[PATCH v3 00/23] Add support for MediaTek MT7620 SoC
This series will add support for MediaTek MT7620 SoC with two reference boards and related drivers.
The MediaTek MT7620 is a 2x2 802.11n WiSoC integrating a MIPS 24KEc processor running at a maximum frequency of 620MHz. This chip can be found in many wireless routers.
This series add all basic drivers which are useful in u-boot, like usb, sdhc, ethernet, spi and serial. Booting from NAND is currently unsupported.
Thanks, Weijie
v3 changes: - Use bool instead of int in for mt7620_spi_set_cs() mt7620_spi.c - Add detail comments for mt7620_wdt_expire_now() in mt7620_wdt.c - Remove duplicated dev field in mt7620-usb-phy.c - Add fixes for mtk-sd (fix sclk cycles shift value, assign plat->cfg.f_max)
v2 changes: - Remove non-DM code from mt7620-serial driver, and use of-platdata instead - Fix dev_err related compilation error - Add expire_now for mt7620-wdt - Remove use of common.h
Weijie Gao (23): mips: dts: switch to board defines for dtb for mtmips mips: mtmips: move mt7628 related Kconfig into mt7628 subdirectory mips: mtmips: select SYSRESET for mt7628 only mips: mtmips: fix dram size detection in dram_init mips: enable _machine_restart for spl mips: mtmips: add support to initialize SDRAM mips: mtmips: add support for MediaTek MT7620 SoC mips: mtmips: add two reference boards for mt7620 configs: mtmips: refresh for mt7628 based boards serial: add uart driver for MediaTek MT7620 SoC clk: add clock driver for MediaTek MT7620 SoC reset: mtmips: add reset controller support for MediaTek MT7620 SoC pinctrl: mtmips: add support for MediaTek MT7620 SoC watchdog: add watchdog driver for MediaTek MT7620 SoC gpio: add GPIO controller driver for MediaTek MT7620 SoC spi: add spi controller support for MediaTek MT7620 SoC phy: add USB PHY driver for MediaTek MT7620 SoC net: add ethernet driver for MediaTek MT7620 SoC mmc: mtk-sd: fix sclk cycles shift value mmc: mtk-sd: add pad control settings for MediaTek MT7620/MT76x8 SoCs mmc: mtk-sd: assign plat->cfg.f_max with a correct value reset: reset-mtmips: add DM_FLAG_PRE_RELOC flag MAINTAINERS: add maintainer for MediaTek MIPS platform
MAINTAINERS | 23 + arch/mips/Kconfig | 1 - arch/mips/cpu/cpu.c | 2 +- arch/mips/dts/Makefile | 7 +- arch/mips/dts/mediatek,mt7620-mt7530-rfb.dts | 100 ++ arch/mips/dts/mediatek,mt7620-rfb.dts | 97 ++ arch/mips/dts/mt7620-u-boot.dtsi | 14 + arch/mips/dts/mt7620.dtsi | 296 ++++ arch/mips/mach-mtmips/Kconfig | 72 +- arch/mips/mach-mtmips/Makefile | 1 + arch/mips/mach-mtmips/cpu.c | 5 +- arch/mips/mach-mtmips/ddr_init.c | 59 + arch/mips/mach-mtmips/include/mach/ddr.h | 4 + .../mach-mtmips/include/mach/mt7620-sysc.h | 54 + arch/mips/mach-mtmips/mt7620/Kconfig | 71 + arch/mips/mach-mtmips/mt7620/Makefile | 10 + arch/mips/mach-mtmips/mt7620/dram.c | 113 ++ arch/mips/mach-mtmips/mt7620/init.c | 193 +++ arch/mips/mach-mtmips/mt7620/lowlevel_init.S | 53 + arch/mips/mach-mtmips/mt7620/mt7620.h | 103 ++ arch/mips/mach-mtmips/mt7620/serial.c | 36 + arch/mips/mach-mtmips/mt7620/sysc.c | 172 +++ arch/mips/mach-mtmips/mt7628/Kconfig | 53 + board/mediatek/mt7620/Kconfig | 12 + board/mediatek/mt7620/MAINTAINERS | 9 + board/mediatek/mt7620/Makefile | 3 + board/mediatek/mt7620/board.c | 6 + .../gardena-smart-gateway-mt7688_defconfig | 1 + configs/linkit-smart-7688_defconfig | 1 + configs/mt7620_mt7530_rfb_defconfig | 58 + configs/mt7620_rfb_defconfig | 76 + configs/mt7628_rfb_defconfig | 1 + configs/vocore2_defconfig | 1 + drivers/clk/mtmips/Makefile | 1 + drivers/clk/mtmips/clk-mt7620.c | 159 +++ drivers/gpio/Kconfig | 8 + drivers/gpio/Makefile | 1 + drivers/gpio/mt7620_gpio.c | 146 ++ drivers/mmc/mtk-sd.c | 136 +- drivers/net/Kconfig | 12 + drivers/net/Makefile | 1 + drivers/net/mt7620-eth.c | 1222 +++++++++++++++++ drivers/phy/Kconfig | 7 + drivers/phy/Makefile | 1 + drivers/phy/mt7620-usb-phy.c | 110 ++ drivers/pinctrl/mtmips/Kconfig | 9 + drivers/pinctrl/mtmips/Makefile | 1 + drivers/pinctrl/mtmips/pinctrl-mt7620.c | 200 +++ drivers/reset/reset-mtmips.c | 1 + drivers/serial/Kconfig | 20 + drivers/serial/Makefile | 1 + drivers/serial/serial.c | 2 + drivers/serial/serial_mt7620.c | 246 ++++ drivers/spi/Kconfig | 7 + drivers/spi/Makefile | 1 + drivers/spi/mt7620_spi.c | 281 ++++ drivers/watchdog/Kconfig | 7 + drivers/watchdog/Makefile | 1 + drivers/watchdog/mt7620_wdt.c | 142 ++ include/configs/mt7620.h | 46 + include/dt-bindings/clock/mt7620-clk.h | 40 + include/dt-bindings/reset/mt7620-reset.h | 35 + 62 files changed, 4479 insertions(+), 72 deletions(-) create mode 100644 arch/mips/dts/mediatek,mt7620-mt7530-rfb.dts create mode 100644 arch/mips/dts/mediatek,mt7620-rfb.dts create mode 100644 arch/mips/dts/mt7620-u-boot.dtsi create mode 100644 arch/mips/dts/mt7620.dtsi create mode 100644 arch/mips/mach-mtmips/include/mach/mt7620-sysc.h create mode 100644 arch/mips/mach-mtmips/mt7620/Kconfig create mode 100644 arch/mips/mach-mtmips/mt7620/Makefile create mode 100644 arch/mips/mach-mtmips/mt7620/dram.c create mode 100644 arch/mips/mach-mtmips/mt7620/init.c create mode 100644 arch/mips/mach-mtmips/mt7620/lowlevel_init.S create mode 100644 arch/mips/mach-mtmips/mt7620/mt7620.h create mode 100644 arch/mips/mach-mtmips/mt7620/serial.c create mode 100644 arch/mips/mach-mtmips/mt7620/sysc.c create mode 100644 arch/mips/mach-mtmips/mt7628/Kconfig create mode 100644 board/mediatek/mt7620/Kconfig create mode 100644 board/mediatek/mt7620/MAINTAINERS create mode 100644 board/mediatek/mt7620/Makefile create mode 100644 board/mediatek/mt7620/board.c create mode 100644 configs/mt7620_mt7530_rfb_defconfig create mode 100644 configs/mt7620_rfb_defconfig create mode 100644 drivers/clk/mtmips/clk-mt7620.c create mode 100644 drivers/gpio/mt7620_gpio.c create mode 100644 drivers/net/mt7620-eth.c create mode 100644 drivers/phy/mt7620-usb-phy.c create mode 100644 drivers/pinctrl/mtmips/pinctrl-mt7620.c create mode 100644 drivers/serial/serial_mt7620.c create mode 100644 drivers/spi/mt7620_spi.c create mode 100644 drivers/watchdog/mt7620_wdt.c create mode 100644 include/configs/mt7620.h create mode 100644 include/dt-bindings/clock/mt7620-clk.h create mode 100644 include/dt-bindings/reset/mt7620-reset.h
Previous the dts files for gardena-smart-gateway-mt7688 and linkit-smart-7688 are set to be built when mtmips is selected.
This can lead to a compilation error if another soc is added to this arch with different dtsi files.
So it's better to build the dtb only if their board is selected.
Reviewed-by: Stefan Roese sr@denx.de Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v3 changes: none v2 changes: none --- arch/mips/dts/Makefile | 5 ++--- 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/arch/mips/dts/Makefile b/arch/mips/dts/Makefile index dc85901dca..e82f96d4e4 100644 --- a/arch/mips/dts/Makefile +++ b/arch/mips/dts/Makefile @@ -1,8 +1,5 @@ # SPDX-License-Identifier: GPL-2.0+
-dtb-$(CONFIG_ARCH_MTMIPS) += \ - gardena-smart-gateway-mt7688.dtb \ - linkit-smart-7688.dtb dtb-$(CONFIG_TARGET_AP121) += ap121.dtb dtb-$(CONFIG_TARGET_AP143) += ap143.dtb dtb-$(CONFIG_TARGET_AP152) += ap152.dtb @@ -18,6 +15,8 @@ dtb-$(CONFIG_BOARD_COMTREND_VR3032U) += comtrend,vr-3032u.dtb dtb-$(CONFIG_BOARD_COMTREND_WAP5813N) += comtrend,wap-5813n.dtb dtb-$(CONFIG_BOARD_HUAWEI_HG556A) += huawei,hg556a.dtb dtb-$(CONFIG_BOARD_MT7628_RFB) += mediatek,mt7628-rfb.dtb +dtb-$(CONFIG_BOARD_GARDENA_SMART_GATEWAY_MT7688) += gardena-smart-gateway-mt7688.dtb +dtb-$(CONFIG_BOARD_LINKIT_SMART_7688) += linkit-smart-7688.dtb dtb-$(CONFIG_TARGET_OCTEON_EBB7304) += mrvl,octeon-ebb7304.dtb dtb-$(CONFIG_BOARD_NETGEAR_CG3100D) += netgear,cg3100d.dtb dtb-$(CONFIG_BOARD_NETGEAR_DGND3700V2) += netgear,dgnd3700v2.dtb
This patch is a preparation for add a new soc fot mtmips.
Move all mt7628 related Kconfig (boards and UART selection) into mt7628 subdirectory and make sure the top directory of mtmips contains only selection for SoCs.
Reviewed-by: Stefan Roese sr@denx.de Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v3 changes: none v2 changes: none --- arch/mips/mach-mtmips/Kconfig | 53 +--------------------------- arch/mips/mach-mtmips/mt7628/Kconfig | 53 ++++++++++++++++++++++++++++ 2 files changed, 54 insertions(+), 52 deletions(-) create mode 100644 arch/mips/mach-mtmips/mt7628/Kconfig
diff --git a/arch/mips/mach-mtmips/Kconfig b/arch/mips/mach-mtmips/Kconfig index 737de2cb8e..7c07430a0c 100644 --- a/arch/mips/mach-mtmips/Kconfig +++ b/arch/mips/mach-mtmips/Kconfig @@ -58,57 +58,6 @@ config SOC_MT7628
endchoice
-choice - prompt "Board select" - -config BOARD_GARDENA_SMART_GATEWAY_MT7688 - bool "GARDENA smart Gateway" - depends on SOC_MT7628 - select BOARD_LATE_INIT - help - GARDENA smart Gateway boards have a MT7688 SoC with 128 MiB of RAM - and 8 MiB of flash (SPI NOR) and additional SPI NAND storage. - -config BOARD_LINKIT_SMART_7688 - bool "LinkIt Smart 7688" - depends on SOC_MT7628 - help - Seeed LinkIt Smart 7688 boards have a MT7688 SoC with 128 MiB of RAM - and 32 MiB of flash (SPI). - Between its different peripherals there's an integrated switch with 4 - ethernet ports, 1 USB port, 1 UART, GPIO buttons and LEDs, and - a MT7688 (PCIe). - -config BOARD_MT7628_RFB - bool "MediaTek MT7628 RFB" - depends on SOC_MT7628 - help - The reference design of MT7628. The board has 128 MiB DDR2, 8 MiB - SPI-NOR flash, 1 built-in switch with 5 ports, 1 UART, 1 USB host, - 1 SDXC, 1 PCIe socket and JTAG pins. - -config BOARD_VOCORE2 - bool "VoCore2" - depends on SOC_MT7628 - select SPL_SERIAL_SUPPORT - select SPL_UART2_SPIS_PINMUX - help - VoCore VoCore2 board has a MT7628 SoC with 128 MiB of RAM - and 16 MiB of flash (SPI). - -endchoice - -config SPL_UART2_SPIS_PINMUX - bool "Use alternative pinmux for UART2 in SPL stage" - depends on SPL_SERIAL_SUPPORT - default n - help - Select this if the UART2 of your board is connected to GPIO 16/17 - (shared with SPIS) rather than the usual GPIO 20/21. - -source "board/gardena/smart-gateway-mt7688/Kconfig" -source "board/mediatek/mt7628/Kconfig" -source "board/seeed/linkit-smart-7688/Kconfig" -source "board/vocore/vocore2/Kconfig" +source "arch/mips/mach-mtmips/mt7628/Kconfig"
endmenu diff --git a/arch/mips/mach-mtmips/mt7628/Kconfig b/arch/mips/mach-mtmips/mt7628/Kconfig new file mode 100644 index 0000000000..e3f56e782e --- /dev/null +++ b/arch/mips/mach-mtmips/mt7628/Kconfig @@ -0,0 +1,53 @@ + +if SOC_MT7628 + +choice + prompt "Board select" + +config BOARD_GARDENA_SMART_GATEWAY_MT7688 + bool "GARDENA smart Gateway" + select BOARD_LATE_INIT + help + GARDENA smart Gateway boards have a MT7688 SoC with 128 MiB of RAM + and 8 MiB of flash (SPI NOR) and additional SPI NAND storage. + +config BOARD_LINKIT_SMART_7688 + bool "LinkIt Smart 7688" + help + Seeed LinkIt Smart 7688 boards have a MT7688 SoC with 128 MiB of RAM + and 32 MiB of flash (SPI). + Between its different peripherals there's an integrated switch with 4 + ethernet ports, 1 USB port, 1 UART, GPIO buttons and LEDs, and + a MT7688 (PCIe). + +config BOARD_MT7628_RFB + bool "MediaTek MT7628 RFB" + help + The reference design of MT7628. The board has 128 MiB DDR2, 8 MiB + SPI-NOR flash, 1 built-in switch with 5 ports, 1 UART, 1 USB host, + 1 SDXC, 1 PCIe socket and JTAG pins. + +config BOARD_VOCORE2 + bool "VoCore2" + select SPL_SERIAL_SUPPORT + select SPL_UART2_SPIS_PINMUX + help + VoCore VoCore2 board has a MT7628 SoC with 128 MiB of RAM + and 16 MiB of flash (SPI). + +endchoice + +config SPL_UART2_SPIS_PINMUX + bool "Use alternative pinmux for UART2 in SPL stage" + depends on SPL_SERIAL_SUPPORT + default n + help + Select this if the UART2 of your board is connected to GPIO 16/17 + (shared with SPIS) rather than the usual GPIO 20/21. + +source "board/gardena/smart-gateway-mt7688/Kconfig" +source "board/mediatek/mt7628/Kconfig" +source "board/seeed/linkit-smart-7688/Kconfig" +source "board/vocore/vocore2/Kconfig" + +endif
Currently only mt7628 needs the sysreset driver, do not select it for mt7620.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v3 changes: none v2 changes: new --- arch/mips/Kconfig | 1 - arch/mips/mach-mtmips/Kconfig | 1 + 2 files changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/mips/Kconfig b/arch/mips/Kconfig index e0f6b6c4b3..77f563e98e 100644 --- a/arch/mips/Kconfig +++ b/arch/mips/Kconfig @@ -97,7 +97,6 @@ config ARCH_MTMIPS select SUPPORTS_CPU_MIPS32_R1 select SUPPORTS_CPU_MIPS32_R2 select SUPPORTS_LITTLE_ENDIAN - select SYSRESET select SUPPORT_SPL
config ARCH_JZ47XX diff --git a/arch/mips/mach-mtmips/Kconfig b/arch/mips/mach-mtmips/Kconfig index 7c07430a0c..c383e82a6b 100644 --- a/arch/mips/mach-mtmips/Kconfig +++ b/arch/mips/mach-mtmips/Kconfig @@ -43,6 +43,7 @@ config SOC_MT7628 select SYS_MIPS_CACHE_INIT_RAM_LOAD select PINCTRL_MT7628 select MTK_SERIAL + select SYSRESET select SYSRESET_RESETCTL select SPL_SEPARATE_BSS if SPL select SPL_INIT_STACK_WITHOUT_MALLOC_F if SPL
Thanks, Stefan
config ARCH_JZ47XX
- select SYSRESET select SYSRESET_RESETCTL select SPL_SEPARATE_BSS if SPL select SPL_INIT_STACK_WITHOUT_MALLOC_F if SPL
Viele Grüße, Stefan
CONFIG_SYS_SDRAM_BASE points to cached memory, i.e. KSEG0, which is not suitable for detecting memory size.
Replace CONFIG_SYS_SDRAM_BASE with KSEG1, and make dram_init() always do memory size detection in any stage.
Reviewed-by: Stefan Roese sr@denx.de Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v3 changes: none v2 changes: none --- arch/mips/mach-mtmips/cpu.c | 5 ++--- 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/arch/mips/mach-mtmips/cpu.c b/arch/mips/mach-mtmips/cpu.c index 2ddf8cb096..ca1967055a 100644 --- a/arch/mips/mach-mtmips/cpu.c +++ b/arch/mips/mach-mtmips/cpu.c @@ -6,6 +6,7 @@ #include <common.h> #include <init.h> #include <malloc.h> +#include <asm/addrspace.h> #include <linux/bitops.h> #include <linux/io.h> #include <linux/sizes.h> @@ -14,9 +15,7 @@ DECLARE_GLOBAL_DATA_PTR;
int dram_init(void) { -#ifdef CONFIG_SKIP_LOWLEVEL_INIT - gd->ram_size = get_ram_size((void *)CONFIG_SYS_SDRAM_BASE, SZ_256M); -#endif + gd->ram_size = get_ram_size((void *)KSEG1, SZ_256M);
return 0; }
The sysreset driver has a config CONFIG_SPL_SYSRESET for the spl stage. Change CONFIG_SYSRESET to CONFIG_IS_ENABLED(SYSRESET) will give spl a chance to use _machine_restart instead of the sysreset driver.
Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v3 changes: none v2 changes: new --- arch/mips/cpu/cpu.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/mips/cpu/cpu.c b/arch/mips/cpu/cpu.c index 7d5c9fd83a..b304026a67 100644 --- a/arch/mips/cpu/cpu.c +++ b/arch/mips/cpu/cpu.c @@ -12,7 +12,7 @@ #include <asm/mipsregs.h> #include <asm/reboot.h>
-#ifndef CONFIG_SYSRESET +#if !CONFIG_IS_ENABLED(SYSRESET) void __weak _machine_restart(void) { fprintf(stderr, "*** reset failed ***\n");
Thanks, Stefan
Viele Grüße, Stefan
This patch adds support for mtmips SoCs to initialize the SDRAM.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v3 changes: none v2 changes: none --- arch/mips/mach-mtmips/ddr_init.c | 59 ++++++++++++++++++++++++ arch/mips/mach-mtmips/include/mach/ddr.h | 4 ++ 2 files changed, 63 insertions(+)
diff --git a/arch/mips/mach-mtmips/ddr_init.c b/arch/mips/mach-mtmips/ddr_init.c index 6c6d0933f2..9c986daea6 100644 --- a/arch/mips/mach-mtmips/ddr_init.c +++ b/arch/mips/mach-mtmips/ddr_init.c @@ -15,6 +15,13 @@
#define DDR_BW_TEST_PAT 0xaa5555aa
+static const u32 sdr_size_cfg1[] = { + [DRAM_8MB] = (1 << NUMROWS_S), + [DRAM_16MB] = (1 << NUMROWS_S) | (1 << NUMCOLS_S), + [DRAM_32MB] = (2 << NUMROWS_S) | (1 << NUMCOLS_S), + [DRAM_64MB] = (2 << NUMROWS_S) | (2 << NUMCOLS_S), +}; + static const u32 dram_size[] = { [DRAM_8MB] = SZ_8M, [DRAM_16MB] = SZ_16M, @@ -193,3 +200,55 @@ void ddr2_init(struct mc_ddr_init_param *param) param->memsize = dram_size[sz]; param->bus_width = bw; } + +static void mc_sdr_init(void __iomem *memc, mc_reset_t mc_reset, u32 cfg0, + u32 cfg1) +{ + mc_reset(1); + __udelay(200); + mc_reset(0); + + writel(cfg0, memc + MEMCTL_SDRAM_CFG0_REG); + writel(cfg1, memc + MEMCTL_SDRAM_CFG1_REG); + + while (!(readl(memc + MEMCTL_SDRAM_CFG1_REG) & SDRAM_INIT_DONE)) + ; + + clrsetbits_32(memc + MEMCTL_PWR_SAVE_CNT_REG, SR_TAR_CNT_M, + 1 << SR_TAR_CNT_S); + + setbits_32(memc + MEMCTL_DDR_SELF_REFRESH_REG, SR_AUTO_EN); +} + +void sdr_init(struct mc_ddr_init_param *param) +{ + enum mc_dram_size sz; + u32 cfg1; + + cfg1 = param->sdr_cfg1 | SDRAM_INIT_START; + cfg1 &= ~(NUMCOLS_M | NUMROWS_M); + + /* First initialization, determine SDR capacity */ + mc_sdr_init(param->memc, param->mc_reset, param->sdr_cfg0, + cfg1 | sdr_size_cfg1[DRAM_64MB]); + + if (dram_addr_test_bit(9)) { + sz = DRAM_8MB; + } else { + if (dram_addr_test_bit(10)) { + if (dram_addr_test_bit(23)) + sz = DRAM_16MB; + else + sz = DRAM_32MB; + } else { + sz = DRAM_64MB; + } + } + + /* Final initialization */ + mc_sdr_init(param->memc, param->mc_reset, param->sdr_cfg0, + cfg1 | sdr_size_cfg1[sz]); + + /* Return actual DDR configuration */ + param->memsize = dram_size[sz]; +} diff --git a/arch/mips/mach-mtmips/include/mach/ddr.h b/arch/mips/mach-mtmips/include/mach/ddr.h index f92198137b..15ff66ace6 100644 --- a/arch/mips/mach-mtmips/include/mach/ddr.h +++ b/arch/mips/mach-mtmips/include/mach/ddr.h @@ -35,6 +35,9 @@ typedef void (*mc_reset_t)(int assert); struct mc_ddr_init_param { void __iomem *memc;
+ u32 sdr_cfg0; + u32 sdr_cfg1; + u32 dq_dly; u32 dqs_dly;
@@ -45,6 +48,7 @@ struct mc_ddr_init_param { u32 bus_width; };
+void sdr_init(struct mc_ddr_init_param *param); void ddr1_init(struct mc_ddr_init_param *param); void ddr2_init(struct mc_ddr_init_param *param); void ddr_calibrate(void __iomem *memc, u32 memsize, u32 bw);
Thanks, Stefan
- [DRAM_8MB] = (1 << NUMROWS_S),
- [DRAM_16MB] = (1 << NUMROWS_S) | (1 << NUMCOLS_S),
- [DRAM_32MB] = (2 << NUMROWS_S) | (1 << NUMCOLS_S),
- [DRAM_64MB] = (2 << NUMROWS_S) | (2 << NUMCOLS_S),
- static const u32 dram_size[] = { [DRAM_8MB] = SZ_8M, [DRAM_16MB] = SZ_16M,
u32 cfg1)
- mc_reset(1);
- __udelay(200);
- mc_reset(0);
- writel(cfg0, memc + MEMCTL_SDRAM_CFG0_REG);
- writel(cfg1, memc + MEMCTL_SDRAM_CFG1_REG);
- while (!(readl(memc + MEMCTL_SDRAM_CFG1_REG) & SDRAM_INIT_DONE))
- clrsetbits_32(memc + MEMCTL_PWR_SAVE_CNT_REG, SR_TAR_CNT_M,
1 << SR_TAR_CNT_S);
- setbits_32(memc + MEMCTL_DDR_SELF_REFRESH_REG, SR_AUTO_EN);
- enum mc_dram_size sz;
- u32 cfg1;
- cfg1 = param->sdr_cfg1 | SDRAM_INIT_START;
- cfg1 &= ~(NUMCOLS_M | NUMROWS_M);
- /* First initialization, determine SDR capacity */
- mc_sdr_init(param->memc, param->mc_reset, param->sdr_cfg0,
- if (dram_addr_test_bit(9)) {
sz = DRAM_8MB;
- } else {
sz = DRAM_16MB;
else
sz = DRAM_32MB;
} else {
sz = DRAM_64MB;
- /* Final initialization */
- /* Return actual DDR configuration */
- param->memsize = dram_size[sz];
- u32 sdr_cfg0;
- u32 sdr_cfg1;
- u32 dq_dly; u32 dqs_dly;
Viele Grüße, Stefan
This patch adds support for MediaTek MT7620 SoC. All files are dedicated for u-boot.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v3 changes: none v2 changes: remove use of common.h --- arch/mips/dts/mt7620-u-boot.dtsi | 14 + arch/mips/dts/mt7620.dtsi | 296 ++++++++++++++++++ arch/mips/mach-mtmips/Kconfig | 18 ++ arch/mips/mach-mtmips/Makefile | 1 + .../mach-mtmips/include/mach/mt7620-sysc.h | 54 ++++ arch/mips/mach-mtmips/mt7620/Kconfig | 54 ++++ arch/mips/mach-mtmips/mt7620/Makefile | 10 + arch/mips/mach-mtmips/mt7620/dram.c | 113 +++++++ arch/mips/mach-mtmips/mt7620/init.c | 193 ++++++++++++ arch/mips/mach-mtmips/mt7620/lowlevel_init.S | 53 ++++ arch/mips/mach-mtmips/mt7620/mt7620.h | 103 ++++++ arch/mips/mach-mtmips/mt7620/serial.c | 36 +++ arch/mips/mach-mtmips/mt7620/sysc.c | 172 ++++++++++ include/configs/mt7620.h | 46 +++ 14 files changed, 1163 insertions(+) create mode 100644 arch/mips/dts/mt7620-u-boot.dtsi create mode 100644 arch/mips/dts/mt7620.dtsi create mode 100644 arch/mips/mach-mtmips/include/mach/mt7620-sysc.h create mode 100644 arch/mips/mach-mtmips/mt7620/Kconfig create mode 100644 arch/mips/mach-mtmips/mt7620/Makefile create mode 100644 arch/mips/mach-mtmips/mt7620/dram.c create mode 100644 arch/mips/mach-mtmips/mt7620/init.c create mode 100644 arch/mips/mach-mtmips/mt7620/lowlevel_init.S create mode 100644 arch/mips/mach-mtmips/mt7620/mt7620.h create mode 100644 arch/mips/mach-mtmips/mt7620/serial.c create mode 100644 arch/mips/mach-mtmips/mt7620/sysc.c create mode 100644 include/configs/mt7620.h
diff --git a/arch/mips/dts/mt7620-u-boot.dtsi b/arch/mips/dts/mt7620-u-boot.dtsi new file mode 100644 index 0000000000..ed8425719b --- /dev/null +++ b/arch/mips/dts/mt7620-u-boot.dtsi @@ -0,0 +1,14 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020 MediaTek Inc. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +&uartlite { + u-boot,dm-pre-reloc; +}; + +&uartfull { + u-boot,dm-pre-reloc; +}; diff --git a/arch/mips/dts/mt7620.dtsi b/arch/mips/dts/mt7620.dtsi new file mode 100644 index 0000000000..03a80b7a70 --- /dev/null +++ b/arch/mips/dts/mt7620.dtsi @@ -0,0 +1,296 @@ +// SPDX-License-Identifier: GPL-2.0 +#include <dt-bindings/clock/mt7620-clk.h> +#include <dt-bindings/reset/mt7620-reset.h> + +/ { + #address-cells = <1>; + #size-cells = <1>; + compatible = "mediatek,mt7620-soc"; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu@0 { + compatible = "mti,mips24KEc"; + device_type = "cpu"; + reg = <0>; + }; + }; + + clk48m: clk48m@0 { + compatible = "fixed-clock"; + + clock-frequency = <48000000>; + + #clock-cells = <0>; + }; + + sysc: sysc@10000000 { + compatible = "mediatek,mt7620-sysc"; + reg = <0x10000000 0x100>; + }; + + clkctrl: clkctrl@10000030 { + compatible = "mediatek,mt7620-clk"; + mediatek,sysc = <&sysc>; + + #clock-cells = <1>; + }; + + rstctrl: rstctrl@10000034 { + compatible = "mediatek,mtmips-reset"; + reg = <0x10000034 0x4>; + #reset-cells = <1>; + }; + + reboot: resetctl-reboot { + compatible = "resetctl-reboot"; + + resets = <&rstctrl SYS_RST>; + reset-names = "sysreset"; + }; + + uartfull: uartfull@10000500 { + compatible = "mediatek,mt7620-uart"; + reg = <10000500 0x100>; + + pinctrl-names = "default"; + pinctrl-0 = <&uartf_gpio_pins>; + + clocks = <&clkctrl CLK_UARTF>; + + resets = <&rstctrl UARTF_RST>; + reset-names = "uartf"; + + clock-frequency = <40000000>; + + status = "disabled"; + }; + + uartlite: uartlite@10000c00 { + compatible = "mediatek,mt7620-uart"; + reg = <0x10000c00 0x100>; + + pinctrl-names = "default"; + pinctrl-0 = <&uartl_pins>; + + clocks = <&clkctrl CLK_UARTL>; + + resets = <&rstctrl UARTL_RST>; + reset-names = "uartl"; + + clock-frequency = <40000000>; + }; + + pinctrl: pinctrl@10000060 { + compatible = "mediatek,mt7620-pinctrl"; + reg = <0x10000060 0x4>; + + pinctrl-names = "default"; + pinctrl-0 = <&state_default>; + + state_default: pin_state { + sutif_pins { + groups = "sutif"; + function = "none"; + }; + }; + + nand_pins: nand_pins { + groups = "nand"; + function = "nand"; + }; + + sd_pins: sd_pins { + groups = "nand"; + function = "sd"; + }; + + spi_single_pins: spi_single_pins { + groups = "spi"; + function = "spi"; + }; + + spi_dual_pins: spi_dual_pins { + spi_master_pins { + groups = "spi"; + function = "spi"; + }; + + spi_cs1_pin { + groups = "spi cs1"; + function = "spi cs1"; + }; + }; + + uartl_pins: uartl_pins { + groups = "uartl"; + function = "uartl"; + }; + + uartf_pins: uartf_pins { + groups = "uartf"; + function = "uartf"; + }; + + uartf_pcm_pins: uartf_pcm_pins { + groups = "uartf"; + function = "uartf pcm"; + }; + + uartf_i2s_pins: uartf_i2s_pins { + groups = "uartf"; + function = "i2s uartf"; + }; + + uartf_gpio_pins: uartf_gpio_pins { + groups = "uartf"; + function = "uartf gpio"; + }; + }; + + watchdog: watchdog@10000120 { + compatible = "mediatek,mt7620-wdt"; + reg = <0x10000120 0x10>; + + resets = <&rstctrl TIMER_RST>; + reset-names = "wdt"; + }; + + gpio0: gpio0@10000600 { + compatible = "mediatek,mt7620-gpio"; + reg = <0x10000600 0x34>; + + resets = <&rstctrl PIO_RST>; + reset-names = "pio"; + + mediatek,bank-name = "PIOA"; + mediatek,gpio-num = <24>; + mediatek,register-map = <0x20 0x24 0x2c 0x30>; + + gpio-controller; + #gpio-cells = <2>; + }; + + gpio1: gpio1@10000638 { + compatible = "mediatek,mt7620-gpio"; + reg = <0x10000638 0x24>; + + resets = <&rstctrl PIO_RST>; + reset-names = "pio"; + + mediatek,bank-name = "PIOB"; + mediatek,gpio-num = <16>; + mediatek,register-map = <0x10 0x14 0x1c 0x20>; + + gpio-controller; + #gpio-cells = <2>; + }; + + gpio2: gpio2@10000660 { + compatible = "mediatek,mt7620-gpio"; + reg = <0x10000660 0x24>; + + resets = <&rstctrl PIO_RST>; + reset-names = "pio"; + + mediatek,bank-name = "PIOC"; + mediatek,gpio-num = <32>; + mediatek,register-map = <0x10 0x14 0x1c 0x20>; + + gpio-controller; + #gpio-cells = <2>; + }; + + gpio3: gpio3@10000688 { + compatible = "mediatek,mt7620-gpio"; + reg = <0x10000688 0x24>; + + resets = <&rstctrl PIO_RST>; + reset-names = "pio"; + + mediatek,bank-name = "PIOD"; + mediatek,gpio-num = <1>; + mediatek,register-map = <0x10 0x14 0x1c 0x20>; + + gpio-controller; + #gpio-cells = <2>; + }; + + spi0: spi@10000b00 { + compatible = "mediatek,mt7620-spi"; + reg = <0x10000b00 0x100>; + + pinctrl-names = "default"; + pinctrl-0 = <&spi_single_pins>; + + resets = <&rstctrl SPI_RST>; + reset-names = "spi"; + + #address-cells = <1>; + #size-cells = <0>; + + clocks = <&clkctrl CLK_SPI>; + }; + + eth: eth@10100000 { + compatible = "mediatek,mt7620-eth"; + reg = <0x10100000 0x10000 + 0x10110000 0x8000>; + reg-names = "fe", "esw"; + + mediatek,sysc = <&sysc>; + + resets = <&rstctrl EPHY_RST>, + <&rstctrl ESW_RST>, + <&rstctrl FE_RST>; + reset-names = "ephy", "esw", "fe"; + + clocks = <&clkctrl CLK_EPHY>, + <&clkctrl CLK_ESW>, + <&clkctrl CLK_FE>; + clock-names = "ephy", "esw", "fe"; + + status = "disabled"; + }; + + usb_phy: mt7620-usb-phy { + compatible = "mediatek,mt7620-usbphy"; + + #phy-cells = <0>; + + mediatek,sysc = <&sysc>; + + clocks = <&clkctrl CLK_UPHY_48M>, <&clkctrl CLK_UPHY_12M>; + clock-names = "uphy48m", "uphy12m"; + + resets = <&rstctrl UHST_RST>, <&rstctrl UDEV_RST>; + reset-names = "uhst", "udev"; + }; + + ehci@101c0000 { + compatible = "generic-ehci"; + reg = <0x101c0000 0x1000>; + + phys = <&usb_phy>; + phy-names = "usb"; + }; + + mmc: mmc@10130000 { + compatible = "mediatek,mt7620-mmc"; + reg = <0x10130000 0x4000>; + builtin-cd = <1>; + r_smpl = <1>; + + pinctrl-names = "default"; + pinctrl-0 = <&sd_pins>; + + clocks = <&clk48m>, <&clkctrl CLK_SDHC>; + clock-names = "source", "hclk"; + + resets = <&rstctrl SDHC_RST>; + + status = "disabled"; + }; +}; diff --git a/arch/mips/mach-mtmips/Kconfig b/arch/mips/mach-mtmips/Kconfig index c383e82a6b..8756cadb0b 100644 --- a/arch/mips/mach-mtmips/Kconfig +++ b/arch/mips/mach-mtmips/Kconfig @@ -5,6 +5,7 @@ config SYS_MALLOC_F_LEN default 0x1000
