[U-Boot] [PATCH] imx: Add support for the SabreSD shipped with i.MX6DL
The SabreSD platform is available with i.MX6Q or i.MX6DL. This patch adds the support of the i.MX6DL. The config file and the board directory are renamed to remove the reference to the MX6Q.
Signed-off-by: Pierre Aubert p.aubert@staubli.com CC: Stefano Babic sbabic@denx.de --- .../freescale/{mx6qsabresd => mx6sabresd}/Makefile | 2 +- .../mx6qsabresd.c => mx6sabresd/mx6sabresd.c} | 11 ++++++----- boards.cfg | 5 +++-- include/configs/mx6qsabreauto.h | 2 +- .../{mx6qsabre_common.h => mx6sabre_common.h} | 1 - include/configs/{mx6qsabresd.h => mx6sabresd.h} | 2 +- 6 files changed, 12 insertions(+), 11 deletions(-) rename board/freescale/{mx6qsabresd => mx6sabresd}/Makefile (98%) rename board/freescale/{mx6qsabresd/mx6qsabresd.c => mx6sabresd/mx6sabresd.c} (98%) rename include/configs/{mx6qsabre_common.h => mx6sabre_common.h} (99%) rename include/configs/{mx6qsabresd.h => mx6sabresd.h} (97%)
diff --git a/board/freescale/mx6qsabresd/Makefile b/board/freescale/mx6sabresd/Makefile similarity index 98% rename from board/freescale/mx6qsabresd/Makefile rename to board/freescale/mx6sabresd/Makefile index 5693772..ff3c94b 100644 --- a/board/freescale/mx6qsabresd/Makefile +++ b/board/freescale/mx6sabresd/Makefile @@ -23,7 +23,7 @@ include $(TOPDIR)/config.mk
LIB = $(obj)lib$(BOARD).o
-COBJS := mx6qsabresd.o +COBJS := mx6sabresd.o
SRCS := $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) diff --git a/board/freescale/mx6qsabresd/mx6qsabresd.c b/board/freescale/mx6sabresd/mx6sabresd.c similarity index 98% rename from board/freescale/mx6qsabresd/mx6qsabresd.c rename to board/freescale/mx6sabresd/mx6sabresd.c index 0d7cb9e..dcefdab 100644 --- a/board/freescale/mx6qsabresd/mx6qsabresd.c +++ b/board/freescale/mx6sabresd/mx6sabresd.c @@ -17,12 +17,10 @@ * GNU General Public License for more details. */
-#include <common.h> -#include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/imx-regs.h> #include <asm/arch/iomux.h> -#include <asm/arch/mx6q_pins.h> +#include <asm/arch/mx6-pins.h> #include <asm/errno.h> #include <asm/gpio.h> #include <asm/imx-common/iomux-v3.h> @@ -291,7 +289,10 @@ int board_late_init(void)
int checkboard(void) { - puts("Board: MX6Q-SabreSD\n"); - +#ifdef CONFIG_MX6Q + puts("Board: MX6Q-SabreSD\n"); +#else + puts("Board: MX6DL-SabreSD\n"); +#endif return 0; } diff --git a/boards.cfg b/boards.cfg index f785da8..c002cf7 100644 --- a/boards.cfg +++ b/boards.cfg @@ -256,9 +256,10 @@ mx53smd arm armv7 mx53smd freesca ima3-mx53 arm armv7 ima3-mx53 esg mx5 ima3-mx53:IMX_CONFIG=board/esg/ima3-mx53/imximage.cfg vision2 arm armv7 vision2 ttcontrol mx5 vision2:IMX_CONFIG=board/ttcontrol/vision2/imximage_hynix.cfg mx6qarm2 arm armv7 mx6qarm2 freescale mx6 mx6qarm2:IMX_CONFIG=board/freescale/mx6qarm2/imximage.cfg -mx6qsabreauto arm armv7 mx6qsabreauto freescale mx6 mx6qsabreauto:IMX_CONFIG=board/freescale/mx6qsabreauto/imximage.cfg +mx6qsabreauto arm armv7 mx6qsabreauto freescale mx6 mx6qsabreauto:IMX_CONFIG=board/freescale/mx6qsabreauto/imximage.cfg,MX6Q mx6qsabrelite arm armv7 mx6qsabrelite freescale mx6 mx6qsabrelite:IMX_CONFIG=board/freescale/imx/ddr/mx6q_4x_mt41j128.cfg -mx6qsabresd arm armv7 mx6qsabresd freescale mx6 mx6qsabresd:IMX_CONFIG=board/freescale/imx/ddr/mx6q_4x_mt41j128.cfg +mx6qsabresd arm armv7 mx6sabresd freescale mx6 mx6sabresd:IMX_CONFIG=board/freescale/imx/ddr/mx6q_4x_mt41j128.cfg,MX6Q +mx6dlsabresd arm armv7 mx6sabresd freescale mx6 mx6sabresd:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl.cfg,MX6DL eco5pk arm armv7 eco5pk 8dtech omap3 nitrogen6dl arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl.cfg,MX6DL,DDR_MB=1024 nitrogen6dl2g arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl2g.cfg,MX6DL,DDR_MB=2048 diff --git a/include/configs/mx6qsabreauto.h b/include/configs/mx6qsabreauto.h index 1583c11..099839a 100644 --- a/include/configs/mx6qsabreauto.h +++ b/include/configs/mx6qsabreauto.h @@ -30,7 +30,7 @@ #define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) #define CONFIG_MXC_USB_FLAGS 0
-#include "mx6qsabre_common.h" +#include "mx6sabre_common.h"
#define CONFIG_SYS_FSL_USDHC_NUM 2 #if defined(CONFIG_ENV_IS_IN_MMC) diff --git a/include/configs/mx6qsabre_common.h b/include/configs/mx6sabre_common.h similarity index 99% rename from include/configs/mx6qsabre_common.h rename to include/configs/mx6sabre_common.h index f5f115f..203158d 100644 --- a/include/configs/mx6qsabre_common.h +++ b/include/configs/mx6sabre_common.h @@ -18,7 +18,6 @@ #define __MX6QSABRE_COMMON_CONFIG_H
#define CONFIG_MX6 -#define CONFIG_MX6Q
#include "mx6_common.h"
diff --git a/include/configs/mx6qsabresd.h b/include/configs/mx6sabresd.h similarity index 97% rename from include/configs/mx6qsabresd.h rename to include/configs/mx6sabresd.h index 3b8d752..e7facd3 100644 --- a/include/configs/mx6qsabresd.h +++ b/include/configs/mx6sabresd.h @@ -24,7 +24,7 @@ #define CONFIG_DEFAULT_FDT_FILE "imx6q-sabresd.dtb" #define PHYS_SDRAM_SIZE (1u * 1024 * 1024 * 1024)
#define CONFIG_SYS_FSL_USDHC_NUM 3 #if defined(CONFIG_ENV_IS_IN_MMC)
Dear Pierre Aubert,
Formal issues:
- entry to MAINTAINERS file missing - there are 2 checkpatch warnings ("please, no spaces at the start of a line") that need to be fixed.
+#ifdef CONFIG_MX6Q
+#else
- puts("Board: MX6DL-SabreSD\n");
Can we please avoid such #ifdef's? Here, we could for example refer to the board name (CONFIG_SYS_BOARD if you like the name, or some custom defined CONFIG_BOARD_NAME like other boards do).
Hello Wolfgang,
Le 18/04/2013 19:37, Wolfgang Denk a écrit :
Dear Pierre Aubert,
Formal issues:
Fabio Estevam is already the maintainer of the SabreSD. I didn't add any new boad, I've just add the support for the i.MX6DL on this board. I will update the MAINTAINERS file.
Will be fixed
+#ifdef CONFIG_MX6Q
+#else
The board name in MX6-SabreSD. The Soc type (dual or quad core) is already printed by print_cpuinfo.
Best regards Pierre Aubert
On 18/04/2013 19:37, Wolfgang Denk wrote:
Dear Pierre Aubert,
Formal issues:
+#ifdef CONFIG_MX6Q
+#else
And who does set CONFIG_MX6Q ? You drop it, but I do not see who sets it.
Best regards, Stefano Babic
+#ifdef CONFIG_MX6Q
+#else
It is set in boards.cfg:
Hi Stefano,
Dear Pierre Aubert,
Formal issues:
+#ifdef CONFIG_MX6Q
+#else
that's done in boards.cfg : +++ b/boards.cfg +mx6qsabreauto arm armv7 mx6qsabreauto freescale mx6 mx6qsabreauto:IMX_CONFIG=board/freescale/mx6qsabreauto/imximage.cfg,MX6Q
Eric
On 19/04/2013 10:27, Eric Bénard wrote:
Hi Stefano,
Hi Eric,
Ah, ok, thanks.
Regards, Stefano
Hi Pierre,
mx6qsabreauto changes should be done on a different patch.
Regards,
Fabio Estevam
Hi Fabio,
I can split the patch if you wish, but in this case the compilation would be broken for the sabreauto if only one of the two patches is applied.
Best regards
Pierre Aubert
Le 18/04/2013 19:51, Fabio Estevam a écrit :
Hi Pierre,
Regards,
Fabio Estevam
Signed-off-by: Pierre Aubert p.aubert@staubli.com CC: Stefano Babic sbabic@denx.de --- Changes for v2: - reformat definitions
arch/arm/include/asm/arch-mx6/mx6dl_pins.h | 1597 +++++++++++++++++++++++++++- 1 files changed, 1576 insertions(+), 21 deletions(-)
diff --git a/arch/arm/include/asm/arch-mx6/mx6dl_pins.h b/arch/arm/include/asm/arch-mx6/mx6dl_pins.h index 9846f1b..5f0f987 100644 --- a/arch/arm/include/asm/arch-mx6/mx6dl_pins.h +++ b/arch/arm/include/asm/arch-mx6/mx6dl_pins.h @@ -50,106 +50,1661 @@ #define NO_MUX_I 0 #define NO_PAD_I 0 enum { + MX6_PAD_CSI0_DAT10__IPU1_CSI0_D_10 = IOMUX_PAD(0x0360, 0x004C, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT10__AUDMUX_AUD3_RXC = IOMUX_PAD(0x0360, 0x004C, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT10__ECSPI2_MISO = IOMUX_PAD(0x0360, 0x004C, 2, 0x07F8, 0, 0), MX6_PAD_CSI0_DAT10__UART1_TXD = IOMUX_PAD(0x0360, 0x004C, 3, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT10__UART1_RXD = IOMUX_PAD(0x0360, 0x004C, 3, 0x08FC, 0, 0), + MX6_PAD_CSI0_DAT10__SDMA_DEBUG_PC_4 = IOMUX_PAD(0x0360, 0x004C, 4, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT10__GPIO_5_28 = IOMUX_PAD(0x0360, 0x004C, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT10__MMDC_MMDC_DEBUG_33 = IOMUX_PAD(0x0360, 0x004C, 6, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT10__SIMBA_TRACE_7 = IOMUX_PAD(0x0360, 0x004C, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT11__IPU1_CSI0_D_11 = IOMUX_PAD(0x0364, 0x0050, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT11__AUDMUX_AUD3_RXFS = IOMUX_PAD(0x0364, 0x0050, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT11__ECSPI2_SS0 = IOMUX_PAD(0x0364, 0x0050, 2, 0x0800, 0, 0), + MX6_PAD_CSI0_DAT11__UART1_TXD = IOMUX_PAD(0x0364, 0x0050, 3, 0x0000, 0, 0), MX6_PAD_CSI0_DAT11__UART1_RXD = IOMUX_PAD(0x0364, 0x0050, 3, 0x08FC, 1, 0), - MX6_PAD_DI0_DISP_CLK__IPU1_DI0_DISP_CLK = IOMUX_PAD(0x03B0, 0x009C, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_CSI0_DAT11__SDMA_DEBUG_PC_5 = IOMUX_PAD(0x0364, 0x0050, 4, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT11__GPIO_5_29 = IOMUX_PAD(0x0364, 0x0050, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT11__MMDC_MMDC_DEBUG_34 = IOMUX_PAD(0x0364, 0x0050, 6, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT11__SIMBA_TRACE_8 = IOMUX_PAD(0x0364, 0x0050, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT12__IPU1_CSI0_D_12 = IOMUX_PAD(0x0368, 0x0054, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT12__WEIM_WEIM_D_8 = IOMUX_PAD(0x0368, 0x0054, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT12__PCIE_CTRL_DIAG_STATUS_BUS_MUX_16 = IOMUX_PAD(0x0368, 0x0054, 2, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT12__UART4_TXD = IOMUX_PAD(0x0368, 0x0054, 3, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT12__UART4_RXD = IOMUX_PAD(0x0368, 0x0054, 3, 0x0914, 0, 0), + MX6_PAD_CSI0_DAT12__SDMA_DEBUG_PC_6 = IOMUX_PAD(0x0368, 0x0054, 4, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT12__GPIO_5_30 = IOMUX_PAD(0x0368, 0x0054, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT12__MMDC_MMDC_DEBUG_35 = IOMUX_PAD(0x0368, 0x0054, 6, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT12__SIMBA_TRACE_9 = IOMUX_PAD(0x0368, 0x0054, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT13__IPU1_CSI0_D_13 = IOMUX_PAD(0x036C, 0x0058, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT13__WEIM_WEIM_D_9 = IOMUX_PAD(0x036C, 0x0058, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT13__PCIE_CTRL_DIAG_STATUS_BUS_MUX_17 = IOMUX_PAD(0x036C, 0x0058, 2, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT13__UART4_TXD = IOMUX_PAD(0x036C, 0x0058, 3, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT13__UART4_RXD = IOMUX_PAD(0x036C, 0x0058, 3, 0x0914, 1, 0), + MX6_PAD_CSI0_DAT13__SDMA_DEBUG_PC_7 = IOMUX_PAD(0x036C, 0x0058, 4, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT13__GPIO_5_31 = IOMUX_PAD(0x036C, 0x0058, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT13__MMDC_MMDC_DEBUG_36 = IOMUX_PAD(0x036C, 0x0058, 6, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT13__SIMBA_TRACE_10 = IOMUX_PAD(0x036C, 0x0058, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT14__IPU1_CSI0_D_14 = IOMUX_PAD(0x0370, 0x005C, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT14__WEIM_WEIM_D_10 = IOMUX_PAD(0x0370, 0x005C, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT14__PCIE_CTRL_DIAG_STATUS_BUS_MUX_18 = IOMUX_PAD(0x0370, 0x005C, 2, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT14__UART5_TXD = IOMUX_PAD(0x0370, 0x005C, 3, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT14__UART5_RXD = IOMUX_PAD(0x0370, 0x005C, 3, 0x091C, 0, 0), + MX6_PAD_CSI0_DAT14__SDMA_DEBUG_PC_8 = IOMUX_PAD(0x0370, 0x005C, 4, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT14__GPIO_6_0 = IOMUX_PAD(0x0370, 0x005C, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT14__MMDC_MMDC_DEBUG_37 = IOMUX_PAD(0x0370, 0x005C, 6, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT14__SIMBA_TRACE_11 = IOMUX_PAD(0x0370, 0x005C, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT15__IPU1_CSI0_D_15 = IOMUX_PAD(0x0374, 0x0060, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT15__WEIM_WEIM_D_11 = IOMUX_PAD(0x0374, 0x0060, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT15__PCIE_CTRL_DIAG_STATUS_BUS_MUX_19 = IOMUX_PAD(0x0374, 0x0060, 2, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT15__UART5_TXD = IOMUX_PAD(0x0374, 0x0060, 3, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT15__UART5_RXD = IOMUX_PAD(0x0374, 0x0060, 3, 0x091C, 1, 0), + MX6_PAD_CSI0_DAT15__SDMA_DEBUG_PC_9 = IOMUX_PAD(0x0374, 0x0060, 4, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT15__GPIO_6_1 = IOMUX_PAD(0x0374, 0x0060, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT15__MMDC_MMDC_DEBUG_38 = IOMUX_PAD(0x0374, 0x0060, 6, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT15__SIMBA_TRACE_12 = IOMUX_PAD(0x0374, 0x0060, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT16__IPU1_CSI0_D_16 = IOMUX_PAD(0x0378, 0x0064, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT16__WEIM_WEIM_D_12 = IOMUX_PAD(0x0378, 0x0064, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT16__PCIE_CTRL_DIAG_STATUS_BUS_MUX_20 = IOMUX_PAD(0x0378, 0x0064, 2, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT16__UART4_CTS = IOMUX_PAD(0x0378, 0x0064, 3, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT16__UART4_RTS = IOMUX_PAD(0x0378, 0x0064, 3, 0x0910, 0, 0), + MX6_PAD_CSI0_DAT16__SDMA_DEBUG_PC_10 = IOMUX_PAD(0x0378, 0x0064, 4, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT16__GPIO_6_2 = IOMUX_PAD(0x0378, 0x0064, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT16__MMDC_MMDC_DEBUG_39 = IOMUX_PAD(0x0378, 0x0064, 6, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT16__SIMBA_TRACE_13 = IOMUX_PAD(0x0378, 0x0064, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT17__IPU1_CSI0_D_17 = IOMUX_PAD(0x037C, 0x0068, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT17__WEIM_WEIM_D_13 = IOMUX_PAD(0x037C, 0x0068, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT17__PCIE_CTRL_DIAG_STATUS_BUS_MUX_21 = IOMUX_PAD(0x037C, 0x0068, 2, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT17__UART4_CTS = IOMUX_PAD(0x037C, 0x0068, 3, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT17__UART4_RTS = IOMUX_PAD(0x037C, 0x0068, 3, 0x0910, 1, 0), + MX6_PAD_CSI0_DAT17__SDMA_DEBUG_PC_11 = IOMUX_PAD(0x037C, 0x0068, 4, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT17__GPIO_6_3 = IOMUX_PAD(0x037C, 0x0068, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT17__MMDC_MMDC_DEBUG_40 = IOMUX_PAD(0x037C, 0x0068, 6, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT17__SIMBA_TRACE_14 = IOMUX_PAD(0x037C, 0x0068, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT18__IPU1_CSI0_D_18 = IOMUX_PAD(0x0380, 0x006C, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT18__WEIM_WEIM_D_14 = IOMUX_PAD(0x0380, 0x006C, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT18__PCIE_CTRL_DIAG_STATUS_BUS_MUX_22 = IOMUX_PAD(0x0380, 0x006C, 2, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT18__UART5_CTS = IOMUX_PAD(0x0380, 0x006C, 3, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT18__UART5_RTS = IOMUX_PAD(0x0380, 0x006C, 3, 0x0918, 0, 0), + MX6_PAD_CSI0_DAT18__SDMA_DEBUG_PC_12 = IOMUX_PAD(0x0380, 0x006C, 4, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT18__GPIO_6_4 = IOMUX_PAD(0x0380, 0x006C, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT18__MMDC_MMDC_DEBUG_41 = IOMUX_PAD(0x0380, 0x006C, 6, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT18__SIMBA_TRACE_15 = IOMUX_PAD(0x0380, 0x006C, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT19__IPU1_CSI0_D_19 = IOMUX_PAD(0x0384, 0x0070, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT19__WEIM_WEIM_D_15 = IOMUX_PAD(0x0384, 0x0070, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT19__PCIE_CTRL_DIAG_STATUS_BUS_MUX_23 = IOMUX_PAD(0x0384, 0x0070, 2, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT19__UART5_CTS = IOMUX_PAD(0x0384, 0x0070, 3, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT19__UART5_RTS = IOMUX_PAD(0x0384, 0x0070, 3, 0x0918, 1, 0), + MX6_PAD_CSI0_DAT19__SDMA_DEBUG_PC_13 = IOMUX_PAD(0x0384, 0x0070, 4, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT19__GPIO_6_5 = IOMUX_PAD(0x0384, 0x0070, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT19__MMDC_MMDC_DEBUG_42 = IOMUX_PAD(0x0384, 0x0070, 6, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT19__ANATOP_ANATOP_TESTO_9 = IOMUX_PAD(0x0384, 0x0070, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT4__IPU1_CSI0_D_4 = IOMUX_PAD(0x0388, 0x0074, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT4__WEIM_WEIM_D_2 = IOMUX_PAD(0x0388, 0x0074, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT4__ECSPI1_SCLK = IOMUX_PAD(0x0388, 0x0074, 2, 0x07D8, 0, 0), + MX6_PAD_CSI0_DAT4__KPP_COL_5 = IOMUX_PAD(0x0388, 0x0074, 3, 0x08C0, 0, 0), + MX6_PAD_CSI0_DAT4__AUDMUX_AUD3_TXC = IOMUX_PAD(0x0388, 0x0074, 4, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT4__GPIO_5_22 = IOMUX_PAD(0x0388, 0x0074, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT4__MMDC_MMDC_DEBUG_43 = IOMUX_PAD(0x0388, 0x0074, 6, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT4__SIMBA_TRACE_1 = IOMUX_PAD(0x0388, 0x0074, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT5__IPU1_CSI0_D_5 = IOMUX_PAD(0x038C, 0x0078, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT5__WEIM_WEIM_D_3 = IOMUX_PAD(0x038C, 0x0078, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT5__ECSPI1_MOSI = IOMUX_PAD(0x038C, 0x0078, 2, 0x07E0, 0, 0), + MX6_PAD_CSI0_DAT5__KPP_ROW_5 = IOMUX_PAD(0x038C, 0x0078, 3, 0x08CC, 0, 0), + MX6_PAD_CSI0_DAT5__AUDMUX_AUD3_TXD = IOMUX_PAD(0x038C, 0x0078, 4, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT5__GPIO_5_23 = IOMUX_PAD(0x038C, 0x0078, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT5__MMDC_MMDC_DEBUG_44 = IOMUX_PAD(0x038C, 0x0078, 6, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT5__SIMBA_TRACE_2 = IOMUX_PAD(0x038C, 0x0078, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT6__IPU1_CSI0_D_6 = IOMUX_PAD(0x0390, 0x007C, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT6__WEIM_WEIM_D_4 = IOMUX_PAD(0x0390, 0x007C, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT6__ECSPI1_MISO = IOMUX_PAD(0x0390, 0x007C, 2, 0x07DC, 0, 0), + MX6_PAD_CSI0_DAT6__KPP_COL_6 = IOMUX_PAD(0x0390, 0x007C, 3, 0x08C4, 0, 0), + MX6_PAD_CSI0_DAT6__AUDMUX_AUD3_TXFS = IOMUX_PAD(0x0390, 0x007C, 4, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT6__GPIO_5_24 = IOMUX_PAD(0x0390, 0x007C, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT6__MMDC_MMDC_DEBUG_45 = IOMUX_PAD(0x0390, 0x007C, 6, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT6__SIMBA_TRACE_3 = IOMUX_PAD(0x0390, 0x007C, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT7__IPU1_CSI0_D_7 = IOMUX_PAD(0x0394, 0x0080, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT7__WEIM_WEIM_D_5 = IOMUX_PAD(0x0394, 0x0080, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT7__ECSPI1_SS0 = IOMUX_PAD(0x0394, 0x0080, 2, 0x07E4, 0, 0), + MX6_PAD_CSI0_DAT7__KPP_ROW_6 = IOMUX_PAD(0x0394, 0x0080, 3, 0x08D0, 0, 0), + MX6_PAD_CSI0_DAT7__AUDMUX_AUD3_RXD = IOMUX_PAD(0x0394, 0x0080, 4, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT7__GPIO_5_25 = IOMUX_PAD(0x0394, 0x0080, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT7__MMDC_MMDC_DEBUG_46 = IOMUX_PAD(0x0394, 0x0080, 6, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT7__SIMBA_TRACE_4 = IOMUX_PAD(0x0394, 0x0080, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT8__IPU1_CSI0_D_8 = IOMUX_PAD(0x0398, 0x0084, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT8__WEIM_WEIM_D_6 = IOMUX_PAD(0x0398, 0x0084, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT8__ECSPI2_SCLK = IOMUX_PAD(0x0398, 0x0084, 2, 0x07F4, 0, 0), + MX6_PAD_CSI0_DAT8__KPP_COL_7 = IOMUX_PAD(0x0398, 0x0084, 3, 0x08C8, 0, 0), + MX6_PAD_CSI0_DAT8__I2C1_SDA = IOMUX_PAD(0x0398, 0x0084, 4 | IOMUX_CONFIG_SION, 0x086C, 0, 0), + MX6_PAD_CSI0_DAT8__GPIO_5_26 = IOMUX_PAD(0x0398, 0x0084, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT8__MMDC_MMDC_DEBUG_47 = IOMUX_PAD(0x0398, 0x0084, 6, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT8__SIMBA_TRACE_5 = IOMUX_PAD(0x0398, 0x0084, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT9__IPU1_CSI0_D_9 = IOMUX_PAD(0x039C, 0x0088, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT9__WEIM_WEIM_D_7 = IOMUX_PAD(0x039C, 0x0088, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT9__ECSPI2_MOSI = IOMUX_PAD(0x039C, 0x0088, 2, 0x07FC, 0, 0), + MX6_PAD_CSI0_DAT9__KPP_ROW_7 = IOMUX_PAD(0x039C, 0x0088, 3, 0x08D4, 0, 0), + MX6_PAD_CSI0_DAT9__I2C1_SCL = IOMUX_PAD(0x039C, 0x0088, 4 | IOMUX_CONFIG_SION, 0x0868, 0, 0), + MX6_PAD_CSI0_DAT9__GPIO_5_27 = IOMUX_PAD(0x039C, 0x0088, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT9__MMDC_MMDC_DEBUG_48 = IOMUX_PAD(0x039C, 0x0088, 6, 0x0000, 0, 0), + MX6_PAD_CSI0_DAT9__SIMBA_TRACE_6 = IOMUX_PAD(0x039C, 0x0088, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_DATA_EN__IPU1_CSI0_DATA_EN = IOMUX_PAD(0x03A0, 0x008C, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_DATA_EN__WEIM_WEIM_D_0 = IOMUX_PAD(0x03A0, 0x008C, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_DATA_EN__PCIE_CTRL_DIAG_STATUS_BUS_MUX_14 = IOMUX_PAD(0x03A0, 0x008C, 2, 0x0000, 0, 0), + MX6_PAD_CSI0_DATA_EN__SDMA_DEBUG_PC_2 = IOMUX_PAD(0x03A0, 0x008C, 4, 0x0000, 0, 0), + MX6_PAD_CSI0_DATA_EN__GPIO_5_20 = IOMUX_PAD(0x03A0, 0x008C, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_DATA_EN__MMDC_MMDC_DEBUG_31 = IOMUX_PAD(0x03A0, 0x008C, 6, 0x0000, 0, 0), + MX6_PAD_CSI0_DATA_EN__SIMBA_TRCLK = IOMUX_PAD(0x03A0, 0x008C, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_MCLK__IPU1_CSI0_HSYNC = IOMUX_PAD(0x03A4, 0x0090, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_MCLK__PCIE_CTRL_DIAG_STATUS_BUS_MUX_13 = IOMUX_PAD(0x03A4, 0x0090, 2, 0x0000, 0, 0), + MX6_PAD_CSI0_MCLK__CCM_CLKO = IOMUX_PAD(0x03A4, 0x0090, 3, 0x0000, 0, 0), + MX6_PAD_CSI0_MCLK__SDMA_DEBUG_PC_1 = IOMUX_PAD(0x03A4, 0x0090, 4, 0x0000, 0, 0), + MX6_PAD_CSI0_MCLK__GPIO_5_19 = IOMUX_PAD(0x03A4, 0x0090, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_MCLK__MMDC_MMDC_DEBUG_30 = IOMUX_PAD(0x03A4, 0x0090, 6, 0x0000, 0, 0), + MX6_PAD_CSI0_MCLK__SIMBA_TRCTL = IOMUX_PAD(0x03A4, 0x0090, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_PIXCLK__IPU1_CSI0_PIXCLK = IOMUX_PAD(0x03A8, 0x0094, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_PIXCLK__PCIE_CTRL_DIAG_STATUS_BUS_MUX_12 = IOMUX_PAD(0x03A8, 0x0094, 2, 0x0000, 0, 0), + MX6_PAD_CSI0_PIXCLK__SDMA_DEBUG_PC_0 = IOMUX_PAD(0x03A8, 0x0094, 4, 0x0000, 0, 0), + MX6_PAD_CSI0_PIXCLK__GPIO_5_18 = IOMUX_PAD(0x03A8, 0x0094, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_PIXCLK__MMDC_MMDC_DEBUG_29 = IOMUX_PAD(0x03A8, 0x0094, 6, 0x0000, 0, 0), + MX6_PAD_CSI0_PIXCLK__SIMBA_EVENTO = IOMUX_PAD(0x03A8, 0x0094, 7, 0x0000, 0, 0), + MX6_PAD_CSI0_VSYNC__IPU1_CSI0_VSYNC = IOMUX_PAD(0x03AC, 0x0098, 0, 0x0000, 0, 0), + MX6_PAD_CSI0_VSYNC__WEIM_WEIM_D_1 = IOMUX_PAD(0x03AC, 0x0098, 1, 0x0000, 0, 0), + MX6_PAD_CSI0_VSYNC__PCIE_CTRL_DIAG_STATUS_BUS_MUX_15 = IOMUX_PAD(0x03AC, 0x0098, 2, 0x0000, 0, 0), + MX6_PAD_CSI0_VSYNC__SDMA_DEBUG_PC_3 = IOMUX_PAD(0x03AC, 0x0098, 4, 0x0000, 0, 0), + MX6_PAD_CSI0_VSYNC__GPIO_5_21 = IOMUX_PAD(0x03AC, 0x0098, 5, 0x0000, 0, 0), + MX6_PAD_CSI0_VSYNC__MMDC_MMDC_DEBUG_32 = IOMUX_PAD(0x03AC, 0x0098, 6, 0x0000, 0, 0), + MX6_PAD_CSI0_VSYNC__SIMBA_TRACE_0 = IOMUX_PAD(0x03AC, 0x0098, 7, 0x0000, 0, 0), + MX6_PAD_DI0_DISP_CLK__IPU1_DI0_DISP_CLK = IOMUX_PAD(0x03B0, 0x009C, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DI0_DISP_CLK__LCDIF_CLK = IOMUX_PAD(0x03B0, 0x009C, 1, 0x0000, 0, 0), + MX6_PAD_DI0_DISP_CLK__MIPI_CORE_DPHY_TEST_OUT_28 = IOMUX_PAD(0x03B0, 0x009C, 3, 0x0000, 0, 0), + MX6_PAD_DI0_DISP_CLK__SDMA_DEBUG_CORE_STATE_0 = IOMUX_PAD(0x03B0, 0x009C, 4, 0x0000, 0, 0), + MX6_PAD_DI0_DISP_CLK__GPIO_4_16 = IOMUX_PAD(0x03B0, 0x009C, 5, 0x0000, 0, 0), + MX6_PAD_DI0_DISP_CLK__MMDC_MMDC_DEBUG_0 = IOMUX_PAD(0x03B0, 0x009C, 6, 0x0000, 0, 0), + MX6_PAD_DI0_DISP_CLK__TPSMP_HDATA_DIR = IOMUX_PAD(0x03B0, 0x009C, 7, 0x0000, 0, 0), + MX6_PAD_DI0_DISP_CLK__LCDIF_WR_RWN = IOMUX_PAD(0x03B0, 0x009C, 8, 0x0000, 0, 0), MX6_PAD_DI0_PIN15__IPU1_DI0_PIN15 = IOMUX_PAD(0x03B4, 0x00A0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DI0_PIN2__IPU1_DI0_PIN2 = IOMUX_PAD(0x03B8, 0x00A4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DI0_PIN3__IPU1_DI0_PIN3 = IOMUX_PAD(0x03BC, 0x00A8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DI0_PIN4__GPIO_4_20 = IOMUX_PAD(0x03C0, 0x00AC, 5, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DI0_PIN15__LCDIF_ENABLE = IOMUX_PAD(0x03B4, 0x00A0, 1, 0x0000, 0, 0), + MX6_PAD_DI0_PIN15__AUDMUX_AUD6_TXC = IOMUX_PAD(0x03B4, 0x00A0, 2, 0x0000, 0, 0), + MX6_PAD_DI0_PIN15__MIPI_CORE_DPHY_TEST_OUT_29 = IOMUX_PAD(0x03B4, 0x00A0, 3, 0x0000, 0, 0), + MX6_PAD_DI0_PIN15__SDMA_DEBUG_CORE_STATE_1 = IOMUX_PAD(0x03B4, 0x00A0, 4, 0x0000, 0, 0), + MX6_PAD_DI0_PIN15__GPIO_4_17 = IOMUX_PAD(0x03B4, 0x00A0, 5, 0x0000, 0, 0), + MX6_PAD_DI0_PIN15__MMDC_MMDC_DEBUG_1 = IOMUX_PAD(0x03B4, 0x00A0, 6, 0x0000, 0, 0), + MX6_PAD_DI0_PIN15__PL301_SIM_MX6DL_PER1_HSIZE_0 = IOMUX_PAD(0x03B4, 0x00A0, 7, 0x0000, 0, 0), + MX6_PAD_DI0_PIN15__LCDIF_RD_E = IOMUX_PAD(0x03B4, 0x00A0, 8, 0x0000, 0, 0), + MX6_PAD_DI0_PIN2__IPU1_DI0_PIN2 = IOMUX_PAD(0x03B8, 0x00A4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DI0_PIN2__LCDIF_HSYNC = IOMUX_PAD(0x03B8, 0x00A4, 1, 0x08D8, 0, 0), + MX6_PAD_DI0_PIN2__AUDMUX_AUD6_TXD = IOMUX_PAD(0x03B8, 0x00A4, 2, 0x0000, 0, 0), + MX6_PAD_DI0_PIN2__MIPI_CORE_DPHY_TEST_OUT_30 = IOMUX_PAD(0x03B8, 0x00A4, 3, 0x0000, 0, 0), + MX6_PAD_DI0_PIN2__SDMA_DEBUG_CORE_STATE_2 = IOMUX_PAD(0x03B8, 0x00A4, 4, 0x0000, 0, 0), + MX6_PAD_DI0_PIN2__GPIO_4_18 = IOMUX_PAD(0x03B8, 0x00A4, 5, 0x0000, 0, 0), + MX6_PAD_DI0_PIN2__MMDC_MMDC_DEBUG_2 = IOMUX_PAD(0x03B8, 0x00A4, 6, 0x0000, 0, 0), + MX6_PAD_DI0_PIN2__PL301_SIM_MX6DL_PER1_HADDR_9 = IOMUX_PAD(0x03B8, 0x00A4, 7, 0x0000, 0, 0), + MX6_PAD_DI0_PIN2__LCDIF_RS = IOMUX_PAD(0x03B8, 0x00A4, 8, 0x0000, 0, 0), + MX6_PAD_DI0_PIN3__IPU1_DI0_PIN3 = IOMUX_PAD(0x03BC, 0x00A8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DI0_PIN3__LCDIF_VSYNC = IOMUX_PAD(0x03BC, 0x00A8, 1, 0x0000, 0, 0), + MX6_PAD_DI0_PIN3__AUDMUX_AUD6_TXFS = IOMUX_PAD(0x03BC, 0x00A8, 2, 0x0000, 0, 0), + MX6_PAD_DI0_PIN3__MIPI_CORE_DPHY_TEST_OUT_31 = IOMUX_PAD(0x03BC, 0x00A8, 3, 0x0000, 0, 0), + MX6_PAD_DI0_PIN3__SDMA_DEBUG_CORE_STATE_3 = IOMUX_PAD(0x03BC, 0x00A8, 4, 0x0000, 0, 0), + MX6_PAD_DI0_PIN3__GPIO_4_19 = IOMUX_PAD(0x03BC, 0x00A8, 5, 0x0000, 0, 0), + MX6_PAD_DI0_PIN3__MMDC_MMDC_DEBUG_3 = IOMUX_PAD(0x03BC, 0x00A8, 6, 0x0000, 0, 0), + MX6_PAD_DI0_PIN3__PL301_SIM_MX6DL_PER1_HADDR_10 = IOMUX_PAD(0x03BC, 0x00A8, 7, 0x0000, 0, 0), + MX6_PAD_DI0_PIN3__LCDIF_CS = IOMUX_PAD(0x03BC, 0x00A8, 8, 0x0000, 0, 0), + MX6_PAD_DI0_PIN4__IPU1_DI0_PIN4 = IOMUX_PAD(0x03C0, 0x00AC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DI0_PIN4__LCDIF_BUSY = IOMUX_PAD(0x03C0, 0x00AC, 1, 0x08D8, 1, 0), + MX6_PAD_DI0_PIN4__AUDMUX_AUD6_RXD = IOMUX_PAD(0x03C0, 0x00AC, 2, 0x0000, 0, 0), + MX6_PAD_DI0_PIN4__USDHC1_WP = IOMUX_PAD(0x03C0, 0x00AC, 3, 0x092C, 0, 0), + MX6_PAD_DI0_PIN4__SDMA_DEBUG_YIELD = IOMUX_PAD(0x03C0, 0x00AC, 4, 0x0000, 0, 0), + MX6_PAD_DI0_PIN4__GPIO_4_20 = IOMUX_PAD(0x03C0, 0x00AC, 5, 0x0000, 0, 0), + MX6_PAD_DI0_PIN4__MMDC_MMDC_DEBUG_4 = IOMUX_PAD(0x03C0, 0x00AC, 6, 0x0000, 0, 0), + MX6_PAD_DI0_PIN4__PL301_SIM_MX6DL_PER1_HADDR_11 = IOMUX_PAD(0x03C0, 0x00AC, 7, 0x0000, 0, 0), + MX6_PAD_DI0_PIN4__LCDIF_RESET = IOMUX_PAD(0x03C0, 0x00AC, 8, 0x0000, 0, 0), MX6_PAD_DISP0_DAT0__IPU1_DISP0_DAT_0 = IOMUX_PAD(0x03C4, 0x00B0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT0__LCDIF_DAT_0 = IOMUX_PAD(0x03C4, 0x00B0, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT0__ECSPI3_SCLK = IOMUX_PAD(0x03C4, 0x00B0, 2, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT0__USDHC1_USDHC_DEBUG_0 = IOMUX_PAD(0x03C4, 0x00B0, 3, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT0__SDMA_DEBUG_CORE_RUN = IOMUX_PAD(0x03C4, 0x00B0, 4, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT0__GPIO_4_21 = IOMUX_PAD(0x03C4, 0x00B0, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT0__MMDC_MMDC_DEBUG_5 = IOMUX_PAD(0x03C4, 0x00B0, 6, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT0__PL301_SIM_MX6DL_PER1_HSIZE_1 = IOMUX_PAD(0x03C4, 0x00B0, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT1__IPU1_DISP0_DAT_1 = IOMUX_PAD(0x03C8, 0x00B4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT10__IPU1_DISP0_DAT_10 = IOMUX_PAD(0x03CC, 0x00B8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT11__IPU1_DISP0_DAT_11 = IOMUX_PAD(0x03D0, 0x00BC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT12__IPU1_DISP0_DAT_12 = IOMUX_PAD(0x03D4, 0x00C0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT13__IPU1_DISP0_DAT_13 = IOMUX_PAD(0x03D8, 0x00C4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT14__IPU1_DISP0_DAT_14 = IOMUX_PAD(0x03DC, 0x00C8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT15__IPU1_DISP0_DAT_15 = IOMUX_PAD(0x03E0, 0x00CC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT16__IPU1_DISP0_DAT_16 = IOMUX_PAD(0x03E4, 0x00D0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT17__IPU1_DISP0_DAT_17 = IOMUX_PAD(0x03E8, 0x00D4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT18__IPU1_DISP0_DAT_18 = IOMUX_PAD(0x03EC, 0x00D8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT19__IPU1_DISP0_DAT_19 = IOMUX_PAD(0x03F0, 0x00DC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT2__IPU1_DISP0_DAT_2 = IOMUX_PAD(0x03F4, 0x00E0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT20__IPU1_DISP0_DAT_20 = IOMUX_PAD(0x03F8, 0x00E4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT21__IPU1_DISP0_DAT_21 = IOMUX_PAD(0x03FC, 0x00E8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT22__IPU1_DISP0_DAT_22 = IOMUX_PAD(0x0400, 0x00EC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), - MX6_PAD_DISP0_DAT23__IPU1_DISP0_DAT_23 = IOMUX_PAD(0x0404, 0x00F0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT1__LCDIF_DAT_1 = IOMUX_PAD(0x03C8, 0x00B4, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT1__ECSPI3_MOSI = IOMUX_PAD(0x03C8, 0x00B4, 2, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT1__USDHC1_USDHC_DEBUG_1 = IOMUX_PAD(0x03C8, 0x00B4, 3, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT1__SDMA_DEBUG_EVENT_CHANNEL_SEL = IOMUX_PAD(0x03C8, 0x00B4, 4, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT1__GPIO_4_22 = IOMUX_PAD(0x03C8, 0x00B4, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT1__MMDC_MMDC_DEBUG_6 = IOMUX_PAD(0x03C8, 0x00B4, 6, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT1__PL301_SIM_MX6DL_PER1_HADDR_12 = IOMUX_PAD(0x03C8, 0x00B4, 7, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT10__IPU1_DISP0_DAT_10 = IOMUX_PAD(0x03CC, 0x00B8, 0, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT10__LCDIF_DAT_10 = IOMUX_PAD(0x03CC, 0x00B8, 1, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT10__USDHC1_USDHC_DEBUG_6 = IOMUX_PAD(0x03CC, 0x00B8, 3, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT10__SDMA_DEBUG_EVENT_CHANNEL_3 = IOMUX_PAD(0x03CC, 0x00B8, 4, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT10__GPIO_4_31 = IOMUX_PAD(0x03CC, 0x00B8, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT10__MMDC_MMDC_DEBUG_15 = IOMUX_PAD(0x03CC, 0x00B8, 6, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT10__PL301_SIM_MX6DL_PER1_HADDR_21 = IOMUX_PAD(0x03CC, 0x00B8, 7, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT11__IPU1_DISP0_DAT_11 = IOMUX_PAD(0x03D0, 0x00BC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT11__LCDIF_DAT_11 = IOMUX_PAD(0x03D0, 0x00BC, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT11__USDHC1_USDHC_DEBUG_7 = IOMUX_PAD(0x03D0, 0x00BC, 3, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT11__SDMA_DEBUG_EVENT_CHANNEL_4 = IOMUX_PAD(0x03D0, 0x00BC, 4, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT11__GPIO_5_5 = IOMUX_PAD(0x03D0, 0x00BC, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT11__MMDC_MMDC_DEBUG_16 = IOMUX_PAD(0x03D0, 0x00BC, 6, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT11__PL301_SIM_MX6DL_PER1_HADDR_22 = IOMUX_PAD(0x03D0, 0x00BC, 7, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT12__IPU1_DISP0_DAT_12 = IOMUX_PAD(0x03D4, 0x00C0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT12__LCDIF_DAT_12 = IOMUX_PAD(0x03D4, 0x00C0, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT12__SDMA_DEBUG_EVENT_CHANNEL_5 = IOMUX_PAD(0x03D4, 0x00C0, 4, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT12__GPIO_5_6 = IOMUX_PAD(0x03D4, 0x00C0, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT12__MMDC_MMDC_DEBUG_17 = IOMUX_PAD(0x03D4, 0x00C0, 6, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT12__PL301_SIM_MX6DL_PER1_HADDR_23 = IOMUX_PAD(0x03D4, 0x00C0, 7, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT13__IPU1_DISP0_DAT_13 = IOMUX_PAD(0x03D8, 0x00C4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT13__LCDIF_DAT_13 = IOMUX_PAD(0x03D8, 0x00C4, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT13__AUDMUX_AUD5_RXFS = IOMUX_PAD(0x03D8, 0x00C4, 3, 0x07BC, 0, 0), + MX6_PAD_DISP0_DAT13__SDMA_DEBUG_EVT_CHN_LINES_0 = IOMUX_PAD(0x03D8, 0x00C4, 4, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT13__GPIO_5_7 = IOMUX_PAD(0x03D8, 0x00C4, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT13__MMDC_MMDC_DEBUG_18 = IOMUX_PAD(0x03D8, 0x00C4, 6, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT13__PL301_SIM_MX6DL_PER1_HADDR_24 = IOMUX_PAD(0x03D8, 0x00C4, 7, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT14__IPU1_DISP0_DAT_14 = IOMUX_PAD(0x03DC, 0x00C8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT14__LCDIF_DAT_14 = IOMUX_PAD(0x03DC, 0x00C8, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT14__AUDMUX_AUD5_RXC = IOMUX_PAD(0x03DC, 0x00C8, 3, 0x07B8, 0, 0), + MX6_PAD_DISP0_DAT14__SDMA_DEBUG_EVT_CHN_LINES_1 = IOMUX_PAD(0x03DC, 0x00C8, 4, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT14__GPIO_5_8 = IOMUX_PAD(0x03DC, 