - int base = QIXIS_READ(clk_base[0]) << 8 | QIXIS_READ(clk_base[1]); - u32 val; - - val = freq * base; - if (val) { - debug("SYS Clock measurement is: %d\n", val); - return val; - } else { - printf("Warning: SYS clock measurement is invalid, using value from brdcfg1.\n"); - } -#endif - - switch (sysclk_conf & 0x0F) { - case QIXIS_SYSCLK_83: - return 83333333; - case QIXIS_SYSCLK_100: - return 100000000; - case QIXIS_SYSCLK_125: - return 125000000; - case QIXIS_SYSCLK_133: - return 133333333; - case QIXIS_SYSCLK_150: - return 150000000; - case QIXIS_SYSCLK_160: - return 160000000; - case QIXIS_SYSCLK_166: - return 166666666; - } - return 66666666; -} - -unsigned long get_board_ddr_clk(void) -{ - u8 ddrclk_conf = QIXIS_READ(brdcfg[1]); -#ifdef CONFIG_FSL_QIXIS_CLOCK_MEASUREMENT - /* use accurate clock measurement */ - int freq = QIXIS_READ(clk_freq[2]) << 8 | QIXIS_READ(clk_freq[3]); - int base = QIXIS_READ(clk_base[0]) << 8 | QIXIS_READ(clk_base[1]); - u32 val; - - val = freq * base; - if (val) { - debug("DDR Clock measurement is: %d\n", val); - return val; - } else { - printf("Warning: DDR clock measurement is invalid, using value from brdcfg1.\n"); - } -#endif - - switch ((ddrclk_conf & 0x30) >> 4) { - case QIXIS_DDRCLK_100: - return 100000000; - case QIXIS_DDRCLK_125: - return 125000000; - case QIXIS_DDRCLK_133: - return 133333333; - } - return 66666666; -} - -static const char *serdes_clock_to_string(u32 clock) -{ - switch (clock) { - case SRDS_PLLCR0_RFCK_SEL_100: - return "100"; - case SRDS_PLLCR0_RFCK_SEL_125: - return "125"; - case SRDS_PLLCR0_RFCK_SEL_156_25: - return "156.25"; - case SRDS_PLLCR0_RFCK_SEL_161_13: - return "161.1328125"; - default: - return "???"; - } -} - -int misc_init_r(void) -{ - u8 sw; - serdes_corenet_t *srds_regs = - (void *)CONFIG_SYS_FSL_CORENET_SERDES_ADDR; - u32 actual[MAX_SERDES]; - unsigned int i; - - sw = QIXIS_READ(brdcfg[2]); - for (i = 0; i < MAX_SERDES; i++) { - unsigned int clock = (sw >> (6 - 2 * i)) & 3; - switch (clock) { - case 0: - actual[i] = SRDS_PLLCR0_RFCK_SEL_100; - break; - case 1: - actual[i] = SRDS_PLLCR0_RFCK_SEL_125; - break; - case 2: - actual[i] = SRDS_PLLCR0_RFCK_SEL_156_25; - break; - case 3: - actual[i] = SRDS_PLLCR0_RFCK_SEL_161_13; - break; - } - } - - for (i = 0; i < MAX_SERDES; i++) { - u32 pllcr0 = srds_regs->bank[i].pllcr0; - u32 expected = pllcr0 & SRDS_PLLCR0_RFCK_SEL_MASK; - if (expected != actual[i]) { - printf("Warning: SERDES%u expects reference clock" - " %sMHz, but actual is %sMHz\n", i + 1, - serdes_clock_to_string(expected), - serdes_clock_to_string(actual[i])); - } - } - - return 0; -} - -void ft_board_setup(void *blob, bd_t *bd) -{ - phys_addr_t base; - phys_size_t size; - - ft_cpu_setup(blob, bd); - - base = getenv_bootm_low(); - size = getenv_bootm_size(); - - fdt_fixup_memory(blob, (u64)base, (u64)size); - -#ifdef CONFIG_PCI - pci_of_setup(blob, bd); -#endif - - fdt_fixup_liodn(blob); - fdt_fixup_dr_usb(blob, bd); - -#ifdef CONFIG_SYS_DPAA_FMAN - fdt_fixup_fman_ethernet(blob); - fdt_fixup_board_enet(blob); -#endif -} - -/* - * This function is called by bdinfo to print detail board information. - * As an exmaple for future board, we organize the messages into - * several sections. If applicable, the message is in the format of - * <name> = <value> - * It should aligned with normal output of bdinfo command. - * - * Voltage: Core, DDR and another configurable voltages - * Clock : Critical clocks which are not printed already - * RCW : RCW source if not printed already - * Misc : Other important information not in above catagories - */ -void board_detail(void) -{ - int i; - u8 brdcfg[16], dutcfg[16], rst_ctl; - int vdd, rcwsrc; - static const char * const clk[] = {"66.67", "100", "125", "133.33"}; - - for (i = 0; i < 16; i++) { - brdcfg[i] = qixis_read(offsetof(struct qixis, brdcfg[0]) + i); - dutcfg[i] = qixis_read(offsetof(struct qixis, dutcfg[0]) + i); - } - - /* Voltage secion */ - if (!select_i2c_ch_pca9547(I2C_MUX_CH_VOL_MONITOR)) { - vdd = read_voltage(); - if (vdd > 0) - printf("Core voltage= %d mV\n", vdd); - select_i2c_ch_pca9547(I2C_MUX_CH_DEFAULT); - } - - printf("XVDD = 1.%d V\n", ((brdcfg[8] & 0xf) - 4) * 5 + 25); - - /* clock section */ - printf("SYSCLK = %s MHz\nDDRCLK = %s MHz\n", - clk[(brdcfg[11] >> 2) & 0x3], clk[brdcfg[11] & 3]); - - /* RCW section */ - rcwsrc = (dutcfg[0] << 1) + (dutcfg[1] & 1); - puts("RCW source = "); - switch (rcwsrc) { - case 0x017: - case 0x01f: - puts("8-bit NOR\n"); - break; - case 0x027: - case 0x02F: - puts("16-bit NOR\n"); - break; - case 0x040: - puts("SDHC/eMMC\n"); - break; - case 0x044: - puts("SPI 16-bit addressing\n"); - break; - case 0x045: - puts("SPI 24-bit addressing\n"); - break; - case 0x048: - puts("I2C normal addressing\n"); - break; - case 0x049: - puts("I2C extended addressing\n"); - break; - case 0x108: - case 0x109: - case 0x10a: - case 0x10b: - puts("8-bit NAND, 2KB\n"); - break; - default: - if ((rcwsrc >= 0x080) && (rcwsrc <= 0x09f)) - puts("Hard-coded RCW\n"); - else if ((rcwsrc >= 0x110) && (rcwsrc <= 0x11f)) - puts("8-bit NAND, 4KB\n"); - else - puts("unknown\n"); - break; - } - - /* Misc section */ - rst_ctl = QIXIS_READ(rst_ctl); - puts("HRESET_REQ = "); - switch (rst_ctl & 0x30) { - case 0x00: - puts("Ignored\n"); - break; - case 0x10: - puts("Assert HRESET\n"); - break; - case 0x30: - puts("Reset system\n"); - break; - default: - puts("N/A\n"); - break; - } -} - -/* - * Reverse engineering switch settings. - * Some bits cannot be figured out. They will be displayed as - * underscore in binary format. mask[] has those bits. - * Some bits are calculated differently than the actual switches - * if booting with overriding by FPGA. - */ -void qixis_dump_switch(void) -{ - int i; - u8 sw[9]; - - /* - * Any bit with 1 means that bit cannot be reverse engineered. - * It will be displayed as _ in binary format. - */ - static const u8 mask[] = {0, 0, 0, 0, 0, 0x1, 0xcf, 0x3f, 0x1f}; - char buf[10]; - u8 brdcfg[16], dutcfg[16]; - - for (i = 0; i < 16; i++) { - brdcfg[i] = qixis_read(offsetof(struct qixis, brdcfg[0]) + i); - dutcfg[i] = qixis_read(offsetof(struct qixis, dutcfg[0]) + i); - } - - sw[0] = dutcfg[0]; - sw[1] = (dutcfg[1] << 0x07) | \ - ((dutcfg[12] & 0xC0) >> 1) | \ - ((dutcfg[11] & 0xE0) >> 3) | \ - ((dutcfg[6] & 0x80) >> 6) | \ - ((dutcfg[1] & 0x80) >> 7); - sw[2] = ((brdcfg[1] & 0x0f) << 4) | \ - ((brdcfg[1] & 0x30) >> 2) | \ - ((brdcfg[1] & 0x40) >> 5) | \ - ((brdcfg[1] & 0x80) >> 7); - sw[3] = brdcfg[2]; - sw[4] = ((dutcfg[2] & 0x01) << 7) | \ - ((dutcfg[2] & 0x06) << 4) | \ - ((~QIXIS_READ(present)) & 0x10) | \ - ((brdcfg[3] & 0x80) >> 4) | \ - ((brdcfg[3] & 0x01) << 2) | \ - ((brdcfg[6] == 0x62) ? 3 : \ - ((brdcfg[6] == 0x5a) ? 2 : \ - ((brdcfg[6] == 0x5e) ? 1 : 0))); - sw[5] = ((brdcfg[0] & 0x0f) << 4) | \ - ((QIXIS_READ(rst_ctl) & 0x30) >> 2) | \ - ((brdcfg[0] & 0x40) >> 5); - sw[6] = (brdcfg[11] & 0x20) | - ((brdcfg[5] & 0x02) << 3); - sw[7] = (((~QIXIS_READ(rst_ctl)) & 0x40) << 1) | \ - ((brdcfg[5] & 0x10) << 2); - sw[8] = ((brdcfg[12] & 0x08) << 4) | \ - ((brdcfg[12] & 0x03) << 5); - - puts("DIP switch (reverse-engineering)\n"); - for (i = 0; i < 9; i++) { - printf("SW%d = 0b%s (0x%02x)\n", - i + 1, byte_to_binary_mask(sw[i], mask[i], buf), sw[i]); - } -} - -static int do_vdd_adjust(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{ - ulong override; - - if (argc < 2) - return CMD_RET_USAGE; - if (!strict_strtoul(argv[1], 10, &override)) - adjust_vdd(override); /* the value is checked by callee */ - else - return CMD_RET_USAGE; - - return 0; -} - -U_BOOT_CMD( - vdd_override, 2, 0, do_vdd_adjust, - "Override VDD", - "- override with the voltage specified in mV, eg. 1050" -); diff --git a/board/freescale/t4qds/tlb.c b/board/freescale/t4qds/tlb.c index 92c01cf..08bf1f0 100644 --- a/board/freescale/t4qds/tlb.c +++ b/board/freescale/t4qds/tlb.c @@ -127,10 +127,11 @@ struct fsl_e_tlb_entry tlb_table[] = { MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, 0, 16, BOOKE_PAGESZ_64K, 1), #endif +#ifdef QIXIS_BASE_PHYS SET_TLB_ENTRY(1, QIXIS_BASE, QIXIS_BASE_PHYS, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, 0, 17, BOOKE_PAGESZ_4K, 1), - +#endif };
