[U-Boot] [PATCH v8 1/9] mips: add base support for QCA/Atheros ath79 SOCs
This patch add some common code for QCA/Atheros ath79 SOCs such as DDR tuning, chip reset and CPU detection.
Signed-off-by: Wills Wang wills.wang@live.com ---
Changes in v8: - Use setbits_be32 - Use lookup-table instead of big switch statement for CPU detection
Changes in v7: - Use setbits_32 - Fix include path for SoC specific headers
Changes in v6: - Move ar933x as separate patch - Add get_bootstrap in reset.c - Use map_physmem instead of KSEG1ADDR - Add arch_cpu_init for detect SOC type for early
Changes in v5: - Add independent Kconfig - Use SRAM for initial stack - Move DDR initialization into board_early_init_f - Convert DDR tap tunning code to C - Save SOC's version into arch_global_data
Changes in v4: - Use global_data to save CPU/DDR/AHB clock - Use arch_global_data to save SOC's type, revison and id
Changes in v3: - Move SoC specific header files into arch/mips/mach-ath79/include/mach - Optimize assembly code - Same code style convertion
Changes in v2: - Move all SoC specific header files into arch/mips/include/asm/arch-ath79 - Check SOC type and extract common code into arch/mips/mach-ath79
arch/mips/Kconfig | 6 + arch/mips/Makefile | 1 + arch/mips/include/asm/global_data.h | 6 + arch/mips/mach-ath79/Kconfig | 7 + arch/mips/mach-ath79/Makefile | 7 + arch/mips/mach-ath79/cpu.c | 142 +++ arch/mips/mach-ath79/dram.c | 16 + arch/mips/mach-ath79/include/mach/ar71xx_regs.h | 1184 +++++++++++++++++++++++ arch/mips/mach-ath79/include/mach/ath79.h | 143 +++ arch/mips/mach-ath79/include/mach/ddr.h | 13 + arch/mips/mach-ath79/include/mach/reset.h | 14 + arch/mips/mach-ath79/reset.c | 71 ++ 12 files changed, 1610 insertions(+) create mode 100644 arch/mips/mach-ath79/Kconfig create mode 100644 arch/mips/mach-ath79/Makefile create mode 100644 arch/mips/mach-ath79/cpu.c create mode 100644 arch/mips/mach-ath79/dram.c create mode 100644 arch/mips/mach-ath79/include/mach/ar71xx_regs.h create mode 100644 arch/mips/mach-ath79/include/mach/ath79.h create mode 100644 arch/mips/mach-ath79/include/mach/ddr.h create mode 100644 arch/mips/mach-ath79/include/mach/reset.h create mode 100644 arch/mips/mach-ath79/reset.c
diff --git a/arch/mips/Kconfig b/arch/mips/Kconfig index f852a1f..fbedb29 100644 --- a/arch/mips/Kconfig +++ b/arch/mips/Kconfig @@ -55,6 +55,11 @@ config TARGET_PB1X00 select SYS_MIPS_CACHE_INIT_RAM_LOAD select MIPS_TUNE_4KC
+config ARCH_ATH79 + bool "Support QCA/Atheros ath79" + select OF_CONTROL + select DM + config MACH_PIC32 bool "Support Microchip PIC32" select OF_CONTROL @@ -67,6 +72,7 @@ source "board/imgtec/malta/Kconfig" source "board/micronas/vct/Kconfig" source "board/pb1x00/Kconfig" source "board/qemu-mips/Kconfig" +source "arch/mips/mach-ath79/Kconfig" source "arch/mips/mach-pic32/Kconfig"
if MIPS diff --git a/arch/mips/Makefile b/arch/mips/Makefile index aec5a15..7a82316 100644 --- a/arch/mips/Makefile +++ b/arch/mips/Makefile @@ -8,6 +8,7 @@ libs-y += arch/mips/cpu/ libs-y += arch/mips/lib/
machine-$(CONFIG_SOC_AU1X00) += au1x00 +machine-$(CONFIG_ARCH_ATH79) += ath79 machine-$(CONFIG_MACH_PIC32) += pic32
machdirs := $(patsubst %,arch/mips/mach-%/,$(machine-y)) diff --git a/arch/mips/include/asm/global_data.h b/arch/mips/include/asm/global_data.h index a1ca257..3f230b0 100644 --- a/arch/mips/include/asm/global_data.h +++ b/arch/mips/include/asm/global_data.h @@ -23,6 +23,12 @@ struct arch_global_data { unsigned long tbl; unsigned long lastinc; #endif +#ifdef CONFIG_ARCH_ATH79 + unsigned long id; + unsigned long soc; + unsigned long rev; + unsigned long ver; +#endif };
#include <asm-generic/global_data.h> diff --git a/arch/mips/mach-ath79/Kconfig b/arch/mips/mach-ath79/Kconfig new file mode 100644 index 0000000..7d8ce09 --- /dev/null +++ b/arch/mips/mach-ath79/Kconfig @@ -0,0 +1,7 @@ +menu "QCA/Atheros 7xxx/9xxx platforms" + depends on ARCH_ATH79 + +config SYS_SOC + default "ath79" + +endmenu diff --git a/arch/mips/mach-ath79/Makefile b/arch/mips/mach-ath79/Makefile new file mode 100644 index 0000000..6203cf0 --- /dev/null +++ b/arch/mips/mach-ath79/Makefile @@ -0,0 +1,7 @@ +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += reset.o +obj-y += cpu.o +obj-y += dram.o diff --git a/arch/mips/mach-ath79/cpu.c b/arch/mips/mach-ath79/cpu.c new file mode 100644 index 0000000..c6122f2 --- /dev/null +++ b/arch/mips/mach-ath79/cpu.c @@ -0,0 +1,142 @@ +/* + * Copyright (C) 2015-2016 Wills Wang wills.wang@live.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/addrspace.h> +#include <asm/types.h> +#include <mach/ath79.h> +#include <mach/ar71xx_regs.h> + +struct ath79_soc_desc { + enum ath79_soc_type soc; + const char *chip; + int major; + int minor; +}; + +static struct ath79_soc_desc desc[] = { + {ATH79_SOC_AR7130, "7130", + REV_ID_MAJOR_AR71XX, AR71XX_REV_ID_MINOR_AR7130}, + {ATH79_SOC_AR7141, "7141", + REV_ID_MAJOR_AR71XX, AR71XX_REV_ID_MINOR_AR7141}, + {ATH79_SOC_AR7161, "7161", + REV_ID_MAJOR_AR71XX, AR71XX_REV_ID_MINOR_AR7161}, + {ATH79_SOC_AR7240, "7240", REV_ID_MAJOR_AR7240, 0}, + {ATH79_SOC_AR7241, "7241", REV_ID_MAJOR_AR7241, 0}, + {ATH79_SOC_AR7242, "7242", REV_ID_MAJOR_AR7242, 0}, + {ATH79_SOC_AR9130, "9130", + REV_ID_MAJOR_AR913X, AR913X_REV_ID_MINOR_AR9130}, + {ATH79_SOC_AR9132, "9132", + REV_ID_MAJOR_AR913X, AR913X_REV_ID_MINOR_AR9132}, + {ATH79_SOC_AR9330, "9330", REV_ID_MAJOR_AR9330, 0}, + {ATH79_SOC_AR9331, "9331", REV_ID_MAJOR_AR9331, 0}, + {ATH79_SOC_AR9341, "9341", REV_ID_MAJOR_AR9341, 0}, + {ATH79_SOC_AR9342, "9342", REV_ID_MAJOR_AR9342, 0}, + {ATH79_SOC_AR9344, "9344", REV_ID_MAJOR_AR9344, 0}, + {ATH79_SOC_QCA9533, "9533", REV_ID_MAJOR_QCA9533, 0}, + {ATH79_SOC_QCA9533, "9533", + REV_ID_MAJOR_QCA9533_V2, 0}, + {ATH79_SOC_QCA9556, "9556", REV_ID_MAJOR_QCA9556, 0}, + {ATH79_SOC_QCA9558, "9558", REV_ID_MAJOR_QCA9558, 0}, + {ATH79_SOC_TP9343, "9343", REV_ID_MAJOR_TP9343, 0}, + {ATH79_SOC_QCA9561, "9561", REV_ID_MAJOR_QCA9561, 0}, +}; + +int arch_cpu_init(void) +{ + void __iomem *base; + enum ath79_soc_type soc = ATH79_SOC_UNKNOWN; + u32 id, major, minor = 0; + u32 rev = 0, ver = 1; + int i; + + base = map_physmem(AR71XX_RESET_BASE, AR71XX_RESET_SIZE, + MAP_NOCACHE); + + id = readl(base + AR71XX_RESET_REG_REV_ID); + major = id & REV_ID_MAJOR_MASK; + switch (major) { + case REV_ID_MAJOR_AR71XX: + case REV_ID_MAJOR_AR913X: + minor = id & AR71XX_REV_ID_MINOR_MASK; + rev = id >> AR71XX_REV_ID_REVISION_SHIFT; + rev &= AR71XX_REV_ID_REVISION_MASK; + break; + + case REV_ID_MAJOR_QCA9533_V2: + ver = 2; + /* drop through */ + + case REV_ID_MAJOR_AR9341: + case REV_ID_MAJOR_AR9342: + case REV_ID_MAJOR_AR9344: + case REV_ID_MAJOR_QCA9533: + case REV_ID_MAJOR_QCA9556: + case REV_ID_MAJOR_QCA9558: + case REV_ID_MAJOR_TP9343: + case REV_ID_MAJOR_QCA9561: + rev = id & AR71XX_REV_ID_REVISION2_MASK; + break; + default: + rev = id & AR71XX_REV_ID_REVISION_MASK; + break; + } + + for (i = 0; i < ARRAY_SIZE(desc); i++) { + if ((desc[i].major == major) && + (desc[i].minor == minor)) { + soc = desc[i].soc; + break; + } + } + + gd->arch.id = id; + gd->arch.soc = soc; + gd->arch.rev = rev; + gd->arch.ver = ver; + return 0; +} + +int print_cpuinfo(void) +{ + enum ath79_soc_type soc = ATH79_SOC_UNKNOWN; + const char *chip = "????"; + u32 id, rev, ver; + int i; + + for (i = 0; i < ARRAY_SIZE(desc); i++) { + if (desc[i].soc == gd->arch.soc) { + chip = desc[i].chip; + soc = desc[i].soc; + break; + } + } + + id = gd->arch.id; + rev = gd->arch.rev; + ver = gd->arch.ver; + + switch (soc) { + case ATH79_SOC_QCA9533: + case ATH79_SOC_QCA9556: + case ATH79_SOC_QCA9558: + case ATH79_SOC_QCA9561: + printf("Qualcomm Atheros QCA%s ver %u rev %u\n", chip, + ver, rev); + break; + case ATH79_SOC_TP9343: + printf("Qualcomm Atheros TP%s rev %u\n", chip, rev); + break; + case ATH79_SOC_UNKNOWN: + printf("ATH79: unknown SoC, id:0x%08x", id); + break; + default: + printf("Atheros AR%s rev %u\n", chip, rev); + } + + return 0; +} diff --git a/arch/mips/mach-ath79/dram.c b/arch/mips/mach-ath79/dram.c new file mode 100644 index 0000000..c29e98c --- /dev/null +++ b/arch/mips/mach-ath79/dram.c @@ -0,0 +1,16 @@ +/* + * Copyright (C) 2015-2016 Wills Wang wills.wang@live.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <linux/sizes.h> +#include <asm/addrspace.h> +#include <mach/ddr.h> + +phys_size_t initdram(int board_type) +{ + ddr_tap_tuning(); + return get_ram_size((void *)KSEG1, SZ_256M); +} diff --git a/arch/mips/mach-ath79/include/mach/ar71xx_regs.h b/arch/mips/mach-ath79/include/mach/ar71xx_regs.h new file mode 100644 index 0000000..893dedc --- /dev/null +++ b/arch/mips/mach-ath79/include/mach/ar71xx_regs.h @@ -0,0 +1,1184 @@ +/* + * Atheros AR71XX/AR724X/AR913X SoC register definitions + * + * Copyright (C) 2015-2016 Wills Wang wills.wang@live.com + * Copyright (C) 2010-2011 Jaiganesh Narayanan jnarayanan@atheros.com + * Copyright (C) 2008-2010 Gabor Juhos juhosg@openwrt.org + * Copyright (C) 2008 Imre Kaloz kaloz@openwrt.org + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __ASM_MACH_AR71XX_REGS_H +#define __ASM_MACH_AR71XX_REGS_H + +#ifndef __ASSEMBLY__ +#include <linux/bitops.h> +#else +#ifndef BIT +#define BIT(nr) (1 << (nr)) +#endif +#endif + +#define AR71XX_APB_BASE 0x18000000 +#define AR71XX_GE0_BASE 0x19000000 +#define AR71XX_GE0_SIZE 0x10000 +#define AR71XX_GE1_BASE 0x1a000000 +#define AR71XX_GE1_SIZE 0x10000 +#define AR71XX_EHCI_BASE 0x1b000000 +#define AR71XX_EHCI_SIZE 0x1000 +#define AR71XX_OHCI_BASE 0x1c000000 +#define AR71XX_OHCI_SIZE 0x1000 +#define AR71XX_SPI_BASE 0x1f000000 +#define AR71XX_SPI_SIZE 0x01000000 + +#define AR71XX_DDR_CTRL_BASE (AR71XX_APB_BASE + 0x00000000) +#define AR71XX_DDR_CTRL_SIZE 0x100 +#define AR71XX_UART_BASE (AR71XX_APB_BASE + 0x00020000) +#define AR71XX_UART_SIZE 0x100 +#define AR71XX_USB_CTRL_BASE (AR71XX_APB_BASE + 0x00030000) +#define AR71XX_USB_CTRL_SIZE 0x100 +#define AR71XX_GPIO_BASE (AR71XX_APB_BASE + 0x00040000) +#define AR71XX_GPIO_SIZE 0x100 +#define AR71XX_PLL_BASE (AR71XX_APB_BASE + 0x00050000) +#define AR71XX_PLL_SIZE 0x100 +#define AR71XX_RESET_BASE (AR71XX_APB_BASE + 0x00060000) +#define AR71XX_RESET_SIZE 0x100 +#define AR71XX_MII_BASE (AR71XX_APB_BASE + 0x00070000) +#define AR71XX_MII_SIZE 0x100 + +#define AR71XX_PCI_MEM_BASE 0x10000000 +#define AR71XX_PCI_MEM_SIZE 0x07000000 + +#define AR71XX_PCI_WIN0_OFFS 0x10000000 +#define AR71XX_PCI_WIN1_OFFS 0x11000000 +#define AR71XX_PCI_WIN2_OFFS 0x12000000 +#define AR71XX_PCI_WIN3_OFFS 0x13000000 +#define AR71XX_PCI_WIN4_OFFS 0x14000000 +#define AR71XX_PCI_WIN5_OFFS 0x15000000 +#define AR71XX_PCI_WIN6_OFFS 0x16000000 +#define AR71XX_PCI_WIN7_OFFS 0x07000000 + +#define AR71XX_PCI_CFG_BASE \ + (AR71XX_PCI_MEM_BASE + AR71XX_PCI_WIN7_OFFS + 0x10000) +#define AR71XX_PCI_CFG_SIZE 0x100 + +#define AR7240_USB_CTRL_BASE (AR71XX_APB_BASE + 0x00030000) +#define AR7240_USB_CTRL_SIZE 0x100 +#define AR7240_OHCI_BASE 0x1b000000 +#define AR7240_OHCI_SIZE 0x1000 + +#define AR724X_PCI_MEM_BASE 0x10000000 +#define AR724X_PCI_MEM_SIZE 0x04000000 + +#define AR724X_PCI_CFG_BASE 0x14000000 +#define AR724X_PCI_CFG_SIZE 0x1000 +#define AR724X_PCI_CRP_BASE (AR71XX_APB_BASE + 0x000c0000) +#define AR724X_PCI_CRP_SIZE 0x1000 +#define AR724X_PCI_CTRL_BASE (AR71XX_APB_BASE + 0x000f0000) +#define AR724X_PCI_CTRL_SIZE 0x100 + +#define AR724X_EHCI_BASE 0x1b000000 +#define AR724X_EHCI_SIZE 0x1000 + +#define AR913X_EHCI_BASE 0x1b000000 +#define AR913X_EHCI_SIZE 0x1000 +#define AR913X_WMAC_BASE (AR71XX_APB_BASE + 0x000C0000) +#define AR913X_WMAC_SIZE 0x30000 + +#define AR933X_UART_BASE (AR71XX_APB_BASE + 0x00020000) +#define AR933X_UART_SIZE 0x14 +#define AR933X_GMAC_BASE (AR71XX_APB_BASE + 0x00070000) +#define AR933X_GMAC_SIZE 0x04 +#define AR933X_WMAC_BASE (AR71XX_APB_BASE + 0x00100000) +#define AR933X_WMAC_SIZE 0x20000 +#define AR933X_RTC_BASE (AR71XX_APB_BASE + 0x00107000) +#define AR933X_RTC_SIZE 0x1000 +#define AR933X_EHCI_BASE 0x1b000000 +#define AR933X_EHCI_SIZE 0x1000 +#define AR933X_SRIF_BASE (AR71XX_APB_BASE + 0x00116000) +#define AR933X_SRIF_SIZE 0x1000 + +#define AR934X_GMAC_BASE (AR71XX_APB_BASE + 0x00070000) +#define AR934X_GMAC_SIZE 0x14 +#define AR934X_WMAC_BASE (AR71XX_APB_BASE + 0x00100000) +#define AR934X_WMAC_SIZE 0x20000 +#define AR934X_EHCI_BASE 0x1b000000 +#define AR934X_EHCI_SIZE 0x200 +#define AR934X_NFC_BASE 0x1b000200 +#define AR934X_NFC_SIZE 0xb8 +#define AR934X_SRIF_BASE (AR71XX_APB_BASE + 0x00116000) +#define AR934X_SRIF_SIZE 0x1000 + +#define QCA953X_GMAC_BASE (AR71XX_APB_BASE + 0x00070000) +#define QCA953X_GMAC_SIZE 0x14 +#define QCA953X_WMAC_BASE (AR71XX_APB_BASE + 0x00100000) +#define QCA953X_WMAC_SIZE 0x20000 +#define QCA953X_RTC_BASE (AR71XX_APB_BASE + 0x00107000) +#define QCA953X_RTC_SIZE 0x1000 +#define QCA953X_EHCI_BASE 0x1b000000 +#define QCA953X_EHCI_SIZE 0x200 +#define QCA953X_SRIF_BASE (AR71XX_APB_BASE + 0x00116000) +#define QCA953X_SRIF_SIZE 0x1000 + +#define QCA953X_PCI_CFG_BASE0 0x14000000 +#define QCA953X_PCI_CTRL_BASE0 (AR71XX_APB_BASE + 0x000f0000) +#define QCA953X_PCI_CRP_BASE0 (AR71XX_APB_BASE + 0x000c0000) +#define QCA953X_PCI_MEM_BASE0 0x10000000 +#define QCA953X_PCI_MEM_SIZE 0x02000000 + +#define QCA955X_PCI_MEM_BASE0 0x10000000 +#define QCA955X_PCI_MEM_BASE1 0x12000000 +#define QCA955X_PCI_MEM_SIZE 0x02000000 +#define QCA955X_PCI_CFG_BASE0 0x14000000 +#define QCA955X_PCI_CFG_BASE1 0x16000000 +#define QCA955X_PCI_CFG_SIZE 0x1000 +#define QCA955X_PCI_CRP_BASE0 (AR71XX_APB_BASE + 0x000c0000) +#define QCA955X_PCI_CRP_BASE1 (AR71XX_APB_BASE + 0x00250000) +#define QCA955X_PCI_CRP_SIZE 0x1000 +#define QCA955X_PCI_CTRL_BASE0 (AR71XX_APB_BASE + 0x000f0000) +#define QCA955X_PCI_CTRL_BASE1 (AR71XX_APB_BASE + 0x00280000) +#define QCA955X_PCI_CTRL_SIZE 0x100 + +#define QCA955X_GMAC_BASE (AR71XX_APB_BASE + 0x00070000) +#define QCA955X_GMAC_SIZE 0x40 +#define QCA955X_WMAC_BASE (AR71XX_APB_BASE + 0x00100000) +#define QCA955X_WMAC_SIZE 0x20000 +#define QCA955X_EHCI0_BASE 0x1b000000 +#define QCA955X_EHCI1_BASE 0x1b400000 +#define QCA955X_EHCI_SIZE 0x1000 +#define QCA955X_NFC_BASE 0x1b800200 +#define QCA955X_NFC_SIZE 0xb8 + +#define QCA956X_PCI_MEM_BASE1 0x12000000 +#define QCA956X_PCI_MEM_SIZE 0x02000000 +#define QCA956X_PCI_CFG_BASE1 0x16000000 +#define QCA956X_PCI_CFG_SIZE 0x1000 +#define QCA956X_PCI_CRP_BASE1 (AR71XX_APB_BASE + 0x00250000) +#define QCA956X_PCI_CRP_SIZE 0x1000 +#define QCA956X_PCI_CTRL_BASE1 (AR71XX_APB_BASE + 0x00280000) +#define QCA956X_PCI_CTRL_SIZE 0x100 + +#define QCA956X_WMAC_BASE (AR71XX_APB_BASE + 0x00100000) +#define QCA956X_WMAC_SIZE 0x20000 +#define QCA956X_EHCI0_BASE 0x1b000000 +#define QCA956X_EHCI1_BASE 0x1b400000 +#define QCA956X_EHCI_SIZE 0x200 +#define QCA956X_GMAC_BASE (AR71XX_APB_BASE + 0x00070000) +#define QCA956X_GMAC_SIZE 0x64 + +/* + * DDR_CTRL block + */ +#define AR71XX_DDR_REG_CONFIG 0x00 +#define AR71XX_DDR_REG_CONFIG2 0x04 +#define AR71XX_DDR_REG_MODE 0x08 +#define AR71XX_DDR_REG_EMR 0x0c +#define AR71XX_DDR_REG_CONTROL 0x10 +#define AR71XX_DDR_REG_REFRESH 0x14 +#define AR71XX_DDR_REG_RD_CYCLE 0x18 +#define AR71XX_DDR_REG_TAP_CTRL0 0x1c +#define AR71XX_DDR_REG_TAP_CTRL1 0x20 + +#define AR71XX_DDR_REG_PCI_WIN0 0x7c +#define AR71XX_DDR_REG_PCI_WIN1 0x80 +#define AR71XX_DDR_REG_PCI_WIN2 0x84 +#define AR71XX_DDR_REG_PCI_WIN3 0x88 +#define AR71XX_DDR_REG_PCI_WIN4 0x8c +#define AR71XX_DDR_REG_PCI_WIN5 0x90 +#define AR71XX_DDR_REG_PCI_WIN6 0x94 +#define AR71XX_DDR_REG_PCI_WIN7 0x98 +#define AR71XX_DDR_REG_FLUSH_GE0 0x9c +#define AR71XX_DDR_REG_FLUSH_GE1 0xa0 +#define AR71XX_DDR_REG_FLUSH_USB 0xa4 +#define AR71XX_DDR_REG_FLUSH_PCI 0xa8 + +#define AR724X_DDR_REG_FLUSH_GE0 0x7c +#define AR724X_DDR_REG_FLUSH_GE1 0x80 +#define AR724X_DDR_REG_FLUSH_USB 0x84 +#define AR724X_DDR_REG_FLUSH_PCIE 0x88 + +#define AR913X_DDR_REG_FLUSH_GE0 0x7c +#define AR913X_DDR_REG_FLUSH_GE1 0x80 +#define AR913X_DDR_REG_FLUSH_USB 0x84 +#define AR913X_DDR_REG_FLUSH_WMAC 0x88 + +#define AR933X_DDR_REG_FLUSH_GE0 0x7c +#define AR933X_DDR_REG_FLUSH_GE1 0x80 +#define AR933X_DDR_REG_FLUSH_USB 0x84 +#define AR933X_DDR_REG_FLUSH_WMAC 0x88 +#define AR933X_DDR_REG_DDR2_CONFIG 0x8c +#define AR933X_DDR_REG_EMR2 0x90 +#define AR933X_DDR_REG_EMR3 0x94 +#define AR933X_DDR_REG_BURST 0x98 +#define AR933X_DDR_REG_TIMEOUT_MAX 0x9c +#define AR933X_DDR_REG_TIMEOUT_CNT 0x9c +#define AR933X_DDR_REG_TIMEOUT_ADDR 0x9c + +#define AR934X_DDR_REG_FLUSH_GE0 0x9c +#define AR934X_DDR_REG_FLUSH_GE1 0xa0 +#define AR934X_DDR_REG_FLUSH_USB 0xa4 +#define AR934X_DDR_REG_FLUSH_PCIE 0xa8 +#define AR934X_DDR_REG_FLUSH_WMAC 0xac + +#define QCA953X_DDR_REG_FLUSH_GE0 0x9c +#define QCA953X_DDR_REG_FLUSH_GE1 0xa0 +#define QCA953X_DDR_REG_FLUSH_USB 0xa4 +#define QCA953X_DDR_REG_FLUSH_PCIE 0xa8 +#define QCA953X_DDR_REG_FLUSH_WMAC 0xac +#define QCA953X_DDR_REG_DDR2_CONFIG 0xb8 +#define QCA953X_DDR_REG_BURST 0xc4 +#define QCA953X_DDR_REG_BURST2 0xc8 +#define QCA953X_DDR_REG_TIMEOUT_MAX 0xcc +#define QCA953X_DDR_REG_CTL_CONF 0x108 +#define QCA953X_DDR_REG_CONFIG3 0x15c + +/* + * PLL block + */ +#define AR71XX_PLL_REG_CPU_CONFIG 0x00 +#define AR71XX_PLL_REG_SEC_CONFIG 0x04 +#define AR71XX_PLL_REG_ETH0_INT_CLOCK 0x10 +#define AR71XX_PLL_REG_ETH1_INT_CLOCK 0x14 + +#define AR71XX_PLL_DIV_SHIFT 3 +#define AR71XX_PLL_DIV_MASK 0x1f +#define AR71XX_CPU_DIV_SHIFT 16 +#define AR71XX_CPU_DIV_MASK 0x3 +#define AR71XX_DDR_DIV_SHIFT 18 +#define AR71XX_DDR_DIV_MASK 0x3 +#define AR71XX_AHB_DIV_SHIFT 20 +#define AR71XX_AHB_DIV_MASK 0x7 + +#define AR71XX_ETH0_PLL_SHIFT 17 +#define AR71XX_ETH1_PLL_SHIFT 19 + +#define AR724X_PLL_REG_CPU_CONFIG 0x00 +#define AR724X_PLL_REG_PCIE_CONFIG 0x18 + +#define AR724X_PLL_DIV_SHIFT 0 +#define AR724X_PLL_DIV_MASK 0x3ff +#define AR724X_PLL_REF_DIV_SHIFT 10 +#define AR724X_PLL_REF_DIV_MASK 0xf +#define AR724X_AHB_DIV_SHIFT 19 +#define AR724X_AHB_DIV_MASK 0x1 +#define AR724X_DDR_DIV_SHIFT 22 +#define AR724X_DDR_DIV_MASK 0x3 + +#define AR7242_PLL_REG_ETH0_INT_CLOCK 0x2c + +#define AR913X_PLL_REG_CPU_CONFIG 0x00 +#define AR913X_PLL_REG_ETH_CONFIG 0x04 +#define AR913X_PLL_REG_ETH0_INT_CLOCK 0x14 +#define AR913X_PLL_REG_ETH1_INT_CLOCK 0x18 + +#define AR913X_PLL_DIV_SHIFT 0 +#define AR913X_PLL_DIV_MASK 0x3ff +#define AR913X_DDR_DIV_SHIFT 22 +#define AR913X_DDR_DIV_MASK 0x3 +#define AR913X_AHB_DIV_SHIFT 19 +#define AR913X_AHB_DIV_MASK 0x1 + +#define AR913X_ETH0_PLL_SHIFT 20 +#define AR913X_ETH1_PLL_SHIFT 22 + +#define AR933X_PLL_CPU_CONFIG_REG 0x00 +#define AR933X_PLL_CLK_CTRL_REG 0x08 +#define AR933X_PLL_DITHER_FRAC_REG 0x10 + +#define AR933X_PLL_CPU_CONFIG_NINT_SHIFT 10 +#define AR933X_PLL_CPU_CONFIG_NINT_MASK 0x3f +#define AR933X_PLL_CPU_CONFIG_REFDIV_SHIFT 16 +#define AR933X_PLL_CPU_CONFIG_REFDIV_MASK 0x1f +#define AR933X_PLL_CPU_CONFIG_OUTDIV_SHIFT 23 +#define AR933X_PLL_CPU_CONFIG_OUTDIV_MASK 0x7 + +#define AR933X_PLL_CLK_CTRL_BYPASS BIT(2) +#define AR933X_PLL_CLK_CTRL_CPU_POST_DIV_SHIFT 5 +#define AR933X_PLL_CLK_CTRL_CPU_POST_DIV_MASK 0x3 +#define AR933X_PLL_CLK_CTRL_DDR_POST_DIV_SHIFT 10 +#define AR933X_PLL_CLK_CTRL_DDR_POST_DIV_MASK 0x3 +#define AR933X_PLL_CLK_CTRL_AHB_POST_DIV_SHIFT 15 +#define AR933X_PLL_CLK_CTRL_AHB_POST_DIV_MASK 0x7 + +#define AR934X_PLL_CPU_CONFIG_REG 0x00 +#define AR934X_PLL_DDR_CONFIG_REG 0x04 +#define AR934X_PLL_CPU_DDR_CLK_CTRL_REG 0x08 +#define AR934X_PLL_SWITCH_CLOCK_CONTROL_REG 0x24 +#define AR934X_PLL_ETH_XMII_CONTROL_REG 0x2c + +#define AR934X_PLL_CPU_CONFIG_NFRAC_SHIFT 0 +#define AR934X_PLL_CPU_CONFIG_NFRAC_MASK 0x3f +#define AR934X_PLL_CPU_CONFIG_NINT_SHIFT 6 +#define AR934X_PLL_CPU_CONFIG_NINT_MASK 0x3f +#define AR934X_PLL_CPU_CONFIG_REFDIV_SHIFT 12 +#define AR934X_PLL_CPU_CONFIG_REFDIV_MASK 0x1f +#define AR934X_PLL_CPU_CONFIG_OUTDIV_SHIFT 19 +#define AR934X_PLL_CPU_CONFIG_OUTDIV_MASK 0x3 + +#define AR934X_PLL_DDR_CONFIG_NFRAC_SHIFT 0 +#define AR934X_PLL_DDR_CONFIG_NFRAC_MASK 0x3ff +#define AR934X_PLL_DDR_CONFIG_NINT_SHIFT 10 +#define AR934X_PLL_DDR_CONFIG_NINT_MASK 0x3f +#define AR934X_PLL_DDR_CONFIG_REFDIV_SHIFT 16 +#define AR934X_PLL_DDR_CONFIG_REFDIV_MASK 0x1f +#define AR934X_PLL_DDR_CONFIG_OUTDIV_SHIFT 23 +#define AR934X_PLL_DDR_CONFIG_OUTDIV_MASK 0x7 + +#define AR934X_PLL_CLK_CTRL_CPU_PLL_BYPASS BIT(2) +#define AR934X_PLL_CLK_CTRL_DDR_PLL_BYPASS BIT(3) +#define AR934X_PLL_CLK_CTRL_AHB_PLL_BYPASS BIT(4) +#define AR934X_PLL_CLK_CTRL_CPU_POST_DIV_SHIFT 5 +#define AR934X_PLL_CLK_CTRL_CPU_POST_DIV_MASK 0x1f +#define AR934X_PLL_CLK_CTRL_DDR_POST_DIV_SHIFT 10 +#define AR934X_PLL_CLK_CTRL_DDR_POST_DIV_MASK 0x1f +#define AR934X_PLL_CLK_CTRL_AHB_POST_DIV_SHIFT 15 +#define AR934X_PLL_CLK_CTRL_AHB_POST_DIV_MASK 0x1f +#define AR934X_PLL_CLK_CTRL_CPUCLK_FROM_CPUPLL BIT(20) +#define AR934X_PLL_CLK_CTRL_DDRCLK_FROM_DDRPLL BIT(21) +#define AR934X_PLL_CLK_CTRL_AHBCLK_FROM_DDRPLL BIT(24) + +#define AR934X_PLL_SWITCH_CLK_CTRL_MDIO_CLK_SEL BIT(6) + +#define QCA953X_PLL_CPU_CONFIG_REG 0x00 +#define QCA953X_PLL_DDR_CONFIG_REG 0x04 +#define QCA953X_PLL_CLK_CTRL_REG 0x08 +#define QCA953X_PLL_SWITCH_CLOCK_CONTROL_REG 0x24 +#define QCA953X_PLL_ETH_XMII_CONTROL_REG 0x2c +#define QCA953X_PLL_DDR_DIT_FRAC_REG 0x44 +#define QCA953X_PLL_CPU_DIT_FRAC_REG 0x48 + +#define QCA953X_PLL_CPU_CONFIG_NFRAC_SHIFT 0 +#define QCA953X_PLL_CPU_CONFIG_NFRAC_MASK 0x3f +#define QCA953X_PLL_CPU_CONFIG_NINT_SHIFT 6 +#define QCA953X_PLL_CPU_CONFIG_NINT_MASK 0x3f +#define QCA953X_PLL_CPU_CONFIG_REFDIV_SHIFT 12 +#define QCA953X_PLL_CPU_CONFIG_REFDIV_MASK 0x1f +#define QCA953X_PLL_CPU_CONFIG_OUTDIV_SHIFT 19 +#define QCA953X_PLL_CPU_CONFIG_OUTDIV_MASK 0x7 + +#define QCA953X_PLL_DDR_CONFIG_NFRAC_SHIFT 0 +#define QCA953X_PLL_DDR_CONFIG_NFRAC_MASK 0x3ff +#define QCA953X_PLL_DDR_CONFIG_NINT_SHIFT 10 +#define QCA953X_PLL_DDR_CONFIG_NINT_MASK 0x3f +#define QCA953X_PLL_DDR_CONFIG_REFDIV_SHIFT 16 +#define QCA953X_PLL_DDR_CONFIG_REFDIV_MASK 0x1f +#define QCA953X_PLL_DDR_CONFIG_OUTDIV_SHIFT 23 +#define QCA953X_PLL_DDR_CONFIG_OUTDIV_MASK 0x7 + +#define QCA953X_PLL_CONFIG_PWD BIT(30) + +#define QCA953X_PLL_CLK_CTRL_CPU_PLL_BYPASS BIT(2) +#define QCA953X_PLL_CLK_CTRL_DDR_PLL_BYPASS BIT(3) +#define QCA953X_PLL_CLK_CTRL_AHB_PLL_BYPASS BIT(4) +#define QCA953X_PLL_CLK_CTRL_CPU_POST_DIV_SHIFT 5 +#define QCA953X_PLL_CLK_CTRL_CPU_POST_DIV_MASK 0x1f +#define QCA953X_PLL_CLK_CTRL_DDR_POST_DIV_SHIFT 10 +#define QCA953X_PLL_CLK_CTRL_DDR_POST_DIV_MASK 0x1f +#define QCA953X_PLL_CLK_CTRL_AHB_POST_DIV_SHIFT 15 +#define QCA953X_PLL_CLK_CTRL_AHB_POST_DIV_MASK 0x1f +#define QCA953X_PLL_CLK_CTRL_CPUCLK_FROM_CPUPLL BIT(20) +#define QCA953X_PLL_CLK_CTRL_DDRCLK_FROM_DDRPLL BIT(21) +#define QCA953X_PLL_CLK_CTRL_AHBCLK_FROM_DDRPLL BIT(24) + +#define QCA953X_PLL_CPU_DIT_FRAC_MAX_SHIFT 0 +#define QCA953X_PLL_CPU_DIT_FRAC_MAX_MASK 0x3f +#define QCA953X_PLL_CPU_DIT_FRAC_MIN_SHIFT 6 +#define QCA953X_PLL_CPU_DIT_FRAC_MIN_MASK 0x3f +#define QCA953X_PLL_CPU_DIT_FRAC_STEP_SHIFT 12 +#define QCA953X_PLL_CPU_DIT_FRAC_STEP_MASK 0x3f +#define QCA953X_PLL_CPU_DIT_UPD_CNT_SHIFT 18 +#define QCA953X_PLL_CPU_DIT_UPD_CNT_MASK 0x3f + +#define QCA953X_PLL_DDR_DIT_FRAC_MAX_SHIFT 0 +#define QCA953X_PLL_DDR_DIT_FRAC_MAX_MASK 0x3ff +#define QCA953X_PLL_DDR_DIT_FRAC_MIN_SHIFT 9 +#define QCA953X_PLL_DDR_DIT_FRAC_MIN_MASK 0x3ff +#define QCA953X_PLL_DDR_DIT_FRAC_STEP_SHIFT 20 +#define QCA953X_PLL_DDR_DIT_FRAC_STEP_MASK 0x3f +#define QCA953X_PLL_DDR_DIT_UPD_CNT_SHIFT 27 +#define QCA953X_PLL_DDR_DIT_UPD_CNT_MASK 0x3f + +#define QCA953X_PLL_DIT_FRAC_EN BIT(31) + +#define QCA955X_PLL_CPU_CONFIG_REG 0x00 +#define QCA955X_PLL_DDR_CONFIG_REG 0x04 +#define QCA955X_PLL_CLK_CTRL_REG 0x08 +#define QCA955X_PLL_ETH_XMII_CONTROL_REG 0x28 +#define QCA955X_PLL_ETH_SGMII_CONTROL_REG 0x48 + +#define QCA955X_PLL_CPU_CONFIG_NFRAC_SHIFT 0 +#define QCA955X_PLL_CPU_CONFIG_NFRAC_MASK 0x3f +#define QCA955X_PLL_CPU_CONFIG_NINT_SHIFT 6 +#define QCA955X_PLL_CPU_CONFIG_NINT_MASK 0x3f +#define QCA955X_PLL_CPU_CONFIG_REFDIV_SHIFT 12 +#define QCA955X_PLL_CPU_CONFIG_REFDIV_MASK 0x1f +#define QCA955X_PLL_CPU_CONFIG_OUTDIV_SHIFT 19 +#define QCA955X_PLL_CPU_CONFIG_OUTDIV_MASK 0x3 + +#define QCA955X_PLL_DDR_CONFIG_NFRAC_SHIFT 0 +#define QCA955X_PLL_DDR_CONFIG_NFRAC_MASK 0x3ff +#define QCA955X_PLL_DDR_CONFIG_NINT_SHIFT 10 +#define QCA955X_PLL_DDR_CONFIG_NINT_MASK 0x3f +#define QCA955X_PLL_DDR_CONFIG_REFDIV_SHIFT 16 +#define QCA955X_PLL_DDR_CONFIG_REFDIV_MASK 0x1f +#define QCA955X_PLL_DDR_CONFIG_OUTDIV_SHIFT 23 +#define QCA955X_PLL_DDR_CONFIG_OUTDIV_MASK 0x7 + +#define QCA955X_PLL_CLK_CTRL_CPU_PLL_BYPASS BIT(2) +#define QCA955X_PLL_CLK_CTRL_DDR_PLL_BYPASS BIT(3) +#define QCA955X_PLL_CLK_CTRL_AHB_PLL_BYPASS BIT(4) +#define QCA955X_PLL_CLK_CTRL_CPU_POST_DIV_SHIFT 5 +#define QCA955X_PLL_CLK_CTRL_CPU_POST_DIV_MASK 0x1f +#define QCA955X_PLL_CLK_CTRL_DDR_POST_DIV_SHIFT 10 +#define QCA955X_PLL_CLK_CTRL_DDR_POST_DIV_MASK 0x1f +#define QCA955X_PLL_CLK_CTRL_AHB_POST_DIV_SHIFT 15 +#define QCA955X_PLL_CLK_CTRL_AHB_POST_DIV_MASK 0x1f +#define QCA955X_PLL_CLK_CTRL_CPUCLK_FROM_CPUPLL BIT(20) +#define QCA955X_PLL_CLK_CTRL_DDRCLK_FROM_DDRPLL BIT(21) +#define QCA955X_PLL_CLK_CTRL_AHBCLK_FROM_DDRPLL BIT(24) + +#define QCA956X_PLL_CPU_CONFIG_REG 0x00 +#define QCA956X_PLL_CPU_CONFIG1_REG 0x04 +#define QCA956X_PLL_DDR_CONFIG_REG 0x08 +#define QCA956X_PLL_DDR_CONFIG1_REG 0x0c +#define QCA956X_PLL_CLK_CTRL_REG 0x10 + +#define QCA956X_PLL_CPU_CONFIG_REFDIV_SHIFT 12 +#define QCA956X_PLL_CPU_CONFIG_REFDIV_MASK 0x1f +#define QCA956X_PLL_CPU_CONFIG_OUTDIV_SHIFT 19 +#define QCA956X_PLL_CPU_CONFIG_OUTDIV_MASK 0x7 + +#define QCA956X_PLL_CPU_CONFIG1_NFRAC_L_SHIFT 0 +#define QCA956X_PLL_CPU_CONFIG1_NFRAC_L_MASK 0x1f +#define QCA956X_PLL_CPU_CONFIG1_NFRAC_H_SHIFT 5 +#define QCA956X_PLL_CPU_CONFIG1_NFRAC_H_MASK 0x3fff +#define QCA956X_PLL_CPU_CONFIG1_NINT_SHIFT 18 +#define QCA956X_PLL_CPU_CONFIG1_NINT_MASK 0x1ff + +#define QCA956X_PLL_DDR_CONFIG_REFDIV_SHIFT 16 +#define QCA956X_PLL_DDR_CONFIG_REFDIV_MASK 0x1f +#define QCA956X_PLL_DDR_CONFIG_OUTDIV_SHIFT 23 +#define QCA956X_PLL_DDR_CONFIG_OUTDIV_MASK 0x7 + +#define QCA956X_PLL_DDR_CONFIG1_NFRAC_L_SHIFT 0 +#define QCA956X_PLL_DDR_CONFIG1_NFRAC_L_MASK 0x1f +#define QCA956X_PLL_DDR_CONFIG1_NFRAC_H_SHIFT 5 +#define QCA956X_PLL_DDR_CONFIG1_NFRAC_H_MASK 0x3fff +#define QCA956X_PLL_DDR_CONFIG1_NINT_SHIFT 18 +#define QCA956X_PLL_DDR_CONFIG1_NINT_MASK 0x1ff + +#define QCA956X_PLL_CLK_CTRL_CPU_PLL_BYPASS BIT(2) +#define QCA956X_PLL_CLK_CTRL_DDR_PLL_BYPASS BIT(3) +#define QCA956X_PLL_CLK_CTRL_AHB_PLL_BYPASS BIT(4) +#define QCA956X_PLL_CLK_CTRL_CPU_POST_DIV_SHIFT 5 +#define QCA956X_PLL_CLK_CTRL_CPU_POST_DIV_MASK 0x1f +#define QCA956X_PLL_CLK_CTRL_DDR_POST_DIV_SHIFT 10 +#define QCA956X_PLL_CLK_CTRL_DDR_POST_DIV_MASK 0x1f +#define QCA956X_PLL_CLK_CTRL_AHB_POST_DIV_SHIFT 15 +#define QCA956X_PLL_CLK_CTRL_AHB_POST_DIV_MASK 0x1f +#define QCA956X_PLL_CLK_CTRL_CPU_DDRCLK_FROM_DDRPLL BIT(20) +#define QCA956X_PLL_CLK_CTRL_CPU_DDRCLK_FROM_CPUPLL BIT(21) +#define QCA956X_PLL_CLK_CTRL_AHBCLK_FROM_DDRPLL BIT(24) + +/* + * USB_CONFIG block + */ +#define AR71XX_USB_CTRL_REG_FLADJ 0x00 +#define AR71XX_USB_CTRL_REG_CONFIG 0x04 + +/* + * RESET block + */ +#define AR71XX_RESET_REG_TIMER 0x00 +#define AR71XX_RESET_REG_TIMER_RELOAD 0x04 +#define AR71XX_RESET_REG_WDOG_CTRL 0x08 +#define AR71XX_RESET_REG_WDOG 0x0c +#define AR71XX_RESET_REG_MISC_INT_STATUS 0x10 +#define AR71XX_RESET_REG_MISC_INT_ENABLE 0x14 +#define AR71XX_RESET_REG_PCI_INT_STATUS 0x18 +#define AR71XX_RESET_REG_PCI_INT_ENABLE 0x1c +#define AR71XX_RESET_REG_GLOBAL_INT_STATUS 0x20 +#define AR71XX_RESET_REG_RESET_MODULE 0x24 +#define AR71XX_RESET_REG_PERFC_CTRL 0x2c +#define AR71XX_RESET_REG_PERFC0 0x30 +#define AR71XX_RESET_REG_PERFC1 0x34 +#define AR71XX_RESET_REG_REV_ID 0x90 + +#define AR913X_RESET_REG_GLOBAL_INT_STATUS 0x18 +#define AR913X_RESET_REG_RESET_MODULE 0x1c +#define AR913X_RESET_REG_PERF_CTRL 0x20 +#define AR913X_RESET_REG_PERFC0 0x24 +#define AR913X_RESET_REG_PERFC1 0x28 + +#define AR724X_RESET_REG_RESET_MODULE 0x1c + +#define AR933X_RESET_REG_RESET_MODULE 0x1c +#define AR933X_RESET_REG_BOOTSTRAP 0xac + +#define AR934X_RESET_REG_RESET_MODULE 0x1c +#define AR934X_RESET_REG_BOOTSTRAP 0xb0 +#define AR934X_RESET_REG_PCIE_WMAC_INT_STATUS 0xac + +#define QCA953X_RESET_REG_RESET_MODULE 0x1c +#define QCA953X_RESET_REG_BOOTSTRAP 0xb0 +#define QCA953X_RESET_REG_PCIE_WMAC_INT_STATUS 0xac + +#define QCA955X_RESET_REG_RESET_MODULE 0x1c +#define QCA955X_RESET_REG_BOOTSTRAP 0xb0 +#define QCA955X_RESET_REG_EXT_INT_STATUS 0xac + +#define QCA956X_RESET_REG_RESET_MODULE 0x1c +#define QCA956X_RESET_REG_BOOTSTRAP 0xb0 +#define QCA956X_RESET_REG_EXT_INT_STATUS 0xac + +#define MISC_INT_MIPS_SI_TIMERINT_MASK BIT(28) +#define MISC_INT_ETHSW BIT(12) +#define MISC_INT_TIMER4 BIT(10) +#define MISC_INT_TIMER3 BIT(9) +#define MISC_INT_TIMER2 BIT(8) +#define MISC_INT_DMA BIT(7) +#define MISC_INT_OHCI BIT(6) +#define MISC_INT_PERFC BIT(5) +#define MISC_INT_WDOG BIT(4) +#define