config SYS_SOC + default "mt7620" if SOC_MT7620 default "mt7628" if SOC_MT7628
config SYS_DCACHE_SIZE @@ -31,10 +32,26 @@ config SPL_PAYLOAD
config BUILD_TARGET default "u-boot-with-spl.bin" if SPL + default "u-boot.bin"
choice prompt "MediaTek MIPS SoC select"
+config SOC_MT7620 + bool "MT7620" + select MIPS_L1_CACHE_SHIFT_5 + select SYS_MIPS_CACHE_INIT_RAM_LOAD + select PINCTRL_MT7620 + select MT7620_SERIAL + select MISC + select SPL_SEPARATE_BSS if SPL + select SPL_LOADER_SUPPORT if SPL + select SPL_OF_CONTROL if SPL_DM + select SPL_OF_PLATDATA if SPL_DM + select SPL_DM_SERIAL if SPL_DM + help + This supports MediaTek MT7620. + config SOC_MT7628 bool "MT7628" select MIPS_L1_CACHE_SHIFT_5 @@ -59,6 +76,7 @@ config SOC_MT7628
endchoice
+source "arch/mips/mach-mtmips/mt7620/Kconfig" source "arch/mips/mach-mtmips/mt7628/Kconfig"
endmenu diff --git a/arch/mips/mach-mtmips/Makefile b/arch/mips/mach-mtmips/Makefile index a7e6a66304..4909b47ef2 100644 --- a/arch/mips/mach-mtmips/Makefile +++ b/arch/mips/mach-mtmips/Makefile @@ -5,4 +5,5 @@ obj-y += ddr_init.o obj-y += ddr_cal.o obj-$(CONFIG_SPL_BUILD) += spl.o
+obj-$(CONFIG_SOC_MT7620) += mt7620/ obj-$(CONFIG_SOC_MT7628) += mt7628/ diff --git a/arch/mips/mach-mtmips/include/mach/mt7620-sysc.h b/arch/mips/mach-mtmips/include/mach/mt7620-sysc.h new file mode 100644 index 0000000000..743ca034c8 --- /dev/null +++ b/arch/mips/mach-mtmips/include/mach/mt7620-sysc.h @@ -0,0 +1,54 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2020 MediaTek Inc. + * + * Author: Weijie Gao weijie.gao@mediatek.com + * + * Definitions of ioctl requests of MT7620 sysc driver + */ + +#ifndef _MT7620_SYSC_H_ +#define _MT7620_SYSC_H_ + +#include <linux/types.h> + +enum mt7620_sysc_requests { + MT7620_SYSC_IOCTL_GET_CLK, + MT7620_SYSC_IOCTL_GET_CHIP_REV, + MT7620_SYSC_IOCTL_SET_GE1_MODE, + MT7620_SYSC_IOCTL_SET_GE2_MODE, + MT7620_SYSC_IOCTL_SET_USB_MODE, + MT7620_SYSC_IOCTL_SET_PCIE_MODE +}; + +struct mt7620_sysc_clks { + u32 cpu_clk; + u32 sys_clk; + u32 xtal_clk; + u32 peri_clk; +}; + +struct mt7620_sysc_chip_rev { + bool bga; + u32 ver : 4; + u32 eco : 4; +}; + +enum mt7620_sysc_ge_mode { + MT7620_SYSC_GE_RGMII, + MT7620_SYSC_GE_MII, + MT7620_SYSC_GE_RMII, + MT7620_SYSC_GE_ESW_PHY, +}; + +enum mt7620_sysc_usb_mode { + MT7620_SYSC_USB_DEVICE_MODE, + MT7620_SYSC_USB_HOST_MODE +}; + +enum mt7620_sysc_pcie_mode { + MT7620_SYSC_PCIE_EP_MODE, + MT7620_SYSC_PCIE_RC_MODE +}; + +#endif /* _MT7620_SYSC_H_ */ diff --git a/arch/mips/mach-mtmips/mt7620/Kconfig b/arch/mips/mach-mtmips/mt7620/Kconfig new file mode 100644 index 0000000000..aa7cf1d3c1 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7620/Kconfig @@ -0,0 +1,54 @@ + +if SOC_MT7620 + +config DEBUG_UART_BOARD_INIT + default y + +choice + prompt "Board select" + +endchoice + +choice + prompt "CPU frequency select" + default CPU_FREQ_580MHZ + +config CPU_FREQ_480MHZ + bool "480MHz" + +config CPU_FREQ_500MHZ + bool "500MHz" + +config CPU_FREQ_520MHZ + bool "520MHz" + +config CPU_FREQ_540MHZ + bool "540MHz" + +config CPU_FREQ_560MHZ + bool "560MHz" + +config CPU_FREQ_580MHZ + bool "580MHz" + +config CPU_FREQ_600MHZ + bool "600MHz" + +config CPU_FREQ_620MHZ + bool "620MHz" + +endchoice + +config CPU_FREQ_MULTI + int + range 0 7 + default 0 if CPU_FREQ_480MHZ + default 1 if CPU_FREQ_500MHZ + default 2 if CPU_FREQ_520MHZ + default 3 if CPU_FREQ_540MHZ + default 4 if CPU_FREQ_560MHZ + default 5 if CPU_FREQ_580MHZ + default 6 if CPU_FREQ_600MHZ + default 7 if CPU_FREQ_620MHZ + +endif diff --git a/arch/mips/mach-mtmips/mt7620/Makefile b/arch/mips/mach-mtmips/mt7620/Makefile new file mode 100644 index 0000000000..649f6c3798 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7620/Makefile @@ -0,0 +1,10 @@ +# SPDX-License-Identifier: GPL-2.0 + +obj-y += lowlevel_init.o +obj-y += init.o +obj-y += dram.o +obj-y += serial.o + +ifndef CONFIG_SPL_BUILD +obj-y += sysc.o +endif diff --git a/arch/mips/mach-mtmips/mt7620/dram.c b/arch/mips/mach-mtmips/mt7620/dram.c new file mode 100644 index 0000000000..0f0e64bf5e --- /dev/null +++ b/arch/mips/mach-mtmips/mt7620/dram.c @@ -0,0 +1,113 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020 MediaTek Inc. All Rights Reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#include <asm/addrspace.h> +#include <linux/bitops.h> +#include <linux/delay.h> +#include <linux/sizes.h> +#include <linux/io.h> +#include <mach/ddr.h> +#include <mach/mc.h> +#include "mt7620.h" + +/* SDR parameters */ +#define SDR_CFG0_VAL 0x51B283B3 +#define SDR_CFG1_VAL 0xC00003A9 + +/* DDR2 DQ_DLY */ +#define DDR2_DQ_DLY 0x88888888 + +/* DDR2 DQS_DLY */ +#define DDR2_DQS_DLY 0x88888888 + +static const struct mc_ddr_cfg ddr1_cfgs_200mhz[] = { + [DRAM_8MB] = { 0x34A1EB94, 0x20262324, 0x28000033, 0x00000002, 0x00000000 }, + [DRAM_16MB] = { 0x34A1EB94, 0x202A2324, 0x28000033, 0x00000002, 0x00000000 }, + [DRAM_32MB] = { 0x34A1E5CA, 0x202E2324, 0x28000033, 0x00000002, 0x00000000 }, + [DRAM_64MB] = { 0x3421E5CA, 0x20322324, 0x28000033, 0x00000002, 0x00000000 }, + [DRAM_128MB] = { 0x241B05CA, 0x20362334, 0x28000033, 0x00000002, 0x00000000 }, +}; + +static const struct mc_ddr_cfg ddr1_cfgs_160mhz[] = { + [DRAM_8MB] = { 0x239964A1, 0x20262323, 0x00000033, 0x00000002, 0x00000000 }, + [DRAM_16MB] = { 0x239964A1, 0x202A2323, 0x00000033, 0x00000002, 0x00000000 }, + [DRAM_32MB] = { 0x239964A1, 0x202E2323, 0x00000033, 0x00000002, 0x00000000 }, + [DRAM_64MB] = { 0x239984A1, 0x20322323, 0x00000033, 0x00000002, 0x00000000 }, + [DRAM_128MB] = { 0x239AB4A1, 0x20362333, 0x00000033, 0x00000002, 0x00000000 }, +}; + +static const struct mc_ddr_cfg ddr2_cfgs_200mhz[] = { + [DRAM_32MB] = { 0x2519E2E5, 0x222E2323, 0x68000C43, 0x00000416, 0x0000000A }, + [DRAM_64MB] = { 0x249AA2E5, 0x22322323, 0x68000C43, 0x00000416, 0x0000000A }, + [DRAM_128MB] = { 0x249B42E5, 0x22362323, 0x68000C43, 0x00000416, 0x0000000A }, + [DRAM_256MB] = { 0x249CE2E5, 0x223A2323, 0x68000C43, 0x00000416, 0x0000000A }, +}; + +static const struct mc_ddr_cfg ddr2_cfgs_160mhz[] = { + [DRAM_32MB] = { 0x23918250, 0x222E2322, 0x40000A43, 0x00000416, 0x00000006 }, + [DRAM_64MB] = { 0x239A2250, 0x22322322, 0x40000A43, 0x00000416, 0x00000008 }, + [DRAM_128MB] = { 0x2392A250, 0x22362322, 0x40000A43, 0x00000416, 0x00000008 }, + [DRAM_256MB] = { 0x24140250, 0x223A2322, 0x40000A43, 0x00000416, 0x00000008 }, +}; + +static void mt7620_memc_reset(int assert) +{ + void __iomem *sysc = ioremap_nocache(SYSCTL_BASE, SYSCTL_SIZE); + + if (assert) + setbits_32(sysc + SYSCTL_RSTCTL_REG, MC_RST); + else + clrbits_32(sysc + SYSCTL_RSTCTL_REG, MC_RST); +} + +void mt7620_dram_init(void) +{ + void __iomem *sysc; + bool lspd = false; + int ddr_type, aux; + struct mc_ddr_init_param param; + + sysc = ioremap_nocache(SYSCTL_BASE, SYSCTL_SIZE); + ddr_type = (readl(sysc + SYSCTL_SYSCFG0_REG) & DRAM_TYPE_M) + >> DRAM_TYPE_S; + aux = readl(sysc + SYSCTL_CPLL_CFG1_REG) & + (CPU_CLK_AUX1 | CPU_CLK_AUX0); + + if (aux == CPU_CLK_AUX1 || aux == CPU_CLK_AUX0) + lspd = true; + + mt7620_memc_reset(1); + __udelay(200); + + param.memc = ioremap_nocache(MEMCTL_BASE, MEMCTL_SIZE); + param.dq_dly = DDR2_DQ_DLY; + param.dqs_dly = DDR2_DQS_DLY; + param.mc_reset = mt7620_memc_reset; + param.memsize = 0; + param.bus_width = 0; + + if (ddr_type == DRAM_DDR1) { + if (lspd) + param.cfgs = ddr1_cfgs_160mhz; + else + param.cfgs = ddr1_cfgs_200mhz; + + ddr1_init(¶m); + } else if (ddr_type == DRAM_DDR2) { + if (lspd) + param.cfgs = ddr2_cfgs_160mhz; + else + param.cfgs = ddr2_cfgs_200mhz; + + ddr2_init(¶m); + } else { + param.sdr_cfg0 = SDR_CFG0_VAL; + param.sdr_cfg1 = SDR_CFG1_VAL; + + sdr_init(¶m); + } +} diff --git a/arch/mips/mach-mtmips/mt7620/init.c b/arch/mips/mach-mtmips/mt7620/init.c new file mode 100644 index 0000000000..93abf9228d --- /dev/null +++ b/arch/mips/mach-mtmips/mt7620/init.c @@ -0,0 +1,193 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020 MediaTek Inc. All Rights Reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#include <config.h> +#include <asm/global_data.h> +#include <linux/io.h> +#include "mt7620.h" + +DECLARE_GLOBAL_DATA_PTR; + +static const char * const dram_type[] = { + "SDRAM", "DDR", "DDR2", "SDRAM" +}; + +static const char * const boot_mode[(CHIP_MODE_M >> CHIP_MODE_S) + 1] = { + [1] = "NAND 4-cycles 2KB-page", + [2] = "SPI-NOR 3-Byte Addr", + [3] = "SPI-NOR 4-Byte Addr", + [10] = "NAND 4-cycles 512B-page", + [11] = "NAND 5-cycles 2KB-page", + [12] = "NAND 3-cycles 512B-page", +}; + +static void cpu_pll_init(void) +{ + void __iomem *sysc = ioremap_nocache(SYSCTL_BASE, SYSCTL_SIZE); + u32 pllmul = CONFIG_CPU_FREQ_MULTI; + + /* Make sure the pll multiplier is valid */ + if (pllmul > 7) + pllmul = 7; + + /* Set init CPU clock to 480MHz */ + clrsetbits_32(sysc + SYSCTL_CPLL_CFG1_REG, CPU_CLK_AUX1, CPU_CLK_AUX0); + + /* Enable software control of CPU PLL */ + setbits_32(sysc + SYSCTL_CPLL_CFG0_REG, CPLL_SW_CFG); + + /* CPU PLL power down */ + setbits_32(sysc + SYSCTL_CPLL_CFG1_REG, CPLL_PD); + + /* PLL configuration */ + clrsetbits_32(sysc + SYSCTL_CPLL_CFG0_REG, PLL_MULT_RATIO_M | + PLL_DIV_RATIO_M | SSC_UP_BOUND_M | SSC_EN, + (pllmul << PLL_MULT_RATIO_S) | SSC_SWING_M); + + /* CPU PLL power up */ + clrbits_32(sysc + SYSCTL_CPLL_CFG1_REG, CPLL_PD); + + /* Wait for CPU PLL locked */ + while (!(readl(sysc + SYSCTL_CPLL_CFG1_REG) & CPLL_LD)) + ; + + /* Set final CPU clock source */ + clrbits_32(sysc + SYSCTL_CPLL_CFG1_REG, CPU_CLK_AUX1 | CPU_CLK_AUX0); + + /* Adjust CPU clock */ + clrsetbits_32(sysc + SYSCTL_CPU_SYS_CLKCFG_REG, + CPU_FDIV_M | CPU_FFRAC_M, + (1 << CPU_FDIV_S) | (1 << CPU_FFRAC_S)); +} + +void mt7620_init(void) +{ + u32 cpu_clk; + + cpu_pll_init(); + + /* + * Set timer freq, which will be used during DRAM initialization + * Note that this function is using a temporary gd which will be + * destroyed after leaving this function. + */ + mt7620_get_clks(&cpu_clk, NULL, NULL); + gd->arch.timer_freq = cpu_clk / 2; + + mt7620_dram_init(); +} + +void mt7620_get_clks(u32 *cpu_clk, u32 *sys_clk, u32 *xtal_clk) +{ + void __iomem *sysc = ioremap_nocache(SYSCTL_BASE, SYSCTL_SIZE); + u32 val, multi, div, fdiv, ffrac, dram_type, sys_div; + u32 cpu_freq, xtal_freq; + + static const u32 div_ratio_table[] = {2, 3, 4, 8}; + + val = readl(sysc + SYSCTL_SYSCFG0_REG); + + dram_type = (val & DRAM_TYPE_M) >> DRAM_TYPE_S; + + if (val & XTAL_FREQ_SEL) + xtal_freq = 40000000; + else + xtal_freq = 20000000; + + val = readl(sysc + SYSCTL_CPLL_CFG1_REG); + if (val & CPU_CLK_AUX1) { + cpu_freq = xtal_freq; + } else if (val & CPU_CLK_AUX0) { + cpu_freq = 480000000; + } else { + val = readl(sysc + SYSCTL_CPLL_CFG0_REG); + if (val & CPLL_SW_CFG) { + multi = (val & PLL_MULT_RATIO_M) >> PLL_MULT_RATIO_S; + div = (val & PLL_DIV_RATIO_M) >> PLL_DIV_RATIO_S; + cpu_freq = (multi + 24) * 40000000 / + div_ratio_table[div]; + } else { + cpu_freq = 600000000; + } + } + + val = readl(sysc + SYSCTL_CUR_CLK_STS_REG); + ffrac = (val & CUR_CPU_FFRAC_M) >> CUR_CPU_FFRAC_S; + fdiv = (val & CUR_CPU_FDIV_M) >> CUR_CPU_FDIV_S; + cpu_freq = (cpu_freq * ffrac) / fdiv; + + switch (dram_type) { + case DRAM_SDRAM_E1: + sys_div = 4; + break; + case DRAM_DDR1: + case DRAM_DDR2: + sys_div = 3; + break; + case DRAM_SDRAM: + sys_div = 5; + break; + } + + if (cpu_clk) + *cpu_clk = cpu_freq; + + if (sys_clk) + *sys_clk = cpu_freq / sys_div; + + if (xtal_clk) + *xtal_clk = xtal_freq; +} + +int print_cpuinfo(void) +{ + void __iomem *sysc = ioremap_nocache(SYSCTL_BASE, SYSCTL_SIZE); + u32 cpu_clk, bus_clk, xtal_clk; + u32 val, ver, eco, pkg, dram, chipmode; + const char *bootdev; + + val = readl(sysc + SYSCTL_CHIP_REV_ID_REG); + ver = (val & VER_M) >> VER_S; + eco = (val & ECO_M) >> ECO_S; + pkg = !!(val & PKG_ID); + + val = readl(sysc + SYSCTL_SYSCFG0_REG); + dram = (val & DRAM_TYPE_M) >> DRAM_TYPE_S; + chipmode = (val & CHIP_MODE_M) >> CHIP_MODE_S; + + bootdev = boot_mode[chipmode]; + if (!bootdev) + bootdev = "Unsupported boot mode"; + + printf("CPU: MediaTek MT7620%c ver:%u eco:%u\n", + pkg ? 'A' : 'N', ver, eco); + + printf("Boot: %s, %s\n", dram_type[dram], bootdev); + + mt7620_get_clks(&cpu_clk, &bus_clk, &xtal_clk); + + /* Set final timer frequency */ + gd->arch.timer_freq = cpu_clk / 2; + + printf("Clock: CPU: %uMHz, Bus: %uMHz, XTAL: %uMHz\n", + cpu_clk / 1000000, bus_clk / 1000000, xtal_clk / 1000000); + + return 0; +} + +ulong notrace get_tbclk(void) +{ + return gd->arch.timer_freq; +} + +void _machine_restart(void) +{ + void __iomem *sysc = ioremap_nocache(SYSCTL_BASE, SYSCTL_SIZE); + + while (1) + writel(SYS_RST, sysc + SYSCTL_RSTCTL_REG); +} diff --git a/arch/mips/mach-mtmips/mt7620/lowlevel_init.S b/arch/mips/mach-mtmips/mt7620/lowlevel_init.S new file mode 100644 index 0000000000..399174620d --- /dev/null +++ b/arch/mips/mach-mtmips/mt7620/lowlevel_init.S @@ -0,0 +1,53 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2020 MediaTek Inc. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#include <config.h> +#include <asm-offsets.h> +#include <asm/regdef.h> +#include <asm/asm.h> + + .set noreorder + +NESTED(lowlevel_init, 0, ra) + /* Save ra and do real lowlevel initialization */ + move s0, ra + + /* + * Use SRAM from 802.11n MAC/BBP, 16KiB (0x10184000 ~ 0x10187fff) + * NOTE: non-word operations may fail in this SRAM. + * Use it as stack only for CPU/DRAM init which only has word operations. + */ + PTR_LI sp, 0xb0187f00 + + /* We still need a temporary gd for udelay */ + PTR_SUBU \ + sp, sp, GD_SIZE # reserve space for gd + li t0, -16 + and sp, sp, t0 # force 16 byte alignment + move k0, sp # save gd pointer + + move fp, sp + + /* Clear gd */ + move t0, k0 +1: + PTR_S zero, 0(t0) + PTR_ADDIU t0, PTRSIZE + blt t0, t1, 1b + nop + + /* Do CPU & DRAM initialization */ + PTR_LA t9, mt7620_init + jalr t9 + nop + + /* Restore ra */ + move ra, s0 + + jr ra + nop + END(lowlevel_init) diff --git a/arch/mips/mach-mtmips/mt7620/mt7620.h b/arch/mips/mach-mtmips/mt7620/mt7620.h new file mode 100644 index 0000000000..dd5e6d00e5 --- /dev/null +++ b/arch/mips/mach-mtmips/mt7620/mt7620.h @@ -0,0 +1,103 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2020 MediaTek Inc. All Rights Reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#ifndef _MT7620_H_ +#define _MT7620_H_ + +#include <linux/bitops.h> + +#define SYSCTL_BASE 0x10000000 +#define SYSCTL_SIZE 0x100 +#define MEMCTL_BASE 0x10000300 +#define MEMCTL_SIZE 0x100 +#define UARTFULL_BASE 0x10000500 +#define UARTFULL_SIZE 0x100 +#define UARTLITE_BASE 0x10000c00 +#define UARTLITE_SIZE 0x100 + +#define SYSCTL_CHIP_REV_ID_REG 0x0c +#define PKG_ID BIT(16) +#define PKG_ID_A 1 +#define PKG_ID_N 0 +#define VER_S 8 +#define VER_M GENMASK(11, 8) +#define ECO_S 0 +#define ECO_M GENMASK(3, 0) + +#define SYSCTL_SYSCFG0_REG 0x10 +#define XTAL_FREQ_SEL BIT(6) +#define XTAL_40MHZ 1 +#define XTAL_20MHZ 0 +#define DRAM_TYPE_S 4 +#define DRAM_TYPE_M GENMASK(5, 4) +#define DRAM_SDRAM 3 +#define DRAM_DDR2 2 +#define DRAM_DDR1 1 +#define DRAM_SDRAM_E1 0 +#define CHIP_MODE_S 0 +#define CHIP_MODE_M GENMASK(3, 0) + +#define SYSCTL_SYSCFG1_REG 0x14 +#define GE2_MODE_S 14 +#define GE2_MODE_M GENMASK(15, 14) +#define GE1_MODE_S 12 +#define GE1_MODE_M GENMASK(13, 12) +#define USB0_HOST_MODE BIT(10) +#define PCIE_RC_MODE BIT(8) +#define GE_MODE_M GENMASK(1, 0) + +#define SYSCTL_RSTCTL_REG 0x34 +#define MC_RST BIT(10) +#define SYS_RST BIT(0) + +#define SYSCTL_CLKCFG0_REG 0x2c +#define PERI_CLK_SEL BIT(4) + +#define SYSCTL_CPU_SYS_CLKCFG_REG 0x3c +#define CPU_OCP_RATIO_S 16 +#define CPU_OCP_RATIO_M GENMASK(19, 16) +#define CPU_FDIV_S 8 +#define CPU_FDIV_M GENMASK(12, 8) +#define CPU_FFRAC_S 0 +#define CPU_FFRAC_M GENMASK(4, 0) + +#define SYSCTL_CUR_CLK_STS_REG 0x44 +#define CUR_CPU_OCP_RATIO_S 16 +#define CUR_CPU_OCP_RATIO_M GENMASK(19, 16) +#define CUR_CPU_FDIV_S 8 +#define CUR_CPU_FDIV_M GENMASK(12, 8) +#define CUR_CPU_FFRAC_S 0 +#define CUR_CPU_FFRAC_M GENMASK(4, 0) + +#define SYSCTL_CPLL_CFG0_REG 0x54 +#define CPLL_SW_CFG BIT(31) +#define PLL_MULT_RATIO_S 16 +#define PLL_MULT_RATIO_M GENMASK(18, 16) +#define PLL_DIV_RATIO_S 10 +#define PLL_DIV_RATIO_M GENMASK(11, 10) +#define SSC_UP_BOUND_S 8 +#define SSC_UP_BOUND_M GENMASK(9, 8) +#define SSC_EN BIT(7) +#define SSC_SWING_S 4 +#define SSC_SWING_M GENMASK(6, 4) + +#define SYSCTL_CPLL_CFG1_REG 0x58 +#define CPLL_PD BIT(26) +#define CPU_CLK_AUX1 BIT(25) +#define CPU_CLK_AUX0 BIT(24) +#define CPLL_LD BIT(23) + +#define SYSCTL_GPIOMODE_REG 0x60 +#define UARTL_GPIO_MODE BIT(5) +#define UARTF_SHARE_MODE_S 2 +#define UARTF_SHARE_MODE_M GENMASK(4, 2) +#define UARTF_MODE_UARTF_GPIO 5 + +void mt7620_dram_init(void); +void mt7620_get_clks(u32 *cpu_clk, u32 *sys_clk, u32 *xtal_clk); + +#endif /* _MT7620_H_ */ diff --git a/arch/mips/mach-mtmips/mt7620/serial.c b/arch/mips/mach-mtmips/mt7620/serial.c new file mode 100644 index 0000000000..44f061cd6c --- /dev/null +++ b/arch/mips/mach-mtmips/mt7620/serial.c @@ -0,0 +1,36 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020 MediaTek Inc. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#include <asm/io.h> +#include <asm/addrspace.h> +#include "mt7620.h" + +void board_debug_uart_init(void) +{ + void __iomem *base = ioremap_nocache(SYSCTL_BASE, SYSCTL_SIZE); + +#if CONFIG_DEBUG_UART_BASE == 0xb0000500 /* KSEG1ADDR(UARTFULL_BASE) */ + clrsetbits_32(base + SYSCTL_GPIOMODE_REG, UARTF_SHARE_MODE_M, + UARTF_MODE_UARTF_GPIO << UARTF_SHARE_MODE_S); +#else + clrbits_32(base + SYSCTL_GPIOMODE_REG, UARTL_GPIO_MODE); +#endif +} + +void mtmips_spl_serial_init(void) +{ +#ifdef CONFIG_SPL_SERIAL_SUPPORT + void __iomem *base = ioremap_nocache(SYSCTL_BASE, SYSCTL_SIZE); + +#if CONFIG_CONS_INDEX == 1 + clrbits_32(base + SYSCTL_GPIOMODE_REG, UARTL_GPIO_MODE); +#elif CONFIG_CONS_INDEX == 2 + clrsetbits_32(base + SYSCTL_GPIOMODE_REG, UARTF_SHARE_MODE_M, + UARTF_MODE_UARTF_GPIO << UARTF_SHARE_MODE_S); +#endif +#endif /* CONFIG_SPL_SERIAL_SUPPORT */ +} diff --git a/arch/mips/mach-mtmips/mt7620/sysc.c b/arch/mips/mach-mtmips/mt7620/sysc.c new file mode 100644 index 0000000000..4de01b72be --- /dev/null +++ b/arch/mips/mach-mtmips/mt7620/sysc.c @@ -0,0 +1,172 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020 MediaTek Inc. All Rights Reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + * + * Misc driver for manipulating System control registers + */ + +#include <dm.h> +#include <misc.h> +#include <asm/io.h> +#include <asm/addrspace.h> +#include <dm/device_compat.h> +#include <mach/mt7620-sysc.h> +#include "mt7620.h" + +struct mt7620_sysc_priv { + void __iomem *base; +}; + +static int mt7620_sysc_read(struct udevice *dev, int offset, void *buf, + int size) +{ + struct mt7620_sysc_priv *priv = dev_get_priv(dev); + u32 val; + + if (offset % sizeof(u32) || size != sizeof(u32) || + offset >= SYSCTL_SIZE) + return -EINVAL; + + val = readl(priv->base + offset); + + if (buf) + *(u32 *)buf = val; + + return 0; +} + +static int mt7620_sysc_write(struct udevice *dev, int offset, const void *buf, + int size) +{ + struct mt7620_sysc_priv *priv = dev_get_priv(dev); + u32 val; + + if (offset % sizeof(u32) || size != sizeof(u32) || + offset >= SYSCTL_SIZE || !buf) + return -EINVAL; + + val = *(u32 *)buf; + writel(val, priv->base + offset); + + return 0; +} + +static int mt7620_sysc_ioctl(struct udevice *dev, unsigned long request, + void *buf) +{ + struct mt7620_sysc_priv *priv = dev_get_priv(dev); + struct mt7620_sysc_chip_rev *chip_rev; + struct mt7620_sysc_clks *clks; + u32 val, shift; + + if (!buf) + return -EINVAL; + + switch (request) { + case MT7620_SYSC_IOCTL_GET_CLK: + clks = buf; + mt7620_get_clks(&clks->cpu_clk, &clks->sys_clk, + &clks->xtal_clk); + + val = readl(priv->base + SYSCTL_CLKCFG0_REG); + if (val & PERI_CLK_SEL) + clks->peri_clk = clks->xtal_clk; + else + clks->peri_clk = 40000000; + + return 0; + + case MT7620_SYSC_IOCTL_GET_CHIP_REV: + chip_rev = buf; + + val = readl(priv->base + SYSCTL_CHIP_REV_ID_REG); + + chip_rev->bga = !!(val & PKG_ID); + chip_rev->ver = (val & VER_M) >> VER_S; + chip_rev->eco = (val & ECO_M) >> ECO_S; + + return 0; + + case MT7620_SYSC_IOCTL_SET_GE1_MODE: + case MT7620_SYSC_IOCTL_SET_GE2_MODE: + val = *(u32 *)buf; + + if (val > MT7620_SYSC_GE_ESW_PHY) + return -EINVAL; + + if (request == MT7620_SYSC_IOCTL_SET_GE1_MODE) + shift = GE1_MODE_S; + else + shift = GE2_MODE_S; + + clrsetbits_32(priv->base + SYSCTL_SYSCFG1_REG, + GE_MODE_M << shift, val << shift); + + return 0; + + case MT7620_SYSC_IOCTL_SET_USB_MODE: + val = *(u32 *)buf; + + if (val == MT7620_SYSC_USB_DEVICE_MODE) + val = 0; + else if (val == MT7620_SYSC_USB_HOST_MODE) + val = USB0_HOST_MODE; + + clrsetbits_32(priv->base + SYSCTL_SYSCFG1_REG, + USB0_HOST_MODE, val); + + return 0; + + case MT7620_SYSC_IOCTL_SET_PCIE_MODE: + val = *(u32 *)buf; + + if (val == MT7620_SYSC_PCIE_EP_MODE) + val = 0; + else if (val == MT7620_SYSC_PCIE_RC_MODE) + val = PCIE_RC_MODE; + + clrsetbits_32(priv->base + SYSCTL_SYSCFG1_REG, + PCIE_RC_MODE, val); + + return 0; + + default: + return -EINVAL; + } +} + +static int mt7620_sysc_probe(struct udevice *dev) +{ + struct mt7620_sysc_priv *priv = dev_get_priv(dev); + + priv->base = dev_remap_addr_index(dev, 0); + if (!priv->base) { + dev_err(dev, "failed to map sysc registers\n"); + return -EINVAL; + } + + return 0; +} + +static struct misc_ops mt7620_sysc_ops = { + .read = mt7620_sysc_read, + .write = mt7620_sysc_write, + .ioctl = mt7620_sysc_ioctl, +}; + +static const struct udevice_id mt7620_sysc_ids[] = { + { .compatible = "mediatek,mt7620-sysc" }, + { } +}; + +U_BOOT_DRIVER(mt7620_sysc) = { + .name = "mt7620_sysc", + .id = UCLASS_MISC, + .of_match = mt7620_sysc_ids, + .probe = mt7620_sysc_probe, + .ops = &mt7620_sysc_ops, + .priv_auto_alloc_size = sizeof(struct mt7620_sysc_priv), + .flags = DM_FLAG_PRE_RELOC, +}; diff --git a/include/configs/mt7620.h b/include/configs/mt7620.h new file mode 100644 index 0000000000..4d074a3688 --- /dev/null +++ b/include/configs/mt7620.h @@ -0,0 +1,46 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2020 MediaTek Inc. All Rights Reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#ifndef __CONFIG_MT7620_H +#define __CONFIG_MT7620_H + +#define CONFIG_SYS_HZ 1000 +#define CONFIG_SYS_MIPS_TIMER_FREQ 290000000 + +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE + +#define CONFIG_SYS_MALLOC_LEN 0x100000 +#define CONFIG_SYS_BOOTPARAMS_LEN 0x20000 + +#define CONFIG_SYS_SDRAM_BASE 0x80000000 +#define CONFIG_SYS_LOAD_ADDR 0x80010000 + +#define CONFIG_SYS_INIT_SP_OFFSET 0x400000 + +#define CONFIG_SYS_BOOTM_LEN 0x1000000 + +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_CBSIZE 1024 + +/* Serial common */ +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +/* SPL */ +#if defined(CONFIG_SPL) && !defined(CONFIG_SPL_BUILD) +#define CONFIG_SKIP_LOWLEVEL_INIT +#endif + +#define CONFIG_SYS_UBOOT_START CONFIG_SYS_TEXT_BASE +#define CONFIG_SPL_BSS_START_ADDR 0x80010000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x10000 +#define CONFIG_SPL_MAX_SIZE 0x10000 +#define CONFIG_SPL_PAD_TO 0 + +/* Dummy value */ +#define CONFIG_SYS_UBOOT_BASE 0 + +#endif /* __CONFIG_MT7620_H */
Thanks, Stefan
- Copyright (C) 2020 MediaTek Inc.
