[U-Boot] [PATCH] Add WinCE image load/boot cmd
The patch is to add support functions which load and boot WinCE image. It introduces one new CMD macro named 'CONFIG_CMD_WINCE'. The source codes have tested on STLS board.
Signed-off-by: Ryan Chen ryan.chen@st.com
--- common/Makefile | 1 + common/cmd_bootm.c | 32 ++++++++ common/cmd_wince.c | 193 ++++++++++++++++++++++++++++++++++++++++++++++ include/config_cmd_all.h | 1 + include/image.h | 1 + 5 files changed, 228 insertions(+), 0 deletions(-) create mode 100644 common/cmd_wince.c
diff --git a/common/Makefile b/common/Makefile index 4287108..e427828 100644 --- a/common/Makefile +++ b/common/Makefile @@ -144,6 +144,7 @@ COBJS-y += cmd_mac.o COBJS-$(CONFIG_CMD_MFSL) += cmd_mfsl.o COBJS-$(CONFIG_MP) += cmd_mp.o COBJS-$(CONFIG_CMD_SF) += cmd_sf.o +COBJS-$(CONFIG_CMD_WINCE) += cmd_wince.o
COBJS := $(COBJS-y) SRCS := $(AOBJS:.o=.S) $(COBJS:.o=.c) diff --git a/common/cmd_bootm.c b/common/cmd_bootm.c index 1c0a416..e6397d7 100644 --- a/common/cmd_bootm.c +++ b/common/cmd_bootm.c @@ -106,6 +106,10 @@ int do_bootelf (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]); #if defined(CONFIG_ARTOS) && defined(CONFIG_PPC) static boot_os_fn do_bootm_artos; #endif +#if defined(CONFIG_CMD_WINCE) +static boot_os_fn do_bootm_wince; +int do_bootwince (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]); +#endif
ulong load_addr = CFG_LOAD_ADDR; /* Default Load Address */ static bootm_headers_t images; /* pointers to os/initrd/fdt images */ @@ -358,6 +362,12 @@ int do_bootm (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) do_bootm_artos (cmdtp, flag, argc, argv, &images); break; #endif + +#ifdef CONFIG_CMD_WINCE + case IH_OS_WINCE: + do_bootm_wince (cmdtp, flag, argc, argv, &images); + break; +#endif }
show_boot_progress (-9); @@ -1142,3 +1152,25 @@ static void do_bootm_artos (cmd_tbl_t *cmdtp, int flag, (*entry) (kbd, cmdline, fwenv, top); } #endif + +#if defined(CONFIG_CMD_WINCE) +static void do_bootm_wince (cmd_tbl_t *cmdtp, int flag, + int argc, char *argv[], + bootm_headers_t *images) +{ + char str[80]; + image_header_t *hdr = &images->legacy_hdr_os_copy; + +#if defined(CONFIG_FIT) + if (!images->legacy_hdr_valid) { + fit_unsupported_reset ("WinCE"); + do_reset (cmdtp, flag, argc, argv); + } +#endif + + sprintf(str, "%x", image_get_ep (hdr)); /* write entry-point into string */ + setenv("loadaddr", str); + do_bootwince(cmdtp, 0, 0, NULL); +} +#endif/* CONFIG_CMD_WINCE */ + diff --git a/common/cmd_wince.c b/common/cmd_wince.c new file mode 100644 index 0000000..fdc2e6b --- /dev/null +++ b/common/cmd_wince.c @@ -0,0 +1,193 @@ +/* + * 2008 (c) STMicroelectronics, Inc. + * Author: Ryan Chen Ryan.Chen@st.com + * + * Redistribution and use in source and binary forms, with or without + * modification, are permitted provided that the following conditions + * are met: + * 1. Redistributions of source code must retain the above copyright + * notice, this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright + * notice, this list of conditions and the following disclaimer in the + * documentation and/or other materials provided with the distribution. + * 3. All advertising materials mentioning features or use of this software + * must display the following acknowledgement: + * This product includes software developed by Opsycon AB, Sweden. + * 4. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS + * OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED + * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE + * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY + * DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF + * SUCH DAMAGE. + */ + +#include <common.h> +#include <command.h> +#include <linux/ctype.h> +#include <net.h> + +/* + * Windows CE Binary Image Data Format + * The binary image (.bin) file format organizes data by sections. Each section contains + * a section header that specifies the starting address, length, and checksum for that + * section. + * + * Refer to http://msdn.microsoft.com/en-us/library/ms924510.aspx + * + * The following table shows the .bin file format. + * Field Length (bytes) Description + * Sync bytes (optional) 7 Byte 0 is B, indicating a .bin file format. + * Bytes 1-6 are reserved and set to 0, 0, 0, F, F, \n. + * Run-time image address 4 Physical starting address of the run-time image. + * Run-time image length 4 Physical length, in bytes, of the run-time image. + * Record Address 4 Physical starting address of data record. + * If this value is zero, the Record Address is the end of + * the file, and record length contains the starting address + * of the run-time image. + * Record length 4 Length of record data, in bytes. + * Record checksum 4 Signed 32-bit sum of record data bytes. + * Record data Record length Record data. + */ +#define WINCE_IMAGE_SYNC_SIZE 7 +#define WINCE_IMAGE_SYNC "B000FF\n" + +typedef struct { + unsigned char sync_bytes[WINCE_IMAGE_SYNC_SIZE]; + unsigned int img_addr; + unsigned int img_length; +} type_wince_image_header; + +int check_sum(unsigned char * buf, int len, unsigned int checksum) +{ + unsigned int count,i; + + for (i = 0,count = 0 ; i < len ; i++) + count += buf[i]; + + if (count == checksum) + return 0; + + return 1; +} + +/* ====================================================================== + * Determine if a valid WinCE image exists at the given memory location. + * First looks at the image header field, the makes sure that it is + * WinCE image. + * ====================================================================== */ +int valid_wince_image (unsigned long addr) +{ + type_wince_image_header *p = (type_wince_image_header *)addr; + + if(strcmp((char *)p->sync_bytes, (char *)WINCE_IMAGE_SYNC) != 0) + return 0; + + return 1; +} + +/* ====================================================================== + * A very simple WinCE image loader, assumes the image is valid, returns the + * entry point address. + * ====================================================================== */ +unsigned long load_wince_image (unsigned long addr) +{ + unsigned char *p = (unsigned char *)addr; + u32 start_addr, total_length; + u32 record_addr, record_length, record_checksum; + u32 i = 0; + + if(valid_wince_image(addr) == 0) + return ~0; + + printf("WINCE image is found: "); + p += WINCE_IMAGE_SYNC_SIZE; + start_addr = (u32)(p[3]<<24) + (u32)(p[2]<<16) + (u32)(p[1]<<8) + (u32)p[0]; + p += 4; + total_length = (u32)(p[3]<<24) + (u32)(p[2]<<16) + (u32)(p[1]<<8) + (u32)p[0]; + printf(" Start Address = 0x%x @ Total Length = 0x%x\n", start_addr, total_length); + p += 4; + + /* read each records */ + while(1) { + record_length = (u32)(p[7]<<24) + (u32)(p[6]<<16) + (u32)(p[5]<<8) + (u32)p[4]; + record_checksum = (u32)(p[11]<<24) + (u32)(p[10]<<16) + (u32)(p[9]<<8) + (u32)p[8]; + record_addr = (u32)(p[3]<<24) + (u32)(p[2]<<16) + (u32)(p[1]<<8) + (u32)p[0]; + if(record_addr == 0) + break; + + if(check_sum((unsigned char *)&p[12], record_length, record_checksum) != 0) { + printf("Checksum Error!\n"); + return (unsigned long)~0; + } + memcpy ((void *)record_addr, (const void *)&p[12], (unsigned long)record_length); + printf("Region %d: Loading from 0x%x to 0x%x @ Length 0x%x\n", i, (unsigned int)&p[12], \ + (unsigned int)record_addr, record_length); + p = p + 12 + record_length; + i++; + } + + /* the lastest checksun should be zero */ + if(record_checksum != 0) { + printf("Checksum Error!