[U-Boot] U-Boot (porting) problem on MCF5445x board
Hi list,
I am trying to get U-Boot to run on my new MCF5445x board and have some problems.
What I did: - use M54455EVB as a starting point (non-SBF mode) - comment out RAM setup to start U-Boot from the debugger [debugger does RAM setup with my init script] - change flexbus and clock settings for my board [meanwhile tried some various settings, but without any change] The stack configuration is as follows: #define CONFIG_SYS_INIT_RAM_ADDR 0x80000000 #define CONFIG_SYS_INIT_RAM_END 0x8000 /* End of used area in internal SRAM */ #define CONFIG_SYS_INIT_RAM_CTRL 0x221 #define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ #define CONFIG_SYS_GBL_DATA_OFFSET ((CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) - 32) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
I can get U-boot to start and print out some messages, but even those are garbled in a way I do not understand. Here is what I get:
`¼ RR$(`¼ RR$(`¼ RR$( CPU CLK 250 MHz BUS CLK 125 MHz FLB CLK `¼ RR$(. 250 MHz INP CLK 50 MHz VCO CLK 500 MHz Board: ASTRO MCF5445x board I2C: ready SPI: ready `¼ RR$(128 MB`¼ RR$(FLASH:
*** Unexpected exception *** Vector Number: 0 Format: 0 Fault Status: 0
PC: 47da0080 SR: 00002700 SP: 47d6ff5c D0: 00000000 D1: 47d6fe84 D2: 47dca0e4 D3: 00000003 D4: 47db7dbc D5: 47dca0d8 D6: 66f36213 D7: 47d86f76 A0: 47d86f76 A1: 47db2e2a A2: 47d60080 A3: 47dca0e8 A4: 47dca0e4 A5: 47dc7c00 A6: 47d6ffb4
*** Please Reset Board! ***
As can be seen, the first lines are missing (or replaced by some fixed string), and even within printing the processor clocks (mcf5445x/cpu.c), this fixed string shows up as part of the "strmhz" output. The flash probably can not be initialised because I did not yet check if the serial flash settings are correct as I did not see a sense in it if there are errors in earlier stages. RAM is 128MB located at 0x40000000-0x47ffffff, I set TEXT_BASE and CONFIG_SYS_LOAD_ADDR to 0x40020000 (I am used to this address because I used it on MCF5373L, too), I can read back the U-Boot image after the above crash and it is identical to what I wrote to RAM before, so I would exclude a SDRAM configuration or other access problem. When changing anything in the code, the "pattern" of which printfs do work and which show the erroneous string changes, but I could not see a scheme in it.
When trying to debug the program (using PEEDI) I tried to step into printf, but without reproducible success: (gdb) break cpu.c:81 Breakpoint 1 at 0x40033966: file cpu.c, line 81. (gdb) c Continuing.
Breakpoint 1, checkcpu () at cpu.c:81 81 printf("Freescale MCF%d (Mask:%01x Version:%x)\n", id, msk, (gdb) s 83 printf(" CPU CLK %s MHz BUS CLK %s MHz FLB CLK %s MHz\n", (gdb) s 81 printf("Freescale MCF%d (Mask:%01x Version:%x)\n", id, msk, (gdb) s 83 printf(" CPU CLK %s MHz BUS CLK %s MHz FLB CLK %s MHz\n", (gdb) s 81 printf("Freescale MCF%d (Mask:%01x Version:%x)\n", id, msk, (gdb) s
Program received signal SIGTRAP, Trace/breakpoint trap. 0x47db9392 in ?? ()
I once managed to step into printf using ddd as a frontend, but was not able to print the address of printbuffer (which I wanted to check to see if there are maybe stack problems). As far as I understand, the first printfs are executed before relocation (and thus using a stack in internal SRAM). The relocation itself seems to work as 0x47da0080 seems a reasonable PC value.
Any hints on how I can debug this are highly appreciated, seems I am making some wrong assumptions or am overlooking another fundamental (or stupid) mistake here. Probably there are few people here using Coldfire, but maybe parts of the problem are common to other processors, too.
Thank you, Wolfgang
two more observations:
- there are some entries in the linker script reminiscent from and embedded environment forcing .text from start.o, traps.o, interrupts.o, dlmalloc.o and zlib.o to the beginning of the .text section; if I remove these, U-Boot crashes without any output (did not yet find out where) - when debugging properly, I can break in console.c:printf() and get these: Breakpoint 1, printf (fmt=0x40030000 "`¼ RR\213$(") at console.c:381 381 i = vsprintf(printbuffer, fmt, args); (gdb) c Continuing.