MISC_INT_UART BIT(3) +#define MISC_INT_GPIO BIT(2) +#define MISC_INT_ERROR BIT(1) +#define MISC_INT_TIMER BIT(0) + +#define AR71XX_RESET_EXTERNAL BIT(28) +#define AR71XX_RESET_FULL_CHIP BIT(24) +#define AR71XX_RESET_CPU_NMI BIT(21) +#define AR71XX_RESET_CPU_COLD BIT(20) +#define AR71XX_RESET_DMA BIT(19) +#define AR71XX_RESET_SLIC BIT(18) +#define AR71XX_RESET_STEREO BIT(17) +#define AR71XX_RESET_DDR BIT(16) +#define AR71XX_RESET_GE1_MAC BIT(13) +#define AR71XX_RESET_GE1_PHY BIT(12) +#define AR71XX_RESET_USBSUS_OVERRIDE BIT(10) +#define AR71XX_RESET_GE0_MAC BIT(9) +#define AR71XX_RESET_GE0_PHY BIT(8) +#define AR71XX_RESET_USB_OHCI_DLL BIT(6) +#define AR71XX_RESET_USB_HOST BIT(5) +#define AR71XX_RESET_USB_PHY BIT(4) +#define AR71XX_RESET_PCI_BUS BIT(1) +#define AR71XX_RESET_PCI_CORE BIT(0) + +#define AR7240_RESET_USB_HOST BIT(5) +#define AR7240_RESET_OHCI_DLL BIT(3) + +#define AR724X_RESET_GE1_MDIO BIT(23) +#define AR724X_RESET_GE0_MDIO BIT(22) +#define AR724X_RESET_PCIE_PHY_SERIAL BIT(10) +#define AR724X_RESET_PCIE_PHY BIT(7) +#define AR724X_RESET_PCIE BIT(6) +#define AR724X_RESET_USB_HOST BIT(5) +#define AR724X_RESET_USB_PHY BIT(4) +#define AR724X_RESET_USBSUS_OVERRIDE BIT(3) + +#define AR913X_RESET_AMBA2WMAC BIT(22) +#define AR913X_RESET_USBSUS_OVERRIDE BIT(10) +#define AR913X_RESET_USB_HOST BIT(5) +#define AR913X_RESET_USB_PHY BIT(4) + +#define AR933X_RESET_GE1_MDIO BIT(23) +#define AR933X_RESET_GE0_MDIO BIT(22) +#define AR933X_RESET_GE1_MAC BIT(13) +#define AR933X_RESET_WMAC BIT(11) +#define AR933X_RESET_GE0_MAC BIT(9) +#define AR933X_RESET_USB_HOST BIT(5) +#define AR933X_RESET_USB_PHY BIT(4) +#define AR933X_RESET_USBSUS_OVERRIDE BIT(3) + +#define AR934X_RESET_HOST BIT(31) +#define AR934X_RESET_SLIC BIT(30) +#define AR934X_RESET_HDMA BIT(29) +#define AR934X_RESET_EXTERNAL BIT(28) +#define AR934X_RESET_RTC BIT(27) +#define AR934X_RESET_PCIE_EP_INT BIT(26) +#define AR934X_RESET_CHKSUM_ACC BIT(25) +#define AR934X_RESET_FULL_CHIP BIT(24) +#define AR934X_RESET_GE1_MDIO BIT(23) +#define AR934X_RESET_GE0_MDIO BIT(22) +#define AR934X_RESET_CPU_NMI BIT(21) +#define AR934X_RESET_CPU_COLD BIT(20) +#define AR934X_RESET_HOST_RESET_INT BIT(19) +#define AR934X_RESET_PCIE_EP BIT(18) +#define AR934X_RESET_UART1 BIT(17) +#define AR934X_RESET_DDR BIT(16) +#define AR934X_RESET_USB_PHY_PLL_PWD_EXT BIT(15) +#define AR934X_RESET_NANDF BIT(14) +#define AR934X_RESET_GE1_MAC BIT(13) +#define AR934X_RESET_ETH_SWITCH_ANALOG BIT(12) +#define AR934X_RESET_USB_PHY_ANALOG BIT(11) +#define AR934X_RESET_HOST_DMA_INT BIT(10) +#define AR934X_RESET_GE0_MAC BIT(9) +#define AR934X_RESET_ETH_SWITCH BIT(8) +#define AR934X_RESET_PCIE_PHY BIT(7) +#define AR934X_RESET_PCIE BIT(6) +#define AR934X_RESET_USB_HOST BIT(5) +#define AR934X_RESET_USB_PHY BIT(4) +#define AR934X_RESET_USBSUS_OVERRIDE BIT(3) +#define AR934X_RESET_LUT BIT(2) +#define AR934X_RESET_MBOX BIT(1) +#define AR934X_RESET_I2S BIT(0) + +#define QCA953X_RESET_USB_EXT_PWR BIT(29) +#define QCA953X_RESET_EXTERNAL BIT(28) +#define QCA953X_RESET_RTC BIT(27) +#define QCA953X_RESET_FULL_CHIP BIT(24) +#define QCA953X_RESET_GE1_MDIO BIT(23) +#define QCA953X_RESET_GE0_MDIO BIT(22) +#define QCA953X_RESET_CPU_NMI BIT(21) +#define QCA953X_RESET_CPU_COLD BIT(20) +#define QCA953X_RESET_DDR BIT(16) +#define QCA953X_RESET_USB_PHY_PLL_PWD_EXT BIT(15) +#define QCA953X_RESET_GE1_MAC BIT(13) +#define QCA953X_RESET_ETH_SWITCH_ANALOG BIT(12) +#define QCA953X_RESET_USB_PHY_ANALOG BIT(11) +#define QCA953X_RESET_GE0_MAC BIT(9) +#define QCA953X_RESET_ETH_SWITCH BIT(8) +#define QCA953X_RESET_PCIE_PHY BIT(7) +#define QCA953X_RESET_PCIE BIT(6) +#define QCA953X_RESET_USB_HOST BIT(5) +#define QCA953X_RESET_USB_PHY BIT(4) +#define QCA953X_RESET_USBSUS_OVERRIDE BIT(3) + +#define QCA955X_RESET_HOST BIT(31) +#define QCA955X_RESET_SLIC BIT(30) +#define QCA955X_RESET_HDMA BIT(29) +#define QCA955X_RESET_EXTERNAL BIT(28) +#define QCA955X_RESET_RTC BIT(27) +#define QCA955X_RESET_PCIE_EP_INT BIT(26) +#define QCA955X_RESET_CHKSUM_ACC BIT(25) +#define QCA955X_RESET_FULL_CHIP BIT(24) +#define QCA955X_RESET_GE1_MDIO BIT(23) +#define QCA955X_RESET_GE0_MDIO BIT(22) +#define QCA955X_RESET_CPU_NMI BIT(21) +#define QCA955X_RESET_CPU_COLD BIT(20) +#define QCA955X_RESET_HOST_RESET_INT BIT(19) +#define QCA955X_RESET_PCIE_EP BIT(18) +#define QCA955X_RESET_UART1 BIT(17) +#define QCA955X_RESET_DDR BIT(16) +#define QCA955X_RESET_USB_PHY_PLL_PWD_EXT BIT(15) +#define QCA955X_RESET_NANDF BIT(14) +#define QCA955X_RESET_GE1_MAC BIT(13) +#define QCA955X_RESET_SGMII_ANALOG BIT(12) +#define QCA955X_RESET_USB_PHY_ANALOG BIT(11) +#define QCA955X_RESET_HOST_DMA_INT BIT(10) +#define QCA955X_RESET_GE0_MAC BIT(9) +#define QCA955X_RESET_SGMII BIT(8) +#define QCA955X_RESET_PCIE_PHY BIT(7) +#define QCA955X_RESET_PCIE BIT(6) +#define QCA955X_RESET_USB_HOST BIT(5) +#define QCA955X_RESET_USB_PHY BIT(4) +#define QCA955X_RESET_USBSUS_OVERRIDE BIT(3) +#define QCA955X_RESET_LUT BIT(2) +#define QCA955X_RESET_MBOX BIT(1) +#define QCA955X_RESET_I2S BIT(0) + +#define AR933X_BOOTSTRAP_MDIO_GPIO_EN BIT(18) +#define AR933X_BOOTSTRAP_DDR2 BIT(13) +#define AR933X_BOOTSTRAP_EEPBUSY BIT(4) +#define AR933X_BOOTSTRAP_REF_CLK_40 BIT(0) + +#define AR934X_BOOTSTRAP_SW_OPTION8 BIT(23) +#define AR934X_BOOTSTRAP_SW_OPTION7 BIT(22) +#define AR934X_BOOTSTRAP_SW_OPTION6 BIT(21) +#define AR934X_BOOTSTRAP_SW_OPTION5 BIT(20) +#define AR934X_BOOTSTRAP_SW_OPTION4 BIT(19) +#define AR934X_BOOTSTRAP_SW_OPTION3 BIT(18) +#define AR934X_BOOTSTRAP_SW_OPTION2 BIT(17) +#define AR934X_BOOTSTRAP_SW_OPTION1 BIT(16) +#define AR934X_BOOTSTRAP_USB_MODE_DEVICE BIT(7) +#define AR934X_BOOTSTRAP_PCIE_RC BIT(6) +#define AR934X_BOOTSTRAP_EJTAG_MODE BIT(5) +#define AR934X_BOOTSTRAP_REF_CLK_40 BIT(4) +#define AR934X_BOOTSTRAP_BOOT_FROM_SPI BIT(2) +#define AR934X_BOOTSTRAP_SDRAM_DISABLED BIT(1) +#define AR934X_BOOTSTRAP_DDR1 BIT(0) + +#define QCA953X_BOOTSTRAP_SW_OPTION2 BIT(12) +#define QCA953X_BOOTSTRAP_SW_OPTION1 BIT(11) +#define QCA953X_BOOTSTRAP_EJTAG_MODE BIT(5) +#define QCA953X_BOOTSTRAP_REF_CLK_40 BIT(4) +#define QCA953X_BOOTSTRAP_SDRAM_DISABLED BIT(1) +#define QCA953X_BOOTSTRAP_DDR1 BIT(0) + +#define QCA955X_BOOTSTRAP_REF_CLK_40 BIT(4) + +#define QCA956X_BOOTSTRAP_REF_CLK_40 BIT(2) + +#define AR934X_PCIE_WMAC_INT_WMAC_MISC BIT(0) +#define AR934X_PCIE_WMAC_INT_WMAC_TX BIT(1) +#define AR934X_PCIE_WMAC_INT_WMAC_RXLP BIT(2) +#define AR934X_PCIE_WMAC_INT_WMAC_RXHP BIT(3) +#define AR934X_PCIE_WMAC_INT_PCIE_RC BIT(4) +#define AR934X_PCIE_WMAC_INT_PCIE_RC0 BIT(5) +#define AR934X_PCIE_WMAC_INT_PCIE_RC1 BIT(6) +#define AR934X_PCIE_WMAC_INT_PCIE_RC2 BIT(7) +#define AR934X_PCIE_WMAC_INT_PCIE_RC3 BIT(8) +#define AR934X_PCIE_WMAC_INT_WMAC_ALL \ + (AR934X_PCIE_WMAC_INT_WMAC_MISC | AR934X_PCIE_WMAC_INT_WMAC_TX | \ + AR934X_PCIE_WMAC_INT_WMAC_RXLP | AR934X_PCIE_WMAC_INT_WMAC_RXHP) + +#define AR934X_PCIE_WMAC_INT_PCIE_ALL \ + (AR934X_PCIE_WMAC_INT_PCIE_RC | AR934X_PCIE_WMAC_INT_PCIE_RC0 | \ + AR934X_PCIE_WMAC_INT_PCIE_RC1 | AR934X_PCIE_WMAC_INT_PCIE_RC2 | \ + AR934X_PCIE_WMAC_INT_PCIE_RC3) + +#define QCA953X_PCIE_WMAC_INT_WMAC_MISC BIT(0) +#define QCA953X_PCIE_WMAC_INT_WMAC_TX BIT(1) +#define QCA953X_PCIE_WMAC_INT_WMAC_RXLP BIT(2) +#define QCA953X_PCIE_WMAC_INT_WMAC_RXHP BIT(3) +#define QCA953X_PCIE_WMAC_INT_PCIE_RC BIT(4) +#define QCA953X_PCIE_WMAC_INT_PCIE_RC0 BIT(5) +#define QCA953X_PCIE_WMAC_INT_PCIE_RC1 BIT(6) +#define QCA953X_PCIE_WMAC_INT_PCIE_RC2 BIT(7) +#define QCA953X_PCIE_WMAC_INT_PCIE_RC3 BIT(8) +#define QCA953X_PCIE_WMAC_INT_WMAC_ALL \ + (QCA953X_PCIE_WMAC_INT_WMAC_MISC | QCA953X_PCIE_WMAC_INT_WMAC_TX | \ + QCA953X_PCIE_WMAC_INT_WMAC_RXLP | QCA953X_PCIE_WMAC_INT_WMAC_RXHP) + +#define QCA953X_PCIE_WMAC_INT_PCIE_ALL \ + (QCA953X_PCIE_WMAC_INT_PCIE_RC | QCA953X_PCIE_WMAC_INT_PCIE_RC0 | \ + QCA953X_PCIE_WMAC_INT_PCIE_RC1 | QCA953X_PCIE_WMAC_INT_PCIE_RC2 | \ + QCA953X_PCIE_WMAC_INT_PCIE_RC3) + +#define QCA955X_EXT_INT_WMAC_MISC BIT(0) +#define QCA955X_EXT_INT_WMAC_TX BIT(1) +#define QCA955X_EXT_INT_WMAC_RXLP BIT(2) +#define QCA955X_EXT_INT_WMAC_RXHP BIT(3) +#define QCA955X_EXT_INT_PCIE_RC1 BIT(4) +#define QCA955X_EXT_INT_PCIE_RC1_INT0 BIT(5) +#define QCA955X_EXT_INT_PCIE_RC1_INT1 BIT(6) +#define QCA955X_EXT_INT_PCIE_RC1_INT2 BIT(7) +#define QCA955X_EXT_INT_PCIE_RC1_INT3 BIT(8) +#define QCA955X_EXT_INT_PCIE_RC2 BIT(12) +#define QCA955X_EXT_INT_PCIE_RC2_INT0 BIT(13) +#define QCA955X_EXT_INT_PCIE_RC2_INT1 BIT(14) +#define QCA955X_EXT_INT_PCIE_RC2_INT2 BIT(15) +#define QCA955X_EXT_INT_PCIE_RC2_INT3 BIT(16) +#define QCA955X_EXT_INT_USB1 BIT(24) +#define QCA955X_EXT_INT_USB2 BIT(28) + +#define QCA955X_EXT_INT_WMAC_ALL \ + (QCA955X_EXT_INT_WMAC_MISC | QCA955X_EXT_INT_WMAC_TX | \ + QCA955X_EXT_INT_WMAC_RXLP | QCA955X_EXT_INT_WMAC_RXHP) + +#define QCA955X_EXT_INT_PCIE_RC1_ALL \ + (QCA955X_EXT_INT_PCIE_RC1 | QCA955X_EXT_INT_PCIE_RC1_INT0 | \ + QCA955X_EXT_INT_PCIE_RC1_INT1 | QCA955X_EXT_INT_PCIE_RC1_INT2 | \ + QCA955X_EXT_INT_PCIE_RC1_INT3) + +#define QCA955X_EXT_INT_PCIE_RC2_ALL \ + (QCA955X_EXT_INT_PCIE_RC2 | QCA955X_EXT_INT_PCIE_RC2_INT0 | \ + QCA955X_EXT_INT_PCIE_RC2_INT1 | QCA955X_EXT_INT_PCIE_RC2_INT2 | \ + QCA955X_EXT_INT_PCIE_RC2_INT3) + +#define QCA956X_EXT_INT_WMAC_MISC BIT(0) +#define QCA956X_EXT_INT_WMAC_TX BIT(1) +#define QCA956X_EXT_INT_WMAC_RXLP BIT(2) +#define QCA956X_EXT_INT_WMAC_RXHP BIT(3) +#define QCA956X_EXT_INT_PCIE_RC1 BIT(4) +#define QCA956X_EXT_INT_PCIE_RC1_INT0 BIT(5) +#define QCA956X_EXT_INT_PCIE_RC1_INT1 BIT(6) +#define QCA956X_EXT_INT_PCIE_RC1_INT2 BIT(7) +#define QCA956X_EXT_INT_PCIE_RC1_INT3 BIT(8) +#define QCA956X_EXT_INT_PCIE_RC2 BIT(12) +#define QCA956X_EXT_INT_PCIE_RC2_INT0 BIT(13) +#define QCA956X_EXT_INT_PCIE_RC2_INT1 BIT(14) +#define QCA956X_EXT_INT_PCIE_RC2_INT2 BIT(15) +#define QCA956X_EXT_INT_PCIE_RC2_INT3 BIT(16) +#define QCA956X_EXT_INT_USB1 BIT(24) +#define QCA956X_EXT_INT_USB2 BIT(28) + +#define QCA956X_EXT_INT_WMAC_ALL \ + (QCA956X_EXT_INT_WMAC_MISC | QCA956X_EXT_INT_WMAC_TX | \ + QCA956X_EXT_INT_WMAC_RXLP | QCA956X_EXT_INT_WMAC_RXHP) + +#define QCA956X_EXT_INT_PCIE_RC1_ALL \ + (QCA956X_EXT_INT_PCIE_RC1 | QCA956X_EXT_INT_PCIE_RC1_INT0 | \ + QCA956X_EXT_INT_PCIE_RC1_INT1 | QCA956X_EXT_INT_PCIE_RC1_INT2 | \ + QCA956X_EXT_INT_PCIE_RC1_INT3) + +#define QCA956X_EXT_INT_PCIE_RC2_ALL \ + (QCA956X_EXT_INT_PCIE_RC2 | QCA956X_EXT_INT_PCIE_RC2_INT0 | \ + QCA956X_EXT_INT_PCIE_RC2_INT1 | QCA956X_EXT_INT_PCIE_RC2_INT2 | \ + QCA956X_EXT_INT_PCIE_RC2_INT3) + +#define REV_ID_MAJOR_MASK 0xfff0 +#define REV_ID_MAJOR_AR71XX 0x00a0 +#define REV_ID_MAJOR_AR913X 0x00b0 +#define REV_ID_MAJOR_AR7240 0x00c0 +#define REV_ID_MAJOR_AR7241 0x0100 +#define REV_ID_MAJOR_AR7242 0x1100 +#define REV_ID_MAJOR_AR9330 0x0110 +#define REV_ID_MAJOR_AR9331 0x1110 +#define REV_ID_MAJOR_AR9341 0x0120 +#define REV_ID_MAJOR_AR9342 0x1120 +#define REV_ID_MAJOR_AR9344 0x2120 +#define REV_ID_MAJOR_QCA9533 0x0140 +#define REV_ID_MAJOR_QCA9533_V2 0x0160 +#define REV_ID_MAJOR_QCA9556 0x0130 +#define REV_ID_MAJOR_QCA9558 0x1130 +#define REV_ID_MAJOR_TP9343 0x0150 +#define REV_ID_MAJOR_QCA9561 0x1150 + +#define AR71XX_REV_ID_MINOR_MASK 0x3 +#define AR71XX_REV_ID_MINOR_AR7130 0x0 +#define AR71XX_REV_ID_MINOR_AR7141 0x1 +#define AR71XX_REV_ID_MINOR_AR7161 0x2 +#define AR913X_REV_ID_MINOR_AR9130 0x0 +#define AR913X_REV_ID_MINOR_AR9132 0x1 + +#define AR71XX_REV_ID_REVISION_MASK 0x3 +#define AR71XX_REV_ID_REVISION_SHIFT 2 +#define AR71XX_REV_ID_REVISION2_MASK 0xf + +/* + * RTC block + */ +#define AR933X_RTC_REG_RESET 0x40 +#define AR933X_RTC_REG_STATUS 0x44 +#define AR933X_RTC_REG_DERIVED 0x48 +#define AR933X_RTC_REG_FORCE_WAKE 0x4c +#define AR933X_RTC_REG_INT_CAUSE 0x50 +#define AR933X_RTC_REG_CAUSE_CLR 0x50 +#define AR933X_RTC_REG_INT_ENABLE 0x54 +#define AR933X_RTC_REG_INT_MASKE 0x58 + +#define QCA953X_RTC_REG_SYNC_RESET 0x40 +#define QCA953X_RTC_REG_SYNC_STATUS 0x44 + +/* + * SPI block + */ +#define AR71XX_SPI_REG_FS 0x00 +#define AR71XX_SPI_REG_CTRL 0x04 +#define AR71XX_SPI_REG_IOC 0x08 +#define AR71XX_SPI_REG_RDS 0x0c + +#define AR71XX_SPI_FS_GPIO BIT(0) + +#define AR71XX_SPI_CTRL_RD BIT(6) +#define AR71XX_SPI_CTRL_DIV_MASK 0x3f + +#define AR71XX_SPI_IOC_DO BIT(0) +#define AR71XX_SPI_IOC_CLK BIT(8) +#define AR71XX_SPI_IOC_CS(n) BIT(16 + (n)) +#define AR71XX_SPI_IOC_CS0 AR71XX_SPI_IOC_CS(0) +#define AR71XX_SPI_IOC_CS1 AR71XX_SPI_IOC_CS(1) +#define AR71XX_SPI_IOC_CS2 AR71XX_SPI_IOC_CS(2) +#define AR71XX_SPI_IOC_CS_ALL \ + (AR71XX_SPI_IOC_CS0 | AR71XX_SPI_IOC_CS1 | AR71XX_SPI_IOC_CS2) + +/* + * GPIO block + */ +#define AR71XX_GPIO_REG_OE 0x00 +#define AR71XX_GPIO_REG_IN 0x04 +#define AR71XX_GPIO_REG_OUT 0x08 +#define AR71XX_GPIO_REG_SET 0x0c +#define AR71XX_GPIO_REG_CLEAR 0x10 +#define AR71XX_GPIO_REG_INT_MODE 0x14 +#define AR71XX_GPIO_REG_INT_TYPE 0x18 +#define AR71XX_GPIO_REG_INT_POLARITY 0x1c +#define AR71XX_GPIO_REG_INT_PENDING 0x20 +#define AR71XX_GPIO_REG_INT_ENABLE 0x24 +#define AR71XX_GPIO_REG_FUNC 0x28 +#define AR933X_GPIO_REG_FUNC 0x30 + +#define AR934X_GPIO_REG_OUT_FUNC0 0x2c +#define AR934X_GPIO_REG_OUT_FUNC1 0x30 +#define AR934X_GPIO_REG_OUT_FUNC2 0x34 +#define AR934X_GPIO_REG_OUT_FUNC3 0x38 +#define AR934X_GPIO_REG_OUT_FUNC4 0x3c +#define AR934X_GPIO_REG_OUT_FUNC5 0x40 +#define AR934X_GPIO_REG_FUNC 0x6c + +#define QCA953X_GPIO_REG_OUT_FUNC0 0x2c +#define QCA953X_GPIO_REG_OUT_FUNC1 0x30 +#define QCA953X_GPIO_REG_OUT_FUNC2 0x34 +#define QCA953X_GPIO_REG_OUT_FUNC3 0x38 +#define QCA953X_GPIO_REG_OUT_FUNC4 0x3c +#define QCA953X_GPIO_REG_IN_ENABLE0 0x44 +#define QCA953X_GPIO_REG_FUNC 0x6c + +#define QCA955X_GPIO_REG_OUT_FUNC0 0x2c +#define QCA955X_GPIO_REG_OUT_FUNC1 0x30 +#define QCA955X_GPIO_REG_OUT_FUNC2 0x34 +#define QCA955X_GPIO_REG_OUT_FUNC3 0x38 +#define QCA955X_GPIO_REG_OUT_FUNC4 0x3c +#define QCA955X_GPIO_REG_OUT_FUNC5 0x40 +#define QCA955X_GPIO_REG_FUNC 0x6c + +#define QCA956X_GPIO_REG_OUT_FUNC0 0x2c +#define QCA956X_GPIO_REG_OUT_FUNC1 0x30 +#define QCA956X_GPIO_REG_OUT_FUNC2 0x34 +#define QCA956X_GPIO_REG_OUT_FUNC3 0x38 +#define QCA956X_GPIO_REG_OUT_FUNC4 0x3c +#define QCA956X_GPIO_REG_OUT_FUNC5 0x40 +#define QCA956X_GPIO_REG_IN_ENABLE0 0x44 +#define QCA956X_GPIO_REG_IN_ENABLE3 0x50 +#define QCA956X_GPIO_REG_FUNC 0x6c + +#define AR71XX_GPIO_FUNC_STEREO_EN BIT(17) +#define AR71XX_GPIO_FUNC_SLIC_EN BIT(16) +#define AR71XX_GPIO_FUNC_SPI_CS2_EN BIT(13) +#define AR71XX_GPIO_FUNC_SPI_CS1_EN BIT(12) +#define AR71XX_GPIO_FUNC_UART_EN BIT(8) +#define AR71XX_GPIO_FUNC_USB_OC_EN BIT(4) +#define