Re: [U-Boot] Uboot- Nor flash
On Tue, Mar 15, 2011 at 11:07:46, Sanjeeva Kumara wrote:
Hi pls help me....... How the boot image is read into memory.... from where exactly execution starts...
1. what is your board configuration (memory, Processor, ram, etc..) 2. Is your board inside u-boot repository ?. what is the board config name
Regards Gururaja
-----Original Message----- From: Hebbar, Gururaja [mailto:gururaja.hebbar@ti.com] Sent: Friday, March 11, 2011 6:14 PM To: Sanjeeva Kumara; u-boot@lists.denx.de Subject: RE: Uboot- Nor flash
On Fri, Mar 11, 2011 at 14:02:20, Sanjeeva Kumara wrote:
Hi.... My self Sanjeev. I'm working on marvell's processor ( PXA ). I'm using NOR flash to port Uboot. I want to do partition in NOR flash so that in one partition I can keep my master copy and provide Uboot upgrade option. Please suggest me how can I achieve this.
The quickest would be to use CONFIG_SYS_FLASH_AUTOPROTECT_LIST. Search for this config and this will help you setup autoprotect options for various partitions.
Regards, Gururaja
Larsen & Toubro Limited
www.larsentoubro.com
This Email may contain confidential or privileged information for the intended recipient (s) If you are not the intended recipient, please do not use or disseminate the information, notify the sender and delete it from your system.
Regards, Gururaja
Hebbar, Gururaja