- Author: Weijie Gao weijie.gao@mediatek.com
+&uartlite {
- u-boot,dm-pre-reloc;
+&uartfull {
- #address-cells = <1>;
- #size-cells = <1>;
- compatible = "mediatek,mt7620-soc";
- cpus {
#size-cells = <0>;
cpu@0 {
reg = <0>;
- clk48m: clk48m@0 {
#clock-cells = <0>;
- sysc: sysc@10000000 {
- clkctrl: clkctrl@10000030 {
#clock-cells = <1>;
- rstctrl: rstctrl@10000034 {
#reset-cells = <1>;
- reboot: resetctl-reboot {
- uartfull: uartfull@10000500 {
- uartlite: uartlite@10000c00 {
- pinctrl: pinctrl@10000060 {
sutif_pins {
groups = "sutif";
function = "none";
groups = "nand";
function = "nand";
sd_pins: sd_pins {
groups = "nand";
function = "sd";
groups = "spi";
function = "spi";
spi_master_pins {
groups = "spi";
function = "spi";
spi_cs1_pin {
groups = "spi cs1";
groups = "uartl";
function = "uartl";
groups = "uartf";
function = "uartf";
groups = "uartf";
groups = "uartf";
groups = "uartf";
- watchdog: watchdog@10000120 {
- gpio0: gpio0@10000600 {
gpio-controller;
#gpio-cells = <2>;
- gpio1: gpio1@10000638 {
gpio-controller;
#gpio-cells = <2>;
- gpio2: gpio2@10000660 {
gpio-controller;
#gpio-cells = <2>;
- gpio3: gpio3@10000688 {
gpio-controller;
#gpio-cells = <2>;
- spi0: spi@10000b00 {
#size-cells = <0>;
- eth: eth@10100000 {
0x10110000 0x8000>;
<&rstctrl ESW_RST>,
<&rstctrl FE_RST>;
<&clkctrl CLK_ESW>,
<&clkctrl CLK_FE>;
- usb_phy: mt7620-usb-phy {
#phy-cells = <0>;
- ehci@101c0000 {
phys = <&usb_phy>;
phy-names = "usb";
- mmc: mmc@10130000 {
builtin-cd = <1>;
r_smpl = <1>;
config SYS_SOC
+config SOC_MT7620
- bool "MT7620"
- select MIPS_L1_CACHE_SHIFT_5
- select SYS_MIPS_CACHE_INIT_RAM_LOAD
- select PINCTRL_MT7620
- select MT7620_SERIAL
- select MISC
- select SPL_SEPARATE_BSS if SPL
- select SPL_LOADER_SUPPORT if SPL
- select SPL_OF_CONTROL if SPL_DM
- select SPL_OF_PLATDATA if SPL_DM
- select SPL_DM_SERIAL if SPL_DM
- help
- config SOC_MT7628 bool "MT7628" select MIPS_L1_CACHE_SHIFT_5
endchoice
- Definitions of ioctl requests of MT7620 sysc driver
- MT7620_SYSC_IOCTL_GET_CLK,
- MT7620_SYSC_IOCTL_GET_CHIP_REV,
- MT7620_SYSC_IOCTL_SET_GE1_MODE,
- MT7620_SYSC_IOCTL_SET_GE2_MODE,
- MT7620_SYSC_IOCTL_SET_USB_MODE,
- MT7620_SYSC_IOCTL_SET_PCIE_MODE
- u32 cpu_clk;
- u32 sys_clk;
- u32 xtal_clk;
- u32 peri_clk;
- bool bga;
- u32 ver : 4;
- u32 eco : 4;
- MT7620_SYSC_GE_RGMII,
- MT7620_SYSC_GE_MII,
- MT7620_SYSC_GE_RMII,
- MT7620_SYSC_GE_ESW_PHY,
- MT7620_SYSC_USB_DEVICE_MODE,
- MT7620_SYSC_USB_HOST_MODE
- MT7620_SYSC_PCIE_EP_MODE,
- MT7620_SYSC_PCIE_RC_MODE
+if SOC_MT7620
- default y
+choice
+endchoice
+choice
- prompt "CPU frequency select"
- default CPU_FREQ_580MHZ
- bool "480MHz"
- bool "500MHz"
- bool "520MHz"
- bool "540MHz"
- bool "560MHz"
- bool "580MHz"
- bool "600MHz"
- bool "620MHz"
+endchoice
- int
- range 0 7
- default 0 if CPU_FREQ_480MHZ
- default 1 if CPU_FREQ_500MHZ
- default 2 if CPU_FREQ_520MHZ
- default 3 if CPU_FREQ_540MHZ
- default 4 if CPU_FREQ_560MHZ
- default 5 if CPU_FREQ_580MHZ
- default 6 if CPU_FREQ_600MHZ
- default 7 if CPU_FREQ_620MHZ
- Copyright (C) 2020 MediaTek Inc. All Rights Reserved.
- [DRAM_8MB] = { 0x34A1EB94, 0x20262324, 0x28000033, 0x00000002, 0x00000000 },
- [DRAM_16MB] = { 0x34A1EB94, 0x202A2324, 0x28000033, 0x00000002, 0x00000000 },
- [DRAM_32MB] = { 0x34A1E5CA, 0x202E2324, 0x28000033, 0x00000002, 0x00000000 },
- [DRAM_64MB] = { 0x3421E5CA, 0x20322324, 0x28000033, 0x00000002, 0x00000000 },
- [DRAM_128MB] = { 0x241B05CA, 0x20362334, 0x28000033, 0x00000002, 0x00000000 },
- [DRAM_8MB] = { 0x239964A1, 0x20262323, 0x00000033, 0x00000002, 0x00000000 },
- [DRAM_16MB] = { 0x239964A1, 0x202A2323, 0x00000033, 0x00000002, 0x00000000 },
- [DRAM_32MB] = { 0x239964A1, 0x202E2323, 0x00000033, 0x00000002, 0x00000000 },
- [DRAM_64MB] = { 0x239984A1, 0x20322323, 0x00000033, 0x00000002, 0x00000000 },
- [DRAM_128MB] = { 0x239AB4A1, 0x20362333, 0x00000033, 0x00000002, 0x00000000 },
- [DRAM_32MB] = { 0x2519E2E5, 0x222E2323, 0x68000C43, 0x00000416, 0x0000000A },
- [DRAM_64MB] = { 0x249AA2E5, 0x22322323, 0x68000C43, 0x00000416, 0x0000000A },
- [DRAM_128MB] = { 0x249B42E5, 0x22362323, 0x68000C43, 0x00000416, 0x0000000A },
- [DRAM_256MB] = { 0x249CE2E5, 0x223A2323, 0x68000C43, 0x00000416, 0x0000000A },
- [DRAM_32MB] = { 0x23918250, 0x222E2322, 0x40000A43, 0x00000416, 0x00000006 },
- [DRAM_64MB] = { 0x239A2250, 0x22322322, 0x40000A43, 0x00000416, 0x00000008 },
- [DRAM_128MB] = { 0x2392A250, 0x22362322, 0x40000A43, 0x00000416, 0x00000008 },
- [DRAM_256MB] = { 0x24140250, 0x223A2322, 0x40000A43, 0x00000416, 0x00000008 },
- void __iomem *sysc = ioremap_nocache(SYSCTL_BASE, SYSCTL_SIZE);
- if (assert)
- else
- void __iomem *sysc;
- bool lspd = false;
- int ddr_type, aux;
- struct mc_ddr_init_param param;
- sysc = ioremap_nocache(SYSCTL_BASE, SYSCTL_SIZE);
- ddr_type = (readl(sysc + SYSCTL_SYSCFG0_REG) & DRAM_TYPE_M)
>> DRAM_TYPE_S;
- aux = readl(sysc + SYSCTL_CPLL_CFG1_REG) &
- if (aux == CPU_CLK_AUX1 || aux == CPU_CLK_AUX0)
lspd = true;
- mt7620_memc_reset(1);
- __udelay(200);
- param.memc = ioremap_nocache(MEMCTL_BASE, MEMCTL_SIZE);
- param.dq_dly = DDR2_DQ_DLY;
- param.dqs_dly = DDR2_DQS_DLY;
- param.mc_reset = mt7620_memc_reset;
- param.memsize = 0;
- param.bus_width = 0;
- if (ddr_type == DRAM_DDR1) {
if (lspd)
else
ddr1_init(¶m);
- } else if (ddr_type == DRAM_DDR2) {
if (lspd)
else
ddr2_init(¶m);
- } else {
sdr_init(¶m);
- "SDRAM", "DDR", "DDR2", "SDRAM"
- [1] = "NAND 4-cycles 2KB-page",
- [2] = "SPI-NOR 3-Byte Addr",
- [3] = "SPI-NOR 4-Byte Addr",
- [10] = "NAND 4-cycles 512B-page",
- [11] = "NAND 5-cycles 2KB-page",
- [12] = "NAND 3-cycles 512B-page",
- u32 pllmul = CONFIG_CPU_FREQ_MULTI;
- /* Make sure the pll multiplier is valid */
- if (pllmul > 7)
pllmul = 7;
- /* Set init CPU clock to 480MHz */
- clrsetbits_32(sysc + SYSCTL_CPLL_CFG1_REG, CPU_CLK_AUX1, CPU_CLK_AUX0);
- /* Enable software control of CPU PLL */
- setbits_32(sysc + SYSCTL_CPLL_CFG0_REG, CPLL_SW_CFG);
- /* CPU PLL power down */
- setbits_32(sysc + SYSCTL_CPLL_CFG1_REG, CPLL_PD);
- /* PLL configuration */
- clrsetbits_32(sysc + SYSCTL_CPLL_CFG0_REG, PLL_MULT_RATIO_M |
- /* CPU PLL power up */
- clrbits_32(sysc + SYSCTL_CPLL_CFG1_REG, CPLL_PD);
- /* Wait for CPU PLL locked */
- while (!(readl(sysc + SYSCTL_CPLL_CFG1_REG) & CPLL_LD))
- /* Set final CPU clock source */
- clrbits_32(sysc + SYSCTL_CPLL_CFG1_REG, CPU_CLK_AUX1 | CPU_CLK_AUX0);
- /* Adjust CPU clock */
- clrsetbits_32(sysc + SYSCTL_CPU_SYS_CLKCFG_REG,
- u32 cpu_clk;
- cpu_pll_init();
- mt7620_get_clks(&cpu_clk, NULL, NULL);
- gd->arch.timer_freq = cpu_clk / 2;
- mt7620_dram_init();
- u32 val, multi, div, fdiv, ffrac, dram_type, sys_div;
- u32 cpu_freq, xtal_freq;
- static const u32 div_ratio_table[] = {2, 3, 4, 8};
- val = readl(sysc + SYSCTL_SYSCFG0_REG);
- dram_type = (val & DRAM_TYPE_M) >> DRAM_TYPE_S;
- if (val & XTAL_FREQ_SEL)
- else
- val = readl(sysc + SYSCTL_CPLL_CFG1_REG);
- if (val & CPU_CLK_AUX1) {
- } else if (val & CPU_CLK_AUX0) {
- } else {
} else {
- val = readl(sysc + SYSCTL_CUR_CLK_STS_REG);
- ffrac = (val & CUR_CPU_FFRAC_M) >> CUR_CPU_FFRAC_S;
- fdiv = (val & CUR_CPU_FDIV_M) >> CUR_CPU_FDIV_S;
- cpu_freq = (cpu_freq * ffrac) / fdiv;
- switch (dram_type) {
- case DRAM_SDRAM_E1:
sys_div = 4;
break;
- case DRAM_DDR1:
- case DRAM_DDR2:
sys_div = 3;
break;
- case DRAM_SDRAM:
sys_div = 5;
break;
- if (cpu_clk)
- if (sys_clk)
- if (xtal_clk)
- u32 cpu_clk, bus_clk, xtal_clk;
- u32 val, ver, eco, pkg, dram, chipmode;
- const char *bootdev;
- val = readl(sysc + SYSCTL_CHIP_REV_ID_REG);
- ver = (val & VER_M) >> VER_S;
- eco = (val & ECO_M) >> ECO_S;
- pkg = !!(val & PKG_ID);
- dram = (val & DRAM_TYPE_M) >> DRAM_TYPE_S;
- chipmode = (val & CHIP_MODE_M) >> CHIP_MODE_S;
- bootdev = boot_mode[chipmode];
- if (!bootdev)
- printf("CPU: MediaTek MT7620%c ver:%u eco:%u\n",
- printf("Boot: %s, %s\n", dram_type[dram], bootdev);
- mt7620_get_clks(&cpu_clk, &bus_clk, &xtal_clk);
- /* Set final timer frequency */
- printf("Clock: CPU: %uMHz, Bus: %uMHz, XTAL: %uMHz\n",
- return gd->arch.timer_freq;
- while (1)
- .set noreorder
- /* Save ra and do real lowlevel initialization */
- move s0, ra
- Use SRAM from 802.11n MAC/BBP, 16KiB (0x10184000 ~ 0x10187fff)
- NOTE: non-word operations may fail in this SRAM.
- Use it as stack only for CPU/DRAM init which only has word operations.
- PTR_LI sp, 0xb0187f00
- /* We still need a temporary gd for udelay */
- PTR_SUBU \
- li t0, -16
- and sp, sp, t0 # force 16 byte alignment
- move k0, sp # save gd pointer
- move fp, sp
- /* Clear gd */
- move t0, k0
+1:
- PTR_S zero, 0(t0)
- PTR_ADDIU t0, PTRSIZE
- blt t0, t1, 1b
nop
- /* Do CPU & DRAM initialization */
- PTR_LA t9, mt7620_init
- jalr t9
nop
- /* Restore ra */
- move ra, s0
- jr ra
nop
- END(lowlevel_init)
- void __iomem *base = ioremap_nocache(SYSCTL_BASE, SYSCTL_SIZE);
- clrsetbits_32(base + SYSCTL_GPIOMODE_REG, UARTF_SHARE_MODE_M,
+#else
- clrbits_32(base + SYSCTL_GPIOMODE_REG, UARTL_GPIO_MODE);
+#endif +}
- Misc driver for manipulating System control registers
- void __iomem *base;
int size)
- struct mt7620_sysc_priv *priv = dev_get_priv(dev);
- u32 val;
- if (offset % sizeof(u32) || size != sizeof(u32) ||
return -EINVAL;
- val = readl(priv->base + offset);
- if (buf)
*(u32 *)buf = val;
int size)
- u32 val;
return -EINVAL;
- val = *(u32 *)buf;
- writel(val, priv->base + offset);
void *buf)
- struct mt7620_sysc_chip_rev *chip_rev;
- struct mt7620_sysc_clks *clks;
- u32 val, shift;
- if (!buf)
return -EINVAL;
- switch (request) {
- case MT7620_SYSC_IOCTL_GET_CLK:
clks = buf;
&clks->xtal_clk);
else
- case MT7620_SYSC_IOCTL_GET_CHIP_REV:
chip_rev = buf;
- case MT7620_SYSC_IOCTL_SET_GE1_MODE:
- case MT7620_SYSC_IOCTL_SET_GE2_MODE:
val = *(u32 *)buf;
return -EINVAL;
shift = GE1_MODE_S;
else
shift = GE2_MODE_S;
- case MT7620_SYSC_IOCTL_SET_USB_MODE:
val = *(u32 *)buf;
val = 0;
- case MT7620_SYSC_IOCTL_SET_PCIE_MODE:
val = *(u32 *)buf;
val = 0;
val = PCIE_RC_MODE;
PCIE_RC_MODE, val);
- default:
return -EINVAL;
- priv->base = dev_remap_addr_index(dev, 0);
- if (!priv->base) {
return -EINVAL;
- .read = mt7620_sysc_read,
- .write = mt7620_sysc_write,
- .ioctl = mt7620_sysc_ioctl,
- { .compatible = "mediatek,mt7620-sysc" },
- .name = "mt7620_sysc",
- .id = UCLASS_MISC,
- .of_match = mt7620_sysc_ids,
- .probe = mt7620_sysc_probe,
- .ops = &mt7620_sysc_ops,
- .priv_auto_alloc_size = sizeof(struct mt7620_sysc_priv),
- .flags = DM_FLAG_PRE_RELOC,
Viele Grüße, Stefan
The mt7620_rfb board supports integrated 10/100M PHYs plus two external giga PHYs. It also has 8MB SPI-NOR, mini PCI-e x1 slot, SDHC and USB.
The mt7620_mt7530_rfb boards supports an external MT7530 giga switch and a 16MB SPI-NOR flash.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v3 changes: none v2 changes: remove use of common.h --- arch/mips/dts/Makefile | 2 + arch/mips/dts/mediatek,mt7620-mt7530-rfb.dts | 100 +++++++++++++++++++ arch/mips/dts/mediatek,mt7620-rfb.dts | 97 ++++++++++++++++++ arch/mips/mach-mtmips/mt7620/Kconfig | 17 ++++ board/mediatek/mt7620/Kconfig | 12 +++ board/mediatek/mt7620/MAINTAINERS | 9 ++ board/mediatek/mt7620/Makefile | 3 + board/mediatek/mt7620/board.c | 6 ++ configs/mt7620_mt7530_rfb_defconfig | 58 +++++++++++ configs/mt7620_rfb_defconfig | 76 ++++++++++++++ 10 files changed, 380 insertions(+) create mode 100644 arch/mips/dts/mediatek,mt7620-mt7530-rfb.dts create mode 100644 arch/mips/dts/mediatek,mt7620-rfb.dts create mode 100644 board/mediatek/mt7620/Kconfig create mode 100644 board/mediatek/mt7620/MAINTAINERS create mode 100644 board/mediatek/mt7620/Makefile create mode 100644 board/mediatek/mt7620/board.c create mode 100644 configs/mt7620_mt7530_rfb_defconfig create mode 100644 configs/mt7620_rfb_defconfig
diff --git a/arch/mips/dts/Makefile b/arch/mips/dts/Makefile index e82f96d4e4..7c42923134 100644 --- a/arch/mips/dts/Makefile +++ b/arch/mips/dts/Makefile @@ -14,6 +14,8 @@ dtb-$(CONFIG_BOARD_COMTREND_CT5361) += comtrend,ct-5361.dtb dtb-$(CONFIG_BOARD_COMTREND_VR3032U) += comtrend,vr-3032u.dtb dtb-$(CONFIG_BOARD_COMTREND_WAP5813N) += comtrend,wap-5813n.dtb dtb-$(CONFIG_BOARD_HUAWEI_HG556A) += huawei,hg556a.dtb +dtb-$(CONFIG_BOARD_MT7620_RFB) += mediatek,mt7620-rfb.dtb +dtb-$(CONFIG_BOARD_MT7620_MT7530_RFB) += mediatek,mt7620-mt7530-rfb.dtb dtb-$(CONFIG_BOARD_MT7628_RFB) += mediatek,mt7628-rfb.dtb dtb-$(CONFIG_BOARD_GARDENA_SMART_GATEWAY_MT7688) += gardena-smart-gateway-mt7688.dtb dtb-$(CONFIG_BOARD_LINKIT_SMART_7688) += linkit-smart-7688.dtb diff --git a/arch/mips/dts/mediatek,mt7620-mt7530-rfb.dts b/arch/mips/dts/mediatek,mt7620-mt7530-rfb.dts new file mode 100644 index 0000000000..8bc3b1673a --- /dev/null +++ b/arch/mips/dts/mediatek,mt7620-mt7530-rfb.dts @@ -0,0 +1,100 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020 MediaTek Inc. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +/dts-v1/; + +#include <dt-bindings/gpio/gpio.h> +#include "mt7620.dtsi" + +/ { + compatible = "mediatek,mt7620-mt7530-rfb", "mediatek,mt7620-soc"; + model = "MediaTek MT7620-MT7530 RFB (MTKC712)"; + + aliases { + serial0 = &uartlite; + spi0 = &spi0; + }; + + chosen { + stdout-path = &uartlite; + }; +}; + +&uartlite { + status = "okay"; +}; + +&pinctrl { + state_default: pin_state { + pleds { + groups = "ephy led", "wled"; + function = "led"; + }; + + gpios { + groups = "pa", "uartf"; + function = "gpio"; + }; + }; + + gsw_pins: gsw_pins { + mdio { + groups = "mdio"; + function = "mdio"; + }; + + rgmii1 { + groups = "rgmii1"; + function = "rgmii1"; + }; + }; +}; + +&spi0 { + status = "okay"; + num-cs = <2>; + + spi-flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "jedec,spi-nor"; + spi-max-frequency = <25000000>; + reg = <0>; + }; +}; + +&gpio0 { + pa0_pull_low { + gpio-hog; + output-low; + gpios = <20 GPIO_ACTIVE_HIGH>; + }; + + pa1_pull_low { + gpio-hog; + output-low; + gpios = <21 GPIO_ACTIVE_HIGH>; + }; +}; + +ð { + status = "okay"; + + pinctrl-names = "default"; + pinctrl-0 = <&gsw_pins>; + + port5 { + phy-mode = "rgmii"; + phy-addr = <5>; + fixed-link { + full-duplex; + speed = <1000>; + mediatek,mt7530; + mediatek,mt7530-reset = <&gpio0 10 GPIO_ACTIVE_HIGH>; + }; + }; +}; diff --git a/arch/mips/dts/mediatek,mt7620-rfb.dts b/arch/mips/dts/mediatek,mt7620-rfb.dts new file mode 100644 index 0000000000..616903e554 --- /dev/null +++ b/arch/mips/dts/mediatek,mt7620-rfb.dts @@ -0,0 +1,97 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020 MediaTek Inc. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +/dts-v1/; + +#include <dt-bindings/gpio/gpio.h> +#include "mt7620.dtsi" + +/ { + compatible = "mediatek,mt7620-rfb", "mediatek,mt7620-soc"; + model = "MediaTek MT7620 RFB (WS2120)"; + + aliases { + serial0 = &uartlite; + spi0 = &spi0; + }; + + chosen { + stdout-path = &uartlite; + }; +}; + +&uartlite { + status = "okay"; +}; + +&pinctrl { + state_default: pin_state { + pleds { + groups = "ephy led", "wled"; + function = "led"; + }; + + gpios { + groups = "uartf"; + function = "gpio"; + }; + }; + + gsw_pins: gsw_pins { + mdio { + groups = "mdio"; + function = "mdio"; + }; + + rgmii1 { + groups = "rgmii1"; + function = "rgmii1"; + }; + + rgmii2 { + groups = "rgmii2"; + function = "rgmii2"; + }; + }; +}; + +&spi0 { + status = "okay"; + num-cs = <2>; + + spi-flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "jedec,spi-nor"; + spi-max-frequency = <25000000>; + reg = <0>; + }; +}; + +ð { + status = "okay"; + + pinctrl-names = "default"; + pinctrl-0 = <&gsw_pins>; + + port4 { + phy-mode = "rgmii"; + phy-addr = <4>; + }; + + port5 { + phy-mode = "rgmii"; + phy-addr = <5>; + }; +}; + +&mmc { + bus-width = <4>; + cap-sd-highspeed; + + status = "okay"; +}; diff --git a/arch/mips/mach-mtmips/mt7620/Kconfig b/arch/mips/mach-mtmips/mt7620/Kconfig index aa7cf1d3c1..5db83eb9d9 100644 --- a/arch/mips/mach-mtmips/mt7620/Kconfig +++ b/arch/mips/mach-mtmips/mt7620/Kconfig @@ -7,6 +7,21 @@ config DEBUG_UART_BOARD_INIT choice prompt "Board select"
+config BOARD_MT7620_RFB + bool "MediaTek MT7620 RFB" + help + The reference design of MT7620A (WS2120). The board has 64 MiB DDR2, + 8 MiB SPI-NOR flash, 1 built-in 6 port switch (two GE PHYs and five + FE PHYs,one port can be configured to use either FE PHY or GE PHY), + 1 UART, 1 USB host, 1 SDXC, 1 PCIe socket and JTAG pins. + +config BOARD_MT7620_MT7530_RFB + bool "MediaTek MT7620-MT7530 RFB" + help + The reference design of MT7620DA (MTKC712). The board has 64 MiB + intergrated DDR2 KGD, 16 MiB SPI-NOR flash, an external 5-port giga + switch MT7530 and 1 UART. + endchoice
choice @@ -51,4 +66,6 @@ config CPU_FREQ_MULTI default 6 if CPU_FREQ_600MHZ default 7 if CPU_FREQ_620MHZ
+source "board/mediatek/mt7620/Kconfig" + endif diff --git a/board/mediatek/mt7620/Kconfig b/board/mediatek/mt7620/Kconfig new file mode 100644 index 0000000000..b9137adcc9 --- /dev/null +++ b/board/mediatek/mt7620/Kconfig @@ -0,0 +1,12 @@ +if BOARD_MT7620_RFB || BOARD_MT7620_MT7530_RFB + +config SYS_BOARD + default "mt7620" + +config SYS_VENDOR + default "mediatek" + +config SYS_CONFIG_NAME + default "mt7620" + +endif diff --git a/board/mediatek/mt7620/MAINTAINERS b/board/mediatek/mt7620/MAINTAINERS new file mode 100644 index 0000000000..05db777ced --- /dev/null +++ b/board/mediatek/mt7620/MAINTAINERS @@ -0,0 +1,9 @@ +MT7620_RFB BOARD +M: Weijie Gao weijie.gao@mediatek.com +S: Maintained +F: board/mediatek/mt7620 +F: include/configs/mt7620.h +F: configs/mt7620_rfb_defconfig +F: configs/mt7620_mt7530_rfb_defconfig +F: arch/mips/dts/mediatek,mt7620-rfb.dts +F: arch/mips/dts/mediatek,mt7620-mt7530-rfb.dts diff --git a/board/mediatek/mt7620/Makefile b/board/mediatek/mt7620/Makefile new file mode 100644 index 0000000000..db129c5aba --- /dev/null +++ b/board/mediatek/mt7620/Makefile @@ -0,0 +1,3 @@ +# SPDX-License-Identifier: GPL-2.0 + +obj-y += board.o diff --git a/board/mediatek/mt7620/board.c b/board/mediatek/mt7620/board.c new file mode 100644 index 0000000000..119b8fc9e5 --- /dev/null +++ b/board/mediatek/mt7620/board.c @@ -0,0 +1,6 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020 MediaTek Inc. All Rights Reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ diff --git a/configs/mt7620_mt7530_rfb_defconfig b/configs/mt7620_mt7530_rfb_defconfig new file mode 100644 index 0000000000..341d86838c --- /dev/null +++ b/configs/mt7620_mt7530_rfb_defconfig @@ -0,0 +1,58 @@ +CONFIG_MIPS=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x30000 +CONFIG_ENV_SECT_SIZE=0x10000 +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_SYS_MALLOC_F_LEN=0x40000 +CONFIG_SPL=y +CONFIG_DEBUG_UART_BASE=0xb0000c00 +CONFIG_DEBUG_UART_CLOCK=40000000 +CONFIG_ARCH_MTMIPS=y +CONFIG_BOARD_MT7620_MT7530_RFB=y +CONFIG_DEFAULT_DEVICE_TREE="mediatek,mt7620-mt7530-rfb" +CONFIG_RESTORE_EXCEPTION_VECTOR_BASE=y +CONFIG_MIPS_BOOT_FDT=y +CONFIG_DEBUG_UART=y +CONFIG_FIT=y +# CONFIG_ARCH_FIXUP_FDT_MEMORY is not set +CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_NOR_SUPPORT=y +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_CRC32 is not set +# CONFIG_CMD_DM is not set +CONFIG_CMD_GPIO=y +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_SPI=y +# CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y +# CONFIG_CMD_MDIO is not set +# CONFIG_PARTITIONS is not set +CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clocks clock-names interrupt-parent interrupts resets reset-names" +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPL_DM=y +# CONFIG_SIMPLE_BUS is not set +# CONFIG_SPL_SIMPLE_BUS is not set +CONFIG_GPIO_HOG=y +# CONFIG_INPUT is not set +CONFIG_SPI_FLASH_SFDP_SUPPORT=y +CONFIG_SPI_FLASH_EON=y +CONFIG_SPI_FLASH_GIGADEVICE=y +CONFIG_SPI_FLASH_ISSI=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_SPI_FLASH_XMC=y +CONFIG_MT7620_ETH=y +CONFIG_SPECIFY_CONSOLE_INDEX=y +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SPI=y +CONFIG_MT7620_SPI=y +CONFIG_LZMA=y +CONFIG_SPL_LZMA=y diff --git a/configs/mt7620_rfb_defconfig b/configs/mt7620_rfb_defconfig new file mode 100644 index 0000000000..9829371513 --- /dev/null +++ b/configs/mt7620_rfb_defconfig @@ -0,0 +1,76 @@ +CONFIG_MIPS=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x30000 +CONFIG_ENV_SECT_SIZE=0x10000 +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_SYS_MALLOC_F_LEN=0x40000 +CONFIG_SPL=y +CONFIG_DEBUG_UART_BASE=0xb0000c00 +CONFIG_DEBUG_UART_CLOCK=40000000 +CONFIG_ARCH_MTMIPS=y +CONFIG_DEFAULT_DEVICE_TREE="mediatek,mt7620-rfb" +CONFIG_RESTORE_EXCEPTION_VECTOR_BASE=y +CONFIG_MIPS_BOOT_FDT=y +CONFIG_DEBUG_UART=y +CONFIG_FIT=y +# CONFIG_ARCH_FIXUP_FDT_MEMORY is not set +CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_NOR_SUPPORT=y +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_CRC32 is not set +# CONFIG_CMD_DM is not set +CONFIG_CMD_GPIO=y +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y +# CONFIG_CMD_NFS is not set +CONFIG_CMD_MII=y +# CONFIG_CMD_MDIO is not set +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_ISO_PARTITION is not set +CONFIG_EFI_PARTITION=y +# CONFIG_SPL_EFI_PARTITION is not set +CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clocks clock-names interrupt-parent interrupts resets reset-names" +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPL_DM=y +# CONFIG_SIMPLE_BUS is not set +# CONFIG_SPL_SIMPLE_BUS is not set +# CONFIG_SPL_BLK is not set +CONFIG_GPIO_HOG=y +# CONFIG_INPUT is not set +CONFIG_MMC=y +CONFIG_DM_MMC=y +# CONFIG_MMC_QUIRKS is not set +# CONFIG_MMC_HW_PARTITIONING is not set +CONFIG_MMC_MTK=y +CONFIG_SPI_FLASH_SFDP_SUPPORT=y +CONFIG_SPI_FLASH_EON=y +CONFIG_SPI_FLASH_GIGADEVICE=y +CONFIG_SPI_FLASH_ISSI=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_SPI_FLASH_XMC=y +CONFIG_MT7620_ETH=y +CONFIG_PHY=y +CONFIG_MT7620_USB_PHY=y +CONFIG_SPECIFY_CONSOLE_INDEX=y +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SPI=y +CONFIG_MT7620_SPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_LZMA=y +CONFIG_SPL_LZMA=y
Thanks, Stefan
+/dts-v1/;
- compatible = "mediatek,mt7620-mt7530-rfb", "mediatek,mt7620-soc";
- model = "MediaTek MT7620-MT7530 RFB (MTKC712)";
- aliases {
spi0 = &spi0;
- chosen {
+&uartlite {
- status = "okay";
+&pinctrl {
- state_default: pin_state {
pleds {
function = "led";
gpios {
function = "gpio";
- gsw_pins: gsw_pins {
mdio {
groups = "mdio";
function = "mdio";
rgmii1 {
groups = "rgmii1";
+&spi0 {
- status = "okay";
- num-cs = <2>;
- spi-flash@0 {
#size-cells = <1>;
reg = <0>;
+&gpio0 {
- pa0_pull_low {
gpio-hog;
output-low;
- pa1_pull_low {
gpio-hog;
output-low;
+ð {
- status = "okay";
- pinctrl-names = "default";
- pinctrl-0 = <&gsw_pins>;
- port5 {
phy-mode = "rgmii";
phy-addr = <5>;
fixed-link {
full-duplex;
speed = <1000>;
mediatek,mt7530;
+/dts-v1/;
- compatible = "mediatek,mt7620-rfb", "mediatek,mt7620-soc";
- model = "MediaTek MT7620 RFB (WS2120)";
- aliases {
spi0 = &spi0;
- chosen {
+&uartlite {
- status = "okay";
+&pinctrl {
pleds {
function = "led";
gpios {
groups = "uartf";
function = "gpio";
mdio {
groups = "mdio";
function = "mdio";
rgmii1 {
groups = "rgmii1";
rgmii2 {
groups = "rgmii2";
+&spi0 {
- status = "okay";
- num-cs = <2>;
- spi-flash@0 {
#size-cells = <1>;
reg = <0>;
+ð {
- status = "okay";
- port4 {
phy-mode = "rgmii";
phy-addr = <4>;
- port5 {
phy-mode = "rgmii";
phy-addr = <5>;
+&mmc {
- bus-width = <4>;
- cap-sd-highspeed;
- status = "okay";
- bool "MediaTek MT7620 RFB"
- help
help
endchoice
choice
- endif
+config SYS_BOARD
- default "mt7620"
+config SYS_VENDOR
- default "mediatek"
- default "mt7620"
Viele Grüße, Stefan
Since mt7620 is added into Kconfig, the CONFIG_SOC_MT7628=y which is omitted by default must be added back, otherwise make xxx_defconfig for these boards will be configured for mt7620 platform.