int num_tlb_entries = ARRAY_SIZE(tlb_table); diff --git a/boards.cfg b/boards.cfg index 1e598cb..6a1d56b 100644 --- a/boards.cfg +++ b/boards.cfg @@ -910,6 +910,7 @@ stxgp3 powerpc mpc85xx stxgp3 stx stxssa powerpc mpc85xx stxssa stx - stxssa stxssa_4M powerpc mpc85xx stxssa stx - stxssa:STXSSA_4M T4240QDS powerpc mpc85xx t4qds freescale - T4240QDS:PPC_T4240 +T4240EMU powerpc mpc85xx t4qds freescale - T4240EMU:PPC_T4240 T4240QDS_SDCARD powerpc mpc85xx t4qds freescale - T4240QDS:PPC_T4240,RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 T4240QDS_SPIFLASH powerpc mpc85xx t4qds freescale - T4240QDS:PPC_T4240,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 T4160QDS powerpc mpc85xx t4qds freescale - T4240QDS:PPC_T4160 diff --git a/include/configs/T4240EMU.h b/include/configs/T4240EMU.h new file mode 100644 index 0000000..399e878 --- /dev/null +++ b/include/configs/T4240EMU.h @@ -0,0 +1,185 @@ +/* + * Copyright 2013 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * T4240 EMU board configuration file + */ +#ifndef __CONFIG_H +#define __CONFIG_H + +#define CONFIG_T4240EMU +#define CONFIG_PHYS_64BIT + +#define CONFIG_SYS_NO_FLASH 1 +#define CONFIG_SYS_FSL_DDR_EMU 1 +#define CONFIG_SYS_FSL_NO_QIXIS 1 +#define CONFIG_SYS_FSL_NO_SERDES 1 + +#include "t4qds.h" + +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_CACHE_FLUSH + +#define CONFIG_ENV_IS_NOWHERE +#define CONFIG_ENV_SIZE 0x2000 + +#define CONFIG_SYS_CLK_FREQ 100000000 +#define CONFIG_DDR_CLK_FREQ 133333333 +#define CONFIG_FSL_TBCLK_EXTRA_DIV 100 + + +/* + * DDR Setup + */ +#define CONFIG_SYS_SPD_BUS_NUM 1 +#define SPD_EEPROM_ADDRESS1 0x51 +#define SPD_EEPROM_ADDRESS2 0x52 +#define SPD_EEPROM_ADDRESS3 0x53 +#define SPD_EEPROM_ADDRESS4 0x54 +#define SPD_EEPROM_ADDRESS5 0x55 +#define SPD_EEPROM_ADDRESS6 0x56 +#define SPD_EEPROM_ADDRESS SPD_EEPROM_ADDRESS1 /* for p3041/p5010 */ +#define CONFIG_SYS_SDRAM_SIZE 4096 /* for fixed parameter use */ + +/* + * IFC Definitions + */ +#define CONFIG_SYS_NOR0_CSPR_EXT (0xf) +#define CONFIG_SYS_NOR_AMASK IFC_AMASK(128*1024*1024) +/* NOR Flash Timing Params */ +#define CONFIG_SYS_NOR0_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS \ + + 0x8000000) | \ + CSPR_PORT_SIZE_32 | \ + CSPR_MSEL_NOR | \ + CSPR_V) +#define CONFIG_SYS_NOR_CSOR CSOR_NOR_ADM_SHIFT(0) +#define CONFIG_SYS_NOR_FTIM0 (FTIM0_NOR_TACSE(0x1) | \ + FTIM0_NOR_TEADC(0x1) | \ + FTIM0_NOR_TEAHC(0x1)) +#define CONFIG_SYS_NOR_FTIM1 (FTIM1_NOR_TACO(0x1) | \ + FTIM1_NOR_TRAD_NOR(0x1)) +#define CONFIG_SYS_NOR_FTIM2 (FTIM2_NOR_TCS(0x0) | \ + FTIM2_NOR_TCH(0x0) | \ + FTIM2_NOR_TWP(0x1)) +#define CONFIG_SYS_NOR_FTIM3 0x04000000 +#define CONFIG_SYS_IFC_CCR 0x01000000 + +#define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NOR0_CSPR_EXT +#define CONFIG_SYS_CSPR0 CONFIG_SYS_NOR0_CSPR +#define CONFIG_SYS_AMASK0 CONFIG_SYS_NOR_AMASK +#define CONFIG_SYS_CSOR0 CONFIG_SYS_NOR_CSOR +#define CONFIG_SYS_CS0_FTIM0 CONFIG_SYS_NOR_FTIM0 +#define CONFIG_SYS_CS0_FTIM1 CONFIG_SYS_NOR_FTIM1 +#define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NOR_FTIM2 +#define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NOR_FTIM3 + + +/* I2C */ +#define CONFIG_SYS_I2C_SPEED 4000000 /* faster speed for emulator */ + + +/* Qman/Bman */ +#define CONFIG_SYS_DPAA_QBMAN /* Support Q/Bman */ +#define CONFIG_SYS_BMAN_NUM_PORTALS 50 +#define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 +#define CONFIG_SYS_BMAN_MEM_PHYS 0xff4000000ull +#define CONFIG_SYS_BMAN_MEM_SIZE 0x02000000 +#define CONFIG_SYS_QMAN_NUM_PORTALS 50 +#define CONFIG_SYS_QMAN_MEM_BASE 0xf6000000 +#define CONFIG_SYS_QMAN_MEM_PHYS 0xff6000000ull +#define CONFIG_SYS_QMAN_MEM_SIZE 0x02000000 + +#define CONFIG_SYS_DPAA_FMAN +#define CONFIG_SYS_DPAA_PME +#define CONFIG_SYS_PMAN +#define CONFIG_SYS_DPAA_DCE +#define CONFIG_SYS_INTERLAKEN + +#define CONFIG_SYS_QE_FMAN_FW_IN_NOR +#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xEFF40000 +#define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 +#define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH) + + + +#define CONFIG_BOOTDELAY 0 + +/* + * T4240 has 3 DDR controllers. Default to 3-way interleaving. It can be + * 3way_1KB, 3way_4KB, 3way_8KB. T4160 has 2 DDR controllers. Default to 2-way + * interleaving. It can be cacheline, page, bank, superbank. + * See doc/README.fsl-ddr for details. + */ +#ifdef CONFIG_PPC_T4240 +#define CTRL_INTLV_PREFERED 3way_4KB +#else +#define CTRL_INTLV_PREFERED cacheline +#endif + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "hwconfig=fsl_ddr:" \ + "ctlr_intlv=" __stringify(CTRL_INTLV_PREFERED) "," \ + "bank_intlv=auto;" \ + "netdev=eth0\0" \ + "uboot=" __stringify(CONFIG_UBOOTPATH) "\0" \ + "ubootaddr=" __stringify(CONFIG_SYS_TEXT_BASE) "\0" \ + "consoledev=ttyS0\0" \ + "ramdiskaddr=2000000\0" \ + "ramdiskfile=t4240emu/ramdisk.uboot\0" \ + "fdtaddr=c00000\0" \ + "fdtfile=t4240emu/t4240emu.dtb\0" \ + "bdev=sda3\0" \ + "c=ffe\0" + +/* + * For emulation this causes u-boot to jump to the start of the proof point + * app code automatically + */ +#define CONFIG_PROOF_POINTS \ + "setenv bootargs root=/dev/$bdev rw " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "cpu 1 release 0x29000000 - - -;" \ + "cpu 2 release 0x29000000 - - -;" \ + "cpu 3 release 0x29000000 - - -;" \ + "cpu 4 release 0x29000000 - - -;" \ + "cpu 5 release 0x29000000 - - -;" \ + "cpu 6 release 0x29000000 - - -;" \ + "cpu 7 release 0x29000000 - - -;" \ + "go 0x29000000" + +#define CONFIG_HVBOOT \ + "setenv bootargs config-addr=0x60000000; " \ + "bootm 0x01000000 - 0x00f00000" + +#define CONFIG_LINUX \ + "errata;" \ + "setenv othbootargs ignore_loglevel;" \ + "setenv bootargs root=/dev/ram rw " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "setenv ramdiskaddr 0x02000000;" \ + "setenv fdtaddr 0x00c00000;" \ + "setenv loadaddr 0x1000000;" \ + "bootm $loadaddr $ramdiskaddr $fdtaddr" + +#define CONFIG_BOOTCOMMAND CONFIG_LINUX + +#endif /* __CONFIG_H */ diff --git a/include/configs/T4240QDS.h b/include/configs/T4240QDS.h index 6dd5c0d..6294f2b 100644 --- a/include/configs/T4240QDS.h +++ b/include/configs/T4240QDS.h @@ -23,6 +23,9 @@ /* * T4240 QDS board configuration file */ +#ifndef __CONFIG_H +#define __CONFIG_H + #define CONFIG_T4240QDS #define CONFIG_PHYS_64BIT
@@ -31,4 +34,540 @@
#define CONFIG_ICS307_REFCLK_HZ 25000000 /* ICS307 ref clk freq */
+#ifdef CONFIG_RAMBOOT_PBL +#define CONFIG_RAMBOOT_TEXT_BASE CONFIG_SYS_TEXT_BASE +#define CONFIG_RESET_VECTOR_ADDRESS 0xfffffffc +#define CONFIG_PBLPBI_CONFIG $(SRCTREE)/board/freescale/t4qds/t4_pbi.cfg +#define CONFIG_PBLRCW_CONFIG $(SRCTREE)/board/freescale/t4qds/t4_rcw.cfg +#endif + +#ifdef CONFIG_SRIO_PCIE_BOOT_SLAVE +/* Set 1M boot space */ +#define CONFIG_SYS_SRIO_PCIE_BOOT_SLAVE_ADDR (CONFIG_SYS_TEXT_BASE & 0xfff00000) +#define CONFIG_SYS_SRIO_PCIE_BOOT_SLAVE_ADDR_PHYS \ + (0x300000000ull | CONFIG_SYS_SRIO_PCIE_BOOT_SLAVE_ADDR) +#define CONFIG_RESET_VECTOR_ADDRESS 0xfffffffc +#define CONFIG_SYS_NO_FLASH +#endif + +#define CONFIG_SRIO_PCIE_BOOT_MASTER +#define CONFIG_DDR_ECC + #include "t4qds.h" + +#ifdef CONFIG_SYS_NO_FLASH +#if !defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) && !defined(CONFIG_RAMBOOT_PBL) +#define CONFIG_ENV_IS_NOWHERE +#endif +#else +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE +#endif + +#if defined(CONFIG_SPIFLASH) +#define CONFIG_SYS_EXTRA_ENV_RELOC +#define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_ENV_SPI_BUS 0 +#define CONFIG_ENV_SPI_CS 0 +#define CONFIG_ENV_SPI_MAX_HZ 10000000 +#define CONFIG_ENV_SPI_MODE 0 +#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ +#define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ +#define CONFIG_ENV_SECT_SIZE 0x10000 +#elif defined(CONFIG_SDCARD) +#define CONFIG_SYS_EXTRA_ENV_RELOC +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_ENV_OFFSET (512 * 1097) +#elif defined(CONFIG_NAND) +#define CONFIG_SYS_EXTRA_ENV_RELOC +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE +#define CONFIG_ENV_OFFSET (5 * CONFIG_SYS_NAND_BLOCK_SIZE) +#elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) +#define CONFIG_ENV_IS_IN_REMOTE +#define CONFIG_ENV_ADDR 0xffe20000 +#define CONFIG_ENV_SIZE 0x2000 +#elif defined(CONFIG_ENV_IS_NOWHERE) +#define CONFIG_ENV_SIZE 0x2000 +#else +#define CONFIG_ENV_IS_IN_FLASH +#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ +#endif + +#define CONFIG_SYS_CLK_FREQ get_board_sys_clk() +#define CONFIG_DDR_CLK_FREQ get_board_ddr_clk() + +#ifndef __ASSEMBLY__ +unsigned long get_board_sys_clk(void); +unsigned long get_board_ddr_clk(void); +#endif + +/* EEPROM */ +#define CONFIG_ID_EEPROM +#define CONFIG_SYS_I2C_EEPROM_NXID +#define CONFIG_SYS_EEPROM_BUS_NUM 0 +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x57 +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 + +/* + * DDR Setup + */ +#define CONFIG_SYS_SPD_BUS_NUM 0 +#define SPD_EEPROM_ADDRESS1 0x51 +#define SPD_EEPROM_ADDRESS2 0x52 +#define SPD_EEPROM_ADDRESS3 0x53 +#define SPD_EEPROM_ADDRESS4 0x54 +#define SPD_EEPROM_ADDRESS5 0x55 +#define SPD_EEPROM_ADDRESS6 0x56 +#define SPD_EEPROM_ADDRESS SPD_EEPROM_ADDRESS1 /* for p3041/p5010 */ +#define CONFIG_SYS_SDRAM_SIZE 4096 /* for fixed parameter use */ + +/* + * IFC Definitions + */ +#define CONFIG_SYS_NOR0_CSPR_EXT (0xf) +#define CONFIG_SYS_NOR0_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS \ + + 0x8000000) | \ + CSPR_PORT_SIZE_16 | \ + CSPR_MSEL_NOR | \ + CSPR_V) +#define CONFIG_SYS_NOR1_CSPR_EXT (0xf) +#define CONFIG_SYS_NOR1_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS) | \ + CSPR_PORT_SIZE_16 | \ + CSPR_MSEL_NOR | \ + CSPR_V) +#define CONFIG_SYS_NOR_AMASK IFC_AMASK(128*1024*1024) +/* NOR Flash Timing Params */ +#define CONFIG_SYS_NOR_CSOR CSOR_NAND_TRHZ_80 + +#define CONFIG_SYS_NOR_FTIM0 (FTIM0_NOR_TACSE(0x4) | \ + FTIM0_NOR_TEADC(0x5) | \ + FTIM0_NOR_TEAHC(0x5)) +#define CONFIG_SYS_NOR_FTIM1 (FTIM1_NOR_TACO(0x35) | \ + FTIM1_NOR_TRAD_NOR(0x1A) |\ + FTIM1_NOR_TSEQRAD_NOR(0x13)) +#define CONFIG_SYS_NOR_FTIM2 (FTIM2_NOR_TCS(0x4) | \ + FTIM2_NOR_TCH(0x4) | \ + FTIM2_NOR_TWPH(0x0E) | \ + FTIM2_NOR_TWP(0x1c)) +#define CONFIG_SYS_NOR_FTIM3 0x0 + +#define CONFIG_SYS_FLASH_QUIET_TEST +#define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */ + +#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* number of banks */ +#define CONFIG_SYS_MAX_FLASH_SECT 1024 /* sectors per device */ +#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ +#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */ + +#define CONFIG_SYS_FLASH_EMPTY_INFO +#define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS \ + + 0x8000000, CONFIG_SYS_FLASH_BASE_PHYS} + +#define CONFIG_FSL_QIXIS /* use common QIXIS code */ +#define QIXIS_BASE 0xffdf0000 +#define QIXIS_LBMAP_SWITCH 6 +#define QIXIS_LBMAP_MASK 0x0f +#define QIXIS_LBMAP_SHIFT 