0x00C8, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT14__MMDC_MMDC_DEBUG_19 = IOMUX_PAD(0x03DC, 0x00C8, 6, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT14__PL301_SIM_MX6DL_PER1_HSIZE_2 = IOMUX_PAD(0x03DC, 0x00C8, 7, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT15__IPU1_DISP0_DAT_15 = IOMUX_PAD(0x03E0, 0x00CC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT15__LCDIF_DAT_15 = IOMUX_PAD(0x03E0, 0x00CC, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT15__ECSPI1_SS1 = IOMUX_PAD(0x03E0, 0x00CC, 2, 0x07E8, 0, 0), + MX6_PAD_DISP0_DAT15__ECSPI2_SS1 = IOMUX_PAD(0x03E0, 0x00CC, 3, 0x0804, 0, 0), + MX6_PAD_DISP0_DAT15__SDMA_DEBUG_EVT_CHN_LINES_2 = IOMUX_PAD(0x03E0, 0x00CC, 4, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT15__GPIO_5_9 = IOMUX_PAD(0x03E0, 0x00CC, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT15__MMDC_MMDC_DEBUG_20 = IOMUX_PAD(0x03E0, 0x00CC, 6, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT15__PL301_SIM_MX6DL_PER1_HADDR_25 = IOMUX_PAD(0x03E0, 0x00CC, 7, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT16__IPU1_DISP0_DAT_16 = IOMUX_PAD(0x03E4, 0x00D0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT16__LCDIF_DAT_16 = IOMUX_PAD(0x03E4, 0x00D0, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT16__ECSPI2_MOSI = IOMUX_PAD(0x03E4, 0x00D0, 2, 0x07FC, 1, 0), + MX6_PAD_DISP0_DAT16__AUDMUX_AUD5_TXC = IOMUX_PAD(0x03E4, 0x00D0, 3, 0x07C0, 0, 0), + MX6_PAD_DISP0_DAT16__SDMA_SDMA_EXT_EVENT_0 = IOMUX_PAD(0x03E4, 0x00D0, 4, 0x08E8, 0, 0), + MX6_PAD_DISP0_DAT16__GPIO_5_10 = IOMUX_PAD(0x03E4, 0x00D0, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT16__MMDC_MMDC_DEBUG_21 = IOMUX_PAD(0x03E4, 0x00D0, 6, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT16__PL301_SIM_MX6DL_PER1_HADDR_26 = IOMUX_PAD(0x03E4, 0x00D0, 7, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT17__IPU1_DISP0_DAT_17 = IOMUX_PAD(0x03E8, 0x00D4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT17__LCDIF_DAT_17 = IOMUX_PAD(0x03E8, 0x00D4, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT17__ECSPI2_MISO = IOMUX_PAD(0x03E8, 0x00D4, 2, 0x07F8, 1, 0), + MX6_PAD_DISP0_DAT17__AUDMUX_AUD5_TXD = IOMUX_PAD(0x03E8, 0x00D4, 3, 0x07B4, 0, 0), + MX6_PAD_DISP0_DAT17__SDMA_SDMA_EXT_EVENT_1 = IOMUX_PAD(0x03E8, 0x00D4, 4, 0x08EC, 0, 0), + MX6_PAD_DISP0_DAT17__GPIO_5_11 = IOMUX_PAD(0x03E8, 0x00D4, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT17__MMDC_MMDC_DEBUG_22 = IOMUX_PAD(0x03E8, 0x00D4, 6, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT17__PL301_SIM_MX6DL_PER1_HADDR_27 = IOMUX_PAD(0x03E8, 0x00D4, 7, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT18__IPU1_DISP0_DAT_18 = IOMUX_PAD(0x03EC, 0x00D8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT18__LCDIF_DAT_18 = IOMUX_PAD(0x03EC, 0x00D8, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT18__ECSPI2_SS0 = IOMUX_PAD(0x03EC, 0x00D8, 2, 0x0800, 1, 0), + MX6_PAD_DISP0_DAT18__AUDMUX_AUD5_TXFS = IOMUX_PAD(0x03EC, 0x00D8, 3, 0x07C4, 0, 0), + MX6_PAD_DISP0_DAT18__AUDMUX_AUD4_RXFS = IOMUX_PAD(0x03EC, 0x00D8, 4, 0x07A4, 0, 0), + MX6_PAD_DISP0_DAT18__GPIO_5_12 = IOMUX_PAD(0x03EC, 0x00D8, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT18__MMDC_MMDC_DEBUG_23 = IOMUX_PAD(0x03EC, 0x00D8, 6, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT18__WEIM_WEIM_CS_2 = IOMUX_PAD(0x03EC, 0x00D8, 7, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT19__IPU1_DISP0_DAT_19 = IOMUX_PAD(0x03F0, 0x00DC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT19__LCDIF_DAT_19 = IOMUX_PAD(0x03F0, 0x00DC, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT19__ECSPI2_SCLK = IOMUX_PAD(0x03F0, 0x00DC, 2, 0x07F4, 1, 0), + MX6_PAD_DISP0_DAT19__AUDMUX_AUD5_RXD = IOMUX_PAD(0x03F0, 0x00DC, 3, 0x07B0, 0, 0), + MX6_PAD_DISP0_DAT19__AUDMUX_AUD4_RXC = IOMUX_PAD(0x03F0, 0x00DC, 4, 0x07A0, 0, 0), + MX6_PAD_DISP0_DAT19__GPIO_5_13 = IOMUX_PAD(0x03F0, 0x00DC, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT19__MMDC_MMDC_DEBUG_24 = IOMUX_PAD(0x03F0, 0x00DC, 6, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT19__WEIM_WEIM_CS_3 = IOMUX_PAD(0x03F0, 0x00DC, 7, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT2__IPU1_DISP0_DAT_2 = IOMUX_PAD(0x03F4, 0x00E0, 0, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT2__LCDIF_DAT_2 = IOMUX_PAD(0x03F4, 0x00E0, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT2__ECSPI3_MISO = IOMUX_PAD(0x03F4, 0x00E0, 2, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT2__USDHC1_USDHC_DEBUG_2 = IOMUX_PAD(0x03F4, 0x00E0, 3, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT2__SDMA_DEBUG_MODE = IOMUX_PAD(0x03F4, 0x00E0, 4, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT2__GPIO_4_23 = IOMUX_PAD(0x03F4, 0x00E0, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT2__MMDC_MMDC_DEBUG_7 = IOMUX_PAD(0x03F4, 0x00E0, 6, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT2__PL301_SIM_MX6DL_PER1_HADDR_13 = IOMUX_PAD(0x03F4, 0x00E0, 7, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT20__IPU1_DISP0_DAT_20 = IOMUX_PAD(0x03F8, 0x00E4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT20__LCDIF_DAT_20 = IOMUX_PAD(0x03F8, 0x00E4, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT20__ECSPI1_SCLK = IOMUX_PAD(0x03F8, 0x00E4, 2, 0x07D8, 1, 0), + MX6_PAD_DISP0_DAT20__AUDMUX_AUD4_TXC = IOMUX_PAD(0x03F8, 0x00E4, 3, 0x07A8, 0, 0), + MX6_PAD_DISP0_DAT20__SDMA_DEBUG_EVT_CHN_LINES_7 = IOMUX_PAD(0x03F8, 0x00E4, 4, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT20__GPIO_5_14 = IOMUX_PAD(0x03F8, 0x00E4, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT20__MMDC_MMDC_DEBUG_25 = IOMUX_PAD(0x03F8, 0x00E4, 6, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT20__PL301_SIM_MX6DL_PER1_HADDR_28 = IOMUX_PAD(0x03F8, 0x00E4, 7, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT21__IPU1_DISP0_DAT_21 = IOMUX_PAD(0x03FC, 0x00E8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT21__LCDIF_DAT_21 = IOMUX_PAD(0x03FC, 0x00E8, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT21__ECSPI1_MOSI = IOMUX_PAD(0x03FC, 0x00E8, 2, 0x07E0, 1, 0), + MX6_PAD_DISP0_DAT21__AUDMUX_AUD4_TXD = IOMUX_PAD(0x03FC, 0x00E8, 3, 0x079C, 0, 0), + MX6_PAD_DISP0_DAT21__SDMA_DEBUG_BUS_DEVICE_0 = IOMUX_PAD(0x03FC, 0x00E8, 4, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT21__GPIO_5_15 = IOMUX_PAD(0x03FC, 0x00E8, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT21__MMDC_MMDC_DEBUG_26 = IOMUX_PAD(0x03FC, 0x00E8, 6, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT21__PL301_SIM_MX6DL_PER1_HADDR_29 = IOMUX_PAD(0x03FC, 0x00E8, 7, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT22__IPU1_DISP0_DAT_22 = IOMUX_PAD(0x0400, 0x00EC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT22__LCDIF_DAT_22 = IOMUX_PAD(0x0400, 0x00EC, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT22__ECSPI1_MISO = IOMUX_PAD(0x0400, 0x00EC, 2, 0x07DC, 1, 0), + MX6_PAD_DISP0_DAT22__AUDMUX_AUD4_TXFS = IOMUX_PAD(0x0400, 0x00EC, 3, 0x07AC, 0, 0), + MX6_PAD_DISP0_DAT22__SDMA_DEBUG_BUS_DEVICE_1 = IOMUX_PAD(0x0400, 0x00EC, 4, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT22__GPIO_5_16 = IOMUX_PAD(0x0400, 0x00EC, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT22__MMDC_MMDC_DEBUG_27 = IOMUX_PAD(0x0400, 0x00EC, 6, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT22__PL301_SIM_MX6DL_PER1_HADDR_30 = IOMUX_PAD(0x0400, 0x00EC, 7, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT23__IPU1_DISP0_DAT_23 = IOMUX_PAD(0x0404, 0x00F0, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT23__LCDIF_DAT_23 = IOMUX_PAD(0x0404, 0x00F0, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT23__ECSPI1_SS0 = IOMUX_PAD(0x0404, 0x00F0, 2, 0x07E4, 1, 0), + MX6_PAD_DISP0_DAT23__AUDMUX_AUD4_RXD = IOMUX_PAD(0x0404, 0x00F0, 3, 0x0798, 0, 0), + MX6_PAD_DISP0_DAT23__SDMA_DEBUG_BUS_DEVICE_2 = IOMUX_PAD(0x0404, 0x00F0, 4, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT23__GPIO_5_17 = IOMUX_PAD(0x0404, 0x00F0, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT23__MMDC_MMDC_DEBUG_28 = IOMUX_PAD(0x0404, 0x00F0, 6, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT23__PL301_SIM_MX6DL_PER1_HADDR_31 = IOMUX_PAD(0x0404, 0x00F0, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT3__IPU1_DISP0_DAT_3 = IOMUX_PAD(0x0408, 0x00F4, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT3__LCDIF_DAT_3 = IOMUX_PAD(0x0408, 0x00F4, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT3__ECSPI3_SS0 = IOMUX_PAD(0x0408, 0x00F4, 2, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT3__USDHC1_USDHC_DEBUG_3 = IOMUX_PAD(0x0408, 0x00F4, 3, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT3__SDMA_DEBUG_BUS_ERROR = IOMUX_PAD(0x0408, 0x00F4, 4, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT3__GPIO_4_24 = IOMUX_PAD(0x0408, 0x00F4, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT3__MMDC_MMDC_DEBUG_8 = IOMUX_PAD(0x0408, 0x00F4, 6, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT3__PL301_SIM_MX6DL_PER1_HADDR_14 = IOMUX_PAD(0x0408, 0x00F4, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT4__IPU1_DISP0_DAT_4 = IOMUX_PAD(0x040C, 0x00F8, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT4__LCDIF_DAT_4 = IOMUX_PAD(0x040C, 0x00F8, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT4__ECSPI3_SS1 = IOMUX_PAD(0x040C, 0x00F8, 2, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT4__USDHC1_USDHC_DEBUG_4 = IOMUX_PAD(0x040C, 0x00F8, 3, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT4__SDMA_DEBUG_BUS_RWB = IOMUX_PAD(0x040C, 0x00F8, 4, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT4__GPIO_4_25 = IOMUX_PAD(0x040C, 0x00F8, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT4__MMDC_MMDC_DEBUG_9 = IOMUX_PAD(0x040C, 0x00F8, 6, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT4__PL301_SIM_MX6DL_PER1_HADDR_15 = IOMUX_PAD(0x040C, 0x00F8, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT5__IPU1_DISP0_DAT_5 = IOMUX_PAD(0x0410, 0x00FC, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT5__LCDIF_DAT_5 = IOMUX_PAD(0x0410, 0x00FC, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT5__ECSPI3_SS2 = IOMUX_PAD(0x0410, 0x00FC, 2, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT5__AUDMUX_AUD6_RXFS = IOMUX_PAD(0x0410, 0x00FC, 3, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT5__SDMA_DEBUG_MATCHED_DMBUS = IOMUX_PAD(0x0410, 0x00FC, 4, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT5__GPIO_4_26 = IOMUX_PAD(0x0410, 0x00FC, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT5__MMDC_MMDC_DEBUG_10 = IOMUX_PAD(0x0410, 0x00FC, 6, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT5__PL301_SIM_MX6DL_PER1_HADDR_16 = IOMUX_PAD(0x0410, 0x00FC, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT6__IPU1_DISP0_DAT_6 = IOMUX_PAD(0x0414, 0x0100, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT6__LCDIF_DAT_6 = IOMUX_PAD(0x0414, 0x0100, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT6__ECSPI3_SS3 = IOMUX_PAD(0x0414, 0x0100, 2, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT6__AUDMUX_AUD6_RXC = IOMUX_PAD(0x0414, 0x0100, 3, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT6__SDMA_DEBUG_RTBUFFER_WRITE = IOMUX_PAD(0x0414, 0x0100, 4, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT6__GPIO_4_27 = IOMUX_PAD(0x0414, 0x0100, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT6__MMDC_MMDC_DEBUG_11 = IOMUX_PAD(0x0414, 0x0100, 6, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT6__PL301_SIM_MX6DL_PER1_HADDR_17 = IOMUX_PAD(0x0414, 0x0100, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT7__IPU1_DISP0_DAT_7 = IOMUX_PAD(0x0418, 0x0104, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT7__LCDIF_DAT_7 = IOMUX_PAD(0x0418, 0x0104, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT7__ECSPI3_RDY = IOMUX_PAD(0x0418, 0x0104, 2, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT7__USDHC1_USDHC_DEBUG_5 = IOMUX_PAD(0x0418, 0x0104, 3, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT7__SDMA_DEBUG_EVENT_CHANNEL_0 = IOMUX_PAD(0x0418, 0x0104, 4, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT7__GPIO_4_28 = IOMUX_PAD(0x0418, 0x0104, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT7__MMDC_MMDC_DEBUG_12 = IOMUX_PAD(0x0418, 0x0104, 6, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT7__PL301_SIM_MX6DL_PER1_HADDR_18 = IOMUX_PAD(0x0418, 0x0104, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT8__IPU1_DISP0_DAT_8 = IOMUX_PAD(0x041C, 0x0108, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT8__LCDIF_DAT_8 = IOMUX_PAD(0x041C, 0x0108, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT8__PWM1_PWMO = IOMUX_PAD(0x041C, 0x0108, 2, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT8__WDOG1_WDOG_B = IOMUX_PAD(0x041C, 0x0108, 3, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT8__SDMA_DEBUG_EVENT_CHANNEL_1 = IOMUX_PAD(0x041C, 0x0108, 4, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT8__GPIO_4_29 = IOMUX_PAD(0x041C, 0x0108, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT8__MMDC_MMDC_DEBUG_13 = IOMUX_PAD(0x041C, 0x0108, 6, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT8__PL301_SIM_MX6DL_PER1_HADDR_19 = IOMUX_PAD(0x041C, 0x0108, 7, 0x0000, 0, 0), MX6_PAD_DISP0_DAT9__IPU1_DISP0_DAT_9 = IOMUX_PAD(0x0420, 0x010C, 0, 0x0000, 0, PAD_CTL_DSE_120ohm), + MX6_PAD_DISP0_DAT9__LCDIF_DAT_9 = IOMUX_PAD(0x0420, 0x010C, 1, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT9__PWM2_PWMO = IOMUX_PAD(0x0420, 0x010C, 2, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT9__WDOG2_WDOG_B = IOMUX_PAD(0x0420, 0x010C, 3, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT9__SDMA_DEBUG_EVENT_CHANNEL_2 = IOMUX_PAD(0x0420, 0x010C, 4, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT9__GPIO_4_30 = IOMUX_PAD(0x0420, 0x010C, 5, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT9__MMDC_MMDC_DEBUG_14 = IOMUX_PAD(0x0420, 0x010C, 6, 0x0000, 0, 0), + MX6_PAD_DISP0_DAT9__PL301_SIM_MX6DL_PER1_HADDR_20 = IOMUX_PAD(0x0420, 0x010C, 7, 0x0000, 0, 0), + MX6_PAD_DRAM_A0__MMDC_DRAM_A_0 = IOMUX_PAD(0x0424, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_A1__MMDC_DRAM_A_1 = IOMUX_PAD(0x0428, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_A10__MMDC_DRAM_A_10 = IOMUX_PAD(0x042C, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_A11__MMDC_DRAM_A_11 = IOMUX_PAD(0x0430, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_A12__MMDC_DRAM_A_12 = IOMUX_PAD(0x0434, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_A13__MMDC_DRAM_A_13 = IOMUX_PAD(0x0438, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_A14__MMDC_DRAM_A_14 = IOMUX_PAD(0x043C, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_A15__MMDC_DRAM_A_15 = IOMUX_PAD(0x0440, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_A2__MMDC_DRAM_A_2 = IOMUX_PAD(0x0444, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_A3__MMDC_DRAM_A_3 = IOMUX_PAD(0x0448, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_A4__MMDC_DRAM_A_4 = IOMUX_PAD(0x044C, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_A5__MMDC_DRAM_A_5 = IOMUX_PAD(0x0450, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_A6__MMDC_DRAM_A_6 = IOMUX_PAD(0x0454, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_A7__MMDC_DRAM_A_7 = IOMUX_PAD(0x0458, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_A8__MMDC_DRAM_A_8 = IOMUX_PAD(0x045C, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_A9__MMDC_DRAM_A_9 = IOMUX_PAD(0x0460, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_CAS__MMDC_DRAM_CAS = IOMUX_PAD(0x0464, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_CS0__MMDC_DRAM_CS_0 = IOMUX_PAD(0x0468, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_CS1__MMDC_DRAM_CS_1 = IOMUX_PAD(0x046C, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D0__MMDC_DRAM_D_0 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D1__MMDC_DRAM_D_1 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D10__MMDC_DRAM_D_10 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D11__MMDC_DRAM_D_11 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D12__MMDC_DRAM_D_12 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D13__MMDC_DRAM_D_13 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D14__MMDC_DRAM_D_14 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D15__MMDC_DRAM_D_15 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D16__MMDC_DRAM_D_16 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D17__MMDC_DRAM_D_17 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D18__MMDC_DRAM_D_18 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D19__MMDC_DRAM_D_19 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D2__MMDC_DRAM_D_2 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D20__MMDC_DRAM_D_20 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D21__MMDC_DRAM_D_21 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D22__MMDC_DRAM_D_22 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D23__MMDC_DRAM_D_23 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D24__MMDC_DRAM_D_24 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D25__MMDC_DRAM_D_25 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D26__MMDC_DRAM_D_26 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D27__MMDC_DRAM_D_27 