[U-Boot] [PATCH] mx53loco: Fix U-Boot corruption after saving the environment
U-Boot binary has grown in such a way that it goes beyond the reserved area for the environment variables.
Running "saveenv" causes U-Boot to hang because of this overlap.
Fix this problem by increasing the CONFIG_ENV_OFFSET size.
Also, in order to prevent this same problem in the future, use CONFIG_BOARD_SIZE_LIMIT, which will detect the overlap in build-time.
CONFIG_BOARD_SIZE_LIMIT does not accept math expressions, so declare CONFIG_ENV_OFFSET with its direct value instead.
Signed-off-by: Fabio Estevam festevam@gmail.com --- include/configs/mx53loco.h | 14 ++++++++++++-- 1 file changed, 12 insertions(+), 2 deletions(-)
diff --git a/include/configs/mx53loco.h b/include/configs/mx53loco.h index b734b822dd..65a5993f61 100644 --- a/include/configs/mx53loco.h +++ b/include/configs/mx53loco.h @@ -163,8 +163,18 @@ #define CONFIG_SYS_INIT_SP_ADDR \ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
-/* environment organization */ -#define CONFIG_ENV_OFFSET (6 * 64 * 1024) +/* Environment starts at 768k = 768 * 1024 = 786432 */ +#define CONFIG_ENV_OFFSET 786432 +/* + * Detect overlap between U-Boot image and environment area in build-time + * + * CONFIG_BOARD_SIZE_LIMIT = CONFIG_ENV_OFFSET - u-boot.imx offset + * CONFIG_BOARD_SIZE_LIMIT = 768k - 1k = 767k = 785408 + * + * Currently CONFIG_BOARD_SIZE_LIMIT does not handle expressions, so + * write the direct value here + */ +#define CONFIG_BOARD_SIZE_LIMIT 785408 #define CONFIG_ENV_SIZE (8 * 1024) #define CONFIG_SYS_MMC_ENV_DEV 0
Gah!
Are there more i.mx platforms that are not setting BOARD_SIZE_LIMIT today? I assume there are, sadly. Can you audit and catch the rest of these likely problems, and add limits so we won't repeat this again. Thanks!
Hi Tom,
Yes, only a very few i.MX boards set BOARD_SIZE_LIMIT currently.
Yes, I can audit this, but this task requires more time and I can do that after 2019.10 is released.
Could this one that fixes mx53qsb be applied for 2019.10?
Thanks
On Mon, Sep 02, 2019 at 01:40:27PM -0300, Fabio Estevam wrote:
Hi Tom,
As some is better than none, yes, we should fix and detect this for this platform. But I am a little frustrated in that this is not a new problem and the hook to check for this problem was put in back in June, so I had hoped for more preemptive conversions. It's also on me for having not reminded folks about that too. So please, can we make sure to get this covered ASAP? I think the kludge patch I've posted and linked to before (http://patchwork.ozlabs.org/patch/790476/) can be used here to get a current value calculated and spit out. Moving the question to Kconfig would then make it easier still to: 1. sync all configs 2. loop over appending value to defconfigs 3. re-sync all defconfigs 4. drop first patch, squash next approximately anyhow. Thanks!
Fabio Estevam
