[U-Boot] [PATCH] at91: Get rid of some warnings when building for otc570
The soft-i2c code for AT91 defines I2C_SOFT_DECLARATIONS for direct access by dereferencing a pio pointer. The OTC570 platform uses the AT91 gpio API so it does not need the pio variable.
Signed-off-by: Matthias Fuchs matthias.fuchs@esd.eu --- include/configs/otc570.h | 1 + 1 files changed, 1 insertions(+), 0 deletions(-)
diff --git a/include/configs/otc570.h b/include/configs/otc570.h index 8e27eba..4fde012 100644 --- a/include/configs/otc570.h +++ b/include/configs/otc570.h @@ -102,6 +102,7 @@ at91_set_pio_output(AT91_PIO_PORTB, 4, 0); \ at91_set_pio_output(AT91_PIO_PORTB, 5, 0); \ } +#define I2C_SOFT_DECLARATIONS /* Configure data pin as output */ #define I2C_ACTIVE at91_set_pio_output(AT91_PIO_PORTB, 4, 0) /* Configure data pin as input */
Dear Matthias Fuchs,
Applied, thanks.
So this reduces the warnings to the (pretty common, on AT91):
atmel_dataflash_spi.c:25:2: warning: #warning Please update to use C structur SoC access ! atmel_usart.c:21:2: warning: #warning Please update to use C structur SoC access ! ohci-at91.c:30:2: warning: #warning Please update to use C structur SoC access !
Applied, thanks.
These are not fixable on-the-fly. As you might know there is a bigger work-in-progress to switch the AT91 support completely towards c structs. I don't expect this to be done before the outstanding release.
I am not sure if anyone is working on this right now. If so, please raise your finger!
Matthias
Matthias Fuchs
Matthias Fuchs