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D28__MMDC_DRAM_D_28 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D29__MMDC_DRAM_D_29 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D3__MMDC_DRAM_D_3 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D30__MMDC_DRAM_D_30 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D31__MMDC_DRAM_D_31 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D32__MMDC_DRAM_D_32 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D33__MMDC_DRAM_D_33 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D34__MMDC_DRAM_D_34 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D35__MMDC_DRAM_D_35 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D36__MMDC_DRAM_D_36 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D37__MMDC_DRAM_D_37 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D38__MMDC_DRAM_D_38 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D39__MMDC_DRAM_D_39 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D4__MMDC_DRAM_D_4 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D40__MMDC_DRAM_D_40 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D41__MMDC_DRAM_D_41 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D42__MMDC_DRAM_D_42 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D43__MMDC_DRAM_D_43 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D44__MMDC_DRAM_D_44 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D45__MMDC_DRAM_D_45 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D46__MMDC_DRAM_D_46 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D47__MMDC_DRAM_D_47 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D48__MMDC_DRAM_D_48 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D49__MMDC_DRAM_D_49 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D5__MMDC_DRAM_D_5 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D50__MMDC_DRAM_D_50 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D51__MMDC_DRAM_D_51 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D52__MMDC_DRAM_D_52 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D53__MMDC_DRAM_D_53 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D54__MMDC_DRAM_D_54 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D55__MMDC_DRAM_D_55 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D56__MMDC_DRAM_D_56 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D57__MMDC_DRAM_D_57 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D58__MMDC_DRAM_D_58 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D59__MMDC_DRAM_D_59 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D6__MMDC_DRAM_D_6 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D60__MMDC_DRAM_D_60 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D61__MMDC_DRAM_D_61 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D62__MMDC_DRAM_D_62 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D63__MMDC_DRAM_D_63 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D7__MMDC_DRAM_D_7 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D8__MMDC_DRAM_D_8 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_D9__MMDC_DRAM_D_9 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_DQM0__MMDC_DRAM_DQM_0 = IOMUX_PAD(0x0470, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_DQM1__MMDC_DRAM_DQM_1 = IOMUX_PAD(0x0474, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_DQM2__MMDC_DRAM_DQM_2 = IOMUX_PAD(0x0478, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_DQM3__MMDC_DRAM_DQM_3 = IOMUX_PAD(0x047C, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_DQM4__MMDC_DRAM_DQM_4 = IOMUX_PAD(0x0480, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_DQM5__MMDC_DRAM_DQM_5 = IOMUX_PAD(0x0484, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_DQM6__MMDC_DRAM_DQM_6 = IOMUX_PAD(0x0488, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_DQM7__MMDC_DRAM_DQM_7 = IOMUX_PAD(0x048C, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_RAS__MMDC_DRAM_RAS = IOMUX_PAD(0x0490, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_RESET__MMDC_DRAM_RESET = IOMUX_PAD(0x0494, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_SDBA0__MMDC_DRAM_SDBA_0 = IOMUX_PAD(0x0498, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_SDBA1__MMDC_DRAM_SDBA_1 = IOMUX_PAD(0x049C, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_SDBA2__MMDC_DRAM_SDBA_2 = IOMUX_PAD(0x04A0, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_SDCKE0__MMDC_DRAM_SDCKE_0 = IOMUX_PAD(0x04A4, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_SDCKE1__MMDC_DRAM_SDCKE_1 = IOMUX_PAD(0x04A8, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_SDCLK_0__MMDC_DRAM_SDCLK0 = IOMUX_PAD(0x04AC, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_SDCLK_1__MMDC_DRAM_SDCLK1 = IOMUX_PAD(0x04B0, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_SDODT0__MMDC_DRAM_ODT_0 = IOMUX_PAD(0x04B4, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_SDODT1__MMDC_DRAM_ODT_1 = IOMUX_PAD(0x04B8, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_SDQS0__MMDC_DRAM_SDQS_0 = IOMUX_PAD(0x04BC, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_SDQS1__MMDC_DRAM_SDQS_1 = IOMUX_PAD(0x04C0, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_SDQS2__MMDC_DRAM_SDQS_2 = IOMUX_PAD(0x04C4, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_SDQS3__MMDC_DRAM_SDQS_3 = IOMUX_PAD(0x04C8, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_SDQS4__MMDC_DRAM_SDQS_4 = IOMUX_PAD(0x04CC, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_SDQS5__MMDC_DRAM_SDQS_5 = IOMUX_PAD(0x04D0, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_SDQS6__MMDC_DRAM_SDQS_6 = IOMUX_PAD(0x04D4, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_SDQS7__MMDC_DRAM_SDQS_7 = IOMUX_PAD(0x04D8, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_DRAM_SDWE__MMDC_DRAM_SDWE = IOMUX_PAD(0x04DC, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_EIM_A16__WEIM_WEIM_A_16 = IOMUX_PAD(0x04E0, 0x0110, 0, 0x0000, 0, 0), + MX6_PAD_EIM_A16__IPU1_DI1_DISP_CLK = IOMUX_PAD(0x04E0, 0x0110, 1, 0x0000, 0, 0), + MX6_PAD_EIM_A16__IPU1_CSI1_PIXCLK = IOMUX_PAD(0x04E0, 0x0110, 2, 0x08B8, 0, 0), + MX6_PAD_EIM_A16__MIPI_CORE_DPHY_TEST_OUT_23 = IOMUX_PAD(0x04E0, 0x0110, 4, 0x0000, 0, 0), + MX6_PAD_EIM_A16__GPIO_2_22 = IOMUX_PAD(0x04E0, 0x0110, 5, 0x0000, 0, 0), + MX6_PAD_EIM_A16__TPSMP_HDATA_6 = IOMUX_PAD(0x04E0, 0x0110, 6, 0x0000, 0, 0), + MX6_PAD_EIM_A16__SRC_BT_CFG_16 = IOMUX_PAD(0x04E0, 0x0110, 7, 0x0000, 0, 0), + MX6_PAD_EIM_A16__EPDC_SDDO_0 = IOMUX_PAD(0x04E0, 0x0110, 8, 0x0000, 0, 0), + MX6_PAD_EIM_A17__WEIM_WEIM_A_17 = IOMUX_PAD(0x04E4, 0x0114, 0, 0x0000, 0, 0), + MX6_PAD_EIM_A17__IPU1_DISP1_DAT_12 = IOMUX_PAD(0x04E4, 0x0114, 1, 0x0000, 0, 0), + MX6_PAD_EIM_A17__IPU1_CSI1_D_12 = IOMUX_PAD(0x04E4, 0x0114, 2, 0x0890, 0, 0), + MX6_PAD_EIM_A17__MIPI_CORE_DPHY_TEST_OUT_22 = IOMUX_PAD(0x04E4, 0x0114, 4, 0x0000, 0, 0), + MX6_PAD_EIM_A17__GPIO_2_21 = IOMUX_PAD(0x04E4, 0x0114, 5, 0x0000, 0, 0), + MX6_PAD_EIM_A17__TPSMP_HDATA_5 = IOMUX_PAD(0x04E4, 0x0114, 6, 0x0000, 0, 0), + MX6_PAD_EIM_A17__SRC_BT_CFG_17 = IOMUX_PAD(0x04E4, 0x0114, 7, 0x0000, 0, 0), + MX6_PAD_EIM_A17__EPDC_PWRSTAT = IOMUX_PAD(0x04E4, 0x0114, 8, 0x0000, 0, 0), + MX6_PAD_EIM_A18__WEIM_WEIM_A_18 = IOMUX_PAD(0x04E8, 0x0118, 0, 0x0000, 0, 0), + MX6_PAD_EIM_A18__IPU1_DISP1_DAT_13 = IOMUX_PAD(0x04E8, 0x0118, 1, 0x0000, 0, 0), + MX6_PAD_EIM_A18__IPU1_CSI1_D_13 = IOMUX_PAD(0x04E8, 0x0118, 2, 0x0894, 0, 0), + MX6_PAD_EIM_A18__MIPI_CORE_DPHY_TEST_OUT_21 = IOMUX_PAD(0x04E8, 0x0118, 4, 0x0000, 0, 0), + MX6_PAD_EIM_A18__GPIO_2_20 = IOMUX_PAD(0x04E8, 0x0118, 5, 0x0000, 0, 0), + MX6_PAD_EIM_A18__TPSMP_HDATA_4 = IOMUX_PAD(0x04E8, 0x0118, 6, 0x0000, 0, 0), + MX6_PAD_EIM_A18__SRC_BT_CFG_18 = IOMUX_PAD(0x04E8, 0x0118, 7, 0x0000, 0, 0), + MX6_PAD_EIM_A18__EPDC_PWRCTRL_0 = IOMUX_PAD(0x04E8, 0x0118, 8, 0x0000, 0, 0), + MX6_PAD_EIM_A19__WEIM_WEIM_A_19 = IOMUX_PAD(0x04EC, 0x011C, 0, 0x0000, 0, 0), + MX6_PAD_EIM_A19__IPU1_DISP1_DAT_14 = IOMUX_PAD(0x04EC, 0x011C, 1, 0x0000, 0, 0), + MX6_PAD_EIM_A19__IPU1_CSI1_D_14 = IOMUX_PAD(0x04EC, 0x011C, 2, 0x0898, 0, 0), + MX6_PAD_EIM_A19__MIPI_CORE_DPHY_TEST_OUT_20 = IOMUX_PAD(0x04EC, 0x011C, 4, 0x0000, 0, 0), + MX6_PAD_EIM_A19__GPIO_2_19 = IOMUX_PAD(0x04EC, 0x011C, 5, 0x0000, 0, 0), + MX6_PAD_EIM_A19__TPSMP_HDATA_3 = IOMUX_PAD(0x04EC, 0x011C, 6, 0x0000, 0, 0), + MX6_PAD_EIM_A19__SRC_BT_CFG_19 = IOMUX_PAD(0x04EC, 0x011C, 7, 0x0000, 0, 0), + MX6_PAD_EIM_A19__EPDC_PWRCTRL_1 = IOMUX_PAD(0x04EC, 0x011C, 8, 0x0000, 0, 0), + MX6_PAD_EIM_A20__WEIM_WEIM_A_20 = IOMUX_PAD(0x04F0, 0x0120, 0, 0x0000, 0, 0), + MX6_PAD_EIM_A20__IPU1_DISP1_DAT_15 = IOMUX_PAD(0x04F0, 0x0120, 1, 0x0000, 0, 0), + MX6_PAD_EIM_A20__IPU1_CSI1_D_15 = IOMUX_PAD(0x04F0, 0x0120, 2, 0x089C, 0, 0), + MX6_PAD_EIM_A20__MIPI_CORE_DPHY_TEST_OUT_19 = IOMUX_PAD(0x04F0, 0x0120, 4, 0x0000, 0, 0), + MX6_PAD_EIM_A20__GPIO_2_18 = IOMUX_PAD(0x04F0, 0x0120, 5, 0x0000, 0, 0), + MX6_PAD_EIM_A20__TPSMP_HDATA_2 = IOMUX_PAD(0x04F0, 0x0120, 6, 0x0000, 0, 0), + MX6_PAD_EIM_A20__SRC_BT_CFG_20 = IOMUX_PAD(0x04F0, 0x0120, 7, 0x0000, 0, 0), + MX6_PAD_EIM_A20__EPDC_PWRCTRL_2 = IOMUX_PAD(0x04F0, 0x0120, 8, 0x0000, 0, 0), + MX6_PAD_EIM_A21__WEIM_WEIM_A_21 = IOMUX_PAD(0x04F4, 0x0124, 0, 0x0000, 0, 0), + MX6_PAD_EIM_A21__IPU1_DISP1_DAT_16 = IOMUX_PAD(0x04F4, 0x0124, 1, 0x0000, 0, 0), + MX6_PAD_EIM_A21__IPU1_CSI1_D_16 = IOMUX_PAD(0x04F4, 0x0124, 2, 0x08A0, 0, 0), + MX6_PAD_EIM_A21__MIPI_CORE_DPHY_TEST_OUT_18 = IOMUX_PAD(0x04F4, 0x0124, 4, 0x0000, 0, 0), + MX6_PAD_EIM_A21__GPIO_2_17 = IOMUX_PAD(0x04F4, 0x0124, 5, 0x0000, 0, 0), + MX6_PAD_EIM_A21__TPSMP_HDATA_1 = IOMUX_PAD(0x04F4, 0x0124, 6, 0x0000, 0, 0), + MX6_PAD_EIM_A21__SRC_BT_CFG_21 = IOMUX_PAD(0x04F4, 0x0124, 7, 0x0000, 0, 0), + MX6_PAD_EIM_A21__EPDC_GDCLK = IOMUX_PAD(0x04F4, 0x0124, 8, 0x0000, 0, 0), + MX6_PAD_EIM_A22__WEIM_WEIM_A_22 = IOMUX_PAD(0x04F8, 0x0128, 0, 0x0000, 0, 0), + MX6_PAD_EIM_A22__IPU1_DISP1_DAT_17 = IOMUX_PAD(0x04F8, 0x0128, 1, 0x0000, 0, 0), + MX6_PAD_EIM_A22__IPU1_CSI1_D_17 = IOMUX_PAD(0x04F8, 0x0128, 2, 0x08A4, 0, 0), + MX6_PAD_EIM_A22__GPIO_2_16 = IOMUX_PAD(0x04F8, 0x0128, 5, 0x0000, 0, 0), + MX6_PAD_EIM_A22__TPSMP_HDATA_0 = IOMUX_PAD(0x04F8, 0x0128, 6, 0x0000, 0, 0), + MX6_PAD_EIM_A22__SRC_BT_CFG_22 = IOMUX_PAD(0x04F8, 0x0128, 7, 0x0000, 0, 0), + MX6_PAD_EIM_A22__EPDC_GDSP = IOMUX_PAD(0x04F8, 0x0128, 8, 0x0000, 0, 0), + MX6_PAD_EIM_A23__WEIM_WEIM_A_23 = IOMUX_PAD(0x04FC, 0x012C, 0, 0x0000, 0, 0), + MX6_PAD_EIM_A23__IPU1_DISP1_DAT_18 = IOMUX_PAD(0x04FC, 0x012C, 1, 0x0000, 0, 0), + MX6_PAD_EIM_A23__IPU1_CSI1_D_18 = IOMUX_PAD(0x04FC, 0x012C, 2, 0x08A8, 0, 0), + MX6_PAD_EIM_A23__IPU1_SISG_3 = IOMUX_PAD(0x04FC, 0x012C, 4, 0x0000, 0, 0), + MX6_PAD_EIM_A23__GPIO_6_6 = IOMUX_PAD(0x04FC, 0x012C, 5, 0x0000, 0, 0), + MX6_PAD_EIM_A23__PL301_SIM_MX6DL_PER1_HPROT_3 = IOMUX_PAD(0x04FC, 0x012C, 6, 0x0000, 0, 0), + MX6_PAD_EIM_A23__SRC_BT_CFG_23 = IOMUX_PAD(0x04FC, 0x012C, 7, 0x0000, 0, 0), + MX6_PAD_EIM_A23__EPDC_GDOE = IOMUX_PAD(0x04FC, 0x012C, 8, 0x0000, 0, 0), + MX6_PAD_EIM_A24__WEIM_WEIM_A_24 = IOMUX_PAD(0x0500, 0x0130, 0, 0x0000, 0, 0), + MX6_PAD_EIM_A24__IPU1_DISP1_DAT_19 = IOMUX_PAD(0x0500, 0x0130, 1, 0x0000, 0, 0), + MX6_PAD_EIM_A24__IPU1_CSI1_D_19 = IOMUX_PAD(0x0500, 0x0130, 2, 0x08AC, 0, 0), + MX6_PAD_EIM_A24__IPU1_SISG_2 = IOMUX_PAD(0x0500, 0x0130, 4, 0x0000, 0, 0), + MX6_PAD_EIM_A24__GPIO_5_4 = IOMUX_PAD(0x0500, 0x0130, 5, 0x0000, 0, 0), + MX6_PAD_EIM_A24__PL301_SIM_MX6DL_PER1_HPROT_2 = IOMUX_PAD(0x0500, 0x0130, 6, 0x0000, 0, 0), + MX6_PAD_EIM_A24__SRC_BT_CFG_24 = IOMUX_PAD(0x0500, 0x0130, 7, 0x0000, 0, 0), + MX6_PAD_EIM_A24__EPDC_GDRL = IOMUX_PAD(0x0500, 0x0130, 8, 0x0000, 0, 0), + MX6_PAD_EIM_A25__WEIM_WEIM_A_25 = IOMUX_PAD(0x0504, 0x0134, 0, 0x0000, 0, 0), + MX6_PAD_EIM_A25__ECSPI4_SS1 = IOMUX_PAD(0x0504, 0x0134, 1, 0x0000, 0, 0), + MX6_PAD_EIM_A25__ECSPI2_RDY = IOMUX_PAD(0x0504, 0x0134, 2, 0x0000, 0, 0), + MX6_PAD_EIM_A25__IPU1_DI1_PIN12 = IOMUX_PAD(0x0504, 0x0134, 3, 0x0000, 0, 0), + MX6_PAD_EIM_A25__IPU1_DI0_D1_CS = IOMUX_PAD(0x0504, 0x0134, 4, 0x0000, 0, 0), + MX6_PAD_EIM_A25__GPIO_5_2 = IOMUX_PAD(0x0504, 0x0134, 5, 0x0000, 0, 0), + MX6_PAD_EIM_A25__HDMI_TX_CEC_LINE = IOMUX_PAD(0x0504, 0x0134, 6, 0x085C, 0, 0), + MX6_PAD_EIM_A25__PL301_SIM_MX6DL_PER1_HBURST_0 = IOMUX_PAD(0x0504, 0x0134, 7, 0x0000, 0, 0), + MX6_PAD_EIM_A25__EPDC_SDDO_15 = IOMUX_PAD(0x0504, 0x0134, 8, 0x0000, 0, 0), + MX6_PAD_EIM_A25__WEIM_ACLK_FREERUN = IOMUX_PAD(0x0504, 0x0134, 9, 0x0000, 0, 0), + MX6_PAD_EIM_BCLK__WEIM_WEIM_BCLK = IOMUX_PAD(0x0508, 0x0138, 0, 0x0000, 0, 0), + MX6_PAD_EIM_BCLK__IPU1_DI1_PIN16 = IOMUX_PAD(0x0508, 0x0138, 1, 0x0000, 0, 0), + MX6_PAD_EIM_BCLK__GPIO_6_31 = IOMUX_PAD(0x0508, 0x0138, 5, 0x0000, 0, 0), + MX6_PAD_EIM_BCLK__TPSMP_HDATA_31 = IOMUX_PAD(0x0508, 0x0138, 6, 0x0000, 0, 0), + MX6_PAD_EIM_BCLK__EPDC_SDCE_9 = IOMUX_PAD(0x0508, 0x0138, 8, 0x0000, 0, 0), + MX6_PAD_EIM_CS0__WEIM_WEIM_CS_0 = IOMUX_PAD(0x050C, 0x013C, 0, 0x0000, 0, 0), + MX6_PAD_EIM_CS0__IPU1_DI1_PIN5 = IOMUX_PAD(0x050C, 0x013C, 1, 0x0000, 0, 0), + MX6_PAD_EIM_CS0__ECSPI2_SCLK = IOMUX_PAD(0x050C, 0x013C, 2, 0x07F4, 2, 0), + MX6_PAD_EIM_CS0__MIPI_CORE_DPHY_TEST_OUT_24 = IOMUX_PAD(0x050C, 0x013C, 4, 0x0000, 0, 0), + MX6_PAD_EIM_CS0__GPIO_2_23 = IOMUX_PAD(0x050C, 0x013C, 5, 0x0000, 0, 0), + MX6_PAD_EIM_CS0__TPSMP_HDATA_7 = IOMUX_PAD(0x050C, 0x013C, 6, 0x0000, 0, 0), + MX6_PAD_EIM_CS0__EPDC_SDDO_6 = IOMUX_PAD(0x050C, 0x013C, 8, 0x0000, 0, 0), + MX6_PAD_EIM_CS1__WEIM_WEIM_CS_1 = IOMUX_PAD(0x0510, 0x0140, 0, 0x0000, 0, 0), + MX6_PAD_EIM_CS1__IPU1_DI1_PIN6 = IOMUX_PAD(0x0510, 0x0140, 1, 0x0000, 0, 0), + MX6_PAD_EIM_CS1__ECSPI2_MOSI = IOMUX_PAD(0x0510, 0x0140, 2, 0x07FC, 2, 0), + MX6_PAD_EIM_CS1__MIPI_CORE_DPHY_TEST_OUT_25 = IOMUX_PAD(0x0510, 0x0140, 4, 0x0000, 0, 0), + MX6_PAD_EIM_CS1__GPIO_2_24 = IOMUX_PAD(0x0510, 0x0140, 5, 0x0000, 0, 0), + MX6_PAD_EIM_CS1__TPSMP_HDATA_8 = IOMUX_PAD(0x0510, 0x0140, 6, 0x0000, 0, 0), + MX6_PAD_EIM_CS1__EPDC_SDDO_8 = IOMUX_PAD(0x0510, 0x0140, 8, 0x0000, 0, 0), + MX6_PAD_EIM_D16__WEIM_WEIM_D_16 = IOMUX_PAD(0x0514, 0x0144, 0, 0x0000, 0, 0), MX6_PAD_EIM_D16__ECSPI1_SCLK = IOMUX_PAD(0x0514, 0x0144, 1, 0x07D8, 2, 0), + MX6_PAD_EIM_D16__IPU1_DI0_PIN5 = IOMUX_PAD(0x0514, 0x0144, 2, 0x0000, 0, 0), + MX6_PAD_EIM_D16__IPU1_CSI1_D_18 = IOMUX_PAD(0x0514, 0x0144, 3, 0x08A8, 1, 0), + MX6_PAD_EIM_D16__HDMI_TX_DDC_SDA = IOMUX_PAD(0x0514, 0x0144, 4, 0x0864, 0, 0), + MX6_PAD_EIM_D16__GPIO_3_16 = IOMUX_PAD(0x0514, 0x0144, 5, 0x0000, 0, 0), + MX6_PAD_EIM_D16__I2C2_SDA = IOMUX_PAD(0x0514, 0x0144, 6 | IOMUX_CONFIG_SION, 0x0874, 0, 0), + MX6_PAD_EIM_D16__TPSMP_HTRANS_0 = IOMUX_PAD(0x0514, 0x0144, 7, 0x0000, 0, 0), + MX6_PAD_EIM_D16__EPDC_SDDO_10 = IOMUX_PAD(0x0514, 0x0144, 8, 0x0000, 0, 0), + MX6_PAD_EIM_D17__WEIM_WEIM_D_17 = IOMUX_PAD(0x0518, 0x0148, 0, 0x0000, 0, 0), MX6_PAD_EIM_D17__ECSPI1_MISO = IOMUX_PAD(0x0518, 0x0148, 1, 0x07DC, 2, 0), + MX6_PAD_EIM_D17__IPU1_DI0_PIN6 = IOMUX_PAD(0x0518, 0x0148, 2, 0x0000, 0, 0), + MX6_PAD_EIM_D17__IPU1_CSI1_PIXCLK = IOMUX_PAD(0x0518, 0x0148, 3, 0x08B8, 1, 0), + MX6_PAD_EIM_D17__DCIC1_DCIC_OUT = IOMUX_PAD(0x0518, 0x0148, 4, 0x0000, 0, 0), + MX6_PAD_EIM_D17__GPIO_3_17 = IOMUX_PAD(0x0518, 0x0148, 5, 0x0000, 0, 0), + MX6_PAD_EIM_D17__I2C3_SCL = IOMUX_PAD(0x0518, 0x0148, 6 | IOMUX_CONFIG_SION, 0x0878, 0, 0), + MX6_PAD_EIM_D17__PL301_SIM_MX6DL_PER1_HBURST_1 = IOMUX_PAD(0x0518, 0x0148, 7, 0x0000, 0, 0), + MX6_PAD_EIM_D17__EPDC_VCOM_0 = IOMUX_PAD(0x0518, 0x0148, 8, 0x0000, 0, 0), + MX6_PAD_EIM_D18__WEIM_WEIM_D_18 = IOMUX_PAD(0x051C, 0x014C, 0, 0x0000, 0, 0), MX6_PAD_EIM_D18__ECSPI1_MOSI = IOMUX_PAD(0x051C, 0x014C, 1, 0x07E0, 2, 0), + MX6_PAD_EIM_D18__IPU1_DI0_PIN7 = IOMUX_PAD(0x051C, 0x014C, 2, 0x0000, 0, 0), + MX6_PAD_EIM_D18__IPU1_CSI1_D_17 = IOMUX_PAD(0x051C, 0x014C, 3, 0x08A4, 1, 0), + MX6_PAD_EIM_D18__IPU1_DI1_D0_CS = IOMUX_PAD(0x051C, 0x014C, 4, 0x0000, 0, 0), + MX6_PAD_EIM_D18__GPIO_3_18 = IOMUX_PAD(0x051C, 0x014C, 5, 0x0000, 0, 0), + MX6_PAD_EIM_D18__I2C3_SDA = IOMUX_PAD(0x051C, 0x014C, 6 | IOMUX_CONFIG_SION, 0x087C, 0, 0), + MX6_PAD_EIM_D18__PL301_SIM_MX6DL_PER1_HBURST_2 = IOMUX_PAD(0x051C, 0x014C, 7, 0x0000, 0, 0), + MX6_PAD_EIM_D18__EPDC_VCOM_1 = IOMUX_PAD(0x051C, 0x014C, 8, 0x0000, 0, 0), + MX6_PAD_EIM_D19__WEIM_WEIM_D_19 = IOMUX_PAD(0x0520, 0x0150, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D19__ECSPI1_SS1 = IOMUX_PAD(0x0520, 0x0150, 1, 0x07E8, 1, 0), + MX6_PAD_EIM_D19__IPU1_DI0_PIN8 = IOMUX_PAD(0x0520, 0x0150, 2, 0x0000, 0, 0), + MX6_PAD_EIM_D19__IPU1_CSI1_D_16 = IOMUX_PAD(0x0520, 0x0150, 3, 0x08A0, 1, 0), + MX6_PAD_EIM_D19__UART1_CTS = IOMUX_PAD(0x0520, 0x0150, 4, 0x0000, 0, 0), + MX6_PAD_EIM_D19__UART1_RTS = IOMUX_PAD(0x0520, 0x0150, 4, 0x08F8, 0, 0), MX6_PAD_EIM_D19__GPIO_3_19 = IOMUX_PAD(0x0520, 0x0150, 5, 0x0000, 0, 0), + MX6_PAD_EIM_D19__EPIT1_EPITO = IOMUX_PAD(0x0520, 0x0150, 6, 0x0000, 0, 0), + MX6_PAD_EIM_D19__PL301_SIM_MX6DL_PER1_HRESP = IOMUX_PAD(0x0520, 0x0150, 7, 0x0000, 0, 0), + MX6_PAD_EIM_D19__EPDC_SDDO_12 = IOMUX_PAD(0x0520, 0x0150, 8, 0x0000, 0, 0), + MX6_PAD_EIM_D20__WEIM_WEIM_D_20 = IOMUX_PAD(0x0524, 0x0154, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D20__ECSPI4_SS0 = IOMUX_PAD(0x0524, 0x0154, 1, 0x0808, 0, 0), + MX6_PAD_EIM_D20__IPU1_DI0_PIN16 = IOMUX_PAD(0x0524, 0x0154, 2, 0x0000, 0, 0), + MX6_PAD_EIM_D20__IPU1_CSI1_D_15 = IOMUX_PAD(0x0524, 0x0154, 3, 0x089C, 1, 0), + MX6_PAD_EIM_D20__UART1_CTS = IOMUX_PAD(0x0524, 0x0154, 4, 0x0000, 0, 0), + MX6_PAD_EIM_D20__UART1_RTS = IOMUX_PAD(0x0524, 0x0154, 4, 0x08F8, 1, 0), + MX6_PAD_EIM_D20__GPIO_3_20 = IOMUX_PAD(0x0524, 0x0154, 5, 0x0000, 0, 0), + MX6_PAD_EIM_D20__EPIT2_EPITO = IOMUX_PAD(0x0524, 0x0154, 6, 0x0000, 0, 0), + MX6_PAD_EIM_D20__TPSMP_HTRANS_1 = IOMUX_PAD(0x0524, 0x0154, 7, 0x0000, 0, 0), + MX6_PAD_EIM_D21__WEIM_WEIM_D_21 = IOMUX_PAD(0x0528, 0x0158, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D21__ECSPI4_SCLK = IOMUX_PAD(0x0528, 0x0158, 1, 0x0000, 0, 0), + MX6_PAD_EIM_D21__IPU1_DI0_PIN17 = IOMUX_PAD(0x0528, 0x0158, 2, 0x0000, 0, 0), + MX6_PAD_EIM_D21__IPU1_CSI1_D_11 = IOMUX_PAD(0x0528, 0x0158, 3, 0x088C, 0, 0), + MX6_PAD_EIM_D21__USBOH3_USBOTG_OC = IOMUX_PAD(0x0528, 0x0158, 4, 0x0920, 0, 0), MX6_PAD_EIM_D21__GPIO_3_21 = IOMUX_PAD(0x0528, 0x0158, 5, 0x0000, 0, 0), MX6_PAD_EIM_D21__I2C1_SCL = IOMUX_PAD(0x0528, 0x0158, 6 | IOMUX_CONFIG_SION, 0x0868, 1, 0), + MX6_PAD_EIM_D21__SPDIF_IN1 = IOMUX_PAD(0x0528, 0x0158, 7, 0x08F0, 0, 0), + MX6_PAD_EIM_D22__WEIM_WEIM_D_22 = IOMUX_PAD(0x052C, 0x015C, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D22__ECSPI4_MISO = IOMUX_PAD(0x052C, 0x015C, 1, 0x0000, 0, 0), + MX6_PAD_EIM_D22__IPU1_DI0_PIN1 = IOMUX_PAD(0x052C, 0x015C, 2, 0x0000, 0, 0), + MX6_PAD_EIM_D22__IPU1_CSI1_D_10 = IOMUX_PAD(0x052C, 0x015C, 3, 0x0888, 0, 0), + MX6_PAD_EIM_D22__USBOH3_USBOTG_PWR = IOMUX_PAD(0x052C, 0x015C, 4, 0x0000, 0, 0), + MX6_PAD_EIM_D22__GPIO_3_22 = IOMUX_PAD(0x052C, 0x015C, 5, 0x0000, 0, 0), + MX6_PAD_EIM_D22__SPDIF_OUT1 = IOMUX_PAD(0x052C, 0x015C, 6, 0x0000, 0, 0), + MX6_PAD_EIM_D22__PL301_SIM_MX6DL_PER1_HWRITE = IOMUX_PAD(0x052C, 0x015C, 7, 0x0000, 0, 0), + MX6_PAD_EIM_D22__EPDC_SDCE_6 = IOMUX_PAD(0x052C, 0x015C, 8, 0x0000, 0, 0), + MX6_PAD_EIM_D23__WEIM_WEIM_D_23 = IOMUX_PAD(0x0530, 0x0160, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D23__IPU1_DI0_D0_CS = IOMUX_PAD(0x0530, 0x0160, 1, 0x0000, 0, 0), + MX6_PAD_EIM_D23__UART3_CTS = IOMUX_PAD(0x0530, 0x0160, 2, 0x0000, 0, 0), + MX6_PAD_EIM_D23__UART3_RTS = IOMUX_PAD(0x0530, 0x0160, 2, 0x0908, 0, 0), + MX6_PAD_EIM_D23__UART1_DCD = IOMUX_PAD(0x0530, 0x0160, 3, 0x0000, 0, 0), + MX6_PAD_EIM_D23__IPU1_CSI1_DATA_EN = IOMUX_PAD(0x0530, 0x0160, 4, 0x08B0, 0, 0), MX6_PAD_EIM_D23__GPIO_3_23 = IOMUX_PAD(0x0530, 0x0160, 5, 0x0000, 0, 0), + MX6_PAD_EIM_D23__IPU1_DI1_PIN2 = IOMUX_PAD(0x0530, 0x0160, 6, 0x0000, 0, 0), + MX6_PAD_EIM_D23__IPU1_DI1_PIN14 = IOMUX_PAD(0x0530, 0x0160, 7, 0x0000, 0, 0), + MX6_PAD_EIM_D23__EPDC_SDDO_11 = IOMUX_PAD(0x0530, 0x0160, 8, 0x0000, 0, 0), + MX6_PAD_EIM_D24__WEIM_WEIM_D_24 = IOMUX_PAD(0x0534, 0x0164, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D24__ECSPI4_SS2 = IOMUX_PAD(0x0534, 0x0164, 1, 0x0000, 0, 0), + MX6_PAD_EIM_D24__UART3_TXD = IOMUX_PAD(0x0534, 0x0164, 2, 0x0000, 0, 0), + MX6_PAD_EIM_D24__UART3_RXD = IOMUX_PAD(0x0534, 0x0164, 2, 0x090C, 0, 0), + MX6_PAD_EIM_D24__ECSPI1_SS2 = IOMUX_PAD(0x0534, 0x0164, 3, 0x07EC, 0, 0), + MX6_PAD_EIM_D24__ECSPI2_SS2 = IOMUX_PAD(0x0534, 0x0164, 4, 0x0000, 0, 0), + MX6_PAD_EIM_D24__GPIO_3_24 = IOMUX_PAD(0x0534, 0x0164, 5, 0x0000, 0, 0), + MX6_PAD_EIM_D24__AUDMUX_AUD5_RXFS = IOMUX_PAD(0x0534, 0x0164, 6, 0x07BC, 1, 0), + MX6_PAD_EIM_D24__UART1_DTR = IOMUX_PAD(0x0534, 0x0164, 7, 0x0000, 0, 0), + MX6_PAD_EIM_D24__EPDC_SDCE_7 = IOMUX_PAD(0x0534, 0x0164, 8, 0x0000, 0, 0), + MX6_PAD_EIM_D25__WEIM_WEIM_D_25 = IOMUX_PAD(0x0538, 0x0168, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D25__ECSPI4_SS3 = IOMUX_PAD(0x0538, 0x0168, 1, 0x0000, 0, 0), + MX6_PAD_EIM_D25__UART3_TXD = IOMUX_PAD(0x0538, 0x0168, 2, 0x0000, 0, 0), + MX6_PAD_EIM_D25__UART3_RXD = IOMUX_PAD(0x0538, 0x0168, 2, 0x090C, 1, 0), + MX6_PAD_EIM_D25__ECSPI1_SS3 = IOMUX_PAD(0x0538, 0x0168, 3, 0x07F0, 0, 0), + MX6_PAD_EIM_D25__ECSPI2_SS3 = IOMUX_PAD(0x0538, 0x0168, 4, 0x0000, 0, 0), + MX6_PAD_EIM_D25__GPIO_3_25 = IOMUX_PAD(0x0538, 0x0168, 5, 0x0000, 0, 0), + MX6_PAD_EIM_D25__AUDMUX_AUD5_RXC = IOMUX_PAD(0x0538, 0x0168, 6, 0x07B8, 1, 0), + MX6_PAD_EIM_D25__UART1_DSR = IOMUX_PAD(0x0538, 0x0168, 7, 0x0000, 0, 0), + MX6_PAD_EIM_D25__EPDC_SDCE_8 = IOMUX_PAD(0x0538, 0x0168, 8, 0x0000, 0, 0), + MX6_PAD_EIM_D26__WEIM_WEIM_D_26 = IOMUX_PAD(0x053C, 0x016C, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D26__IPU1_DI1_PIN11 = IOMUX_PAD(0x053C, 0x016C, 1, 0x0000, 0, 0), + MX6_PAD_EIM_D26__IPU1_CSI0_D_1 = IOMUX_PAD(0x053C, 0x016C, 2, 0x0000, 0, 0), + MX6_PAD_EIM_D26__IPU1_CSI1_D_14 = IOMUX_PAD(0x053C, 0x016C, 3, 0x0898, 1, 0), MX6_PAD_EIM_D26__UART2_TXD = IOMUX_PAD(0x053C, 0x016C, 4, 0x0000, 0, 0), + MX6_PAD_EIM_D26__UART2_RXD = IOMUX_PAD(0x053C, 0x016C, 4, 0x0904, 0, 0), + MX6_PAD_EIM_D26__GPIO_3_26 = IOMUX_PAD(0x053C, 0x016C, 5, 0x0000, 0, 0), + MX6_PAD_EIM_D26__IPU1_SISG_2 = IOMUX_PAD(0x053C, 0x016C, 6, 0x0000, 0, 0), + MX6_PAD_EIM_D26__IPU1_DISP1_DAT_22 = IOMUX_PAD(0x053C, 0x016C, 7, 0x0000, 0, 0), + MX6_PAD_EIM_D26__EPDC_SDOED = IOMUX_PAD(0x053C, 0x016C, 8, 0x0000, 0, 0), + MX6_PAD_EIM_D27__WEIM_WEIM_D_27 = IOMUX_PAD(0x0540, 0x0170, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D27__IPU1_DI1_PIN13 = IOMUX_PAD(0x0540, 0x0170, 1, 0x0000, 0, 0), + MX6_PAD_EIM_D27__IPU1_CSI0_D_0 = IOMUX_PAD(0x0540, 0x0170, 2, 0x0000, 0, 0), + MX6_PAD_EIM_D27__IPU1_CSI1_D_13 = IOMUX_PAD(0x0540, 0x0170, 3, 0x0894, 1, 0), + MX6_PAD_EIM_D27__UART2_TXD = IOMUX_PAD(0x0540, 0x0170, 4, 0x0000, 0, 0), MX6_PAD_EIM_D27__UART2_RXD = IOMUX_PAD(0x0540, 0x0170, 4, 0x0904, 1, 0), + MX6_PAD_EIM_D27__GPIO_3_27 = IOMUX_PAD(0x0540, 0x0170, 5, 0x0000, 0, 0), + MX6_PAD_EIM_D27__IPU1_SISG_3 = IOMUX_PAD(0x0540, 0x0170, 6, 0x0000, 0, 0), + MX6_PAD_EIM_D27__IPU1_DISP1_DAT_23 = IOMUX_PAD(0x0540, 0x0170, 7, 0x0000, 0, 0), + MX6_PAD_EIM_D27__EPDC_SDOE = IOMUX_PAD(0x0540, 0x0170, 8, 0x0000, 0, 0), + MX6_PAD_EIM_D28__WEIM_WEIM_D_28 = IOMUX_PAD(0x0544, 0x0174, 0, 0x0000, 0, 0), MX6_PAD_EIM_D28__I2C1_SDA = IOMUX_PAD(0x0544, 0x0174, 1 | IOMUX_CONFIG_SION, 0x086C, 1, 0), + MX6_PAD_EIM_D28__ECSPI4_MOSI = IOMUX_PAD(0x0544, 0x0174, 2, 0x0000, 0, 0), + MX6_PAD_EIM_D28__IPU1_CSI1_D_12 = IOMUX_PAD(0x0544, 0x0174, 3, 0x0890, 1, 0), + MX6_PAD_EIM_D28__UART2_CTS = IOMUX_PAD(0x0544, 0x0174, 4, 0x0000, 0, 0), + MX6_PAD_EIM_D28__UART2_RTS = IOMUX_PAD(0x0544, 0x0174, 4, 0x0900, 0, 0), MX6_PAD_EIM_D28__GPIO_3_28 = IOMUX_PAD(0x0544, 0x0174, 5, 0x0000, 0, 0), + MX6_PAD_EIM_D28__IPU1_EXT_TRIG = IOMUX_PAD(0x0544, 0x0174, 6, 0x0000, 0, 0), + MX6_PAD_EIM_D28__IPU1_DI0_PIN13 = IOMUX_PAD(0x0544, 0x0174, 7, 0x0000, 0, 0), + MX6_PAD_EIM_D28__EPDC_PWRCTRL_3 = IOMUX_PAD(0x0544, 0x0174, 8, 0x0000, 0, 0), + MX6_PAD_EIM_D29__WEIM_WEIM_D_29 = IOMUX_PAD(0x0548, 0x0178, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D29__IPU1_DI1_PIN15 = IOMUX_PAD(0x0548, 0x0178, 1, 0x0000, 0, 0), + MX6_PAD_EIM_D29__ECSPI4_SS0 = IOMUX_PAD(0x0548, 0x0178, 2, 0x0808, 1, 0), + MX6_PAD_EIM_D29__UART2_CTS = IOMUX_PAD(0x0548, 0x0178, 4, 0x0000, 0, 0), + MX6_PAD_EIM_D29__UART2_RTS = IOMUX_PAD(0x0548, 0x0178, 4, 0x0900, 1, 0), MX6_PAD_EIM_D29__GPIO_3_29 = IOMUX_PAD(0x0548, 0x0178, 5, 0x0000, 0, 0), + MX6_PAD_EIM_D29__IPU1_CSI1_VSYNC = IOMUX_PAD(0x0548, 0x0178, 6, 0x08BC, 0, 0), + MX6_PAD_EIM_D29__IPU1_DI0_PIN14 = IOMUX_PAD(0x0548, 0x0178, 7, 0x0000, 0, 0), + MX6_PAD_EIM_D29__EPDC_PWRWAKE = IOMUX_PAD(0x0548, 0x0178, 8, 0x0000, 0, 0), + MX6_PAD_EIM_D30__WEIM_WEIM_D_30 = IOMUX_PAD(0x054C, 0x017C, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D30__IPU1_DISP1_DAT_21 = IOMUX_PAD(0x054C, 0x017C, 1, 0x0000, 0, 0), + MX6_PAD_EIM_D30__IPU1_DI0_PIN11 = IOMUX_PAD(0x054C, 0x017C, 2, 0x0000, 0, 0), + MX6_PAD_EIM_D30__IPU1_CSI0_D_3 = IOMUX_PAD(0x054C, 0x017C, 3, 0x0000, 0, 0), + MX6_PAD_EIM_D30__UART3_CTS = IOMUX_PAD(0x054C, 0x017C, 4, 0x0000, 0, 0), + MX6_PAD_EIM_D30__UART3_RTS = IOMUX_PAD(0x054C, 0x017C, 4, 0x0908, 1, 0), + MX6_PAD_EIM_D30__GPIO_3_30 = IOMUX_PAD(0x054C, 0x017C, 5, 0x0000, 0, 0), + MX6_PAD_EIM_D30__USBOH3_USBH1_OC = IOMUX_PAD(0x054C, 0x017C, 6, 0x0924, 0, 0), + MX6_PAD_EIM_D30__PL301_SIM_MX6DL_PER1_HPROT_0 = IOMUX_PAD(0x054C, 0x017C, 7, 0x0000, 0, 0), + MX6_PAD_EIM_D30__EPDC_SDOEZ = IOMUX_PAD(0x054C, 0x017C, 8, 0x0000, 0, 0), + MX6_PAD_EIM_D31__WEIM_WEIM_D_31 = IOMUX_PAD(0x0550, 0x0180, 0, 0x0000, 0, 0), + MX6_PAD_EIM_D31__IPU1_DISP1_DAT_20 = IOMUX_PAD(0x0550, 0x0180, 1, 0x0000, 0, 0), + MX6_PAD_EIM_D31__IPU1_DI0_PIN12 = IOMUX_PAD(0x0550, 0x0180, 2, 0x0000, 0, 0), + MX6_PAD_EIM_D31__IPU1_CSI0_D_2 = IOMUX_PAD(0x0550, 0x0180, 3, 0x0000, 0, 0), + MX6_PAD_EIM_D31__UART3_CTS = IOMUX_PAD(0x0550, 0x0180, 4, 0x0000, 0, 0), + MX6_PAD_EIM_D31__UART3_RTS = IOMUX_PAD(0x0550, 0x0180, 4, 0x0908, 2, 0), + MX6_PAD_EIM_D31__GPIO_3_31 = IOMUX_PAD(0x0550, 0x0180, 5, 0x0000, 0, 0), + MX6_PAD_EIM_D31__USBOH3_USBH1_PWR = IOMUX_PAD(0x0550, 0x0180, 6, 0x0000, 0, 0), + MX6_PAD_EIM_D31__PL301_SIM_MX6DL_PER1_HPROT_1 = IOMUX_PAD(0x0550, 0x0180, 7, 0x0000, 0, 0), + MX6_PAD_EIM_D31__EPDC_SDCLK = IOMUX_PAD(0x0550, 0x0180, 8, 0x0000, 0, 0), + MX6_PAD_EIM_D31__WEIM_ACLK_FREERUN = IOMUX_PAD(0x0550, 0x0180, 9, 0x0000, 0, 0), + MX6_PAD_EIM_DA0__WEIM_WEIM_DA_A_0 = IOMUX_PAD(0x0554, 0x0184, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA0__IPU1_DISP1_DAT_9 = IOMUX_PAD(0x0554, 0x0184, 1, 0x0000, 0, 0), + MX6_PAD_EIM_DA0__IPU1_CSI1_D_9 = IOMUX_PAD(0x0554, 0x0184, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA0__MIPI_CORE_DPHY_TEST_OUT_2 = IOMUX_PAD(0x0554, 0x0184, 3, 0x0000, 0, 0), + MX6_PAD_EIM_DA0__GPIO_3_0 = IOMUX_PAD(0x0554, 0x0184, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA0__TPSMP_HDATA_14 = IOMUX_PAD(0x0554, 0x0184, 6, 0x0000, 0, 0), + MX6_PAD_EIM_DA0__SRC_BT_CFG_0 = IOMUX_PAD(0x0554, 0x0184, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA0__EPDC_SDCLKN = IOMUX_PAD(0x0554, 0x0184, 8, 0x0000, 0, 0), + MX6_PAD_EIM_DA1__WEIM_WEIM_DA_A_1 = IOMUX_PAD(0x0558, 0x0188, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA1__IPU1_DISP1_DAT_8 = IOMUX_PAD(0x0558, 0x0188, 1, 0x0000, 0, 0), + MX6_PAD_EIM_DA1__IPU1_CSI1_D_8 = IOMUX_PAD(0x0558, 0x0188, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA1__MIPI_CORE_DPHY_TEST_OUT_3 = IOMUX_PAD(0x0558, 0x0188, 3, 0x0000, 0, 0), + MX6_PAD_EIM_DA1__ANATOP_USBPHY1_TSTI_TX_LS_MODE = IOMUX_PAD(0x0558, 0x0188, 4, 0x0000, 0, 0), + MX6_PAD_EIM_DA1__GPIO_3_1 = IOMUX_PAD(0x0558, 0x0188, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA1__TPSMP_HDATA_15 = IOMUX_PAD(0x0558, 0x0188, 6, 0x0000, 0, 0), + MX6_PAD_EIM_DA1__SRC_BT_CFG_1 = IOMUX_PAD(0x0558, 0x0188, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA1__EPDC_SDLE = IOMUX_PAD(0x0558, 0x0188, 8, 0x0000, 0, 0), + MX6_PAD_EIM_DA10__WEIM_WEIM_DA_A_10 = IOMUX_PAD(0x055C, 0x018C, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA10__IPU1_DI1_PIN15 = IOMUX_PAD(0x055C, 0x018C, 1, 0x0000, 0, 0), + MX6_PAD_EIM_DA10__IPU1_CSI1_DATA_EN = IOMUX_PAD(0x055C, 0x018C, 2, 0x08B0, 1, 0), + MX6_PAD_EIM_DA10__MIPI_CORE_DPHY_TEST_OUT_12 = IOMUX_PAD(0x055C, 0x018C, 3, 0x0000, 0, 0), + MX6_PAD_EIM_DA10__GPIO_3_10 = IOMUX_PAD(0x055C, 0x018C, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA10__TPSMP_HDATA_24 = IOMUX_PAD(0x055C, 0x018C, 6, 0x0000, 0, 0), + MX6_PAD_EIM_DA10__SRC_BT_CFG_10 = IOMUX_PAD(0x055C, 0x018C, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA10__EPDC_SDDO_1 = IOMUX_PAD(0x055C, 0x018C, 8, 0x0000, 0, 0), + MX6_PAD_EIM_DA11__WEIM_WEIM_DA_A_11 = IOMUX_PAD(0x0560, 0x0190, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA11__IPU1_DI1_PIN2 = IOMUX_PAD(0x0560, 0x0190, 1, 0x0000, 0, 0), + MX6_PAD_EIM_DA11__IPU1_CSI1_HSYNC = IOMUX_PAD(0x0560, 0x0190, 2, 0x08B4, 0, 0), + MX6_PAD_EIM_DA11__MIPI_CORE_DPHY_TEST_OUT_13 = IOMUX_PAD(0x0560, 0x0190, 3, 0x0000, 0, 0), + MX6_PAD_EIM_DA11__SDMA_DEBUG_EVT_CHN_LINES_6 = IOMUX_PAD(0x0560, 0x0190, 4, 0x0000, 0, 0), + MX6_PAD_EIM_DA11__GPIO_3_11 = IOMUX_PAD(0x0560, 0x0190, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA11__TPSMP_HDATA_25 = IOMUX_PAD(0x0560, 0x0190, 6, 0x0000, 0, 0), + MX6_PAD_EIM_DA11__SRC_BT_CFG_11 = IOMUX_PAD(0x0560, 0x0190, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA11__EPDC_SDDO_3 = IOMUX_PAD(0x0560, 0x0190, 8, 0x0000, 0, 0), + MX6_PAD_EIM_DA12__WEIM_WEIM_DA_A_12 = IOMUX_PAD(0x0564, 0x0194, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA12__IPU1_DI1_PIN3 = IOMUX_PAD(0x0564, 0x0194, 1, 0x0000, 0, 0), + MX6_PAD_EIM_DA12__IPU1_CSI1_VSYNC = IOMUX_PAD(0x0564, 0x0194, 2, 0x08BC, 1, 0), + MX6_PAD_EIM_DA12__MIPI_CORE_DPHY_TEST_OUT_14 = IOMUX_PAD(0x0564, 0x0194, 3, 0x0000, 0, 0), + MX6_PAD_EIM_DA12__SDMA_DEBUG_EVT_CHN_LINES_3 = IOMUX_PAD(0x0564, 0x0194, 4, 0x0000, 0, 0), + MX6_PAD_EIM_DA12__GPIO_3_12 = IOMUX_PAD(0x0564, 0x0194, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA12__TPSMP_HDATA_26 = IOMUX_PAD(0x0564, 0x0194, 6, 0x0000, 0, 0), + MX6_PAD_EIM_DA12__SRC_BT_CFG_12 = IOMUX_PAD(0x0564, 0x0194, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA12__EPDC_SDDO_2 = IOMUX_PAD(0x0564, 0x0194, 8, 0x0000, 0, 0), + MX6_PAD_EIM_DA13__WEIM_WEIM_DA_A_13 = IOMUX_PAD(0x0568, 0x0198, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA13__IPU1_DI1_D0_CS = IOMUX_PAD(0x0568, 0x0198, 1, 0x0000, 0, 0), + MX6_PAD_EIM_DA13__CCM_DI1_EXT_CLK = IOMUX_PAD(0x0568, 0x0198, 2, 0x07D0, 0, 0), + MX6_PAD_EIM_DA13__MIPI_CORE_DPHY_TEST_OUT_15 = IOMUX_PAD(0x0568, 0x0198, 3, 0x0000, 0, 0), + MX6_PAD_EIM_DA13__SDMA_DEBUG_EVT_CHN_LINES_4 = IOMUX_PAD(0x0568, 0x0198, 4, 0x0000, 0, 0), + MX6_PAD_EIM_DA13__GPIO_3_13 = IOMUX_PAD(0x0568, 0x0198, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA13__TPSMP_HDATA_27 = IOMUX_PAD(0x0568, 0x0198, 6, 0x0000, 0, 0), + MX6_PAD_EIM_DA13__SRC_BT_CFG_13 = IOMUX_PAD(0x0568, 0x0198, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA13__EPDC_SDDO_13 = IOMUX_PAD(0x0568, 0x0198, 8, 0x0000, 0, 0), + MX6_PAD_EIM_DA14__WEIM_WEIM_DA_A_14 = IOMUX_PAD(0x056C, 0x019C, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA14__IPU1_DI1_D1_CS = IOMUX_PAD(0x056C, 0x019C, 1, 0x0000, 0, 0), + MX6_PAD_EIM_DA14__CCM_DI0_EXT_CLK = IOMUX_PAD(0x056C, 0x019C, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA14__MIPI_CORE_DPHY_TEST_OUT_16 = IOMUX_PAD(0x056C, 0x019C, 3, 0x0000, 0, 0), + MX6_PAD_EIM_DA14__SDMA_DEBUG_EVT_CHN_LINES_5 = IOMUX_PAD(0x056C, 0x019C, 4, 0x0000, 0, 0), + MX6_PAD_EIM_DA14__GPIO_3_14 = IOMUX_PAD(0x056C, 0x019C, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA14__TPSMP_HDATA_28 = IOMUX_PAD(0x056C, 0x019C, 6, 0x0000, 0, 0), + MX6_PAD_EIM_DA14__SRC_BT_CFG_14 = IOMUX_PAD(0x056C, 0x019C, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA14__EPDC_SDDO_14 = IOMUX_PAD(0x056C, 0x019C, 8, 0x0000, 0, 0), + MX6_PAD_EIM_DA15__WEIM_WEIM_DA_A_15 = IOMUX_PAD(0x0570, 0x01A0, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA15__IPU1_DI1_PIN1 = IOMUX_PAD(0x0570, 0x01A0, 1, 0x0000, 0, 0), + MX6_PAD_EIM_DA15__IPU1_DI1_PIN4 = IOMUX_PAD(0x0570, 0x01A0, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA15__MIPI_CORE_DPHY_TEST_OUT_17 = IOMUX_PAD(0x0570, 0x01A0, 3, 0x0000, 0, 0), + MX6_PAD_EIM_DA15__GPIO_3_15 = IOMUX_PAD(0x0570, 0x01A0, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA15__TPSMP_HDATA_29 = IOMUX_PAD(0x0570, 0x01A0, 6, 0x0000, 0, 0), + MX6_PAD_EIM_DA15__SRC_BT_CFG_15 = IOMUX_PAD(0x0570, 0x01A0, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA15__EPDC_SDDO_9 = IOMUX_PAD(0x0570, 0x01A0, 8, 0x0000, 0, 0), + MX6_PAD_EIM_DA2__WEIM_WEIM_DA_A_2 = IOMUX_PAD(0x0574, 0x01A4, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA2__IPU1_DISP1_DAT_7 = IOMUX_PAD(0x0574, 0x01A4, 1, 0x0000, 0, 0), + MX6_PAD_EIM_DA2__IPU1_CSI1_D_7 = IOMUX_PAD(0x0574, 0x01A4, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA2__MIPI_CORE_DPHY_TEST_OUT_4 = IOMUX_PAD(0x0574, 0x01A4, 3, 0x0000, 0, 0), + MX6_PAD_EIM_DA2__ANATOP_USBPHY1_TSTI_TX_HS_MODE = IOMUX_PAD(0x0574, 0x01A4, 4, 0x0000, 0, 0), + MX6_PAD_EIM_DA2__GPIO_3_2 = IOMUX_PAD(0x0574, 0x01A4, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA2__TPSMP_HDATA_16 = IOMUX_PAD(0x0574, 0x01A4, 6, 0x0000, 0, 0), + MX6_PAD_EIM_DA2__SRC_BT_CFG_2 = IOMUX_PAD(0x0574, 0x01A4, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA2__EPDC_BDR_0 = IOMUX_PAD(0x0574, 0x01A4, 8, 0x0000, 0, 0), + MX6_PAD_EIM_DA3__WEIM_WEIM_DA_A_3 = IOMUX_PAD(0x0578, 0x01A8, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA3__IPU1_DISP1_DAT_6 = IOMUX_PAD(0x0578, 0x01A8, 1, 0x0000, 0, 0), + MX6_PAD_EIM_DA3__IPU1_CSI1_D_6 = IOMUX_PAD(0x0578, 0x01A8, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA3__MIPI_CORE_DPHY_TEST_OUT_5 = IOMUX_PAD(0x0578, 0x01A8, 3, 0x0000, 0, 0), + MX6_PAD_EIM_DA3__ANATOP_USBPHY1_TSTI_TX_HIZ = IOMUX_PAD(0x0578, 0x01A8, 4, 0x0000, 0, 0), + MX6_PAD_EIM_DA3__GPIO_3_3 = IOMUX_PAD(0x0578, 0x01A8, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA3__TPSMP_HDATA_17 = IOMUX_PAD(0x0578, 0x01A8, 6, 0x0000, 0, 0), + MX6_PAD_EIM_DA3__SRC_BT_CFG_3 = IOMUX_PAD(0x0578, 0x01A8, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA3__EPDC_BDR_1 = IOMUX_PAD(0x0578, 0x01A8, 8, 0x0000, 0, 0), + MX6_PAD_EIM_DA4__WEIM_WEIM_DA_A_4 = IOMUX_PAD(0x057C, 