Reviewed-by: Stefan Roese sr@denx.de Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v3 changes: none v2 changes: none --- configs/gardena-smart-gateway-mt7688_defconfig | 1 + configs/linkit-smart-7688_defconfig | 1 + configs/mt7628_rfb_defconfig | 1 + configs/vocore2_defconfig | 1 + 4 files changed, 4 insertions(+)
diff --git a/configs/gardena-smart-gateway-mt7688_defconfig b/configs/gardena-smart-gateway-mt7688_defconfig index 001a66d0f6..c03123f6e4 100644 --- a/configs/gardena-smart-gateway-mt7688_defconfig +++ b/configs/gardena-smart-gateway-mt7688_defconfig @@ -12,6 +12,7 @@ CONFIG_SPL=y CONFIG_SYS_BOOTCOUNT_SINGLEWORD=y CONFIG_ENV_OFFSET_REDUND=0xB0000 CONFIG_ARCH_MTMIPS=y +CONFIG_SOC_MT7628=y CONFIG_DEFAULT_DEVICE_TREE="gardena-smart-gateway-mt7688" CONFIG_RESTORE_EXCEPTION_VECTOR_BASE=y # CONFIG_MIPS_BOOT_ENV_LEGACY is not set diff --git a/configs/linkit-smart-7688_defconfig b/configs/linkit-smart-7688_defconfig index 437000b4c7..dd2524e4ec 100644 --- a/configs/linkit-smart-7688_defconfig +++ b/configs/linkit-smart-7688_defconfig @@ -9,6 +9,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_SYS_MALLOC_F_LEN=0x40000 CONFIG_SPL=y CONFIG_ARCH_MTMIPS=y +CONFIG_SOC_MT7628=y CONFIG_BOARD_LINKIT_SMART_7688=y CONFIG_DEFAULT_DEVICE_TREE="linkit-smart-7688" CONFIG_RESTORE_EXCEPTION_VECTOR_BASE=y diff --git a/configs/mt7628_rfb_defconfig b/configs/mt7628_rfb_defconfig index 69025728b2..831e54e9f3 100644 --- a/configs/mt7628_rfb_defconfig +++ b/configs/mt7628_rfb_defconfig @@ -9,6 +9,7 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_SYS_MALLOC_F_LEN=0x40000 CONFIG_SPL=y CONFIG_ARCH_MTMIPS=y +CONFIG_SOC_MT7628=y CONFIG_BOARD_MT7628_RFB=y CONFIG_DEFAULT_DEVICE_TREE="mediatek,mt7628-rfb" CONFIG_RESTORE_EXCEPTION_VECTOR_BASE=y diff --git a/configs/vocore2_defconfig b/configs/vocore2_defconfig index acb9abf1be..e255829366 100644 --- a/configs/vocore2_defconfig +++ b/configs/vocore2_defconfig @@ -10,6 +10,7 @@ CONFIG_SPL_SYS_MALLOC_F_LEN=0x40000 CONFIG_SPL=y CONFIG_SYS_BOOTCOUNT_SINGLEWORD=y CONFIG_ARCH_MTMIPS=y +CONFIG_SOC_MT7628=y CONFIG_BOARD_VOCORE2=y CONFIG_DEFAULT_DEVICE_TREE="vocore_vocore2" CONFIG_RESTORE_EXCEPTION_VECTOR_BASE=y
This patch adds uart support for MediaTek MT7620 and earlier SoCs.
The UART used by MT7620 is incompatible with the ns16550a driver. All registers of this UART have different addresses. A special 16-bit register for Divisor Latch is used to set the baudrate instead of the original two 8-bit registers (DLL and DLM).
The driver supports of-platdata which is useful for tiny SPL.
Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v3 changes: none v2 changes: replace non-DM code with of-platdata --- drivers/serial/Kconfig | 20 +++ drivers/serial/Makefile | 1 + drivers/serial/serial.c | 2 + drivers/serial/serial_mt7620.c | 246 +++++++++++++++++++++++++++++++++ 4 files changed, 269 insertions(+) create mode 100644 drivers/serial/serial_mt7620.c
diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig index b4805a2e4e..44fff8a3cd 100644 --- a/drivers/serial/Kconfig +++ b/drivers/serial/Kconfig @@ -401,6 +401,16 @@ config DEBUG_UART_MTK driver will be available until the real driver model serial is running.
+config DEBUG_UART_MT7620 + bool "UART driver for MediaTek MT7620 and earlier SoCs" + depends on MT7620_SERIAL + help + Select this to enable a debug UART using the UART driver for + MediaTek MT7620 and earlier SoCs. + You will need to provide parameters to make this work. The + driver will be available until the real driver model serial is + running. + endchoice
config DEBUG_UART_BASE @@ -817,6 +827,16 @@ config MTK_SERIAL The High-speed UART is compatible with the ns16550a UART and have its own high-speed registers.
+config MT7620_SERIAL + bool "UART driver for MediaTek MT7620 and earlier SoCs" + depends on DM_SERIAL + help + Select this to enable UART support for MediaTek MT7620 and earlier + SoCs. This driver uses driver model and requires a device tree + binding to operate. + The UART driver for MediaTek MT7620 and earlier SoCs is *NOT* + compatible with the ns16550a UART. + config MPC8XX_CONS bool "Console driver for MPC8XX" depends on MPC8xx diff --git a/drivers/serial/Makefile b/drivers/serial/Makefile index 25f7f8d342..0c3810f5d5 100644 --- a/drivers/serial/Makefile +++ b/drivers/serial/Makefile @@ -69,6 +69,7 @@ obj-$(CONFIG_NULLDEV_SERIAL) += serial_nulldev.o obj-$(CONFIG_OWL_SERIAL) += serial_owl.o obj-$(CONFIG_OMAP_SERIAL) += serial_omap.o obj-$(CONFIG_MTK_SERIAL) += serial_mtk.o +obj-$(CONFIG_MT7620_SERIAL) += serial_mt7620.o obj-$(CONFIG_SIFIVE_SERIAL) += serial_sifive.o obj-$(CONFIG_XEN_SERIAL) += serial_xen.o
diff --git a/drivers/serial/serial.c b/drivers/serial/serial.c index 355659ba05..1546f41e42 100644 --- a/drivers/serial/serial.c +++ b/drivers/serial/serial.c @@ -127,6 +127,7 @@ serial_initfunc(pl01x_serial_initialize); serial_initfunc(pxa_serial_initialize); serial_initfunc(sh_serial_initialize); serial_initfunc(mtk_serial_initialize); +serial_initfunc(mt7620_serial_initialize);
/** * serial_register() - Register serial driver with serial driver core @@ -181,6 +182,7 @@ int serial_initialize(void) pxa_serial_initialize(); sh_serial_initialize(); mtk_serial_initialize(); + mt7620_serial_initialize();
serial_assign(default_serial_console()->name);
diff --git a/drivers/serial/serial_mt7620.c b/drivers/serial/serial_mt7620.c new file mode 100644 index 0000000000..4f6b5de4cf --- /dev/null +++ b/drivers/serial/serial_mt7620.c @@ -0,0 +1,246 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * UART driver for MediaTek MT7620 and earlier SoCs + * + * Copyright (C) 2020 MediaTek Inc. + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#include <clk.h> +#include <div64.h> +#include <dm.h> +#include <errno.h> +#include <log.h> +#include <reset.h> +#include <serial.h> +#include <watchdog.h> +#include <asm/io.h> +#include <asm/types.h> +#include <asm/addrspace.h> +#include <dm/device_compat.h> +#include <linux/err.h> + +#if CONFIG_IS_ENABLED(OF_PLATDATA) +#include <dt-structs.h> +#endif + +struct mt7620_serial_regs { + u32 rbr; + u32 thr; + u32 ier; + u32 iir; + u32 fcr; + u32 lcr; + u32 mcr; + u32 lsr; + u32 msr; + u32 scratch; + u32 dl; + u32 dll; + u32 dlm; + u32 ifctl; +}; + +#define UART_LCR_WLS_8 0x03 /* 8 bit character length */ + +#define UART_LSR_DR 0x01 /* Data ready */ +#define UART_LSR_THRE 0x20 /* Xmit holding register empty */ +#define UART_LSR_TEMT 0x40 /* Xmitter empty */ + +#define UART_MCR_DTR 0x01 /* DTR */ +#define UART_MCR_RTS 0x02 /* RTS */ + +#define UART_FCR_FIFO_EN 0x01 /* Fifo enable */ +#define UART_FCR_RXSR 0x02 /* Receiver soft reset */ +#define UART_FCR_TXSR 0x04 /* Transmitter soft reset */ + +#define UART_MCRVAL (UART_MCR_DTR | \ + UART_MCR_RTS) + +/* Clear & enable FIFOs */ +#define UART_FCRVAL (UART_FCR_FIFO_EN | \ + UART_FCR_RXSR | \ + UART_FCR_TXSR) + +struct mt7620_serial_plat { +#if CONFIG_IS_ENABLED(OF_PLATDATA) + struct dtd_serial_mt7620 dtplat; +#endif + + struct mt7620_serial_regs __iomem *regs; + u32 clock; +}; + +static void _mt7620_serial_setbrg(struct mt7620_serial_plat *plat, int baud) +{ + u32 quot; + + /* set divisor */ + quot = DIV_ROUND_CLOSEST(plat->clock, 16 * baud); + writel(quot, &plat->regs->dl); + + /* set character length and stop bits */ + writel(UART_LCR_WLS_8, &plat->regs->lcr); +} + +static int mt7620_serial_setbrg(struct udevice *dev, int baudrate) +{ + struct mt7620_serial_plat *plat = dev_get_platdata(dev); + + _mt7620_serial_setbrg(plat, baudrate); + + return 0; +} + +static int mt7620_serial_putc(struct udevice *dev, const char ch) +{ + struct mt7620_serial_plat *plat = dev_get_platdata(dev); + + if (!(readl(&plat->regs->lsr) & UART_LSR_THRE)) + return -EAGAIN; + + writel(ch, &plat->regs->thr); + + if (ch == '\n') + WATCHDOG_RESET(); + + return 0; +} + +static int mt7620_serial_getc(struct udevice *dev) +{ + struct mt7620_serial_plat *plat = dev_get_platdata(dev); + + if (!(readl(&plat->regs->lsr) & UART_LSR_DR)) + return -EAGAIN; + + return readl(&plat->regs->rbr); +} + +static int mt7620_serial_pending(struct udevice *dev, bool input) +{ + struct mt7620_serial_plat *plat = dev_get_platdata(dev); + + if (input) + return (readl(&plat->regs->lsr) & UART_LSR_DR) ? 1 : 0; + + return (readl(&plat->regs->lsr) & UART_LSR_THRE) ? 0 : 1; +} + +static int mt7620_serial_probe(struct udevice *dev) +{ + struct mt7620_serial_plat *plat = dev_get_platdata(dev); + +#if CONFIG_IS_ENABLED(OF_PLATDATA) + plat->regs = (void __iomem *)KSEG1ADDR(plat->dtplat.reg[0]); + plat->clock = plat->dtplat.clock_frequency; +#endif + + /* Disable interrupt */ + writel(0, &plat->regs->ier); + + writel(UART_MCRVAL, &plat->regs->mcr); + writel(UART_FCRVAL, &plat->regs->fcr); + + return 0; +} + +#if !CONFIG_IS_ENABLED(OF_PLATDATA) +static int mt7620_serial_ofdata_to_platdata(struct udevice *dev) +{ + struct mt7620_serial_plat *plat = dev_get_platdata(dev); + struct reset_ctl reset_uart; + struct clk clk; + int err; + + err = reset_get_by_index(dev, 0, &reset_uart); + if (!err) + reset_deassert(&reset_uart); + + plat->regs = dev_remap_addr_index(dev, 0); + if (!plat->regs) { + dev_err(dev, "mt7620_serial: unable to map UART registers\n"); + return -EINVAL; + } + + err = clk_get_by_index(dev, 0, &clk); + if (!err) { + err = clk_get_rate(&clk); + if (!IS_ERR_VALUE(err)) + plat->clock = err; + } else if (err != -ENOENT && err != -ENODEV && err != -ENOSYS) { + dev_err(dev, "mt7620_serial: failed to get clock\n"); + return err; + } + + if (!plat->clock) + plat->clock = dev_read_u32_default(dev, "clock-frequency", 0); + + if (!plat->clock) { + dev_err(dev, "mt7620_serial: clock not defined\n"); + return -EINVAL; + } + + return 0; +} + +static const struct udevice_id mt7620_serial_ids[] = { + { .compatible = "mediatek,mt7620-uart" }, + { } +}; +#endif + +static const struct dm_serial_ops mt7620_serial_ops = { + .putc = mt7620_serial_putc, + .pending = mt7620_serial_pending, + .getc = mt7620_serial_getc, + .setbrg = mt7620_serial_setbrg, +}; + +U_BOOT_DRIVER(serial_mt7620) = { + .name = "serial_mt7620", + .id = UCLASS_SERIAL, +#if !CONFIG_IS_ENABLED(OF_PLATDATA) + .of_match = mt7620_serial_ids, + .ofdata_to_platdata = mt7620_serial_ofdata_to_platdata, +#endif + .platdata_auto_alloc_size = sizeof(struct mt7620_serial_plat), + .probe = mt7620_serial_probe, + .ops = &mt7620_serial_ops, + .flags = DM_FLAG_PRE_RELOC, +}; + +U_BOOT_DRIVER_ALIAS(serial_mt7620, mediatek_mt7620_uart); + +#ifdef CONFIG_DEBUG_UART_MT7620 + +#include <debug_uart.h> + +static inline void _debug_uart_init(void) +{ + struct mt7620_serial_plat plat; + + plat.regs = (void *)CONFIG_DEBUG_UART_BASE; + plat.clock = CONFIG_DEBUG_UART_CLOCK; + + writel(0, &plat.regs->ier); + writel(UART_MCRVAL, &plat.regs->mcr); + writel(UART_FCRVAL, &plat.regs->fcr); + + _mt7620_serial_setbrg(&plat, CONFIG_BAUDRATE); +} + +static inline void _debug_uart_putc(int ch) +{ + struct mt7620_serial_regs __iomem *regs = + (void *)CONFIG_DEBUG_UART_BASE; + + while (!(readl(®s->lsr) & UART_LSR_THRE)) + ; + + writel(ch, ®s->thr); +} + +DEBUG_UART_FUNCS + +#endif
Thanks, Stefan
help
running.
endchoice
- bool "UART driver for MediaTek MT7620 and earlier SoCs"
- depends on DM_SERIAL
- help
binding to operate.
- config MPC8XX_CONS bool "Console driver for MPC8XX" depends on MPC8xx
- serial_register() - Register serial driver with serial driver core
- UART driver for MediaTek MT7620 and earlier SoCs
- u32 rbr;
- u32 thr;
- u32 ier;
- u32 iir;
- u32 fcr;
- u32 lcr;
- u32 mcr;
- u32 lsr;
- u32 msr;
- u32 scratch;
- u32 dl;
- u32 dll;
- u32 dlm;
- u32 ifctl;
UART_MCR_RTS)
UART_FCR_RXSR | \
UART_FCR_TXSR)
- struct dtd_serial_mt7620 dtplat;
- struct mt7620_serial_regs __iomem *regs;
- u32 clock;
- u32 quot;
- /* set divisor */
- quot = DIV_ROUND_CLOSEST(plat->clock, 16 * baud);
- writel(quot, &plat->regs->dl);
- /* set character length and stop bits */
- writel(UART_LCR_WLS_8, &plat->regs->lcr);
- struct mt7620_serial_plat *plat = dev_get_platdata(dev);
- _mt7620_serial_setbrg(plat, baudrate);
- if (!(readl(&plat->regs->lsr) & UART_LSR_THRE))
return -EAGAIN;
- writel(ch, &plat->regs->thr);
- if (ch == '\n')
WATCHDOG_RESET();
- if (!(readl(&plat->regs->lsr) & UART_LSR_DR))
return -EAGAIN;
- return readl(&plat->regs->rbr);
- if (input)
- return (readl(&plat->regs->lsr) & UART_LSR_THRE) ? 0 : 1;
- plat->regs = (void __iomem *)KSEG1ADDR(plat->dtplat.reg[0]);
- plat->clock = plat->dtplat.clock_frequency;
- /* Disable interrupt */
- writel(0, &plat->regs->ier);
- writel(UART_MCRVAL, &plat->regs->mcr);
- writel(UART_FCRVAL, &plat->regs->fcr);
- struct reset_ctl reset_uart;
- struct clk clk;
- int err;
- err = reset_get_by_index(dev, 0, &reset_uart);
- if (!err)
- plat->regs = dev_remap_addr_index(dev, 0);
- if (!plat->regs) {
return -EINVAL;
- err = clk_get_by_index(dev, 0, &clk);
- if (!err) {
plat->clock = err;
- } else if (err != -ENOENT && err != -ENODEV && err != -ENOSYS) {
return err;
- if (!plat->clock)
- if (!plat->clock) {
return -EINVAL;
- { .compatible = "mediatek,mt7620-uart" },
+}; +#endif
- .putc = mt7620_serial_putc,
- .pending = mt7620_serial_pending,
- .getc = mt7620_serial_getc,
- .setbrg = mt7620_serial_setbrg,
- .name = "serial_mt7620",
- .id = UCLASS_SERIAL,
- .of_match = mt7620_serial_ids,
- .ofdata_to_platdata = mt7620_serial_ofdata_to_platdata,
- .platdata_auto_alloc_size = sizeof(struct mt7620_serial_plat),
- .probe = mt7620_serial_probe,
- .ops = &mt7620_serial_ops,
- struct mt7620_serial_plat plat;
- plat.regs = (void *)CONFIG_DEBUG_UART_BASE;
- plat.clock = CONFIG_DEBUG_UART_CLOCK;
- writel(0, &plat.regs->ier);
- writel(UART_MCRVAL, &plat.regs->mcr);
- writel(UART_FCRVAL, &plat.regs->fcr);
- _mt7620_serial_setbrg(&plat, CONFIG_BAUDRATE);
- struct mt7620_serial_regs __iomem *regs =
- while (!(readl(®s->lsr) & UART_LSR_THRE))
- writel(ch, ®s->thr);
+DEBUG_UART_FUNCS
Viele Grüße, Stefan
This patch adds a clock driver for MediaTek MT7620 SoC. This driver provides clock gate control as well as getting clock frequency for CPU/SYS/XTAL and some peripherals.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v3 changes: none v2 changes: none --- drivers/clk/mtmips/Makefile | 1 + drivers/clk/mtmips/clk-mt7620.c | 159 +++++++++++++++++++++++++ include/dt-bindings/clock/mt7620-clk.h | 40 +++++++ 3 files changed, 200 insertions(+) create mode 100644 drivers/clk/mtmips/clk-mt7620.c create mode 100644 include/dt-bindings/clock/mt7620-clk.h
diff --git a/drivers/clk/mtmips/Makefile b/drivers/clk/mtmips/Makefile index e1938418da..732e7f2545 100644 --- a/drivers/clk/mtmips/Makefile +++ b/drivers/clk/mtmips/Makefile @@ -1,3 +1,4 @@ # SPDX-License-Identifier: GPL-2.0
+obj-$(CONFIG_SOC_MT7620) += clk-mt7620.o obj-$(CONFIG_SOC_MT7628) += clk-mt7628.o diff --git a/drivers/clk/mtmips/clk-mt7620.c b/drivers/clk/mtmips/clk-mt7620.c new file mode 100644 index 0000000000..44e4b53c21 --- /dev/null +++ b/drivers/clk/mtmips/clk-mt7620.c @@ -0,0 +1,159 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020 MediaTek Inc. All Rights Reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#include <clk-uclass.h> +#include <dm.h> +#include <dm/device_compat.h> +#include <dt-bindings/clock/mt7620-clk.h> +#include <misc.h> +#include <mach/mt7620-sysc.h> + +/* CLKCFG1 */ +#define CLKCFG1_REG 0x30 + +#define CLK_SRC_CPU -1 +#define CLK_SRC_CPU_D2 -2 +#define CLK_SRC_SYS -3 +#define CLK_SRC_XTAL -4 +#define CLK_SRC_PERI -5 + +struct mt7620_clk_priv { + struct udevice *dev; + struct udevice *sysc; + struct mt7620_sysc_clks clks; +}; + +static const int mt7620_clks[] = { + [CLK_SYS] = CLK_SRC_SYS, + [CLK_CPU] = CLK_SRC_CPU, + [CLK_XTAL] = CLK_SRC_XTAL, + [CLK_MIPS_CNT] = CLK_SRC_CPU_D2, + [CLK_UARTF] = CLK_SRC_PERI, + [CLK_UARTL] = CLK_SRC_PERI, + [CLK_SPI] = CLK_SRC_SYS, + [CLK_I2C] = CLK_SRC_PERI, + [CLK_I2S] = CLK_SRC_PERI, +}; + +static ulong mt7620_clk_get_rate(struct clk *clk) +{ + struct mt7620_clk_priv *priv = dev_get_priv(clk->dev); + + if (clk->id >= ARRAY_SIZE(mt7620_clks)) + return 0; + + switch (mt7620_clks[clk->id]) { + case CLK_SRC_CPU: + return priv->clks.cpu_clk; + case CLK_SRC_CPU_D2: + return priv->clks.cpu_clk / 2; + case CLK_SRC_SYS: + return priv->clks.sys_clk; + case CLK_SRC_XTAL: + return priv->clks.xtal_clk; + case CLK_SRC_PERI: + return priv->clks.peri_clk; + default: + return mt7620_clks[clk->id]; + } +} + +static int mt7620_clkcfg1_rmw(struct mt7620_clk_priv *priv, u32 clr, u32 set) +{ + u32 val; + int ret; + + ret = misc_read(priv->sysc, CLKCFG1_REG, &val, sizeof(val)); + if (ret) { + dev_err(priv->dev, "mt7620_clk: failed to read CLKCFG1\n"); + return ret; + } + + val &= ~clr; + val |= set; + + ret = misc_write(priv->sysc, CLKCFG1_REG, &val, sizeof(val)); + if (ret) { + dev_err(priv->dev, "mt7620_clk: failed to write CLKCFG1\n"); + return ret; + } + + return 0; +} + +static int mt7620_clk_enable(struct clk *clk) +{ + struct mt7620_clk_priv *priv = dev_get_priv(clk->dev); + + if (clk->id > 30) + return -1; + + return mt7620_clkcfg1_rmw(priv, 0, BIT(clk->id)); +} + +static int mt7620_clk_disable(struct clk *clk) +{ + struct mt7620_clk_priv *priv = dev_get_priv(clk->dev); + + if (clk->id > 30) + return -1; + + return mt7620_clkcfg1_rmw(priv, BIT(clk->id), 0); +} + +const struct clk_ops mt7620_clk_ops = { + .enable = mt7620_clk_enable, + .disable = mt7620_clk_disable, + .get_rate = mt7620_clk_get_rate, +}; + +static int mt7620_clk_probe(struct udevice *dev) +{ + struct mt7620_clk_priv *priv = dev_get_priv(dev); + struct ofnode_phandle_args sysc_args; + int ret; + + ret = ofnode_parse_phandle_with_args(dev->node, "mediatek,sysc", NULL, + 0, 0, &sysc_args); + if (ret) { + dev_err(dev, "mt7620_clk: sysc property not found\n"); + return ret; + } + + ret = uclass_get_device_by_ofnode(UCLASS_MISC, sysc_args.node, + &priv->sysc); + if (ret) { + dev_err(dev, "mt7620_clk: failed to sysc device\n"); + return ret; + } + + ret = misc_ioctl(priv->sysc, MT7620_SYSC_IOCTL_GET_CLK, + &priv->clks); + if (ret) { + dev_err(dev, "mt7620_clk: failed to get base clocks\n"); + return ret; + } + + priv->dev = dev; + + return 0; +} + +static const struct udevice_id mt7620_clk_ids[] = { + { .compatible = "mediatek,mt7620-clk" }, + { } +}; + +U_BOOT_DRIVER(mt7620_clk) = { + .name = "mt7620-clk", + .id = UCLASS_CLK, + .of_match = mt7620_clk_ids, + .probe = mt7620_clk_probe, + .priv_auto_alloc_size = sizeof(struct mt7620_clk_priv), + .ops = &mt7620_clk_ops, + .flags = DM_FLAG_PRE_RELOC, +}; diff --git a/include/dt-bindings/clock/mt7620-clk.h b/include/dt-bindings/clock/mt7620-clk.h new file mode 100644 index 0000000000..3bb91ebdf1 --- /dev/null +++ b/include/dt-bindings/clock/mt7620-clk.h @@ -0,0 +1,40 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2020 MediaTek Inc. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#ifndef _DT_BINDINGS_MT7620_CLK_H_ +#define _DT_BINDINGS_MT7620_CLK_H_ + +/* Base clocks */ +#define CLK_SYS 34 +#define CLK_CPU 33 +#define CLK_XTAL 32 + +/* Peripheral clocks */ +#define CLK_SDHC 30 +#define CLK_MIPS_CNT 28 +#define CLK_PCIE 26 +#define CLK_UPHY_12M 25 +#define CLK_EPHY 24 +#define CLK_ESW 23 +#define CLK_UPHY_48M 22 +#define CLK_FE 21 +#define CLK_UARTL 19 +#define CLK_SPI 18 +#define CLK_I2S 17 +#define CLK_I2C 16 +#define CLK_NAND 15 +#define CLK_GDMA 14 +#define CLK_PIO 13 +#define CLK_UARTF 12 +#define CLK_PCM 11 +#define CLK_MC 10 +#define CLK_INTC 9 +#define CLK_TIMER 8 +#define CLK_GE2 7 +#define CLK_GE1 6 + +#endif /* _DT_BINDINGS_MT7620_CLK_H_ */
Thanks, Stefan
- struct udevice *dev;
- struct udevice *sysc;
- struct mt7620_sysc_clks clks;
- [CLK_SYS] = CLK_SRC_SYS,
- [CLK_CPU] = CLK_SRC_CPU,
- [CLK_XTAL] = CLK_SRC_XTAL,
- [CLK_MIPS_CNT] = CLK_SRC_CPU_D2,
- [CLK_UARTF] = CLK_SRC_PERI,
- [CLK_UARTL] = CLK_SRC_PERI,
- [CLK_SPI] = CLK_SRC_SYS,
- [CLK_I2C] = CLK_SRC_PERI,
- [CLK_I2S] = CLK_SRC_PERI,
- struct mt7620_clk_priv *priv = dev_get_priv(clk->dev);
- if (clk->id >= ARRAY_SIZE(mt7620_clks))
- switch (mt7620_clks[clk->id]) {
- case CLK_SRC_CPU:
- case CLK_SRC_CPU_D2:
- case CLK_SRC_SYS:
- case CLK_SRC_XTAL:
- case CLK_SRC_PERI:
- default:
- u32 val;
- int ret;
- ret = misc_read(priv->sysc, CLKCFG1_REG, &val, sizeof(val));
- if (ret) {
return ret;
- val &= ~clr;
- val |= set;
- ret = misc_write(priv->sysc, CLKCFG1_REG, &val, sizeof(val));
- if (ret) {
return ret;
- if (clk->id > 30)
return -1;
- return mt7620_clkcfg1_rmw(priv, 0, BIT(clk->id));
- if (clk->id > 30)
return -1;
- return mt7620_clkcfg1_rmw(priv, BIT(clk->id), 0);
- .enable = mt7620_clk_enable,
- .disable = mt7620_clk_disable,
- .get_rate = mt7620_clk_get_rate,
- struct mt7620_clk_priv *priv = dev_get_priv(dev);
- struct ofnode_phandle_args sysc_args;
- int ret;
- ret = ofnode_parse_phandle_with_args(dev->node, "mediatek,sysc", NULL,
0, 0, &sysc_args);
- if (ret) {
return ret;
- ret = uclass_get_device_by_ofnode(UCLASS_MISC, sysc_args.node,
&priv->sysc);
- if (ret) {
return ret;
- ret = misc_ioctl(priv->sysc, MT7620_SYSC_IOCTL_GET_CLK,
&priv->clks);
- if (ret) {
return ret;
- priv->dev = dev;
- { .compatible = "mediatek,mt7620-clk" },
- .name = "mt7620-clk",
- .id = UCLASS_CLK,
- .of_match = mt7620_clk_ids,
- .probe = mt7620_clk_probe,
- .priv_auto_alloc_size = sizeof(struct mt7620_clk_priv),
- .ops = &mt7620_clk_ops,
Viele Grüße, Stefan
This patch adds reset controller bits definition header file for MediaTek MT7620 SoC
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v3 changes: none v2 changes: none --- include/dt-bindings/reset/mt7620-reset.h | 35 ++++++++++++++++++++++++ 1 file changed, 35 insertions(+) create mode 100644 include/dt-bindings/reset/mt7620-reset.h
diff --git a/include/dt-bindings/reset/mt7620-reset.h b/include/dt-bindings/reset/mt7620-reset.h new file mode 100644 index 0000000000..3096b29cdb --- /dev/null +++ b/include/dt-bindings/reset/mt7620-reset.h @@ -0,0 +1,35 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2020 MediaTek Inc. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#ifndef _DT_BINDINGS_MT7620_RESET_H_ +#define _DT_BINDINGS_MT7620_RESET_H_ + +#define PPE_RST 31 +#define SDHC_RST 30 +#define MIPS_CNT_RST 28 +#define PCIE_RST 26 +#define UHST_RST 25 +#define EPHY_RST 24 +#define ESW_RST 23 +#define UDEV_RST 22 +#define FE_RST 21 +#define WLAN_RST 20 +#define UARTL_RST 19 +#define SPI_RST 18 +#define I2S_RST 17 +#define I2C_RST 16 +#define NAND_RST 15 +#define DMA_RST 14 +#define PIO_RST 13 +#define UARTF_RST 12 +#define PCM_RST 11 +#define MC_RST 10 +#define INTC_RST 9 +#define TIMER_RST 8 +#define SYS_RST 0 + +#endif /* _DT_BINDINGS_MT7620_RESET_H_ */
Just curious: Where are you including this file? I couldn't find it in a quick search through the following patches. Perhaps its also a good idea to add some MTMIPS_ or MT7620_ before the defines, to not "pollute" the namespace with too generic macros.
Other than that:
Thanks, Stefan
Viele Grüße, Stefan
This header files is only included in arch/mips/dts/mt7620.dtsi, and used in the resets properties, e.g. resets = <&rstctrl PIO_RST>;
Other than that:
Thanks, Stefan
Viele Grüße, Stefan
Ah, okay.