0 +#define QIXIS_LBMAP_DFLTBANK 0x00 +#define QIXIS_LBMAP_ALTBANK 0x04 +#define QIXIS_RST_CTL_RESET 0x83 +#define QIXIS_RCFG_CTL_RECONFIG_IDLE 0x20 +#define QIXIS_RCFG_CTL_RECONFIG_START 0x21 +#define QIXIS_RCFG_CTL_WATCHDOG_ENBLE 0x08 +#define QIXIS_BASE_PHYS (0xf00000000ull | QIXIS_BASE) + +#define CONFIG_SYS_CSPR3_EXT (0xf) +#define CONFIG_SYS_CSPR3 (CSPR_PHYS_ADDR(QIXIS_BASE_PHYS) \ + | CSPR_PORT_SIZE_8 \ + | CSPR_MSEL_GPCM \ + | CSPR_V) +#define CONFIG_SYS_AMASK3 IFC_AMASK(4*1024) +#define CONFIG_SYS_CSOR3 0x0 +/* QIXIS Timing parameters for IFC CS3 */ +#define CONFIG_SYS_CS3_FTIM0 (FTIM0_GPCM_TACSE(0x0e) | \ + FTIM0_GPCM_TEADC(0x0e) | \ + FTIM0_GPCM_TEAHC(0x0e)) +#define CONFIG_SYS_CS3_FTIM1 (FTIM1_GPCM_TACO(0xff) | \ + FTIM1_GPCM_TRAD(0x3f)) +#define CONFIG_SYS_CS3_FTIM2 (FTIM2_GPCM_TCS(0x0e) | \ + FTIM2_GPCM_TCH(0x0) | \ + FTIM2_GPCM_TWP(0x1f)) +#define CONFIG_SYS_CS3_FTIM3 0x0 + +/* NAND Flash on IFC */ +#define CONFIG_NAND_FSL_IFC +#define CONFIG_SYS_NAND_BASE 0xff800000 +#define CONFIG_SYS_NAND_BASE_PHYS (0xf00000000ull | CONFIG_SYS_NAND_BASE) + +#define CONFIG_SYS_NAND_CSPR_EXT (0xf) +#define CONFIG_SYS_NAND_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_NAND_BASE_PHYS) \ + | CSPR_PORT_SIZE_8 /* Port Size = 8 bit */ \ + | CSPR_MSEL_NAND /* MSEL = NAND */ \ + | CSPR_V) +#define CONFIG_SYS_NAND_AMASK IFC_AMASK(64*1024) + +#define CONFIG_SYS_NAND_CSOR (CSOR_NAND_ECC_ENC_EN /* ECC on encode */ \ + | CSOR_NAND_ECC_DEC_EN /* ECC on decode */ \ + | CSOR_NAND_ECC_MODE_4 /* 4-bit ECC */ \ + | CSOR_NAND_RAL_3 /* RAL = 2Byes */ \ + | CSOR_NAND_PGS_2K /* Page Size = 2K */ \ + | CSOR_NAND_SPRZ_64/* Spare size = 64 */ \ + | CSOR_NAND_PB(64)) /*Pages Per Block = 64*/ + +#define CONFIG_SYS_NAND_ONFI_DETECTION + +/* ONFI NAND Flash mode0 Timing Params */ +#define CONFIG_SYS_NAND_FTIM0 (FTIM0_NAND_TCCST(0x07) | \ + FTIM0_NAND_TWP(0x18) | \ + FTIM0_NAND_TWCHT(0x07) | \ + FTIM0_NAND_TWH(0x0a)) +#define CONFIG_SYS_NAND_FTIM1 (FTIM1_NAND_TADLE(0x32) | \ + FTIM1_NAND_TWBE(0x39) | \ + FTIM1_NAND_TRR(0x0e) | \ + FTIM1_NAND_TRP(0x18)) +#define CONFIG_SYS_NAND_FTIM2 (FTIM2_NAND_TRAD(0x0f) | \ + FTIM2_NAND_TREH(0x0a) | \ + FTIM2_NAND_TWHRE(0x1e)) +#define CONFIG_SYS_NAND_FTIM3 0x0 + +#define CONFIG_SYS_NAND_DDR_LAW 11 + +#define CONFIG_SYS_NAND_BASE_LIST { CONFIG_SYS_NAND_BASE } +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_MTD_NAND_VERIFY_WRITE +#define CONFIG_CMD_NAND + +#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) + +#if defined(CONFIG_NAND) +#define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NAND_CSPR_EXT +#define CONFIG_SYS_CSPR0 CONFIG_SYS_NAND_CSPR +#define CONFIG_SYS_AMASK0 CONFIG_SYS_NAND_AMASK +#define CONFIG_SYS_CSOR0 CONFIG_SYS_NAND_CSOR +#define CONFIG_SYS_CS0_FTIM0 CONFIG_SYS_NAND_FTIM0 +#define CONFIG_SYS_CS0_FTIM1 CONFIG_SYS_NAND_FTIM1 +#define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NAND_FTIM2 +#define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NAND_FTIM3 +#define CONFIG_SYS_CSPR2_EXT CONFIG_SYS_NOR0_CSPR_EXT +#define CONFIG_SYS_CSPR2 CONFIG_SYS_NOR0_CSPR +#define CONFIG_SYS_AMASK2 CONFIG_SYS_NOR_AMASK +#define CONFIG_SYS_CSOR2 CONFIG_SYS_NOR_CSOR +#define CONFIG_SYS_CS2_FTIM0 CONFIG_SYS_NOR_FTIM0 +#define CONFIG_SYS_CS2_FTIM1 CONFIG_SYS_NOR_FTIM1 +#define CONFIG_SYS_CS2_FTIM2 CONFIG_SYS_NOR_FTIM2 +#define CONFIG_SYS_CS2_FTIM3 CONFIG_SYS_NOR_FTIM3 +#else +#define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NOR0_CSPR_EXT +#define CONFIG_SYS_CSPR0 CONFIG_SYS_NOR0_CSPR +#define CONFIG_SYS_AMASK0 CONFIG_SYS_NOR_AMASK +#define CONFIG_SYS_CSOR0 CONFIG_SYS_NOR_CSOR +#define CONFIG_SYS_CS0_FTIM0 CONFIG_SYS_NOR_FTIM0 +#define CONFIG_SYS_CS0_FTIM1 CONFIG_SYS_NOR_FTIM1 +#define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NOR_FTIM2 +#define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NOR_FTIM3 +#define CONFIG_SYS_CSPR2_EXT CONFIG_SYS_NAND_CSPR_EXT +#define CONFIG_SYS_CSPR2 CONFIG_SYS_NAND_CSPR +#define CONFIG_SYS_AMASK2 CONFIG_SYS_NAND_AMASK +#define CONFIG_SYS_CSOR2 CONFIG_SYS_NAND_CSOR +#define CONFIG_SYS_CS2_FTIM0 CONFIG_SYS_NAND_FTIM0 +#define CONFIG_SYS_CS2_FTIM1 CONFIG_SYS_NAND_FTIM1 +#define CONFIG_SYS_CS2_FTIM2 CONFIG_SYS_NAND_FTIM2 +#define CONFIG_SYS_CS2_FTIM3 CONFIG_SYS_NAND_FTIM3 +#endif +#define CONFIG_SYS_CSPR1_EXT CONFIG_SYS_NOR1_CSPR_EXT +#define CONFIG_SYS_CSPR1 CONFIG_SYS_NOR1_CSPR +#define CONFIG_SYS_AMASK1 CONFIG_SYS_NOR_AMASK +#define CONFIG_SYS_CSOR1 CONFIG_SYS_NOR_CSOR +#define CONFIG_SYS_CS1_FTIM0 CONFIG_SYS_NOR_FTIM0 +#define CONFIG_SYS_CS1_FTIM1 CONFIG_SYS_NOR_FTIM1 +#define CONFIG_SYS_CS1_FTIM2 CONFIG_SYS_NOR_FTIM2 +#define CONFIG_SYS_CS1_FTIM3 CONFIG_SYS_NOR_FTIM3 + +#if defined(CONFIG_RAMBOOT_PBL) +#define CONFIG_SYS_RAMBOOT +#endif + + +/* I2C */ +#define CONFIG_SYS_I2C_SPEED 100000 /* I2C speed */ +#define I2C_MUX_PCA_ADDR_PRI 0x77 /* I2C bus multiplexer,primary */ +#define I2C_MUX_PCA_ADDR_SEC 0x76 /* I2C bus multiplexer,secondary */ + +#define I2C_MUX_CH_DEFAULT 0x8 +#define I2C_MUX_CH_VOL_MONITOR 0xa +#define I2C_MUX_CH_VSC3316_FS 0xc +#define I2C_MUX_CH_VSC3316_BS 0xd + +/* Voltage monitor on channel 2*/ +#define I2C_VOL_MONITOR_ADDR 0x40 +#define I2C_VOL_MONITOR_BUS_V_OFFSET 0x2 +#define I2C_VOL_MONITOR_BUS_V_OVF 0x1 +#define I2C_VOL_MONITOR_BUS_V_SHIFT 3 + +/* VSC Crossbar switches */ +#define CONFIG_VSC_CROSSBAR +#define VSC3316_FSM_TX_ADDR 0x70 +#define VSC3316_FSM_RX_ADDR 0x71 + +/* + * RapidIO + */ + +/* + * for slave u-boot IMAGE instored in master memory space, + * PHYS must be aligned based on the SIZE + */ +#define CONFIG_SRIO_PCIE_BOOT_IMAGE_MEM_PHYS 0xfef080000ull +#define CONFIG_SRIO_PCIE_BOOT_IMAGE_MEM_BUS1 0xfff80000ull +#define CONFIG_SRIO_PCIE_BOOT_IMAGE_SIZE 0x80000 /* 512K */ +#define CONFIG_SRIO_PCIE_BOOT_IMAGE_MEM_BUS2 0x3fff80000ull +/* + * for slave UCODE and ENV instored in master memory space, + * PHYS must be aligned based on the SIZE + */ +#define CONFIG_SRIO_PCIE_BOOT_UCODE_ENV_MEM_PHYS 0xfef040000ull +#define CONFIG_SRIO_PCIE_BOOT_UCODE_ENV_MEM_BUS 0x3ffe00000ull +#define CONFIG_SRIO_PCIE_BOOT_UCODE_ENV_SIZE 0x40000 /* 256K */ + +/* slave core release by master*/ +#define CONFIG_SRIO_PCIE_BOOT_BRR_OFFSET 0xe00e4 +#define CONFIG_SRIO_PCIE_BOOT_RELEASE_MASK 0x00000001 /* release core 0 */ + +/* + * SRIO_PCIE_BOOT - SLAVE + */ +#ifdef CONFIG_SRIO_PCIE_BOOT_SLAVE +#define CONFIG_SYS_SRIO_PCIE_BOOT_UCODE_ENV_ADDR 0xFFE00000 +#define CONFIG_SYS_SRIO_PCIE_BOOT_UCODE_ENV_ADDR_PHYS \ + (0x300000000ull | CONFIG_SYS_SRIO_PCIE_BOOT_UCODE_ENV_ADDR) +#endif +/* + * eSPI - Enhanced SPI + */ +#define CONFIG_FSL_ESPI +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_SST +#define CONFIG_CMD_SF +#define CONFIG_SF_DEFAULT_SPEED 10000000 +#define CONFIG_SF_DEFAULT_MODE 0 + + +/* Qman/Bman */ +#ifndef CONFIG_NOBQFMAN +#define CONFIG_SYS_DPAA_QBMAN /* Support Q/Bman */ +#define CONFIG_SYS_BMAN_NUM_PORTALS 50 +#define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 +#define CONFIG_SYS_BMAN_MEM_PHYS 0xff4000000ull +#define CONFIG_SYS_BMAN_MEM_SIZE 0x02000000 +#define CONFIG_SYS_QMAN_NUM_PORTALS 50 +#define CONFIG_SYS_QMAN_MEM_BASE 0xf6000000 +#define CONFIG_SYS_QMAN_MEM_PHYS 0xff6000000ull +#define CONFIG_SYS_QMAN_MEM_SIZE 0x02000000 + +#define CONFIG_SYS_DPAA_FMAN +#define CONFIG_SYS_DPAA_PME +#define CONFIG_SYS_PMAN +#define CONFIG_SYS_DPAA_DCE +#define CONFIG_SYS_INTERLAKEN + +/* Default address of microcode for the Linux Fman driver */ +#if defined(CONFIG_SPIFLASH) +/* + * env is stored at 0x100000, sector size is 0x10000, ucode is stored after + * env, so we got 0x110000. + */ +#define CONFIG_SYS_QE_FW_IN_SPIFLASH +#define CONFIG_SYS_QE_FMAN_FW_ADDR 0x110000 +#elif defined(CONFIG_SDCARD) +/* + * PBL SD boot image should stored at 0x1000(8 blocks), the size of the image is + * about 545KB (1089 blocks), Env is stored after the image, and the env size is + * 0x2000 (16 blocks), 8 + 1089 + 16 = 1113, enlarge it to 1130. + */ +#define CONFIG_SYS_QE_FMAN_FW_IN_MMC +#define CONFIG_SYS_QE_FMAN_FW_ADDR (512 * 1130) +#elif defined(CONFIG_NAND) +#define CONFIG_SYS_QE_FMAN_FW_IN_NAND +#define CONFIG_SYS_QE_FMAN_FW_ADDR (6 * CONFIG_SYS_NAND_BLOCK_SIZE) +#elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) +/* + * Slave has no ucode locally, it can fetch this from remote. When implementing + * in two corenet boards, slave's ucode could be stored in master's memory + * space, the address can be mapped from slave TLB->slave LAW-> + * slave SRIO or PCIE outbound window->master inbound window-> + * master LAW->the ucode address in master's memory space. + */ +#define CONFIG_SYS_QE_FMAN_FW_IN_REMOTE +#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xFFE00000 +#else +#define CONFIG_SYS_QE_FMAN_FW_IN_NOR +#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xEFF40000 +#endif +#define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 +#define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH) +#endif /* CONFIG_NOBQFMAN */ + +#ifdef CONFIG_SYS_DPAA_FMAN +#define CONFIG_FMAN_ENET +#define CONFIG_PHYLIB_10G +#define CONFIG_PHY_VITESSE +#define CONFIG_PHY_TERANETICS +#define SGMII_CARD_PORT1_PHY_ADDR 0x1C +#define SGMII_CARD_PORT2_PHY_ADDR 0x1D +#define SGMII_CARD_PORT3_PHY_ADDR 0x1E +#define SGMII_CARD_PORT4_PHY_ADDR 0x1F +#define FM1_10GEC1_PHY_ADDR 0x0 +#define FM1_10GEC2_PHY_ADDR 0x1 +#define FM2_10GEC1_PHY_ADDR 0x2 +#define FM2_10GEC2_PHY_ADDR 0x3 +#endif + + +/* SATA */ +#ifdef CONFIG_FSL_SATA_V2 +#define CONFIG_LIBATA +#define CONFIG_FSL_SATA + +#define CONFIG_SYS_SATA_MAX_DEVICE 2 +#define CONFIG_SATA1 +#define CONFIG_SYS_SATA1 CONFIG_SYS_MPC85xx_SATA1_ADDR +#define CONFIG_SYS_SATA1_FLAGS FLAGS_DMA +#define CONFIG_SATA2 +#define CONFIG_SYS_SATA2 CONFIG_SYS_MPC85xx_SATA2_ADDR +#define CONFIG_SYS_SATA2_FLAGS FLAGS_DMA + +#define CONFIG_LBA48 +#define CONFIG_CMD_SATA +#define CONFIG_DOS_PARTITION +#define CONFIG_CMD_EXT2 +#endif + +#ifdef CONFIG_FMAN_ENET +#define CONFIG_MII /* MII PHY management */ +#define CONFIG_ETHPRIME "FM1@DTSEC1" +#define CONFIG_PHY_GIGE /* Include GbE speed/duplex detection */ +#endif + +/* +* USB +*/ +#define CONFIG_CMD_USB +#define CONFIG_USB_STORAGE +#define CONFIG_USB_EHCI +#define CONFIG_USB_EHCI_FSL +#define CONFIG_EHCI_HCD_INIT_AFTER_RESET +#define CONFIG_CMD_EXT2 +#define CONFIG_HAS_FSL_DR_USB + +#define CONFIG_MMC + +#ifdef CONFIG_MMC +#define CONFIG_FSL_ESDHC +#define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR +#define CONFIG_SYS_FSL_ESDHC_BROKEN_TIMEOUT +#define CONFIG_CMD_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_FAT +#define CONFIG_DOS_PARTITION +#endif + +#define CONFIG_BOOTDELAY 10 /* -1 disables auto-boot */ + +#define __USB_PHY_TYPE utmi + +/* + * T4240 has 3 DDR controllers. Default to 3-way interleaving. It can be + * 3way_1KB, 3way_4KB, 3way_8KB. T4160 has 2 DDR controllers. Default to 2-way + * interleaving. It can be cacheline, page, bank, superbank. + * See doc/README.fsl-ddr for details. + */ +#ifdef CONFIG_PPC_T4240 +#define CTRL_INTLV_PREFERED 3way_4KB +#else +#define CTRL_INTLV_PREFERED cacheline +#endif + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "hwconfig=fsl_ddr:" \ + "ctlr_intlv=" __stringify(CTRL_INTLV_PREFERED) "," \ + "bank_intlv=auto;" \ + "usb1:dr_mode=host,phy_type=" __stringify(__USB_PHY_TYPE) "\0"\ + "netdev=eth0\0" \ + "uboot=" __stringify(CONFIG_UBOOTPATH) "\0" \ + "ubootaddr=" __stringify(CONFIG_SYS_TEXT_BASE) "\0" \ + "tftpflash=tftpboot $loadaddr $uboot && " \ + "protect off $ubootaddr +$filesize && " \ + "erase $ubootaddr +$filesize && " \ + "cp.b $loadaddr $ubootaddr $filesize && " \ + "protect on $ubootaddr +$filesize && " \ + "cmp.b $loadaddr $ubootaddr $filesize\0" \ + "consoledev=ttyS0\0" \ + "ramdiskaddr=2000000\0" \ + "ramdiskfile=t4240qds/ramdisk.uboot\0" \ + "fdtaddr=c00000\0" \ + "fdtfile=t4240qds/t4240qds.dtb\0" \ + "bdev=sda3\0" \ + "c=ffe\0" + +#define CONFIG_HVBOOT \ + "setenv bootargs config-addr=0x60000000; " \ + "bootm 0x01000000 - 0x00f00000" + +#define CONFIG_ALU \ + "setenv bootargs root=/dev/$bdev rw " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "cpu 1 release 0x01000000 - - -;" \ + "cpu 2 release 0x01000000 - - -;" \ + "cpu 3 release 0x01000000 - - -;" \ + "cpu 4 release 0x01000000 - - -;" \ + "cpu 5 release 0x01000000 - - -;" \ + "cpu 6 release 0x01000000 - - -;" \ + "cpu 7 release 0x01000000 - - -;" \ + "go 0x01000000" + +#define CONFIG_LINUX \ + "setenv bootargs root=/dev/ram rw " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "setenv ramdiskaddr 0x02000000;" \ + "setenv fdtaddr 0x00c00000;" \ + "setenv loadaddr 0x1000000;" \ + "bootm $loadaddr $ramdiskaddr $fdtaddr" + +#define CONFIG_HDBOOT \ + "setenv bootargs root=/dev/$bdev rw " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "tftp $loadaddr $bootfile;" \ + "tftp $fdtaddr $fdtfile;" \ + "bootm $loadaddr - $fdtaddr" + +#define CONFIG_NFSBOOTCOMMAND \ + "setenv bootargs root=/dev/nfs rw " \ + "nfsroot=$serverip:$rootpath " \ + "ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "tftp $loadaddr $bootfile;" \ + "tftp $fdtaddr $fdtfile;" \ + "bootm $loadaddr - $fdtaddr" + +#define CONFIG_RAMBOOTCOMMAND \ + "setenv bootargs root=/dev/ram rw " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "tftp $ramdiskaddr $ramdiskfile;" \ + "tftp $loadaddr $bootfile;" \ + "tftp $fdtaddr $fdtfile;" \ + "bootm $loadaddr $ramdiskaddr $fdtaddr" + +#define CONFIG_BOOTCOMMAND CONFIG_LINUX + +#ifdef CONFIG_SECURE_BOOT +#include <asm/fsl_secure_boot.h> +#endif + +#endif /* __CONFIG_H */ diff --git a/include/configs/t4qds.h b/include/configs/t4qds.h index 3f7b82d..c3fa3b7 100644 --- a/include/configs/t4qds.h +++ b/include/configs/t4qds.h @@ -23,15 +23,8 @@ /* * Corenet DS style board configuration file */ -#ifndef __CONFIG_H -#define __CONFIG_H - -#ifdef CONFIG_RAMBOOT_PBL -#define CONFIG_RAMBOOT_TEXT_BASE CONFIG_SYS_TEXT_BASE -#define CONFIG_RESET_VECTOR_ADDRESS 0xfffffffc -#define CONFIG_PBLPBI_CONFIG $(SRCTREE)/board/freescale/t4qds/t4_pbi.cfg -#define CONFIG_PBLRCW_CONFIG $(SRCTREE)/board/freescale/t4qds/t4_rcw.cfg -#endif +#ifndef __T4QDS_H +#define __T4QDS_H
#define CONFIG_CMD_REGINFO
@@ -69,63 +62,12 @@
#define CONFIG_ENV_OVERWRITE
-#ifdef CONFIG_SYS_NO_FLASH -#define CONFIG_ENV_IS_NOWHERE -#else -#define CONFIG_FLASH_CFI_DRIVER -#define CONFIG_SYS_FLASH_CFI -#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE -#endif - -#ifndef CONFIG_SYS_NO_FLASH -#if defined(CONFIG_SPIFLASH) -#define CONFIG_SYS_EXTRA_ENV_RELOC -#define CONFIG_ENV_IS_IN_SPI_FLASH -#define CONFIG_ENV_SPI_BUS 0 -#define CONFIG_ENV_SPI_CS 0 -#define CONFIG_ENV_SPI_MAX_HZ 10000000 -#define CONFIG_ENV_SPI_MODE 0 -#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ -#define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ -#define CONFIG_ENV_SECT_SIZE 0x10000 -#elif defined(CONFIG_SDCARD) -#define CONFIG_SYS_EXTRA_ENV_RELOC -#define CONFIG_ENV_IS_IN_MMC -#define CONFIG_SYS_MMC_ENV_DEV 0 -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_OFFSET (512 * 1097) -#elif defined(CONFIG_NAND) -#define CONFIG_SYS_EXTRA_ENV_RELOC -#define CONFIG_ENV_IS_IN_NAND -#define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE -#define CONFIG_ENV_OFFSET (5 * CONFIG_SYS_NAND_BLOCK_SIZE) -#else -#define CONFIG_ENV_IS_IN_FLASH -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ -#endif -#else /* CONFIG_SYS_NO_FLASH */ -#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ -#endif - - - -#define CONFIG_SYS_CLK_FREQ get_board_sys_clk() -#define CONFIG_DDR_CLK_FREQ get_board_ddr_clk() - -#ifndef __ASSEMBLY__ -unsigned long get_board_sys_clk(void); -unsigned long get_board_ddr_clk(void); -#endif
/* * These can be toggled for performance analysis, otherwise use default. */ #define CONFIG_SYS_CACHE_STASHING #define CONFIG_BTB /* toggle branch predition */ -#define CONFIG_DDR_ECC #ifdef CONFIG_DDR_ECC #define CONFIG_ECC_INIT_VIA_DDRCONTROLLER #define CONFIG_MEM_INIT_VALUE 0xdeadbeef @@ -149,13 +91,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_DCSRBAR 0xf0000000 #define CONFIG_SYS_DCSRBAR_PHYS 0xf00000000ull
-/* EEPROM */ -#define CONFIG_ID_EEPROM -#define CONFIG_SYS_I2C_EEPROM_NXID -#define CONFIG_SYS_EEPROM_BUS_NUM 0 -#define CONFIG_SYS_I2C_EEPROM_ADDR 0x57 -#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 - /* * DDR Setup */ @@ -171,15 +106,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_DDR_SPD #define CONFIG_FSL_DDR3
-#define CONFIG_SYS_SPD_BUS_NUM 0 -#define SPD_EEPROM_ADDRESS1 0x51 -#define SPD_EEPROM_ADDRESS2 0x52 -#define SPD_EEPROM_ADDRESS3 0x53 -#define SPD_EEPROM_ADDRESS4 0x54 -#define SPD_EEPROM_ADDRESS5 0x55 -#define SPD_EEPROM_ADDRESS6 0x56 -#define SPD_EEPROM_ADDRESS SPD_EEPROM_ADDRESS1 /* for p3041/p5010 */ -#define CONFIG_SYS_SDRAM_SIZE 4096 /* for fixed parameter use */
/* * IFC Definitions @@ -187,171 +113,9 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_FLASH_BASE 0xe0000000 #define CONFIG_SYS_FLASH_BASE_PHYS (0xf00000000ull | CONFIG_SYS_FLASH_BASE)
-#define CONFIG_SYS_NOR0_CSPR_EXT (0xf) -#define CONFIG_SYS_NOR0_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS \ - + 0x8000000) | \ - CSPR_PORT_SIZE_16 | \ - CSPR_MSEL_NOR | \ - CSPR_V) -#define CONFIG_SYS_NOR1_CSPR_EXT (0xf) -#define CONFIG_SYS_NOR1_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS) | \ - CSPR_PORT_SIZE_16 | \ - CSPR_MSEL_NOR | \ - CSPR_V) -#define CONFIG_SYS_NOR_AMASK IFC_AMASK(128*1024*1024) -/* NOR Flash Timing Params */ -#define CONFIG_SYS_NOR_CSOR CSOR_NAND_TRHZ_80 - -#define CONFIG_SYS_NOR_FTIM0 (FTIM0_NOR_TACSE(0x4) | \ - FTIM0_NOR_TEADC(0x5) | \ - FTIM0_NOR_TEAHC(0x5)) -#define CONFIG_SYS_NOR_FTIM1 (FTIM1_NOR_TACO(0x35) | \ - FTIM1_NOR_TRAD_NOR(0x1A) |\ - FTIM1_NOR_TSEQRAD_NOR(0x13)) -#define CONFIG_SYS_NOR_FTIM2 (FTIM2_NOR_TCS(0x4) | \ - FTIM2_NOR_TCH(0x4) | \ - FTIM2_NOR_TWPH(0x0E) | \ - FTIM2_NOR_TWP(0x1c)) -#define CONFIG_SYS_NOR_FTIM3 0x0 - -#define CONFIG_SYS_FLASH_QUIET_TEST -#define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */ - -#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* number of banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 1024 /* sectors per device */ -#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */ - -#define CONFIG_SYS_FLASH_EMPTY_INFO -#define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS \ - + 0x8000000, CONFIG_SYS_FLASH_BASE_PHYS} - -#define CONFIG_FSL_QIXIS /* use common QIXIS code */ -#define QIXIS_BASE 0xffdf0000 -#define QIXIS_LBMAP_SWITCH 6 -#define QIXIS_LBMAP_MASK 0x0f -#define QIXIS_LBMAP_SHIFT 0 -#define QIXIS_LBMAP_DFLTBANK 0x00 -#define QIXIS_LBMAP_ALTBANK 0x04 -#define QIXIS_RST_CTL_RESET 0x83 -#define QIXIS_RCFG_CTL_RECONFIG_IDLE 0x20 -#define QIXIS_RCFG_CTL_RECONFIG_START 0x21 -#define QIXIS_RCFG_CTL_WATCHDOG_ENBLE 0x08 -#define QIXIS_BASE_PHYS (0xf00000000ull | QIXIS_BASE) - -#define CONFIG_SYS_CSPR3_EXT (0xf) -#define CONFIG_SYS_CSPR3 (CSPR_PHYS_ADDR(QIXIS_BASE_PHYS) \ - | CSPR_PORT_SIZE_8 \ - | CSPR_MSEL_GPCM \ - | CSPR_V) -#define CONFIG_SYS_AMASK3 IFC_AMASK(4 * 1024) -#define CONFIG_SYS_CSOR3 0x0 -/* QIXIS Timing parameters for IFC CS3 */ -#define CONFIG_SYS_CS3_FTIM0 (FTIM0_GPCM_TACSE(0x0e) | \ - FTIM0_GPCM_TEADC(0x0e) | \ - FTIM0_GPCM_TEAHC(0x0e)) -#define CONFIG_SYS_CS3_FTIM1 (FTIM1_GPCM_TACO(0xff) | \ - FTIM1_GPCM_TRAD(0x3f)) -#define CONFIG_SYS_CS3_FTIM2 (FTIM2_GPCM_TCS(0x0e) | \ - FTIM2_GPCM_TCH(0x0) | \ - FTIM2_GPCM_TWP(0x1f)) -#define CONFIG_SYS_CS3_FTIM3 0x0 - -/* NAND Flash on IFC */ -#define CONFIG_NAND_FSL_IFC -#define CONFIG_SYS_NAND_BASE 0xff800000 -#define CONFIG_SYS_NAND_BASE_PHYS (0xf00000000ull | CONFIG_SYS_NAND_BASE) - -#define CONFIG_SYS_NAND_CSPR_EXT (0xf) -#define CONFIG_SYS_NAND_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_NAND_BASE_PHYS) \ - | CSPR_PORT_SIZE_8 /* Port Size = 8 bit */ \ - | CSPR_MSEL_NAND /* MSEL = NAND */ \ - | CSPR_V) -#define CONFIG_SYS_NAND_AMASK IFC_AMASK(64*1024) - -#define CONFIG_SYS_NAND_CSOR (CSOR_NAND_ECC_ENC_EN /* ECC on encode */ \ - | CSOR_NAND_ECC_DEC_EN /* ECC on decode */ \ - | CSOR_NAND_ECC_MODE_4 /* 4-bit ECC */ \ - | CSOR_NAND_RAL_3 /* RAL = 2Byes */ \ - | CSOR_NAND_PGS_2K /* Page Size = 2K */ \ - | CSOR_NAND_SPRZ_64/* Spare size = 64 */ \ - | CSOR_NAND_PB(64)) /*Pages Per Block = 64*/ - -#define CONFIG_SYS_NAND_ONFI_DETECTION - -/* ONFI NAND Flash mode0 Timing Params */ -#define CONFIG_SYS_NAND_FTIM0 (FTIM0_NAND_TCCST(0x07) | \ - FTIM0_NAND_TWP(0x18) | \ - FTIM0_NAND_TWCHT(0x07) | \ - FTIM0_NAND_TWH(0x0a)) -#define CONFIG_SYS_NAND_FTIM1 (FTIM1_NAND_TADLE(0x32) | \ - FTIM1_NAND_TWBE(0x39) | \ - FTIM1_NAND_TRR(0x0e) | \ - FTIM1_NAND_TRP(0x18)) -#define CONFIG_SYS_NAND_FTIM2 (FTIM2_NAND_TRAD(0x0f) | \ - FTIM2_NAND_TREH(0x0a) | \ - FTIM2_NAND_TWHRE(0x1e)) -#define CONFIG_SYS_NAND_FTIM3 0x0 - -#define CONFIG_SYS_NAND_DDR_LAW 11 - -#define CONFIG_SYS_NAND_BASE_LIST { CONFIG_SYS_NAND_BASE } -#define CONFIG_SYS_MAX_NAND_DEVICE 1 -#define CONFIG_MTD_NAND_VERIFY_WRITE -#define CONFIG_CMD_NAND - -#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) - -#if defined(CONFIG_NAND) -#define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NAND_CSPR_EXT -#define CONFIG_SYS_CSPR0 CONFIG_SYS_NAND_CSPR -#define CONFIG_SYS_AMASK0 CONFIG_SYS_NAND_AMASK -#define CONFIG_SYS_CSOR0 CONFIG_SYS_NAND_CSOR -#define CONFIG_SYS_CS0_FTIM0 CONFIG_SYS_NAND_FTIM0 -#define CONFIG_SYS_CS0_FTIM1 CONFIG_SYS_NAND_FTIM1 -#define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NAND_FTIM2 -#define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NAND_FTIM3 -#define CONFIG_SYS_CSPR2_EXT CONFIG_SYS_NOR0_CSPR_EXT -#define CONFIG_SYS_CSPR2 CONFIG_SYS_NOR0_CSPR -#define CONFIG_SYS_AMASK2 CONFIG_SYS_NOR_AMASK -#define CONFIG_SYS_CSOR2 CONFIG_SYS_NOR_CSOR -#define CONFIG_SYS_CS2_FTIM0 CONFIG_SYS_NOR_FTIM0 -#define CONFIG_SYS_CS2_FTIM1 CONFIG_SYS_NOR_FTIM1 -#define CONFIG_SYS_CS2_FTIM2 CONFIG_SYS_NOR_FTIM2 -#define CONFIG_SYS_CS2_FTIM3 CONFIG_SYS_NOR_FTIM3 -#else -#define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NOR0_CSPR_EXT -#define CONFIG_SYS_CSPR0 CONFIG_SYS_NOR0_CSPR -#define CONFIG_SYS_AMASK0 CONFIG_SYS_NOR_AMASK -#define CONFIG_SYS_CSOR0 CONFIG_SYS_NOR_CSOR -#define CONFIG_SYS_CS0_FTIM0 CONFIG_SYS_NOR_FTIM0 -#define CONFIG_SYS_CS0_FTIM1 CONFIG_SYS_NOR_FTIM1 -#define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NOR_FTIM2 -#define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NOR_FTIM3 -#define CONFIG_SYS_CSPR2_EXT CONFIG_SYS_NAND_CSPR_EXT -#define CONFIG_SYS_CSPR2 CONFIG_SYS_NAND_CSPR -#define CONFIG_SYS_AMASK2 CONFIG_SYS_NAND_AMASK -#define CONFIG_SYS_CSOR2 CONFIG_SYS_NAND_CSOR -#define CONFIG_SYS_CS2_FTIM0 CONFIG_SYS_NAND_FTIM0 -#define CONFIG_SYS_CS2_FTIM1 CONFIG_SYS_NAND_FTIM1 -#define CONFIG_SYS_CS2_FTIM2 CONFIG_SYS_NAND_FTIM2 -#define CONFIG_SYS_CS2_FTIM3 CONFIG_SYS_NAND_FTIM3 -#endif -#define CONFIG_SYS_CSPR1_EXT CONFIG_SYS_NOR1_CSPR_EXT -#define CONFIG_SYS_CSPR1 CONFIG_SYS_NOR1_CSPR -#define CONFIG_SYS_AMASK1 CONFIG_SYS_NOR_AMASK -#define CONFIG_SYS_CSOR1 CONFIG_SYS_NOR_CSOR -#define CONFIG_SYS_CS1_FTIM0 CONFIG_SYS_NOR_FTIM0 -#define CONFIG_SYS_CS1_FTIM1 CONFIG_SYS_NOR_FTIM1 -#define CONFIG_SYS_CS1_FTIM2 CONFIG_SYS_NOR_FTIM2 -#define CONFIG_SYS_CS1_FTIM3 CONFIG_SYS_NOR_FTIM3
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE
-#if defined(CONFIG_RAMBOOT_PBL) -#define CONFIG_SYS_RAMBOOT -#endif - #define CONFIG_BOARD_EARLY_INIT_R /* call board_early_init_r function */ #define CONFIG_MISC_INIT_R
@@ -412,28 +176,9 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_HARD_I2C /* I2C with hardware support */ #define CONFIG_I2C_MULTI_BUS #define CONFIG_I2C_CMD_TREE -#define CONFIG_SYS_I2C_SPEED 100000 /* I2C speed */ #define CONFIG_SYS_I2C_SLAVE 0x7F #define CONFIG_SYS_I2C_OFFSET 0x118000 #define CONFIG_SYS_I2C2_OFFSET 0x118100 -#define I2C_MUX_PCA_ADDR_PRI 0x77 /* I2C bus multiplexer,primary */ -#define I2C_MUX_PCA_ADDR_SEC 0x76 /* I2C bus multiplexer,secondary */ - -#define I2C_MUX_CH_DEFAULT 0x8 -#define I2C_MUX_CH_VOL_MONITOR 0xa -#define I2C_MUX_CH_VSC3316_FS 0xc -#define I2C_MUX_CH_VSC3316_BS 0xd - -/* Voltage monitor on channel 2*/ -#define I2C_VOL_MONITOR_ADDR 0x40 -#define I2C_VOL_MONITOR_BUS_V_OFFSET 0x2 -#define I2C_VOL_MONITOR_BUS_V_OVF 0x1 -#define I2C_VOL_MONITOR_BUS_V_SHIFT 3 - -/* VSC Crossbar switches */ -#define CONFIG_VSC_CROSSBAR -#define VSC3316_FSM_TX_ADDR 0x70 -#define VSC3316_FSM_RX_ADDR 0x71
/* * RapidIO @@ -447,44 +192,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_SRIO2_MEM_SIZE 0x10000000 /* 256M */
/* - * for slave u-boot IMAGE instored in master memory space, - * PHYS must be aligned based on the SIZE - */ -#define CONFIG_SRIO_PCIE_BOOT_IMAGE_MEM_PHYS 0xfef080000ull -#define CONFIG_SRIO_PCIE_BOOT_IMAGE_MEM_BUS1 0xfff80000ull -#define CONFIG_SRIO_PCIE_BOOT_IMAGE_SIZE 0x80000 /* 512K */ -#define CONFIG_SRIO_PCIE_BOOT_IMAGE_MEM_BUS2 0x3fff80000ull -/* - * for slave UCODE and ENV instored in master memory space, - * PHYS must be aligned based on the SIZE - */ -#define CONFIG_SRIO_PCIE_BOOT_UCODE_ENV_MEM_PHYS 0xfef040000ull -#define CONFIG_SRIO_PCIE_BOOT_UCODE_ENV_MEM_BUS 0x3ffe00000ull -#define CONFIG_SRIO_PCIE_BOOT_UCODE_ENV_SIZE 0x40000 /* 256K */ - -/* slave core release by master*/ -#define CONFIG_SRIO_PCIE_BOOT_BRR_OFFSET 0xe00e4 -#define CONFIG_SRIO_PCIE_BOOT_RELEASE_MASK 0x00000001 /* release core 0 */ - -/* - * SRIO_PCIE_BOOT - SLAVE - */ -#ifdef CONFIG_SRIO_PCIE_BOOT_SLAVE -#define CONFIG_SYS_SRIO_PCIE_BOOT_UCODE_ENV_ADDR 0xFFE00000 -#define CONFIG_SYS_SRIO_PCIE_BOOT_UCODE_ENV_ADDR_PHYS \ - (0x300000000ull | CONFIG_SYS_SRIO_PCIE_BOOT_UCODE_ENV_ADDR) -#endif -/* - * eSPI - Enhanced SPI - */ -#define CONFIG_FSL_ESPI -#define CONFIG_SPI_FLASH -#define CONFIG_SPI_FLASH_SST -#define CONFIG_CMD_SF -#define CONFIG_SF_DEFAULT_SPEED 10000000 -#define CONFIG_SF_DEFAULT_MODE 0 - -/* * General PCI * Memory space is mapped 1-1, but I/O space must start from 0. */ @@ -527,66 +234,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_PCIE4_IO_PHYS 0xff8030000ull #define CONFIG_SYS_PCIE4_IO_SIZE 0x00010000 /* 64k */
-/* Qman/Bman */ -#ifndef CONFIG_NOBQFMAN -#define CONFIG_SYS_DPAA_QBMAN /* Support Q/Bman */ -#define CONFIG_SYS_BMAN_NUM_PORTALS 50 -#define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 -#define CONFIG_SYS_BMAN_MEM_PHYS 0xff4000000ull -#define CONFIG_SYS_BMAN_MEM_SIZE 0x02000000 -#define CONFIG_SYS_QMAN_NUM_PORTALS 50 -#define CONFIG_SYS_QMAN_MEM_BASE 0xf6000000 -#define CONFIG_SYS_QMAN_MEM_PHYS 0xff6000000ull -#define CONFIG_SYS_QMAN_MEM_SIZE 0x02000000 - -#define CONFIG_SYS_DPAA_FMAN -#define CONFIG_SYS_DPAA_PME -#define CONFIG_SYS_PMAN -#define CONFIG_SYS_DPAA_DCE -#define CONFIG_SYS_INTERLAKEN - -/* Default address of microcode for the Linux Fman driver */ -#if defined(CONFIG_SPIFLASH) -/* - * env is stored at 0x100000, sector size is 0x10000, ucode is stored after - * env, so we got 0x110000. - */ -#define CONFIG_SYS_QE_FW_IN_SPIFLASH -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0x110000 -#elif defined(CONFIG_SDCARD) -/* - * PBL SD boot image should stored at 0x1000(8 blocks), the size of the image is - * about 545KB (1089 blocks), Env is stored after the image, and the env size is - * 0x2000 (16 blocks), 8 + 1089 + 16 = 1113, enlarge it to 1130. - */ -#define CONFIG_SYS_QE_FMAN_FW_IN_MMC -#define CONFIG_SYS_QE_FMAN_FW_ADDR (512 * 1130) -#elif defined(CONFIG_NAND) -#define CONFIG_SYS_QE_FMAN_FW_IN_NAND -#define CONFIG_SYS_QE_FMAN_FW_ADDR (6 * CONFIG_SYS_NAND_BLOCK_SIZE) -#else -#define CONFIG_SYS_QE_FMAN_FW_IN_NOR -#define CONFIG_SYS_QE_FMAN_FW_ADDR 0xEFF40000 -#endif -#define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 -#define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH) -#endif /* CONFIG_NOBQFMAN */ - -#ifdef CONFIG_SYS_DPAA_FMAN -#define CONFIG_FMAN_ENET -#define CONFIG_PHYLIB_10G -#define CONFIG_PHY_VITESSE -#define CONFIG_PHY_TERANETICS -#define SGMII_CARD_PORT1_PHY_ADDR 0x1C -#define SGMII_CARD_PORT2_PHY_ADDR 0x1D -#define SGMII_CARD_PORT3_PHY_ADDR 0x1E -#define SGMII_CARD_PORT4_PHY_ADDR 0x1F -#define FM1_10GEC1_PHY_ADDR 0x0 -#define FM1_10GEC2_PHY_ADDR 0x1 -#define FM2_10GEC1_PHY_ADDR 0x2 -#define FM2_10GEC2_PHY_ADDR 0x3 -#endif - #ifdef CONFIG_PCI #define CONFIG_PCI_INDIRECT_BRIDGE #define CONFIG_NET_MULTI @@ -649,30 +296,6 @@ unsigned long get_board_ddr_clk(void); #endif