AR71XX_GPIO_FUNC_USB_CLK_EN BIT(0) + +#define AR724X_GPIO_FUNC_GE0_MII_CLK_EN BIT(19) +#define AR724X_GPIO_FUNC_SPI_EN BIT(18) +#define AR724X_GPIO_FUNC_SPI_CS_EN2 BIT(14) +#define AR724X_GPIO_FUNC_SPI_CS_EN1 BIT(13) +#define AR724X_GPIO_FUNC_CLK_OBS5_EN BIT(12) +#define AR724X_GPIO_FUNC_CLK_OBS4_EN BIT(11) +#define AR724X_GPIO_FUNC_CLK_OBS3_EN BIT(10) +#define AR724X_GPIO_FUNC_CLK_OBS2_EN BIT(9) +#define AR724X_GPIO_FUNC_CLK_OBS1_EN BIT(8) +#define AR724X_GPIO_FUNC_ETH_SWITCH_LED4_EN BIT(7) +#define AR724X_GPIO_FUNC_ETH_SWITCH_LED3_EN BIT(6) +#define AR724X_GPIO_FUNC_ETH_SWITCH_LED2_EN BIT(5) +#define AR724X_GPIO_FUNC_ETH_SWITCH_LED1_EN BIT(4) +#define AR724X_GPIO_FUNC_ETH_SWITCH_LED0_EN BIT(3) +#define AR724X_GPIO_FUNC_UART_RTS_CTS_EN BIT(2) +#define AR724X_GPIO_FUNC_UART_EN BIT(1) +#define AR724X_GPIO_FUNC_JTAG_DISABLE BIT(0) + +#define AR913X_GPIO_FUNC_WMAC_LED_EN BIT(22) +#define AR913X_GPIO_FUNC_EXP_PORT_CS_EN BIT(21) +#define AR913X_GPIO_FUNC_I2S_REFCLKEN BIT(20) +#define AR913X_GPIO_FUNC_I2S_MCKEN BIT(19) +#define AR913X_GPIO_FUNC_I2S1_EN BIT(18) +#define AR913X_GPIO_FUNC_I2S0_EN BIT(17) +#define AR913X_GPIO_FUNC_SLIC_EN BIT(16) +#define AR913X_GPIO_FUNC_UART_RTSCTS_EN BIT(9) +#define AR913X_GPIO_FUNC_UART_EN BIT(8) +#define AR913X_GPIO_FUNC_USB_CLK_EN BIT(4) + +#define AR933X_GPIO(x) BIT(x) +#define AR933X_GPIO_FUNC_SPDIF2TCK BIT(31) +#define AR933X_GPIO_FUNC_SPDIF_EN BIT(30) +#define AR933X_GPIO_FUNC_I2SO_22_18_EN BIT(29) +#define AR933X_GPIO_FUNC_I2S_MCK_EN BIT(27) +#define AR933X_GPIO_FUNC_I2SO_EN BIT(26) +#define AR933X_GPIO_FUNC_ETH_SWITCH_LED_DUPL BIT(25) +#define AR933X_GPIO_FUNC_ETH_SWITCH_LED_COLL BIT(24) +#define AR933X_GPIO_FUNC_ETH_SWITCH_LED_ACT BIT(23) +#define AR933X_GPIO_FUNC_SPI_EN BIT(18) +#define AR933X_GPIO_FUNC_RES_TRUE BIT(15) +#define AR933X_GPIO_FUNC_SPI_CS_EN2 BIT(14) +#define AR933X_GPIO_FUNC_SPI_CS_EN1 BIT(13) +#define AR933X_GPIO_FUNC_XLNA_EN BIT(12) +#define AR933X_GPIO_FUNC_ETH_SWITCH_LED4_EN BIT(7) +#define AR933X_GPIO_FUNC_ETH_SWITCH_LED3_EN BIT(6) +#define AR933X_GPIO_FUNC_ETH_SWITCH_LED2_EN BIT(5) +#define AR933X_GPIO_FUNC_ETH_SWITCH_LED1_EN BIT(4) +#define AR933X_GPIO_FUNC_ETH_SWITCH_LED0_EN BIT(3) +#define AR933X_GPIO_FUNC_UART_RTS_CTS_EN BIT(2) +#define AR933X_GPIO_FUNC_UART_EN BIT(1) +#define AR933X_GPIO_FUNC_JTAG_DISABLE BIT(0) + +#define AR934X_GPIO_FUNC_CLK_OBS7_EN BIT(9) +#define AR934X_GPIO_FUNC_CLK_OBS6_EN BIT(8) +#define AR934X_GPIO_FUNC_CLK_OBS5_EN BIT(7) +#define AR934X_GPIO_FUNC_CLK_OBS4_EN BIT(6) +#define AR934X_GPIO_FUNC_CLK_OBS3_EN BIT(5) +#define AR934X_GPIO_FUNC_CLK_OBS2_EN BIT(4) +#define AR934X_GPIO_FUNC_CLK_OBS1_EN BIT(3) +#define AR934X_GPIO_FUNC_CLK_OBS0_EN BIT(2) +#define AR934X_GPIO_FUNC_JTAG_DISABLE BIT(1) + +#define AR934X_GPIO_OUT_GPIO 0 +#define AR934X_GPIO_OUT_SPI_CS1 7 +#define AR934X_GPIO_OUT_LED_LINK0 41 +#define AR934X_GPIO_OUT_LED_LINK1 42 +#define AR934X_GPIO_OUT_LED_LINK2 43 +#define AR934X_GPIO_OUT_LED_LINK3 44 +#define AR934X_GPIO_OUT_LED_LINK4 45 +#define AR934X_GPIO_OUT_EXT_LNA0 46 +#define AR934X_GPIO_OUT_EXT_LNA1 47 + +#define QCA953X_GPIO(x) BIT(x) +#define QCA953X_GPIO_MUX_MASK(x) (0xff << (x)) +#define QCA953X_GPIO_OUT_MUX_SPI_CS1 10 +#define QCA953X_GPIO_OUT_MUX_SPI_CS2 11 +#define QCA953X_GPIO_OUT_MUX_SPI_CS0 9 +#define QCA953X_GPIO_OUT_MUX_SPI_CLK 8 +#define QCA953X_GPIO_OUT_MUX_SPI_MOSI 12 +#define QCA953X_GPIO_OUT_MUX_UART0_SOUT 22 +#define QCA953X_GPIO_OUT_MUX_LED_LINK1 41 +#define QCA953X_GPIO_OUT_MUX_LED_LINK2 42 +#define QCA953X_GPIO_OUT_MUX_LED_LINK3 43 +#define QCA953X_GPIO_OUT_MUX_LED_LINK4 44 +#define QCA953X_GPIO_OUT_MUX_LED_LINK5 45 + +#define QCA953X_GPIO_IN_MUX_UART0_SIN 9 +#define QCA953X_GPIO_IN_MUX_SPI_DATA_IN 8 + +#define QCA956X_GPIO_OUT_MUX_GE0_MDO 32 +#define QCA956X_GPIO_OUT_MUX_GE0_MDC 33 + +#define AR71XX_GPIO_COUNT 16 +#define AR7240_GPIO_COUNT 18 +#define AR7241_GPIO_COUNT 20 +#define AR913X_GPIO_COUNT 22 +#define AR933X_GPIO_COUNT 30 +#define AR934X_GPIO_COUNT 23 +#define QCA953X_GPIO_COUNT 18 +#define QCA955X_GPIO_COUNT 24 +#define QCA956X_GPIO_COUNT 23 + +/* + * SRIF block + */ +#define AR933X_SRIF_DDR_DPLL1_REG 0x240 +#define AR933X_SRIF_DDR_DPLL2_REG 0x244 +#define AR933X_SRIF_DDR_DPLL3_REG 0x248 +#define AR933X_SRIF_DDR_DPLL4_REG 0x24c + +#define AR934X_SRIF_CPU_DPLL1_REG 0x1c0 +#define AR934X_SRIF_CPU_DPLL2_REG 0x1c4 +#define AR934X_SRIF_CPU_DPLL3_REG 0x1c8 + +#define AR934X_SRIF_DDR_DPLL1_REG 0x240 +#define AR934X_SRIF_DDR_DPLL2_REG 0x244 +#define AR934X_SRIF_DDR_DPLL3_REG 0x248 + +#define AR934X_SRIF_DPLL1_REFDIV_SHIFT 27 +#define AR934X_SRIF_DPLL1_REFDIV_MASK 0x1f +#define AR934X_SRIF_DPLL1_NINT_SHIFT 18 +#define AR934X_SRIF_DPLL1_NINT_MASK 0x1ff +#define AR934X_SRIF_DPLL1_NFRAC_MASK 0x0003ffff + +#define AR934X_SRIF_DPLL2_LOCAL_PLL BIT(30) +#define AR934X_SRIF_DPLL2_OUTDIV_SHIFT 13 +#define AR934X_SRIF_DPLL2_OUTDIV_MASK 0x7 + +#define QCA953X_SRIF_BB_DPLL1_REG 0x180 +#define QCA953X_SRIF_BB_DPLL2_REG 0x184 +#define QCA953X_SRIF_BB_DPLL3_REG 0x188 + +#define QCA953X_SRIF_CPU_DPLL1_REG 0x1c0 +#define QCA953X_SRIF_CPU_DPLL2_REG 0x1c4 +#define QCA953X_SRIF_CPU_DPLL3_REG 0x1c8 + +#define QCA953X_SRIF_DDR_DPLL1_REG 0x240 +#define QCA953X_SRIF_DDR_DPLL2_REG 0x244 +#define QCA953X_SRIF_DDR_DPLL3_REG 0x248 + +#define QCA953X_SRIF_PCIE_DPLL1_REG 0xc00 +#define QCA953X_SRIF_PCIE_DPLL2_REG 0xc04 +#define QCA953X_SRIF_PCIE_DPLL3_REG 0xc08 + +#define QCA953X_SRIF_PMU1_REG 0xc40 +#define QCA953X_SRIF_PMU2_REG 0xc44 + +#define QCA953X_SRIF_DPLL1_REFDIV_SHIFT 27 +#define QCA953X_SRIF_DPLL1_REFDIV_MASK 0x1f + +#define QCA953X_SRIF_DPLL1_NINT_SHIFT 18 +#define QCA953X_SRIF_DPLL1_NINT_MASK 0x1ff +#define QCA953X_SRIF_DPLL1_NFRAC_MASK 0x0003ffff + +#define QCA953X_SRIF_DPLL2_LOCAL_PLL BIT(30) + +#define QCA953X_SRIF_DPLL2_KI_SHIFT 29 +#define QCA953X_SRIF_DPLL2_KI_MASK 0x3 + +#define QCA953X_SRIF_DPLL2_KD_SHIFT 25 +#define QCA953X_SRIF_DPLL2_KD_MASK 0xf + +#define QCA953X_SRIF_DPLL2_PWD BIT(22) + +#define QCA953X_SRIF_DPLL2_OUTDIV_SHIFT 13 +#define QCA953X_SRIF_DPLL2_OUTDIV_MASK 0x7 + +/* + * MII_CTRL block + */ +#define AR71XX_MII_REG_MII0_CTRL 0x00 +#define AR71XX_MII_REG_MII1_CTRL 0x04 + +#define AR71XX_MII_CTRL_IF_MASK 3 +#define AR71XX_MII_CTRL_SPEED_SHIFT 4 +#define AR71XX_MII_CTRL_SPEED_MASK 3 +#define AR71XX_MII_CTRL_SPEED_10 0 +#define AR71XX_MII_CTRL_SPEED_100 1 +#define AR71XX_MII_CTRL_SPEED_1000 2 + +#define AR71XX_MII0_CTRL_IF_GMII 0 +#define AR71XX_MII0_CTRL_IF_MII 1 +#define AR71XX_MII0_CTRL_IF_RGMII 2 +#define AR71XX_MII0_CTRL_IF_RMII 3 + +#define AR71XX_MII1_CTRL_IF_RGMII 0 +#define AR71XX_MII1_CTRL_IF_RMII 1 + +/* + * AR933X GMAC interface + */ +#define AR933X_GMAC_REG_ETH_CFG 0x00 + +#define AR933X_ETH_CFG_RGMII_GE0 BIT(0) +#define AR933X_ETH_CFG_MII_GE0 BIT(1) +#define AR933X_ETH_CFG_GMII_GE0 BIT(2) +#define AR933X_ETH_CFG_MII_GE0_MASTER BIT(3) +#define AR933X_ETH_CFG_MII_GE0_SLAVE BIT(4) +#define AR933X_ETH_CFG_MII_GE0_ERR_EN BIT(5) +#define AR933X_ETH_CFG_SW_PHY_SWAP BIT(7) +#define AR933X_ETH_CFG_SW_PHY_ADDR_SWAP BIT(8) +#define AR933X_ETH_CFG_RMII_GE0 BIT(9) +#define AR933X_ETH_CFG_RMII_GE0_SPD_10 0 +#define AR933X_ETH_CFG_RMII_GE0_SPD_100 BIT(10) + +/* + * AR934X GMAC Interface + */ +#define AR934X_GMAC_REG_ETH_CFG 0x00 + +#define AR934X_ETH_CFG_RGMII_GMAC0 BIT(0) +#define AR934X_ETH_CFG_MII_GMAC0 BIT(1) +#define AR934X_ETH_CFG_GMII_GMAC0 BIT(2) +#define AR934X_ETH_CFG_MII_GMAC0_MASTER BIT(3) +#define AR934X_ETH_CFG_MII_GMAC0_SLAVE BIT(4) +#define AR934X_ETH_CFG_MII_GMAC0_ERR_EN BIT(5) +#define AR934X_ETH_CFG_SW_ONLY_MODE BIT(6) +#define AR934X_ETH_CFG_SW_PHY_SWAP BIT(7) +#define AR934X_ETH_CFG_SW_APB_ACCESS BIT(9) +#define AR934X_ETH_CFG_RMII_GMAC0 BIT(10) +#define AR933X_ETH_CFG_MII_CNTL_SPEED BIT(11) +#define AR934X_ETH_CFG_RMII_GMAC0_MASTER BIT(12) +#define AR933X_ETH_CFG_SW_ACC_MSB_FIRST BIT(13) +#define AR934X_ETH_CFG_RXD_DELAY BIT(14) +#define AR934X_ETH_CFG_RXD_DELAY_MASK 0x3 +#define AR934X_ETH_CFG_RXD_DELAY_SHIFT 14 +#define AR934X_ETH_CFG_RDV_DELAY BIT(16) +#define AR934X_ETH_CFG_RDV_DELAY_MASK 0x3 +#define AR934X_ETH_CFG_RDV_DELAY_SHIFT 16 + +/* + * QCA953X GMAC Interface + */ +#define QCA953X_GMAC_REG_ETH_CFG 0x00 + +#define QCA953X_ETH_CFG_SW_ONLY_MODE BIT(6) +#define QCA953X_ETH_CFG_SW_PHY_SWAP BIT(7) +#define QCA953X_ETH_CFG_SW_APB_ACCESS BIT(9) +#define QCA953X_ETH_CFG_SW_ACC_MSB_FIRST BIT(13) + +/* + * QCA955X GMAC Interface + */ + +#define QCA955X_GMAC_REG_ETH_CFG 0x00 + +#define QCA955X_ETH_CFG_RGMII_EN BIT(0) +#define QCA955X_ETH_CFG_GE0_SGMII BIT(6) + +#endif /* __ASM_AR71XX_H */ diff --git a/arch/mips/mach-ath79/include/mach/ath79.h b/arch/mips/mach-ath79/include/mach/ath79.h new file mode 100644 index 0000000..90d80b8 --- /dev/null +++ b/arch/mips/mach-ath79/include/mach/ath79.h @@ -0,0 +1,143 @@ +/* + * Atheros AR71XX/AR724X/AR913X common definitions + * + * Copyright (C) 2015-2016 Wills Wang wills.wang@live.com + * Copyright (C) 2008-2011 Gabor Juhos juhosg@openwrt.org + * Copyright (C) 2008 Imre Kaloz kaloz@openwrt.org + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __ASM_MACH_ATH79_H +#define __ASM_MACH_ATH79_H + +#include <linux/types.h> + +DECLARE_GLOBAL_DATA_PTR; + +enum ath79_soc_type { + ATH79_SOC_UNKNOWN, + ATH79_SOC_AR7130, + ATH79_SOC_AR7141, + ATH79_SOC_AR7161, + ATH79_SOC_AR7240, + ATH79_SOC_AR7241, + ATH79_SOC_AR7242, + ATH79_SOC_AR9130, + ATH79_SOC_AR9132, + ATH79_SOC_AR9330, + ATH79_SOC_AR9331, + ATH79_SOC_AR9341, + ATH79_SOC_AR9342, + ATH79_SOC_AR9344, + ATH79_SOC_QCA9533, + ATH79_SOC_QCA9556, + ATH79_SOC_QCA9558, + ATH79_SOC_TP9343, + ATH79_SOC_QCA9561, +}; + +static inline int soc_is_ar71xx(void) +{ + return gd->arch.soc == ATH79_SOC_AR7130 || + gd->arch.soc == ATH79_SOC_AR7141 || + gd->arch.soc == ATH79_SOC_AR7161; +} + +static inline int soc_is_ar724x(void) +{ + return gd->arch.soc == ATH79_SOC_AR7240 || + gd->arch.soc == ATH79_SOC_AR7241 || + gd->arch.soc == ATH79_SOC_AR7242; +} + +static inline int soc_is_ar7240(void) +{ + return gd->arch.soc == ATH79_SOC_AR7240; +} + +static inline int soc_is_ar7241(void) +{ + return gd->arch.soc == ATH79_SOC_AR7241; +} + +static inline int soc_is_ar7242(void) +{ + return gd->arch.soc == ATH79_SOC_AR7242; +} + +static inline int soc_is_ar913x(void) +{ + return gd->arch.soc == ATH79_SOC_AR9130 || + gd->arch.soc == ATH79_SOC_AR9132; +} + +static inline int soc_is_ar933x(void) +{ + return gd->arch.soc == ATH79_SOC_AR9330 || + gd->arch.soc == ATH79_SOC_AR9331; +} + +static inline int soc_is_ar9341(void) +{ + return gd->arch.soc == ATH79_SOC_AR9341; +} + +static inline int soc_is_ar9342(void) +{ + return gd->arch.soc == ATH79_SOC_AR9342; +} + +static inline int soc_is_ar9344(void) +{ + return gd->arch.soc == ATH79_SOC_AR9344; +} + +static inline int soc_is_ar934x(void) +{ + return soc_is_ar9341() || + soc_is_ar9342() || + soc_is_ar9344(); +} + +static inline int soc_is_qca9533(void) +{ + return gd->arch.soc == ATH79_SOC_QCA9533; +} + +static inline int soc_is_qca953x(void) +{ + return soc_is_qca9533(); +} + +static inline int soc_is_qca9556(void) +{ + return gd->arch.soc == ATH79_SOC_QCA9556; +} + +static inline int soc_is_qca9558(void) +{ + return gd->arch.soc == ATH79_SOC_QCA9558; +} + +static inline int soc_is_qca955x(void) +{ + return soc_is_qca9556() || soc_is_qca9558(); +} + +static inline int soc_is_tp9343(void) +{ + return gd->arch.soc == ATH79_SOC_TP9343; +} + +static inline int soc_is_qca9561(void) +{ + return gd->arch.soc == ATH79_SOC_QCA9561; +} + +static inline int soc_is_qca956x(void) +{ + return soc_is_tp9343() || soc_is_qca9561(); +} + +#endif /* __ASM_MACH_ATH79_H */ diff --git a/arch/mips/mach-ath79/include/mach/ddr.h b/arch/mips/mach-ath79/include/mach/ddr.h new file mode 100644 index 0000000..181179a --- /dev/null +++ b/arch/mips/mach-ath79/include/mach/ddr.h @@ -0,0 +1,13 @@ +/* + * Copyright (C) 2015-2016 Wills Wang wills.wang@live.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __ASM_MACH_DDR_H +#define __ASM_MACH_DDR_H + +void ddr_init(void); +void ddr_tap_tuning(void); + +#endif /* __ASM_MACH_DDR_H */ diff --git a/arch/mips/mach-ath79/include/mach/reset.h b/arch/mips/mach-ath79/include/mach/reset.h new file mode 100644 index 0000000..c383bfe --- /dev/null +++ b/arch/mips/mach-ath79/include/mach/reset.h @@ -0,0 +1,14 @@ +/* + * Copyright (C) 2015-2016 Wills Wang wills.wang@live.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __ASM_MACH_RESET_H +#define __ASM_MACH_RESET_H + +#include <linux/types.h> + +u32 get_bootstrap(void); + +#endif /* __ASM_MACH_RESET_H */ diff --git a/arch/mips/mach-ath79/reset.c b/arch/mips/mach-ath79/reset.c new file mode 100644 index 0000000..2ea2f8d --- /dev/null +++ b/arch/mips/mach-ath79/reset.c @@ -0,0 +1,71 @@ +/* + * Copyright (C) 2015-2016 Wills Wang wills.wang@live.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/addrspace.h> +#include <asm/types.h> +#include <mach/ath79.h> +#include <mach/ar71xx_regs.h> + +void _machine_restart(void) +{ + void __iomem *base; + u32 reg = 0; + + base = map_physmem(AR71XX_RESET_BASE, AR71XX_RESET_SIZE, + MAP_NOCACHE); + if (soc_is_ar71xx()) + reg = AR71XX_RESET_REG_RESET_MODULE; + else if (soc_is_ar724x()) + reg = AR724X_RESET_REG_RESET_MODULE; + else if (soc_is_ar913x()) + reg = AR913X_RESET_REG_RESET_MODULE; + else if (soc_is_ar933x()) + reg = AR933X_RESET_REG_RESET_MODULE; + else if (soc_is_ar934x()) + reg = AR934X_RESET_REG_RESET_MODULE; + else if (soc_is_qca953x()) + reg = QCA953X_RESET_REG_RESET_MODULE; + else if (soc_is_qca955x()) + reg = QCA955X_RESET_REG_RESET_MODULE; + else if (soc_is_qca956x()) + reg = QCA956X_RESET_REG_RESET_MODULE; + else + puts("Reset register not defined for this SOC\n"); + + if (reg) + setbits_be32(base + reg, AR71XX_RESET_FULL_CHIP); + + while (1) + /* NOP */; +} + +u32 get_bootstrap(void) +{ + const void __iomem *base; + u32 reg = 0; + + base = map_physmem(AR71XX_RESET_BASE, AR71XX_RESET_SIZE, + MAP_NOCACHE); + if (soc_is_ar933x()) + reg = AR933X_RESET_REG_BOOTSTRAP; + else if (soc_is_ar934x()) + reg = AR934X_RESET_REG_BOOTSTRAP; + else if (soc_is_qca953x()) + reg = QCA953X_RESET_REG_BOOTSTRAP; + else if (soc_is_qca955x()) + reg = QCA955X_RESET_REG_BOOTSTRAP; + else if (soc_is_qca956x()) + reg = QCA956X_RESET_REG_BOOTSTRAP; + else + puts("Bootstrap register not defined for this SOC\n"); + + if (reg) + return readl(base + reg); + + return 0; +}
Changes in v8:
- Use setbits_be32
Good stuff, minor nits below.
