RE: [U-Boot-Users] u-boot and 2.4.18 kernel problem
Thanks for this
I checked and rechecked my sequence according to document and I do not see any problem. However, I changed PLPRCR to give me reset if I get checkstop, and that is what is happening i.e. I am getting checkstop exception. Any ideas what could be wrong?
Lokesh
-----Original Message----- From: Sam Song [mailto:samsongshu@yahoo.com.cn] Sent: Wednesday, June 30, 2004 10:22 AM To: Lokesh Kumar Cc: u-boot-users@lists.sourceforge.net Subject: RE: [U-Boot-Users] u-boot and 2.4.18 kernel problem
Lokesh Kumar wrote:
/* perform SDRAM initializsation sequence */
memctl->memc_mar = 0x00000088;
memctl->memc_mcr = 0x80002105; memctl->memc_mcr = 0x80002830; memctl->memc_mcr = 0x80002106;
It seems sth out of place here.But I am not quite sure.At least two cycles before refresh should be safer than one.You could refer to my poor work http://cvs.sourceforge.net/viewcvs.py/*checkout*/u-boot/u-boot/board/RPXlite _dw/RPXlite_dw.c?rev=1.1
udelay (1000);
size10 = dram_size (CFG_MAMR_10COL, (ulong > *)
SDRAM_BASE_PRELIM,
SDRAM_MAX_SIZE);
memctl->memc_mamr |= MAMR_PTAE; return (size10); }
I do not have the upm config tool from motorola to verify these settings. Has anybody used this chip with mpc855T and can help me figure this out?
I tested 2 MT48LC16M16A2-75 in 32-bit mode on 832e RPXlite_DW board.It worked fine.Next,I will also test 2 MT48LC8M16A2 on a 8xx custom board.So please let me know your advancement.I just had a look at the datasheet of MT48LC8M16A2 and MT48LC16M16A2.They have exactly the same timing waveform on initialization.
Hope this help!
Sam
_________________________________________________________ Do You Yahoo!? 100兆邮箱够不够用?雅虎电邮自助扩容! http://cn.rd.yahoo.com/mail_cn/tag/100m/*http://cn.promo.yahoo.com/minisite/ 100m/
Lokesh Kumar kumar.lokesh@wrx-us.com wrote:
Thanks for this
Sorry for this late reply.
Only PLPRCR and checkstop exception these key words doesn't make me to figure out the problem for you.If posting the debugging info,some would help you out of the hot water,I guess.
Sam
_________________________________________________________ Do You Yahoo!? 100兆邮箱够不够用?雅虎电邮自助扩容! http://cn.rd.yahoo.com/mail_cn/tag/100m/*http://cn.promo.yahoo.com/minisite/...
Lokesh Kumar
Sam Song