/* -* USB -*/ -#define CONFIG_CMD_USB -#define CONFIG_USB_STORAGE -#define CONFIG_USB_EHCI -#define CONFIG_USB_EHCI_FSL -#define CONFIG_EHCI_HCD_INIT_AFTER_RESET -#define CONFIG_CMD_EXT2 -#define CONFIG_HAS_FSL_DR_USB - -#define CONFIG_MMC - -#ifdef CONFIG_MMC -#define CONFIG_FSL_ESDHC -#define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR -#define CONFIG_SYS_FSL_ESDHC_BROKEN_TIMEOUT -#define CONFIG_CMD_MMC -#define CONFIG_GENERIC_MMC -#define CONFIG_CMD_EXT2 -#define CONFIG_CMD_FAT -#define CONFIG_DOS_PARTITION -#endif - -/* * Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ @@ -713,112 +336,11 @@ unsigned long get_board_ddr_clk(void); /* default location for tftp and bootm */ #define CONFIG_LOADADDR 1000000
-#define CONFIG_BOOTDELAY 10 /* -1 disables auto-boot */
#define CONFIG_BAUDRATE 115200
-#define __USB_PHY_TYPE utmi - -/* - * T4240 has 3 DDR controllers. Default to 3way_4KB interleaving. It can be - * 3way_1KB, 3way_4KB, 3way_8KB. T4160 has 2 DDR controllers. Default to - * cacheline interleaving. It can be cacheline, page, bank, superbank. - * See doc/README.fsl-ddr for details. - */ -#ifdef CONFIG_PPC_T4240 -#define CTRL_INTLV_PREFERED 3way_4KB -#else -#define CTRL_INTLV_PREFERED cacheline -#endif - -#define CONFIG_EXTRA_ENV_SETTINGS \ - "hwconfig=fsl_ddr:" \ - "ctlr_intlv=" __stringify(CTRL_INTLV_PREFERED) "," \ - "bank_intlv=auto;" \ - "usb1:dr_mode=host,phy_type=" __stringify(__USB_PHY_TYPE) "\0"\ - "netdev=eth0\0" \ - "uboot=" __stringify(CONFIG_UBOOTPATH) "\0" \ - "ubootaddr=" __stringify(CONFIG_SYS_TEXT_BASE) "\0" \ - "tftpflash=tftpboot $loadaddr $uboot && " \ - "protect off $ubootaddr +$filesize && " \ - "erase $ubootaddr +$filesize && " \ - "cp.b $loadaddr $ubootaddr $filesize && " \ - "protect on $ubootaddr +$filesize && " \ - "cmp.b $loadaddr $ubootaddr $filesize\0" \ - "consoledev=ttyS0\0" \ - "ramdiskaddr=2000000\0" \ - "ramdiskfile=t4240qds/ramdisk.uboot\0" \ - "fdtaddr=c00000\0" \ - "fdtfile=t4240qds/t4240qds.dtb\0" \ - "bdev=sda3\0" \ - "c=ffe\0" - -/* For emulation this causes u-boot to jump to the start of the proof point - app code automatically */ -#define CONFIG_PROOF_POINTS \ - "setenv bootargs root=/dev/$bdev rw " \ - "console=$consoledev,$baudrate $othbootargs;" \ - "cpu 1 release 0x29000000 - - -;" \ - "cpu 2 release 0x29000000 - - -;" \ - "cpu 3 release 0x29000000 - - -;" \ - "cpu 4 release 0x29000000 - - -;" \ - "cpu 5 release 0x29000000 - - -;" \ - "cpu 6 release 0x29000000 - - -;" \ - "cpu 7 release 0x29000000 - - -;" \ - "go 0x29000000" - #define CONFIG_HVBOOT \ "setenv bootargs config-addr=0x60000000; " \ "bootm 0x01000000 - 0x00f00000"
-#define CONFIG_ALU \ - "setenv bootargs root=/dev/$bdev rw " \ - "console=$consoledev,$baudrate $othbootargs;" \ - "cpu 1 release 0x01000000 - - -;" \ - "cpu 2 release 0x01000000 - - -;" \ - "cpu 3 release 0x01000000 - - -;" \ - "cpu 4 release 0x01000000 - - -;" \ - "cpu 5 release 0x01000000 - - -;" \ - "cpu 6 release 0x01000000 - - -;" \ - "cpu 7 release 0x01000000 - - -;" \ - "go 0x01000000" - -#define CONFIG_LINUX \ - "setenv bootargs root=/dev/ram rw " \ - "console=$consoledev,$baudrate $othbootargs;" \ - "setenv ramdiskaddr 0x02000000;" \ - "setenv fdtaddr 0x00c00000;" \ - "setenv loadaddr 0x1000000;" \ - "bootm $loadaddr $ramdiskaddr $fdtaddr" - -#define CONFIG_HDBOOT \ - "setenv bootargs root=/dev/$bdev rw " \ - "console=$consoledev,$baudrate $othbootargs;" \ - "tftp $loadaddr $bootfile;" \ - "tftp $fdtaddr $fdtfile;" \ - "bootm $loadaddr - $fdtaddr" - -#define CONFIG_NFSBOOTCOMMAND \ - "setenv bootargs root=/dev/nfs rw " \ - "nfsroot=$serverip:$rootpath " \ - "ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off " \ - "console=$consoledev,$baudrate $othbootargs;" \ - "tftp $loadaddr $bootfile;" \ - "tftp $fdtaddr $fdtfile;" \ - "bootm $loadaddr - $fdtaddr" - -#define CONFIG_RAMBOOTCOMMAND \ - "setenv bootargs root=/dev/ram rw " \ - "console=$consoledev,$baudrate $othbootargs;" \ - "tftp $ramdiskaddr $ramdiskfile;" \ - "tftp $loadaddr $bootfile;" \ - "tftp $fdtaddr $fdtfile;" \ - "bootm $loadaddr $ramdiskaddr $fdtaddr" - -#define CONFIG_BOOTCOMMAND CONFIG_LINUX - -#ifdef CONFIG_SECURE_BOOT -#include <asm/fsl_secure_boot.h> -#endif - #endif /* __CONFIG_H */
Dear York Sun,
In message 1372185469-14161-6-git-send-email-yorksun@freescale.com you wrote:
Add emulator support for T4240. Emulator has limited peripherals and interfaces. Difference between emulator and T4240QDS includes: ECC for DDR is disabled due the procedure to load images No board FPGA (QIXIS) NOR flash has 32-bit port for higher loading speed IFC and I2C timing don't really matter, so set them fast No ethernet
Signed-off-by: York Sun yorksun@freescale.com
board/freescale/t4qds/Makefile | 3 +- board/freescale/t4qds/ddr.c | 73 +--- board/freescale/t4qds/ddr.h | 122 ++++++ board/freescale/t4qds/law.c | 2 + board/freescale/t4qds/t4240emu.c | 96 +++++ board/freescale/t4qds/t4240qds.c | 855 ++++++++++++++++++++++++++++++++++++++ board/freescale/t4qds/t4qds.c | 853 ------------------------------------- board/freescale/t4qds/tlb.c | 3 +- boards.cfg | 1 + include/configs/T4240EMU.h | 185 +++++++++ include/configs/T4240QDS.h | 539 ++++++++++++++++++++++++ include/configs/t4qds.h | 482 +-------------------- 12 files changed, 1807 insertions(+), 1407 deletions(-) create mode 100644 board/freescale/t4qds/ddr.h create mode 100644 board/freescale/t4qds/t4240emu.c create mode 100644 board/freescale/t4qds/t4240qds.c delete mode 100644 board/freescale/t4qds/t4qds.c create mode 100644 include/configs/T4240EMU.h
Entry to MAINTAINERS missing. And checkpatch reports a number of warnings that need to be fixed:
- WARNING: quoted string split across lines - WARNING: Avoid unnecessary line continuations
Thanks.
Didn't know we are enforcing this. Will add.
Noticed. How are we going to balance the long lines vs split across lines?
York
String literals are an exception to the 80-column rule, to aid greppability.
-Scott
When chip select interleaving is enabled, cs0_bnds is used for address binding. Other csn_bnds are not used. When two controllers interleaving is enabled, cs0_bnds of both controllers are used, other csn_bnds are not. However, the unused csn_bnds may be used internally for calculating addresses for calibration. Setting those registers to 0 may confuse controllers in some cases. Instead, setting them to 0xffffffff together with normal LAWs will guarantee the address is not mapped to DDR.
Signed-off-by: York Sun yorksun@freescale.com --- arch/powerpc/cpu/mpc8xxx/ddr/ctrl_regs.c | 4 ++-- arch/powerpc/cpu/mpc8xxx/ddr/main.c | 8 +++++++- 2 files changed, 9 insertions(+), 3 deletions(-)
diff --git a/arch/powerpc/cpu/mpc8xxx/ddr/ctrl_regs.c b/arch/powerpc/cpu/mpc8xxx/ddr/ctrl_regs.c index 8c95cad..a6f8d95 100644 --- a/arch/powerpc/cpu/mpc8xxx/ddr/ctrl_regs.c +++ b/arch/powerpc/cpu/mpc8xxx/ddr/ctrl_regs.c @@ -1588,8 +1588,8 @@ compute_fsl_memctl_config_regs(const memctl_options_t *popts, | ((ea & 0xFFF) << 0) /* ending address MSB */ ); } else { - debug("FSLDDR: setting bnds to 0 for inactive CS\n"); - ddr->cs[i].bnds = 0; + /* setting bnds to 0xffffffff for inactive CS */ + ddr->cs[i].bnds = 0xffffffff; }
debug("FSLDDR: cs[%d]_bnds = 0x%08x\n", i, ddr->cs[i].bnds); diff --git a/arch/powerpc/cpu/mpc8xxx/ddr/main.c b/arch/powerpc/cpu/mpc8xxx/ddr/main.c index 7a8636d..c35405d 100644 --- a/arch/powerpc/cpu/mpc8xxx/ddr/main.c +++ b/arch/powerpc/cpu/mpc8xxx/ddr/main.c @@ -504,7 +504,13 @@ fsl_ddr_compute(fsl_ddr_info_t *pinfo, unsigned int start_step, fsl_ddr_cfg_regs_t *reg = &ddr_reg[i]; if (reg->cs[j].config & 0x80000000) { unsigned int end; - end = reg->cs[j].bnds & 0xFFF; + /* + * 0xfffffff is a special value we put + * for unused bnds + */ + if (reg->cs[j].bnds == 0xffffffff) + continue; + end = reg->cs[j].bnds & 0xffff; if (end > max_end) { max_end = end; }
RDIMM has different timing. Tested RDIMM is MT18JSF1G72PDZ-1G9E1 for dual rank. Single- and quad-rank are not tested due to availability.
Signed-off-by: York Sun yorksun@freescale.com --- board/freescale/t4qds/ddr.h | 19 +++++++++---------- 1 file changed, 9 insertions(+), 10 deletions(-)
diff --git a/board/freescale/t4qds/ddr.h b/board/freescale/t4qds/ddr.h index cde0785..4f73285 100644 --- a/board/freescale/t4qds/ddr.h +++ b/board/freescale/t4qds/ddr.h @@ -64,16 +64,15 @@ static const struct board_specific_parameters rdimm0[] = { * num| hi| rank| clk| wrlvl | wrlvl | wrlvl | cpo |wrdata|2T * ranks| mhz| GB |adjst| start | ctl2 | ctl3 | |delay | */ - {4, 1350, 0, 5, 9, 0x08070605, 0x07080805, 0xff, 2, 0}, - {4, 1666, 0, 5, 8, 0x08070605, 0x07080805, 0xff, 2, 0}, - {4, 2140, 0, 5, 8, 0x08070605, 0x07081805, 0xff, 2, 0}, - {2, 1350, 0, 5, 7, 0x0809090b, 0x0c0c0d09, 0xff, 2, 0}, - {2, 1666, 0, 5, 8, 0x080a0a0c, 0x0c0d0e0a, 0xff, 2, 0}, - {2, 2140, 0, 5, 8, 0x090a0b0c, 0x0e0f100b, 0xff, 2, 0}, - {1, 1350, 0, 5, 8, 0x0809090b, 0x0c0c0d0a, 0xff, 2, 0}, - {1, 1700, 0, 5, 8, 0x080a0a0c, 0x0c0d0e0a, 0xff, 2, 0}, - {1, 1900, 0, 4, 8, 0x080a0a0c, 0x0e0e0f0a, 0xff, 2, 0}, - {1, 2140, 0, 4, 8, 0x090a0b0c, 0x0e0f100b, 0xff, 2, 0}, + {4, 1350, 0, 5, 9, 0x08070605, 0x06070806, 0xff, 2, 0}, + {4, 1666, 0, 5, 11, 0x0a080706, 0x07090906, 0xff, 2, 0}, + {4, 2140, 0, 5, 12, 0x0b090807, 0x080a0b07, 0xff, 2, 0}, + {2, 1350, 0, 5, 9, 0x08070605, 0x06070806, 0xff, 2, 0}, + {2, 1666, 0, 5, 11, 0x0a090806, 0x08090a06, 0xff, 2, 0}, + {2, 2140, 0, 5, 12, 0x0b090807, 0x080a0b07, 0xff, 2, 0}, + {1, 1350, 0, 5, 9, 0x08070605, 0x06070806, 0xff, 2, 0}, + {1, 1666, 0, 5, 11, 0x0a090806, 0x08090a06, 0xff, 2, 0}, + {1, 2140, 0, 4, 12, 0x0b090807, 0x080a0b07, 0xff, 2, 0}, {} };
On selected platforms, x4 DDR devices can be supported. Using x4 devices may lower the performance, but generally they are available for higher density.
Tested on MT36JSF2G72PZ-1G9E1 RDIMM.