- Copyright (C) 2015-2016 Wills Wang wills.wang@live.com
- enum ath79_soc_type soc;
- const char *chip;
- int major;
- int minor;
All of this stuff can be const, no ?
- ddr_tap_tuning();
Is the DDR tap tuning needed on all AR7xxx/AR9xxx systems ?
- return get_ram_size((void *)KSEG1, SZ_256M);
- Atheros AR71XX/AR724X/AR913X SoC register definitions
- Copyright (C) 2010-2011 Jaiganesh Narayanan jnarayanan@atheros.com
- Copyright (C) 2008-2010 Gabor Juhos juhosg@openwrt.org
- Copyright (C) 2008 Imre Kaloz kaloz@openwrt.org
This should really go into some common header.
+#endif +#endif
Indent the macro value with tabs in this file please.
Changes in v8:
- Use setbits_be32
- const char *chip;
- int major;
- int minor;
OK.
- ddr_tap_tuning();
Yes, it's for optimizing DDR timing according to hardware. Sometimes, the hard code value is not ideal.
This header is also included by some assembly code, but the BIT macro in linux/bitops.h isn't compatiable with assembler.
+#endif +#endif
Changes in v8:
- Use setbits_be32
- ddr_tap_tuning();
AR934x doesn't seem to need this.
Because of the 1UL in it ?
Changes in v8:
- Use setbits_be32
- ddr_tap_tuning();
I seem the following code in u-boot from Atheros LSDK: #ifdef CONFIG_AP123 ath_ddr_tap_cal();
Yes, there are also a few other C keywords and syntax, such as in-line function.
Changes in v8:
- Use setbits_be32
- ddr_tap_tuning();
Where can I get the LSDK ? I'd like to take a look and add it into my ar934x support patch.
Hmmmmm, it pains me to see such duplication, but I have no better idea how to deal with it without introducing ifdefs.
Changes in v8:
- Use setbits_be32
- ddr_tap_tuning();
You can refer to u-boot from Atheros QSDK https://us.codeaurora.org/cgit/quic/qsdk/oss/boot/u-boot-1.1.4/ It's almost same as u-boot from Atheros LSDK. The above snippet can be found in https://us.codeaurora.org/cgit/quic/qsdk/oss/boot/u-boot-1.1.4/tree/board/ar...
On 03/16/2016 09:59 AM, Wills Wang wrote: > This patch add some common code for QCA/Atheros ath79 SOCs such as > DDR tuning, chip reset and CPU detection. > > Signed-off-by: Wills Wang wills.wang@live.com > --- > > Changes in v8: > - Use setbits_be32 > - Use lookup-table instead of big switch statement for CPU detection > Good stuff, minor nits below.
> +phys_size_t initdram(int board_type) > +{ > + ddr_tap_tuning(); Is the DDR tap tuning needed on all AR7xxx/AR9xxx systems ?
Thank you!
> + return get_ram_size((void *)KSEG1, SZ_256M); > +} > diff --git a/arch/mips/mach-ath79/include/mach/ar71xx_regs.h > b/arch/mips/mach-ath79/include/mach/ar71xx_regs.h > new file mode 100644 > index 0000000..893dedc > --- /dev/null > +++ b/arch/mips/mach-ath79/include/mach/ar71xx_regs.h > @@ -0,0 +1,1184 @@ > +/* > + * Atheros AR71XX/AR724X/AR913X SoC register definitions > + * > + * Copyright (C) 2015-2016 Wills Wang wills.wang@live.com > + * Copyright (C) 2010-2011 Jaiganesh Narayanan > jnarayanan@atheros.com > + * Copyright (C) 2008-2010 Gabor Juhos juhosg@openwrt.org > + * Copyright (C) 2008 Imre Kaloz kaloz@openwrt.org > + * > + * SPDX-License-Identifier: GPL-2.0+ > + */ > + > +#ifndef __ASM_MACH_AR71XX_REGS_H > +#define __ASM_MACH_AR71XX_REGS_H > + > +#ifndef __ASSEMBLY__ > +#include <linux/bitops.h> > +#else > +#ifndef BIT > +#define BIT(nr) (1 << (nr)) This should really go into some common header.
Daniel, can we have this V8 applied, so I can start adding more stuff on top of these patches into mainline ?
Thanks!
2016-03-17 13:20 GMT+01:00 Marek Vasut marex@denx.de:
This patch add some common code for QCA/Atheros ath79 SOCs such as DDR tuning, chip reset and CPU detection.
Changes in v8:
- Use setbits_be32
- ddr_tap_tuning();
actually such register definitions files are obsolete because register base adresses and sizes are taken from device-tree. The only exceptions are early startup or assembly code, but then you only need to add the definitions whose are needed by a driver. Thus I suggest you remove all the crap from this file you don't need.
And put the remaining bits into drivers themselves , right ?
But still, this doesn't help us with the BIT() macro redefinition problem.
Am 16.03.2016 um 09:59 schrieb Wills Wang:
all nine patches applied to u-boot-mips/next, thanks.
Changes in v8:
- Use setbits_be32
Changes in v7:
- Use setbits_32
- Fix include path for SoC specific headers
Changes in v6:
- Move ar933x as separate patch
- Add get_bootstrap in reset.c
- Use map_physmem instead of KSEG1ADDR
- Add arch_cpu_init for detect SOC type for early
Changes in v5:
- Add independent Kconfig
- Use SRAM for initial stack
- Move DDR initialization into board_early_init_f
- Convert DDR tap tunning code to C
- Save SOC's version into arch_global_data
Changes in v4:
- Use global_data to save CPU/DDR/AHB clock
- Use arch_global_data to save SOC's type, revison and id
Changes in v3:
- Move SoC specific header files into arch/mips/mach-ath79/include/mach
- Optimize assembly code
- Same code style convertion
Changes in v2:
- Move all SoC specific header files into arch/mips/include/asm/arch-ath79
- Check SOC type and extract common code into arch/mips/mach-ath79
arch/mips/Kconfig | 6 + arch/mips/Makefile | 1 + arch/mips/include/asm/global_data.h | 6 + arch/mips/mach-ath79/Kconfig | 7 + arch/mips/mach-ath79/Makefile | 7 + arch/mips/mach-ath79/cpu.c | 142 +++ arch/mips/mach-ath79/dram.c | 16 + arch/mips/mach-ath79/include/mach/ar71xx_regs.h | 1184 +++++++++++++++++++++++ arch/mips/mach-ath79/include/mach/ath79.h | 143 +++ arch/mips/mach-ath79/include/mach/ddr.h | 13 + arch/mips/mach-ath79/include/mach/reset.h | 14 + arch/mips/mach-ath79/reset.c | 71 ++ 12 files changed, 1610 insertions(+) create mode 100644 arch/mips/mach-ath79/Kconfig create mode 100644 arch/mips/mach-ath79/Makefile create mode 100644 arch/mips/mach-ath79/cpu.c create mode 100644 arch/mips/mach-ath79/dram.c create mode 100644 arch/mips/mach-ath79/include/mach/ar71xx_regs.h create mode 100644 arch/mips/mach-ath79/include/mach/ath79.h create mode 100644 arch/mips/mach-ath79/include/mach/ddr.h create mode 100644 arch/mips/mach-ath79/include/mach/reset.h create mode 100644 arch/mips/mach-ath79/reset.c
diff --git a/arch/mips/Kconfig b/arch/mips/Kconfig index f852a1f..fbedb29 100644 --- a/arch/mips/Kconfig +++ b/arch/mips/Kconfig @@ -55,6 +55,11 @@ config TARGET_PB1X00 select SYS_MIPS_CACHE_INIT_RAM_LOAD select MIPS_TUNE_4KC
+config ARCH_ATH79
- bool "Support QCA/Atheros ath79"
- select OF_CONTROL
- select DM
config MACH_PIC32 bool "Support Microchip PIC32" select OF_CONTROL @@ -67,6 +72,7 @@ source "board/imgtec/malta/Kconfig" source "board/micronas/vct/Kconfig" source "board/pb1x00/Kconfig" source "board/qemu-mips/Kconfig" +source "arch/mips/mach-ath79/Kconfig" source "arch/mips/mach-pic32/Kconfig"
if MIPS diff --git a/arch/mips/Makefile b/arch/mips/Makefile index aec5a15..7a82316 100644 --- a/arch/mips/Makefile +++ b/arch/mips/Makefile @@ -8,6 +8,7 @@ libs-y += arch/mips/cpu/ libs-y += arch/mips/lib/
machine-$(CONFIG_SOC_AU1X00) += au1x00 +machine-$(CONFIG_ARCH_ATH79) += ath79 machine-$(CONFIG_MACH_PIC32) += pic32
machdirs := $(patsubst %,arch/mips/mach-%/,$(machine-y)) diff --git a/arch/mips/include/asm/global_data.h b/arch/mips/include/asm/global_data.h index a1ca257..3f230b0 100644 --- a/arch/mips/include/asm/global_data.h +++ b/arch/mips/include/asm/global_data.h @@ -23,6 +23,12 @@ struct arch_global_data { unsigned long tbl; unsigned long lastinc; #endif +#ifdef CONFIG_ARCH_ATH79
- unsigned long id;
- unsigned long soc;
- unsigned long rev;
- unsigned long ver;
+#endif };
#include <asm-generic/global_data.h> diff --git a/arch/mips/mach-ath79/Kconfig b/arch/mips/mach-ath79/Kconfig new file mode 100644 index 0000000..7d8ce09 --- /dev/null +++ b/arch/mips/mach-ath79/Kconfig @@ -0,0 +1,7 @@ +menu "QCA/Atheros 7xxx/9xxx platforms"
- depends on ARCH_ATH79
+config SYS_SOC
- default "ath79"
+endmenu diff --git a/arch/mips/mach-ath79/Makefile b/arch/mips/mach-ath79/Makefile new file mode 100644 index 0000000..6203cf0 --- /dev/null +++ b/arch/mips/mach-ath79/Makefile @@ -0,0 +1,7 @@ +# +# SPDX-License-Identifier: GPL-2.0+ +#
+obj-y += reset.o +obj-y += cpu.o +obj-y += dram.o diff --git a/arch/mips/mach-ath79/cpu.c b/arch/mips/mach-ath79/cpu.c new file mode 100644 index 0000000..c6122f2 --- /dev/null +++ b/arch/mips/mach-ath79/cpu.c @@ -0,0 +1,142 @@ +/*
+struct ath79_soc_desc {
- const char *chip;
- int major;
- int minor;
+static struct ath79_soc_desc desc[] = {
- {ATH79_SOC_AR7130, "7130",
REV_ID_MAJOR_AR71XX, AR71XX_REV_ID_MINOR_AR7130},
- {ATH79_SOC_AR7141, "7141",
REV_ID_MAJOR_AR71XX, AR71XX_REV_ID_MINOR_AR7141},
- {ATH79_SOC_AR7161, "7161",
REV_ID_MAJOR_AR71XX, AR71XX_REV_ID_MINOR_AR7161},
- {ATH79_SOC_AR7240, "7240", REV_ID_MAJOR_AR7240, 0},
- {ATH79_SOC_AR7241, "7241", REV_ID_MAJOR_AR7241, 0},
- {ATH79_SOC_AR7242, "7242", REV_ID_MAJOR_AR7242, 0},
- {ATH79_SOC_AR9130, "9130",
REV_ID_MAJOR_AR913X, AR913X_REV_ID_MINOR_AR9130},
- {ATH79_SOC_AR9132, "9132",
REV_ID_MAJOR_AR913X, AR913X_REV_ID_MINOR_AR9132},
- {ATH79_SOC_AR9330, "9330", REV_ID_MAJOR_AR9330, 0},
- {ATH79_SOC_AR9331, "9331", REV_ID_MAJOR_AR9331, 0},
- {ATH79_SOC_AR9341, "9341", REV_ID_MAJOR_AR9341, 0},
- {ATH79_SOC_AR9342, "9342", REV_ID_MAJOR_AR9342, 0},
- {ATH79_SOC_AR9344, "9344", REV_ID_MAJOR_AR9344, 0},
- {ATH79_SOC_QCA9533, "9533", REV_ID_MAJOR_QCA9533, 0},
REV_ID_MAJOR_QCA9533_V2, 0},
- {ATH79_SOC_QCA9556, "9556", REV_ID_MAJOR_QCA9556, 0},
- {ATH79_SOC_QCA9558, "9558", REV_ID_MAJOR_QCA9558, 0},
- {ATH79_SOC_TP9343, "9343", REV_ID_MAJOR_TP9343, 0},
- {ATH79_SOC_QCA9561, "9561", REV_ID_MAJOR_QCA9561, 0},
+int arch_cpu_init(void) +{
- void __iomem *base;
- enum ath79_soc_type soc = ATH79_SOC_UNKNOWN;
- u32 id, major, minor = 0;
- u32 rev = 0, ver = 1;
- int i;
- base = map_physmem(AR71XX_RESET_BASE, AR71XX_RESET_SIZE,
MAP_NOCACHE);
- id = readl(base + AR71XX_RESET_REG_REV_ID);
- major = id & REV_ID_MAJOR_MASK;
- switch (major) {
- case REV_ID_MAJOR_AR71XX:
- case REV_ID_MAJOR_AR913X:
minor = id & AR71XX_REV_ID_MINOR_MASK;
rev = id >> AR71XX_REV_ID_REVISION_SHIFT;
rev &= AR71XX_REV_ID_REVISION_MASK;
break;
- case REV_ID_MAJOR_QCA9533_V2:
ver = 2;
/* drop through */
- case REV_ID_MAJOR_AR9341:
- case REV_ID_MAJOR_AR9342:
- case REV_ID_MAJOR_AR9344:
- case REV_ID_MAJOR_QCA9533:
- case REV_ID_MAJOR_QCA9556:
- case REV_ID_MAJOR_QCA9558:
- case REV_ID_MAJOR_TP9343:
- case REV_ID_MAJOR_QCA9561:
rev = id & AR71XX_REV_ID_REVISION2_MASK;
break;
- default:
rev = id & AR71XX_REV_ID_REVISION_MASK;
break;
- for (i = 0; i < ARRAY_SIZE(desc); i++) {
if ((desc[i].major == major) &&
(desc[i].minor == minor)) {
soc = desc[i].soc;
break;
- gd->arch.id = id;
- gd->arch.soc = soc;
- gd->arch.rev = rev;
- gd->arch.ver = ver;
+int print_cpuinfo(void) +{
- const char *chip = "????";
- u32 id, rev, ver;
- int i;
if (desc[i].soc == gd->arch.soc) {
chip = desc[i].chip;
soc = desc[i].soc;
break;
- id = gd->arch.id;
- rev = gd->arch.rev;
- ver = gd->arch.ver;
- switch (soc) {
- case ATH79_SOC_QCA9533:
- case ATH79_SOC_QCA9556:
- case ATH79_SOC_QCA9558:
- case ATH79_SOC_QCA9561:
printf("Qualcomm Atheros QCA%s ver %u rev %u\n", chip,
ver, rev);
break;
- case ATH79_SOC_TP9343:
printf("Qualcomm Atheros TP%s rev %u\n", chip, rev);
break;
- case ATH79_SOC_UNKNOWN:
printf("ATH79: unknown SoC, id:0x%08x", id);
break;
- default:
printf("Atheros AR%s rev %u\n", chip, rev);
+} diff --git a/arch/mips/mach-ath79/dram.c b/arch/mips/mach-ath79/dram.c new file mode 100644 index 0000000..c29e98c --- /dev/null +++ b/arch/mips/mach-ath79/dram.c @@ -0,0 +1,16 @@ +/*
+#include <common.h> +#include <linux/sizes.h> +#include <asm/addrspace.h> +#include <mach/ddr.h>
+phys_size_t initdram(int board_type) +{
- ddr_tap_tuning();
+} diff --git a/arch/mips/mach-ath79/include/mach/ar71xx_regs.h b/arch/mips/mach-ath79/include/mach/ar71xx_regs.h new file mode 100644 index 0000000..893dedc --- /dev/null +++ b/arch/mips/mach-ath79/include/mach/ar71xx_regs.h @@ -0,0 +1,1184 @@ +/*
+#ifndef __ASM_MACH_AR71XX_REGS_H +#define __ASM_MACH_AR71XX_REGS_H
+#ifndef __ASSEMBLY__ +#include <linux/bitops.h> +#else +#ifndef BIT +#define BIT(nr) (1 << (nr)) +#endif +#endif
+#define AR71XX_APB_BASE 0x18000000 +#define AR71XX_GE0_BASE 0x19000000 +#define AR71XX_GE0_SIZE 0x10000 +#define AR71XX_GE1_BASE 0x1a000000 +#define AR71XX_GE1_SIZE 0x10000 +#define AR71XX_EHCI_BASE 0x1b000000 +#define AR71XX_EHCI_SIZE 0x1000 +#define AR71XX_OHCI_BASE 0x1c000000 +#define AR71XX_OHCI_SIZE 0x1000 +#define AR71XX_SPI_BASE 0x1f000000 +#define AR71XX_SPI_SIZE 0x01000000
+#define AR71XX_DDR_CTRL_BASE (AR71XX_APB_BASE + 0x00000000) +#define AR71XX_DDR_CTRL_SIZE 0x100 +#define AR71XX_UART_BASE (AR71XX_APB_BASE + 0x00020000) +#define AR71XX_UART_SIZE 0x100 +#define AR71XX_USB_CTRL_BASE (AR71XX_APB_BASE + 0x00030000) +#define AR71XX_USB_CTRL_SIZE 0x100 +#define AR71XX_GPIO_BASE (AR71XX_APB_BASE + 0x00040000) +#define AR71XX_GPIO_SIZE 0x100 +#define AR71XX_PLL_BASE (AR71XX_APB_BASE + 0x00050000) +#define AR71XX_PLL_SIZE 0x100 +#define AR71XX_RESET_BASE (AR71XX_APB_BASE + 0x00060000) +#define AR71XX_RESET_SIZE 0x100 +#define AR71XX_MII_BASE (AR71XX_APB_BASE + 0x00070000) +#define AR71XX_MII_SIZE 0x100
+#define AR71XX_PCI_MEM_BASE 0x10000000 +#define AR71XX_PCI_MEM_SIZE 0x07000000
+#define AR71XX_PCI_WIN0_OFFS 0x10000000 +#define AR71XX_PCI_WIN1_OFFS 0x11000000 +#define AR71XX_PCI_WIN2_OFFS 0x12000000 +#define AR71XX_PCI_WIN3_OFFS 0x13000000 +#define AR71XX_PCI_WIN4_OFFS 0x14000000 +#define AR71XX_PCI_WIN5_OFFS 0x15000000 +#define AR71XX_PCI_WIN6_OFFS 0x16000000 +#define AR71XX_PCI_WIN7_OFFS 0x07000000
+#define AR71XX_PCI_CFG_BASE \
- (AR71XX_PCI_MEM_BASE + AR71XX_PCI_WIN7_OFFS + 0x10000)
+#define AR71XX_PCI_CFG_SIZE 0x100
+#define AR7240_USB_CTRL_BASE (AR71XX_APB_BASE + 0x00030000) +#define AR7240_USB_CTRL_SIZE 0x100 +#define AR7240_OHCI_BASE 0x1b000000 +#define AR7240_OHCI_SIZE 0x1000
+#define AR724X_PCI_MEM_BASE 0x10000000 +#define AR724X_PCI_MEM_SIZE 0x04000000
+#define AR724X_PCI_CFG_BASE 0x14000000 +#define AR724X_PCI_CFG_SIZE 0x1000 +#define AR724X_PCI_CRP_BASE (AR71XX_APB_BASE + 0x000c0000) +#define AR724X_PCI_CRP_SIZE 0x1000 +#define AR724X_PCI_CTRL_BASE (AR71XX_APB_BASE + 0x000f0000) +#define AR724X_PCI_CTRL_SIZE 0x100
+#define AR724X_EHCI_BASE 0x1b000000 +#define AR724X_EHCI_SIZE 0x1000