0x01AC, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA4__IPU1_DISP1_DAT_5 = IOMUX_PAD(0x057C, 0x01AC, 1, 0x0000, 0, 0), + MX6_PAD_EIM_DA4__IPU1_CSI1_D_5 = IOMUX_PAD(0x057C, 0x01AC, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA4__MIPI_CORE_DPHY_TEST_OUT_6 = IOMUX_PAD(0x057C, 0x01AC, 3, 0x0000, 0, 0), + MX6_PAD_EIM_DA4__ANATOP_USBPHY1_TSTI_TX_EN = IOMUX_PAD(0x057C, 0x01AC, 4, 0x0000, 0, 0), + MX6_PAD_EIM_DA4__GPIO_3_4 = IOMUX_PAD(0x057C, 0x01AC, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA4__TPSMP_HDATA_18 = IOMUX_PAD(0x057C, 0x01AC, 6, 0x0000, 0, 0), + MX6_PAD_EIM_DA4__SRC_BT_CFG_4 = IOMUX_PAD(0x057C, 0x01AC, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA4__EPDC_SDCE_0 = IOMUX_PAD(0x057C, 0x01AC, 8, 0x0000, 0, 0), + MX6_PAD_EIM_DA5__WEIM_WEIM_DA_A_5 = IOMUX_PAD(0x0580, 0x01B0, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA5__IPU1_DISP1_DAT_4 = IOMUX_PAD(0x0580, 0x01B0, 1, 0x0000, 0, 0), + MX6_PAD_EIM_DA5__IPU1_CSI1_D_4 = IOMUX_PAD(0x0580, 0x01B0, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA5__MIPI_CORE_DPHY_TEST_OUT_7 = IOMUX_PAD(0x0580, 0x01B0, 3, 0x0000, 0, 0), + MX6_PAD_EIM_DA5__ANATOP_USBPHY1_TSTI_TX_DP = IOMUX_PAD(0x0580, 0x01B0, 4, 0x0000, 0, 0), + MX6_PAD_EIM_DA5__GPIO_3_5 = IOMUX_PAD(0x0580, 0x01B0, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA5__TPSMP_HDATA_19 = IOMUX_PAD(0x0580, 0x01B0, 6, 0x0000, 0, 0), + MX6_PAD_EIM_DA5__SRC_BT_CFG_5 = IOMUX_PAD(0x0580, 0x01B0, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA5__EPDC_SDCE_1 = IOMUX_PAD(0x0580, 0x01B0, 8, 0x0000, 0, 0), + MX6_PAD_EIM_DA6__WEIM_WEIM_DA_A_6 = IOMUX_PAD(0x0584, 0x01B4, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA6__IPU1_DISP1_DAT_3 = IOMUX_PAD(0x0584, 0x01B4, 1, 0x0000, 0, 0), + MX6_PAD_EIM_DA6__IPU1_CSI1_D_3 = IOMUX_PAD(0x0584, 0x01B4, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA6__MIPI_CORE_DPHY_TEST_OUT_8 = IOMUX_PAD(0x0584, 0x01B4, 3, 0x0000, 0, 0), + MX6_PAD_EIM_DA6__ANATOP_USBPHY1_TSTI_TX_DN = IOMUX_PAD(0x0584, 0x01B4, 4, 0x0000, 0, 0), + MX6_PAD_EIM_DA6__GPIO_3_6 = IOMUX_PAD(0x0584, 0x01B4, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA6__TPSMP_HDATA_20 = IOMUX_PAD(0x0584, 0x01B4, 6, 0x0000, 0, 0), + MX6_PAD_EIM_DA6__SRC_BT_CFG_6 = IOMUX_PAD(0x0584, 0x01B4, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA6__EPDC_SDCE_2 = IOMUX_PAD(0x0584, 0x01B4, 8, 0x0000, 0, 0), + MX6_PAD_EIM_DA7__WEIM_WEIM_DA_A_7 = IOMUX_PAD(0x0588, 0x01B8, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA7__IPU1_DISP1_DAT_2 = IOMUX_PAD(0x0588, 0x01B8, 1, 0x0000, 0, 0), + MX6_PAD_EIM_DA7__IPU1_CSI1_D_2 = IOMUX_PAD(0x0588, 0x01B8, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA7__MIPI_CORE_DPHY_TEST_OUT_9 = IOMUX_PAD(0x0588, 0x01B8, 3, 0x0000, 0, 0), + MX6_PAD_EIM_DA7__GPIO_3_7 = IOMUX_PAD(0x0588, 0x01B8, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA7__TPSMP_HDATA_21 = IOMUX_PAD(0x0588, 0x01B8, 6, 0x0000, 0, 0), + MX6_PAD_EIM_DA7__SRC_BT_CFG_7 = IOMUX_PAD(0x0588, 0x01B8, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA7__EPDC_SDCE_3 = IOMUX_PAD(0x0588, 0x01B8, 8, 0x0000, 0, 0), + MX6_PAD_EIM_DA8__WEIM_WEIM_DA_A_8 = IOMUX_PAD(0x058C, 0x01BC, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA8__IPU1_DISP1_DAT_1 = IOMUX_PAD(0x058C, 0x01BC, 1, 0x0000, 0, 0), + MX6_PAD_EIM_DA8__IPU1_CSI1_D_1 = IOMUX_PAD(0x058C, 0x01BC, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA8__MIPI_CORE_DPHY_TEST_OUT_10 = IOMUX_PAD(0x058C, 0x01BC, 3, 0x0000, 0, 0), + MX6_PAD_EIM_DA8__GPIO_3_8 = IOMUX_PAD(0x058C, 0x01BC, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA8__TPSMP_HDATA_22 = IOMUX_PAD(0x058C, 0x01BC, 6, 0x0000, 0, 0), + MX6_PAD_EIM_DA8__SRC_BT_CFG_8 = IOMUX_PAD(0x058C, 0x01BC, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA8__EPDC_SDCE_4 = IOMUX_PAD(0x058C, 0x01BC, 8, 0x0000, 0, 0), + MX6_PAD_EIM_DA9__WEIM_WEIM_DA_A_9 = IOMUX_PAD(0x0590, 0x01C0, 0, 0x0000, 0, 0), + MX6_PAD_EIM_DA9__IPU1_DISP1_DAT_0 = IOMUX_PAD(0x0590, 0x01C0, 1, 0x0000, 0, 0), + MX6_PAD_EIM_DA9__IPU1_CSI1_D_0 = IOMUX_PAD(0x0590, 0x01C0, 2, 0x0000, 0, 0), + MX6_PAD_EIM_DA9__MIPI_CORE_DPHY_TEST_OUT_11 = IOMUX_PAD(0x0590, 0x01C0, 3, 0x0000, 0, 0), + MX6_PAD_EIM_DA9__GPIO_3_9 = IOMUX_PAD(0x0590, 0x01C0, 5, 0x0000, 0, 0), + MX6_PAD_EIM_DA9__TPSMP_HDATA_23 = IOMUX_PAD(0x0590, 0x01C0, 6, 0x0000, 0, 0), + MX6_PAD_EIM_DA9__SRC_BT_CFG_9 = IOMUX_PAD(0x0590, 0x01C0, 7, 0x0000, 0, 0), + MX6_PAD_EIM_DA9__EPDC_SDCE_5 = IOMUX_PAD(0x0590, 0x01C0, 8, 0x0000, 0, 0), + MX6_PAD_EIM_EB0__WEIM_WEIM_EB_0 = IOMUX_PAD(0x0594, 0x01C4, 0, 0x0000, 0, 0), + MX6_PAD_EIM_EB0__IPU1_DISP1_DAT_11 = IOMUX_PAD(0x0594, 0x01C4, 1, 0x0000, 0, 0), + MX6_PAD_EIM_EB0__IPU1_CSI1_D_11 = IOMUX_PAD(0x0594, 0x01C4, 2, 0x088C, 1, 0), + MX6_PAD_EIM_EB0__MIPI_CORE_DPHY_TEST_OUT_0 = IOMUX_PAD(0x0594, 0x01C4, 3, 0x0000, 0, 0), + MX6_PAD_EIM_EB0__CCM_PMIC_RDY = IOMUX_PAD(0x0594, 0x01C4, 4, 0x07D4, 0, 0), + MX6_PAD_EIM_EB0__GPIO_2_28 = IOMUX_PAD(0x0594, 0x01C4, 5, 0x0000, 0, 0), + MX6_PAD_EIM_EB0__TPSMP_HDATA_12 = IOMUX_PAD(0x0594, 0x01C4, 6, 0x0000, 0, 0), + MX6_PAD_EIM_EB0__SRC_BT_CFG_27 = IOMUX_PAD(0x0594, 0x01C4, 7, 0x0000, 0, 0), + MX6_PAD_EIM_EB0__EPDC_PWRCOM = IOMUX_PAD(0x0594, 0x01C4, 8, 0x0000, 0, 0), + MX6_PAD_EIM_EB1__WEIM_WEIM_EB_1 = IOMUX_PAD(0x0598, 0x01C8, 0, 0x0000, 0, 0), + MX6_PAD_EIM_EB1__IPU1_DISP1_DAT_10 = IOMUX_PAD(0x0598, 0x01C8, 1, 0x0000, 0, 0), + MX6_PAD_EIM_EB1__IPU1_CSI1_D_10 = IOMUX_PAD(0x0598, 0x01C8, 2, 0x0888, 1, 0), + MX6_PAD_EIM_EB1__MIPI_CORE_DPHY_TEST_OUT_1 = IOMUX_PAD(0x0598, 0x01C8, 3, 0x0000, 0, 0), + MX6_PAD_EIM_EB1__GPIO_2_29 = IOMUX_PAD(0x0598, 0x01C8, 5, 0x0000, 0, 0), + MX6_PAD_EIM_EB1__TPSMP_HDATA_13 = IOMUX_PAD(0x0598, 0x01C8, 6, 0x0000, 0, 0), + MX6_PAD_EIM_EB1__SRC_BT_CFG_28 = IOMUX_PAD(0x0598, 0x01C8, 7, 0x0000, 0, 0), + MX6_PAD_EIM_EB1__EPDC_SDSHR = IOMUX_PAD(0x0598, 0x01C8, 8, 0x0000, 0, 0), + MX6_PAD_EIM_EB2__WEIM_WEIM_EB_2 = IOMUX_PAD(0x059C, 0x01CC, 0, 0x0000, 0, 0), + MX6_PAD_EIM_EB2__ECSPI1_SS0 = IOMUX_PAD(0x059C, 0x01CC, 1, 0x07E4, 2, 0), + MX6_PAD_EIM_EB2__CCM_DI1_EXT_CLK = IOMUX_PAD(0x059C, 0x01CC, 2, 0x07D0, 1, 0), + MX6_PAD_EIM_EB2__IPU1_CSI1_D_19 = IOMUX_PAD(0x059C, 0x01CC, 3, 0x08AC, 1, 0), + MX6_PAD_EIM_EB2__HDMI_TX_DDC_SCL = IOMUX_PAD(0x059C, 0x01CC, 4, 0x0860, 0, 0), + MX6_PAD_EIM_EB2__GPIO_2_30 = IOMUX_PAD(0x059C, 0x01CC, 5, 0x0000, 0, 0), + MX6_PAD_EIM_EB2__I2C2_SCL = IOMUX_PAD(0x059C, 0x01CC, 6 | IOMUX_CONFIG_SION, 0x0870, 0, 0), + MX6_PAD_EIM_EB2__SRC_BT_CFG_30 = IOMUX_PAD(0x059C, 0x01CC, 7, 0x0000, 0, 0), + MX6_PAD_EIM_EB2__EPDC_SDDO_5 = IOMUX_PAD(0x059C, 0x01CC, 8, 0x0000, 0, 0), + MX6_PAD_EIM_EB3__WEIM_WEIM_EB_3 = IOMUX_PAD(0x05A0, 0x01D0, 0, 0x0000, 0, 0), + MX6_PAD_EIM_EB3__ECSPI4_RDY = IOMUX_PAD(0x05A0, 0x01D0, 1, 0x0000, 0, 0), + MX6_PAD_EIM_EB3__UART3_CTS = IOMUX_PAD(0x05A0, 0x01D0, 2, 0x0000, 0, 0), + MX6_PAD_EIM_EB3__UART3_RTS = IOMUX_PAD(0x05A0, 0x01D0, 2, 0x0908, 3, 0), + MX6_PAD_EIM_EB3__UART1_RI = IOMUX_PAD(0x05A0, 0x01D0, 3, 0x0000, 0, 0), + MX6_PAD_EIM_EB3__IPU1_CSI1_HSYNC = IOMUX_PAD(0x05A0, 0x01D0, 4, 0x08B4, 1, 0), + MX6_PAD_EIM_EB3__GPIO_2_31 = IOMUX_PAD(0x05A0, 0x01D0, 5, 0x0000, 0, 0), + MX6_PAD_EIM_EB3__IPU1_DI1_PIN3 = IOMUX_PAD(0x05A0, 0x01D0, 6, 0x0000, 0, 0), + MX6_PAD_EIM_EB3__SRC_BT_CFG_31 = IOMUX_PAD(0x05A0, 0x01D0, 7, 0x0000, 0, 0), + MX6_PAD_EIM_EB3__EPDC_SDCE_0 = IOMUX_PAD(0x05A0, 0x01D0, 8, 0x0000, 0, 0), + MX6_PAD_EIM_EB3__WEIM_ACLK_FREERUN = IOMUX_PAD(0x05A0, 0x01D0, 9, 0x0000, 0, 0), + MX6_PAD_EIM_LBA__WEIM_WEIM_LBA = IOMUX_PAD(0x05A4, 0x01D4, 0, 0x0000, 0, 0), + MX6_PAD_EIM_LBA__IPU1_DI1_PIN17 = IOMUX_PAD(0x05A4, 0x01D4, 1, 0x0000, 0, 0), + MX6_PAD_EIM_LBA__ECSPI2_SS1 = IOMUX_PAD(0x05A4, 0x01D4, 2, 0x0804, 1, 0), + MX6_PAD_EIM_LBA__GPIO_2_27 = IOMUX_PAD(0x05A4, 0x01D4, 5, 0x0000, 0, 0), + MX6_PAD_EIM_LBA__TPSMP_HDATA_11 = IOMUX_PAD(0x05A4, 0x01D4, 6, 0x0000, 0, 0), + MX6_PAD_EIM_LBA__SRC_BT_CFG_26 = IOMUX_PAD(0x05A4, 0x01D4, 7, 0x0000, 0, 0), + MX6_PAD_EIM_LBA__EPDC_SDDO_4 = IOMUX_PAD(0x05A4, 0x01D4, 8, 0x0000, 0, 0), + MX6_PAD_EIM_OE__WEIM_WEIM_OE = IOMUX_PAD(0x05A8, 0x01D8, 0, 0x0000, 0, 0), + MX6_PAD_EIM_OE__IPU1_DI1_PIN7 = IOMUX_PAD(0x05A8, 0x01D8, 1, 0x0000, 0, 0), + MX6_PAD_EIM_OE__ECSPI2_MISO = IOMUX_PAD(0x05A8, 0x01D8, 2, 0x07F8, 2, 0), + MX6_PAD_EIM_OE__MIPI_CORE_DPHY_TEST_OUT_26 = IOMUX_PAD(0x05A8, 0x01D8, 4, 0x0000, 0, 0), + MX6_PAD_EIM_OE__GPIO_2_25 = IOMUX_PAD(0x05A8, 0x01D8, 5, 0x0000, 0, 0), + MX6_PAD_EIM_OE__TPSMP_HDATA_9 = IOMUX_PAD(0x05A8, 0x01D8, 6, 0x0000, 0, 0), + MX6_PAD_EIM_OE__EPDC_PWRIRQ = IOMUX_PAD(0x05A8, 0x01D8, 8, 0x0000, 0, 0), + MX6_PAD_EIM_RW__WEIM_WEIM_RW = IOMUX_PAD(0x05AC, 0x01DC, 0, 0x0000, 0, 0), + MX6_PAD_EIM_RW__IPU1_DI1_PIN8 = IOMUX_PAD(0x05AC, 0x01DC, 1, 0x0000, 0, 0), + MX6_PAD_EIM_RW__ECSPI2_SS0 = IOMUX_PAD(0x05AC, 0x01DC, 2, 0x0800, 2, 0), + MX6_PAD_EIM_RW__MIPI_CORE_DPHY_TEST_OUT_27 = IOMUX_PAD(0x05AC, 0x01DC, 4, 0x0000, 0, 0), + MX6_PAD_EIM_RW__GPIO_2_26 = IOMUX_PAD(0x05AC, 0x01DC, 5, 0x0000, 0, 0), + MX6_PAD_EIM_RW__TPSMP_HDATA_10 = IOMUX_PAD(0x05AC, 0x01DC, 6, 0x0000, 0, 0), + MX6_PAD_EIM_RW__SRC_BT_CFG_29 = IOMUX_PAD(0x05AC, 0x01DC, 7, 0x0000, 0, 0), + MX6_PAD_EIM_RW__EPDC_SDDO_7 = IOMUX_PAD(0x05AC, 0x01DC, 8, 0x0000, 0, 0), + MX6_PAD_EIM_WAIT__WEIM_WEIM_WAIT = IOMUX_PAD(0x05B0, 0x01E0, 0, 0x0000, 0, 0), + MX6_PAD_EIM_WAIT__WEIM_WEIM_DTACK_B = IOMUX_PAD(0x05B0, 0x01E0, 1, 0x0000, 0, 0), + MX6_PAD_EIM_WAIT__GPIO_5_0 = IOMUX_PAD(0x05B0, 0x01E0, 5, 0x0000, 0, 0), + MX6_PAD_EIM_WAIT__TPSMP_HDATA_30 = IOMUX_PAD(0x05B0, 0x01E0, 6, 0x0000, 0, 0), + MX6_PAD_EIM_WAIT__SRC_BT_CFG_25 = IOMUX_PAD(0x05B0, 0x01E0, 7, 0x0000, 0, 0), + MX6_PAD_ENET_CRS_DV__ENET_RX_EN = IOMUX_PAD(0x05B4, 0x01E4, 1, 0x0828, 0, 0), + MX6_PAD_ENET_CRS_DV__ESAI1_SCKT = IOMUX_PAD(0x05B4, 0x01E4, 2, 0x0840, 0, 0), + MX6_PAD_ENET_CRS_DV__SPDIF_SPDIF_EXTCLK = IOMUX_PAD(0x05B4, 0x01E4, 3, 0x08F4, 0, 0), + MX6_PAD_ENET_CRS_DV__GPIO_1_25 = IOMUX_PAD(0x05B4, 0x01E4, 5, 0x0000, 0, 0), + MX6_PAD_ENET_CRS_DV__PHY_TDO = IOMUX_PAD(0x05B4, 0x01E4, 6, 0x0000, 0, 0), + MX6_PAD_ENET_CRS_DV__ANATOP_USBPHY1_TSTO_RX_FS_RXD = IOMUX_PAD(0x05B4, 0x01E4, 7, 0x0000, 0, 0), + MX6_PAD_ENET_MDC__MLB_MLBDAT = IOMUX_PAD(0x05B8, 0x01E8, 0, 0x08E0, 0, 0), MX6_PAD_ENET_MDC__ENET_MDC = IOMUX_PAD(0x05B8, 0x01E8, 1, 0x0000, 0, 0), + MX6_PAD_ENET_MDC__ESAI1_TX5_RX0 = IOMUX_PAD(0x05B8, 0x01E8, 2, 0x0858, 0, 0), + MX6_PAD_ENET_MDC__ENET_1588_EVENT1_IN = IOMUX_PAD(0x05B8, 0x01E8, 4, 0x0000, 0, 0), + MX6_PAD_ENET_MDC__GPIO_1_31 = IOMUX_PAD(0x05B8, 0x01E8, 5, 0x0000, 0, 0), + MX6_PAD_ENET_MDC__ANATOP_USBPHY2_TSTO_RX_DISCON_DET = IOMUX_PAD(0x05B8, 0x01E8, 7, 0x0000, 0, 0), MX6_PAD_ENET_MDIO__ENET_MDIO = IOMUX_PAD(0x05BC, 0x01EC, 1, 0x0810, 0, 0), + MX6_PAD_ENET_MDIO__ESAI1_SCKR = IOMUX_PAD(0x05BC, 0x01EC, 2, 0x083C, 0, 0), + MX6_PAD_ENET_MDIO__SDMA_DEBUG_BUS_DEVICE_3 = IOMUX_PAD(0x05BC, 0x01EC, 3, 0x0000, 0, 0), + MX6_PAD_ENET_MDIO__ENET_1588_EVENT1_OUT = IOMUX_PAD(0x05BC, 0x01EC, 4, 0x0000, 0, 0), + MX6_PAD_ENET_MDIO__GPIO_1_22 = IOMUX_PAD(0x05BC, 0x01EC, 5, 0x0000, 0, 0), + MX6_PAD_ENET_MDIO__SPDIF_PLOCK = IOMUX_PAD(0x05BC, 0x01EC, 6, 0x0000, 0, 0), MX6_PAD_ENET_REF_CLK__ENET_TX_CLK = IOMUX_PAD(0x05C0, 0x01F0, 1, 0x0000, 0, 0), + MX6_PAD_ENET_REF_CLK__ESAI1_FSR = IOMUX_PAD(0x05C0, 0x01F0, 2, 0x082C, 0, 0), + MX6_PAD_ENET_REF_CLK__SDMA_DEBUG_BUS_DEVICE_4 = IOMUX_PAD(0x05C0, 0x01F0, 3, 0x0000, 0, 0), + MX6_PAD_ENET_REF_CLK__GPIO_1_23 = IOMUX_PAD(0x05C0, 0x01F0, 5, 0x0000, 0, 0), + MX6_PAD_ENET_REF_CLK__SPDIF_SRCLK = IOMUX_PAD(0x05C0, 0x01F0, 6, 0x0000, 0, 0), + MX6_PAD_ENET_REF_CLK__ANATOP_USBPHY1_TSTO_RX_SQUELCH = IOMUX_PAD(0x05C0, 0x01F0, 7, 0x0000, 0, 0), + MX6_PAD_ENET_RX_ER__ANATOP_USBOTG_ID = IOMUX_PAD(0x05C4, 0x01F4, 0, 0x0790, 0, 0), + MX6_PAD_ENET_RX_ER__ENET_RX_ER = IOMUX_PAD(0x05C4, 0x01F4, 1, 0x0000, 0, 0), + MX6_PAD_ENET_RX_ER__ESAI1_HCKR = IOMUX_PAD(0x05C4, 0x01F4, 2, 0x0834, 0, 0), + MX6_PAD_ENET_RX_ER__SPDIF_IN1 = IOMUX_PAD(0x05C4, 0x01F4, 3, 0x08F0, 1, 0), + MX6_PAD_ENET_RX_ER__ENET_1588_EVENT2_OUT = IOMUX_PAD(0x05C4, 0x01F4, 4, 0x0000, 0, 0), + MX6_PAD_ENET_RX_ER__GPIO_1_24 = IOMUX_PAD(0x05C4, 0x01F4, 5, 0x0000, 0, 0), + MX6_PAD_ENET_RX_ER__PHY_TDI = IOMUX_PAD(0x05C4, 0x01F4, 6, 0x0000, 0, 0), + MX6_PAD_ENET_RX_ER__ANATOP_USBPHY1_TSTO_RX_HS_RXD = IOMUX_PAD(0x05C4, 0x01F4, 7, 0x0000, 0, 0), + MX6_PAD_ENET_RXD0__OSC32K_32K_OUT = IOMUX_PAD(0x05C8, 0x01F8, 0, 0x0000, 0, 0), + MX6_PAD_ENET_RXD0__ENET_RDATA_0 = IOMUX_PAD(0x05C8, 0x01F8, 1, 0x0818, 0, 0), + MX6_PAD_ENET_RXD0__ESAI1_HCKT = IOMUX_PAD(0x05C8, 0x01F8, 2, 0x0838, 0, 0), + MX6_PAD_ENET_RXD0__SPDIF_OUT1 = IOMUX_PAD(0x05C8, 0x01F8, 3, 0x0000, 0, 0), MX6_PAD_ENET_RXD0__GPIO_1_27 = IOMUX_PAD(0x05C8, 0x01F8, 5, 0x0000, 0, 0), + MX6_PAD_ENET_RXD0__PHY_TMS = IOMUX_PAD(0x05C8, 0x01F8, 6, 0x0000, 0, 0), + MX6_PAD_ENET_RXD0__ANATOP_USBPHY1_TSTO_PLL_CLK20DIV = IOMUX_PAD(0x05C8, 0x01F8, 7, 0x0000, 0, 0), + MX6_PAD_ENET_RXD1__MLB_MLBSIG = IOMUX_PAD(0x05CC, 0x01FC, 0, 0x08E4, 0, 0), + MX6_PAD_ENET_RXD1__ENET_RDATA_1 = IOMUX_PAD(0x05CC, 0x01FC, 1, 0x081C, 0, 0), + MX6_PAD_ENET_RXD1__ESAI1_FST = IOMUX_PAD(0x05CC, 0x01FC, 2, 0x0830, 0, 0), + MX6_PAD_ENET_RXD1__ENET_1588_EVENT3_OUT = IOMUX_PAD(0x05CC, 0x01FC, 4, 0x0000, 0, 0), + MX6_PAD_ENET_RXD1__GPIO_1_26 = IOMUX_PAD(0x05CC, 0x01FC, 5, 0x0000, 0, 0), + MX6_PAD_ENET_RXD1__PHY_TCK = IOMUX_PAD(0x05CC, 0x01FC, 6, 0x0000, 0, 0), + MX6_PAD_ENET_RXD1__ANATOP_USBPHY1_TSTO_RX_DISCON_DET = IOMUX_PAD(0x05CC, 0x01FC, 7, 0x0000, 0, 0), + MX6_PAD_ENET_TX_EN__ENET_TX_EN = IOMUX_PAD(0x05D0, 0x0200, 1, 0x0000, 0, 0), + MX6_PAD_ENET_TX_EN__ESAI1_TX3_RX2 = IOMUX_PAD(0x05D0, 0x0200, 2, 0x0850, 0, 0), + MX6_PAD_ENET_TX_EN__GPIO_1_28 = IOMUX_PAD(0x05D0, 0x0200, 5, 0x0000, 0, 0), + MX6_PAD_ENET_TX_EN__ANATOP_USBPHY2_TSTO_RX_SQUELCH = IOMUX_PAD(0x05D0, 0x0200, 7, 0x0000, 0, 0), + MX6_PAD_ENET_TX_EN__I2C4_SCL = IOMUX_PAD(0x05D0, 0x0200, 9 | IOMUX_CONFIG_SION, 0x0880, 0, 0), + MX6_PAD_ENET_TXD0__ENET_TDATA_0 = IOMUX_PAD(0x05D4, 0x0204, 1, 0x0000, 0, 0), + MX6_PAD_ENET_TXD0__ESAI1_TX4_RX1 = IOMUX_PAD(0x05D4, 0x0204, 2, 0x0854, 0, 0), + MX6_PAD_ENET_TXD0__GPIO_1_30 = IOMUX_PAD(0x05D4, 0x0204, 5, 0x0000, 0, 0), + MX6_PAD_ENET_TXD0__ANATOP_USBPHY2_TSTO_RX_FS_RXD = IOMUX_PAD(0x05D4, 0x0204, 7, 0x0000, 0, 0), + MX6_PAD_ENET_TXD1__MLB_MLBCLK = IOMUX_PAD(0x05D8, 0x0208, 0, 0x08DC, 0, 0), + MX6_PAD_ENET_TXD1__ENET_TDATA_1 = IOMUX_PAD(0x05D8, 0x0208, 1, 0x0000, 0, 0), + MX6_PAD_ENET_TXD1__ESAI1_TX2_RX3 = IOMUX_PAD(0x05D8, 0x0208, 2, 0x084C, 0, 0), + MX6_PAD_ENET_TXD1__ENET_1588_EVENT0_IN = IOMUX_PAD(0x05D8, 0x0208, 4, 0x0000, 0, 0), + MX6_PAD_ENET_TXD1__GPIO_1_29 = IOMUX_PAD(0x05D8, 0x0208, 5, 0x0000, 0, 0), + MX6_PAD_ENET_TXD1__ANATOP_USBPHY2_TSTO_RX_HS_RXD = IOMUX_PAD(0x05D8, 0x0208, 7, 0x0000, 0, 0), + MX6_PAD_ENET_TXD1__I2C4_SDA = IOMUX_PAD(0x05D8, 0x0208, 9 | IOMUX_CONFIG_SION, 0x0884, 0, 0), + MX6_PAD_GPIO_0__CCM_CLKO = IOMUX_PAD(0x05DC, 0x020C, 0, 0x0000, 0, 0), + MX6_PAD_GPIO_0__KPP_COL_5 = IOMUX_PAD(0x05DC, 0x020C, 2, 0x08C0, 1, 0), + MX6_PAD_GPIO_0__ASRC_ASRC_EXT_CLK = IOMUX_PAD(0x05DC, 0x020C, 3, 0x0794, 0, 0), + MX6_PAD_GPIO_0__EPIT1_EPITO = IOMUX_PAD(0x05DC, 0x020C, 4, 0x0000, 0, 0), + MX6_PAD_GPIO_0__GPIO_1_0 = IOMUX_PAD(0x05DC, 0x020C, 5, 0x0000, 0, 0), + MX6_PAD_GPIO_0__USBOH3_USBH1_PWR = IOMUX_PAD(0x05DC, 0x020C, 6, 0x0000, 0, 0), + MX6_PAD_GPIO_0__SNVS_HP_WRAPPER_SNVS_VIO_5 = IOMUX_PAD(0x05DC, 0x020C, 7, 0x0000, 0, 0), + MX6_PAD_GPIO_1__ESAI1_SCKR = IOMUX_PAD(0x05E0, 0x0210, 0, 0x083C, 1, 0), + MX6_PAD_GPIO_1__WDOG2_WDOG_B = IOMUX_PAD(0x05E0, 0x0210, 1, 0x0000, 0, 0), + MX6_PAD_GPIO_1__KPP_ROW_5 = IOMUX_PAD(0x05E0, 0x0210, 2, 0x08CC, 1, 0), + MX6_PAD_GPIO_1__USBOTG_ID = IOMUX_PAD(0x05E0, 0x0210, 3, 0x0790, 1, 0), + MX6_PAD_GPIO_1__PWM2_PWMO = IOMUX_PAD(0x05E0, 0x0210, 4, 0x0000, 0, 0), + MX6_PAD_GPIO_1__GPIO_1_1 = IOMUX_PAD(0x05E0, 0x0210, 5, 0x0000, 0, 0), + MX6_PAD_GPIO_1__USDHC1_CD = IOMUX_PAD(0x05E0, 0x0210, 6, 0x0000, 0, 0), + MX6_PAD_GPIO_1__SRC_TESTER_ACK = IOMUX_PAD(0x05E0, 0x0210, 7, 0x0000, 0, 0), + MX6_PAD_GPIO_16__ESAI1_TX3_RX2 = IOMUX_PAD(0x05E4, 0x0214, 0, 0x0850, 1, 0), + MX6_PAD_GPIO_16__ENET_1588_EVENT2_IN = IOMUX_PAD(0x05E4, 0x0214, 1, 0x0000, 0, 0), + MX6_PAD_GPIO_16__ENET_ANATOP_ETHERNET_REF_OUT = IOMUX_PAD(0x05E4, 0x0214, 2, 0x080C, 0, 0), + MX6_PAD_GPIO_16__USDHC1_LCTL = IOMUX_PAD(0x05E4, 0x0214, 3, 0x0000, 0, 0), + MX6_PAD_GPIO_16__SPDIF_IN1 = IOMUX_PAD(0x05E4, 0x0214, 4, 0x08F0, 2, 0), MX6_PAD_GPIO_16__GPIO_7_11 = IOMUX_PAD(0x05E4, 0x0214, 5, 0x0000, 0, 0), MX6_PAD_GPIO_16__I2C3_SDA = IOMUX_PAD(0x05E4, 0x0214, 6 | IOMUX_CONFIG_SION, 0x087C, 1, 0), + MX6_PAD_GPIO_16__SJC_DE_B = IOMUX_PAD(0x05E4, 0x0214, 7, 0x0000, 0, 0), + MX6_PAD_GPIO_17__ESAI1_TX0 = IOMUX_PAD(0x05E8, 0x0218, 0, 0x0844, 0, 0), + MX6_PAD_GPIO_17__ENET_1588_EVENT3_IN = IOMUX_PAD(0x05E8, 0x0218, 1, 0x0000, 0, 0), + MX6_PAD_GPIO_17__CCM_PMIC_RDY = IOMUX_PAD(0x05E8, 0x0218, 2, 0x07D4, 1, 0), + MX6_PAD_GPIO_17__SDMA_SDMA_EXT_EVENT_0 = IOMUX_PAD(0x05E8, 0x0218, 3, 0x08E8, 1, 0), + MX6_PAD_GPIO_17__SPDIF_OUT1 = IOMUX_PAD(0x05E8, 0x0218, 4, 0x0000, 0, 0), MX6_PAD_GPIO_17__GPIO_7_12 = IOMUX_PAD(0x05E8, 0x0218, 5, 0x0000, 0, 0), + MX6_PAD_GPIO_17__SJC_JTAG_ACT = IOMUX_PAD(0x05E8, 0x0218, 7, 0x0000, 0, 0), + MX6_PAD_GPIO_18__ESAI1_TX1 = IOMUX_PAD(0x05EC, 0x021C, 0, 0x0848, 0, 0), + MX6_PAD_GPIO_18__ENET_RX_CLK = IOMUX_PAD(0x05EC, 0x021C, 1, 0x0814, 0, 0), + MX6_PAD_GPIO_18__USDHC3_VSELECT = IOMUX_PAD(0x05EC, 0x021C, 2, 0x0000, 0, 0), + MX6_PAD_GPIO_18__SDMA_SDMA_EXT_EVENT_1 = IOMUX_PAD(0x05EC, 0x021C, 3, 0x08EC, 1, 0), + MX6_PAD_GPIO_18__ASRC_ASRC_EXT_CLK = IOMUX_PAD(0x05EC, 0x021C, 4, 0x0794, 1, 0), MX6_PAD_GPIO_18__GPIO_7_13 = IOMUX_PAD(0x05EC, 0x021C, 5, 0x0000, 0, 0), + MX6_PAD_GPIO_18__SNVS_HP_WRAPPER_SNVS_VIO_5_CTL = IOMUX_PAD(0x05EC, 0x021C, 6, 0x0000, 0, 0), + MX6_PAD_GPIO_18__SRC_SYSTEM_RST = IOMUX_PAD(0x05EC, 0x021C, 7, 0x0000, 0, 0), + MX6_PAD_GPIO_19__KPP_COL_5 = IOMUX_PAD(0x05F0, 0x0220, 0, 0x08C0, 2, 0), + MX6_PAD_GPIO_19__ENET_1588_EVENT0_OUT = IOMUX_PAD(0x05F0, 0x0220, 1, 0x0000, 0, 0), + MX6_PAD_GPIO_19__SPDIF_OUT1 = IOMUX_PAD(0x05F0, 0x0220, 2, 0x0000, 0, 0), + MX6_PAD_GPIO_19__CCM_CLKO = IOMUX_PAD(0x05F0, 0x0220, 3, 0x0000, 0, 0), + MX6_PAD_GPIO_19__ECSPI1_RDY = IOMUX_PAD(0x05F0, 0x0220, 4, 0x0000, 0, 0), MX6_PAD_GPIO_19__GPIO_4_5 = IOMUX_PAD(0x05F0, 0x0220, 5, 0x0000, 0, 0), + MX6_PAD_GPIO_19__ENET_TX_ER = IOMUX_PAD(0x05F0, 0x0220, 6, 0x0000, 0, 0), + MX6_PAD_GPIO_19__SRC_INT_BOOT = IOMUX_PAD(0x05F0, 0x0220, 7, 0x0000, 0, 0), + MX6_PAD_GPIO_2__ESAI1_FST = IOMUX_PAD(0x05F4, 0x0224, 0, 0x0830, 1, 0), + MX6_PAD_GPIO_2__OBSERVE_MUX_OBSRV_INT_OUT2 = IOMUX_PAD(0x05F4, 0x0224, 1, 0x0000, 0, 0), + MX6_PAD_GPIO_2__KPP_ROW_6 = IOMUX_PAD(0x05F4, 0x0224, 2, 0x08D0, 1, 0), + MX6_PAD_GPIO_2__CCM_CCM_OUT_1 = IOMUX_PAD(0x05F4, 0x0224, 3, 0x0000, 0, 0), + MX6_PAD_GPIO_2__CSU_CSU_ALARM_AUT_0 = IOMUX_PAD(0x05F4, 0x0224, 4, 0x0000, 0, 0), + MX6_PAD_GPIO_2__GPIO_1_2 = IOMUX_PAD(0x05F4, 0x0224, 5, 0x0000, 0, 0), + MX6_PAD_GPIO_2__USDHC2_WP = IOMUX_PAD(0x05F4, 0x0224, 6, 0x0000, 0, 0), + MX6_PAD_GPIO_2__MLB_MLBDAT = IOMUX_PAD(0x05F4, 0x0224, 7, 0x08E0, 1, 0), + MX6_PAD_GPIO_3__ESAI1_HCKR = IOMUX_PAD(0x05F8, 0x0228, 0, 0x0834, 1, 0), + MX6_PAD_GPIO_3__OBSERVE_MUX_OBSRV_INT_OUT0 = IOMUX_PAD(0x05F8, 0x0228, 1, 0x0000, 0, 0), + MX6_PAD_GPIO_3__I2C3_SCL = IOMUX_PAD(0x05F8, 0x0228, 2 | IOMUX_CONFIG_SION, 0x0878, 1, 0), + MX6_PAD_GPIO_3__ANATOP_ANATOP_24M_OUT = IOMUX_PAD(0x05F8, 0x0228, 3, 0x0000, 0, 0), + MX6_PAD_GPIO_3__CCM_CLKO2 = IOMUX_PAD(0x05F8, 0x0228, 4, 0x0000, 0, 0), + MX6_PAD_GPIO_3__GPIO_1_3 = IOMUX_PAD(0x05F8, 0x0228, 5, 0x0000, 0, 0), + MX6_PAD_GPIO_3__USBOH3_USBH1_OC = IOMUX_PAD(0x05F8, 0x0228, 6, 0x0924, 1, 0), + MX6_PAD_GPIO_3__MLB_MLBCLK = IOMUX_PAD(0x05F8, 0x0228, 7, 0x08DC, 1, 0), + MX6_PAD_GPIO_4__ESAI1_HCKT = IOMUX_PAD(0x05FC, 0x022C, 0, 0x0838, 1, 0), + MX6_PAD_GPIO_4__OBSERVE_MUX_OBSRV_INT_OUT3 = IOMUX_PAD(0x05FC, 0x022C, 1, 0x0000, 0, 0), + MX6_PAD_GPIO_4__KPP_COL_7 = IOMUX_PAD(0x05FC, 0x022C, 2, 0x08C8, 1, 0), + MX6_PAD_GPIO_4__CCM_CCM_OUT_2 = IOMUX_PAD(0x05FC, 0x022C, 3, 0x0000, 0, 0), + MX6_PAD_GPIO_4__CSU_CSU_ALARM_AUT_1 = IOMUX_PAD(0x05FC, 0x022C, 4, 0x0000, 0, 0), + MX6_PAD_GPIO_4__GPIO_1_4 = IOMUX_PAD(0x05FC, 0x022C, 5, 0x0000, 0, 0), + MX6_PAD_GPIO_4__USDHC2_CD = IOMUX_PAD(0x05FC, 0x022C, 6, 0x0000, 0, 0), + MX6_PAD_GPIO_4__OCOTP_CTRL_WRAPPER_FUSE_LATCHED = IOMUX_PAD(0x05FC, 0x022C, 7, 0x0000, 0, 0), + MX6_PAD_GPIO_5__ESAI1_TX2_RX3 = IOMUX_PAD(0x0600, 0x0230, 0, 0x084C, 1, 0), + MX6_PAD_GPIO_5__OBSERVE_MUX_OBSRV_INT_OUT4 = IOMUX_PAD(0x0600, 0x0230, 1, 0x0000, 0, 0), + MX6_PAD_GPIO_5__KPP_ROW_7 = IOMUX_PAD(0x0600, 0x0230, 2, 0x08D4, 1, 0), + MX6_PAD_GPIO_5__CCM_CLKO = IOMUX_PAD(0x0600, 0x0230, 3, 0x0000, 0, 0), + MX6_PAD_GPIO_5__CSU_CSU_ALARM_AUT_2 = IOMUX_PAD(0x0600, 0x0230, 4, 0x0000, 0, 0), MX6_PAD_GPIO_5__GPIO_1_5 = IOMUX_PAD(0x0600, 0x0230, 5, 0x0000, 0, 0), MX6_PAD_GPIO_5__I2C3_SCL = IOMUX_PAD(0x0600, 0x0230, 6 | IOMUX_CONFIG_SION, 0x0878, 2, 0), + MX6_PAD_GPIO_5__SIMBA_EVENTI = IOMUX_PAD(0x0600, 0x0230, 7, 0x0000, 0, 0), + MX6_PAD_GPIO_6__ESAI1_SCKT = IOMUX_PAD(0x0604, 0x0234, 0, 0x0840, 1, 0), + MX6_PAD_GPIO_6__OBSERVE_MUX_OBSRV_INT_OUT1 = IOMUX_PAD(0x0604, 0x0234, 1, 0x0000, 0, 0), + MX6_PAD_GPIO_6__I2C3_SDA = IOMUX_PAD(0x0604, 0x0234, 2 | IOMUX_CONFIG_SION, 0x087C, 2, 0), + MX6_PAD_GPIO_6__CCM_CCM_OUT_0 = IOMUX_PAD(0x0604, 0x0234, 3, 0x0000, 0, 0), + MX6_PAD_GPIO_6__CSU_CSU_INT_DEB = IOMUX_PAD(0x0604, 0x0234, 4, 0x0000, 0, 0), + MX6_PAD_GPIO_6__GPIO_1_6 = IOMUX_PAD(0x0604, 0x0234, 5, 0x0000, 0, 0), + MX6_PAD_GPIO_6__USDHC2_LCTL = IOMUX_PAD(0x0604, 0x0234, 6, 0x0000, 0, 0), + MX6_PAD_GPIO_6__MLB_MLBSIG = IOMUX_PAD(0x0604, 0x0234, 7, 0x08E4, 1, 0), + MX6_PAD_GPIO_7__ESAI1_TX4_RX1 = IOMUX_PAD(0x0608, 0x0238, 0, 0x0854, 1, 0), + MX6_PAD_GPIO_7__EPIT1_EPITO = IOMUX_PAD(0x0608, 0x0238, 2, 0x0000, 0, 0), + MX6_PAD_GPIO_7__CAN1_TXCAN = IOMUX_PAD(0x0608, 0x0238, 3, 0x0000, 0, 0), + MX6_PAD_GPIO_7__UART2_TXD = IOMUX_PAD(0x0608, 0x0238, 4, 0x0000, 0, 0), + MX6_PAD_GPIO_7__UART2_RXD = IOMUX_PAD(0x0608, 0x0238, 4, 0x0904, 2, 0), + MX6_PAD_GPIO_7__GPIO_1_7 = IOMUX_PAD(0x0608, 0x0238, 5, 0x0000, 0, 0), + MX6_PAD_GPIO_7__SPDIF_PLOCK = IOMUX_PAD(0x0608, 0x0238, 6, 0x0000, 0, 0), + MX6_PAD_GPIO_7__USBOH3_OTGUSB_HOST_MODE = IOMUX_PAD(0x0608, 0x0238, 7, 0x0000, 0, 0), + MX6_PAD_GPIO_7__I2C4_SCL = IOMUX_PAD(0x0608, 0x0238, 8 | IOMUX_CONFIG_SION, 0x0880, 1, 0), + MX6_PAD_GPIO_8__ESAI1_TX5_RX0 = IOMUX_PAD(0x060C, 0x023C, 0, 0x0858, 1, 0), + MX6_PAD_GPIO_8__ANATOP_ANATOP_32K_OUT = IOMUX_PAD(0x060C, 0x023C, 1, 0x0000, 0, 0), + MX6_PAD_GPIO_8__EPIT2_EPITO = IOMUX_PAD(0x060C, 0x023C, 2, 0x0000, 0, 0), + MX6_PAD_GPIO_8__CAN1_RXCAN = IOMUX_PAD(0x060C, 0x023C, 3, 0x07C8, 0, 0), + MX6_PAD_GPIO_8__UART2_TXD = IOMUX_PAD(0x060C, 0x023C, 4, 0x0000, 0, 0), + MX6_PAD_GPIO_8__UART2_RXD = IOMUX_PAD(0x060C, 0x023C, 4, 0x0904, 3, 0), + MX6_PAD_GPIO_8__GPIO_1_8 = IOMUX_PAD(0x060C, 0x023C, 5, 0x0000, 0, 0), + MX6_PAD_GPIO_8__SPDIF_SRCLK = IOMUX_PAD(0x060C, 0x023C, 6, 0x0000, 0, 0), + MX6_PAD_GPIO_8__USBOH3_OTGUSB_PWRCTL_WAKEUP = IOMUX_PAD(0x060C, 0x023C, 7, 0x0000, 0, 0), + MX6_PAD_GPIO_8__I2C4_SDA = IOMUX_PAD(0x060C, 0x023C, 8 | IOMUX_CONFIG_SION, 0x0884, 1, 0), + MX6_PAD_GPIO_9__ESAI1_FSR = IOMUX_PAD(0x0610, 0x0240, 0, 0x082C, 1, 0), + MX6_PAD_GPIO_9__WDOG1_WDOG_B = IOMUX_PAD(0x0610, 0x0240, 1, 0x0000, 0, 0), + MX6_PAD_GPIO_9__KPP_COL_6 = IOMUX_PAD(0x0610, 0x0240, 2, 0x08C4, 1, 0), + MX6_PAD_GPIO_9__CCM_REF_EN_B = IOMUX_PAD(0x0610, 0x0240, 3, 0x0000, 0, 0), + MX6_PAD_GPIO_9__PWM1_PWMO = IOMUX_PAD(0x0610, 0x0240, 4, 0x0000, 0, 0), + MX6_PAD_GPIO_9__GPIO_1_9 = IOMUX_PAD(0x0610, 0x0240, 5, 0x0000, 0, 0), + MX6_PAD_GPIO_9__USDHC1_WP = IOMUX_PAD(0x0610, 0x0240, 6, 0x092C, 1, 0), + MX6_PAD_GPIO_9__SRC_EARLY_RST = IOMUX_PAD(0x0610, 0x0240, 7, 0x0000, 0, 0), + MX6_PAD_JTAG_MOD__SJC_MOD = IOMUX_PAD(0x0614, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_JTAG_TCK__SJC_TCK = IOMUX_PAD(0x0618, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_JTAG_TDI__SJC_TDI = IOMUX_PAD(0x061C, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_JTAG_TDO__SJC_TDO = IOMUX_PAD(0x0620, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_JTAG_TMS__SJC_TMS = IOMUX_PAD(0x0624, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_JTAG_TRSTB__SJC_TRSTB = IOMUX_PAD(0x0628, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_KEY_COL0__ECSPI1_SCLK = IOMUX_PAD(0x062C, 0x0244, 0, 0x07D8, 3, 0), + MX6_PAD_KEY_COL0__ENET_RDATA_3 = IOMUX_PAD(0x062C, 0x0244, 1, 0x0824, 0, 0), + MX6_PAD_KEY_COL0__AUDMUX_AUD5_TXC = IOMUX_PAD(0x062C, 0x0244, 2, 0x07C0, 1, 0), + MX6_PAD_KEY_COL0__KPP_COL_0 = IOMUX_PAD(0x062C, 0x0244, 3, 0x0000, 0, 0), + MX6_PAD_KEY_COL0__UART4_TXD = IOMUX_PAD(0x062C, 0x0244, 4, 0x0000, 0, 0), + MX6_PAD_KEY_COL0__UART4_RXD = IOMUX_PAD(0x062C, 0x0244, 4, 0x0914, 2, 0), + MX6_PAD_KEY_COL0__GPIO_4_6 = IOMUX_PAD(0x062C, 0x0244, 5, 0x0000, 0, 0), + MX6_PAD_KEY_COL0__DCIC1_DCIC_OUT = IOMUX_PAD(0x062C, 0x0244, 6, 0x0000, 0, 0), + MX6_PAD_KEY_COL0__SRC_ANY_PU_RST = IOMUX_PAD(0x062C, 0x0244, 7, 0x0000, 0, 0), + MX6_PAD_KEY_COL1__ECSPI1_MISO = IOMUX_PAD(0x0630, 0x0248, 0, 0x07DC, 3, 0), + MX6_PAD_KEY_COL1__ENET_MDIO = IOMUX_PAD(0x0630, 0x0248, 1, 0x0810, 1, 0), + MX6_PAD_KEY_COL1__AUDMUX_AUD5_TXFS = IOMUX_PAD(0x0630, 0x0248, 2, 0x07C4, 1, 0), + MX6_PAD_KEY_COL1__KPP_COL_1 = IOMUX_PAD(0x0630, 0x0248, 3, 0x0000, 0, 0), + MX6_PAD_KEY_COL1__UART5_TXD = IOMUX_PAD(0x0630, 0x0248, 4, 0x0000, 0, 0), + MX6_PAD_KEY_COL1__UART5_RXD = IOMUX_PAD(0x0630, 0x0248, 4, 0x091C, 2, 0), + MX6_PAD_KEY_COL1__GPIO_4_8 = IOMUX_PAD(0x0630, 0x0248, 5, 0x0000, 0, 0), + MX6_PAD_KEY_COL1__USDHC1_VSELECT = IOMUX_PAD(0x0630, 0x0248, 6, 0x0000, 0, 0), + MX6_PAD_KEY_COL1__PL301_SIM_MX6DL_PER1_HADDR_1 = IOMUX_PAD(0x0630, 0x0248, 7, 0x0000, 0, 0), + MX6_PAD_KEY_COL2__ECSPI1_SS1 = IOMUX_PAD(0x0634, 0x024C, 0, 0x07E8, 2, 0), + MX6_PAD_KEY_COL2__ENET_RDATA_2 = IOMUX_PAD(0x0634, 0x024C, 1, 0x0820, 0, 0), + MX6_PAD_KEY_COL2__CAN1_TXCAN = IOMUX_PAD(0x0634, 0x024C, 2, 0x0000, 0, 0), + MX6_PAD_KEY_COL2__KPP_COL_2 = IOMUX_PAD(0x0634, 0x024C, 3, 0x0000, 0, 0), + MX6_PAD_KEY_COL2__ENET_MDC = IOMUX_PAD(0x0634, 0x024C, 4, 0x0000, 0, 0), + MX6_PAD_KEY_COL2__GPIO_4_10 = IOMUX_PAD(0x0634, 0x024C, 5, 0x0000, 0, 0), + MX6_PAD_KEY_COL2__USBOH3_H1USB_PWRCTL_WAKEUP = IOMUX_PAD(0x0634, 0x024C, 6, 0x0000, 0, 0), + MX6_PAD_KEY_COL2__PL301_SIM_MX6DL_PER1_HADDR_3 = IOMUX_PAD(0x0634, 0x024C, 7, 0x0000, 0, 0), + MX6_PAD_KEY_COL3__ECSPI1_SS3 = IOMUX_PAD(0x0638, 0x0250, 0, 0x07F0, 1, 0), + MX6_PAD_KEY_COL3__ENET_CRS = IOMUX_PAD(0x0638, 0x0250, 1, 0x0000, 0, 0), + MX6_PAD_KEY_COL3__HDMI_TX_DDC_SCL = IOMUX_PAD(0x0638, 0x0250, 2, 0x0860, 1, 0), + MX6_PAD_KEY_COL3__KPP_COL_3 = IOMUX_PAD(0x0638, 0x0250, 3, 0x0000, 0, 0), MX6_PAD_KEY_COL3__I2C2_SCL = IOMUX_PAD(0x0638, 0x0250, 4 | IOMUX_CONFIG_SION, 0x0870, 1, 0), MX6_PAD_KEY_COL3__GPIO_4_12 = IOMUX_PAD(0x0638, 0x0250, 5, 0x0000, 0, 0), + MX6_PAD_KEY_COL3__SPDIF_IN1 = IOMUX_PAD(0x0638, 0x0250, 6, 0x08F0, 3, 0), + MX6_PAD_KEY_COL3__PL301_SIM_MX6DL_PER1_HADDR_5 = IOMUX_PAD(0x0638, 0x0250, 7, 0x0000, 0, 0), + MX6_PAD_KEY_COL4__CAN2_TXCAN = IOMUX_PAD(0x063C, 0x0254, 0, 0x0000, 0, 0), + MX6_PAD_KEY_COL4__IPU1_SISG_4 = IOMUX_PAD(0x063C, 0x0254, 1, 0x0000, 0, 0), + MX6_PAD_KEY_COL4__USBOH3_USBOTG_OC = IOMUX_PAD(0x063C, 0x0254, 2, 0x0920, 1, 0), + MX6_PAD_KEY_COL4__KPP_COL_4 = IOMUX_PAD(0x063C, 0x0254, 3, 0x0000, 0, 0), + MX6_PAD_KEY_COL4__UART5_CTS = IOMUX_PAD(0x063C, 0x0254, 4, 0x0000, 0, 0), + MX6_PAD_KEY_COL4__UART5_RTS = IOMUX_PAD(0x063C, 0x0254, 4, 0x0918, 2, 0), + MX6_PAD_KEY_COL4__GPIO_4_14 = IOMUX_PAD(0x063C, 0x0254, 5, 0x0000, 0, 0), + MX6_PAD_KEY_COL4__MMDC_MMDC_DEBUG_49 = IOMUX_PAD(0x063C, 0x0254, 6, 0x0000, 0, 0), + MX6_PAD_KEY_COL4__PL301_SIM_MX6DL_PER1_HADDR_7 = IOMUX_PAD(0x063C, 0x0254, 7, 0x0000, 0, 0), + MX6_PAD_KEY_ROW0__ECSPI1_MOSI = IOMUX_PAD(0x0640, 0x0258, 0, 0x07E0, 3, 0), + MX6_PAD_KEY_ROW0__ENET_TDATA_3 = IOMUX_PAD(0x0640, 0x0258, 1, 0x0000, 0, 0), + MX6_PAD_KEY_ROW0__AUDMUX_AUD5_TXD = IOMUX_PAD(0x0640, 0x0258, 2, 0x07B4, 1, 0), + MX6_PAD_KEY_ROW0__KPP_ROW_0 = IOMUX_PAD(0x0640, 0x0258, 3, 0x0000, 0, 0), + MX6_PAD_KEY_ROW0__UART4_TXD = IOMUX_PAD(0x0640, 0x0258, 4, 0x0000, 0, 0), + MX6_PAD_KEY_ROW0__UART4_RXD = IOMUX_PAD(0x0640, 0x0258, 4, 0x0914, 3, 0), + MX6_PAD_KEY_ROW0__GPIO_4_7 = IOMUX_PAD(0x0640, 0x0258, 5, 0x0000, 0, 0), + MX6_PAD_KEY_ROW0__DCIC2_DCIC_OUT = IOMUX_PAD(0x0640, 0x0258, 6, 0x0000, 0, 0), + MX6_PAD_KEY_ROW0__PL301_SIM_MX6DL_PER1_HADDR_0 = IOMUX_PAD(0x0640, 0x0258, 7, 0x0000, 0, 0), + MX6_PAD_KEY_ROW1__ECSPI1_SS0 = IOMUX_PAD(0x0644, 0x025C, 0, 0x07E4, 3, 0), + MX6_PAD_KEY_ROW1__ENET_COL = IOMUX_PAD(0x0644, 0x025C, 1, 0x0000, 0, 0), + MX6_PAD_KEY_ROW1__AUDMUX_AUD5_RXD = IOMUX_PAD(0x0644, 0x025C, 2, 0x07B0, 1, 0), + MX6_PAD_KEY_ROW1__KPP_ROW_1 = IOMUX_PAD(0x0644, 0x025C, 3, 0x0000, 0, 0), + MX6_PAD_KEY_ROW1__UART5_TXD = IOMUX_PAD(0x0644, 0x025C, 4, 0x0000, 0, 0), + MX6_PAD_KEY_ROW1__UART5_RXD = IOMUX_PAD(0x0644, 0x025C, 4, 0x091C, 3, 0), + MX6_PAD_KEY_ROW1__GPIO_4_9 = IOMUX_PAD(0x0644, 0x025C, 5, 0x0000, 0, 0), + MX6_PAD_KEY_ROW1__USDHC2_VSELECT = IOMUX_PAD(0x0644, 0x025C, 6, 0x0000, 0, 0), + MX6_PAD_KEY_ROW1__PL301_SIM_MX6DL_PER1_HADDR_2 = IOMUX_PAD(0x0644, 0x025C, 7, 0x0000, 0, 0), + MX6_PAD_KEY_ROW2__ECSPI1_SS2 = IOMUX_PAD(0x0648, 0x0260, 0, 0x07EC, 1, 0), + MX6_PAD_KEY_ROW2__ENET_TDATA_2 = IOMUX_PAD(0x0648, 0x0260, 1, 0x0000, 0, 0), + MX6_PAD_KEY_ROW2__CAN1_RXCAN = IOMUX_PAD(0x0648, 0x0260, 2, 0x07C8, 1, 0), + MX6_PAD_KEY_ROW2__KPP_ROW_2 = IOMUX_PAD(0x0648, 0x0260, 3, 0x0000, 0, 0), + MX6_PAD_KEY_ROW2__USDHC2_VSELECT = IOMUX_PAD(0x0648, 0x0260, 4, 0x0000, 0, 0), + MX6_PAD_KEY_ROW2__GPIO_4_11 = IOMUX_PAD(0x0648, 0x0260, 5, 0x0000, 0, 0), + MX6_PAD_KEY_ROW2__HDMI_TX_CEC_LINE = IOMUX_PAD(0x0648, 0x0260, 6, 0x085C, 1, 0), + MX6_PAD_KEY_ROW2__PL301_SIM_MX6DL_PER1_HADDR_4 = IOMUX_PAD(0x0648, 0x0260, 7, 0x0000, 0, 0), + MX6_PAD_KEY_ROW3__OSC32K_32K_OUT = IOMUX_PAD(0x064C, 0x0264, 0, 0x0000, 0, 0), + MX6_PAD_KEY_ROW3__ASRC_ASRC_EXT_CLK = IOMUX_PAD(0x064C, 0x0264, 1, 0x0794, 2, 0), + MX6_PAD_KEY_ROW3__HDMI_TX_DDC_SDA = IOMUX_PAD(0x064C, 0x0264, 2, 0x0864, 1, 0), + MX6_PAD_KEY_ROW3__KPP_ROW_3 = IOMUX_PAD(0x064C, 0x0264, 3, 0x0000, 0, 0), MX6_PAD_KEY_ROW3__I2C2_SDA = IOMUX_PAD(0x064C, 0x0264, 4 | IOMUX_CONFIG_SION, 0x0874, 1, 0), MX6_PAD_KEY_ROW3__GPIO_4_13 = IOMUX_PAD(0x064C, 0x0264, 5, 0x0000, 0, 0), + MX6_PAD_KEY_ROW3__USDHC1_VSELECT = IOMUX_PAD(0x064C, 0x0264, 6, 0x0000, 0, 0), + MX6_PAD_KEY_ROW3__PL301_SIM_MX6DL_PER1_HADDR_6 = IOMUX_PAD(0x064C, 0x0264, 7, 0x0000, 0, 0), + MX6_PAD_KEY_ROW4__CAN2_RXCAN = IOMUX_PAD(0x0650, 0x0268, 0, 0x07CC, 0, 0), + MX6_PAD_KEY_ROW4__IPU1_SISG_5 = IOMUX_PAD(0x0650, 0x0268, 1, 0x0000, 0, 0), + MX6_PAD_KEY_ROW4__USBOH3_USBOTG_PWR = IOMUX_PAD(0x0650, 0x0268, 2, 0x0000, 0, 0), + MX6_PAD_KEY_ROW4__KPP_ROW_4 = IOMUX_PAD(0x0650, 0x0268, 3, 0x0000, 0, 0), + MX6_PAD_KEY_ROW4__UART5_CTS = IOMUX_PAD(0x0650, 0x0268, 4, 0x0000, 0, 0), + MX6_PAD_KEY_ROW4__UART5_RTS = IOMUX_PAD(0x0650, 0x0268, 4, 0x0918, 3, 0), + MX6_PAD_KEY_ROW4__GPIO_4_15 = IOMUX_PAD(0x0650, 0x0268, 5, 0x0000, 0, 0), + MX6_PAD_KEY_ROW4__MMDC_MMDC_DEBUG_50 = IOMUX_PAD(0x0650, 0x0268, 6, 0x0000, 0, 0), + MX6_PAD_KEY_ROW4__PL301_SIM_MX6DL_PER1_HADDR_8 = IOMUX_PAD(0x0650, 0x0268, 7, 0x0000, 0, 0), + MX6_PAD_LVDS0_CLK_P__LDB_LVDS0_CLK = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_LVDS0_TX0_P__LDB_LVDS0_TX0 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_LVDS0_TX1_P__LDB_LVDS0_TX1 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_LVDS0_TX2_P__LDB_LVDS0_TX2 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_LVDS0_TX3_P__LDB_LVDS0_TX3 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_LVDS1_CLK_P__LDB_LVDS1_CLK = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_LVDS1_TX0_P__LDB_LVDS1_TX0 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_LVDS1_TX1_P__LDB_LVDS1_TX1 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_LVDS1_TX2_P__LDB_LVDS1_TX2 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_LVDS1_TX3_P__LDB_LVDS1_TX3 = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_ALE__RAWNAND_ALE = IOMUX_PAD(0x0654, 0x026C, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_ALE__USDHC4_RST = IOMUX_PAD(0x0654, 0x026C, 1, 0x0000, 0, 0), + MX6_PAD_NANDF_ALE__PCIE_CTRL_DIAG_STATUS_BUS_MUX_0 = IOMUX_PAD(0x0654, 0x026C, 2, 0x0000, 0, 0), + MX6_PAD_NANDF_ALE__USBOH3_UH3_DFD_OUT_12 = IOMUX_PAD(0x0654, 0x026C, 3, 0x0000, 0, 0), + MX6_PAD_NANDF_ALE__USBOH3_UH2_DFD_OUT_12 = IOMUX_PAD(0x0654, 0x026C, 4, 0x0000, 0, 0), + MX6_PAD_NANDF_ALE__GPIO_6_8 = IOMUX_PAD(0x0654, 0x026C, 5, 0x0000, 0, 0), + MX6_PAD_NANDF_ALE__MIPI_CORE_DPHY_TEST_IN_24 = IOMUX_PAD(0x0654, 0x026C, 6, 0x0000, 0, 0), + MX6_PAD_NANDF_ALE__USDHC3_CLKI = IOMUX_PAD(0x0654, 0x026C, 8, 0x0934, 0, 0), + MX6_PAD_NANDF_CLE__RAWNAND_CLE = IOMUX_PAD(0x0658, 0x0270, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_CLE__PCIE_CTRL_DIAG_STATUS_BUS_MUX_31 = IOMUX_PAD(0x0658, 0x0270, 2, 0x0000, 0, 0), + MX6_PAD_NANDF_CLE__USBOH3_UH3_DFD_OUT_11 = IOMUX_PAD(0x0658, 0x0270, 3, 0x0000, 0, 0), + MX6_PAD_NANDF_CLE__USBOH3_UH2_DFD_OUT_11 = IOMUX_PAD(0x0658, 0x0270, 4, 0x0000, 0, 0), + MX6_PAD_NANDF_CLE__GPIO_6_7 = IOMUX_PAD(0x0658, 0x0270, 5, 0x0000, 0, 0), + MX6_PAD_NANDF_CLE__MIPI_CORE_DPHY_TEST_IN_23 = IOMUX_PAD(0x0658, 0x0270, 6, 0x0000, 0, 0), + MX6_PAD_NANDF_CLE__USDHC3_CLKO = IOMUX_PAD(0x0658, 0x0270, 8, 0x0000, 0, 0), + MX6_PAD_NANDF_CS0__RAWNAND_CE0N = IOMUX_PAD(0x065C, 0x0274, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_CS0__USBOH3_UH3_DFD_OUT_15 = IOMUX_PAD(0x065C, 0x0274, 3, 0x0000, 0, 0), + MX6_PAD_NANDF_CS0__USBOH3_UH2_DFD_OUT_15 = IOMUX_PAD(0x065C, 0x0274, 4, 0x0000, 0, 0), + MX6_PAD_NANDF_CS0__GPIO_6_11 = IOMUX_PAD(0x065C, 0x0274, 5, 0x0000, 0, 0), + MX6_PAD_NANDF_CS0__USDHC1_CLKO = IOMUX_PAD(0x065C, 0x0274, 8, 0x0000, 0, 0), + MX6_PAD_NANDF_CS1__RAWNAND_CE1N = IOMUX_PAD(0x0660, 0x0278, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_CS1__USDHC4_VSELECT = IOMUX_PAD(0x0660, 0x0278, 1, 0x0000, 0, 0), + MX6_PAD_NANDF_CS1__USDHC3_VSELECT = IOMUX_PAD(0x0660, 0x0278, 2, 0x0000, 0, 0), + MX6_PAD_NANDF_CS1__PCIE_CTRL_DIAG_STATUS_BUS_MUX_3 = IOMUX_PAD(0x0660, 0x0278, 4, 0x0000, 0, 0), MX6_PAD_NANDF_CS1__GPIO_6_14 = IOMUX_PAD(0x0660, 0x0278, 5, 0x0000, 0, 0), + MX6_PAD_NANDF_CS1__PL301_SIM_MX6DL_PER1_HREADYOUT = IOMUX_PAD(0x0660, 0x0278, 7, 