Breakpoint 1, printf ( fmt=0x4003e556 "Freescale MCF%d (Mask:%01x Version:%x)\n") at console.c:381 381 i = vsprintf(printbuffer, fmt, args); (gdb) c
0x40030000 is in the middle of the .text section. Furthermore, when stepping further with 'c' U-Boot again crashes sometime before printing the unexpected exception report. I do not understand where this different behaviour with and without breakpoints results from.
Maybe this gives someone more experienced a hint what I am doing wrong.
Regards, Wolfgang
Sorry for another self-followup...
With the modified linker script, I already have a failure in board.c/board_init_f():
(gdb) break board.c:249 Breakpoint 1 at 0x4002089e: file board.c, line 249. (gdb) c Continuing.
Breakpoint 1, board_init_f (bootflag=0) at board.c:249 249 memset ((void *) gd, 0, sizeof (gd_t)); (gdb) n 252 if ((*init_fnc_ptr)() != 0) { (gdb) print init_fnc_ptr $1 = (init_fnc_t **) 0x40040000 (gdb) print init_sequence $2 = {0x40033aca <get_clocks>, 0x4002e22e <env_init>, 0x400205ca <init_baudrate>, 0x40026ad2 <serial_init>, 0x4002ce4e <console_init_f>, 0x40030262 <display_options>, 0x400338e8 <checkcpu>, 0x4002ff80 <checkboard>, 0x40020596 <init_func_i2c>, 0x4002056c <init_func_spi>, 0x40020510 <init_func_ram>, 0} (gdb) print *init_fnc_ptr $3 = (init_fnc_t *) 0x1010101 (gdb) s [gdb hangs here, does not reach get_clocks()]
The addresses from "print init_sequence" correspond to those found in u-boot.map. I have to admit I am a bit puzzled by the behaviour of gdb when printing pointers (did not use it for some years now...), but to me the init_fnc_ptr looks ... weird. And somehow truncated (?) like the fmt string in the debugged printf() from the last mail. I tried disabling the cache which was formerly enabled already in cpu_init_f(), but this did not change anything.
Have to give up for today, hopefully I see more clearly next morning.
Regards, Wolfgang
Hi list,
sorry for the noise!
The problem turned out to be a simple SDRAM setup problem. I had set "burst read to read/precharge delay" and "burst write to read/write/precharge delay" by 1 too low.
Don't know how I messed these values up, but these lead to all memory accesses in single-step mode and via BDM to work correctly but gave erroneous results in real program execution.
[note to self: in case of strange errors, always check memory interface. If triple-checked: check again...]
Sorry again, Wolfgang
PS: just in case anybody is interested, I am using two pieces of MT47H32M16HR-3IT on an MCF54455 with this setup:
; SDRAM init ; SDCS0: mem write 0xFC0B8110 0x40000019 ; SDCS1: mem write 0xFC0B8114 0x44000019 ; SDCFG1: mem write 0xFC0B8008 0x66311720 ; SDCFG2: mem write 0xFC0B800C 0x6A670000 ; SDCR (PALL): mem write 0xFC0B8004 0xE9062002 ; SDMR (EMode2): mem write 0xFC0B8000 0x80010000 ; SDMR (EMode3): mem write 0xFC0B8000 0xC0010000 ; SDMR (EMode) mem write 0xFC0B8000 0x40010412 ; SDMR (Mode) mem write 0xFC0B8000 0x00010333 wait 10 ; SDCR: mem write 0xFC0B8004 0xE9062C02 mem write 0xFC0B8004 0xE9062C04 mem write 0xFC0B8004 0xE9062C04 ; SDMR (MODE) mem write 0xFC0B8000 0x00010233 ; SDMR (EMODE, OCD default) mem write 0xFC0B8000 0x40010792 ; SDMR (EMODE, OCD exit) mem write 0xFC0B8000 0x40010412 ; SDCR: mem write 0xFC0B8004 0x79062C00
Dear Wolfgang Wegner,
Congrats for fixing it - note that y ou are not the first one to discover this. There is a reason why this topic has a top entry in the FAQ.
wolfgang@leila.ping.de