+#define AR913X_EHCI_BASE 0x1b000000 +#define AR913X_EHCI_SIZE 0x1000 +#define AR913X_WMAC_BASE (AR71XX_APB_BASE + 0x000C0000) +#define AR913X_WMAC_SIZE 0x30000
+#define AR933X_UART_BASE (AR71XX_APB_BASE + 0x00020000) +#define AR933X_UART_SIZE 0x14 +#define AR933X_GMAC_BASE (AR71XX_APB_BASE + 0x00070000) +#define AR933X_GMAC_SIZE 0x04 +#define AR933X_WMAC_BASE (AR71XX_APB_BASE + 0x00100000) +#define AR933X_WMAC_SIZE 0x20000 +#define AR933X_RTC_BASE (AR71XX_APB_BASE + 0x00107000) +#define AR933X_RTC_SIZE 0x1000 +#define AR933X_EHCI_BASE 0x1b000000 +#define AR933X_EHCI_SIZE 0x1000 +#define AR933X_SRIF_BASE (AR71XX_APB_BASE + 0x00116000) +#define AR933X_SRIF_SIZE 0x1000
+#define AR934X_GMAC_BASE (AR71XX_APB_BASE + 0x00070000) +#define AR934X_GMAC_SIZE 0x14 +#define AR934X_WMAC_BASE (AR71XX_APB_BASE + 0x00100000) +#define AR934X_WMAC_SIZE 0x20000 +#define AR934X_EHCI_BASE 0x1b000000 +#define AR934X_EHCI_SIZE 0x200 +#define AR934X_NFC_BASE 0x1b000200 +#define AR934X_NFC_SIZE 0xb8 +#define AR934X_SRIF_BASE (AR71XX_APB_BASE + 0x00116000) +#define AR934X_SRIF_SIZE 0x1000
+#define QCA953X_GMAC_BASE (AR71XX_APB_BASE + 0x00070000) +#define QCA953X_GMAC_SIZE 0x14 +#define QCA953X_WMAC_BASE (AR71XX_APB_BASE + 0x00100000) +#define QCA953X_WMAC_SIZE 0x20000 +#define QCA953X_RTC_BASE (AR71XX_APB_BASE + 0x00107000) +#define QCA953X_RTC_SIZE 0x1000 +#define QCA953X_EHCI_BASE 0x1b000000 +#define QCA953X_EHCI_SIZE 0x200 +#define QCA953X_SRIF_BASE (AR71XX_APB_BASE + 0x00116000) +#define QCA953X_SRIF_SIZE 0x1000
+#define QCA953X_PCI_CFG_BASE0 0x14000000 +#define QCA953X_PCI_CTRL_BASE0 (AR71XX_APB_BASE + 0x000f0000) +#define QCA953X_PCI_CRP_BASE0 (AR71XX_APB_BASE + 0x000c0000) +#define QCA953X_PCI_MEM_BASE0 0x10000000 +#define QCA953X_PCI_MEM_SIZE 0x02000000
+#define QCA955X_PCI_MEM_BASE0 0x10000000 +#define QCA955X_PCI_MEM_BASE1 0x12000000 +#define QCA955X_PCI_MEM_SIZE 0x02000000 +#define QCA955X_PCI_CFG_BASE0 0x14000000 +#define QCA955X_PCI_CFG_BASE1 0x16000000 +#define QCA955X_PCI_CFG_SIZE 0x1000 +#define QCA955X_PCI_CRP_BASE0 (AR71XX_APB_BASE + 0x000c0000) +#define QCA955X_PCI_CRP_BASE1 (AR71XX_APB_BASE + 0x00250000) +#define QCA955X_PCI_CRP_SIZE 0x1000 +#define QCA955X_PCI_CTRL_BASE0 (AR71XX_APB_BASE + 0x000f0000) +#define QCA955X_PCI_CTRL_BASE1 (AR71XX_APB_BASE + 0x00280000) +#define QCA955X_PCI_CTRL_SIZE 0x100
+#define QCA955X_GMAC_BASE (AR71XX_APB_BASE + 0x00070000) +#define QCA955X_GMAC_SIZE 0x40 +#define QCA955X_WMAC_BASE (AR71XX_APB_BASE + 0x00100000) +#define QCA955X_WMAC_SIZE 0x20000 +#define QCA955X_EHCI0_BASE 0x1b000000 +#define QCA955X_EHCI1_BASE 0x1b400000 +#define QCA955X_EHCI_SIZE 0x1000 +#define QCA955X_NFC_BASE 0x1b800200 +#define QCA955X_NFC_SIZE 0xb8
+#define QCA956X_PCI_MEM_BASE1 0x12000000 +#define QCA956X_PCI_MEM_SIZE 0x02000000 +#define QCA956X_PCI_CFG_BASE1 0x16000000 +#define QCA956X_PCI_CFG_SIZE 0x1000 +#define QCA956X_PCI_CRP_BASE1 (AR71XX_APB_BASE + 0x00250000) +#define QCA956X_PCI_CRP_SIZE 0x1000 +#define QCA956X_PCI_CTRL_BASE1 (AR71XX_APB_BASE + 0x00280000) +#define QCA956X_PCI_CTRL_SIZE 0x100
+#define QCA956X_WMAC_BASE (AR71XX_APB_BASE + 0x00100000) +#define QCA956X_WMAC_SIZE 0x20000 +#define QCA956X_EHCI0_BASE 0x1b000000 +#define QCA956X_EHCI1_BASE 0x1b400000 +#define QCA956X_EHCI_SIZE 0x200 +#define QCA956X_GMAC_BASE (AR71XX_APB_BASE + 0x00070000) +#define QCA956X_GMAC_SIZE 0x64
- DDR_CTRL block
+#define AR71XX_DDR_REG_CONFIG 0x00 +#define AR71XX_DDR_REG_CONFIG2 0x04 +#define AR71XX_DDR_REG_MODE 0x08 +#define AR71XX_DDR_REG_EMR 0x0c +#define AR71XX_DDR_REG_CONTROL 0x10 +#define AR71XX_DDR_REG_REFRESH 0x14 +#define AR71XX_DDR_REG_RD_CYCLE 0x18 +#define AR71XX_DDR_REG_TAP_CTRL0 0x1c +#define AR71XX_DDR_REG_TAP_CTRL1 0x20
+#define AR71XX_DDR_REG_PCI_WIN0 0x7c +#define AR71XX_DDR_REG_PCI_WIN1 0x80 +#define AR71XX_DDR_REG_PCI_WIN2 0x84 +#define AR71XX_DDR_REG_PCI_WIN3 0x88 +#define AR71XX_DDR_REG_PCI_WIN4 0x8c +#define AR71XX_DDR_REG_PCI_WIN5 0x90 +#define AR71XX_DDR_REG_PCI_WIN6 0x94 +#define AR71XX_DDR_REG_PCI_WIN7 0x98 +#define AR71XX_DDR_REG_FLUSH_GE0 0x9c +#define AR71XX_DDR_REG_FLUSH_GE1 0xa0 +#define AR71XX_DDR_REG_FLUSH_USB 0xa4 +#define AR71XX_DDR_REG_FLUSH_PCI 0xa8
+#define AR724X_DDR_REG_FLUSH_GE0 0x7c +#define AR724X_DDR_REG_FLUSH_GE1 0x80 +#define AR724X_DDR_REG_FLUSH_USB 0x84 +#define AR724X_DDR_REG_FLUSH_PCIE 0x88
+#define AR913X_DDR_REG_FLUSH_GE0 0x7c +#define AR913X_DDR_REG_FLUSH_GE1 0x80 +#define AR913X_DDR_REG_FLUSH_USB 0x84 +#define AR913X_DDR_REG_FLUSH_WMAC 0x88
+#define AR933X_DDR_REG_FLUSH_GE0 0x7c +#define AR933X_DDR_REG_FLUSH_GE1 0x80 +#define AR933X_DDR_REG_FLUSH_USB 0x84 +#define AR933X_DDR_REG_FLUSH_WMAC 0x88 +#define AR933X_DDR_REG_DDR2_CONFIG 0x8c +#define AR933X_DDR_REG_EMR2 0x90 +#define AR933X_DDR_REG_EMR3 0x94 +#define AR933X_DDR_REG_BURST 0x98 +#define AR933X_DDR_REG_TIMEOUT_MAX 0x9c +#define AR933X_DDR_REG_TIMEOUT_CNT 0x9c +#define AR933X_DDR_REG_TIMEOUT_ADDR 0x9c
+#define AR934X_DDR_REG_FLUSH_GE0 0x9c +#define AR934X_DDR_REG_FLUSH_GE1 0xa0 +#define AR934X_DDR_REG_FLUSH_USB 0xa4 +#define AR934X_DDR_REG_FLUSH_PCIE 0xa8 +#define AR934X_DDR_REG_FLUSH_WMAC 0xac
+#define QCA953X_DDR_REG_FLUSH_GE0 0x9c +#define QCA953X_DDR_REG_FLUSH_GE1 0xa0 +#define QCA953X_DDR_REG_FLUSH_USB 0xa4 +#define QCA953X_DDR_REG_FLUSH_PCIE 0xa8 +#define QCA953X_DDR_REG_FLUSH_WMAC 0xac +#define QCA953X_DDR_REG_DDR2_CONFIG 0xb8 +#define QCA953X_DDR_REG_BURST 0xc4 +#define QCA953X_DDR_REG_BURST2 0xc8 +#define QCA953X_DDR_REG_TIMEOUT_MAX 0xcc +#define QCA953X_DDR_REG_CTL_CONF 0x108 +#define QCA953X_DDR_REG_CONFIG3 0x15c
- PLL block
+#define AR71XX_PLL_REG_CPU_CONFIG 0x00 +#define AR71XX_PLL_REG_SEC_CONFIG 0x04 +#define AR71XX_PLL_REG_ETH0_INT_CLOCK 0x10 +#define AR71XX_PLL_REG_ETH1_INT_CLOCK 0x14
+#define AR71XX_PLL_DIV_SHIFT 3 +#define AR71XX_PLL_DIV_MASK 0x1f +#define AR71XX_CPU_DIV_SHIFT 16 +#define AR71XX_CPU_DIV_MASK 0x3 +#define AR71XX_DDR_DIV_SHIFT 18 +#define AR71XX_DDR_DIV_MASK 0x3 +#define AR71XX_AHB_DIV_SHIFT 20 +#define AR71XX_AHB_DIV_MASK 0x7
+#define AR71XX_ETH0_PLL_SHIFT 17 +#define AR71XX_ETH1_PLL_SHIFT 19
+#define AR724X_PLL_REG_CPU_CONFIG 0x00 +#define AR724X_PLL_REG_PCIE_CONFIG 0x18
+#define AR724X_PLL_DIV_SHIFT 0 +#define AR724X_PLL_DIV_MASK 0x3ff +#define AR724X_PLL_REF_DIV_SHIFT 10 +#define AR724X_PLL_REF_DIV_MASK 0xf +#define AR724X_AHB_DIV_SHIFT 19 +#define AR724X_AHB_DIV_MASK 0x1 +#define AR724X_DDR_DIV_SHIFT 22 +#define AR724X_DDR_DIV_MASK 0x3
+#define AR7242_PLL_REG_ETH0_INT_CLOCK 0x2c
+#define AR913X_PLL_REG_CPU_CONFIG 0x00 +#define AR913X_PLL_REG_ETH_CONFIG 0x04 +#define AR913X_PLL_REG_ETH0_INT_CLOCK 0x14 +#define AR913X_PLL_REG_ETH1_INT_CLOCK 0x18
+#define AR913X_PLL_DIV_SHIFT 0 +#define AR913X_PLL_DIV_MASK 0x3ff +#define AR913X_DDR_DIV_SHIFT 22 +#define AR913X_DDR_DIV_MASK 0x3 +#define AR913X_AHB_DIV_SHIFT 19 +#define AR913X_AHB_DIV_MASK 0x1
+#define AR913X_ETH0_PLL_SHIFT 20 +#define AR913X_ETH1_PLL_SHIFT 22
+#define AR933X_PLL_CPU_CONFIG_REG 0x00 +#define AR933X_PLL_CLK_CTRL_REG 0x08 +#define AR933X_PLL_DITHER_FRAC_REG 0x10
+#define AR933X_PLL_CPU_CONFIG_NINT_SHIFT 10 +#define AR933X_PLL_CPU_CONFIG_NINT_MASK 0x3f +#define AR933X_PLL_CPU_CONFIG_REFDIV_SHIFT 16 +#define AR933X_PLL_CPU_CONFIG_REFDIV_MASK 0x1f +#define AR933X_PLL_CPU_CONFIG_OUTDIV_SHIFT 23 +#define AR933X_PLL_CPU_CONFIG_OUTDIV_MASK 0x7
+#define AR933X_PLL_CLK_CTRL_BYPASS BIT(2) +#define AR933X_PLL_CLK_CTRL_CPU_POST_DIV_SHIFT 5 +#define AR933X_PLL_CLK_CTRL_CPU_POST_DIV_MASK 0x3 +#define AR933X_PLL_CLK_CTRL_DDR_POST_DIV_SHIFT 10 +#define AR933X_PLL_CLK_CTRL_DDR_POST_DIV_MASK 0x3 +#define AR933X_PLL_CLK_CTRL_AHB_POST_DIV_SHIFT 15 +#define AR933X_PLL_CLK_CTRL_AHB_POST_DIV_MASK 0x7
+#define AR934X_PLL_CPU_CONFIG_REG 0x00 +#define AR934X_PLL_DDR_CONFIG_REG 0x04 +#define AR934X_PLL_CPU_DDR_CLK_CTRL_REG 0x08 +#define AR934X_PLL_SWITCH_CLOCK_CONTROL_REG 0x24 +#define AR934X_PLL_ETH_XMII_CONTROL_REG 0x2c
+#define AR934X_PLL_CPU_CONFIG_NFRAC_SHIFT 0 +#define AR934X_PLL_CPU_CONFIG_NFRAC_MASK 0x3f +#define AR934X_PLL_CPU_CONFIG_NINT_SHIFT 6 +#define AR934X_PLL_CPU_CONFIG_NINT_MASK 0x3f +#define AR934X_PLL_CPU_CONFIG_REFDIV_SHIFT 12 +#define AR934X_PLL_CPU_CONFIG_REFDIV_MASK 0x1f +#define AR934X_PLL_CPU_CONFIG_OUTDIV_SHIFT 19 +#define AR934X_PLL_CPU_CONFIG_OUTDIV_MASK 0x3
+#define AR934X_PLL_DDR_CONFIG_NFRAC_SHIFT 0 +#define AR934X_PLL_DDR_CONFIG_NFRAC_MASK 0x3ff +#define AR934X_PLL_DDR_CONFIG_NINT_SHIFT 10 +#define AR934X_PLL_DDR_CONFIG_NINT_MASK 0x3f +#define AR934X_PLL_DDR_CONFIG_REFDIV_SHIFT 16 +#define AR934X_PLL_DDR_CONFIG_REFDIV_MASK 0x1f +#define AR934X_PLL_DDR_CONFIG_OUTDIV_SHIFT 23 +#define AR934X_PLL_DDR_CONFIG_OUTDIV_MASK 0x7
+#define AR934X_PLL_CLK_CTRL_CPU_PLL_BYPASS BIT(2) +#define AR934X_PLL_CLK_CTRL_DDR_PLL_BYPASS BIT(3) +#define AR934X_PLL_CLK_CTRL_AHB_PLL_BYPASS BIT(4) +#define AR934X_PLL_CLK_CTRL_CPU_POST_DIV_SHIFT 5 +#define AR934X_PLL_CLK_CTRL_CPU_POST_DIV_MASK 0x1f +#define AR934X_PLL_CLK_CTRL_DDR_POST_DIV_SHIFT 10 +#define AR934X_PLL_CLK_CTRL_DDR_POST_DIV_MASK 0x1f +#define AR934X_PLL_CLK_CTRL_AHB_POST_DIV_SHIFT 15 +#define AR934X_PLL_CLK_CTRL_AHB_POST_DIV_MASK 0x1f +#define AR934X_PLL_CLK_CTRL_CPUCLK_FROM_CPUPLL BIT(20) +#define AR934X_PLL_CLK_CTRL_DDRCLK_FROM_DDRPLL BIT(21) +#define AR934X_PLL_CLK_CTRL_AHBCLK_FROM_DDRPLL BIT(24)
+#define AR934X_PLL_SWITCH_CLK_CTRL_MDIO_CLK_SEL BIT(6)
+#define QCA953X_PLL_CPU_CONFIG_REG 0x00 +#define QCA953X_PLL_DDR_CONFIG_REG 0x04 +#define QCA953X_PLL_CLK_CTRL_REG 0x08 +#define QCA953X_PLL_SWITCH_CLOCK_CONTROL_REG 0x24 +#define QCA953X_PLL_ETH_XMII_CONTROL_REG 0x2c +#define QCA953X_PLL_DDR_DIT_FRAC_REG 0x44 +#define QCA953X_PLL_CPU_DIT_FRAC_REG 0x48
+#define QCA953X_PLL_CPU_CONFIG_NFRAC_SHIFT 0 +#define QCA953X_PLL_CPU_CONFIG_NFRAC_MASK 0x3f +#define QCA953X_PLL_CPU_CONFIG_NINT_SHIFT 6 +#define QCA953X_PLL_CPU_CONFIG_NINT_MASK 0x3f +#define QCA953X_PLL_CPU_CONFIG_REFDIV_SHIFT 12 +#define QCA953X_PLL_CPU_CONFIG_REFDIV_MASK 0x1f +#define QCA953X_PLL_CPU_CONFIG_OUTDIV_SHIFT 19 +#define QCA953X_PLL_CPU_CONFIG_OUTDIV_MASK 0x7
+#define QCA953X_PLL_DDR_CONFIG_NFRAC_SHIFT 0 +#define QCA953X_PLL_DDR_CONFIG_NFRAC_MASK 0x3ff +#define QCA953X_PLL_DDR_CONFIG_NINT_SHIFT 10 +#define QCA953X_PLL_DDR_CONFIG_NINT_MASK 0x3f +#define QCA953X_PLL_DDR_CONFIG_REFDIV_SHIFT 16 +#define QCA953X_PLL_DDR_CONFIG_REFDIV_MASK 0x1f +#define QCA953X_PLL_DDR_CONFIG_OUTDIV_SHIFT 23 +#define QCA953X_PLL_DDR_CONFIG_OUTDIV_MASK 0x7
+#define QCA953X_PLL_CONFIG_PWD BIT(30)
+#define QCA953X_PLL_CLK_CTRL_CPU_PLL_BYPASS BIT(2) +#define QCA953X_PLL_CLK_CTRL_DDR_PLL_BYPASS BIT(3) +#define QCA953X_PLL_CLK_CTRL_AHB_PLL_BYPASS BIT(4) +#define QCA953X_PLL_CLK_CTRL_CPU_POST_DIV_SHIFT 5 +#define QCA953X_PLL_CLK_CTRL_CPU_POST_DIV_MASK 0x1f +#define QCA953X_PLL_CLK_CTRL_DDR_POST_DIV_SHIFT 10 +#define QCA953X_PLL_CLK_CTRL_DDR_POST_DIV_MASK 0x1f +#define QCA953X_PLL_CLK_CTRL_AHB_POST_DIV_SHIFT 15 +#define QCA953X_PLL_CLK_CTRL_AHB_POST_DIV_MASK 0x1f +#define QCA953X_PLL_CLK_CTRL_CPUCLK_FROM_CPUPLL BIT(20) +#define QCA953X_PLL_CLK_CTRL_DDRCLK_FROM_DDRPLL BIT(21) +#define QCA953X_PLL_CLK_CTRL_AHBCLK_FROM_DDRPLL BIT(24)
+#define QCA953X_PLL_CPU_DIT_FRAC_MAX_SHIFT 0 +#define QCA953X_PLL_CPU_DIT_FRAC_MAX_MASK 0x3f +#define QCA953X_PLL_CPU_DIT_FRAC_MIN_SHIFT 6 +#define QCA953X_PLL_CPU_DIT_FRAC_MIN_MASK 0x3f +#define QCA953X_PLL_CPU_DIT_FRAC_STEP_SHIFT 12 +#define QCA953X_PLL_CPU_DIT_FRAC_STEP_MASK 0x3f +#define QCA953X_PLL_CPU_DIT_UPD_CNT_SHIFT 18 +#define QCA953X_PLL_CPU_DIT_UPD_CNT_MASK 0x3f
+#define QCA953X_PLL_DDR_DIT_FRAC_MAX_SHIFT 0 +#define QCA953X_PLL_DDR_DIT_FRAC_MAX_MASK 0x3ff +#define QCA953X_PLL_DDR_DIT_FRAC_MIN_SHIFT 9 +#define QCA953X_PLL_DDR_DIT_FRAC_MIN_MASK 0x3ff +#define QCA953X_PLL_DDR_DIT_FRAC_STEP_SHIFT 20 +#define QCA953X_PLL_DDR_DIT_FRAC_STEP_MASK 0x3f +#define QCA953X_PLL_DDR_DIT_UPD_CNT_SHIFT 27 +#define QCA953X_PLL_DDR_DIT_UPD_CNT_MASK 0x3f
+#define QCA953X_PLL_DIT_FRAC_EN BIT(31)
+#define QCA955X_PLL_CPU_CONFIG_REG 0x00 +#define QCA955X_PLL_DDR_CONFIG_REG 0x04 +#define QCA955X_PLL_CLK_CTRL_REG 0x08 +#define QCA955X_PLL_ETH_XMII_CONTROL_REG 0x28 +#define QCA955X_PLL_ETH_SGMII_CONTROL_REG 0x48
+#define QCA955X_PLL_CPU_CONFIG_NFRAC_SHIFT 0 +#define QCA955X_PLL_CPU_CONFIG_NFRAC_MASK 0x3f +#define QCA955X_PLL_CPU_CONFIG_NINT_SHIFT 6 +#define QCA955X_PLL_CPU_CONFIG_NINT_MASK 0x3f +#define QCA955X_PLL_CPU_CONFIG_REFDIV_SHIFT 12 +#define QCA955X_PLL_CPU_CONFIG_REFDIV_MASK 0x1f +#define QCA955X_PLL_CPU_CONFIG_OUTDIV_SHIFT 19 +#define QCA955X_PLL_CPU_CONFIG_OUTDIV_MASK 0x3
+#define QCA955X_PLL_DDR_CONFIG_NFRAC_SHIFT 0 +#define QCA955X_PLL_DDR_CONFIG_NFRAC_MASK 0x3ff +#define QCA955X_PLL_DDR_CONFIG_NINT_SHIFT 10 +#define QCA955X_PLL_DDR_CONFIG_NINT_MASK 0x3f +#define QCA955X_PLL_DDR_CONFIG_REFDIV_SHIFT 16 +#define QCA955X_PLL_DDR_CONFIG_REFDIV_MASK 0x1f +#define QCA955X_PLL_DDR_CONFIG_OUTDIV_SHIFT 23 +#define QCA955X_PLL_DDR_CONFIG_OUTDIV_MASK 0x7
+#define QCA955X_PLL_CLK_CTRL_CPU_PLL_BYPASS BIT(2) +#define QCA955X_PLL_CLK_CTRL_DDR_PLL_BYPASS BIT(3) +#define QCA955X_PLL_CLK_CTRL_AHB_PLL_BYPASS BIT(4) +#define QCA955X_PLL_CLK_CTRL_CPU_POST_DIV_SHIFT 5 +#define QCA955X_PLL_CLK_CTRL_CPU_POST_DIV_MASK 0x1f +#define QCA955X_PLL_CLK_CTRL_DDR_POST_DIV_SHIFT 10 +#define QCA955X_PLL_CLK_CTRL_DDR_POST_DIV_MASK 0x1f +#define QCA955X_PLL_CLK_CTRL_AHB_POST_DIV_SHIFT 15 +#define QCA955X_PLL_CLK_CTRL_AHB_POST_DIV_MASK 0x1f +#define QCA955X_PLL_CLK_CTRL_CPUCLK_FROM_CPUPLL BIT(20) +#define QCA955X_PLL_CLK_CTRL_DDRCLK_FROM_DDRPLL BIT(21) +#define QCA955X_PLL_CLK_CTRL_AHBCLK_FROM_DDRPLL BIT(24)
+#define QCA956X_PLL_CPU_CONFIG_REG 0x00 +#define QCA956X_PLL_CPU_CONFIG1_REG 0x04 +#define QCA956X_PLL_DDR_CONFIG_REG 0x08 +#define QCA956X_PLL_DDR_CONFIG1_REG 0x0c +#define QCA956X_PLL_CLK_CTRL_REG 0x10
+#define QCA956X_PLL_CPU_CONFIG_REFDIV_SHIFT 12 +#define QCA956X_PLL_CPU_CONFIG_REFDIV_MASK 0x1f +#define QCA956X_PLL_CPU_CONFIG_OUTDIV_SHIFT 19 +#define QCA956X_PLL_CPU_CONFIG_OUTDIV_MASK 0x7
+#define QCA956X_PLL_CPU_CONFIG1_NFRAC_L_SHIFT 0 +#define QCA956X_PLL_CPU_CONFIG1_NFRAC_L_MASK 0x1f +#define QCA956X_PLL_CPU_CONFIG1_NFRAC_H_SHIFT 5 +#define QCA956X_PLL_CPU_CONFIG1_NFRAC_H_MASK 0x3fff +#define QCA956X_PLL_CPU_CONFIG1_NINT_SHIFT 18 +#define QCA956X_PLL_CPU_CONFIG1_NINT_MASK 0x1ff
