[U-Boot] [PATCH] rpi: increase SYS_BOOTM_LEN to 64M
On AArch64, kernel images are not self-decompressing and easily exceed the 8MB limit.
Signed-off-by: Laurent Bonnans laurent.bonnans@here.com --- include/configs/rpi.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/configs/rpi.h b/include/configs/rpi.h index 9ce41767a9..1a5ae26ae7 100644 --- a/include/configs/rpi.h +++ b/include/configs/rpi.h @@ -55,6 +55,7 @@ #define CONFIG_SYS_MEMTEST_START 0x00100000 #define CONFIG_SYS_MEMTEST_END 0x00200000 #define CONFIG_LOADADDR 0x00200000 +#define CONFIG_SYS_BOOTM_LEN SZ_64M
/* Devices */ /* GPIO */
Hi Laurent,
Sorry for the late reply. If it's only needed for ARM64 then we should make it set for this architecture, right?
Next time you send a patch, plese add the maintainers mailinglist. This way I'll find the patch easier.
Thanks, Matthias
On 7/31/19 9:12 AM, Matthias Brugger wrote:
Hi Laurent,
That seems to be the best call indeed. Then I wonder if we should just set the default larger if CONFIG_ARM64 because the problem should arise almost in all case, I believe. There is a similar define in sunxi-common.h for example.
But anyway, that's a larger debate, I'll send another patch with the ARM64 check in the header file.
Yes, sorry about that. Only realized it later...
Laurent
Bonnans, Laurent
Matthias Brugger