Signed-off-by: York Sun yorksun@freescale.com --- arch/powerpc/cpu/mpc8xxx/ddr/ctrl_regs.c | 4 ++++ arch/powerpc/cpu/mpc8xxx/ddr/ddr3_dimm_params.c | 1 + arch/powerpc/cpu/mpc8xxx/ddr/interactive.c | 4 ++++ arch/powerpc/cpu/mpc8xxx/ddr/options.c | 2 ++ arch/powerpc/include/asm/fsl_ddr_dimm_params.h | 1 + arch/powerpc/include/asm/fsl_ddr_sdram.h | 1 + 6 files changed, 13 insertions(+)
diff --git a/arch/powerpc/cpu/mpc8xxx/ddr/ctrl_regs.c b/arch/powerpc/cpu/mpc8xxx/ddr/ctrl_regs.c index a6f8d95..3a63a04 100644 --- a/arch/powerpc/cpu/mpc8xxx/ddr/ctrl_regs.c +++ b/arch/powerpc/cpu/mpc8xxx/ddr/ctrl_regs.c @@ -684,6 +684,7 @@ static void set_ddr_sdram_cfg_2(fsl_ddr_cfg_regs_t *ddr, unsigned int odt_cfg = 0; /* ODT configuration */ unsigned int num_pr; /* Number of posted refreshes */ unsigned int slow = 0; /* DDR will be run less than 1250 */ + unsigned int x4_en = 0; /* x4 DRAM enable */ unsigned int obc_cfg; /* On-The-Fly Burst Chop Cfg */ unsigned int ap_en; /* Address Parity Enable */ unsigned int d_init; /* DRAM data initialization */ @@ -728,6 +729,8 @@ static void set_ddr_sdram_cfg_2(fsl_ddr_cfg_regs_t *ddr, ap_en = 0; }
+ x4_en = popts->x4_en ? 1 : 0; + #if defined(CONFIG_ECC_INIT_VIA_DDRCONTROLLER) /* Use the DDR controller to auto initialize memory. */ d_init = popts->ECC_init_using_memctl; @@ -750,6 +753,7 @@ static void set_ddr_sdram_cfg_2(fsl_ddr_cfg_regs_t *ddr, | ((odt_cfg & 0x3) << 21) | ((num_pr & 0xf) << 12) | ((slow & 1) << 11) + | (x4_en << 10) | (qd_en << 9) | (unq_mrs_en << 8) | ((obc_cfg & 0x1) << 6) diff --git a/arch/powerpc/cpu/mpc8xxx/ddr/ddr3_dimm_params.c b/arch/powerpc/cpu/mpc8xxx/ddr/ddr3_dimm_params.c index 3e7c269..b67158c 100644 --- a/arch/powerpc/cpu/mpc8xxx/ddr/ddr3_dimm_params.c +++ b/arch/powerpc/cpu/mpc8xxx/ddr/ddr3_dimm_params.c @@ -129,6 +129,7 @@ ddr_compute_dimm_parameters(const ddr3_spd_eeprom_t *spd, pdimm->ec_sdram_width = 0; pdimm->data_width = pdimm->primary_sdram_width + pdimm->ec_sdram_width; + pdimm->device_width = 1 << ((spd->organization & 0x7) + 2);
/* These are the types defined by the JEDEC DDR3 SPD spec */ pdimm->mirrored_dimm = 0; diff --git a/arch/powerpc/cpu/mpc8xxx/ddr/interactive.c b/arch/powerpc/cpu/mpc8xxx/ddr/interactive.c index 46257c9..2bc3516 100644 --- a/arch/powerpc/cpu/mpc8xxx/ddr/interactive.c +++ b/arch/powerpc/cpu/mpc8xxx/ddr/interactive.c @@ -207,6 +207,7 @@ static void fsl_ddr_dimm_parameters_edit(fsl_ddr_info_t *pinfo, DIMM_PARM(primary_sdram_width), DIMM_PARM(ec_sdram_width), DIMM_PARM(registered_dimm), + DIMM_PARM(device_width),
DIMM_PARM(n_row_addr), DIMM_PARM(n_col_addr), @@ -265,6 +266,7 @@ static void print_dimm_parameters(const dimm_params_t *pdimm) DIMM_PARM(primary_sdram_width), DIMM_PARM(ec_sdram_width), DIMM_PARM(registered_dimm), + DIMM_PARM(device_width),
DIMM_PARM(n_row_addr), DIMM_PARM(n_col_addr), @@ -445,6 +447,7 @@ static void fsl_ddr_options_edit(fsl_ddr_info_t *pinfo, CTRL_OPTIONS(twoT_en), CTRL_OPTIONS(threeT_en), CTRL_OPTIONS(ap_en), + CTRL_OPTIONS(x4_en), CTRL_OPTIONS(bstopre), CTRL_OPTIONS(wrlvl_override), CTRL_OPTIONS(wrlvl_sample), @@ -689,6 +692,7 @@ static void print_memctl_options(const memctl_options_t *popts) CTRL_OPTIONS(threeT_en), CTRL_OPTIONS(registered_dimm_en), CTRL_OPTIONS(ap_en), + CTRL_OPTIONS(x4_en), CTRL_OPTIONS(bstopre), CTRL_OPTIONS(wrlvl_override), CTRL_OPTIONS(wrlvl_sample), diff --git a/arch/powerpc/cpu/mpc8xxx/ddr/options.c b/arch/powerpc/cpu/mpc8xxx/ddr/options.c index 2f13b8f..e02d76d 100644 --- a/arch/powerpc/cpu/mpc8xxx/ddr/options.c +++ b/arch/powerpc/cpu/mpc8xxx/ddr/options.c @@ -703,6 +703,8 @@ unsigned int populate_memctl_options(int all_DIMMs_registered, } #endif
+ popts->x4_en = (pdimm[0].device_width == 4) ? 1 : 0; + /* Choose burst length. */ #if defined(CONFIG_FSL_DDR3) #if defined(CONFIG_E500MC) diff --git a/arch/powerpc/include/asm/fsl_ddr_dimm_params.h b/arch/powerpc/include/asm/fsl_ddr_dimm_params.h index ffe4db8..bd312ad 100644 --- a/arch/powerpc/include/asm/fsl_ddr_dimm_params.h +++ b/arch/powerpc/include/asm/fsl_ddr_dimm_params.h @@ -26,6 +26,7 @@ typedef struct dimm_params_s { unsigned int primary_sdram_width; unsigned int ec_sdram_width; unsigned int registered_dimm; + unsigned int device_width; /* x4, x8, x16 components */
/* SDRAM device parameters */ unsigned int n_row_addr; diff --git a/arch/powerpc/include/asm/fsl_ddr_sdram.h b/arch/powerpc/include/asm/fsl_ddr_sdram.h index 640d329..bac22fc 100644 --- a/arch/powerpc/include/asm/fsl_ddr_sdram.h +++ b/arch/powerpc/include/asm/fsl_ddr_sdram.h @@ -277,6 +277,7 @@ typedef struct memctl_options_s { unsigned int mirrored_dimm; unsigned int quad_rank_present; unsigned int ap_en; /* address parity enable for RDIMM */ + unsigned int x4_en; /* enable x4 devices */
/* Global Timing Parameters */ unsigned int cas_latency_override;
JEDEC spec requires the clocks to be stable before deasserting reset signal for RDIMMs. Clocks start when any chip select is enabled and clock control register is set. This patch also adds the interface to toggle memory reset signal if needed by the boards.
Signed-off-by: York Sun yorksun@freescale.com --- arch/powerpc/cpu/mpc85xx/ddr-gen1.c | 2 +- arch/powerpc/cpu/mpc85xx/ddr-gen2.c | 2 +- arch/powerpc/cpu/mpc85xx/ddr-gen3.c | 29 +++++++++++++++- arch/powerpc/cpu/mpc86xx/ddr-8641.c | 2 +- arch/powerpc/cpu/mpc8xxx/ddr/ddr.h | 2 +- arch/powerpc/cpu/mpc8xxx/ddr/main.c | 54 ++++++++++++++++++++++++++---- arch/powerpc/include/asm/fsl_ddr_sdram.h | 24 ++++++++++++- board/freescale/bsc9131rdb/ddr.c | 2 +- board/freescale/bsc9132qds/ddr.c | 2 +- board/freescale/common/qixis.c | 20 +++++++++++ board/freescale/corenet_ds/ddr.c | 4 +-- board/freescale/p1010rdb/ddr.c | 2 +- board/freescale/p1_p2_rdb/ddr.c | 2 +- board/freescale/p1_p2_rdb_pc/ddr.c | 2 +- include/configs/T4240QDS.h | 1 + 15 files changed, 130 insertions(+), 20 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/ddr-gen1.c b/arch/powerpc/cpu/mpc85xx/ddr-gen1.c index 8a86819..4dd8c0b 100644 --- a/arch/powerpc/cpu/mpc85xx/ddr-gen1.c +++ b/arch/powerpc/cpu/mpc85xx/ddr-gen1.c @@ -15,7 +15,7 @@ #endif
void fsl_ddr_set_memctl_regs(const fsl_ddr_cfg_regs_t *regs, - unsigned int ctrl_num) + unsigned int ctrl_num, int step) { unsigned int i; volatile ccsr_ddr_t *ddr = (void *)CONFIG_SYS_MPC8xxx_DDR_ADDR; diff --git a/arch/powerpc/cpu/mpc85xx/ddr-gen2.c b/arch/powerpc/cpu/mpc85xx/ddr-gen2.c index a705862..542bc84 100644 --- a/arch/powerpc/cpu/mpc85xx/ddr-gen2.c +++ b/arch/powerpc/cpu/mpc85xx/ddr-gen2.c @@ -16,7 +16,7 @@ #endif
void fsl_ddr_set_memctl_regs(const fsl_ddr_cfg_regs_t *regs, - unsigned int ctrl_num) + unsigned int ctrl_num, int step) { unsigned int i; ccsr_ddr_t *ddr = (void *)CONFIG_SYS_MPC8xxx_DDR_ADDR; diff --git a/arch/powerpc/cpu/mpc85xx/ddr-gen3.c b/arch/powerpc/cpu/mpc85xx/ddr-gen3.c index 3e7a564..1be51d3 100644 --- a/arch/powerpc/cpu/mpc85xx/ddr-gen3.c +++ b/arch/powerpc/cpu/mpc85xx/ddr-gen3.c @@ -15,8 +15,18 @@ #error Invalid setting for CONFIG_CHIP_SELECTS_PER_CTRL #endif
+ +/* + * regs has the to-be-set values for DDR controller registers + * ctrl_num is the DDR controller number + * step: 0 goes through the initialization in one pass + * 1 sets registers and returns before enabling controller + * 2 resumes from step 1 and continues to initialize + * Dividing the initialization to two steps to deassert DDR reset signal + * to comply with JEDEC specs for RDIMMs. + */ void fsl_ddr_set_memctl_regs(const fsl_ddr_cfg_regs_t *regs, - unsigned int ctrl_num) + unsigned int ctrl_num, int step) { unsigned int i, bus_width; volatile ccsr_ddr_t *ddr; @@ -54,6 +64,9 @@ void fsl_ddr_set_memctl_regs(const fsl_ddr_cfg_regs_t *regs, return; }
+ if (step == 2) + goto step2; + if (regs->ddr_eor) out_be32(&ddr->eor, regs->ddr_eor); #ifdef CONFIG_SYS_FSL_ERRATUM_DDR111_DDR134 @@ -157,6 +170,20 @@ void fsl_ddr_set_memctl_regs(const fsl_ddr_cfg_regs_t *regs, out_be32(&ddr->debug[21], 0x24000000); #endif /* CONFIG_SYS_FSL_ERRATUM_DDR_A003474 */
+ /* + * For RDIMMs, JEDEC spec requires clocks to be stable before reset is + * deasserted. Clocks start when any chip select is enabled and clock + * control register is set. Because all DDR components are connected to + * one reset signal, this needs to be done in two steps. Step 1 is to + * get the clocks started. Step 2 resumes after reset signal is + * deasserted. + */ + if (step == 1) { + udelay(200); + return; + } + +step2: /* Set, but do not enable the memory */ temp_sdram_cfg = regs->ddr_sdram_cfg; temp_sdram_cfg &= ~(SDRAM_CFG_MEM_EN); diff --git a/arch/powerpc/cpu/mpc86xx/ddr-8641.c b/arch/powerpc/cpu/mpc86xx/ddr-8641.c index 92ba26d..33a91f9 100644 --- a/arch/powerpc/cpu/mpc86xx/ddr-8641.c +++ b/arch/powerpc/cpu/mpc86xx/ddr-8641.c @@ -15,7 +15,7 @@ #endif
void fsl_ddr_set_memctl_regs(const fsl_ddr_cfg_regs_t *regs, - unsigned int ctrl_num) + unsigned int ctrl_num, int step) { unsigned int i; volatile ccsr_ddr_t *ddr; diff --git a/arch/powerpc/cpu/mpc8xxx/ddr/ddr.h b/arch/powerpc/cpu/mpc8xxx/ddr/ddr.h index 4dd55fc..c173a5a 100644 --- a/arch/powerpc/cpu/mpc8xxx/ddr/ddr.h +++ b/arch/powerpc/cpu/mpc8xxx/ddr/ddr.h @@ -96,7 +96,7 @@ unsigned int check_fsl_memctl_config_regs(const fsl_ddr_cfg_regs_t *ddr);
/* processor specific function */ void fsl_ddr_set_memctl_regs(const fsl_ddr_cfg_regs_t *regs, - unsigned int ctrl_num); + unsigned int ctrl_num, int step);
/* board specific function */ int fsl_ddr_get_dimm_params(dimm_params_t *pdimm, diff --git a/arch/powerpc/cpu/mpc8xxx/ddr/main.c b/arch/powerpc/cpu/mpc8xxx/ddr/main.c index c35405d..9f4f253 100644 --- a/arch/powerpc/cpu/mpc8xxx/ddr/main.c +++ b/arch/powerpc/cpu/mpc8xxx/ddr/main.c @@ -25,10 +25,6 @@ void fsl_ddr_set_lawbar( unsigned int ctrl_num); void fsl_ddr_set_intl3r(const unsigned int granule_size);
-/* processor specific function */ -extern void fsl_ddr_set_memctl_regs(const fsl_ddr_cfg_regs_t *regs, - unsigned int ctrl_num); - #if defined(SPD_EEPROM_ADDRESS) || \ defined(SPD_EEPROM_ADDRESS1) || defined(SPD_EEPROM_ADDRESS2) || \ defined(SPD_EEPROM_ADDRESS3) || defined(SPD_EEPROM_ADDRESS4) @@ -365,9 +361,11 @@ fsl_ddr_compute(fsl_ddr_info_t *pinfo, unsigned int start_step, { unsigned int i, j; unsigned long long total_mem = 0; + int assert_reset;
fsl_ddr_cfg_regs_t *ddr_reg = pinfo->fsl_ddr_config_reg; common_timing_params_t *timing_params = pinfo->common_timing_params; + assert_reset = board_need_mem_reset();