+#define QCA956X_PLL_DDR_CONFIG_REFDIV_SHIFT 16 +#define QCA956X_PLL_DDR_CONFIG_REFDIV_MASK 0x1f +#define QCA956X_PLL_DDR_CONFIG_OUTDIV_SHIFT 23 +#define QCA956X_PLL_DDR_CONFIG_OUTDIV_MASK 0x7
+#define QCA956X_PLL_DDR_CONFIG1_NFRAC_L_SHIFT 0 +#define QCA956X_PLL_DDR_CONFIG1_NFRAC_L_MASK 0x1f +#define QCA956X_PLL_DDR_CONFIG1_NFRAC_H_SHIFT 5 +#define QCA956X_PLL_DDR_CONFIG1_NFRAC_H_MASK 0x3fff +#define QCA956X_PLL_DDR_CONFIG1_NINT_SHIFT 18 +#define QCA956X_PLL_DDR_CONFIG1_NINT_MASK 0x1ff
+#define QCA956X_PLL_CLK_CTRL_CPU_PLL_BYPASS BIT(2) +#define QCA956X_PLL_CLK_CTRL_DDR_PLL_BYPASS BIT(3) +#define QCA956X_PLL_CLK_CTRL_AHB_PLL_BYPASS BIT(4) +#define QCA956X_PLL_CLK_CTRL_CPU_POST_DIV_SHIFT 5 +#define QCA956X_PLL_CLK_CTRL_CPU_POST_DIV_MASK 0x1f +#define QCA956X_PLL_CLK_CTRL_DDR_POST_DIV_SHIFT 10 +#define QCA956X_PLL_CLK_CTRL_DDR_POST_DIV_MASK 0x1f +#define QCA956X_PLL_CLK_CTRL_AHB_POST_DIV_SHIFT 15 +#define QCA956X_PLL_CLK_CTRL_AHB_POST_DIV_MASK 0x1f +#define QCA956X_PLL_CLK_CTRL_CPU_DDRCLK_FROM_DDRPLL BIT(20) +#define QCA956X_PLL_CLK_CTRL_CPU_DDRCLK_FROM_CPUPLL BIT(21) +#define QCA956X_PLL_CLK_CTRL_AHBCLK_FROM_DDRPLL BIT(24)
- USB_CONFIG block
+#define AR71XX_USB_CTRL_REG_FLADJ 0x00 +#define AR71XX_USB_CTRL_REG_CONFIG 0x04
- RESET block
+#define AR71XX_RESET_REG_TIMER 0x00 +#define AR71XX_RESET_REG_TIMER_RELOAD 0x04 +#define AR71XX_RESET_REG_WDOG_CTRL 0x08 +#define AR71XX_RESET_REG_WDOG 0x0c +#define AR71XX_RESET_REG_MISC_INT_STATUS 0x10 +#define AR71XX_RESET_REG_MISC_INT_ENABLE 0x14 +#define AR71XX_RESET_REG_PCI_INT_STATUS 0x18 +#define AR71XX_RESET_REG_PCI_INT_ENABLE 0x1c +#define AR71XX_RESET_REG_GLOBAL_INT_STATUS 0x20 +#define AR71XX_RESET_REG_RESET_MODULE 0x24 +#define AR71XX_RESET_REG_PERFC_CTRL 0x2c +#define AR71XX_RESET_REG_PERFC0 0x30 +#define AR71XX_RESET_REG_PERFC1 0x34 +#define AR71XX_RESET_REG_REV_ID 0x90
+#define AR913X_RESET_REG_GLOBAL_INT_STATUS 0x18 +#define AR913X_RESET_REG_RESET_MODULE 0x1c +#define AR913X_RESET_REG_PERF_CTRL 0x20 +#define AR913X_RESET_REG_PERFC0 0x24 +#define AR913X_RESET_REG_PERFC1 0x28
+#define AR724X_RESET_REG_RESET_MODULE 0x1c
+#define AR933X_RESET_REG_RESET_MODULE 0x1c +#define AR933X_RESET_REG_BOOTSTRAP 0xac
+#define AR934X_RESET_REG_RESET_MODULE 0x1c +#define AR934X_RESET_REG_BOOTSTRAP 0xb0 +#define AR934X_RESET_REG_PCIE_WMAC_INT_STATUS 0xac
+#define QCA953X_RESET_REG_RESET_MODULE 0x1c +#define QCA953X_RESET_REG_BOOTSTRAP 0xb0 +#define QCA953X_RESET_REG_PCIE_WMAC_INT_STATUS 0xac
+#define QCA955X_RESET_REG_RESET_MODULE 0x1c +#define QCA955X_RESET_REG_BOOTSTRAP 0xb0 +#define QCA955X_RESET_REG_EXT_INT_STATUS 0xac
+#define QCA956X_RESET_REG_RESET_MODULE 0x1c +#define QCA956X_RESET_REG_BOOTSTRAP 0xb0 +#define QCA956X_RESET_REG_EXT_INT_STATUS 0xac
+#define MISC_INT_MIPS_SI_TIMERINT_MASK BIT(28) +#define MISC_INT_ETHSW BIT(12) +#define MISC_INT_TIMER4 BIT(10) +#define MISC_INT_TIMER3 BIT(9) +#define MISC_INT_TIMER2 BIT(8) +#define MISC_INT_DMA BIT(7) +#define MISC_INT_OHCI BIT(6) +#define MISC_INT_PERFC BIT(5) +#define MISC_INT_WDOG BIT(4) +#define MISC_INT_UART BIT(3) +#define MISC_INT_GPIO BIT(2) +#define MISC_INT_ERROR BIT(1) +#define MISC_INT_TIMER BIT(0)
+#define AR71XX_RESET_EXTERNAL BIT(28) +#define AR71XX_RESET_FULL_CHIP BIT(24) +#define AR71XX_RESET_CPU_NMI BIT(21) +#define AR71XX_RESET_CPU_COLD BIT(20) +#define AR71XX_RESET_DMA BIT(19) +#define AR71XX_RESET_SLIC BIT(18) +#define AR71XX_RESET_STEREO BIT(17) +#define AR71XX_RESET_DDR BIT(16) +#define AR71XX_RESET_GE1_MAC BIT(13) +#define AR71XX_RESET_GE1_PHY BIT(12) +#define AR71XX_RESET_USBSUS_OVERRIDE BIT(10) +#define AR71XX_RESET_GE0_MAC BIT(9) +#define AR71XX_RESET_GE0_PHY BIT(8) +#define AR71XX_RESET_USB_OHCI_DLL BIT(6) +#define AR71XX_RESET_USB_HOST BIT(5) +#define AR71XX_RESET_USB_PHY BIT(4) +#define AR71XX_RESET_PCI_BUS BIT(1) +#define AR71XX_RESET_PCI_CORE BIT(0)
+#define AR7240_RESET_USB_HOST BIT(5) +#define AR7240_RESET_OHCI_DLL BIT(3)
+#define AR724X_RESET_GE1_MDIO BIT(23) +#define AR724X_RESET_GE0_MDIO BIT(22) +#define AR724X_RESET_PCIE_PHY_SERIAL BIT(10) +#define AR724X_RESET_PCIE_PHY BIT(7) +#define AR724X_RESET_PCIE BIT(6) +#define AR724X_RESET_USB_HOST BIT(5) +#define AR724X_RESET_USB_PHY BIT(4) +#define AR724X_RESET_USBSUS_OVERRIDE BIT(3)
+#define AR913X_RESET_AMBA2WMAC BIT(22) +#define AR913X_RESET_USBSUS_OVERRIDE BIT(10) +#define AR913X_RESET_USB_HOST BIT(5) +#define AR913X_RESET_USB_PHY BIT(4)
+#define AR933X_RESET_GE1_MDIO BIT(23) +#define AR933X_RESET_GE0_MDIO BIT(22) +#define AR933X_RESET_GE1_MAC BIT(13) +#define AR933X_RESET_WMAC BIT(11) +#define AR933X_RESET_GE0_MAC BIT(9) +#define AR933X_RESET_USB_HOST BIT(5) +#define AR933X_RESET_USB_PHY BIT(4) +#define AR933X_RESET_USBSUS_OVERRIDE BIT(3)
+#define AR934X_RESET_HOST BIT(31) +#define AR934X_RESET_SLIC BIT(30) +#define AR934X_RESET_HDMA BIT(29) +#define AR934X_RESET_EXTERNAL BIT(28) +#define AR934X_RESET_RTC BIT(27) +#define AR934X_RESET_PCIE_EP_INT BIT(26) +#define AR934X_RESET_CHKSUM_ACC BIT(25) +#define AR934X_RESET_FULL_CHIP BIT(24) +#define AR934X_RESET_GE1_MDIO BIT(23) +#define AR934X_RESET_GE0_MDIO BIT(22) +#define AR934X_RESET_CPU_NMI BIT(21) +#define AR934X_RESET_CPU_COLD BIT(20) +#define AR934X_RESET_HOST_RESET_INT BIT(19) +#define AR934X_RESET_PCIE_EP BIT(18) +#define AR934X_RESET_UART1 BIT(17) +#define AR934X_RESET_DDR BIT(16) +#define AR934X_RESET_USB_PHY_PLL_PWD_EXT BIT(15) +#define AR934X_RESET_NANDF BIT(14) +#define AR934X_RESET_GE1_MAC BIT(13) +#define AR934X_RESET_ETH_SWITCH_ANALOG BIT(12) +#define AR934X_RESET_USB_PHY_ANALOG BIT(11) +#define AR934X_RESET_HOST_DMA_INT BIT(10) +#define AR934X_RESET_GE0_MAC BIT(9) +#define AR934X_RESET_ETH_SWITCH BIT(8) +#define AR934X_RESET_PCIE_PHY BIT(7) +#define AR934X_RESET_PCIE BIT(6) +#define AR934X_RESET_USB_HOST BIT(5) +#define AR934X_RESET_USB_PHY BIT(4) +#define AR934X_RESET_USBSUS_OVERRIDE BIT(3) +#define AR934X_RESET_LUT BIT(2) +#define AR934X_RESET_MBOX BIT(1) +#define AR934X_RESET_I2S BIT(0)
+#define QCA953X_RESET_USB_EXT_PWR BIT(29) +#define QCA953X_RESET_EXTERNAL BIT(28) +#define QCA953X_RESET_RTC BIT(27) +#define QCA953X_RESET_FULL_CHIP BIT(24) +#define QCA953X_RESET_GE1_MDIO BIT(23) +#define QCA953X_RESET_GE0_MDIO BIT(22) +#define QCA953X_RESET_CPU_NMI BIT(21) +#define QCA953X_RESET_CPU_COLD BIT(20) +#define QCA953X_RESET_DDR BIT(16) +#define QCA953X_RESET_USB_PHY_PLL_PWD_EXT BIT(15) +#define QCA953X_RESET_GE1_MAC BIT(13) +#define QCA953X_RESET_ETH_SWITCH_ANALOG BIT(12) +#define QCA953X_RESET_USB_PHY_ANALOG BIT(11) +#define QCA953X_RESET_GE0_MAC BIT(9) +#define QCA953X_RESET_ETH_SWITCH BIT(8) +#define QCA953X_RESET_PCIE_PHY BIT(7) +#define QCA953X_RESET_PCIE BIT(6) +#define QCA953X_RESET_USB_HOST BIT(5) +#define QCA953X_RESET_USB_PHY BIT(4) +#define QCA953X_RESET_USBSUS_OVERRIDE BIT(3)
+#define QCA955X_RESET_HOST BIT(31) +#define QCA955X_RESET_SLIC BIT(30) +#define QCA955X_RESET_HDMA BIT(29) +#define QCA955X_RESET_EXTERNAL BIT(28) +#define QCA955X_RESET_RTC BIT(27) +#define QCA955X_RESET_PCIE_EP_INT BIT(26) +#define QCA955X_RESET_CHKSUM_ACC BIT(25) +#define QCA955X_RESET_FULL_CHIP BIT(24) +#define QCA955X_RESET_GE1_MDIO BIT(23) +#define QCA955X_RESET_GE0_MDIO BIT(22) +#define QCA955X_RESET_CPU_NMI BIT(21) +#define QCA955X_RESET_CPU_COLD BIT(20) +#define QCA955X_RESET_HOST_RESET_INT BIT(19) +#define QCA955X_RESET_PCIE_EP BIT(18) +#define QCA955X_RESET_UART1 BIT(17) +#define QCA955X_RESET_DDR BIT(16) +#define QCA955X_RESET_USB_PHY_PLL_PWD_EXT BIT(15) +#define QCA955X_RESET_NANDF BIT(14) +#define QCA955X_RESET_GE1_MAC BIT(13) +#define QCA955X_RESET_SGMII_ANALOG BIT(12) +#define QCA955X_RESET_USB_PHY_ANALOG BIT(11) +#define QCA955X_RESET_HOST_DMA_INT BIT(10) +#define QCA955X_RESET_GE0_MAC BIT(9) +#define QCA955X_RESET_SGMII BIT(8) +#define QCA955X_RESET_PCIE_PHY BIT(7) +#define QCA955X_RESET_PCIE BIT(6) +#define QCA955X_RESET_USB_HOST BIT(5) +#define QCA955X_RESET_USB_PHY BIT(4) +#define QCA955X_RESET_USBSUS_OVERRIDE BIT(3) +#define QCA955X_RESET_LUT BIT(2) +#define QCA955X_RESET_MBOX BIT(1) +#define QCA955X_RESET_I2S BIT(0)
+#define AR933X_BOOTSTRAP_MDIO_GPIO_EN BIT(18) +#define AR933X_BOOTSTRAP_DDR2 BIT(13) +#define AR933X_BOOTSTRAP_EEPBUSY BIT(4) +#define AR933X_BOOTSTRAP_REF_CLK_40 BIT(0)
+#define AR934X_BOOTSTRAP_SW_OPTION8 BIT(23) +#define AR934X_BOOTSTRAP_SW_OPTION7 BIT(22) +#define AR934X_BOOTSTRAP_SW_OPTION6 BIT(21) +#define AR934X_BOOTSTRAP_SW_OPTION5 BIT(20) +#define AR934X_BOOTSTRAP_SW_OPTION4 BIT(19) +#define AR934X_BOOTSTRAP_SW_OPTION3 BIT(18) +#define AR934X_BOOTSTRAP_SW_OPTION2 BIT(17) +#define AR934X_BOOTSTRAP_SW_OPTION1 BIT(16) +#define AR934X_BOOTSTRAP_USB_MODE_DEVICE BIT(7) +#define AR934X_BOOTSTRAP_PCIE_RC BIT(6) +#define AR934X_BOOTSTRAP_EJTAG_MODE BIT(5) +#define AR934X_BOOTSTRAP_REF_CLK_40 BIT(4) +#define AR934X_BOOTSTRAP_BOOT_FROM_SPI BIT(2) +#define AR934X_BOOTSTRAP_SDRAM_DISABLED BIT(1) +#define AR934X_BOOTSTRAP_DDR1 BIT(0)
+#define QCA953X_BOOTSTRAP_SW_OPTION2 BIT(12) +#define QCA953X_BOOTSTRAP_SW_OPTION1 BIT(11) +#define QCA953X_BOOTSTRAP_EJTAG_MODE BIT(5) +#define QCA953X_BOOTSTRAP_REF_CLK_40 BIT(4) +#define QCA953X_BOOTSTRAP_SDRAM_DISABLED BIT(1) +#define QCA953X_BOOTSTRAP_DDR1 BIT(0)
+#define QCA955X_BOOTSTRAP_REF_CLK_40 BIT(4)
+#define QCA956X_BOOTSTRAP_REF_CLK_40 BIT(2)
+#define AR934X_PCIE_WMAC_INT_WMAC_MISC BIT(0) +#define AR934X_PCIE_WMAC_INT_WMAC_TX BIT(1) +#define AR934X_PCIE_WMAC_INT_WMAC_RXLP BIT(2) +#define AR934X_PCIE_WMAC_INT_WMAC_RXHP BIT(3) +#define AR934X_PCIE_WMAC_INT_PCIE_RC BIT(4) +#define AR934X_PCIE_WMAC_INT_PCIE_RC0 BIT(5) +#define AR934X_PCIE_WMAC_INT_PCIE_RC1 BIT(6) +#define AR934X_PCIE_WMAC_INT_PCIE_RC2 BIT(7) +#define AR934X_PCIE_WMAC_INT_PCIE_RC3 BIT(8) +#define AR934X_PCIE_WMAC_INT_WMAC_ALL \
- (AR934X_PCIE_WMAC_INT_WMAC_MISC | AR934X_PCIE_WMAC_INT_WMAC_TX | \
AR934X_PCIE_WMAC_INT_WMAC_RXLP | AR934X_PCIE_WMAC_INT_WMAC_RXHP)
+#define AR934X_PCIE_WMAC_INT_PCIE_ALL \
- (AR934X_PCIE_WMAC_INT_PCIE_RC | AR934X_PCIE_WMAC_INT_PCIE_RC0 | \
AR934X_PCIE_WMAC_INT_PCIE_RC1 | AR934X_PCIE_WMAC_INT_PCIE_RC2 | \
AR934X_PCIE_WMAC_INT_PCIE_RC3)
+#define QCA953X_PCIE_WMAC_INT_WMAC_MISC BIT(0) +#define QCA953X_PCIE_WMAC_INT_WMAC_TX BIT(1) +#define QCA953X_PCIE_WMAC_INT_WMAC_RXLP BIT(2) +#define QCA953X_PCIE_WMAC_INT_WMAC_RXHP BIT(3) +#define QCA953X_PCIE_WMAC_INT_PCIE_RC BIT(4) +#define QCA953X_PCIE_WMAC_INT_PCIE_RC0 BIT(5) +#define QCA953X_PCIE_WMAC_INT_PCIE_RC1 BIT(6) +#define QCA953X_PCIE_WMAC_INT_PCIE_RC2 BIT(7) +#define QCA953X_PCIE_WMAC_INT_PCIE_RC3 BIT(8) +#define QCA953X_PCIE_WMAC_INT_WMAC_ALL \
- (QCA953X_PCIE_WMAC_INT_WMAC_MISC | QCA953X_PCIE_WMAC_INT_WMAC_TX | \
QCA953X_PCIE_WMAC_INT_WMAC_RXLP | QCA953X_PCIE_WMAC_INT_WMAC_RXHP)
+#define QCA953X_PCIE_WMAC_INT_PCIE_ALL \
- (QCA953X_PCIE_WMAC_INT_PCIE_RC | QCA953X_PCIE_WMAC_INT_PCIE_RC0 | \
QCA953X_PCIE_WMAC_INT_PCIE_RC1 | QCA953X_PCIE_WMAC_INT_PCIE_RC2 | \
QCA953X_PCIE_WMAC_INT_PCIE_RC3)
+#define QCA955X_EXT_INT_WMAC_MISC BIT(0) +#define QCA955X_EXT_INT_WMAC_TX BIT(1) +#define QCA955X_EXT_INT_WMAC_RXLP BIT(2) +#define QCA955X_EXT_INT_WMAC_RXHP BIT(3) +#define QCA955X_EXT_INT_PCIE_RC1 BIT(4) +#define QCA955X_EXT_INT_PCIE_RC1_INT0 BIT(5) +#define QCA955X_EXT_INT_PCIE_RC1_INT1 BIT(6) +#define QCA955X_EXT_INT_PCIE_RC1_INT2 BIT(7) +#define QCA955X_EXT_INT_PCIE_RC1_INT3 BIT(8) +#define QCA955X_EXT_INT_PCIE_RC2 BIT(12) +#define QCA955X_EXT_INT_PCIE_RC2_INT0 BIT(13) +#define QCA955X_EXT_INT_PCIE_RC2_INT1 BIT(14) +#define QCA955X_EXT_INT_PCIE_RC2_INT2 BIT(15) +#define QCA955X_EXT_INT_PCIE_RC2_INT3 BIT(16) +#define QCA955X_EXT_INT_USB1 BIT(24) +#define QCA955X_EXT_INT_USB2 BIT(28)
+#define QCA955X_EXT_INT_WMAC_ALL \
- (QCA955X_EXT_INT_WMAC_MISC | QCA955X_EXT_INT_WMAC_TX | \
QCA955X_EXT_INT_WMAC_RXLP | QCA955X_EXT_INT_WMAC_RXHP)
+#define QCA955X_EXT_INT_PCIE_RC1_ALL \
- (QCA955X_EXT_INT_PCIE_RC1 | QCA955X_EXT_INT_PCIE_RC1_INT0 | \
QCA955X_EXT_INT_PCIE_RC1_INT1 | QCA955X_EXT_INT_PCIE_RC1_INT2 | \
QCA955X_EXT_INT_PCIE_RC1_INT3)
+#define QCA955X_EXT_INT_PCIE_RC2_ALL \
- (QCA955X_EXT_INT_PCIE_RC2 | QCA955X_EXT_INT_PCIE_RC2_INT0 | \
QCA955X_EXT_INT_PCIE_RC2_INT1 | QCA955X_EXT_INT_PCIE_RC2_INT2 | \
QCA955X_EXT_INT_PCIE_RC2_INT3)
+#define QCA956X_EXT_INT_WMAC_MISC BIT(0) +#define QCA956X_EXT_INT_WMAC_TX BIT(1) +#define QCA956X_EXT_INT_WMAC_RXLP BIT(2) +#define QCA956X_EXT_INT_WMAC_RXHP BIT(3) +#define QCA956X_EXT_INT_PCIE_RC1 BIT(4) +#define QCA956X_EXT_INT_PCIE_RC1_INT0 BIT(5) +#define QCA956X_EXT_INT_PCIE_RC1_INT1 BIT(6) +#define QCA956X_EXT_INT_PCIE_RC1_INT2 BIT(7) +#define QCA956X_EXT_INT_PCIE_RC1_INT3 BIT(8) +#define QCA956X_EXT_INT_PCIE_RC2 BIT(12) +#define QCA956X_EXT_INT_PCIE_RC2_INT0 BIT(13) +#define QCA956X_EXT_INT_PCIE_RC2_INT1 BIT(14) +#define QCA956X_EXT_INT_PCIE_RC2_INT2 BIT(15) +#define QCA956X_EXT_INT_PCIE_RC2_INT3 BIT(16) +#define QCA956X_EXT_INT_USB1 BIT(24) +#define QCA956X_EXT_INT_USB2 BIT(28)
+#define QCA956X_EXT_INT_WMAC_ALL \
- (QCA956X_EXT_INT_WMAC_MISC | QCA956X_EXT_INT_WMAC_TX | \
QCA956X_EXT_INT_WMAC_RXLP | QCA956X_EXT_INT_WMAC_RXHP)
+#define QCA956X_EXT_INT_PCIE_RC1_ALL \
- (QCA956X_EXT_INT_PCIE_RC1 | QCA956X_EXT_INT_PCIE_RC1_INT0 | \
QCA956X_EXT_INT_PCIE_RC1_INT1 | QCA956X_EXT_INT_PCIE_RC1_INT2 | \
QCA956X_EXT_INT_PCIE_RC1_INT3)
+#define QCA956X_EXT_INT_PCIE_RC2_ALL \
- (QCA956X_EXT_INT_PCIE_RC2 | QCA956X_EXT_INT_PCIE_RC2_INT0 | \
QCA956X_EXT_INT_PCIE_RC2_INT1 | QCA956X_EXT_INT_PCIE_RC2_INT2 | \
QCA956X_EXT_INT_PCIE_RC2_INT3)
+#define REV_ID_MAJOR_MASK 0xfff0 +#define REV_ID_MAJOR_AR71XX 0x00a0 +#define REV_ID_MAJOR_AR913X 0x00b0 +#define REV_ID_MAJOR_AR7240 0x00c0 +#define REV_ID_MAJOR_AR7241 0x0100 +#define REV_ID_MAJOR_AR7242 0x1100 +#define REV_ID_MAJOR_AR9330 0x0110 +#define REV_ID_MAJOR_AR9331 0x1110 +#define REV_ID_MAJOR_AR9341 0x0120 +#define REV_ID_MAJOR_AR9342 0x1120 +#define REV_ID_MAJOR_AR9344 0x2120 +#define REV_ID_MAJOR_QCA9533 0x0140 +#define REV_ID_MAJOR_QCA9533_V2 0x0160 +#define REV_ID_MAJOR_QCA9556 0x0130 +#define REV_ID_MAJOR_QCA9558 0x1130 +#define REV_ID_MAJOR_TP9343 0x0150 +#define REV_ID_MAJOR_QCA9561 0x1150
+#define AR71XX_REV_ID_MINOR_MASK 0x3 +#define AR71XX_REV_ID_MINOR_AR7130 0x0 +#define AR71XX_REV_ID_MINOR_AR7141 0x1 +#define AR71XX_REV_ID_MINOR_AR7161 0x2 +#define AR913X_REV_ID_MINOR_AR9130 0x0 +#define AR913X_REV_ID_MINOR_AR9132 0x1
+#define AR71XX_REV_ID_REVISION_MASK 0x3 +#define AR71XX_REV_ID_REVISION_SHIFT 2 +#define AR71XX_REV_ID_REVISION2_MASK 0xf
- RTC block
