[U-Boot-Users] [PATCH] I2C register access functions for omap1510_i2c driver
drivers/i2c/omap1510_i2c.c does not implement i2c_reg_read and i2c_reg_write which leads to unresolved symbols when using ds1307 driver. While there, enable CONFIG_CMD_DATE for Voiceblue board to have nice test case :-)
Signed-off-by: Ladislav Michl ladis@linux-mips.org
diff --git a/drivers/i2c/omap1510_i2c.c b/drivers/i2c/omap1510_i2c.c index 04400fb..f0fc15e 100644 --- a/drivers/i2c/omap1510_i2c.c +++ b/drivers/i2c/omap1510_i2c.c @@ -240,6 +240,19 @@ int i2c_write (uchar chip, uint addr, int alen, uchar * buffer, int len) return 0; }
+uchar i2c_reg_read (uchar chip, uchar reg) +{ + uchar val; + + i2c_read_byte(chip, reg, &val); + return val; +} + +void i2c_reg_write(uchar chip, uchar reg, uchar val) +{ + i2c_write_byte(chip, reg, val); +} + static void wait_for_bb (void) { int timeout = 10; diff --git a/include/configs/voiceblue.h b/include/configs/voiceblue.h index 8c827af..63e3530 100644 --- a/include/configs/voiceblue.h +++ b/include/configs/voiceblue.h @@ -126,6 +126,7 @@
#define CONFIG_CMD_BDI #define CONFIG_CMD_BOOTD +#define CONFIG_CMD_DATE #define CONFIG_CMD_DHCP #define CONFIG_CMD_ENV #define CONFIG_CMD_FLASH diff --git a/board/voiceblue/voiceblue.c b/board/voiceblue/voiceblue.c index c8dde36..fbbbe9d 100644 --- a/board/voiceblue/voiceblue.c +++ b/board/voiceblue/voiceblue.c @@ -56,6 +56,7 @@ int dram_init(void) int misc_init_r(void) { *((volatile unsigned short *) VOICEBLUE_LED_REG) = 0x55; + i2c_reg_write(CFG_I2C_RTC_ADDR, 0x10, 0xaa); /* Trickle charge */
return 0; }
uchar val;
return val;
While your fix is technically correct, I looked into this last week and found that this exact code is duplicated in EVERY I2C controller, except one (MPC8xx), where there are calls to i2c_init() in each of the functions. I posted a request for information about why the i2c_init() call is necessary in MPC8xx and nobody has responded yet. Maybe somebody has an MPC8xx-based board and could experiment a bit to make it the same???
I'd prefer to see these functions as static inlines in i2c.h in order to cut down on duplication.
Just my $0.02
regards, Ben
Yup, that's why I give up fixing all that stuff, not mentioning my patch doesn't containg the same code which reads:
void i2c_reg_write(uchar chip, uchar reg, uchar val) { i2c_write(chip, reg, 1, &val, 1); }
as omap has separate function to read and write single byte and I used it.
Agree here, except it would be nice to use something like this:
void __i2c_reg_write(uchar chip, uchar reg, uchar val) { i2c_write(chip, reg, 1, &val, 1); } void void i2c_reg_write(uchar chip, uchar reg, uchar val) __attribute__((weak, alias("__i2c_reg_write")));
So anyone may still use his own i2c_reg_write implementation and you do not need to wait for answer to your question about MPC8xx.
Best regards, ladis
Ben Warren
Ladislav Michl