Thanks, Stefan
Other than that:
Thanks, Stefan
Viele Grüße, Stefan
Viele Grüße, Stefan
This patch adds pinctrl support for MediaTek MT7620 SoC. The MT7620 SoC supports only pinmux.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v3 changes: none v2 changes: none --- drivers/pinctrl/mtmips/Kconfig | 9 ++ drivers/pinctrl/mtmips/Makefile | 1 + drivers/pinctrl/mtmips/pinctrl-mt7620.c | 200 ++++++++++++++++++++++++ 3 files changed, 210 insertions(+) create mode 100644 drivers/pinctrl/mtmips/pinctrl-mt7620.c
diff --git a/drivers/pinctrl/mtmips/Kconfig b/drivers/pinctrl/mtmips/Kconfig index 8482a38ebc..844d5b743f 100644 --- a/drivers/pinctrl/mtmips/Kconfig +++ b/drivers/pinctrl/mtmips/Kconfig @@ -3,6 +3,15 @@ config PINCTRL_MTMIPS depends on ARCH_MTMIPS bool
+config PINCTRL_MT7620 + bool "MediaTek MT7620 pin control driver" + select PINCTRL_MTMIPS + depends on SOC_MT7620 && PINCTRL_GENERIC + help + Support pin multiplexing control on MediaTek MT7620. + The driver is controlled by a device tree node which contains + the pin mux functions for each available pin groups. + config PINCTRL_MT7628 bool "MediaTek MT7628 pin control driver" select PINCTRL_MTMIPS diff --git a/drivers/pinctrl/mtmips/Makefile b/drivers/pinctrl/mtmips/Makefile index 3ba5c0c66d..ba945a89a7 100644 --- a/drivers/pinctrl/mtmips/Makefile +++ b/drivers/pinctrl/mtmips/Makefile @@ -4,4 +4,5 @@ obj-$(CONFIG_PINCTRL_MTMIPS) += pinctrl-mtmips-common.o
# SoC Drivers +obj-$(CONFIG_PINCTRL_MT7620) += pinctrl-mt7620.o obj-$(CONFIG_PINCTRL_MT7628) += pinctrl-mt7628.o diff --git a/drivers/pinctrl/mtmips/pinctrl-mt7620.c b/drivers/pinctrl/mtmips/pinctrl-mt7620.c new file mode 100644 index 0000000000..10a4fc6c19 --- /dev/null +++ b/drivers/pinctrl/mtmips/pinctrl-mt7620.c @@ -0,0 +1,200 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020 MediaTek Inc. All Rights Reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#include <dm.h> +#include <dm/pinctrl.h> +#include <linux/bitops.h> +#include <linux/io.h> + +#include "pinctrl-mtmips-common.h" + +#define SUTIF_SHIFT 30 +#define WDT_RST_SHIFT 21 +#define PA_G_SHIFT 20 +#define NAND_SD_SHIFT 18 +#define PERST_SHIFT 16 +#define EPHY_LED_SHIFT 15 +#define WLED_SHIFT 13 +#define SPI_CS1_SHIFT 12 +#define SPI_SHIFT 11 +#define RGMII2_SHIFT 10 +#define RGMII1_SHIFT 9 +#define MDIO_SHIFT 7 +#define UARTL_SHIFT 5 +#define UARTF_SHIFT 2 +#define I2C_SHIFT 0 + +#define GM4_MASK 3 +#define GM8_MASK 7 + +#if CONFIG_IS_ENABLED(PINMUX) +static const struct mtmips_pmx_func sutif_grp[] = { + FUNC("i2c", 2), + FUNC("uartl", 1), + FUNC("none", 0), +}; + +static const struct mtmips_pmx_func wdt_rst_grp[] = { + FUNC("gpio", 2), + FUNC("refclk", 1), + FUNC("wdt rst", 0), +}; + +static const struct mtmips_pmx_func pa_g_grp[] = { + FUNC("gpio", 1), + FUNC("pa", 0), +}; + +static const struct mtmips_pmx_func nand_sd_grp[] = { + FUNC("gpio", 2), + FUNC("sd", 1), + FUNC("nand", 0), +}; + +static const struct mtmips_pmx_func perst_grp[] = { + FUNC("gpio", 2), + FUNC("refclk", 1), + FUNC("perst", 0), +}; + +static const struct mtmips_pmx_func ephy_led_grp[] = { + FUNC("gpio", 1), + FUNC("led", 0), +}; + +static const struct mtmips_pmx_func wled_grp[] = { + FUNC("gpio", 1), + FUNC("led", 0), +}; + +static const struct mtmips_pmx_func spi_cs1_grp[] = { + FUNC("refclk", 1), + FUNC("spi cs1", 0), +}; + +static const struct mtmips_pmx_func spi_grp[] = { + FUNC("gpio", 1), + FUNC("spi", 0), +}; + +static const struct mtmips_pmx_func rgmii2_grp[] = { + FUNC("gpio", 1), + FUNC("rgmii2", 0), +}; + +static const struct mtmips_pmx_func rgmii1_grp[] = { + FUNC("gpio", 1), + FUNC("rgmii1", 0), +}; + +static const struct mtmips_pmx_func mdio_grp[] = { + FUNC("gpio", 2), + FUNC("refclk", 1), + FUNC("mdio", 0), +}; + +static const struct mtmips_pmx_func uartl_grp[] = { + FUNC("gpio", 1), + FUNC("uartl", 0), +}; + +static const struct mtmips_pmx_func uartf_grp[] = { + FUNC("gpio", 7), + FUNC("i2s gpio", 6), + FUNC("uartf gpio", 5), + FUNC("gpio pcm", 4), + FUNC("i2s uartf", 3), + FUNC("i2s pcm", 2), + FUNC("uartf pcm", 1), + FUNC("uartf", 0), +}; + +static const struct mtmips_pmx_func i2c_grp[] = { + FUNC("gpio", 1), + FUNC("i2c", 0), +}; + +static const struct mtmips_pmx_group mt7620_pinmux_data[] = { + GRP("sutif", sutif_grp, 0, SUTIF_SHIFT, GM4_MASK), + GRP("wdt rst", wdt_rst_grp, 0, WDT_RST_SHIFT, GM4_MASK), + GRP("pa", pa_g_grp, 0, PA_G_SHIFT, 1), + GRP("nand", nand_sd_grp, 0, NAND_SD_SHIFT, GM4_MASK), + GRP("perst", perst_grp, 0, PERST_SHIFT, GM4_MASK), + GRP("ephy led", ephy_led_grp, 0, EPHY_LED_SHIFT, 1), + GRP("wled", wled_grp, 0, WLED_SHIFT, 1), + GRP("spi cs1", spi_cs1_grp, 0, SPI_CS1_SHIFT, 1), + GRP("spi", spi_grp, 0, SPI_SHIFT, 1), + GRP("rgmii2", rgmii2_grp, 0, RGMII2_SHIFT, 1), + GRP("rgmii1", rgmii1_grp, 0, RGMII1_SHIFT, 1), + GRP("mdio", mdio_grp, 0, MDIO_SHIFT, GM4_MASK), + GRP("uartl", uartl_grp, 0, UARTL_SHIFT, 1), + GRP("uartf", uartf_grp, 0, UARTF_SHIFT, GM8_MASK), + GRP("i2c", i2c_grp, 0, I2C_SHIFT, 1), +}; + +static int mt7620_get_groups_count(struct udevice *dev) +{ + return ARRAY_SIZE(mt7620_pinmux_data); +} + +static const char *mt7620_get_group_name(struct udevice *dev, + unsigned int selector) +{ + return mt7620_pinmux_data[selector].name; +} +#endif /* CONFIG_IS_ENABLED(PINMUX) */ + +static int mt7620_pinctrl_probe(struct udevice *dev) +{ + struct mtmips_pinctrl_priv *priv = dev_get_priv(dev); + int ret = 0; + +#if CONFIG_IS_ENABLED(PINMUX) + ret = mtmips_pinctrl_probe(priv, ARRAY_SIZE(mt7620_pinmux_data), + mt7620_pinmux_data); +#endif /* CONFIG_IS_ENABLED(PINMUX) */ + + return ret; +} + +static int mt7620_pinctrl_ofdata_to_platdata(struct udevice *dev) +{ + struct mtmips_pinctrl_priv *priv = dev_get_priv(dev); + + priv->base = dev_remap_addr_index(dev, 0); + if (!priv->base) + return -EINVAL; + + return 0; +} + +static const struct pinctrl_ops mt7620_pinctrl_ops = { +#if CONFIG_IS_ENABLED(PINMUX) + .get_groups_count = mt7620_get_groups_count, + .get_group_name = mt7620_get_group_name, + .get_functions_count = mtmips_get_functions_count, + .get_function_name = mtmips_get_function_name, + .pinmux_group_set = mtmips_pinmux_group_set, +#endif /* CONFIG_IS_ENABLED(PINMUX) */ + .set_state = pinctrl_generic_set_state, +}; + +static const struct udevice_id mt7620_pinctrl_ids[] = { + { .compatible = "mediatek,mt7620-pinctrl" }, + { } +}; + +U_BOOT_DRIVER(mt7620_pinctrl) = { + .name = "mt7620-pinctrl", + .id = UCLASS_PINCTRL, + .of_match = mt7620_pinctrl_ids, + .ofdata_to_platdata = mt7620_pinctrl_ofdata_to_platdata, + .ops = &mt7620_pinctrl_ops, + .probe = mt7620_pinctrl_probe, + .priv_auto_alloc_size = sizeof(struct mtmips_pinctrl_priv), + .flags = DM_FLAG_PRE_RELOC, +};
Thanks, Stefan
- bool "MediaTek MT7620 pin control driver"
- select PINCTRL_MTMIPS
- depends on SOC_MT7620 && PINCTRL_GENERIC
- help
- config PINCTRL_MT7628 bool "MediaTek MT7628 pin control driver" select PINCTRL_MTMIPS
- FUNC("i2c", 2),
- FUNC("uartl", 1),
- FUNC("none", 0),
- FUNC("gpio", 2),
- FUNC("refclk", 1),
- FUNC("wdt rst", 0),
- FUNC("gpio", 1),
- FUNC("pa", 0),
- FUNC("gpio", 2),
- FUNC("sd", 1),
- FUNC("nand", 0),
- FUNC("gpio", 2),
- FUNC("perst", 0),
- FUNC("gpio", 1),
- FUNC("led", 0),
- FUNC("gpio", 1),
- FUNC("led", 0),
- FUNC("spi cs1", 0),
- FUNC("gpio", 1),
- FUNC("spi", 0),
- FUNC("gpio", 1),
- FUNC("rgmii2", 0),
- FUNC("gpio", 1),
- FUNC("rgmii1", 0),
- FUNC("gpio", 2),
- FUNC("mdio", 0),
- FUNC("gpio", 1),
- FUNC("uartl", 0),
- FUNC("gpio", 7),
- FUNC("i2s gpio", 6),
- FUNC("uartf gpio", 5),
- FUNC("gpio pcm", 4),
- FUNC("i2s uartf", 3),
- FUNC("i2s pcm", 2),
- FUNC("uartf pcm", 1),
- FUNC("uartf", 0),
- FUNC("gpio", 1),
- FUNC("i2c", 0),
- GRP("sutif", sutif_grp, 0, SUTIF_SHIFT, GM4_MASK),
- GRP("wdt rst", wdt_rst_grp, 0, WDT_RST_SHIFT, GM4_MASK),
- GRP("pa", pa_g_grp, 0, PA_G_SHIFT, 1),
- GRP("nand", nand_sd_grp, 0, NAND_SD_SHIFT, GM4_MASK),
- GRP("perst", perst_grp, 0, PERST_SHIFT, GM4_MASK),
- GRP("ephy led", ephy_led_grp, 0, EPHY_LED_SHIFT, 1),
- GRP("wled", wled_grp, 0, WLED_SHIFT, 1),
- GRP("spi cs1", spi_cs1_grp, 0, SPI_CS1_SHIFT, 1),
- GRP("spi", spi_grp, 0, SPI_SHIFT, 1),
- GRP("rgmii2", rgmii2_grp, 0, RGMII2_SHIFT, 1),
- GRP("rgmii1", rgmii1_grp, 0, RGMII1_SHIFT, 1),
- GRP("mdio", mdio_grp, 0, MDIO_SHIFT, GM4_MASK),
- GRP("uartl", uartl_grp, 0, UARTL_SHIFT, 1),
- GRP("uartf", uartf_grp, 0, UARTF_SHIFT, GM8_MASK),
- GRP("i2c", i2c_grp, 0, I2C_SHIFT, 1),
- return ARRAY_SIZE(mt7620_pinmux_data);
- return mt7620_pinmux_data[selector].name;
- struct mtmips_pinctrl_priv *priv = dev_get_priv(dev);
- int ret = 0;
- ret = mtmips_pinctrl_probe(priv, ARRAY_SIZE(mt7620_pinmux_data),
- return ret;
- if (!priv->base)
return -EINVAL;
- .get_groups_count = mt7620_get_groups_count,
- .get_group_name = mt7620_get_group_name,
- .get_functions_count = mtmips_get_functions_count,
- .get_function_name = mtmips_get_function_name,
- .pinmux_group_set = mtmips_pinmux_group_set,
- .set_state = pinctrl_generic_set_state,
- { .compatible = "mediatek,mt7620-pinctrl" },
- .name = "mt7620-pinctrl",
- .id = UCLASS_PINCTRL,
- .of_match = mt7620_pinctrl_ids,
- .ofdata_to_platdata = mt7620_pinctrl_ofdata_to_platdata,
- .ops = &mt7620_pinctrl_ops,
- .probe = mt7620_pinctrl_probe,
- .priv_auto_alloc_size = sizeof(struct mtmips_pinctrl_priv),
Viele Grüße, Stefan
This patch adds watchdog support for the Mediatek MT7620 SoC
Reviewed-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v3 changes: add detail comments for mt7620_wdt_expire_now() v2 changes: add expire_now --- drivers/watchdog/Kconfig | 7 ++ drivers/watchdog/Makefile | 1 + drivers/watchdog/mt7620_wdt.c | 142 ++++++++++++++++++++++++++++++++++ 3 files changed, 150 insertions(+) create mode 100644 drivers/watchdog/mt7620_wdt.c
diff --git a/drivers/watchdog/Kconfig b/drivers/watchdog/Kconfig index 4532a40e45..7d7bd4dcb7 100644 --- a/drivers/watchdog/Kconfig +++ b/drivers/watchdog/Kconfig @@ -125,6 +125,13 @@ config WDT_MPC8xx help Select this to enable mpc8xx watchdog timer
+config WDT_MT7620 + bool "MediaTek MT7620 watchdog timer support" + depends on WDT && SOC_MT7620 + help + Select this to enable watchdog timer on MediaTek MT7620 and earlier + SoC chips. + config WDT_MT7621 bool "MediaTek MT7621 watchdog timer support" depends on WDT && SOC_MT7628 diff --git a/drivers/watchdog/Makefile b/drivers/watchdog/Makefile index 01b8231f2b..825b50e626 100644 --- a/drivers/watchdog/Makefile +++ b/drivers/watchdog/Makefile @@ -24,6 +24,7 @@ obj-$(CONFIG_WDT_CORTINA) += cortina_wdt.o obj-$(CONFIG_WDT_ORION) += orion_wdt.o obj-$(CONFIG_WDT_CDNS) += cdns_wdt.o obj-$(CONFIG_WDT_MPC8xx) += mpc8xx_wdt.o +obj-$(CONFIG_WDT_MT7620) += mt7620_wdt.o obj-$(CONFIG_WDT_MT7621) += mt7621_wdt.o obj-$(CONFIG_WDT_MTK) += mtk_wdt.o obj-$(CONFIG_WDT_OCTEONTX) += octeontx_wdt.o diff --git a/drivers/watchdog/mt7620_wdt.c b/drivers/watchdog/mt7620_wdt.c new file mode 100644 index 0000000000..8d39010ee7 --- /dev/null +++ b/drivers/watchdog/mt7620_wdt.c @@ -0,0 +1,142 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020 MediaTek Inc. + * + * Author: Weijie Gao weijie.gao@mediatek.com + * + * Watchdog timer for MT7620 and earlier SoCs + */ + +#include <div64.h> +#include <dm.h> +#include <reset.h> +#include <wdt.h> +#include <linux/bitops.h> +#include <linux/io.h> + +struct mt7620_wdt { + void __iomem *regs; + u64 timeout; +}; + +#define TIMER_FREQ 40000000 +#define TIMER_MASK 0xffff +#define TIMER_PRESCALE 65536 + +#define TIMER_LOAD 0x00 +#define TIMER_CTL 0x08 + +#define TIMER_ENABLE BIT(7) +#define TIMER_MODE_SHIFT 4 +#define TIMER_MODE_WDT 3 +#define TIMER_PRESCALE_SHIFT 0 +#define TIMER_PRESCALE_65536 15 + +static void mt7620_wdt_ping(struct mt7620_wdt *priv) +{ + u64 val; + + val = (TIMER_FREQ / TIMER_PRESCALE) * priv->timeout; + do_div(val, 1000); + + if (val > TIMER_MASK) + val = TIMER_MASK; + + writel(val, priv->regs + TIMER_LOAD); +} + +static int mt7620_wdt_start(struct udevice *dev, u64 ms, ulong flags) +{ + struct mt7620_wdt *priv = dev_get_priv(dev); + + priv->timeout = ms; + mt7620_wdt_ping(priv); + + writel(TIMER_ENABLE | (TIMER_MODE_WDT << TIMER_MODE_SHIFT) | + (TIMER_PRESCALE_65536 << TIMER_PRESCALE_SHIFT), + priv->regs + TIMER_CTL); + + return 0; +} + +static int mt7620_wdt_stop(struct udevice *dev) +{ + struct mt7620_wdt *priv = dev_get_priv(dev); + + mt7620_wdt_ping(priv); + + clrbits_32(priv->regs + TIMER_CTL, TIMER_ENABLE); + + return 0; +} + +static int mt7620_wdt_reset(struct udevice *dev) +{ + struct mt7620_wdt *priv = dev_get_priv(dev); + + mt7620_wdt_ping(priv); + + return 0; +} + +static int mt7620_wdt_expire_now(struct udevice *dev, ulong flags) +{ + struct mt7620_wdt *priv = dev_get_priv(dev); + + mt7620_wdt_start(dev, 1, flags); + + /* + * 0 will disable the timer directly, a positive number must be used + * instead. Since the timer is a countdown timer, 1 (tick) is used. + * + * For a timer with input clock = 40MHz, 1 timer tick is short + * enough to trigger a timeout immediately. + * + * Restore prescale to 1, and load timer with 1 to trigger timeout. + */ + writel(TIMER_ENABLE | (TIMER_MODE_WDT << TIMER_MODE_SHIFT), + priv->regs + TIMER_CTL); + writel(1, priv->regs + TIMER_LOAD); + + return 0; +} + +static int mt7620_wdt_probe(struct udevice *dev) +{ + struct mt7620_wdt *priv = dev_get_priv(dev); + struct reset_ctl reset_wdt; + int ret; + + ret = reset_get_by_index(dev, 0, &reset_wdt); + if (!ret) + reset_deassert(&reset_wdt); + + priv->regs = dev_remap_addr(dev); + if (!priv->regs) + return -EINVAL; + + mt7620_wdt_stop(dev); + + return 0; +} + +static const struct wdt_ops mt7620_wdt_ops = { + .start = mt7620_wdt_start, + .reset = mt7620_wdt_reset, + .stop = mt7620_wdt_stop, + .expire_now = mt7620_wdt_expire_now, +}; + +static const struct udevice_id mt7620_wdt_ids[] = { + { .compatible = "mediatek,mt7620-wdt" }, + {} +}; + +U_BOOT_DRIVER(mt7620_wdt) = { + .name = "mt7620_wdt", + .id = UCLASS_WDT, + .of_match = mt7620_wdt_ids, + .probe = mt7620_wdt_probe, + .priv_auto_alloc_size = sizeof(struct mt7620_wdt), + .ops = &mt7620_wdt_ops, +};
Thanks, Stefan
+config WDT_MT7620
- bool "MediaTek MT7620 watchdog timer support"
- depends on WDT && SOC_MT7620
- help
SoC chips.
- config WDT_MT7621 bool "MediaTek MT7621 watchdog timer support" depends on WDT && SOC_MT7628
- Author: Weijie Gao weijie.gao@mediatek.com
- Watchdog timer for MT7620 and earlier SoCs
- void __iomem *regs;
- u64 timeout;
- u64 val;
- val = (TIMER_FREQ / TIMER_PRESCALE) * priv->timeout;
- do_div(val, 1000);
- if (val > TIMER_MASK)
val = TIMER_MASK;
- writel(val, priv->regs + TIMER_LOAD);
- struct mt7620_wdt *priv = dev_get_priv(dev);
- priv->timeout = ms;
- mt7620_wdt_ping(priv);
- writel(TIMER_ENABLE | (TIMER_MODE_WDT << TIMER_MODE_SHIFT) |
- clrbits_32(priv->regs + TIMER_CTL, TIMER_ENABLE);
- mt7620_wdt_start(dev, 1, flags);
- writel(TIMER_ENABLE | (TIMER_MODE_WDT << TIMER_MODE_SHIFT),
- writel(1, priv->regs + TIMER_LOAD);
- struct reset_ctl reset_wdt;
- int ret;
- ret = reset_get_by_index(dev, 0, &reset_wdt);
- if (!ret)
- priv->regs = dev_remap_addr(dev);
- if (!priv->regs)
return -EINVAL;
- mt7620_wdt_stop(dev);
- .start = mt7620_wdt_start,
- .reset = mt7620_wdt_reset,
- .stop = mt7620_wdt_stop,
- .expire_now = mt7620_wdt_expire_now,
- { .compatible = "mediatek,mt7620-wdt" },
- .name = "mt7620_wdt",
- .id = UCLASS_WDT,
- .of_match = mt7620_wdt_ids,
- .probe = mt7620_wdt_probe,
- .priv_auto_alloc_size = sizeof(struct mt7620_wdt),
- .ops = &mt7620_wdt_ops,
Viele Grüße, Stefan
This patch adds GPIO controller driver for MediaTek MT7620 SoC
Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v3 changes: none v2 changes: none --- drivers/gpio/Kconfig | 8 ++ drivers/gpio/Makefile | 1 + drivers/gpio/mt7620_gpio.c | 146 +++++++++++++++++++++++++++++++++++++ 3 files changed, 155 insertions(+) create mode 100644 drivers/gpio/mt7620_gpio.c
diff --git a/drivers/gpio/Kconfig b/drivers/gpio/Kconfig index 202fcc6f47..7e94759a79 100644 --- a/drivers/gpio/Kconfig +++ b/drivers/gpio/Kconfig @@ -471,6 +471,14 @@ config MPC83XX_SPISEL_BOOT
This pin is typically used as spi chip select to a spi nor flash.
+config MT7620_GPIO + bool "MediaTek MT7620 GPIO driver" + depends on DM_GPIO && SOC_MT7620 + default y + help + Device model driver for GPIO controller present in MediaTek MT7620 + and earlier SoCs. + config MT7621_GPIO bool "MediaTek MT7621 GPIO driver" depends on DM_GPIO && SOC_MT7628 diff --git a/drivers/gpio/Makefile b/drivers/gpio/Makefile index d3d0d3cacf..8541ba0b0a 100644 --- a/drivers/gpio/Makefile +++ b/drivers/gpio/Makefile @@ -64,6 +64,7 @@ obj-$(CONFIG_MVEBU_GPIO) += mvebu_gpio.o obj-$(CONFIG_MSM_GPIO) += msm_gpio.o obj-$(CONFIG_$(SPL_)PCF8575_GPIO) += pcf8575_gpio.o obj-$(CONFIG_PM8916_GPIO) += pm8916_gpio.o +obj-$(CONFIG_MT7620_GPIO) += mt7620_gpio.o obj-$(CONFIG_MT7621_GPIO) += mt7621_gpio.o obj-$(CONFIG_MSCC_SGPIO) += mscc_sgpio.o obj-$(CONFIG_NX_GPIO) += nx_gpio.o diff --git a/drivers/gpio/mt7620_gpio.c b/drivers/gpio/mt7620_gpio.c new file mode 100644 index 0000000000..508851ea5f --- /dev/null +++ b/drivers/gpio/mt7620_gpio.c @@ -0,0 +1,146 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020 MediaTek Inc. All Rights Reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + * + * GPIO controller driver for MediaTek MT7620 SoC + */ + +#include <dm.h> +#include <errno.h> +#include <dm/device_compat.h> +#include <linux/bitops.h> +#include <linux/io.h> +#include <asm/gpio.h> + +enum mt7620_regs { + GPIO_REG_DATA, + GPIO_REG_DIR, + GPIO_REG_SET, + GPIO_REG_CLR, + + __GPIO_REG_MAX +}; + +struct mt7620_gpio_priv { + void __iomem *base; + u32 regs[__GPIO_REG_MAX]; + u32 count; +}; + +static int mt7620_gpio_get_value(struct udevice *dev, unsigned int offset) +{ + struct mt7620_gpio_priv *priv = dev_get_priv(dev); + + return !!(readl(priv->base + priv->regs[GPIO_REG_DATA]) & BIT(offset)); +} + +static int mt7620_gpio_set_value(struct udevice *dev, unsigned int offset, + int value) +{ + struct mt7620_gpio_priv *priv = dev_get_priv(dev); + u32 reg; + + reg = value ? priv->regs[GPIO_REG_SET] : priv->regs[GPIO_REG_CLR]; + + writel(BIT(offset), priv->base + reg); + + return 0; +} + +static int mt7620_gpio_direction_input(struct udevice *dev, unsigned int offset) +{ + struct mt7620_gpio_priv *priv = dev_get_priv(dev); + + clrbits_32(priv->base + priv->regs[GPIO_REG_DIR], BIT(offset)); + + return 0; +} + +static int mt7620_gpio_direction_output(struct udevice *dev, + unsigned int offset, int value) +{ + struct mt7620_gpio_priv *priv = dev_get_priv(dev); + + /* Set value first */ + mt7620_gpio_set_value(dev, offset, value); + + setbits_32(priv->base + priv->regs[GPIO_REG_DIR], BIT(offset)); + + return 0; +} + +static int mt7620_gpio_get_function(struct udevice *dev, unsigned int offset) +{ + struct mt7620_gpio_priv *priv = dev_get_priv(dev); + + return (readl(priv->base + priv->regs[GPIO_REG_DIR]) & BIT(offset)) ? + GPIOF_OUTPUT : GPIOF_INPUT; +} + +static const struct dm_gpio_ops mt7620_gpio_ops = { + .direction_input = mt7620_gpio_direction_input, + .direction_output = mt7620_gpio_direction_output, + .get_value = mt7620_gpio_get_value, + .set_value = mt7620_gpio_set_value, + .get_function = mt7620_gpio_get_function, +}; + +static int mt7620_gpio_probe(struct udevice *dev) +{ + struct mt7620_gpio_priv *priv = dev_get_priv(dev); + struct gpio_dev_priv *uc_priv = dev_get_uclass_priv(dev); + const char *name; + + name = dev_read_string(dev, "mediatek,bank-name"); + if (!name) + name = dev->name; + + uc_priv->gpio_count = priv->count; + uc_priv->bank_name = name; + + return 0; +} + +static int mt7620_gpio_ofdata_to_platdata(struct udevice *dev) +{ + struct mt7620_gpio_priv *priv = dev_get_priv(dev); + int ret; + + priv->base = dev_remap_addr_index(dev, 0); + if (!priv->base) { + dev_err(dev, "mt7620_gpio: unable to map registers\n"); + return -EINVAL; + } + + ret = dev_read_u32(dev, "mediatek,gpio-num", &priv->count); + if (ret) { + dev_err(dev, "mt7620_gpio: failed to get GPIO count\n"); + return -EINVAL; + } + + ret = dev_read_u32_array(dev, "mediatek,register-map", priv->regs, + __GPIO_REG_MAX); + if (ret) { + dev_err(dev, "mt7620_gpio: unable to get register map\n"); + return -EINVAL; + } + + return 0; +} + +static const struct udevice_id mt7620_gpio_ids[] = { + { .compatible = "mediatek,mt7620-gpio" }, + { } +}; + +U_BOOT_DRIVER(mt7620_gpio) = { + .name = "mt7620_gpio", + .id = UCLASS_GPIO, + .ops = &mt7620_gpio_ops, + .of_match = mt7620_gpio_ids, + .probe = mt7620_gpio_probe, + .ofdata_to_platdata = mt7620_gpio_ofdata_to_platdata, + .priv_auto_alloc_size = sizeof(struct mt7620_gpio_priv), +};
+config MT7620_GPIO
- bool "MediaTek MT7620 GPIO driver"
- depends on DM_GPIO && SOC_MT7620
- default y
- help
and earlier SoCs.
Nitpicking: It's "driver model" and not "device model".
Other than that:
Thanks, Stefan
- config MT7621_GPIO bool "MediaTek MT7621 GPIO driver" depends on DM_GPIO && SOC_MT7628
- Copyright (C) 2020 MediaTek Inc. All Rights Reserved.
- GPIO controller driver for MediaTek MT7620 SoC
+enum mt7620_regs {
- GPIO_REG_DATA,
- GPIO_REG_DIR,
- GPIO_REG_SET,
- GPIO_REG_CLR,
- __GPIO_REG_MAX
- u32 regs[__GPIO_REG_MAX];
- u32 count;
- struct mt7620_gpio_priv *priv = dev_get_priv(dev);
- return !!(readl(priv->base + priv->regs[GPIO_REG_DATA]) & BIT(offset));
int value)
- u32 reg;
- reg = value ? priv->regs[GPIO_REG_SET] : priv->regs[GPIO_REG_CLR];
- writel(BIT(offset), priv->base + reg);
- clrbits_32(priv->base + priv->regs[GPIO_REG_DIR], BIT(offset));
- /* Set value first */
- mt7620_gpio_set_value(dev, offset, value);
- setbits_32(priv->base + priv->regs[GPIO_REG_DIR], BIT(offset));
- return (readl(priv->base + priv->regs[GPIO_REG_DIR]) & BIT(offset)) ?
- .direction_input = mt7620_gpio_direction_input,
- .direction_output = mt7620_gpio_direction_output,
- .get_value = mt7620_gpio_get_value,
- .set_value = mt7620_gpio_set_value,
- .get_function = mt7620_gpio_get_function,
- struct gpio_dev_priv *uc_priv = dev_get_uclass_priv(dev);
- const char *name;
- name = dev_read_string(dev, "mediatek,bank-name");
- if (!name)
name = dev->name;
- uc_priv->gpio_count = priv->count;
- uc_priv->bank_name = name;
- int ret;
return -EINVAL;
- ret = dev_read_u32(dev, "mediatek,gpio-num", &priv->count);
- if (ret) {
return -EINVAL;
- ret = dev_read_u32_array(dev, "mediatek,register-map", priv->regs,
__GPIO_REG_MAX);
- if (ret) {
return -EINVAL;
- { .compatible = "mediatek,mt7620-gpio" },
- .name = "mt7620_gpio",
- .id = UCLASS_GPIO,
- .ops = &mt7620_gpio_ops,
- .of_match = mt7620_gpio_ids,
- .probe = mt7620_gpio_probe,
- .ofdata_to_platdata = mt7620_gpio_ofdata_to_platdata,
- .priv_auto_alloc_size = sizeof(struct mt7620_gpio_priv),
Viele Grüße, Stefan
This patch adds spi controller support for MediaTek MT7620 SoC.
The SPI controller supports two chip selects. These two chip selects are implemented as two separate register groups, but they share the same bus (DI/DO/CLK), only CS pins are dedicated for each register group. Appearently these two register groups cannot operates simulataneously so they are implemented as one controller.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v3 changes: use bool instead of int in for mt7620_spi_set_cs() v2 changes: none --- drivers/spi/Kconfig | 7 + drivers/spi/Makefile | 1 + drivers/spi/mt7620_spi.c | 281 +++++++++++++++++++++++++++++++++++++++ 3 files changed, 289 insertions(+) create mode 100644 drivers/spi/mt7620_spi.c
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index f7a9852565..ec50d843ef 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -202,6 +202,13 @@ config MSCC_BB_SPI Enable MSCC bitbang SPI driver. This driver can be used on MSCC SOCs.