/* data bus width capacity adjust shift amount */ unsigned int dbw_capacity_adjust[CONFIG_NUM_DDR_CONTROLLERS]; @@ -462,7 +460,20 @@ fsl_ddr_compute(fsl_ddr_info_t *pinfo, unsigned int start_step, timing_params[i].all_DIMMs_registered, &pinfo->memctl_opts[i], pinfo->dimm_params[i], i); + /* + * For RDIMMs, JEDEC spec requires clocks to be stable + * before reset signal is deasserted. For the boards + * using fixed parameters, this function should be + * be called from board init file. + */ + if (timing_params[i].all_DIMMs_registered) + assert_reset = 1; + } + if (assert_reset) { + debug("Asserting mem reset\n"); + board_assert_mem_reset(); } + case STEP_ASSIGN_ADDRESSES: /* STEP 5: Assign addresses to chip selects */ check_interleaving_options(pinfo); @@ -537,6 +548,7 @@ phys_size_t fsl_ddr_sdram(void) unsigned int law_memctl = LAW_TRGT_IF_DDR_1; unsigned long long total_memory; fsl_ddr_info_t info; + int deassert_reset;
/* Reset info structure. */ memset(&info, 0, sizeof(fsl_ddr_info_t)); @@ -565,7 +577,21 @@ phys_size_t fsl_ddr_sdram(void) } }
- /* Program configuration registers. */ + /* + * Program configuration registers. + * JEDEC specs requires clocks to be stable before deasserting reset + * for RDIMMs. Clocks start after chip select is enabled and clock + * control register is set. During step 1, all controllers have their + * registers set but not enabled. Step 2 proceeds after deasserting + * reset through board FPGA or GPIO. + * For non-registered DIMMs, initialization can go through but it is + * also OK to follow the same flow. + */ + deassert_reset = board_need_mem_reset(); + for (i = 0; i < CONFIG_NUM_DDR_CONTROLLERS; i++) { + if (info.common_timing_params[i].all_DIMMs_registered) + deassert_reset = 1; + } for (i = 0; i < CONFIG_NUM_DDR_CONTROLLERS; i++) { debug("Programming controller %u\n", i); if (info.common_timing_params[i].ndimms_present == 0) { @@ -573,8 +599,22 @@ phys_size_t fsl_ddr_sdram(void) "skipping programming\n", i); continue; } - - fsl_ddr_set_memctl_regs(&(info.fsl_ddr_config_reg[i]), i); + /* + * The following call with step = 1 returns before enabling + * the controller. It has to finish with step = 2 later. + */ + fsl_ddr_set_memctl_regs(&(info.fsl_ddr_config_reg[i]), i, + deassert_reset ? 1 : 0); + } + if (deassert_reset) { + /* Use board FPGA or GPIO to deassert reset signal */ + debug("Deasserting mem reset\n"); + board_deassert_mem_reset(); + for (i = 0; i < CONFIG_NUM_DDR_CONTROLLERS; i++) { + /* Call with step = 2 to continue initialization */ + fsl_ddr_set_memctl_regs(&(info.fsl_ddr_config_reg[i]), + i, 2); + } }
/* program LAWs */ diff --git a/arch/powerpc/include/asm/fsl_ddr_sdram.h b/arch/powerpc/include/asm/fsl_ddr_sdram.h index bac22fc..f4eec82 100644 --- a/arch/powerpc/include/asm/fsl_ddr_sdram.h +++ b/arch/powerpc/include/asm/fsl_ddr_sdram.h @@ -331,9 +331,31 @@ extern phys_size_t fsl_ddr_sdram(void); extern phys_size_t fsl_ddr_sdram_size(void); extern int fsl_use_spd(void); extern void fsl_ddr_set_memctl_regs(const fsl_ddr_cfg_regs_t *regs, - unsigned int ctrl_num); + unsigned int ctrl_num, int step); u32 fsl_ddr_get_intl3r(void);
+static void __board_assert_mem_reset(void) +{ +} + +static void __board_deassert_mem_reset(void) +{ +} + +void board_assert_mem_reset(void) + __attribute__((weak, alias("__board_assert_mem_reset"))); + +void board_deassert_mem_reset(void) + __attribute__((weak, alias("__board_deassert_mem_reset"))); + +static int __board_need_mem_reset(void) +{ + return 0; +} + +int board_need_mem_reset(void) + __attribute__((weak, alias("__board_need_mem_reset"))); + /* * The 85xx boards have a common prototype for fixed_sdram so put the * declaration here. diff --git a/board/freescale/bsc9131rdb/ddr.c b/board/freescale/bsc9131rdb/ddr.c index c753edf..5296986 100644 --- a/board/freescale/bsc9131rdb/ddr.c +++ b/board/freescale/bsc9131rdb/ddr.c @@ -103,7 +103,7 @@ phys_size_t fixed_sdram(void) }
ddr_size = (phys_size_t) CONFIG_SYS_SDRAM_SIZE * 1024 * 1024; - fsl_ddr_set_memctl_regs(&ddr_cfg_regs, 0); + fsl_ddr_set_memctl_regs(&ddr_cfg_regs, 0, 0);
if (set_ddr_laws(CONFIG_SYS_DDR_SDRAM_BASE, ddr_size, LAW_TRGT_IF_DDR_1) < 0) { diff --git a/board/freescale/bsc9132qds/ddr.c b/board/freescale/bsc9132qds/ddr.c index 946ad19..60abaa6 100644 --- a/board/freescale/bsc9132qds/ddr.c +++ b/board/freescale/bsc9132qds/ddr.c @@ -125,7 +125,7 @@ phys_size_t fixed_sdram(void) strmhz(buf, ddr_freq));
if (set_ddr_laws(CONFIG_SYS_DDR_SDRAM_BASE, ddr_size, LAW_TRGT_IF_DDR_1) < 0) { diff --git a/board/freescale/common/qixis.c b/board/freescale/common/qixis.c index 2b74d02..0dea660 100644 --- a/board/freescale/common/qixis.c +++ b/board/freescale/common/qixis.c @@ -111,6 +111,26 @@ const char *byte_to_binary_mask(u8 val, u8 mask, char *buf) return buf; }
+#ifdef QIXIS_RST_FORCE_MEM +void board_assert_mem_reset(void) +{ + u8 rst; + + rst = QIXIS_READ(rst_frc[0]); + if (!(rst & QIXIS_RST_FORCE_MEM)) + QIXIS_WRITE(rst_frc[0], rst | QIXIS_RST_FORCE_MEM); +} + +void board_deassert_mem_reset(void) +{ + u8 rst; + + rst = QIXIS_READ(rst_frc[0]); + if (rst & QIXIS_RST_FORCE_MEM) + QIXIS_WRITE(rst_frc[0], rst & ~QIXIS_RST_FORCE_MEM); +} +#endif + void qixis_reset(void) { QIXIS_WRITE(rst_ctl, QIXIS_RST_CTL_RESET); diff --git a/board/freescale/corenet_ds/ddr.c b/board/freescale/corenet_ds/ddr.c index da284cd..517e87f 100644 --- a/board/freescale/corenet_ds/ddr.c +++ b/board/freescale/corenet_ds/ddr.c @@ -56,14 +56,14 @@ phys_size_t fixed_sdram(void)
ddr_size = (phys_size_t) CONFIG_SYS_SDRAM_SIZE * 1024 * 1024; ddr_cfg_regs.ddr_cdr1 = DDR_CDR1_DHC_EN; - fsl_ddr_set_memctl_regs(&ddr_cfg_regs, 0); + fsl_ddr_set_memctl_regs(&ddr_cfg_regs, 0, 0);
#if (CONFIG_NUM_DDR_CONTROLLERS == 2) memcpy(&ddr_cfg_regs, fixed_ddr_parm_1[i].ddr_settings, sizeof(ddr_cfg_regs)); ddr_cfg_regs.ddr_cdr1 = DDR_CDR1_DHC_EN; - fsl_ddr_set_memctl_regs(&ddr_cfg_regs, 1); + fsl_ddr_set_memctl_regs(&ddr_cfg_regs, 1, 0); #endif
/* diff --git a/board/freescale/p1010rdb/ddr.c b/board/freescale/p1010rdb/ddr.c index 49310bd..72c46f1 100644 --- a/board/freescale/p1010rdb/ddr.c +++ b/board/freescale/p1010rdb/ddr.c @@ -155,7 +155,7 @@ phys_size_t fixed_sdram(void) }
if (set_ddr_laws(CONFIG_SYS_DDR_SDRAM_BASE, ddr_size, LAW_TRGT_IF_DDR_1) < 0) { diff --git a/board/freescale/p1_p2_rdb/ddr.c b/board/freescale/p1_p2_rdb/ddr.c index b16b8c8..9c7fc0e 100644 --- a/board/freescale/p1_p2_rdb/ddr.c +++ b/board/freescale/p1_p2_rdb/ddr.c @@ -236,7 +236,7 @@ phys_size_t fixed_sdram (void) ddr_cfg_regs.cs[0].bnds = 0x0000001F; }
set_ddr_laws(0, ddr_size, LAW_TRGT_IF_DDR_1); return ddr_size; diff --git a/board/freescale/p1_p2_rdb_pc/ddr.c b/board/freescale/p1_p2_rdb_pc/ddr.c index 9355536..14f0539 100644 --- a/board/freescale/p1_p2_rdb_pc/ddr.c +++ b/board/freescale/p1_p2_rdb_pc/ddr.c @@ -251,7 +251,7 @@ phys_size_t fixed_sdram(void)
ddr_size = CONFIG_SYS_SDRAM_SIZE * 1024 * 1024;
if (set_ddr_laws(CONFIG_SYS_DDR_SDRAM_BASE, ddr_size, LAW_TRGT_IF_DDR_1) < 0) { diff --git a/include/configs/T4240QDS.h b/include/configs/T4240QDS.h index 6294f2b..d849e24 100644 --- a/include/configs/T4240QDS.h +++ b/include/configs/T4240QDS.h @@ -177,6 +177,7 @@ unsigned long get_board_ddr_clk(void); #define QIXIS_LBMAP_DFLTBANK 0x00 #define QIXIS_LBMAP_ALTBANK 0x04 #define QIXIS_RST_CTL_RESET 0x83 +#define QIXIS_RST_FORCE_MEM 0x1 #define QIXIS_RCFG_CTL_RECONFIG_IDLE 0x20 #define QIXIS_RCFG_CTL_RECONFIG_START 0x21 #define QIXIS_RCFG_CTL_WATCHDOG_ENBLE 0x08
Erratum A-005812 Incorrect reservation clearing in Write Shadow mode can result in invalid atomic operations. For u-boot, this erratum only impacts SoCs running in write shadow mode.
Signed-off-by: York Sun yorksun@freescale.com --- arch/powerpc/cpu/mpc85xx/cmd_errata.c | 3 +++ arch/powerpc/cpu/mpc85xx/cpu_init.c | 8 ++++++++ arch/powerpc/cpu/mpc85xx/release.S | 15 +++++++++++++++ arch/powerpc/include/asm/config_mpc85xx.h | 3 +++ 4 files changed, 29 insertions(+)
diff --git a/arch/powerpc/cpu/mpc85xx/cmd_errata.c b/arch/powerpc/cpu/mpc85xx/cmd_errata.c index 422782c..7db06ac 100644 --- a/arch/powerpc/cpu/mpc85xx/cmd_errata.c +++ b/arch/powerpc/cpu/mpc85xx/cmd_errata.c @@ -258,6 +258,9 @@ static int do_errata(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) #ifdef CONFIG_SYS_FSL_ERRATUM_USB14 puts("Work-around for Erratum USB14 enabled\n"); #endif +#ifdef CONFIG_SYS_FSL_ERRATUM_A005812 + puts("Work-around for Erratum A-005812 enabled\n"); +#endif return 0; }
diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init.c b/arch/powerpc/cpu/mpc85xx/cpu_init.c index fd19d99..ca799ac 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init.c @@ -412,6 +412,14 @@ int cpu_init_r(void) sync(); } #endif +#ifdef CONFIG_SYS_FSL_ERRATUM_A005812 + /* + * A-005812 workaround sets bit 32 of SPR 976 for SoCs running + * in write shadow mode. Checking DCWS before setting SPR 976. + */ + if (mfspr(L1CSR2) & L1CSR2_DCWS) + mtspr(SPRN_HDBCR0, (mfspr(SPRN_HDBCR0) | 0x80000000)); +#endif
#if defined(CONFIG_PPC_SPINTABLE_COMPATIBLE) && defined(CONFIG_MP) spin = getenv("spin_table_compat"); diff --git a/arch/powerpc/cpu/mpc85xx/release.S b/arch/powerpc/cpu/mpc85xx/release.S index a4a21b0..6af2efd 100644 --- a/arch/powerpc/cpu/mpc85xx/release.S +++ b/arch/powerpc/cpu/mpc85xx/release.S @@ -242,6 +242,21 @@ __secondary_start_page: 2: #endif
+#ifdef CONFIG_SYS_FSL_ERRATUM_A005812 + /* + * A-005812 workaround sets bit 32 of SPR 976 for SoCs running in + * write shadow mode. This code should run after other code setting + * DCWS. + */ + mfspr r3,L1CSR2 + andis. r3,r3,(L1CSR2_DCWS)@h + beq 1f + mfspr r3, SPRN_HDBCR0 + oris r3, r3, 0x8000 + mtspr SPRN_HDBCR0, r3 +1: +#endif + #ifdef CONFIG_BACKSIDE_L2_CACHE /* skip L2 setup on P2040/P2040E as they have no L2 */ mfspr r3,SPRN_SVR diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index 057402b..9370a89 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -383,6 +383,7 @@ #define CONFIG_SYS_FSL_CORENET_SNOOPVEC_COREONLY 0xf0000000 #define CONFIG_SYS_FSL_ERRATUM_SRIO_A004034 #define CONFIG_SYS_FSL_ERRATUM_A004849 +#define CONFIG_SYS_FSL_ERRATUM_A005812
#elif defined(CONFIG_PPC_P4080) /* also supports P4040 */ #define CONFIG_SYS_FSL_QORIQ_CHASSIS1 @@ -429,6 +430,7 @@ #define CONFIG_SYS_FSL_ERRATUM_A004849 #define CONFIG_SYS_FSL_ERRATUM_A004580 #define CONFIG_SYS_P4080_ERRATUM_PCIE_A003 +#define CONFIG_SYS_FSL_ERRATUM_A005812
#elif defined(CONFIG_PPC_P5020) /* also supports P5010 */ #define CONFIG_SYS_PPC64 /* 64-bit core */ @@ -491,6 +493,7 @@ #define CONFIG_SYS_FSL_ERRATUM_A004510 #define CONFIG_SYS_FSL_ERRATUM_A004510_SVR_REV 0x10 #define CONFIG_SYS_FSL_CORENET_SNOOPVEC_COREONLY 0xf0000000 +#define CONFIG_SYS_FSL_ERRATUM_A005812
#elif defined(CONFIG_BSC9131) #define CONFIG_MAX_CPUS 1
Scott Wood
York Sun
