[U-Boot] [GIT PULL] please pull u-boot-atmel/master
Dear Albert Aribaud,
please pull the following changes into u-boot-arm/master.
The following changes since commit 9f024f62e4604274a23213dcee30016092e32e7b:
Merge branch 'fixes' of git://git.denx.de/u-boot-mips (2013-02-15 12:23:42 -0500)
git://git.denx.de/u-boot-atmel.git master
for you to fetch changes up to 08f0533a147ca37546a6539b43fce3916e82811a:
ARM: sam9x5: fix ethernet pins in MII mode (2013-03-12 13:02:20 +0100)
---------------------------------------------------------------- Bo Shen (3): ARM: atmel: add at91sam9g20ek_2mmc nand boot support ARM: at91: change nand flash table ARM: at91sam9x5: Using CPU string directly
Jesse Gilles (1): ARM: sam9x5: fix ethernet pins in MII mode
Nicolas Ferre (2): arm: at91/configs: add libfdt to configuration arm: at91/configs: add bootz to configuration
arch/arm/cpu/arm926ejs/at91/at91sam9x5_devices.c | 30 +++++++++++----------- arch/arm/include/asm/arch-at91/at91sam9x5.h | 6 ----- board/atmel/at91sam9260ek/at91sam9260ek.c | 7 ++++- boards.cfg | 1 + include/configs/at91rm9200ek.h | 3 +++ include/configs/at91sam9260ek.h | 23 ++++++++++------- include/configs/at91sam9261ek.h | 19 +++++++------- include/configs/at91sam9263ek.h | 20 +++++++++------ include/configs/at91sam9m10g45ek.h | 17 ++++++------ include/configs/at91sam9rlek.h | 3 +++ include/configs/at91sam9x5ek.h | 12 +++++---- 11 files changed, 79 insertions(+), 62 deletions(-)
Hi Andreas,
On Tue, 12 Mar 2013 13:09:38 +0100, Andreas Bießmann andreas.devel@googlemail.com wrote:
Applied to u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
Andreas Bießmann