+config MT7620_SPI + bool "MediaTek MT7620 SPI driver" + depends on SOC_MT7620 + help + Enable the MT7620 SPI driver. This driver can be used to access + generic SPI devices on MediaTek MT7620 SoC. + config MT7621_SPI bool "MediaTek MT7621 SPI driver" depends on SOC_MT7628 diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index d9b5bd9b79..bfd142d153 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -36,6 +36,7 @@ obj-$(CONFIG_MESON_SPIFC) += meson_spifc.o obj-$(CONFIG_MPC8XX_SPI) += mpc8xx_spi.o obj-$(CONFIG_MPC8XXX_SPI) += mpc8xxx_spi.o obj-$(CONFIG_MTK_SNFI_SPI) += mtk_snfi_spi.o +obj-$(CONFIG_MT7620_SPI) += mt7620_spi.o obj-$(CONFIG_MT7621_SPI) += mt7621_spi.o obj-$(CONFIG_MSCC_BB_SPI) += mscc_bb_spi.o obj-$(CONFIG_MVEBU_A3700_SPI) += mvebu_a3700_spi.o diff --git a/drivers/spi/mt7620_spi.c b/drivers/spi/mt7620_spi.c new file mode 100644 index 0000000000..bc61b4fd13 --- /dev/null +++ b/drivers/spi/mt7620_spi.c @@ -0,0 +1,281 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020 MediaTek Inc. + * + * Author: Weijie Gao weijie.gao@mediatek.com + * + * Generic SPI driver for MediaTek MT7620 SoC + */ + +#include <clk.h> +#include <dm.h> +#include <dm/device_compat.h> +#include <spi.h> +#include <linux/bitops.h> +#include <linux/iopoll.h> +#include <linux/io.h> +#include <linux/log2.h> + +#define MT7620_SPI_NUM_CS 2 +#define MT7620_SPI_MASTER1_OFF 0x00 +#define MT7620_SPI_MASTER2_OFF 0x40 + +/* SPI_STAT */ +#define SPI_BUSY BIT(0) + +/* SPI_CFG */ +#define MSB_FIRST BIT(8) +#define SPI_CLK_POL BIT(6) +#define RX_CLK_EDGE BIT(5) +#define TX_CLK_EDGE BIT(4) +#define SPI_CLK_S 0 +#define SPI_CLK_M GENMASK(2, 0) + +/* SPI_CTL */ +#define START_WR BIT(2) +#define START_RD BIT(1) +#define SPI_HIGH BIT(0) + +#define SPI_ARB 0xf0 +#define ARB_EN BIT(31) + +#define POLLING_SCALE 10 +#define POLLING_FRAC_USEC 100 + +struct mt7620_spi_master_regs { + u32 stat; + u32 reserved0[3]; + u32 cfg; + u32 ctl; + u32 reserved1[2]; + u32 data; +}; + +struct mt7620_spi { + void __iomem *regs; + struct mt7620_spi_master_regs *m[MT7620_SPI_NUM_CS]; + unsigned int sys_freq; + u32 wait_us; + uint mode; + uint speed; +}; + +static void mt7620_spi_master_setup(struct mt7620_spi *ms, int cs) +{ + u32 rate, prescale, freq, tmo, cfg; + + /* Calculate the clock divsior */ + rate = DIV_ROUND_UP(ms->sys_freq, ms->speed); + rate = roundup_pow_of_two(rate); + + prescale = ilog2(rate / 2); + if (prescale > 6) + prescale = 6; + + /* Calculate the real clock, and usecs for one byte transaction */ + freq = ms->sys_freq >> (prescale + 1); + tmo = DIV_ROUND_UP(8 * 1000000, freq); + + /* 10 times tolerance plus 100us */ + ms->wait_us = POLLING_SCALE * tmo + POLLING_FRAC_USEC; + + /* set SPI_CFG */ + cfg = prescale << SPI_CLK_S; + + switch (ms->mode & (SPI_CPOL | SPI_CPHA)) { + case SPI_MODE_0: + cfg |= TX_CLK_EDGE; + break; + case SPI_MODE_1: + cfg |= RX_CLK_EDGE; + break; + case SPI_MODE_2: + cfg |= SPI_CLK_POL | RX_CLK_EDGE; + break; + case SPI_MODE_3: + cfg |= SPI_CLK_POL | TX_CLK_EDGE; + break; + } + + if (!(ms->mode & SPI_LSB_FIRST)) + cfg |= MSB_FIRST; + + writel(cfg, &ms->m[cs]->cfg); + + writel(SPI_HIGH, &ms->m[cs]->ctl); +} + +static void mt7620_spi_set_cs(struct mt7620_spi *ms, int cs, bool enable) +{ + if (enable) + mt7620_spi_master_setup(ms, cs); + + if (ms->mode & SPI_CS_HIGH) + enable = !enable; + + if (enable) + clrbits_32(&ms->m[cs]->ctl, SPI_HIGH); + else + setbits_32(&ms->m[cs]->ctl, SPI_HIGH); +} + +static int mt7620_spi_set_mode(struct udevice *bus, uint mode) +{ + struct mt7620_spi *ms = dev_get_priv(bus); + + ms->mode = mode; + + /* Mode 0 is buggy. Force to use mode 3 */ + if ((mode & SPI_MODE_3) == SPI_MODE_0) + ms->mode |= SPI_MODE_3; + + return 0; +} + +static int mt7620_spi_set_speed(struct udevice *bus, uint speed) +{ + struct mt7620_spi *ms = dev_get_priv(bus); + + ms->speed = speed; + + return 0; +} + +static inline int mt7620_spi_busy_poll(struct mt7620_spi *ms, int cs) +{ + u32 val; + + return readl_poll_timeout(&ms->m[cs]->stat, val, !(val & SPI_BUSY), + ms->wait_us); +} + +static int mt7620_spi_read(struct mt7620_spi *ms, int cs, u8 *buf, size_t len) +{ + int ret; + + while (len) { + setbits_32(&ms->m[cs]->ctl, START_RD); + + ret = mt7620_spi_busy_poll(ms, cs); + if (ret) + return ret; + + *buf++ = (u8)readl(&ms->m[cs]->data); + + len--; + } + + return 0; +} + +static int mt7620_spi_write(struct mt7620_spi *ms, int cs, const u8 *buf, + size_t len) +{ + int ret; + + while (len) { + writel(*buf++, &ms->m[cs]->data); + setbits_32(&ms->m[cs]->ctl, START_WR); + + ret = mt7620_spi_busy_poll(ms, cs); + if (ret) + return ret; + + len--; + } + + return 0; +} + +static int mt7620_spi_xfer(struct udevice *dev, unsigned int bitlen, + const void *dout, void *din, unsigned long flags) +{ + struct udevice *bus = dev->parent; + struct mt7620_spi *ms = dev_get_priv(bus); + int total_size = bitlen >> 3; + int cs, ret = 0; + + /* + * This driver only supports half-duplex, so complain and bail out + * upon full-duplex messages + */ + if (dout && din) { + dev_err(dev, "mt7620_spi: Only half-duplex is supported\n"); + return -EIO; + } + + cs = spi_chip_select(dev); + if (cs < 0 || cs >= MT7620_SPI_NUM_CS) { + dev_err(dev, "mt7620_spi: Invalid chip select %d\n", cs); + return -EINVAL; + } + + if (flags & SPI_XFER_BEGIN) + mt7620_spi_set_cs(ms, cs, true); + + if (din) + ret = mt7620_spi_read(ms, cs, din, total_size); + else if (dout) + ret = mt7620_spi_write(ms, cs, dout, total_size); + + if (ret) + dev_err(dev, "mt7620_spi: %s transaction timeout\n", + din ? "read" : "write"); + + if (flags & SPI_XFER_END) + mt7620_spi_set_cs(ms, cs, false); + + return ret; +} + +static int mt7620_spi_probe(struct udevice *dev) +{ + struct mt7620_spi *ms = dev_get_priv(dev); + struct clk clk; + int ret; + + ms->regs = dev_remap_addr(dev); + if (!ms->regs) + return -EINVAL; + + ms->m[0] = ms->regs + MT7620_SPI_MASTER1_OFF; + ms->m[1] = ms->regs + MT7620_SPI_MASTER2_OFF; + + ret = clk_get_by_index(dev, 0, &clk); + if (ret < 0) { + dev_err(dev, "mt7620_spi: Please provide a clock!\n"); + return ret; + } + + clk_enable(&clk); + + ms->sys_freq = clk_get_rate(&clk); + if (!ms->sys_freq) { + dev_err(dev, "mt7620_spi: Please provide a valid bus clock!\n"); + return -EINVAL; + } + + writel(ARB_EN, ms->regs + SPI_ARB); + + return 0; +} + +static const struct dm_spi_ops mt7620_spi_ops = { + .set_mode = mt7620_spi_set_mode, + .set_speed = mt7620_spi_set_speed, + .xfer = mt7620_spi_xfer, +}; + +static const struct udevice_id mt7620_spi_ids[] = { + { .compatible = "mediatek,mt7620-spi" }, + { } +}; + +U_BOOT_DRIVER(mt7620_spi) = { + .name = "mt7620_spi", + .id = UCLASS_SPI, + .of_match = mt7620_spi_ids, + .ops = &mt7620_spi_ops, + .priv_auto_alloc_size = sizeof(struct mt7620_spi), + .probe = mt7620_spi_probe, +};
Thanks, Stefan
+config MT7620_SPI
- bool "MediaTek MT7620 SPI driver"
- help
- config MT7621_SPI bool "MediaTek MT7621 SPI driver" depends on SOC_MT7628
- Generic SPI driver for MediaTek MT7620 SoC
- u32 stat;
- u32 reserved0[3];
- u32 cfg;
- u32 ctl;
- u32 reserved1[2];
- u32 data;
- struct mt7620_spi_master_regs *m[MT7620_SPI_NUM_CS];
- unsigned int sys_freq;
- u32 wait_us;
- uint mode;
- uint speed;
- u32 rate, prescale, freq, tmo, cfg;
- /* Calculate the clock divsior */
- rate = DIV_ROUND_UP(ms->sys_freq, ms->speed);
- rate = roundup_pow_of_two(rate);
- prescale = ilog2(rate / 2);
- if (prescale > 6)
prescale = 6;
- /* Calculate the real clock, and usecs for one byte transaction */
- freq = ms->sys_freq >> (prescale + 1);
- tmo = DIV_ROUND_UP(8 * 1000000, freq);
- /* 10 times tolerance plus 100us */
- ms->wait_us = POLLING_SCALE * tmo + POLLING_FRAC_USEC;
- /* set SPI_CFG */
- cfg = prescale << SPI_CLK_S;
- switch (ms->mode & (SPI_CPOL | SPI_CPHA)) {
- case SPI_MODE_0:
cfg |= TX_CLK_EDGE;
break;
- case SPI_MODE_1:
cfg |= RX_CLK_EDGE;
break;
- case SPI_MODE_2:
break;
- case SPI_MODE_3:
break;
- if (!(ms->mode & SPI_LSB_FIRST))
cfg |= MSB_FIRST;
- writel(cfg, &ms->m[cs]->cfg);
- writel(SPI_HIGH, &ms->m[cs]->ctl);
- if (enable)
- if (ms->mode & SPI_CS_HIGH)
enable = !enable;
- if (enable)
- else
- struct mt7620_spi *ms = dev_get_priv(bus);
- ms->mode = mode;
- /* Mode 0 is buggy. Force to use mode 3 */
- if ((mode & SPI_MODE_3) == SPI_MODE_0)
- ms->speed = speed;
- u32 val;
- return readl_poll_timeout(&ms->m[cs]->stat, val, !(val & SPI_BUSY),
ms->wait_us);
- int ret;
- while (len) {
if (ret)
return ret;
len--;
size_t len)
- int ret;
- while (len) {
if (ret)
return ret;
len--;
- struct udevice *bus = dev->parent;
- int total_size = bitlen >> 3;
- int cs, ret = 0;
- if (dout && din) {
return -EIO;
- cs = spi_chip_select(dev);
- if (cs < 0 || cs >= MT7620_SPI_NUM_CS) {
return -EINVAL;
- if (flags & SPI_XFER_BEGIN)
- if (din)
- else if (dout)
- if (ret)
- if (flags & SPI_XFER_END)
- return ret;
- struct mt7620_spi *ms = dev_get_priv(dev);
- struct clk clk;
- int ret;
- ms->regs = dev_remap_addr(dev);
- if (!ms->regs)
return -EINVAL;
- ms->m[0] = ms->regs + MT7620_SPI_MASTER1_OFF;
- ms->m[1] = ms->regs + MT7620_SPI_MASTER2_OFF;
- ret = clk_get_by_index(dev, 0, &clk);
- if (ret < 0) {
return ret;
- clk_enable(&clk);
- ms->sys_freq = clk_get_rate(&clk);
- if (!ms->sys_freq) {
return -EINVAL;
- writel(ARB_EN, ms->regs + SPI_ARB);
- .set_mode = mt7620_spi_set_mode,
- .set_speed = mt7620_spi_set_speed,
- .xfer = mt7620_spi_xfer,
- { .compatible = "mediatek,mt7620-spi" },
- .name = "mt7620_spi",
- .id = UCLASS_SPI,
- .of_match = mt7620_spi_ids,
- .ops = &mt7620_spi_ops,
- .priv_auto_alloc_size = sizeof(struct mt7620_spi),
- .probe = mt7620_spi_probe,
Viele Grüße, Stefan
This patch adds USB PHY driver for MediaTek MT7620 SoC
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v3 changes: remove duplicated dev field in mt7620_usb_phy v2 changes: none --- drivers/phy/Kconfig | 7 +++ drivers/phy/Makefile | 1 + drivers/phy/mt7620-usb-phy.c | 110 +++++++++++++++++++++++++++++++++++ 3 files changed, 118 insertions(+) create mode 100644 drivers/phy/mt7620-usb-phy.c
diff --git a/drivers/phy/Kconfig b/drivers/phy/Kconfig index d12a6b02ad..ab638f0e7d 100644 --- a/drivers/phy/Kconfig +++ b/drivers/phy/Kconfig @@ -218,6 +218,13 @@ config KEYSTONE_USB_PHY
This PHY is found on some Keystone (K2) devices supporting USB.
+config MT7620_USB_PHY + bool "MediaTek MT7620 USB PHY support" + depends on PHY + depends on SOC_MT7620 + help + Support the intergated USB PHY in MediaTek MT7620 SoC + config MT76X8_USB_PHY bool "MediaTek MT76x8 (7628/88) USB PHY support" depends on PHY diff --git a/drivers/phy/Makefile b/drivers/phy/Makefile index 45a7fe5b56..6b3761b8c8 100644 --- a/drivers/phy/Makefile +++ b/drivers/phy/Makefile @@ -24,6 +24,7 @@ obj-$(CONFIG_MESON_G12A_USB_PHY) += meson-g12a-usb2.o meson-g12a-usb3-pcie.o obj-$(CONFIG_MSM8916_USB_PHY) += msm8916-usbh-phy.o obj-$(CONFIG_OMAP_USB2_PHY) += omap-usb2-phy.o obj-$(CONFIG_KEYSTONE_USB_PHY) += keystone-usb-phy.o +obj-$(CONFIG_MT7620_USB_PHY) += mt7620-usb-phy.o obj-$(CONFIG_MT76X8_USB_PHY) += mt76x8-usb-phy.o obj-$(CONFIG_PHY_DA8XX_USB) += phy-da8xx-usb.o obj-$(CONFIG_PHY_MTK_TPHY) += phy-mtk-tphy.o diff --git a/drivers/phy/mt7620-usb-phy.c b/drivers/phy/mt7620-usb-phy.c new file mode 100644 index 0000000000..8320df177d --- /dev/null +++ b/drivers/phy/mt7620-usb-phy.c @@ -0,0 +1,110 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020 MediaTek Inc. All Rights Reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#include <clk.h> +#include <dm.h> +#include <generic-phy.h> +#include <misc.h> +#include <reset.h> +#include <dm/device_compat.h> +#include <linux/delay.h> +#include <mach/mt7620-sysc.h> + +struct mt7620_usb_phy { + struct udevice *sysc; + struct clk_bulk clocks; + struct reset_ctl_bulk resets; +}; + +static int mt7620_usb_phy_power_on(struct phy *_phy) +{ + struct mt7620_usb_phy *phy = dev_get_priv(_phy->dev); + u32 mode = MT7620_SYSC_USB_HOST_MODE; + int ret; + + reset_deassert_bulk(&phy->resets); + + clk_enable_bulk(&phy->clocks); + + mdelay(10); + + ret = misc_ioctl(phy->sysc, MT7620_SYSC_IOCTL_SET_USB_MODE, &mode); + if (ret) { + dev_err(_phy->dev, + "mt7620_usbphy: failed to set USB host mode\n"); + return ret; + } + + mdelay(10); + + return 0; +} + +static int mt7620_usb_phy_power_off(struct phy *_phy) +{ + struct mt7620_usb_phy *phy = dev_get_priv(_phy->dev); + + clk_disable_bulk(&phy->clocks); + + reset_assert_bulk(&phy->resets); + + return 0; +} + +static int mt7620_usb_phy_probe(struct udevice *dev) +{ + struct mt7620_usb_phy *phy = dev_get_priv(dev); + struct ofnode_phandle_args sysc_args; + int ret; + + ret = ofnode_parse_phandle_with_args(dev->node, "mediatek,sysc", NULL, + 0, 0, &sysc_args); + if (ret) { + dev_err(dev, "mt7620_usbphy: sysc property not found\n"); + return ret; + } + + ret = uclass_get_device_by_ofnode(UCLASS_MISC, sysc_args.node, + &phy->sysc); + if (ret) { + dev_err(dev, "mt7620_usbphy: failed to sysc device\n"); + return ret; + } + + ret = clk_get_bulk(dev, &phy->clocks); + if (ret) { + dev_err(dev, "mt7620_usbphy: failed to get clocks\n"); + return ret; + } + + ret = reset_get_bulk(dev, &phy->resets); + if (ret) { + dev_err(dev, "mt7620_usbphy: failed to get reset control\n"); + return ret; + } + + return 0; +} + +static struct phy_ops mt7620_usb_phy_ops = { + .power_on = mt7620_usb_phy_power_on, + .power_off = mt7620_usb_phy_power_off, +}; + +static const struct udevice_id mt7620_usb_phy_ids[] = { + { .compatible = "mediatek,mt7620-usbphy" }, + { } +}; + +U_BOOT_DRIVER(mt7620_usb_phy) = { + .name = "mt7620_usb_phy", + .id = UCLASS_PHY, + .of_match = mt7620_usb_phy_ids, + .ops = &mt7620_usb_phy_ops, + .probe = mt7620_usb_phy_probe, + .priv_auto_alloc_size = sizeof(struct mt7620_usb_phy), +};
Thanks, Stefan
- bool "MediaTek MT7620 USB PHY support"
- depends on PHY
- help
- config MT76X8_USB_PHY bool "MediaTek MT76x8 (7628/88) USB PHY support" depends on PHY
- struct clk_bulk clocks;
- struct reset_ctl_bulk resets;
- struct mt7620_usb_phy *phy = dev_get_priv(_phy->dev);
- u32 mode = MT7620_SYSC_USB_HOST_MODE;
- int ret;
- reset_deassert_bulk(&phy->resets);
- clk_enable_bulk(&phy->clocks);
- mdelay(10);
- ret = misc_ioctl(phy->sysc, MT7620_SYSC_IOCTL_SET_USB_MODE, &mode);
- if (ret) {
dev_err(_phy->dev,
return ret;
- mdelay(10);
- clk_disable_bulk(&phy->clocks);
- reset_assert_bulk(&phy->resets);
- struct mt7620_usb_phy *phy = dev_get_priv(dev);
- int ret;
0, 0, &sysc_args);
- if (ret) {
return ret;
&phy->sysc);
- if (ret) {
return ret;
- ret = clk_get_bulk(dev, &phy->clocks);
- if (ret) {
return ret;
- ret = reset_get_bulk(dev, &phy->resets);
- if (ret) {
return ret;
- .power_on = mt7620_usb_phy_power_on,
- .power_off = mt7620_usb_phy_power_off,
- { .compatible = "mediatek,mt7620-usbphy" },
- .name = "mt7620_usb_phy",
- .id = UCLASS_PHY,
- .of_match = mt7620_usb_phy_ids,
- .ops = &mt7620_usb_phy_ops,
- .probe = mt7620_usb_phy_probe,
- .priv_auto_alloc_size = sizeof(struct mt7620_usb_phy),
Viele Grüße, Stefan
This patch adds ethernet driver for MediaTek MT7620 SoC.
The MT7620 SoC has a built-in ethernet (Frame Engine) and a built-in 7-port switch and two xMII interfaces (can be MII/RMII/RGMII).
The port 0-3 of the switch connects to intergrited FE PHYs. Port 4 can be configured to connect to either the intergrited FE PHY, or the xMII. Port 5 always connects to the xMII. Port 6 is the CPU port.
This driver supports MT7530 giga switch connects to port 5.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v3 changes: none v2 changes: none --- drivers/net/Kconfig | 12 + drivers/net/Makefile | 1 + drivers/net/mt7620-eth.c | 1222 ++++++++++++++++++++++++++++++++++++++ 3 files changed, 1235 insertions(+) create mode 100644 drivers/net/mt7620-eth.c
diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index 3a5e036880..d1a52c7264 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -399,6 +399,18 @@ config MACB_ZYNQ The Cadence MACB ethernet interface was used on Zynq platform. Say Y to enable support for the MACB/GEM in Zynq chip.
+config MT7620_ETH + bool "MediaTek MT7620 Ethernet Interface" + depends on SOC_MT7620 + select PHYLIB + select DM_RESET + select DM_GPIO + select CLK + help + The MediaTek MT7620 ethernet interface is used on MT7620 based + boards. It has a built-in switch with two configurable ports which + can connect to external PHY/MACs. + config MT7628_ETH bool "MediaTek MT7628 Ethernet Interface" depends on SOC_MT7628 diff --git a/drivers/net/Makefile b/drivers/net/Makefile index e3bdda359d..f2a0df509d 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -44,6 +44,7 @@ obj-$(CONFIG_MDIO_IPQ4019) += mdio-ipq4019.o obj-$(CONFIG_MDIO_MUX_I2CREG) += mdio_mux_i2creg.o obj-$(CONFIG_MDIO_MUX_SANDBOX) += mdio_mux_sandbox.o obj-$(CONFIG_MPC8XX_FEC) += mpc8xx_fec.o +obj-$(CONFIG_MT7620_ETH) += mt7620-eth.o obj-$(CONFIG_MT7628_ETH) += mt7628-eth.o obj-$(CONFIG_MVGBE) += mvgbe.o obj-$(CONFIG_MVMDIO) += mvmdio.o diff --git a/drivers/net/mt7620-eth.c b/drivers/net/mt7620-eth.c new file mode 100644 index 0000000000..2c148a3b35 --- /dev/null +++ b/drivers/net/mt7620-eth.c @@ -0,0 +1,1222 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020 MediaTek Inc. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#include <cpu_func.h> +#include <dm.h> +#include <clk.h> +#include <malloc.h> +#include <miiphy.h> +#include <misc.h> +#include <net.h> +#include <reset.h> +#include <asm/addrspace.h> +#include <asm/cache.h> +#include <asm/gpio.h> +#include <dm/device_compat.h> +#include <linux/bitfield.h> +#include <linux/bitops.h> +#include <linux/delay.h> +#include <linux/err.h> +#include <linux/ethtool.h> +#include <linux/io.h> +#include <linux/iopoll.h> +#include <linux/mdio.h> +#include <linux/mii.h> +#include <mach/mt7620-sysc.h> + +/* Frame Engine block */ +#define GDMA_BASE 0x600 +#define PDMA_BASE 0x800 + +/* GDMA registers */ +#define GDMA_FWD_CFG 0x00 +#define GDMA_DST_PORT GENMASK(2, 0) +#define GDMA_DST_PORT_CPU 0 + +#define GDMA_MAC_ADRL 0x08 +#define GDMA_MAC_ADRH 0x0c + +/* PDMA registers */ +#define TX_BASE_PTR0 0x000 +#define TX_MAX_CNT0 0x004 +#define TX_CTX_IDX0 0x008 +#define TX_DTX_IDX0 0x00c +#define RX_BASE_PTR0 0x100 +#define RX_MAX_CNT0 0x104 +#define RX_CALC_IDX0 0x108 +#define RX_DRX_IDX0 0x10c + +#define PDMA_GLO_CFG 0x204 +#define TX_WB_DDONE BIT(6) +#define PDMA_BT_SIZE GENMASK(5, 4) +#define PDMA_BT_SIZE_32B 1 +#define RX_DMA_BUSY BIT(3) +#define RX_DMA_EN BIT(2) +#define TX_DMA_BUSY BIT(1) +#define TX_DMA_EN BIT(0) + +#define PDMA_RST_IDX 0x208 +#define RST_DRX_IDX0 BIT(16) +#define RST_DTX_IDX0 BIT(0) + +/* Built-in giga ethernet switch block */ + +/* ARL registers */ +#define GSW_MFC 0x0010 +#define BC_FFP GENMASK(31, 24) +#define UNM_FFP GENMASK(23, 16) +#define UNU_FFP GENMASK(15, 8) +#define CPU_EN BIT(7) +#define CPU_PORT GENMASK(6, 4) + +/* Port registers */ +#define GSW_PCR(p) (0x2004 + (p) * 0x100) +#define PORT_MATRIX GENMASK(23, 16) + +#define GSW_PVC(p) (0x2010 + (p) * 0x100) +#define STAG_VPID GENMASK(31, 16) +#define VLAN_ATTR GENMASK(7, 6) +#define VLAN_ATTR_USER 0 + +/* MAC registers */ +#define GSW_PMCR(p) (0x3000 + (p) * 0x100) +#define IPG_CFG GENMASK(19, 18) +#define IPG_96BIT_WITH_SHORT_IPG 1 +#define MAC_MODE BIT(16) +#define FORCE_MODE BIT(15) +#define MAC_TX_EN BIT(14) +#define MAC_RX_EN BIT(13) +#define BKOFF_EN BIT(9) +#define BACKPR_EN BIT(8) +#define FORCE_EEE1G BIT(7) +#define FORCE_EEE100 BIT(6) +#define FORCE_RX_FC BIT(5) +#define FORCE_TX_FC BIT(4) +#define FORCE_SPEED GENMASK(3, 2) +#define FORCE_SPEED_1000 2 +#define FORCE_SPEED_100 1 +#define FORCE_SPEED_10 0 +#define FORCE_DUPLEX BIT(1) +#define FORCE_LINK BIT(0) + +/* GMAC registers */ +#define GSW_PPSC 0x7000 +#define PHY_AP_EN BIT(31) +#define PHY_PRE_EN BIT(30) +#define PHY_MDC_CFG GENMASK(29, 24) +#define EPHY_AP_EN BIT(23) +#define EE_AN_EN BIT(16) +#define PHY_AP_END_ADDR GENMASK(12, 8) +#define PHY_AP_START_ADDR GENMASK(4, 0) + +#define GSW_PIAC 0x7004 +#define PHY_ACS_ST BIT(31) +#define MDIO_REG_ADDR GENMASK(29, 25) +#define MDIO_PHY_ADDR GENMASK(24, 20) +#define MDIO_CMD GENMASK(19, 18) +#define MDIO_CMD_WRITE 1 +#define MDIO_CMD_READ 2 +#define MDIO_ST GENMASK(17, 16) +#define MDIO_RW_DATA GENMASK(15, 0) + +#define GSW_GPC1 0x7014 +#define PHY_DIS GENMASK(28, 24) +#define PHY_BASE GENMASK(20, 16) +#define TX_CLK_MODE BIT(3) +#define RX_CLK_MODE BIT(2) + +/* MII Registers for MDIO clause 45 indirect access */ +#define MII_MMD_ACC_CTL_REG 0x0d +#define MMD_OP_MODE GENMASK(15, 14) +#define MMD_ADDR 0 +#define MMD_DATA 1 +#define MMD_DATA_RW_POST_INC 2 +#define MMD_DATA_W_POST_INC 3 +#define MMD_DEVAD GENMASK(4, 0) + +#define MII_MMD_ADDR_DATA_REG 0x0e + +/* MT7530 internal register access */ +#define MT7530_REG_PAGE_ADDR GENMASK(15, 6) +#define MT7530_REG_ADDR GENMASK(5, 2) + +/* MT7530 system control registers*/ +#define MT7530_SYS_CTRL 0x7000 +#define SW_SYS_RST BIT(1) +#define SW_REG_RST BIT(0) + +#define MT7530_MHWTRAP 0x7804 +#define P5_INTF_SEL_GMAC5 BIT(13) +#define P5_INTF_DIS BIT(6) + +struct pdma_txd_info1 { + u32 SDP0; +}; + +struct pdma_txd_info2 { + u32 SDL1 : 14; + u32 LS1 : 1; + u32 BURST : 1; + u32 SDL0 : 14; + u32 LS0 : 1; + u32 DDONE : 1; +}; + +struct pdma_txd_info3 { + u32 SDP1; +}; + +struct pdma_txd_info4 { + u32 VPRI_VIDX : 8; + u32 SIDX : 4; + u32 INSP : 1; + u32 RESV : 2; + u32 UDF : 5; + u32 FP_BMAP : 8; + u32 TSO : 1; + u32 TUI_CO : 3; +}; + +struct pdma_tx_desc { + struct pdma_txd_info1 txd_info1; + struct pdma_txd_info2 txd_info2; + struct pdma_txd_info3 txd_info3; + struct pdma_txd_info4 txd_info4; +}; + +struct pdma_rxd_info1 { + u32 PDP0; +}; + +struct pdma_rxd_info2 { + u32 PLEN1 : 14; + u32 LS1 : 1; + u32 UN_USED : 1; + u32 PLEN0 : 14; + u32 LS0 : 1; + u32 DDONE : 1; +}; + +struct pdma_rxd_info3 { + u32 PDP1; +}; + +struct pdma_rxd_info4 { + u32 FOE_ENTRY : 14; + u32 CRSN : 5; + u32 SP : 3; + u32 L4F : 1; + u32 L4VLD : 1; + u32 TACK : 1; + u32 IP4F : 1; + u32 IP4 : 1; + u32 IP6 : 1; + u32 UN_USED : 4; +}; + +struct pdma_rx_desc { + struct pdma_rxd_info1 rxd_info1; + struct pdma_rxd_info2 rxd_info2; + struct pdma_rxd_info3 rxd_info3; + struct pdma_rxd_info4 rxd_info4; +}; + +struct mt7620_gsw_port_cfg { + phy_interface_t mode; + bool force_mode; + bool duplex; + u32 speed; + int phy_addr; +}; + +struct mt7620_eth_priv { + struct udevice *dev; + + void __iomem *fe_base; + void __iomem *gsw_base; + + struct mii_dev *mdio_bus; + + struct pdma_tx_desc *tx_ring_noc; + struct pdma_rx_desc *rx_ring_noc; + + int rx_dma_owner_idx0; + int tx_cpu_owner_idx0; + + void *pkt_buf; + void *tx_ring; + void *rx_ring; + + struct reset_ctl_bulk rsts; + struct clk_bulk clks; + + struct udevice *sysc; + + u32 ephy_num; + bool port5_mt7530; + struct gpio_desc gpio_swrst; + struct mt7620_gsw_port_cfg port_cfg[3]; +}; + +#define PDMA_TIMEOUT 100000 + +#define NUM_TX_DESC 64 +#define NUM_RX_DESC 128 +#define NUM_FE_PHYS 5 +#define NUM_PORTS 7 +#define CPU_PORT_NUM 6 + +#define NUM_MT7530_PHYS 5 + +static void pdma_write(struct mt7620_eth_priv *priv, u32 reg, u32 val) +{ + writel(val, priv->fe_base + PDMA_BASE + reg); +} + +static void gdma_write(struct mt7620_eth_priv *priv, u32 reg, u32 val) +{ + writel(val, priv->fe_base + GDMA_BASE + reg); +} + +static void gdma_rmw(struct mt7620_eth_priv *priv, u32 reg, u32 clr, u32 set) +{ + clrsetbits_le32(priv->fe_base + GDMA_BASE + reg, clr, set); +} + +static u32 gsw_read(struct mt7620_eth_priv *priv, u32 reg) +{ + return readl(priv->gsw_base + reg); +} + +static void gsw_write(struct mt7620_eth_priv *priv, u32 reg, u32 val) +{ + writel(val, priv->gsw_base + reg); +} + +static void gsw_rmw(struct mt7620_eth_priv *priv, u32 reg, u32 clr, u32 set) +{ + clrsetbits_le32(priv->gsw_base + reg, clr, set); +} + +static int mt7620_mdio_rw(struct mt7620_eth_priv *priv, u32 phy, u32 reg, + u32 data, u32 cmd) +{ + int ret; + u32 val; + + val = FIELD_PREP(MDIO_ST, 1) | FIELD_PREP(MDIO_CMD, cmd) | + FIELD_PREP(MDIO_PHY_ADDR, phy) | + FIELD_PREP(MDIO_REG_ADDR, reg); + + if (cmd == MDIO_CMD_WRITE) + val |= FIELD_PREP(MDIO_RW_DATA, data); + + gsw_write(priv, GSW_PIAC, val); + gsw_write(priv, GSW_PIAC, val | PHY_ACS_ST); + + ret = readl_poll_timeout(priv->gsw_base + GSW_PIAC, val, + !