\n"); + return (unsigned long)~0; + } + + /* the lastest length is entry address */ + return (unsigned long)record_length; +} + +/* ====================================================================== + * Interpreter command to boot WinCE from a memory image. The image can + * be an WinCE image. WinCE image do not need the + * bootline and other parameters. + * ====================================================================== */ +int do_bootwince (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + unsigned long addr; /* Address of image */ + + /* + * Check the loadaddr variable. + * If we don't know where the image is then we're done. + */ + if (argc < 2) + addr = load_addr; + else + addr = simple_strtoul (argv[1], NULL, 16); + +#if defined(CONFIG_CMD_NET) + /* Check to see if we need to tftp the image ourselves before starting */ + if ((argc == 2) && (strcmp (argv[1], "tftp") == 0)) { + if (NetLoop (TFTP) <= 0) + return 1; + printf ("Automatic boot of WinCE image at address 0x%08lx ... \n", addr); + } +#endif + + /* + * If the data at the load address is an WinCE image, then + * treat it like an WinCE image. Otherwise, return 1 + */ + if (valid_wince_image (addr)) { + addr = load_wince_image (addr); + } else { + puts ("## Not an WinCE image, exit!\n"); + return 1; + /* leave addr as load_addr */ + } + + printf ("## Starting Wince at 0x%08lx ...\n", addr); + + ((void (*)(void)) addr) (); + + puts ("## WinCE terminated\n"); + return 1; +} + diff --git a/include/config_cmd_all.h b/include/config_cmd_all.h index c2bb094..5f6fab5 100644 --- a/include/config_cmd_all.h +++ b/include/config_cmd_all.h @@ -81,5 +81,6 @@ #define CONFIG_CMD_VFD /* VFD support (TRAB) */ #define CONFIG_CMD_XIMG /* Load part of Multi Image */ #define CONFIG_CMD_AT91_SPIMUX /* AT91 MMC/SPI Mux Support */ +#define CONFIG_CMD_WINCE /* WinCE load/boot cmd */
#endif /* _CONFIG_CMD_ALL_H */ diff --git a/include/image.h b/include/image.h index 46138fa..7253278 100644 --- a/include/image.h +++ b/include/image.h @@ -85,6 +85,7 @@ #define IH_OS_RTEMS 18 /* RTEMS */ #define IH_OS_ARTOS 19 /* ARTOS */ #define IH_OS_UNITY 20 /* Unity OS */ +#define IH_OS_WINCE 21 /* WinCE OS */
/* * CPU Architecture Codes (supported by Linux)
Dear Ryan CHEN,
Sorry, this patch doesn't apply any more.
Can you please rebase and resubmit it? Thanks.
Do you have any plan to rebase it against current HEAD?
Best Regards, J.
- 2008 (c) STMicroelectronics, Inc.
- Author: Ryan Chen Ryan.Chen@st.com
- Redistribution and use in source and binary forms, with or without
- modification, are permitted provided that the following conditions
- are met:
- Redistributions of source code must retain the above copyright
- notice, this list of conditions and the following disclaimer.
- Redistributions in binary form must reproduce the above copyright
- notice, this list of conditions and the following disclaimer in the
- documentation and/or other materials provided with the distribution.
- All advertising materials mentioning features or use of this software
- must display the following acknowledgement:
- The name of the author may not be used to endorse or promote products
- derived from this software without specific prior written permission.
- THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS
- OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
- WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
- ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY
- DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
- DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
- OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
- HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
- LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
- OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
- SUCH DAMAGE.
Could resend this code under either GPL or a clean, GPL-compatible BSD license.
And BTW if needed put Opsycon AB in copy.
Best Regards, J.
Jean-Christophe PLAGNIOL-VILLARD
Ryan CHEN
