[U-Boot] [PATCH] usb: musb: set target address for non-multipoint devices
Signed-off-by: Bryan Wu bryan.wu@analog.com Signed-off-by: Cliff Cai cliff.cai@analog.com Signed-off-by: Mike Frysinger vapier@gentoo.org --- drivers/usb/musb/musb_hcd.c | 7 +++++++ 1 files changed, 7 insertions(+), 0 deletions(-)
diff --git a/drivers/usb/musb/musb_hcd.c b/drivers/usb/musb/musb_hcd.c index dd2aa7f..abb84b2 100644 --- a/drivers/usb/musb/musb_hcd.c +++ b/drivers/usb/musb/musb_hcd.c @@ -917,6 +917,13 @@ int submit_control_msg(struct usb_device *dev, unsigned long pipe, void *buffer,
dev->status = 0; dev->act_len = len; + +#ifdef MUSB_NO_MULTIPOINT + /* Set device address to USB_FADDR register */ + if (setup->request == USB_REQ_SET_ADDRESS) + writew(dev->devnum, &musbr->faddr); +#endif + return len; }
- /* Set device address to USB_FADDR register */
- if (setup->request == USB_REQ_SET_ADDRESS)
FAddr is a 8-bit regisrer, isn't it?
WBR, Sergei
--- a/drivers/usb/musb/musb_hcd.c +++ b/drivers/usb/musb/musb_hcd.c @@ -917,6 +917,13 @@ int submit_control_msg(struct usb_device *dev, unsigned long pipe, void *buffer, dev->status = 0; dev->act_len = len;
- writew(dev->devnum, &musbr->faddr);
on Blackfin systems, it is 16bit ... i'll have to double check to see what the hardware does with an 8bit access. i see there are other places in the code where 8bit is already being done, so those might need to be addressed as well ... -mike
yeah, Blackfin hardware likes to reject 8bit accesses to this mmr. although, i just remembered that in the musb code only, we specifically rewrite all readb/writeb to readw/writew for Blackfin systems. so i'll change this patch to writeb as you suggested. -mike
Signed-off-by: Bryan Wu bryan.wu@analog.com Signed-off-by: Cliff Cai cliff.cai@analog.com Signed-off-by: Mike Frysinger vapier@gentoo.org --- v2 - use writeb instead of writew as pointed out by Sergei Shtylyov
diff --git a/drivers/usb/musb/musb_hcd.c b/drivers/usb/musb/musb_hcd.c index dd2aa7f..8a761df 100644 --- a/drivers/usb/musb/musb_hcd.c +++ b/drivers/usb/musb/musb_hcd.c @@ -917,6 +917,13 @@ int submit_control_msg(struct usb_device *dev, unsigned long pipe, void *buffer,
dev->status = 0; dev->act_len = len; + +#ifdef MUSB_NO_MULTIPOINT + /* Set device address to USB_FADDR register */ + if (setup->request == USB_REQ_SET_ADDRESS) + writeb(dev->devnum, &musbr->faddr); +#endif + return len; }
2010/8/10 Mike Frysinger vapier@gentoo.org:
Applied to u-boot-usb. Thanks.
Remy
Mike Frysinger
Remy Bohmer
Sergei Shtylyov