(val & PHY_ACS_ST), 10000); + if (ret) { + dev_err(priv->dev, "mt7620_eth: MDIO access timeout\n"); + return ret; + } + + if (cmd == MDIO_CMD_READ) { + val = gsw_read(priv, GSW_PIAC); + return FIELD_GET(MDIO_RW_DATA, val); + } + + return 0; +} + +static int mt7620_mii_read(struct mt7620_eth_priv *priv, u32 phy, u32 reg) +{ + return mt7620_mdio_rw(priv, phy, reg, 0, MDIO_CMD_READ); +} + +static int mt7620_mii_write(struct mt7620_eth_priv *priv, u32 phy, u32 reg, + u16 val) +{ + return mt7620_mdio_rw(priv, phy, reg, val, MDIO_CMD_WRITE); +} + +static int mt7620_mdio_read(struct mii_dev *bus, int addr, int devad, int reg) +{ + struct mt7620_eth_priv *priv = bus->priv; + int ret; + + if (devad < 0) + return mt7620_mdio_rw(priv, addr, reg, 0, MDIO_CMD_READ); + + ret = mt7620_mdio_rw(priv, addr, MII_MMD_ACC_CTL_REG, + FIELD_PREP(MMD_OP_MODE, MMD_ADDR) | + FIELD_PREP(MMD_DEVAD, devad), MDIO_CMD_WRITE); + if (ret) + return ret; + + ret = mt7620_mdio_rw(priv, addr, MII_MMD_ADDR_DATA_REG, reg, + MDIO_CMD_WRITE); + if (ret) + return ret; + + ret = mt7620_mdio_rw(priv, addr, MII_MMD_ACC_CTL_REG, + FIELD_PREP(MMD_OP_MODE, MMD_DATA) | + FIELD_PREP(MMD_DEVAD, devad), MDIO_CMD_WRITE); + if (ret) + return ret; + + return mt7620_mdio_rw(priv, addr, MII_MMD_ADDR_DATA_REG, 0, + MDIO_CMD_READ); +} + +static int mt7620_mdio_write(struct mii_dev *bus, int addr, int devad, int reg, + u16 val) +{ + struct mt7620_eth_priv *priv = bus->priv; + int ret; + + if (devad < 0) + return mt7620_mdio_rw(priv, addr, reg, val, MDIO_CMD_WRITE); + + ret = mt7620_mdio_rw(priv, addr, MII_MMD_ACC_CTL_REG, + FIELD_PREP(MMD_OP_MODE, MMD_ADDR) | + FIELD_PREP(MMD_DEVAD, devad), MDIO_CMD_WRITE); + if (ret) + return ret; + + ret = mt7620_mdio_rw(priv, addr, MII_MMD_ADDR_DATA_REG, reg, + MDIO_CMD_WRITE); + if (ret) + return ret; + + ret = mt7620_mdio_rw(priv, addr, MII_MMD_ACC_CTL_REG, + FIELD_PREP(MMD_OP_MODE, MMD_DATA) | + FIELD_PREP(MMD_DEVAD, devad), MDIO_CMD_WRITE); + if (ret) + return ret; + + return mt7620_mdio_rw(priv, addr, MII_MMD_ADDR_DATA_REG, val, + MDIO_CMD_WRITE); +} + +static int mt7620_mdio_register(struct udevice *dev) +{ + struct mt7620_eth_priv *priv = dev_get_priv(dev); + struct mii_dev *mdio_bus = mdio_alloc(); + int ret; + + if (!mdio_bus) + return -ENOMEM; + + mdio_bus->read = mt7620_mdio_read; + mdio_bus->write = mt7620_mdio_write; + snprintf(mdio_bus->name, sizeof(mdio_bus->name), dev->name); + + mdio_bus->priv = (void *)priv; + + ret = mdio_register(mdio_bus); + + if (ret) + return ret; + + priv->mdio_bus = mdio_bus; + + return 0; +} + +static int mt7530_reg_read(struct mt7620_eth_priv *priv, u32 reg, u32 *data) +{ + int ret, low_word, high_word; + + /* Write page address */ + ret = mt7620_mii_write(priv, 0x1f, 0x1f, + FIELD_GET(MT7530_REG_PAGE_ADDR, reg)); + if (ret) + return ret; + + /* Read low word */ + low_word = mt7620_mii_read(priv, 0x1f, FIELD_GET(MT7530_REG_ADDR, reg)); + if (low_word < 0) + return low_word; + + /* Read high word */ + high_word = mt7620_mii_read(priv, 0x1f, 0x10); + if (high_word < 0) + return high_word; + + if (data) + *data = ((u32)high_word << 16) | ((u32)low_word & 0xffff); + + return 0; +} + +static int mt7530_reg_write(struct mt7620_eth_priv *priv, u32 reg, u32 data) +{ + int ret; + + /* Write page address */ + ret = mt7620_mii_write(priv, 0x1f, 0x1f, + FIELD_GET(MT7530_REG_PAGE_ADDR, reg)); + if (ret) + return ret; + + /* Write low word */ + ret = mt7620_mii_write(priv, 0x1f, FIELD_GET(MT7530_REG_ADDR, reg), + data & 0xffff); + if (ret) + return ret; + + /* Write high word */ + return mt7620_mii_write(priv, 0x1f, 0x10, data >> 16); +} + +static void mt7620_phy_restart_an(struct mt7620_eth_priv *priv, u32 phy) +{ + u16 val; + + val = mt7620_mii_read(priv, phy, MII_BMCR); + val |= BMCR_ANRESTART; + mt7620_mii_write(priv, phy, MII_BMCR, val); +} + +static void mt7620_gsw_ephy_init(struct mt7620_eth_priv *priv) +{ + struct mt7620_sysc_chip_rev chip_rev; + int ret; + u32 i; + + ret = misc_ioctl(priv->sysc, MT7620_SYSC_IOCTL_GET_CHIP_REV, &chip_rev); + if (ret) { + /* Assume MT7620A if misc_ioctl() failed */ + dev_warn(priv->dev, "mt7620_eth: failed to get chip rev\n"); + chip_rev.bga = 1; + } + + /* global, page 4 */ + mt7620_mii_write(priv, 1, 31, 0x4000); + mt7620_mii_write(priv, 1, 17, 0x7444); + + if (chip_rev.bga) + mt7620_mii_write(priv, 1, 19, 0x0114); + else + mt7620_mii_write(priv, 1, 19, 0x0117); + + mt7620_mii_write(priv, 1, 22, 0x10cf); + mt7620_mii_write(priv, 1, 25, 0x6212); + mt7620_mii_write(priv, 1, 26, 0x0777); + mt7620_mii_write(priv, 1, 29, 0x4000); + mt7620_mii_write(priv, 1, 28, 0xc077); + mt7620_mii_write(priv, 1, 24, 0x0000); + + /* global, page 3 */ + mt7620_mii_write(priv, 1, 31, 0x3000); + mt7620_mii_write(priv, 1, 17, 0x4838); + + /* global, page 2 */ + mt7620_mii_write(priv, 1, 31, 0x2000); + + if (chip_rev.bga) { + mt7620_mii_write(priv, 1, 21, 0x0515); + mt7620_mii_write(priv, 1, 22, 0x0053); + mt7620_mii_write(priv, 1, 23, 0x00bf); + mt7620_mii_write(priv, 1, 24, 0x0aaf); + mt7620_mii_write(priv, 1, 25, 0x0fad); + mt7620_mii_write(priv, 1, 26, 0x0fc1); + } else { + mt7620_mii_write(priv, 1, 21, 0x0517); + mt7620_mii_write(priv, 1, 22, 0x0fd2); + mt7620_mii_write(priv, 1, 23, 0x00bf); + mt7620_mii_write(priv, 1, 24, 0x0aab); + mt7620_mii_write(priv, 1, 25, 0x00ae); + mt7620_mii_write(priv, 1, 26, 0x0fff); + } + + /* global, page 1 */ + mt7620_mii_write(priv, 1, 31, 0x1000); + mt7620_mii_write(priv, 1, 17, 0xe7f8); + + /* local, page 0 */ + mt7620_mii_write(priv, 1, 31, 0x8000); + for (i = 0; i < priv->ephy_num; i++) + mt7620_mii_write(priv, i, 30, 0xa000); + + for (i = 0; i < priv->ephy_num; i++) + mt7620_mii_write(priv, i, 4, 0x05e1); + + /* local, page 2 */ + mt7620_mii_write(priv, 1, 31, 0xa000); + mt7620_mii_write(priv, 0, 16, 0x1111); + mt7620_mii_write(priv, 1, 16, 0x1010); + mt7620_mii_write(priv, 2, 16, 0x1515); + mt7620_mii_write(priv, 3, 16, 0x0f0f); + if (priv->ephy_num == NUM_FE_PHYS) + mt7620_mii_write(priv, 4, 16, 0x1313); + + /* Restart auto-negotiation */ + for (i = 0; i < priv->ephy_num; i++) + mt7620_phy_restart_an(priv, i); + + if (priv->port_cfg[0].phy_addr > 0) + mt7620_phy_restart_an(priv, priv->port_cfg[0].phy_addr); + + if (priv->port_cfg[1].phy_addr > 0) + mt7620_phy_restart_an(priv, priv->port_cfg[1].phy_addr); +} + +static int mt7620_setup_gmac_mode(struct mt7620_eth_priv *priv, u32 gmac, + phy_interface_t mode) +{ + enum mt7620_sysc_ge_mode ge_mode; + unsigned long req; + int ret; + + switch (gmac) { + case 1: + req = MT7620_SYSC_IOCTL_SET_GE1_MODE; + break; + case 2: + req = MT7620_SYSC_IOCTL_SET_GE2_MODE; + break; + default: + /* Should not reach here */ + return -EINVAL; + } + + switch (mode) { + case PHY_INTERFACE_MODE_MII: + ge_mode = MT7620_SYSC_GE_MII; + break; + case PHY_INTERFACE_MODE_RMII: + ge_mode = MT7620_SYSC_GE_RMII; + break; + case PHY_INTERFACE_MODE_RGMII: + ge_mode = MT7620_SYSC_GE_RGMII; + break; + case PHY_INTERFACE_MODE_NONE: + if (gmac == 2) + ge_mode = MT7620_SYSC_GE_ESW_PHY; + else + ge_mode = MT7620_SYSC_GE_RGMII; + break; + default: + /* Should not reach here */ + return -EINVAL; + } + + ret = misc_ioctl(priv->sysc, req, &ge_mode); + if (ret) + dev_warn(priv->dev, "mt7620_eth: failed to set GE%u mode\n", + gmac); + + return 0; +} + +static void mt7620_gsw_setup_port(struct mt7620_eth_priv *priv, u32 port, + struct mt7620_gsw_port_cfg *port_cfg) +{ + u32 pmcr; + + if (port_cfg->mode == PHY_INTERFACE_MODE_NONE) { + if (port == 5) { + gsw_write(priv, GSW_PMCR(port), FORCE_MODE); + return; + } + + port_cfg->force_mode = port == CPU_PORT_NUM ? true : false; + } + + pmcr = FIELD_PREP(IPG_CFG, IPG_96BIT_WITH_SHORT_IPG) | MAC_MODE | + MAC_TX_EN | MAC_RX_EN | BKOFF_EN | BACKPR_EN; + + if (port_cfg->force_mode) { + pmcr |= FORCE_MODE | FORCE_RX_FC | FORCE_TX_FC | + FIELD_PREP(FORCE_SPEED, port_cfg->speed) | FORCE_LINK; + + if (port_cfg->duplex) + pmcr |= FORCE_DUPLEX; + } + + gsw_write(priv, GSW_PMCR(port), pmcr); +} + +static void mt7620_gsw_set_port_isolation(struct mt7620_eth_priv *priv) +{ + u32 i; + + for (i = 0; i < NUM_PORTS; i++) { + /* Set port matrix mode */ + if (i != CPU_PORT_NUM) + gsw_write(priv, GSW_PCR(i), + FIELD_PREP(PORT_MATRIX, 0x40)); + else + gsw_write(priv, GSW_PCR(i), + FIELD_PREP(PORT_MATRIX, 0x3f)); + + /* Set port mode to user port */ + gsw_write(priv, GSW_PVC(i), FIELD_PREP(STAG_VPID, 0x8100) | + FIELD_PREP(VLAN_ATTR, VLAN_ATTR_USER)); + } +} + +static void mt7620_gsw_setup_phy_polling(struct mt7620_eth_priv *priv) +{ + int phy_addr_st, phy_addr_end; + + if (priv->port_cfg[0].mode == PHY_INTERFACE_MODE_NONE) + priv->ephy_num = NUM_FE_PHYS; + else + priv->ephy_num = NUM_FE_PHYS - 1; + + if (priv->port_cfg[0].phy_addr < 0 && priv->port_cfg[1].phy_addr < 0) + return; + + if (priv->port_cfg[0].phy_addr > 0 && priv->port_cfg[1].phy_addr > 0) { + phy_addr_st = priv->port_cfg[0].phy_addr; + phy_addr_end = priv->port_cfg[1].phy_addr; + } else if (priv->port_cfg[0].phy_addr > 0) { + phy_addr_st = priv->port_cfg[0].phy_addr; + phy_addr_end = priv->port_cfg[0].phy_addr + 1; + } else { + phy_addr_st = 4; + phy_addr_end = priv->port_cfg[1].phy_addr; + } + + gsw_rmw(priv, GSW_PPSC, PHY_AP_END_ADDR | PHY_AP_START_ADDR, + PHY_AP_EN | FIELD_PREP(PHY_AP_START_ADDR, phy_addr_st) | + FIELD_PREP(PHY_AP_END_ADDR, phy_addr_end)); +} + +static void mt7530_gsw_set_port_isolation(struct mt7620_eth_priv *priv) +{ + u32 i; + + for (i = 0; i < NUM_PORTS; i++) { + /* Set port matrix mode */ + if (i != CPU_PORT_NUM) + mt7530_reg_write(priv, GSW_PCR(i), + FIELD_PREP(PORT_MATRIX, 0x40)); + else + mt7530_reg_write(priv, GSW_PCR(i), + FIELD_PREP(PORT_MATRIX, 0x3f)); + + /* Set port mode to user port */ + mt7530_reg_write(priv, GSW_PVC(i), + FIELD_PREP(STAG_VPID, 0x8100) | + FIELD_PREP(VLAN_ATTR, VLAN_ATTR_USER)); + } +} + +static void mt7620_gsw_config_mt7530(struct mt7620_eth_priv *priv) +{ + u16 phy_val; + u32 i, val; + + /* Disable internal PHY, set PHY base to 12 */ + gsw_write(priv, GSW_GPC1, PHY_DIS | FIELD_PREP(PHY_BASE, 12) | + TX_CLK_MODE | RX_CLK_MODE); + + /* MT7530 reset deassert */ + dm_gpio_set_value(&priv->gpio_swrst, 1); + mdelay(1000); + + /* Turn off PHYs */ + for (i = 0; i < NUM_MT7530_PHYS; i++) { + phy_val = mt7620_mii_read(priv, i, MII_BMCR); + phy_val |= BMCR_PDOWN; + mt7620_mii_write(priv, i, MII_BMCR, phy_val); + } + + /* Force MAC link down before reset */ + mt7530_reg_write(priv, GSW_PMCR(5), FORCE_MODE); + mt7530_reg_write(priv, GSW_PMCR(6), FORCE_MODE); + + /* MT7530 soft reset */ + mt7530_reg_write(priv, MT7530_SYS_CTRL, SW_SYS_RST | SW_REG_RST); + udelay(100); + + /* MT7530 port6 force to 1G (connects to MT7620 GSW port5) */ + mt7530_reg_write(priv, GSW_PMCR(6), + FIELD_PREP(IPG_CFG, IPG_96BIT_WITH_SHORT_IPG) | + MAC_MODE | FORCE_MODE | MAC_TX_EN | MAC_RX_EN | + BKOFF_EN | BACKPR_EN | FORCE_RX_FC | FORCE_TX_FC | + FIELD_PREP(FORCE_SPEED, FORCE_SPEED_1000) | + FORCE_DUPLEX | FORCE_LINK); + + /* Disable MT7530 port5 */ + mt7530_reg_read(priv, MT7530_MHWTRAP, &val); + val |= P5_INTF_SEL_GMAC5 | P5_INTF_DIS; + mt7530_reg_write(priv, MT7530_MHWTRAP, val); + + /* Isolate each ports */ + mt7530_gsw_set_port_isolation(priv); + + /* Turn on PHYs */ + for (i = 0; i < NUM_MT7530_PHYS; i++) { + phy_val = mt7620_mii_read(priv, i, MII_BMCR); + phy_val &= ~BMCR_PDOWN; + mt7620_mii_write(priv, i, MII_BMCR, phy_val); + } + /* Restart auto-negotiation */ + for (i = 0; i < NUM_MT7530_PHYS; i++) + mt7620_phy_restart_an(priv, i); +} + +static void mt7620_gsw_init(struct mt7620_eth_priv *priv) +{ + /* If port5 connects to MT7530 Giga-switch, reset it first */ + if (priv->port5_mt7530) + dm_gpio_set_value(&priv->gpio_swrst, 0); + + /* Set forward control */ + gsw_write(priv, GSW_MFC, FIELD_PREP(BC_FFP, 0x7f) | + FIELD_PREP(UNM_FFP, 0x7f) | FIELD_PREP(UNU_FFP, 0x7f) | + CPU_EN | FIELD_PREP(CPU_PORT, CPU_PORT_NUM)); + + /* Set GMAC mode (GMAC1 -> Port5, GMAC2 -> Port4) */ + mt7620_setup_gmac_mode(priv, 1, priv->port_cfg[1].mode); + mt7620_setup_gmac_mode(priv, 2, priv->port_cfg[0].mode); + + /* port_cfg[2] is CPU port */ + priv->port_cfg[2].force_mode = true; + priv->port_cfg[2].duplex = true; + priv->port_cfg[2].speed = FORCE_SPEED_1000; + + /* Configure GSW MAC port */ + mt7620_gsw_setup_port(priv, 4, &priv->port_cfg[0]); + mt7620_gsw_setup_port(priv, 5, &priv->port_cfg[1]); + mt7620_gsw_setup_port(priv, 6, &priv->port_cfg[2]); + + /* Isolate each port */ + mt7620_gsw_set_port_isolation(priv); + + /* Polling external phy if exists */ + mt7620_gsw_setup_phy_polling(priv); + + /* Configure ephy */ + mt7620_gsw_ephy_init(priv); + + /* If port5 connects to MT7530 Giga-switch, do initialization */ + if (priv->port5_mt7530) + mt7620_gsw_config_mt7530(priv); +} + +static void mt7620_eth_fifo_init(struct mt7620_eth_priv *priv) +{ + uintptr_t pkt_base = (uintptr_t)priv->pkt_buf; + int i; + + memset(priv->tx_ring, 0, NUM_TX_DESC * sizeof(struct pdma_tx_desc)); + memset(priv->rx_ring, 0, NUM_RX_DESC * sizeof(struct pdma_rx_desc)); + memset(priv->pkt_buf, 0, (NUM_TX_DESC + NUM_RX_DESC) * PKTSIZE_ALIGN); + + priv->tx_ring_noc = (void *)CKSEG1ADDR((uintptr_t)priv->tx_ring); + priv->rx_ring_noc = (void *)CKSEG1ADDR((uintptr_t)priv->rx_ring); + priv->rx_dma_owner_idx0 = 0; + priv->tx_cpu_owner_idx0 = 0; + + for (i = 0; i < NUM_TX_DESC; i++) { + priv->tx_ring_noc[i].txd_info2.LS0 = 1; + priv->tx_ring_noc[i].txd_info2.DDONE = 1; + priv->tx_ring_noc[i].txd_info4.FP_BMAP = GDMA_DST_PORT_CPU; + priv->tx_ring_noc[i].txd_info1.SDP0 = CPHYSADDR(pkt_base); + pkt_base += PKTSIZE_ALIGN; + } + + for (i = 0; i < NUM_RX_DESC; i++) { + priv->rx_ring_noc[i].rxd_info2.PLEN0 = PKTSIZE_ALIGN; + priv->rx_ring_noc[i].rxd_info1.PDP0 = CPHYSADDR(pkt_base); + pkt_base += PKTSIZE_ALIGN; + } + + pdma_write(priv, TX_BASE_PTR0, CPHYSADDR(priv->tx_ring_noc)); + pdma_write(priv, TX_MAX_CNT0, NUM_TX_DESC); + pdma_write(priv, TX_CTX_IDX0, priv->tx_cpu_owner_idx0); + + pdma_write(priv, RX_BASE_PTR0, CPHYSADDR(priv->rx_ring_noc)); + pdma_write(priv, RX_MAX_CNT0, NUM_RX_DESC); + pdma_write(priv, RX_CALC_IDX0, NUM_RX_DESC - 1); + + pdma_write(priv, PDMA_RST_IDX, RST_DTX_IDX0 | RST_DRX_IDX0); +} + +static int mt7620_eth_start(struct udevice *dev) +{ + struct mt7620_eth_priv *priv = dev_get_priv(dev); + + mt7620_eth_fifo_init(priv); + + gdma_rmw(priv, GDMA_FWD_CFG, GDMA_DST_PORT, + FIELD_PREP(GDMA_DST_PORT, GDMA_DST_PORT_CPU)); + + pdma_write(priv, PDMA_GLO_CFG, + FIELD_PREP(PDMA_BT_SIZE, PDMA_BT_SIZE_32B) | + TX_WB_DDONE | RX_DMA_EN | TX_DMA_EN); + udelay(500); + + return 0; +} + +static void mt7620_eth_stop(struct udevice *dev) +{ + struct mt7620_eth_priv *priv = dev_get_priv(dev); + u32 val; + int ret; + + pdma_write(priv, PDMA_GLO_CFG, + FIELD_PREP(PDMA_BT_SIZE, PDMA_BT_SIZE_32B)); + udelay(500); + + ret = readl_poll_timeout(priv->fe_base + PDMA_BASE + PDMA_GLO_CFG, + val, !(val & (RX_DMA_BUSY | TX_DMA_BUSY)), + PDMA_TIMEOUT); + if (ret) + dev_warn(dev, "mt7620_eth: PDMA is still busy\n"); +} + +static int mt7620_eth_write_hwaddr(struct udevice *dev) +{ + struct eth_pdata *pdata = dev_get_platdata(dev); + struct mt7620_eth_priv *priv = dev_get_priv(dev); + unsigned char *mac = pdata->enetaddr; + u32 macaddr_lsb, macaddr_msb; + + macaddr_msb = ((u32)mac[0] << 8) | (u32)mac[1]; + macaddr_lsb = ((u32)mac[2] << 24) | ((u32)mac[3] << 16) | + ((u32)mac[4] << 8) | (u32)mac[5]; + + gdma_write(priv, GDMA_MAC_ADRH, macaddr_msb); + gdma_write(priv, GDMA_MAC_ADRL, macaddr_lsb); + + return 0; +} + +static int mt7620_eth_send(struct udevice *dev, void *packet, int length) +{ + struct mt7620_eth_priv *priv = dev_get_priv(dev); + u32 idx = priv->tx_cpu_owner_idx0; + void *pkt_base; + + if (!priv->tx_ring_noc[idx].txd_info2.DDONE) { + printf("mt7620_eth: TX DMA descriptor ring is full\n"); + return -EPERM; + } + + pkt_base = (void *)CKSEG0ADDR(priv->tx_ring_noc[idx].txd_info1.SDP0); + memcpy(pkt_base, packet, length); + flush_dcache_range((ulong)pkt_base, (ulong)pkt_base + length); + + priv->tx_ring_noc[idx].txd_info2.SDL0 = length; + priv->tx_ring_noc[idx].txd_info2.DDONE = 0; + + priv->tx_cpu_owner_idx0 = (priv->tx_cpu_owner_idx0 + 1) % NUM_TX_DESC; + pdma_write(priv, TX_CTX_IDX0, priv->tx_cpu_owner_idx0); + + return 0; +} + +static int mt7620_eth_recv(struct udevice *dev, int flags, uchar **packetp) +{ + struct mt7620_eth_priv *priv = dev_get_priv(dev); + u32 idx = priv->rx_dma_owner_idx0, length; + uchar *pkt_base; + + if (!priv->rx_ring_noc[idx].rxd_info2.DDONE) { + debug("mt7620_eth: RX DMA descriptor ring is empty\n"); + return -EAGAIN; + } + + length = priv->rx_ring_noc[idx].rxd_info2.PLEN0; + pkt_base = (void *)CKSEG0ADDR(priv->rx_ring_noc[idx].rxd_info1.PDP0); + invalidate_dcache_range((ulong)pkt_base, (ulong)pkt_base + length); + + if (packetp) + *packetp = pkt_base; + + return length; +} + +static int mt7620_eth_free_pkt(struct udevice *dev, uchar *packet, int length) +{ + struct mt7620_eth_priv *priv = dev_get_priv(dev); + u32 idx = priv->rx_dma_owner_idx0; + + priv->rx_ring_noc[idx].rxd_info2.DDONE = 0; + priv->rx_ring_noc[idx].rxd_info2.LS0 = 0; + priv->rx_ring_noc[idx].rxd_info2.PLEN0 = PKTSIZE_ALIGN; + + pdma_write(priv, RX_CALC_IDX0, idx); + priv->rx_dma_owner_idx0 = (priv->rx_dma_owner_idx0 + 1) % NUM_RX_DESC; + + return 0; +} + +static const struct eth_ops mt7620_eth_ops = { + .start = mt7620_eth_start, + .stop = mt7620_eth_stop, + .send = mt7620_eth_send, + .recv = mt7620_eth_recv, + .free_pkt = mt7620_eth_free_pkt, + .write_hwaddr = mt7620_eth_write_hwaddr, +}; + +static int mt7620_eth_alloc_rings_pkts(struct mt7620_eth_priv *priv) +{ + priv->tx_ring = memalign(ARCH_DMA_MINALIGN, + NUM_TX_DESC * sizeof(struct pdma_tx_desc)); + if (!priv->tx_ring) { + dev_err(priv->dev, "mt7620_eth: unable to alloc tx ring\n"); + return -ENOMEM; + } + + priv->rx_ring = memalign(ARCH_DMA_MINALIGN, + NUM_RX_DESC * sizeof(struct pdma_rx_desc)); + if (!priv->rx_ring) { + dev_err(priv->dev, "mt7620_eth: unable to alloc rx ring\n"); + goto cleanup; + } + + priv->pkt_buf = memalign(ARCH_DMA_MINALIGN, + (NUM_TX_DESC + NUM_RX_DESC) * PKTSIZE_ALIGN); + if (!priv->pkt_buf) { + dev_err(priv->dev, "mt7620_eth: unable to alloc pkt buffer\n"); + goto cleanup; + } + + return 0; + +cleanup: + if (priv->tx_ring) + free(priv->tx_ring); + + if (priv->rx_ring) + free(priv->rx_ring); + + return -ENOMEM; +} + +static void mt7620_eth_free_rings_pkts(struct mt7620_eth_priv *priv) +{ + free(priv->tx_ring); + free(priv->rx_ring); + free(priv->pkt_buf); +} + +static int mt7620_eth_probe(struct udevice *dev) +{ + struct mt7620_eth_priv *priv = dev_get_priv(dev); + u32 pcie_mode = MT7620_SYSC_PCIE_RC_MODE; + int ret; + + misc_ioctl(priv->sysc, MT7620_SYSC_IOCTL_SET_PCIE_MODE, &pcie_mode); + + clk_enable_bulk(&priv->clks); + + reset_assert_bulk(&priv->rsts); + udelay(100); + reset_deassert_bulk(&priv->rsts); + udelay(1000); + + ret = mt7620_eth_alloc_rings_pkts(priv); + if (ret) + return ret; + + ret = mt7620_mdio_register(dev); + if (ret) + dev_warn(dev, "mt7620_eth: failed to register MDIO bus\n"); + + mt7620_gsw_init(priv); + + return 0; +} + +static int mt7620_eth_remove(struct udevice *dev) +{ + struct mt7620_eth_priv *priv = dev_get_priv(dev); + + mt7620_eth_stop(dev); + + mt7620_eth_free_rings_pkts(priv); + + return 0; +} + +static int mt7620_eth_parse_gsw_port(struct mt7620_eth_priv *priv, u32 idx, + ofnode node) +{ + ofnode subnode; + const char *str; + int mode, speed, ret; + u32 phy_addr; + + str = ofnode_read_string(node, "phy-mode"); + if (str) { + mode = phy_get_interface_by_name(str); + if (mode < 0) { + dev_err(priv->dev, "mt7620_eth: invalid phy-mode\n"); + return -EINVAL; + } + + switch (mode) { + case PHY_INTERFACE_MODE_MII: + case PHY_INTERFACE_MODE_RMII: + case PHY_INTERFACE_MODE_RGMII: + case PHY_INTERFACE_MODE_NONE: + break; + default: + dev_err(priv->dev, + "mt7620_eth: unsupported phy-mode\n"); + return -ENOTSUPP; + } + + priv->port_cfg[idx].mode = mode; + } else { + priv->port_cfg[idx].mode = PHY_INTERFACE_MODE_NONE; + } + + subnode = ofnode_find_subnode(node, "fixed-link"); + if (ofnode_valid(subnode)) { + priv->port_cfg[idx].force_mode = 1; + priv->port_cfg[idx].duplex = ofnode_read_bool(subnode, + "full-duplex"); + speed = ofnode_read_u32_default(subnode, "speed", 0); + switch (speed) { + case SPEED_10: + priv->port_cfg[idx].speed = FORCE_SPEED_10; + break; + case SPEED_100: + priv->port_cfg[idx].speed = FORCE_SPEED_100; + break; + case SPEED_1000: + priv->port_cfg[idx].speed = FORCE_SPEED_1000; + break; + default: + dev_err(priv->dev, + "mt7620_eth: invalid speed for fixed-link\n"); + return -EINVAL; + } + + if (idx == 1 && ofnode_read_bool(subnode, "mediatek,mt7530")) { + priv->port5_mt7530 = true; + + ret = gpio_request_by_name_nodev(subnode, + "mediatek,mt7530-reset", 0, &priv->gpio_swrst, + GPIOD_IS_OUT); + if (ret) { + dev_err(priv->dev, + "mt7620_eth: missing mt7530 reset gpio\n"); + return ret; + } + } + } + + ret = ofnode_read_u32(node, "phy-addr", &phy_addr); + if (!ret) { + if (phy_addr > 31 || (idx == 0 && phy_addr < 3) || + (idx == 1 && phy_addr < 4)) { + dev_err(priv->dev, "mt7620_eth: invalid phy address\n"); + return -EINVAL; + } + + priv->port_cfg[idx].phy_addr = phy_addr; + } else { + priv->port_cfg[idx].phy_addr = -1; + } + + return 0; +} + +static int mt7620_eth_parse_gsw_cfg(struct udevice *dev) +{ + struct mt7620_eth_priv *priv = dev_get_priv(dev); + ofnode subnode; + int ret; + + subnode = ofnode_find_subnode(dev_ofnode(dev), "port4"); + if (ofnode_valid(subnode)) { + ret = mt7620_eth_parse_gsw_port(priv, 0, subnode); + if (ret) + return ret; + } else { + priv->port_cfg[0].mode = PHY_INTERFACE_MODE_NONE; + } + + subnode = ofnode_find_subnode(dev_ofnode(dev), "port5"); + if (ofnode_valid(subnode)) + return mt7620_eth_parse_gsw_port(priv, 1, subnode); + + priv->port_cfg[1].mode = PHY_INTERFACE_MODE_NONE; + return 0; +} + +static int mt7620_eth_ofdata_to_platdata(struct udevice *dev) +{ + struct eth_pdata *pdata = dev_get_platdata(dev); + struct mt7620_eth_priv *priv = dev_get_priv(dev); + struct ofnode_phandle_args sysc_args; + int ret; + + pdata->iobase = dev_read_addr(dev); + + priv->dev = dev; + + ret = ofnode_parse_phandle_with_args(dev->node, "mediatek,sysc", NULL, + 0, 0, &sysc_args); + if (ret) { + dev_err(dev, "mt7620_eth: sysc property not found\n"); + return ret; + } + + ret = uclass_get_device_by_ofnode(UCLASS_MISC, sysc_args.node, + &priv->sysc); + if (ret) { + dev_err(dev, "mt7620_eth: failed to sysc device\n"); + return ret; + } + + priv->fe_base = dev_remap_addr_name(dev, "fe"); + if (!priv->fe_base) { + dev_err(dev, "mt7620_eth: failed to map fe registers\n"); + return -EINVAL; + } + + priv->gsw_base = dev_remap_addr_name(dev, "esw"); + if (!priv->gsw_base) { + dev_err(dev, "mt7620_eth: failed to map esw registers\n"); + return -EINVAL; + } + + ret = reset_get_bulk(dev, &priv->rsts); + if (ret) { + dev_err(dev, "mt7620_eth: failed to get resetctl\n"); + return ret; + } + + ret = clk_get_bulk(dev, &priv->clks); + if (ret) { + dev_err(dev, "mt7620_eth: failed to get clocks\n"); + return ret; + } + + return mt7620_eth_parse_gsw_cfg(dev); +} + +static const struct udevice_id mt7620_eth_ids[] = { + { .compatible = "mediatek,mt7620-eth" }, + {} +}; + +U_BOOT_DRIVER(mt7620_eth) = { + .name = "mt7620-eth", + .id = UCLASS_ETH, + .of_match = mt7620_eth_ids, + .ofdata_to_platdata = mt7620_eth_ofdata_to_platdata, + .platdata_auto_alloc_size = sizeof(struct eth_pdata), + .probe = mt7620_eth_probe, + .remove = mt7620_eth_remove, + .ops = &mt7620_eth_ops, + .priv_auto_alloc_size = sizeof(struct mt7620_eth_priv), +};
Thanks, Stefan
+config MT7620_ETH
- bool "MediaTek MT7620 Ethernet Interface"
- depends on SOC_MT7620
- select PHYLIB
- select DM_RESET
- select DM_GPIO
- select CLK
- help
- config MT7628_ETH bool "MediaTek MT7628 Ethernet Interface" depends on SOC_MT7628
- u32 SDP0;
- u32 SDL1 : 14;
- u32 LS1 : 1;
- u32 BURST : 1;
- u32 SDL0 : 14;
- u32 LS0 : 1;
- u32 DDONE : 1;
- u32 SDP1;
- u32 VPRI_VIDX : 8;
- u32 SIDX : 4;
- u32 INSP : 1;
- u32 RESV : 2;
- u32 UDF : 5;
- u32 FP_BMAP : 8;
- u32 TSO : 1;
- u32 TUI_CO : 3;
- struct pdma_txd_info1 txd_info1;
- struct pdma_txd_info2 txd_info2;
- struct pdma_txd_info3 txd_info3;
- struct pdma_txd_info4 txd_info4;
- u32 PDP0;
- u32 PLEN1 : 14;
- u32 LS1 : 1;
- u32 UN_USED : 1;
- u32 PLEN0 : 14;
- u32 LS0 : 1;
- u32 DDONE : 1;
- u32 PDP1;
- u32 FOE_ENTRY : 14;
- u32 CRSN : 5;
- u32 SP : 3;
- u32 L4F : 1;
- u32 L4VLD : 1;
- u32 TACK : 1;
- u32 IP4F : 1;
- u32 IP4 : 1;
- u32 IP6 : 1;
- u32 UN_USED : 4;
- struct pdma_rxd_info1 rxd_info1;
- struct pdma_rxd_info2 rxd_info2;
- struct pdma_rxd_info3 rxd_info3;
- struct pdma_rxd_info4 rxd_info4;
- phy_interface_t mode;
- bool force_mode;
- bool duplex;
- u32 speed;
- int phy_addr;
- struct udevice *dev;
- void __iomem *fe_base;
- void __iomem *gsw_base;
- struct mii_dev *mdio_bus;
- struct pdma_tx_desc *tx_ring_noc;
- struct pdma_rx_desc *rx_ring_noc;
- int rx_dma_owner_idx0;
- int tx_cpu_owner_idx0;
- void *pkt_buf;
- void *tx_ring;
- void *rx_ring;
- struct reset_ctl_bulk rsts;
- struct clk_bulk clks;
- struct udevice *sysc;
- u32 ephy_num;
- bool port5_mt7530;
- struct gpio_desc gpio_swrst;
- struct mt7620_gsw_port_cfg port_cfg[3];
- writel(val, priv->fe_base + PDMA_BASE + reg);
- writel(val, priv->fe_base + GDMA_BASE + reg);
- clrsetbits_le32(priv->fe_base + GDMA_BASE + reg, clr, set);
- return readl(priv->gsw_base + reg);
- writel(val, priv->gsw_base + reg);
- clrsetbits_le32(priv->gsw_base + reg, clr, set);
u32 data, u32 cmd)
- int ret;
- u32 val;
- val = FIELD_PREP(MDIO_ST, 1) | FIELD_PREP(MDIO_CMD, cmd) |
- if (cmd == MDIO_CMD_WRITE)
- gsw_write(priv, GSW_PIAC, val);
- gsw_write(priv, GSW_PIAC, val | PHY_ACS_ST);
- ret = readl_poll_timeout(priv->gsw_base + GSW_PIAC, val,
- if (ret) {
return ret;
- if (cmd == MDIO_CMD_READ) {
- return mt7620_mdio_rw(priv, phy, reg, 0, MDIO_CMD_READ);
u16 val)
