[U-Boot] [PATCH] net: altera_tse: get numbers of fdt address and size cells
Get numbers of fdt address and size cells in altera_tse_probe(), thereby remove the assumption of one address cell and one size cell.
Signed-off-by: Thomas Chou thomas@wytron.com.tw --- drivers/net/altera_tse.c | 14 ++++++++------ 1 file changed, 8 insertions(+), 6 deletions(-)
diff --git a/drivers/net/altera_tse.c b/drivers/net/altera_tse.c index 394503f..b2002f4 100644 --- a/drivers/net/altera_tse.c +++ b/drivers/net/altera_tse.c @@ -409,20 +409,22 @@ static int altera_tse_probe(struct udevice *dev) { struct eth_pdata *pdata = dev_get_platdata(dev); struct altera_tse_priv *priv = dev_get_priv(dev); - const void *blob = gd->fdt_blob; + void *blob = (void *)gd->fdt_blob; int node = dev->of_offset; const char *list, *end; const fdt32_t *cell; void *base, *desc_mem = NULL; unsigned long addr, size; + int parent, addrc, sizec; int len, idx; int ret;
/* - * decode regs, assume address-cells and size-cells are both one. - * there are multiple reg tuples, and they need to match with - * reg-names. + * decode regs. there are multiple reg tuples, and they need to + * match with reg-names. */ + parent = fdt_parent_offset(blob, node); + of_bus_default_count_cells(blob, parent, &addrc, &sizec); list = fdt_getprop(blob, node, "reg-names", &len); if (!list) return -ENOENT; @@ -434,7 +436,7 @@ static int altera_tse_probe(struct udevice *dev) while (list < end) { addr = fdt_translate_address((void *)blob, node, cell + idx); - size = fdt_addr_to_cpu(cell[idx + 1]); + size = fdt_addr_to_cpu(cell[idx + addrc]); base = ioremap(addr, size); len = strlen(list); if (strcmp(list, "control_port") == 0) @@ -445,7 +447,7 @@ static int altera_tse_probe(struct udevice *dev) priv->sgdma_tx = base; else if (strcmp(list, "s1") == 0) desc_mem = base; - idx += 2; + idx += addrc + sizec; list += (len + 1); } /* decode fifo depth */
Hi Thomas,
Applied to u-boot-nios.
* reg-names.
*/* match with reg-names.
- parent = fdt_parent_offset(blob, node);
- of_bus_default_count_cells(blob, parent, &addrc, &sizec); list = fdt_getprop(blob, node, "reg-names", &len); if (!list) return -ENOENT;
base = ioremap(addr, size); len = strlen(list); if (strcmp(list, "control_port") == 0)size = fdt_addr_to_cpu(cell[idx + addrc]);
idx += 2;
list += (len + 1); } /* decode fifo depth */idx += addrc + sizec;
Joe Hershberger
Thomas Chou
