[U-Boot] [PATCH v3 5/7] zynq: Add support for auto nandboot
From: Jagannadha Sutradharudu Teki jaganna@xilinx.com
Added support to find the nand bootmode and also updated the default env. with nandboot.
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com Signed-off-by: Jagannadha Sutradharudu Teki jaganna@xilinx.com --- Changes for v3: -Separated out the nand patch series as per Michal comment. Changes for v2: -None --- board/xilinx/zynq/board.c | 4 ++++ doc/README.zynq | 3 ++- include/configs/zynq-common.h | 3 +++ 3 files changed, 9 insertions(+), 1 deletions(-)
diff --git a/board/xilinx/zynq/board.c b/board/xilinx/zynq/board.c index 5a47149..9dd158c 100644 --- a/board/xilinx/zynq/board.c +++ b/board/xilinx/zynq/board.c @@ -15,6 +15,7 @@ DECLARE_GLOBAL_DATA_PTR; /* Bootmode setting values */ #define ZYNQ_BM_MASK 0x0F #define ZYNQ_BM_NOR 0x02 +#define ZYNQ_BM_NAND 0x04 #define ZYNQ_BM_SD 0x05 #define ZYNQ_BM_JTAG 0x0
@@ -75,6 +76,9 @@ int board_late_init(void) case ZYNQ_BM_NOR: setenv("modeboot", "norboot"); break; + case ZYNQ_BM_NAND: + setenv("modeboot", "nandboot"); + break; case ZYNQ_BM_SD: setenv("modeboot", "sdboot"); break; diff --git a/doc/README.zynq b/doc/README.zynq index 043c970..e0b38cf 100644 --- a/doc/README.zynq +++ b/doc/README.zynq @@ -54,10 +54,11 @@ is intern used in autoboot.
SLCR bootmode register Bit[3:0] values #define ZYNQ_BM_NOR 0x02 +#define ZYNQ_BM_NOR 0x04 #define ZYNQ_BM_SD 0x05 #define ZYNQ_BM_JTAG 0x0
-"modeboot" variable can assign any of "norboot", "sdboot" or "jtagboot" +"modeboot" variable can assign any of "norboot", "nandboot", "sdboot" or "jtagboot" bootmode strings at runtime.
5. Mainline status diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index 08adaa2..068e59a 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -170,6 +170,9 @@ "norboot=echo Copying FIT from NOR flash to RAM... && " \ "cp.b ${nor_flash_off} ${load_addr} ${fit_size} && " \ "bootm ${load_addr}\0" \ + "nandboot=echo Copying FIT from NAND flash to RAM... && " \ + "nand read ${load_addr} ${flash_off} ${fit_size} && " \ + "bootm ${load_addr}\0" \ "sdboot=echo Copying FIT from SD to RAM... && " \ "fatload mmc 0 ${load_addr} ${fit_image} && " \ "bootm ${load_addr}\0" \
On 17 February 2014 12:26, Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com wrote:
-None
case ZYNQ_BM_NAND:
- Mainline status
Is there an opportunity to use 'nboot' here? i.e. nboot ${load_addr} 0 ${flash_off} (instead of nand read and bootm)
This would mean you don't waste time reading NAND you don't use and you don't have to worry about maintaining ${fit_size} whenever the kernel changes size.
Andrew Murray
-- 1.7.4
On Mon, Feb 17, 2014 at 6:34 PM, Andrew Murray amurray@embedded-bits.co.uk wrote:
-None
case ZYNQ_BM_NAND:
- Mainline status
Yes - we can use, thanks for pointing.
Andrew Murray
-- 1.7.4
thanks!
Hi Siva,
On Mon, Feb 17, 2014 at 5:56 PM, Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com wrote:
-None
case ZYNQ_BM_NAND:
Can you please correct this typo - I think it's ZYNQ_BM_NAND
- Mainline status
-- 1.7.4
thanks!
Andrew Murray
Jagan Teki