+#define AR933X_RTC_REG_RESET 0x40 +#define AR933X_RTC_REG_STATUS 0x44 +#define AR933X_RTC_REG_DERIVED 0x48 +#define AR933X_RTC_REG_FORCE_WAKE 0x4c +#define AR933X_RTC_REG_INT_CAUSE 0x50 +#define AR933X_RTC_REG_CAUSE_CLR 0x50 +#define AR933X_RTC_REG_INT_ENABLE 0x54 +#define AR933X_RTC_REG_INT_MASKE 0x58
+#define QCA953X_RTC_REG_SYNC_RESET 0x40 +#define QCA953X_RTC_REG_SYNC_STATUS 0x44
- SPI block
+#define AR71XX_SPI_REG_FS 0x00 +#define AR71XX_SPI_REG_CTRL 0x04 +#define AR71XX_SPI_REG_IOC 0x08 +#define AR71XX_SPI_REG_RDS 0x0c
+#define AR71XX_SPI_FS_GPIO BIT(0)
+#define AR71XX_SPI_CTRL_RD BIT(6) +#define AR71XX_SPI_CTRL_DIV_MASK 0x3f
+#define AR71XX_SPI_IOC_DO BIT(0) +#define AR71XX_SPI_IOC_CLK BIT(8) +#define AR71XX_SPI_IOC_CS(n) BIT(16 + (n)) +#define AR71XX_SPI_IOC_CS0 AR71XX_SPI_IOC_CS(0) +#define AR71XX_SPI_IOC_CS1 AR71XX_SPI_IOC_CS(1) +#define AR71XX_SPI_IOC_CS2 AR71XX_SPI_IOC_CS(2) +#define AR71XX_SPI_IOC_CS_ALL \
- (AR71XX_SPI_IOC_CS0 | AR71XX_SPI_IOC_CS1 | AR71XX_SPI_IOC_CS2)
- GPIO block
+#define AR71XX_GPIO_REG_OE 0x00 +#define AR71XX_GPIO_REG_IN 0x04 +#define AR71XX_GPIO_REG_OUT 0x08 +#define AR71XX_GPIO_REG_SET 0x0c +#define AR71XX_GPIO_REG_CLEAR 0x10 +#define AR71XX_GPIO_REG_INT_MODE 0x14 +#define AR71XX_GPIO_REG_INT_TYPE 0x18 +#define AR71XX_GPIO_REG_INT_POLARITY 0x1c +#define AR71XX_GPIO_REG_INT_PENDING 0x20 +#define AR71XX_GPIO_REG_INT_ENABLE 0x24 +#define AR71XX_GPIO_REG_FUNC 0x28 +#define AR933X_GPIO_REG_FUNC 0x30
+#define AR934X_GPIO_REG_OUT_FUNC0 0x2c +#define AR934X_GPIO_REG_OUT_FUNC1 0x30 +#define AR934X_GPIO_REG_OUT_FUNC2 0x34 +#define AR934X_GPIO_REG_OUT_FUNC3 0x38 +#define AR934X_GPIO_REG_OUT_FUNC4 0x3c +#define AR934X_GPIO_REG_OUT_FUNC5 0x40 +#define AR934X_GPIO_REG_FUNC 0x6c
+#define QCA953X_GPIO_REG_OUT_FUNC0 0x2c +#define QCA953X_GPIO_REG_OUT_FUNC1 0x30 +#define QCA953X_GPIO_REG_OUT_FUNC2 0x34 +#define QCA953X_GPIO_REG_OUT_FUNC3 0x38 +#define QCA953X_GPIO_REG_OUT_FUNC4 0x3c +#define QCA953X_GPIO_REG_IN_ENABLE0 0x44 +#define QCA953X_GPIO_REG_FUNC 0x6c
+#define QCA955X_GPIO_REG_OUT_FUNC0 0x2c +#define QCA955X_GPIO_REG_OUT_FUNC1 0x30 +#define QCA955X_GPIO_REG_OUT_FUNC2 0x34 +#define QCA955X_GPIO_REG_OUT_FUNC3 0x38 +#define QCA955X_GPIO_REG_OUT_FUNC4 0x3c +#define QCA955X_GPIO_REG_OUT_FUNC5 0x40 +#define QCA955X_GPIO_REG_FUNC 0x6c
+#define QCA956X_GPIO_REG_OUT_FUNC0 0x2c +#define QCA956X_GPIO_REG_OUT_FUNC1 0x30 +#define QCA956X_GPIO_REG_OUT_FUNC2 0x34 +#define QCA956X_GPIO_REG_OUT_FUNC3 0x38 +#define QCA956X_GPIO_REG_OUT_FUNC4 0x3c +#define QCA956X_GPIO_REG_OUT_FUNC5 0x40 +#define QCA956X_GPIO_REG_IN_ENABLE0 0x44 +#define QCA956X_GPIO_REG_IN_ENABLE3 0x50 +#define QCA956X_GPIO_REG_FUNC 0x6c
+#define AR71XX_GPIO_FUNC_STEREO_EN BIT(17) +#define AR71XX_GPIO_FUNC_SLIC_EN BIT(16) +#define AR71XX_GPIO_FUNC_SPI_CS2_EN BIT(13) +#define AR71XX_GPIO_FUNC_SPI_CS1_EN BIT(12) +#define AR71XX_GPIO_FUNC_UART_EN BIT(8) +#define AR71XX_GPIO_FUNC_USB_OC_EN BIT(4) +#define AR71XX_GPIO_FUNC_USB_CLK_EN BIT(0)
+#define AR724X_GPIO_FUNC_GE0_MII_CLK_EN BIT(19) +#define AR724X_GPIO_FUNC_SPI_EN BIT(18) +#define AR724X_GPIO_FUNC_SPI_CS_EN2 BIT(14) +#define AR724X_GPIO_FUNC_SPI_CS_EN1 BIT(13) +#define AR724X_GPIO_FUNC_CLK_OBS5_EN BIT(12) +#define AR724X_GPIO_FUNC_CLK_OBS4_EN BIT(11) +#define AR724X_GPIO_FUNC_CLK_OBS3_EN BIT(10) +#define AR724X_GPIO_FUNC_CLK_OBS2_EN BIT(9) +#define AR724X_GPIO_FUNC_CLK_OBS1_EN BIT(8) +#define AR724X_GPIO_FUNC_ETH_SWITCH_LED4_EN BIT(7) +#define AR724X_GPIO_FUNC_ETH_SWITCH_LED3_EN BIT(6) +#define AR724X_GPIO_FUNC_ETH_SWITCH_LED2_EN BIT(5) +#define AR724X_GPIO_FUNC_ETH_SWITCH_LED1_EN BIT(4) +#define AR724X_GPIO_FUNC_ETH_SWITCH_LED0_EN BIT(3) +#define AR724X_GPIO_FUNC_UART_RTS_CTS_EN BIT(2) +#define AR724X_GPIO_FUNC_UART_EN BIT(1) +#define AR724X_GPIO_FUNC_JTAG_DISABLE BIT(0)
+#define AR913X_GPIO_FUNC_WMAC_LED_EN BIT(22) +#define AR913X_GPIO_FUNC_EXP_PORT_CS_EN BIT(21) +#define AR913X_GPIO_FUNC_I2S_REFCLKEN BIT(20) +#define AR913X_GPIO_FUNC_I2S_MCKEN BIT(19) +#define AR913X_GPIO_FUNC_I2S1_EN BIT(18) +#define AR913X_GPIO_FUNC_I2S0_EN BIT(17) +#define AR913X_GPIO_FUNC_SLIC_EN BIT(16) +#define AR913X_GPIO_FUNC_UART_RTSCTS_EN BIT(9) +#define AR913X_GPIO_FUNC_UART_EN BIT(8) +#define AR913X_GPIO_FUNC_USB_CLK_EN BIT(4)
+#define AR933X_GPIO(x) BIT(x) +#define AR933X_GPIO_FUNC_SPDIF2TCK BIT(31) +#define AR933X_GPIO_FUNC_SPDIF_EN BIT(30) +#define AR933X_GPIO_FUNC_I2SO_22_18_EN BIT(29) +#define AR933X_GPIO_FUNC_I2S_MCK_EN BIT(27) +#define AR933X_GPIO_FUNC_I2SO_EN BIT(26) +#define AR933X_GPIO_FUNC_ETH_SWITCH_LED_DUPL BIT(25) +#define AR933X_GPIO_FUNC_ETH_SWITCH_LED_COLL BIT(24) +#define AR933X_GPIO_FUNC_ETH_SWITCH_LED_ACT BIT(23) +#define AR933X_GPIO_FUNC_SPI_EN BIT(18) +#define AR933X_GPIO_FUNC_RES_TRUE BIT(15) +#define AR933X_GPIO_FUNC_SPI_CS_EN2 BIT(14) +#define AR933X_GPIO_FUNC_SPI_CS_EN1 BIT(13) +#define AR933X_GPIO_FUNC_XLNA_EN BIT(12) +#define AR933X_GPIO_FUNC_ETH_SWITCH_LED4_EN BIT(7) +#define AR933X_GPIO_FUNC_ETH_SWITCH_LED3_EN BIT(6) +#define AR933X_GPIO_FUNC_ETH_SWITCH_LED2_EN BIT(5) +#define AR933X_GPIO_FUNC_ETH_SWITCH_LED1_EN BIT(4) +#define AR933X_GPIO_FUNC_ETH_SWITCH_LED0_EN BIT(3) +#define AR933X_GPIO_FUNC_UART_RTS_CTS_EN BIT(2) +#define AR933X_GPIO_FUNC_UART_EN BIT(1) +#define AR933X_GPIO_FUNC_JTAG_DISABLE BIT(0)
+#define AR934X_GPIO_FUNC_CLK_OBS7_EN BIT(9) +#define AR934X_GPIO_FUNC_CLK_OBS6_EN BIT(8) +#define AR934X_GPIO_FUNC_CLK_OBS5_EN BIT(7) +#define AR934X_GPIO_FUNC_CLK_OBS4_EN BIT(6) +#define AR934X_GPIO_FUNC_CLK_OBS3_EN BIT(5) +#define AR934X_GPIO_FUNC_CLK_OBS2_EN BIT(4) +#define AR934X_GPIO_FUNC_CLK_OBS1_EN BIT(3) +#define AR934X_GPIO_FUNC_CLK_OBS0_EN BIT(2) +#define AR934X_GPIO_FUNC_JTAG_DISABLE BIT(1)
+#define AR934X_GPIO_OUT_GPIO 0 +#define AR934X_GPIO_OUT_SPI_CS1 7 +#define AR934X_GPIO_OUT_LED_LINK0 41 +#define AR934X_GPIO_OUT_LED_LINK1 42 +#define AR934X_GPIO_OUT_LED_LINK2 43 +#define AR934X_GPIO_OUT_LED_LINK3 44 +#define AR934X_GPIO_OUT_LED_LINK4 45 +#define AR934X_GPIO_OUT_EXT_LNA0 46 +#define AR934X_GPIO_OUT_EXT_LNA1 47
+#define QCA953X_GPIO(x) BIT(x) +#define QCA953X_GPIO_MUX_MASK(x) (0xff << (x)) +#define QCA953X_GPIO_OUT_MUX_SPI_CS1 10 +#define QCA953X_GPIO_OUT_MUX_SPI_CS2 11 +#define QCA953X_GPIO_OUT_MUX_SPI_CS0 9 +#define QCA953X_GPIO_OUT_MUX_SPI_CLK 8 +#define QCA953X_GPIO_OUT_MUX_SPI_MOSI 12 +#define QCA953X_GPIO_OUT_MUX_UART0_SOUT 22 +#define QCA953X_GPIO_OUT_MUX_LED_LINK1 41 +#define QCA953X_GPIO_OUT_MUX_LED_LINK2 42 +#define QCA953X_GPIO_OUT_MUX_LED_LINK3 43 +#define QCA953X_GPIO_OUT_MUX_LED_LINK4 44 +#define QCA953X_GPIO_OUT_MUX_LED_LINK5 45
+#define QCA953X_GPIO_IN_MUX_UART0_SIN 9 +#define QCA953X_GPIO_IN_MUX_SPI_DATA_IN 8
+#define QCA956X_GPIO_OUT_MUX_GE0_MDO 32 +#define QCA956X_GPIO_OUT_MUX_GE0_MDC 33
+#define AR71XX_GPIO_COUNT 16 +#define AR7240_GPIO_COUNT 18 +#define AR7241_GPIO_COUNT 20 +#define AR913X_GPIO_COUNT 22 +#define AR933X_GPIO_COUNT 30 +#define AR934X_GPIO_COUNT 23 +#define QCA953X_GPIO_COUNT 18 +#define QCA955X_GPIO_COUNT 24 +#define QCA956X_GPIO_COUNT 23
- SRIF block
+#define AR933X_SRIF_DDR_DPLL1_REG 0x240 +#define AR933X_SRIF_DDR_DPLL2_REG 0x244 +#define AR933X_SRIF_DDR_DPLL3_REG 0x248 +#define AR933X_SRIF_DDR_DPLL4_REG 0x24c
+#define AR934X_SRIF_CPU_DPLL1_REG 0x1c0 +#define AR934X_SRIF_CPU_DPLL2_REG 0x1c4 +#define AR934X_SRIF_CPU_DPLL3_REG 0x1c8
+#define AR934X_SRIF_DDR_DPLL1_REG 0x240 +#define AR934X_SRIF_DDR_DPLL2_REG 0x244 +#define AR934X_SRIF_DDR_DPLL3_REG 0x248
+#define AR934X_SRIF_DPLL1_REFDIV_SHIFT 27 +#define AR934X_SRIF_DPLL1_REFDIV_MASK 0x1f +#define AR934X_SRIF_DPLL1_NINT_SHIFT 18 +#define AR934X_SRIF_DPLL1_NINT_MASK 0x1ff +#define AR934X_SRIF_DPLL1_NFRAC_MASK 0x0003ffff
+#define AR934X_SRIF_DPLL2_LOCAL_PLL BIT(30) +#define AR934X_SRIF_DPLL2_OUTDIV_SHIFT 13 +#define AR934X_SRIF_DPLL2_OUTDIV_MASK 0x7
+#define QCA953X_SRIF_BB_DPLL1_REG 0x180 +#define QCA953X_SRIF_BB_DPLL2_REG 0x184 +#define QCA953X_SRIF_BB_DPLL3_REG 0x188
+#define QCA953X_SRIF_CPU_DPLL1_REG 0x1c0 +#define QCA953X_SRIF_CPU_DPLL2_REG 0x1c4 +#define QCA953X_SRIF_CPU_DPLL3_REG 0x1c8
+#define QCA953X_SRIF_DDR_DPLL1_REG 0x240 +#define QCA953X_SRIF_DDR_DPLL2_REG 0x244 +#define QCA953X_SRIF_DDR_DPLL3_REG 0x248
+#define QCA953X_SRIF_PCIE_DPLL1_REG 0xc00 +#define QCA953X_SRIF_PCIE_DPLL2_REG 0xc04 +#define QCA953X_SRIF_PCIE_DPLL3_REG 0xc08
+#define QCA953X_SRIF_PMU1_REG 0xc40 +#define QCA953X_SRIF_PMU2_REG 0xc44
+#define QCA953X_SRIF_DPLL1_REFDIV_SHIFT 27 +#define QCA953X_SRIF_DPLL1_REFDIV_MASK 0x1f
+#define QCA953X_SRIF_DPLL1_NINT_SHIFT 18 +#define QCA953X_SRIF_DPLL1_NINT_MASK 0x1ff +#define QCA953X_SRIF_DPLL1_NFRAC_MASK 0x0003ffff
+#define QCA953X_SRIF_DPLL2_LOCAL_PLL BIT(30)
+#define QCA953X_SRIF_DPLL2_KI_SHIFT 29 +#define QCA953X_SRIF_DPLL2_KI_MASK 0x3
+#define QCA953X_SRIF_DPLL2_KD_SHIFT 25 +#define QCA953X_SRIF_DPLL2_KD_MASK 0xf
+#define QCA953X_SRIF_DPLL2_PWD BIT(22)
+#define QCA953X_SRIF_DPLL2_OUTDIV_SHIFT 13 +#define QCA953X_SRIF_DPLL2_OUTDIV_MASK 0x7
- MII_CTRL block
+#define AR71XX_MII_REG_MII0_CTRL 0x00 +#define AR71XX_MII_REG_MII1_CTRL 0x04
+#define AR71XX_MII_CTRL_IF_MASK 3 +#define AR71XX_MII_CTRL_SPEED_SHIFT 4 +#define AR71XX_MII_CTRL_SPEED_MASK 3 +#define AR71XX_MII_CTRL_SPEED_10 0 +#define AR71XX_MII_CTRL_SPEED_100 1 +#define AR71XX_MII_CTRL_SPEED_1000 2
+#define AR71XX_MII0_CTRL_IF_GMII 0 +#define AR71XX_MII0_CTRL_IF_MII 1 +#define AR71XX_MII0_CTRL_IF_RGMII 2 +#define AR71XX_MII0_CTRL_IF_RMII 3
+#define AR71XX_MII1_CTRL_IF_RGMII 0 +#define AR71XX_MII1_CTRL_IF_RMII 1
- AR933X GMAC interface
+#define AR933X_GMAC_REG_ETH_CFG 0x00
+#define AR933X_ETH_CFG_RGMII_GE0 BIT(0) +#define AR933X_ETH_CFG_MII_GE0 BIT(1) +#define AR933X_ETH_CFG_GMII_GE0 BIT(2) +#define AR933X_ETH_CFG_MII_GE0_MASTER BIT(3) +#define AR933X_ETH_CFG_MII_GE0_SLAVE BIT(4) +#define AR933X_ETH_CFG_MII_GE0_ERR_EN BIT(5) +#define AR933X_ETH_CFG_SW_PHY_SWAP BIT(7) +#define AR933X_ETH_CFG_SW_PHY_ADDR_SWAP BIT(8) +#define AR933X_ETH_CFG_RMII_GE0 BIT(9) +#define AR933X_ETH_CFG_RMII_GE0_SPD_10 0 +#define AR933X_ETH_CFG_RMII_GE0_SPD_100 BIT(10)
- AR934X GMAC Interface
+#define AR934X_GMAC_REG_ETH_CFG 0x00
+#define AR934X_ETH_CFG_RGMII_GMAC0 BIT(0) +#define AR934X_ETH_CFG_MII_GMAC0 BIT(1) +#define AR934X_ETH_CFG_GMII_GMAC0 BIT(2) +#define AR934X_ETH_CFG_MII_GMAC0_MASTER BIT(3) +#define AR934X_ETH_CFG_MII_GMAC0_SLAVE BIT(4) +#define AR934X_ETH_CFG_MII_GMAC0_ERR_EN BIT(5) +#define AR934X_ETH_CFG_SW_ONLY_MODE BIT(6) +#define AR934X_ETH_CFG_SW_PHY_SWAP BIT(7) +#define AR934X_ETH_CFG_SW_APB_ACCESS BIT(9) +#define AR934X_ETH_CFG_RMII_GMAC0 BIT(10) +#define AR933X_ETH_CFG_MII_CNTL_SPEED BIT(11) +#define AR934X_ETH_CFG_RMII_GMAC0_MASTER BIT(12) +#define AR933X_ETH_CFG_SW_ACC_MSB_FIRST BIT(13) +#define AR934X_ETH_CFG_RXD_DELAY BIT(14) +#define AR934X_ETH_CFG_RXD_DELAY_MASK 0x3 +#define AR934X_ETH_CFG_RXD_DELAY_SHIFT 14 +#define AR934X_ETH_CFG_RDV_DELAY BIT(16) +#define AR934X_ETH_CFG_RDV_DELAY_MASK 0x3 +#define AR934X_ETH_CFG_RDV_DELAY_SHIFT 16
- QCA953X GMAC Interface
+#define QCA953X_GMAC_REG_ETH_CFG 0x00
+#define QCA953X_ETH_CFG_SW_ONLY_MODE BIT(6) +#define QCA953X_ETH_CFG_SW_PHY_SWAP BIT(7) +#define QCA953X_ETH_CFG_SW_APB_ACCESS BIT(9) +#define QCA953X_ETH_CFG_SW_ACC_MSB_FIRST BIT(13)
- QCA955X GMAC Interface
+#define QCA955X_GMAC_REG_ETH_CFG 0x00
+#define QCA955X_ETH_CFG_RGMII_EN BIT(0) +#define QCA955X_ETH_CFG_GE0_SGMII BIT(6)
+#endif /* __ASM_AR71XX_H */ diff --git a/arch/mips/mach-ath79/include/mach/ath79.h b/arch/mips/mach-ath79/include/mach/ath79.h new file mode 100644 index 0000000..90d80b8 --- /dev/null +++ b/arch/mips/mach-ath79/include/mach/ath79.h @@ -0,0 +1,143 @@ +/*
- Atheros AR71XX/AR724X/AR913X common definitions
- Copyright (C) 2008-2011 Gabor Juhos juhosg@openwrt.org
+#ifndef __ASM_MACH_ATH79_H +#define __ASM_MACH_ATH79_H
+DECLARE_GLOBAL_DATA_PTR;
+enum ath79_soc_type {
- ATH79_SOC_UNKNOWN,
- ATH79_SOC_AR7130,
- ATH79_SOC_AR7141,
- ATH79_SOC_AR7161,
- ATH79_SOC_AR7240,
- ATH79_SOC_AR7241,
- ATH79_SOC_AR7242,
- ATH79_SOC_AR9130,
- ATH79_SOC_AR9132,
- ATH79_SOC_AR9330,
- ATH79_SOC_AR9331,
- ATH79_SOC_AR9341,
- ATH79_SOC_AR9342,
- ATH79_SOC_AR9344,
- ATH79_SOC_QCA9533,
- ATH79_SOC_QCA9556,
- ATH79_SOC_QCA9558,
- ATH79_SOC_TP9343,
- ATH79_SOC_QCA9561,
+static inline int soc_is_ar71xx(void) +{
- return gd->arch.soc == ATH79_SOC_AR7130 ||
gd->arch.soc == ATH79_SOC_AR7141 ||
gd->arch.soc == ATH79_SOC_AR7161;
+static inline int soc_is_ar724x(void) +{
- return gd->arch.soc == ATH79_SOC_AR7240 ||
gd->arch.soc == ATH79_SOC_AR7241 ||
+static inline int soc_is_ar7240(void) +{
- return gd->arch.soc == ATH79_SOC_AR7240;
+static inline int soc_is_ar7241(void) +{
- return gd->arch.soc == ATH79_SOC_AR7241;
+static inline int soc_is_ar7242(void) +{
- return gd->arch.soc == ATH79_SOC_AR7242;
+static inline int soc_is_ar913x(void) +{
- return gd->arch.soc == ATH79_SOC_AR9130 ||
gd->arch.soc == ATH79_SOC_AR9132;
+static inline int soc_is_ar933x(void) +{
- return gd->arch.soc == ATH79_SOC_AR9330 ||
gd->arch.soc == ATH79_SOC_AR9331;
+static inline int soc_is_ar9341(void) +{
- return gd->arch.soc == ATH79_SOC_AR9341;
+static inline int soc_is_ar9342(void) +{
- return gd->arch.soc == ATH79_SOC_AR9342;
+static inline int soc_is_ar9344(void) +{
- return gd->arch.soc == ATH79_SOC_AR9344;
+static inline int soc_is_ar934x(void) +{
- return soc_is_ar9341() ||
soc_is_ar9342() ||
soc_is_ar9344();
+static inline int soc_is_qca9533(void) +{
- return gd->arch.soc == ATH79_SOC_QCA9533;
+static inline int soc_is_qca953x(void) +{
- return soc_is_qca9533();
+static inline int soc_is_qca9556(void) +{
- return gd->arch.soc == ATH79_SOC_QCA9556;
+static inline int soc_is_qca9558(void) +{
- return gd->arch.soc == ATH79_SOC_QCA9558;
+static inline int soc_is_qca955x(void) +{
- return soc_is_qca9556() || soc_is_qca9558();
+static inline int soc_is_tp9343(void) +{
- return gd->arch.soc == ATH79_SOC_TP9343;
- return gd->arch.soc == ATH79_SOC_QCA9561;
- return soc_is_tp9343() || soc_is_qca9561();
- u32 reg = 0;
MAP_NOCACHE);
- if (soc_is_ar71xx())
- else if (soc_is_ar724x())
- else if (soc_is_ar913x())
- else if (soc_is_ar933x())
- else if (soc_is_ar934x())
- else if (soc_is_qca953x())
- else if (soc_is_qca955x())
- else if (soc_is_qca956x())
- else
- if (reg)
- while (1)
/* NOP */;
- const void __iomem *base;
- u32 reg = 0;
MAP_NOCACHE);
- if (soc_is_ar933x())
- else
- if (reg)
Daniel Schwierzeck
Wills Wang