- return mt7620_mdio_rw(priv, phy, reg, val, MDIO_CMD_WRITE);
- struct mt7620_eth_priv *priv = bus->priv;
- int ret;
- if (devad < 0)
- ret = mt7620_mdio_rw(priv, addr, MII_MMD_ACC_CTL_REG,
- if (ret)
return ret;
- ret = mt7620_mdio_rw(priv, addr, MII_MMD_ADDR_DATA_REG, reg,
MDIO_CMD_WRITE);
- if (ret)
return ret;
- if (ret)
return ret;
- return mt7620_mdio_rw(priv, addr, MII_MMD_ADDR_DATA_REG, 0,
MDIO_CMD_READ);
u16 val)
- int ret;
- if (devad < 0)
- if (ret)
return ret;
MDIO_CMD_WRITE);
- if (ret)
return ret;
- if (ret)
return ret;
- return mt7620_mdio_rw(priv, addr, MII_MMD_ADDR_DATA_REG, val,
MDIO_CMD_WRITE);
- struct mt7620_eth_priv *priv = dev_get_priv(dev);
- struct mii_dev *mdio_bus = mdio_alloc();
- int ret;
- if (!mdio_bus)
return -ENOMEM;
- mdio_bus->read = mt7620_mdio_read;
- mdio_bus->write = mt7620_mdio_write;
- snprintf(mdio_bus->name, sizeof(mdio_bus->name), dev->name);
- mdio_bus->priv = (void *)priv;
- ret = mdio_register(mdio_bus);
- if (ret)
return ret;
- priv->mdio_bus = mdio_bus;
- int ret, low_word, high_word;
- /* Write page address */
- ret = mt7620_mii_write(priv, 0x1f, 0x1f,
- if (ret)
return ret;
- /* Read low word */
- low_word = mt7620_mii_read(priv, 0x1f, FIELD_GET(MT7530_REG_ADDR, reg));
- if (low_word < 0)
return low_word;
- /* Read high word */
- high_word = mt7620_mii_read(priv, 0x1f, 0x10);
- if (high_word < 0)
return high_word;
- if (data)
- int ret;
- if (ret)
return ret;
- /* Write low word */
- ret = mt7620_mii_write(priv, 0x1f, FIELD_GET(MT7530_REG_ADDR, reg),
data & 0xffff);
- if (ret)
return ret;
- /* Write high word */
- return mt7620_mii_write(priv, 0x1f, 0x10, data >> 16);
- u16 val;
- val = mt7620_mii_read(priv, phy, MII_BMCR);
- val |= BMCR_ANRESTART;
- mt7620_mii_write(priv, phy, MII_BMCR, val);
- struct mt7620_sysc_chip_rev chip_rev;
- int ret;
- u32 i;
- ret = misc_ioctl(priv->sysc, MT7620_SYSC_IOCTL_GET_CHIP_REV, &chip_rev);
- if (ret) {
chip_rev.bga = 1;
- mt7620_mii_write(priv, 1, 31, 0x4000);
- mt7620_mii_write(priv, 1, 17, 0x7444);
- if (chip_rev.bga)
- else
- mt7620_mii_write(priv, 1, 22, 0x10cf);
- mt7620_mii_write(priv, 1, 25, 0x6212);
- mt7620_mii_write(priv, 1, 26, 0x0777);
- mt7620_mii_write(priv, 1, 29, 0x4000);
- mt7620_mii_write(priv, 1, 28, 0xc077);
- mt7620_mii_write(priv, 1, 24, 0x0000);
- /* global, page 3 */
- mt7620_mii_write(priv, 1, 31, 0x3000);
- mt7620_mii_write(priv, 1, 17, 0x4838);
- /* global, page 2 */
- mt7620_mii_write(priv, 1, 31, 0x2000);
- if (chip_rev.bga) {
- } else {
- /* global, page 1 */
- mt7620_mii_write(priv, 1, 31, 0x1000);
- mt7620_mii_write(priv, 1, 17, 0xe7f8);
- /* local, page 0 */
- mt7620_mii_write(priv, 1, 31, 0x8000);
- for (i = 0; i < priv->ephy_num; i++)
- /* local, page 2 */
- mt7620_mii_write(priv, 1, 31, 0xa000);
- mt7620_mii_write(priv, 0, 16, 0x1111);
- mt7620_mii_write(priv, 1, 16, 0x1010);
- mt7620_mii_write(priv, 2, 16, 0x1515);
- mt7620_mii_write(priv, 3, 16, 0x0f0f);
- if (priv->ephy_num == NUM_FE_PHYS)
- /* Restart auto-negotiation */
- if (priv->port_cfg[0].phy_addr > 0)
- if (priv->port_cfg[1].phy_addr > 0)
- enum mt7620_sysc_ge_mode ge_mode;
- unsigned long req;
- int ret;
- switch (gmac) {
- case 1:
break;
- case 2:
break;
- default:
return -EINVAL;
- switch (mode) {
- case PHY_INTERFACE_MODE_MII:
break;
- case PHY_INTERFACE_MODE_RMII:
break;
- case PHY_INTERFACE_MODE_RGMII:
break;
- case PHY_INTERFACE_MODE_NONE:
if (gmac == 2)
else
break;
- default:
return -EINVAL;
- ret = misc_ioctl(priv->sysc, req, &ge_mode);
- if (ret)
gmac);
- u32 pmcr;
- if (port_cfg->mode == PHY_INTERFACE_MODE_NONE) {
if (port == 5) {
return;
- pmcr = FIELD_PREP(IPG_CFG, IPG_96BIT_WITH_SHORT_IPG) | MAC_MODE |
- if (port_cfg->force_mode) {
- gsw_write(priv, GSW_PMCR(port), pmcr);
- u32 i;
- for (i = 0; i < NUM_PORTS; i++) {
else
- int phy_addr_st, phy_addr_end;
- if (priv->port_cfg[0].mode == PHY_INTERFACE_MODE_NONE)
- else
- if (priv->port_cfg[0].phy_addr < 0 && priv->port_cfg[1].phy_addr < 0)
return;
- if (priv->port_cfg[0].phy_addr > 0 && priv->port_cfg[1].phy_addr > 0) {
- } else if (priv->port_cfg[0].phy_addr > 0) {
- } else {
phy_addr_st = 4;
- gsw_rmw(priv, GSW_PPSC, PHY_AP_END_ADDR | PHY_AP_START_ADDR,
- u32 i;
else
- u16 phy_val;
- u32 i, val;
- /* Disable internal PHY, set PHY base to 12 */
- gsw_write(priv, GSW_GPC1, PHY_DIS | FIELD_PREP(PHY_BASE, 12) |
- /* MT7530 reset deassert */
- dm_gpio_set_value(&priv->gpio_swrst, 1);
- mdelay(1000);
- /* Turn off PHYs */
- for (i = 0; i < NUM_MT7530_PHYS; i++) {
- /* Force MAC link down before reset */
- mt7530_reg_write(priv, GSW_PMCR(5), FORCE_MODE);
- mt7530_reg_write(priv, GSW_PMCR(6), FORCE_MODE);
- /* MT7530 soft reset */
- mt7530_reg_write(priv, MT7530_SYS_CTRL, SW_SYS_RST | SW_REG_RST);
- udelay(100);
- /* MT7530 port6 force to 1G (connects to MT7620 GSW port5) */
- /* Disable MT7530 port5 */
- mt7530_reg_read(priv, MT7530_MHWTRAP, &val);
- val |= P5_INTF_SEL_GMAC5 | P5_INTF_DIS;
- mt7530_reg_write(priv, MT7530_MHWTRAP, val);
- /* Isolate each ports */
- mt7530_gsw_set_port_isolation(priv);
- /* Turn on PHYs */
- /* If port5 connects to MT7530 Giga-switch, reset it first */
- if (priv->port5_mt7530)
- /* Set forward control */
- gsw_write(priv, GSW_MFC, FIELD_PREP(BC_FFP, 0x7f) |
- /* Set GMAC mode (GMAC1 -> Port5, GMAC2 -> Port4) */
- mt7620_setup_gmac_mode(priv, 1, priv->port_cfg[1].mode);
- mt7620_setup_gmac_mode(priv, 2, priv->port_cfg[0].mode);
- /* port_cfg[2] is CPU port */
- priv->port_cfg[2].force_mode = true;
- priv->port_cfg[2].duplex = true;
- priv->port_cfg[2].speed = FORCE_SPEED_1000;
- /* Configure GSW MAC port */
- mt7620_gsw_setup_port(priv, 4, &priv->port_cfg[0]);
- mt7620_gsw_setup_port(priv, 5, &priv->port_cfg[1]);
- mt7620_gsw_setup_port(priv, 6, &priv->port_cfg[2]);
- /* Isolate each port */
- mt7620_gsw_set_port_isolation(priv);
- /* Polling external phy if exists */
- mt7620_gsw_setup_phy_polling(priv);
- /* Configure ephy */
- mt7620_gsw_ephy_init(priv);
- /* If port5 connects to MT7530 Giga-switch, do initialization */
- uintptr_t pkt_base = (uintptr_t)priv->pkt_buf;
- int i;
- memset(priv->tx_ring, 0, NUM_TX_DESC * sizeof(struct pdma_tx_desc));
- memset(priv->rx_ring, 0, NUM_RX_DESC * sizeof(struct pdma_rx_desc));
- memset(priv->pkt_buf, 0, (NUM_TX_DESC + NUM_RX_DESC) * PKTSIZE_ALIGN);
- priv->tx_ring_noc = (void *)CKSEG1ADDR((uintptr_t)priv->tx_ring);
- priv->rx_ring_noc = (void *)CKSEG1ADDR((uintptr_t)priv->rx_ring);
- priv->rx_dma_owner_idx0 = 0;
- priv->tx_cpu_owner_idx0 = 0;
- for (i = 0; i < NUM_TX_DESC; i++) {
- for (i = 0; i < NUM_RX_DESC; i++) {
- pdma_write(priv, TX_BASE_PTR0, CPHYSADDR(priv->tx_ring_noc));
- pdma_write(priv, TX_MAX_CNT0, NUM_TX_DESC);
- pdma_write(priv, TX_CTX_IDX0, priv->tx_cpu_owner_idx0);
- pdma_write(priv, RX_BASE_PTR0, CPHYSADDR(priv->rx_ring_noc));
- pdma_write(priv, RX_MAX_CNT0, NUM_RX_DESC);
- pdma_write(priv, RX_CALC_IDX0, NUM_RX_DESC - 1);
- pdma_write(priv, PDMA_RST_IDX, RST_DTX_IDX0 | RST_DRX_IDX0);
- mt7620_eth_fifo_init(priv);
- gdma_rmw(priv, GDMA_FWD_CFG, GDMA_DST_PORT,
- pdma_write(priv, PDMA_GLO_CFG,
- udelay(500);
- u32 val;
- int ret;
- udelay(500);
- ret = readl_poll_timeout(priv->fe_base + PDMA_BASE + PDMA_GLO_CFG,
PDMA_TIMEOUT);
- if (ret)
- struct eth_pdata *pdata = dev_get_platdata(dev);
- unsigned char *mac = pdata->enetaddr;
- u32 macaddr_lsb, macaddr_msb;
- macaddr_msb = ((u32)mac[0] << 8) | (u32)mac[1];
- macaddr_lsb = ((u32)mac[2] << 24) | ((u32)mac[3] << 16) |
- gdma_write(priv, GDMA_MAC_ADRH, macaddr_msb);
- gdma_write(priv, GDMA_MAC_ADRL, macaddr_lsb);
- u32 idx = priv->tx_cpu_owner_idx0;
- void *pkt_base;
- if (!priv->tx_ring_noc[idx].txd_info2.DDONE) {
return -EPERM;
- pkt_base = (void *)CKSEG0ADDR(priv->tx_ring_noc[idx].txd_info1.SDP0);
- memcpy(pkt_base, packet, length);
- flush_dcache_range((ulong)pkt_base, (ulong)pkt_base + length);
- priv->tx_ring_noc[idx].txd_info2.SDL0 = length;
- priv->tx_ring_noc[idx].txd_info2.DDONE = 0;
- priv->tx_cpu_owner_idx0 = (priv->tx_cpu_owner_idx0 + 1) % NUM_TX_DESC;
- u32 idx = priv->rx_dma_owner_idx0, length;
- uchar *pkt_base;
- if (!priv->rx_ring_noc[idx].rxd_info2.DDONE) {
return -EAGAIN;
- length = priv->rx_ring_noc[idx].rxd_info2.PLEN0;
- pkt_base = (void *)CKSEG0ADDR(priv->rx_ring_noc[idx].rxd_info1.PDP0);
- invalidate_dcache_range((ulong)pkt_base, (ulong)pkt_base + length);
- if (packetp)
- return length;
- u32 idx = priv->rx_dma_owner_idx0;
- priv->rx_ring_noc[idx].rxd_info2.DDONE = 0;
- priv->rx_ring_noc[idx].rxd_info2.LS0 = 0;
- priv->rx_ring_noc[idx].rxd_info2.PLEN0 = PKTSIZE_ALIGN;
- pdma_write(priv, RX_CALC_IDX0, idx);
- priv->rx_dma_owner_idx0 = (priv->rx_dma_owner_idx0 + 1) % NUM_RX_DESC;
- .start = mt7620_eth_start,
- .stop = mt7620_eth_stop,
- .send = mt7620_eth_send,
- .recv = mt7620_eth_recv,
- .free_pkt = mt7620_eth_free_pkt,
- .write_hwaddr = mt7620_eth_write_hwaddr,
- priv->tx_ring = memalign(ARCH_DMA_MINALIGN,
- if (!priv->tx_ring) {
return -ENOMEM;
- priv->rx_ring = memalign(ARCH_DMA_MINALIGN,
- if (!priv->rx_ring) {
goto cleanup;
- priv->pkt_buf = memalign(ARCH_DMA_MINALIGN,
- if (!priv->pkt_buf) {
goto cleanup;
+cleanup:
- if (priv->tx_ring)
- if (priv->rx_ring)
- return -ENOMEM;
- free(priv->tx_ring);
- free(priv->rx_ring);
- free(priv->pkt_buf);
- u32 pcie_mode = MT7620_SYSC_PCIE_RC_MODE;
- int ret;
- misc_ioctl(priv->sysc, MT7620_SYSC_IOCTL_SET_PCIE_MODE, &pcie_mode);
- clk_enable_bulk(&priv->clks);
- reset_assert_bulk(&priv->rsts);
- udelay(100);
- reset_deassert_bulk(&priv->rsts);
- udelay(1000);
- ret = mt7620_eth_alloc_rings_pkts(priv);
- if (ret)
return ret;
- ret = mt7620_mdio_register(dev);
- if (ret)
- mt7620_gsw_init(priv);
- mt7620_eth_stop(dev);
- mt7620_eth_free_rings_pkts(priv);
ofnode node)
- ofnode subnode;
- const char *str;
- int mode, speed, ret;
- u32 phy_addr;
- str = ofnode_read_string(node, "phy-mode");
- if (str) {
if (mode < 0) {
return -EINVAL;
switch (mode) {
break;
default:
dev_err(priv->dev,
return -ENOTSUPP;
- } else {
- subnode = ofnode_find_subnode(node, "fixed-link");
- if (ofnode_valid(subnode)) {
"full-duplex");
switch (speed) {
case SPEED_10:
break;
case SPEED_100:
break;
case SPEED_1000:
break;
default:
dev_err(priv->dev,
return -EINVAL;
GPIOD_IS_OUT);
if (ret) {
dev_err(priv->dev,
return ret;
- ret = ofnode_read_u32(node, "phy-addr", &phy_addr);
- if (!ret) {
return -EINVAL;
- } else {
- ofnode subnode;
- int ret;
- subnode = ofnode_find_subnode(dev_ofnode(dev), "port4");
if (ret)
return ret;
- } else {
- subnode = ofnode_find_subnode(dev_ofnode(dev), "port5");
- priv->port_cfg[1].mode = PHY_INTERFACE_MODE_NONE;
- struct ofnode_phandle_args sysc_args;
- int ret;
- pdata->iobase = dev_read_addr(dev);
- priv->dev = dev;
- ret = ofnode_parse_phandle_with_args(dev->node, "mediatek,sysc", NULL,
0, 0, &sysc_args);
- if (ret) {
return ret;
- ret = uclass_get_device_by_ofnode(UCLASS_MISC, sysc_args.node,
&priv->sysc);
- if (ret) {
return ret;
- priv->fe_base = dev_remap_addr_name(dev, "fe");
- if (!priv->fe_base) {
return -EINVAL;
- priv->gsw_base = dev_remap_addr_name(dev, "esw");
- if (!priv->gsw_base) {
return -EINVAL;
- ret = reset_get_bulk(dev, &priv->rsts);
- if (ret) {
return ret;
- ret = clk_get_bulk(dev, &priv->clks);
- if (ret) {
return ret;
- return mt7620_eth_parse_gsw_cfg(dev);
- { .compatible = "mediatek,mt7620-eth" },
- .name = "mt7620-eth",
- .id = UCLASS_ETH,
- .of_match = mt7620_eth_ids,
- .ofdata_to_platdata = mt7620_eth_ofdata_to_platdata,
- .platdata_auto_alloc_size = sizeof(struct eth_pdata),
- .probe = mt7620_eth_probe,
- .remove = mt7620_eth_remove,
- .ops = &mt7620_eth_ops,
- .priv_auto_alloc_size = sizeof(struct mt7620_eth_priv),
Viele Grüße, Stefan
It turns out that the sclk cycles used by mt7620/mt7628 is the same as other chips (20 bits, 1048576), not 65536.
This patch removes sclk_cycle_shift from dev_comp, and uses a macro with a value 20 instead.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v3 changes: new --- drivers/mmc/mtk-sd.c | 13 ++++--------- 1 file changed, 4 insertions(+), 9 deletions(-)
diff --git a/drivers/mmc/mtk-sd.c b/drivers/mmc/mtk-sd.c index 4f9fa7d0ec..63ff68272c 100644 --- a/drivers/mmc/mtk-sd.c +++ b/drivers/mmc/mtk-sd.c @@ -166,6 +166,8 @@
#define DEFAULT_CD_DEBOUNCE 8
+#define SCLK_CYCLES_SHIFT 20 + #define CMD_INTS_MASK \ (MSDC_INT_CMDRDY | MSDC_INT_RSPCRCERR | MSDC_INT_CMDTMO)
@@ -256,7 +258,6 @@ struct msdc_top_regs {
struct msdc_compatible { u8 clk_div_bits; - u8 sclk_cycle_shift; bool pad_tune0; bool async_fifo; bool data_tune; @@ -722,7 +723,7 @@ static int msdc_ops_send_cmd(struct udevice *dev, struct mmc_cmd *cmd,
static void msdc_set_timeout(struct msdc_host *host, u32 ns, u32 clks) { - u32 timeout, clk_ns, shift; + u32 timeout, clk_ns, shift = SCLK_CYCLES_SHIFT; u32 mode = 0;
host->timeout_ns = ns; @@ -731,7 +732,6 @@ static void msdc_set_timeout(struct msdc_host *host, u32 ns, u32 clks) if (host->sclk == 0) { timeout = 0; } else { - shift = host->dev_comp->sclk_cycle_shift; clk_ns = 1000000000UL / host->sclk; timeout = (ns + clk_ns - 1) / clk_ns + clks; /* unit is 1048576 sclk cycles */ @@ -1531,7 +1531,7 @@ static int msdc_drv_probe(struct udevice *dev)
host->mmc = &plat->mmc; host->timeout_ns = 100000000; - host->timeout_clks = 3 * (1 << host->dev_comp->sclk_cycle_shift); + host->timeout_clks = 3 * (1 << SCLK_CYCLES_SHIFT);
#ifdef CONFIG_PINCTRL pinctrl_select_state(dev, "default"); @@ -1615,7 +1615,6 @@ static const struct dm_mmc_ops msdc_ops = {
static const struct msdc_compatible mt7620_compat = { .clk_div_bits = 8, - .sclk_cycle_shift = 16, .pad_tune0 = false, .async_fifo = false, .data_tune = false, @@ -1635,7 +1634,6 @@ static const struct msdc_compatible mt7622_compat = {
static const struct msdc_compatible mt7623_compat = { .clk_div_bits = 12, - .sclk_cycle_shift = 20, .pad_tune0 = true, .async_fifo = true, .data_tune = true, @@ -1646,7 +1644,6 @@ static const struct msdc_compatible mt7623_compat = {
static const struct msdc_compatible mt8512_compat = { .clk_div_bits = 12, - .sclk_cycle_shift = 20, .pad_tune0 = true, .async_fifo = true, .data_tune = true, @@ -1656,7 +1653,6 @@ static const struct msdc_compatible mt8512_compat = {
static const struct msdc_compatible mt8516_compat = { .clk_div_bits = 12, - .sclk_cycle_shift = 20, .pad_tune0 = true, .async_fifo = true, .data_tune = true, @@ -1666,7 +1662,6 @@ static const struct msdc_compatible mt8516_compat = {
static const struct msdc_compatible mt8183_compat = { .clk_div_bits = 12, - .sclk_cycle_shift = 20, .pad_tune0 = true, .async_fifo = true, .data_tune = true,
Thanks, Stefan
v3 changes: new
- #define CMD_INTS_MASK \ (MSDC_INT_CMDRDY | MSDC_INT_RSPCRCERR | MSDC_INT_CMDTMO)
clk_ns = 1000000000UL / host->sclk; timeout = (ns + clk_ns - 1) / clk_ns + clks; /* unit is 1048576 sclk cycles */shift = host->dev_comp->sclk_cycle_shift;
Viele Grüße, Stefan
The driver is missing pad control settings (pad delay and pad conf) for the mt7620 and mt76x8. Although mt76x8 still works well, mt7620 will encounter CRC error on data transfers.
This patch adds default pad control settings for mt7620_compat.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v3 changes: none v2 changes: none --- drivers/mmc/mtk-sd.c | 121 +++++++++++++++++++++++++++++++++++++++++-- 1 file changed, 118 insertions(+), 3 deletions(-)
diff --git a/drivers/mmc/mtk-sd.c b/drivers/mmc/mtk-sd.c index 63ff68272c..f4ff8822f2 100644 --- a/drivers/mmc/mtk-sd.c +++ b/drivers/mmc/mtk-sd.c @@ -113,7 +113,51 @@ #define MSDC_PB2_RESPWAIT_M 0x0c #define MSDC_PB2_RESPWAIT_S 2
+/* MSDC_PAD_CTRL0 */ +#define MSDC_PAD_CTRL0_CLKRDSEL_M 0xff000000 +#define MSDC_PAD_CTRL0_CLKRDSEL_S 24 +#define MSDC_PAD_CTRL0_CLKTDSEL BIT(20) +#define MSDC_PAD_CTRL0_CLKIES BIT(19) +#define MSDC_PAD_CTRL0_CLKSMT BIT(18) +#define MSDC_PAD_CTRL0_CLKPU BIT(17) +#define MSDC_PAD_CTRL0_CLKPD BIT(16) +#define MSDC_PAD_CTRL0_CLKSR BIT(8) +#define MSDC_PAD_CTRL0_CLKDRVP_M 0x70 +#define MSDC_PAD_CTRL0_CLKDRVP_S 4 +#define MSDC_PAD_CTRL0_CLKDRVN_M 0x7 +#define MSDC_PAD_CTRL0_CLKDRVN_S 0 + +/* MSDC_PAD_CTRL1 */ +#define MSDC_PAD_CTRL1_CMDRDSEL_M 0xff000000 +#define MSDC_PAD_CTRL1_CMDRDSEL_S 24 +#define MSDC_PAD_CTRL1_CMDTDSEL BIT(20) +#define MSDC_PAD_CTRL1_CMDIES BIT(19) +#define MSDC_PAD_CTRL1_CMDSMT BIT(18) +#define MSDC_PAD_CTRL1_CMDPU BIT(17) +#define MSDC_PAD_CTRL1_CMDPD BIT(16) +#define MSDC_PAD_CTRL1_CMDSR BIT(8) +#define MSDC_PAD_CTRL1_CMDDRVP_M 0x70 +#define MSDC_PAD_CTRL1_CMDDRVP_S 4 +#define MSDC_PAD_CTRL1_CMDDRVN_M 0x7 +#define MSDC_PAD_CTRL1_CMDDRVN_S 0 + +/* MSDC_PAD_CTRL2 */ +#define MSDC_PAD_CTRL2_DATRDSEL_M 0xff000000 +#define MSDC_PAD_CTRL2_DATRDSEL_S 24 +#define MSDC_PAD_CTRL2_DATTDSEL BIT(20) +#define MSDC_PAD_CTRL2_DATIES BIT(19) +#define MSDC_PAD_CTRL2_DATSMT BIT(18) +#define MSDC_PAD_CTRL2_DATPU BIT(17) +#define MSDC_PAD_CTRL2_DATPD BIT(16) +#define MSDC_PAD_CTRL2_DATSR BIT(8) +#define MSDC_PAD_CTRL2_DATDRVP_M 0x70 +#define MSDC_PAD_CTRL2_DATDRVP_S 4 +#define MSDC_PAD_CTRL2_DATDRVN_M 0x7 +#define MSDC_PAD_CTRL2_DATDRVN_S 0 + /* PAD_TUNE */ +#define MSDC_PAD_TUNE_CLKTDLY_M 0xf8000000 +#define MSDC_PAD_TUNE_CLKTDLY_S 27 #define MSDC_PAD_TUNE_CMDRRDLY_M 0x7c00000 #define MSDC_PAD_TUNE_CMDRRDLY_S 22 #define MSDC_PAD_TUNE_CMD_SEL BIT(21) @@ -129,6 +173,26 @@ #define PAD_CMD_TUNE_RX_DLY3 0x3E #define PAD_CMD_TUNE_RX_DLY3_S 1
+/* PAD_TUNE0 */ +#define MSDC_PAD_TUNE0_DAT0RDDLY_M 0x1f000000 +#define MSDC_PAD_TUNE0_DAT0RDDLY_S 24 +#define MSDC_PAD_TUNE0_DAT1RDDLY_M 0x1f0000 +#define MSDC_PAD_TUNE0_DAT1RDDLY_S 16 +#define MSDC_PAD_TUNE0_DAT2RDDLY_M 0x1f00 +#define MSDC_PAD_TUNE0_DAT2RDDLY_S 8 +#define MSDC_PAD_TUNE0_DAT3RDDLY_M 0x1f +#define MSDC_PAD_TUNE0_DAT3RDDLY_S 0 + +/* PAD_TUNE1 */ +#define MSDC_PAD_TUNE1_DAT4RDDLY_M 0x1f000000 +#define MSDC_PAD_TUNE1_DAT4RDDLY_S 24 +#define MSDC_PAD_TUNE1_DAT5RDDLY_M 0x1f0000 +#define MSDC_PAD_TUNE1_DAT5RDDLY_S 16 +#define MSDC_PAD_TUNE1_DAT6RDDLY_M 0x1f00 +#define MSDC_PAD_TUNE1_DAT6RDDLY_S 8 +#define MSDC_PAD_TUNE1_DAT7RDDLY_M 0x1f +#define MSDC_PAD_TUNE1_DAT7RDDLY_S 0 + /* EMMC50_CFG0 */ #define EMMC50_CFG_CFCSTS_SEL BIT(4)
@@ -223,7 +287,10 @@ struct mtk_sd_regs { u32 dat3_tune_crc; u32 cmd_tune_crc; u32 sdio_tune_wind; - u32 reserved4[5]; + u32 reserved4[2]; + u32 pad_ctrl0; + u32 pad_ctrl1; + u32 pad_ctrl2; u32 pad_tune; u32 pad_tune0; u32 pad_tune1; @@ -264,6 +331,8 @@ struct msdc_compatible { bool busy_check; bool stop_clk_fix; bool enhance_rx; + bool builtin_pad_ctrl; + bool default_pad_dly; };
struct msdc_delay_phase { @@ -1391,9 +1460,14 @@ static void msdc_init_hw(struct msdc_host *host) { u32 val; void __iomem *tune_reg = &host->base->pad_tune; + void __iomem *rd_dly0_reg = &host->base->pad_tune0; + void __iomem *rd_dly1_reg = &host->base->pad_tune1;
- if (host->dev_comp->pad_tune0) + if (host->dev_comp->pad_tune0) { tune_reg = &host->base->pad_tune0; + rd_dly0_reg = &host->base->dat_rd_dly[0]; + rd_dly1_reg = &host->base->dat_rd_dly[1]; + }
/* Configure to MMC/SD mode, clock free running */ setbits_le32(&host->base->msdc_cfg, MSDC_CFG_MODE); @@ -1479,6 +1553,45 @@ static void msdc_init_hw(struct msdc_host *host) setbits_le32(tune_reg, MSDC_PAD_TUNE_RXDLYSEL); }
+ if (host->dev_comp->builtin_pad_ctrl) { + /* Set pins driving strength */ + writel(MSDC_PAD_CTRL0_CLKPD | MSDC_PAD_CTRL0_CLKSMT | + MSDC_PAD_CTRL0_CLKIES | (4 << MSDC_PAD_CTRL0_CLKDRVN_S) | + (4 << MSDC_PAD_CTRL0_CLKDRVP_S), &host->base->pad_ctrl0); + writel(MSDC_PAD_CTRL1_CMDPU | MSDC_PAD_CTRL1_CMDSMT | + MSDC_PAD_CTRL1_CMDIES | (4 << MSDC_PAD_CTRL1_CMDDRVN_S) | + (4 << MSDC_PAD_CTRL1_CMDDRVP_S), &host->base->pad_ctrl1); + writel(MSDC_PAD_CTRL2_DATPU | MSDC_PAD_CTRL2_DATSMT | + MSDC_PAD_CTRL2_DATIES | (4 << MSDC_PAD_CTRL2_DATDRVN_S) | + (4 << MSDC_PAD_CTRL2_DATDRVP_S), &host->base->pad_ctrl2); + } + + if (host->dev_comp->default_pad_dly) { + /* Default pad delay may be needed if tuning not enabled */ + clrsetbits_le32(tune_reg, MSDC_PAD_TUNE_CLKTDLY_M | + MSDC_PAD_TUNE_CMDRRDLY_M | + MSDC_PAD_TUNE_CMDRDLY_M | + MSDC_PAD_TUNE_DATRRDLY_M | + MSDC_PAD_TUNE_DATWRDLY_M, + (0x10 << MSDC_PAD_TUNE_CLKTDLY_S) | + (0x10 << MSDC_PAD_TUNE_CMDRRDLY_S) | + (0x10 << MSDC_PAD_TUNE_CMDRDLY_S) | + (0x10 << MSDC_PAD_TUNE_DATRRDLY_S) | + (0x10 << MSDC_PAD_TUNE_DATWRDLY_S)); + + writel((0x10 << MSDC_PAD_TUNE0_DAT0RDDLY_S) | + (0x10 << MSDC_PAD_TUNE0_DAT1RDDLY_S) | + (0x10 << MSDC_PAD_TUNE0_DAT2RDDLY_S) | + (0x10 << MSDC_PAD_TUNE0_DAT3RDDLY_S), + rd_dly0_reg); + + writel((0x10 << MSDC_PAD_TUNE1_DAT4RDDLY_S) | + (0x10 << MSDC_PAD_TUNE1_DAT5RDDLY_S) | + (0x10 << MSDC_PAD_TUNE1_DAT6RDDLY_S) | + (0x10 << MSDC_PAD_TUNE1_DAT7RDDLY_S), + rd_dly1_reg); + } + /* Configure to enable SDIO mode otherwise sdio cmd5 won't work */ setbits_le32(&host->base->sdc_cfg, SDC_CFG_SDIO);
@@ -1620,7 +1733,9 @@ static const struct msdc_compatible mt7620_compat = { .data_tune = false, .busy_check = false, .stop_clk_fix = false, - .enhance_rx = false + .enhance_rx = false, + .builtin_pad_ctrl = true, + .default_pad_dly = true, };
Do you expect no changes for mt76x8 base boards with this pad control settings support at all?
Other than that:
Thanks, Stefan
- /* PAD_TUNE */
- /* EMMC50_CFG0 */ #define EMMC50_CFG_CFCSTS_SEL BIT(4)
- u32 reserved4[5];
- u32 reserved4[2];
- u32 pad_ctrl0;
- u32 pad_ctrl1;
- u32 pad_ctrl2; u32 pad_tune; u32 pad_tune0; u32 pad_tune1;
- void __iomem *rd_dly0_reg = &host->base->pad_tune0;
- void __iomem *rd_dly1_reg = &host->base->pad_tune1;
- if (host->dev_comp->builtin_pad_ctrl) {
- if (host->dev_comp->default_pad_dly) {
rd_dly0_reg);
rd_dly1_reg);
- /* Configure to enable SDIO mode otherwise sdio cmd5 won't work */ setbits_le32(&host->base->sdc_cfg, SDC_CFG_SDIO);
Viele Grüße, Stefan
Actually these settings exist in the old msdc driver in MTK SDK u-boot, and apply for both mt7620/mt7621/mt76x8. I forgot to add this in the mt7628 patches. I've tested this patch on mt7628, and it still works well.
Other than that:
Thanks, Stefan
- /* PAD_TUNE */
- u32 reserved4[5];
- u32 reserved4[2];
- u32 pad_ctrl0;
- u32 pad_ctrl1;
rd_dly0_reg);
rd_dly1_reg);
Viele Grüße, Stefan
Currently this driver does not set the value of plat->cfg.f_max, which results in that MMC framework will always run at the lowest frequency.
This patch sets plat->cfg.f_max to the maximum allowed frequency, which is half of the source clock frequency.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v3 changes: new --- drivers/mmc/mtk-sd.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/drivers/mmc/mtk-sd.c b/drivers/mmc/mtk-sd.c index f4ff8822f2..5e24943212 100644 --- a/drivers/mmc/mtk-sd.c +++ b/drivers/mmc/mtk-sd.c @@ -1639,6 +1639,8 @@ static int msdc_drv_probe(struct udevice *dev) else cfg->f_min = host->src_clk_freq / (4 * 4095);
+ cfg->f_max = host->src_clk_freq / 2; + cfg->b_max = 1024; cfg->voltages = MMC_VDD_32_33 | MMC_VDD_33_34;
Thanks, Stefan
v3 changes: new
- cfg->f_max = host->src_clk_freq / 2;
- cfg->b_max = 1024; cfg->voltages = MMC_VDD_32_33 | MMC_VDD_33_34;
Viele Grüße, Stefan
Add DM_FLAG_PRE_RELOC flag for reset-mtmips to make sure this driver can be probed before relocation even if u-boot,dm-pre-reloc is not present in the dts.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v3 changes: none v2 changes: new --- drivers/reset/reset-mtmips.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/reset/reset-mtmips.c b/drivers/reset/reset-mtmips.c index bc20e3335c..0d6a446465 100644 --- a/drivers/reset/reset-mtmips.c +++ b/drivers/reset/reset-mtmips.c @@ -82,4 +82,5 @@ U_BOOT_DRIVER(mtmips_reset) = { .probe = mtmips_reset_probe, .priv_auto_alloc_size = sizeof(struct mtmips_reset_priv), .ops = &mtmips_reset_ops, + .flags = DM_FLAG_PRE_RELOC, };
Thanks, Stefan
- .flags = DM_FLAG_PRE_RELOC, };
Viele Grüße, Stefan
Update maintainer for MediaTek MIPS platform
Acked-by: Stefan Roese sr@denx.de Reviewed-by: Stefan Roese sr@denx.de Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v3 changes: none v2 changes: none --- MAINTAINERS | 23 +++++++++++++++++++++++ 1 file changed, 23 insertions(+)
diff --git a/MAINTAINERS b/MAINTAINERS index 874cf2c0e5..0123afe7cf 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -802,6 +802,29 @@ F: drivers/mmc/ca_dw_mmc.c F: drivers/i2c/i2c-cortina.c F: drivers/i2c/i2c-cortina.h
+MIPS MEDIATEK +M: Weijie Gao weijie.gao@mediatek.com +R: GSS_MTK_Uboot_upstream GSS_MTK_Uboot_upstream@mediatek.com +S: Maintained +F: arch/mips/mach-mtmips/ +F: arch/mips/dts/mt7620.dtsi +F: arch/mips/dts/mt7620-u-boot.dtsi +F: include/configs/mt7620.h +F: include/dt-bindings/clock/mt7620-clk.h +F: include/dt-bindings/clock/mt7628-clk.h +F: include/dt-bindings/reset/mt7620-reset.h +F: include/dt-bindings/reset/mt7628-reset.h +F: drivers/clk/mtmips/ +F: drivers/pinctrl/mtmips/ +F: drivers/gpio/mt7620_gpio.c +F: drivers/net/mt7620-eth.c +F: drivers/phy/mt7620-usb-phy.c +F: drivers/reset/reset-mtmips.c +F: drivers/serial/serial_mt7620.c +F: drivers/spi/mt7620_spi.c +F: drivers/sysreset/sysreset_resetctl.c +F: drivers/watchdog/mt7620_wdt.c + MIPS MSCC M: Gregory CLEMENT gregory.clement@bootlin.com M: Lars Povlsen lars.povlsen@microchip.com
Stefan Roese
Weijie Gao
