[U-Boot] [PATCH 1/1] driver/mtd: Fix IFC compilation warnings
'eccstat' array elements might be used uninitialized
Signed-off-by: Jaiprakash Singh b44839@freescale.com --- drivers/mtd/nand/fsl_ifc_nand.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mtd/nand/fsl_ifc_nand.c b/drivers/mtd/nand/fsl_ifc_nand.c index 81b5070..b283eae 100644 --- a/drivers/mtd/nand/fsl_ifc_nand.c +++ b/drivers/mtd/nand/fsl_ifc_nand.c @@ -292,7 +292,7 @@ static int fsl_ifc_run_command(struct mtd_info *mtd) struct fsl_ifc *ifc = ctrl->regs; u32 timeo = (CONFIG_SYS_HZ * 10) / 1000; u32 time_start; - u32 eccstat[4]; + u32 eccstat[4] = {0}; int i;
/* set the chip select for NAND Transaction */
Applied to u-boot-fsl-qoriq master, awaiting upstream.
York
Jaiprakash Singh
York Sun
