[PATCH] ARM: imx: verdin-imx8mm: Set CAN oscillator frequency based on model
The older i.MX8M Mini Verdin SoMs may came with 20 MHz SPI CAN controller oscillator, the newer SoMs always use 40 MHz oscillator. Handle both by overriding the oscillator frequency just before booting the kernel.
These are the known variants with 20 MHz oscillator: - 0055, V1.1A, V1.1B, V1.1C and V1.1D, use a 20MHz oscillator - 0059, V1.1A and V1.1B, use a 20MHz oscillator
Signed-off-by: Marek Vasut marex@denx.de --- Cc: "NXP i.MX U-Boot Team" uboot-imx@nxp.com Cc: Fabio Estevam festevam@gmail.com Cc: Francesco Dolcini francesco.dolcini@toradex.com Cc: Marcel Ziswiler marcel.ziswiler@toradex.com Cc: Philippe Schenker philippe.schenker@toradex.com Cc: Martyn Welch martyn.welch@collabora.com Cc: Stefano Babic sbabic@denx.de Cc: u-boot@lists.denx.de --- board/toradex/verdin-imx8mm/verdin-imx8mm.c | 30 +++++++++++++++++++++ 1 file changed, 30 insertions(+)
diff --git a/board/toradex/verdin-imx8mm/verdin-imx8mm.c b/board/toradex/verdin-imx8mm/verdin-imx8mm.c index 55c02653da6..b4a443ebfb0 100644 --- a/board/toradex/verdin-imx8mm/verdin-imx8mm.c +++ b/board/toradex/verdin-imx8mm/verdin-imx8mm.c @@ -125,6 +125,36 @@ int board_phys_sdram_size(phys_size_t *size) #if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) int ft_board_setup(void *blob, struct bd_info *bd) { + const char *canoscpath = "/oscillator"; + int freq = 40000000; /* 40 MHz is used on most variants */ + int canoscoff, ret; + + canoscoff = fdt_path_offset(blob, canoscpath); + if (canoscoff < 0) /* No CAN oscillator found. */ + goto exit; + + /* + * The actual "prodid" (PID4 in Toradex naming) that have the CAN + * functionality are 0055 and 0059. Special case 20 MHz variant + * here: + * - 0055, V1.1A, V1.1B, V1.1C and V1.1D, use a 20MHz oscillator + * - 0059, V1.1A and V1.1B, use a 20MHz oscillator + */ + if ((tdx_hw_tag.ver_major == 1 && tdx_hw_tag.ver_minor == 1) && + ((tdx_hw_tag.prodid == VERDIN_IMX8MMQ_IT && + tdx_hw_tag.ver_assembly <= 1) || /* 0055 rev. A or B */ + (tdx_hw_tag.prodid == VERDIN_IMX8MMQ_WIFI_BT_IT && + tdx_hw_tag.ver_assembly <= 4))) { /* 0059 rev. A/B/C/D */ + freq = 20000000; + } + + ret = fdt_setprop_u32(blob, canoscoff, "clock-frequency", freq); + if (ret < 0) { + printf("Failed to set CAN oscillator clock-frequency, ret=%d\n", + ret); + } + +exit: return ft_common_board_setup(blob, bd); } #endif
Hello Marek, thanks for this.
- const char *canoscpath = "/oscillator";
- int freq = 40000000; /* 40 MHz is used on most variants */
- int canoscoff, ret;
- canoscoff = fdt_path_offset(blob, canoscpath);
- if (canoscoff < 0) /* No CAN oscillator found. */
goto exit;
This is nor correct, we have more, they just always use 40MHz.
I would rephrase this:
/* * 20MHz CAN oscillator product variants: * - 0055, V1.1A, V1.1B, V1.1C and V1.1D * - 0059, V1.1A and V1.1B */
or in a different way, if you prefer, but you got the point.
- if ((tdx_hw_tag.ver_major == 1 && tdx_hw_tag.ver_minor == 1) &&
ver_assembly is the hardware revision - 'A', e.g. 'A' is 0, 'D' is 3.
VERDIN_IMX8MMQ_IT is 0059 VERDIN_IMX8MMQ_WIFI_BT_IT is 0055
with that said, it should be
if ((tdx_hw_tag.ver_major == 1 && tdx_hw_tag.ver_minor == 1) && ((tdx_hw_tag.prodid == VERDIN_IMX8MMQ_WIFI_BT_IT && tdx_hw_tag.ver_assembly <= 1) || /* 0055 rev. A or B */ (tdx_hw_tag.prodid == VERDIN_IMX8MMQ_IT && tdx_hw_tag.ver_assembly <= 3))) { /* 0059 rev. A/B/C/D */
Francesco
goto exit;
- 20MHz CAN oscillator product variants:
whoops. I confused myself. What is correct is the table you have in the comment and the commit message.
What is wrong is the comment in this if branch, and this confused me (and probably also you, sorry).
if ((tdx_hw_tag.ver_major == 1 && tdx_hw_tag.ver_minor == 1) && ((tdx_hw_tag.prodid == VERDIN_IMX8MMQ_IT && tdx_hw_tag.ver_assembly <= 1) || /* 0059 rev. A or B */ (tdx_hw_tag.prodid == VERDIN_IMX8MMQ_WIFI_BT_IT && tdx_hw_tag.ver_assembly <= 3))) { /* 0055 rev. A/B/C/D */
Francesco
Francesco Dolcini