0x0000, 0, 0), + MX6_PAD_NANDF_CS1__USDHC1_CLKI = IOMUX_PAD(0x0660, 0x0278, 8, 0x0928, 0, 0), + MX6_PAD_NANDF_CS2__RAWNAND_CE2N = IOMUX_PAD(0x0664, 0x027C, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_CS2__IPU1_SISG_0 = IOMUX_PAD(0x0664, 0x027C, 1, 0x0000, 0, 0), + MX6_PAD_NANDF_CS2__ESAI1_TX0 = IOMUX_PAD(0x0664, 0x027C, 2, 0x0844, 1, 0), + MX6_PAD_NANDF_CS2__WEIM_WEIM_CRE = IOMUX_PAD(0x0664, 0x027C, 3, 0x0000, 0, 0), + MX6_PAD_NANDF_CS2__CCM_CLKO2 = IOMUX_PAD(0x0664, 0x027C, 4, 0x0000, 0, 0), MX6_PAD_NANDF_CS2__GPIO_6_15 = IOMUX_PAD(0x0664, 0x027C, 5, 0x0000, 0, 0), + MX6_PAD_NANDF_CS2__USDHC2_CLKO = IOMUX_PAD(0x0664, 0x027C, 8, 0x0000, 0, 0), + MX6_PAD_NANDF_CS3__RAWNAND_CE3N = IOMUX_PAD(0x0668, 0x0280, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_CS3__IPU1_SISG_1 = IOMUX_PAD(0x0668, 0x0280, 1, 0x0000, 0, 0), + MX6_PAD_NANDF_CS3__ESAI1_TX1 = IOMUX_PAD(0x0668, 0x0280, 2, 0x0848, 1, 0), + MX6_PAD_NANDF_CS3__WEIM_WEIM_A_26 = IOMUX_PAD(0x0668, 0x0280, 3, 0x0000, 0, 0), + MX6_PAD_NANDF_CS3__PCIE_CTRL_DIAG_STATUS_BUS_MUX_4 = IOMUX_PAD(0x0668, 0x0280, 4, 0x0000, 0, 0), MX6_PAD_NANDF_CS3__GPIO_6_16 = IOMUX_PAD(0x0668, 0x0280, 5, 0x0000, 0, 0), + MX6_PAD_NANDF_CS3__TPSMP_CLK = IOMUX_PAD(0x0668, 0x0280, 7, 0x0000, 0, 0), + MX6_PAD_NANDF_CS3__USDHC2_CLKI = IOMUX_PAD(0x0668, 0x0280, 8, 0x0930, 0, 0), + MX6_PAD_NANDF_CS3__I2C4_SDA = IOMUX_PAD(0x0668, 0x0280, 9 | IOMUX_CONFIG_SION, 0x0884, 2, 0), + MX6_PAD_NANDF_D0__RAWNAND_D0 = IOMUX_PAD(0x066C, 0x0284, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_D0__USDHC1_DAT4 = IOMUX_PAD(0x066C, 0x0284, 1, 0x0000, 0, 0), + MX6_PAD_NANDF_D0__GPU3D_GPU_DEBUG_OUT_0 = IOMUX_PAD(0x066C, 0x0284, 2, 0x0000, 0, 0), + MX6_PAD_NANDF_D0__USBOH3_UH2_DFD_OUT_16 = IOMUX_PAD(0x066C, 0x0284, 3, 0x0000, 0, 0), + MX6_PAD_NANDF_D0__USBOH3_UH3_DFD_OUT_16 = IOMUX_PAD(0x066C, 0x0284, 4, 0x0000, 0, 0), + MX6_PAD_NANDF_D0__GPIO_2_0 = IOMUX_PAD(0x066C, 0x0284, 5, 0x0000, 0, 0), + MX6_PAD_NANDF_D0__IPU1_IPU_DIAG_BUS_0 = IOMUX_PAD(0x066C, 0x0284, 6, 0x0000, 0, 0), + MX6_PAD_NANDF_D1__RAWNAND_D1 = IOMUX_PAD(0x0670, 0x0288, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_D1__USDHC1_DAT5 = IOMUX_PAD(0x0670, 0x0288, 1, 0x0000, 0, 0), + MX6_PAD_NANDF_D1__GPU3D_GPU_DEBUG_OUT_1 = IOMUX_PAD(0x0670, 0x0288, 2, 0x0000, 0, 0), + MX6_PAD_NANDF_D1__USBOH3_UH2_DFD_OUT_17 = IOMUX_PAD(0x0670, 0x0288, 3, 0x0000, 0, 0), + MX6_PAD_NANDF_D1__USBOH3_UH3_DFD_OUT_17 = IOMUX_PAD(0x0670, 0x0288, 4, 0x0000, 0, 0), MX6_PAD_NANDF_D1__GPIO_2_1 = IOMUX_PAD(0x0670, 0x0288, 5, 0x0000, 0, 0), + MX6_PAD_NANDF_D1__IPU1_IPU_DIAG_BUS_1 = IOMUX_PAD(0x0670, 0x0288, 6, 0x0000, 0, 0), + MX6_PAD_NANDF_D2__RAWNAND_D2 = IOMUX_PAD(0x0674, 0x028C, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_D2__USDHC1_DAT6 = IOMUX_PAD(0x0674, 0x028C, 1, 0x0000, 0, 0), + MX6_PAD_NANDF_D2__GPU3D_GPU_DEBUG_OUT_2 = IOMUX_PAD(0x0674, 0x028C, 2, 0x0000, 0, 0), + MX6_PAD_NANDF_D2__USBOH3_UH2_DFD_OUT_18 = IOMUX_PAD(0x0674, 0x028C, 3, 0x0000, 0, 0), + MX6_PAD_NANDF_D2__USBOH3_UH3_DFD_OUT_18 = IOMUX_PAD(0x0674, 0x028C, 4, 0x0000, 0, 0), MX6_PAD_NANDF_D2__GPIO_2_2 = IOMUX_PAD(0x0674, 0x028C, 5, 0x0000, 0, 0), + MX6_PAD_NANDF_D2__IPU1_IPU_DIAG_BUS_2 = IOMUX_PAD(0x0674, 0x028C, 6, 0x0000, 0, 0), + MX6_PAD_NANDF_D3__RAWNAND_D3 = IOMUX_PAD(0x0678, 0x0290, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_D3__USDHC1_DAT7 = IOMUX_PAD(0x0678, 0x0290, 1, 0x0000, 0, 0), + MX6_PAD_NANDF_D3__GPU3D_GPU_DEBUG_OUT_3 = IOMUX_PAD(0x0678, 0x0290, 2, 0x0000, 0, 0), + MX6_PAD_NANDF_D3__USBOH3_UH2_DFD_OUT_19 = IOMUX_PAD(0x0678, 0x0290, 3, 0x0000, 0, 0), + MX6_PAD_NANDF_D3__USBOH3_UH3_DFD_OUT_19 = IOMUX_PAD(0x0678, 0x0290, 4, 0x0000, 0, 0), MX6_PAD_NANDF_D3__GPIO_2_3 = IOMUX_PAD(0x0678, 0x0290, 5, 0x0000, 0, 0), + MX6_PAD_NANDF_D3__IPU1_IPU_DIAG_BUS_3 = IOMUX_PAD(0x0678, 0x0290, 6, 0x0000, 0, 0), + MX6_PAD_NANDF_D4__RAWNAND_D4 = IOMUX_PAD(0x067C, 0x0294, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_D4__USDHC2_DAT4 = IOMUX_PAD(0x067C, 0x0294, 1, 0x0000, 0, 0), + MX6_PAD_NANDF_D4__GPU3D_GPU_DEBUG_OUT_4 = IOMUX_PAD(0x067C, 0x0294, 2, 0x0000, 0, 0), + MX6_PAD_NANDF_D4__USBOH3_UH2_DFD_OUT_20 = IOMUX_PAD(0x067C, 0x0294, 3, 0x0000, 0, 0), + MX6_PAD_NANDF_D4__USBOH3_UH3_DFD_OUT_20 = IOMUX_PAD(0x067C, 0x0294, 4, 0x0000, 0, 0), MX6_PAD_NANDF_D4__GPIO_2_4 = IOMUX_PAD(0x067C, 0x0294, 5, 0x0000, 0, 0), + MX6_PAD_NANDF_D4__IPU1_IPU_DIAG_BUS_4 = IOMUX_PAD(0x067C, 0x0294, 6, 0x0000, 0, 0), + MX6_PAD_NANDF_D5__RAWNAND_D5 = IOMUX_PAD(0x0680, 0x0298, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_D5__USDHC2_DAT5 = IOMUX_PAD(0x0680, 0x0298, 1, 0x0000, 0, 0), + MX6_PAD_NANDF_D5__GPU3D_GPU_DEBUG_OUT_5 = IOMUX_PAD(0x0680, 0x0298, 2, 0x0000, 0, 0), + MX6_PAD_NANDF_D5__USBOH3_UH2_DFD_OUT_21 = IOMUX_PAD(0x0680, 0x0298, 3, 0x0000, 0, 0), + MX6_PAD_NANDF_D5__USBOH3_UH3_DFD_OUT_21 = IOMUX_PAD(0x0680, 0x0298, 4, 0x0000, 0, 0), + MX6_PAD_NANDF_D5__GPIO_2_5 = IOMUX_PAD(0x0680, 0x0298, 5, 0x0000, 0, 0), + MX6_PAD_NANDF_D5__IPU1_IPU_DIAG_BUS_5 = IOMUX_PAD(0x0680, 0x0298, 6, 0x0000, 0, 0), + MX6_PAD_NANDF_D6__RAWNAND_D6 = IOMUX_PAD(0x0684, 0x029C, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_D6__USDHC2_DAT6 = IOMUX_PAD(0x0684, 0x029C, 1, 0x0000, 0, 0), + MX6_PAD_NANDF_D6__GPU3D_GPU_DEBUG_OUT_6 = IOMUX_PAD(0x0684, 0x029C, 2, 0x0000, 0, 0), + MX6_PAD_NANDF_D6__USBOH3_UH2_DFD_OUT_22 = IOMUX_PAD(0x0684, 0x029C, 3, 0x0000, 0, 0), + MX6_PAD_NANDF_D6__USBOH3_UH3_DFD_OUT_22 = IOMUX_PAD(0x0684, 0x029C, 4, 0x0000, 0, 0), MX6_PAD_NANDF_D6__GPIO_2_6 = IOMUX_PAD(0x0684, 0x029C, 5, 0x0000, 0, 0), - MX6_PAD_RGMII_RD0__ENET_RGMII_RD0 = IOMUX_PAD(0x0694, 0x02AC, 1, 0x0818, 1, 0), + MX6_PAD_NANDF_D6__IPU1_IPU_DIAG_BUS_6 = IOMUX_PAD(0x0684, 0x029C, 6, 0x0000, 0, 0), + MX6_PAD_NANDF_D7__RAWNAND_D7 = IOMUX_PAD(0x0688, 0x02A0, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_D7__USDHC2_DAT7 = IOMUX_PAD(0x0688, 0x02A0, 1, 0x0000, 0, 0), + MX6_PAD_NANDF_D7__GPU3D_GPU_DEBUG_OUT_7 = IOMUX_PAD(0x0688, 0x02A0, 2, 0x0000, 0, 0), + MX6_PAD_NANDF_D7__USBOH3_UH2_DFD_OUT_23 = IOMUX_PAD(0x0688, 0x02A0, 3, 0x0000, 0, 0), + MX6_PAD_NANDF_D7__USBOH3_UH3_DFD_OUT_23 = IOMUX_PAD(0x0688, 0x02A0, 4, 0x0000, 0, 0), + MX6_PAD_NANDF_D7__GPIO_2_7 = IOMUX_PAD(0x0688, 0x02A0, 5, 0x0000, 0, 0), + MX6_PAD_NANDF_D7__IPU1_IPU_DIAG_BUS_7 = IOMUX_PAD(0x0688, 0x02A0, 6, 0x0000, 0, 0), + MX6_PAD_NANDF_RB0__RAWNAND_READY0 = IOMUX_PAD(0x068C, 0x02A4, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_RB0__PCIE_CTRL_DIAG_STATUS_BUS_MUX_2 = IOMUX_PAD(0x068C, 0x02A4, 2, 0x0000, 0, 0), + MX6_PAD_NANDF_RB0__USBOH3_UH3_DFD_OUT_14 = IOMUX_PAD(0x068C, 0x02A4, 3, 0x0000, 0, 0), + MX6_PAD_NANDF_RB0__USBOH3_UH2_DFD_OUT_14 = IOMUX_PAD(0x068C, 0x02A4, 4, 0x0000, 0, 0), + MX6_PAD_NANDF_RB0__GPIO_6_10 = IOMUX_PAD(0x068C, 0x02A4, 5, 0x0000, 0, 0), + MX6_PAD_NANDF_RB0__MIPI_CORE_DPHY_TEST_OUT_33 = IOMUX_PAD(0x068C, 0x02A4, 6, 0x0000, 0, 0), + MX6_PAD_NANDF_RB0__USDHC4_CLKI = IOMUX_PAD(0x068C, 0x02A4, 8, 0x0938, 0, 0), + MX6_PAD_NANDF_WP_B__RAWNAND_RESETN = IOMUX_PAD(0x0690, 0x02A8, 0, 0x0000, 0, 0), + MX6_PAD_NANDF_WP_B__PCIE_CTRL_DIAG_STATUS_BUS_MUX_1 = IOMUX_PAD(0x0690, 0x02A8, 2, 0x0000, 0, 0), + MX6_PAD_NANDF_WP_B__USBOH3_UH3_DFD_OUT_13 = IOMUX_PAD(0x0690, 0x02A8, 3, 0x0000, 0, 0), + MX6_PAD_NANDF_WP_B__USBOH3_UH2_DFD_OUT_13 = IOMUX_PAD(0x0690, 0x02A8, 4, 0x0000, 0, 0), + MX6_PAD_NANDF_WP_B__GPIO_6_9 = IOMUX_PAD(0x0690, 0x02A8, 5, 0x0000, 0, 0), + MX6_PAD_NANDF_WP_B__MIPI_CORE_DPHY_TEST_OUT_32 = IOMUX_PAD(0x0690, 0x02A8, 6, 0x0000, 0, 0), + MX6_PAD_NANDF_WP_B__USDHC4_CLKO = IOMUX_PAD(0x0690, 0x02A8, 8, 0x0000, 0, 0), + MX6_PAD_NANDF_WP_B__I2C4_SCL = IOMUX_PAD(0x0690, 0x02A8, 9 | IOMUX_CONFIG_SION, 0x0880, 2, 0), + MX6_PAD_PMIC_ON_REQ__SNVS_LP_WRAPPER_SNVS_WAKEUP_ALARM = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_PMIC_STBY_REQ__CCM_PMIC_VSTBY_REQ = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_POR_B__SRC_POR_B = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_RESET_IN_B__SRC_RESET_B = IOMUX_PAD(NO_PAD_I, NO_MUX_I, 0, 0x0000, 0, 0), + MX6_PAD_RGMII_RD0__MIPI_HSI_CTRL_RX_READY = IOMUX_PAD(0x0694, 0x02AC, 0, 0x0000, 0, 0), + MX6_PAD_RGMII_RD0__ENET_RGMII_RD0 = IOMUX_PAD(0x0694, 0x02AC, 1, 0x0818, 1, 0), MX6_PAD_RGMII_RD0__GPIO_6_25 = IOMUX_PAD(0x0694, 0x02AC, 5, 0x0000, 0, 0), + MX6_PAD_RGMII_RD0__MIPI_CORE_DPHY_TEST_IN_6 = IOMUX_PAD(0x0694, 0x02AC, 6, 0x0000, 0, 0), + MX6_PAD_RGMII_RD1__MIPI_HSI_CTRL_TX_FLAG = IOMUX_PAD(0x0698, 0x02B0, 0, 0x0000, 0, 0), MX6_PAD_RGMII_RD1__ENET_RGMII_RD1 = IOMUX_PAD(0x0698, 0x02B0, 1, 0x081C, 1, 0), MX6_PAD_RGMII_RD1__GPIO_6_27 = IOMUX_PAD(0x0698, 0x02B0, 5, 0x0000, 0, 0), + MX6_PAD_RGMII_RD1__MIPI_CORE_DPHY_TEST_IN_8 = IOMUX_PAD(0x0698, 0x02B0, 6, 0x0000, 0, 0), + MX6_PAD_RGMII_RD1__SJC_FAIL = IOMUX_PAD(0x0698, 0x02B0, 7, 0x0000, 0, 0), + MX6_PAD_RGMII_RD2__MIPI_HSI_CTRL_TX_DATA = IOMUX_PAD(0x069C, 0x02B4, 0, 0x0000, 0, 0), MX6_PAD_RGMII_RD2__ENET_RGMII_RD2 = IOMUX_PAD(0x069C, 0x02B4, 1, 0x0820, 1, 0), MX6_PAD_RGMII_RD2__GPIO_6_28 = IOMUX_PAD(0x069C, 0x02B4, 5, 0x0000, 0, 0), + MX6_PAD_RGMII_RD2__MIPI_CORE_DPHY_TEST_IN_9 = IOMUX_PAD(0x069C, 0x02B4, 6, 0x0000, 0, 0), + MX6_PAD_RGMII_RD3__MIPI_HSI_CTRL_TX_WAKE = IOMUX_PAD(0x06A0, 0x02B8, 0, 0x0000, 0, 0), MX6_PAD_RGMII_RD3__ENET_RGMII_RD3 = IOMUX_PAD(0x06A0, 0x02B8, 1, 0x0824, 1, 0), MX6_PAD_RGMII_RD3__GPIO_6_29 = IOMUX_PAD(0x06A0, 0x02B8, 5, 0x0000, 0, 0), + MX6_PAD_RGMII_RD3__MIPI_CORE_DPHY_TEST_IN_10 = IOMUX_PAD(0x06A0, 0x02B8, 6, 0x0000, 0, 0), + MX6_PAD_RGMII_RX_CTL__USBOH3_H3_DATA = IOMUX_PAD(0x06A4, 0x02BC, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0), MX6_PAD_RGMII_RX_CTL__RGMII_RX_CTL = IOMUX_PAD(0x06A4, 0x02BC, 1, 0x0828, 1, 0), - MX6_PAD_RGMII_RX_CTL__GPIO_6_24 = IOMUX_PAD(0x06A4, 0x02BC, 5, 0x0000, 0, 0), + MX6_PAD_RGMII_RX_CTL__GPIO_6_24 = IOMUX_PAD(0x06A4, 0x02BC, 5, 0x0000, 0, 0), + MX6_PAD_RGMII_RX_CTL__MIPI_CORE_DPHY_TEST_IN_5 = IOMUX_PAD(0x06A4, 0x02BC, 6, 0x0000, 0, 0), + MX6_PAD_RGMII_RXC__USBOH3_H3_STROBE = IOMUX_PAD(0x06A8, 0x02C0, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0), + MX6_PAD_RGMII_RXC__USBOH3_H3_STROBE_START = IOMUX_PAD(0x06A8, 0x02C0, 0 | IOMUX_CONFIG_SION, 0x0000, 0, PAD_CTL_PUS_47K_UP), MX6_PAD_RGMII_RXC__ENET_RGMII_RXC = IOMUX_PAD(0x06A8, 0x02C0, 1, 0x0814, 1, 0), MX6_PAD_RGMII_RXC__GPIO_6_30 = IOMUX_PAD(0x06A8, 0x02C0, 5, 0x0000, 0, 0), + MX6_PAD_RGMII_RXC__MIPI_CORE_DPHY_TEST_IN_11 = IOMUX_PAD(0x06A8, 0x02C0, 6, 0x0000, 0, 0), + MX6_PAD_RGMII_TD0__MIPI_HSI_CTRL_TX_READY = IOMUX_PAD(0x06AC, 0x02C4, 0, 0x0000, 0, 0), MX6_PAD_RGMII_TD0__ENET_RGMII_TD0 = IOMUX_PAD(0x06AC, 0x02C4, 1, 0x0000, 0, 0), + MX6_PAD_RGMII_TD0__GPIO_6_20 = IOMUX_PAD(0x06AC, 0x02C4, 5, 0x0000, 0, 0), + MX6_PAD_RGMII_TD0__MIPI_CORE_DPHY_TEST_IN_1 = IOMUX_PAD(0x06AC, 0x02C4, 6, 0x0000, 0, 0), + MX6_PAD_RGMII_TD1__MIPI_HSI_CTRL_RX_FLAG = IOMUX_PAD(0x06B0, 0x02C8, 0, 0x0000, 0, 0), MX6_PAD_RGMII_TD1__ENET_RGMII_TD1 = IOMUX_PAD(0x06B0, 0x02C8, 1, 0x0000, 0, 0), + MX6_PAD_RGMII_TD1__GPIO_6_21 = IOMUX_PAD(0x06B0, 0x02C8, 5, 0x0000, 0, 0), + MX6_PAD_RGMII_TD1__MIPI_CORE_DPHY_TEST_IN_2 = IOMUX_PAD(0x06B0, 0x02C8, 6, 0x0000, 0, 0), + MX6_PAD_RGMII_TD1__CCM_PLL3_BYP = IOMUX_PAD(0x06B0, 0x02C8, 7, 0x0000, 0, 0), + MX6_PAD_RGMII_TD2__MIPI_HSI_CTRL_RX_DATA = IOMUX_PAD(0x06B4, 0x02CC, 0, 0x0000, 0, 0), MX6_PAD_RGMII_TD2__ENET_RGMII_TD2 = IOMUX_PAD(0x06B4, 0x02CC, 1, 0x0000, 0, 0), + MX6_PAD_RGMII_TD2__GPIO_6_22 = IOMUX_PAD(0x06B4, 0x02CC, 5, 0x0000, 0, 0), + MX6_PAD_RGMII_TD2__MIPI_CORE_DPHY_TEST_IN_3 = IOMUX_PAD(0x06B4, 0x02CC, 6, 0x0000, 0, 0), + MX6_PAD_RGMII_TD2__CCM_PLL2_BYP = IOMUX_PAD(0x06B4, 0x02CC, 7, 0x0000, 0, 0), + MX6_PAD_RGMII_TD3__MIPI_HSI_CTRL_RX_WAKE = IOMUX_PAD(0x06B8, 0x02D0, 0, 0x0000, 0, 0), MX6_PAD_RGMII_TD3__ENET_RGMII_TD3 = IOMUX_PAD(0x06B8, 0x02D0, 1, 0x0000, 0, 0), + MX6_PAD_RGMII_TD3__GPIO_6_23 = IOMUX_PAD(0x06B8, 0x02D0, 5, 0x0000, 0, 0), + MX6_PAD_RGMII_TD3__MIPI_CORE_DPHY_TEST_IN_4 = IOMUX_PAD(0x06B8, 0x02D0, 6, 0x0000, 0, 0), + MX6_PAD_RGMII_TX_CTL__USBOH3_H2_STROBE = IOMUX_PAD(0x06BC, 0x02D4, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0), + MX6_PAD_RGMII_TX_CTL__USBOH3_H2_STROBE_START = IOMUX_PAD(0x06BC, 0x02D4, 0 | IOMUX_CONFIG_SION, 0x0000, 0, PAD_CTL_PUS_47K_UP), MX6_PAD_RGMII_TX_CTL__RGMII_TX_CTL = IOMUX_PAD(0x06BC, 0x02D4, 1, 0x0000, 0, 0), + MX6_PAD_RGMII_TX_CTL__GPIO_6_26 = IOMUX_PAD(0x06BC, 0x02D4, 5, 0x0000, 0, 0), + MX6_PAD_RGMII_TX_CTL__MIPI_CORE_DPHY_TEST_IN_7 = IOMUX_PAD(0x06BC, 0x02D4, 6, 0x0000, 0, 0), + MX6_PAD_RGMII_TX_CTL__ENET_ANATOP_ETHERNET_REF_OUT = IOMUX_PAD(0x06BC, 0x02D4, 7, 0x080C, 1, 0), + MX6_PAD_RGMII_TXC__USBOH3_H2_DATA = IOMUX_PAD(0x06C0, 0x02D8, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0), MX6_PAD_RGMII_TXC__ENET_RGMII_TXC = IOMUX_PAD(0x06C0, 0x02D8, 1, 0x0000, 0, 0), + MX6_PAD_RGMII_TXC__SPDIF_SPDIF_EXTCLK = IOMUX_PAD(0x06C0, 0x02D8, 2, 0x08F4, 1, 0), + MX6_PAD_RGMII_TXC__GPIO_6_19 = IOMUX_PAD(0x06C0, 0x02D8, 5, 0x0000, 0, 0), + MX6_PAD_RGMII_TXC__MIPI_CORE_DPHY_TEST_IN_0 = IOMUX_PAD(0x06C0, 0x02D8, 6, 0x0000, 0, 0), + MX6_PAD_RGMII_TXC__ANATOP_ANATOP_24M_OUT = IOMUX_PAD(0x06C0, 0x02D8, 7, 0x0000, 0, 0), + MX6_PAD_SD1_CLK__USDHC1_CLK = IOMUX_PAD(0x06C4, 0x02DC, 0, 0x0928, 1, 0), + MX6_PAD_SD1_CLK__OSC32K_32K_OUT = IOMUX_PAD(0x06C4, 0x02DC, 2, 0x0000, 0, 0), + MX6_PAD_SD1_CLK__GPT_CLKIN = IOMUX_PAD(0x06C4, 0x02DC, 3, 0x0000, 0, 0), + MX6_PAD_SD1_CLK__GPIO_1_20 = IOMUX_PAD(0x06C4, 0x02DC, 5, 0x0000, 0, 0), + MX6_PAD_SD1_CLK__PHY_DTB_0 = IOMUX_PAD(0x06C4, 0x02DC, 6, 0x0000, 0, 0), + MX6_PAD_SD1_CMD__USDHC1_CMD = IOMUX_PAD(0x06C8, 0x02E0, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0), + MX6_PAD_SD1_CMD__PWM4_PWMO = IOMUX_PAD(0x06C8, 0x02E0, 2, 0x0000, 0, 0), + MX6_PAD_SD1_CMD__GPT_CMPOUT1 = IOMUX_PAD(0x06C8, 0x02E0, 3, 0x0000, 0, 0), MX6_PAD_SD1_CMD__GPIO_1_18 = IOMUX_PAD(0x06C8, 0x02E0, 5, 0x0000, 0, 0), + MX6_PAD_SD1_CMD__ANATOP_ANATOP_TESTO_5 = IOMUX_PAD(0x06C8, 0x02E0, 7, 0x0000, 0, 0), + MX6_PAD_SD1_DAT0__USDHC1_DAT0 = IOMUX_PAD(0x06CC, 0x02E4, 0, 0x0000, 0, 0), + MX6_PAD_SD1_DAT0__CAAM_WRAPPER_RNG_OSC_OBS = IOMUX_PAD(0x06CC, 0x02E4, 2, 0x0000, 0, 0), + MX6_PAD_SD1_DAT0__GPT_CAPIN1 = IOMUX_PAD(0x06CC, 0x02E4, 3, 0x0000, 0, 0), + MX6_PAD_SD1_DAT0__PCIE_CTRL_DIAG_STATUS_BUS_MUX_8 = IOMUX_PAD(0x06CC, 0x02E4, 4, 0x0000, 0, 0), + MX6_PAD_SD1_DAT0__GPIO_1_16 = IOMUX_PAD(0x06CC, 0x02E4, 5, 0x0000, 0, 0), + MX6_PAD_SD1_DAT0__HDMI_TX_OPHYDTB_1 = IOMUX_PAD(0x06CC, 0x02E4, 6, 0x0000, 0, 0), + MX6_PAD_SD1_DAT0__ANATOP_ANATOP_TESTO_7 = IOMUX_PAD(0x06CC, 0x02E4, 7, 0x0000, 0, 0), + MX6_PAD_SD1_DAT1__USDHC1_DAT1 = IOMUX_PAD(0x06D0, 0x02E8, 0, 0x0000, 0, 0), + MX6_PAD_SD1_DAT1__PWM3_PWMO = IOMUX_PAD(0x06D0, 0x02E8, 2, 0x0000, 0, 0), + MX6_PAD_SD1_DAT1__GPT_CAPIN2 = IOMUX_PAD(0x06D0, 0x02E8, 3, 0x0000, 0, 0), + MX6_PAD_SD1_DAT1__PCIE_CTRL_DIAG_STATUS_BUS_MUX_7 = IOMUX_PAD(0x06D0, 0x02E8, 4, 0x0000, 0, 0), + MX6_PAD_SD1_DAT1__GPIO_1_17 = IOMUX_PAD(0x06D0, 0x02E8, 5, 0x0000, 0, 0), + MX6_PAD_SD1_DAT1__HDMI_TX_OPHYDTB_0 = IOMUX_PAD(0x06D0, 0x02E8, 6, 0x0000, 0, 0), + MX6_PAD_SD1_DAT1__ANATOP_ANATOP_TESTO_8 = IOMUX_PAD(0x06D0, 0x02E8, 7, 0x0000, 0, 0), + MX6_PAD_SD1_DAT2__USDHC1_DAT2 = IOMUX_PAD(0x06D4, 0x02EC, 0, 0x0000, 0, 0), + MX6_PAD_SD1_DAT2__GPT_CMPOUT2 = IOMUX_PAD(0x06D4, 0x02EC, 2, 0x0000, 0, 0), + MX6_PAD_SD1_DAT2__PWM2_PWMO = IOMUX_PAD(0x06D4, 0x02EC, 3, 0x0000, 0, 0), + MX6_PAD_SD1_DAT2__WDOG1_WDOG_B = IOMUX_PAD(0x06D4, 0x02EC, 4, 0x0000, 0, 0), + MX6_PAD_SD1_DAT2__GPIO_1_19 = IOMUX_PAD(0x06D4, 0x02EC, 5, 0x0000, 0, 0), + MX6_PAD_SD1_DAT2__WDOG1_WDOG_RST_B_DEB = IOMUX_PAD(0x06D4, 0x02EC, 6, 0x0000, 0, 0), + MX6_PAD_SD1_DAT2__ANATOP_ANATOP_TESTO_4 = IOMUX_PAD(0x06D4, 0x02EC, 7, 0x0000, 0, 0), + MX6_PAD_SD1_DAT3__USDHC1_DAT3 = IOMUX_PAD(0x06D8, 0x02F0, 0, 0x0000, 0, 0), + MX6_PAD_SD1_DAT3__GPT_CMPOUT3 = IOMUX_PAD(0x06D8, 0x02F0, 2, 0x0000, 0, 0), + MX6_PAD_SD1_DAT3__PWM1_PWMO = IOMUX_PAD(0x06D8, 0x02F0, 3, 0x0000, 0, 0), + MX6_PAD_SD1_DAT3__WDOG2_WDOG_B = IOMUX_PAD(0x06D8, 0x02F0, 4, 0x0000, 0, 0), MX6_PAD_SD1_DAT3__GPIO_1_21 = IOMUX_PAD(0x06D8, 0x02F0, 5, 0x0000, 0, 0), + MX6_PAD_SD1_DAT3__WDOG2_WDOG_RST_B_DEB = IOMUX_PAD(0x06D8, 0x02F0, 6, 0x0000, 0, 0), + MX6_PAD_SD1_DAT3__ANATOP_ANATOP_TESTO_6 = IOMUX_PAD(0x06D8, 0x02F0, 7, 0x0000, 0, 0), + MX6_PAD_SD2_CLK__USDHC2_CLK = IOMUX_PAD(0x06DC, 0x02F4, 0, 0x0930, 1, 0), + MX6_PAD_SD2_CLK__KPP_COL_5 = IOMUX_PAD(0x06DC, 0x02F4, 2, 0x08C0, 3, 0), + MX6_PAD_SD2_CLK__AUDMUX_AUD4_RXFS = IOMUX_PAD(0x06DC, 0x02F4, 3, 0x07A4, 1, 0), + MX6_PAD_SD2_CLK__PCIE_CTRL_DIAG_STATUS_BUS_MUX_9 = IOMUX_PAD(0x06DC, 0x02F4, 4, 0x0000, 0, 0), + MX6_PAD_SD2_CLK__GPIO_1_10 = IOMUX_PAD(0x06DC, 0x02F4, 5, 0x0000, 0, 0), + MX6_PAD_SD2_CLK__PHY_DTB_1 = IOMUX_PAD(0x06DC, 0x02F4, 6, 0x0000, 0, 0), + MX6_PAD_SD2_CMD__USDHC2_CMD = IOMUX_PAD(0x06E0, 0x02F8, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0), + MX6_PAD_SD2_CMD__KPP_ROW_5 = IOMUX_PAD(0x06E0, 0x02F8, 2, 0x08CC, 2, 0), + MX6_PAD_SD2_CMD__AUDMUX_AUD4_RXC = IOMUX_PAD(0x06E0, 0x02F8, 3, 0x07A0, 1, 0), + MX6_PAD_SD2_CMD__PCIE_CTRL_DIAG_STATUS_BUS_MUX_10 = IOMUX_PAD(0x06E0, 0x02F8, 4, 0x0000, 0, 0), + MX6_PAD_SD2_CMD__GPIO_1_11 = IOMUX_PAD(0x06E0, 0x02F8, 5, 0x0000, 0, 0), + MX6_PAD_SD2_DAT0__USDHC2_DAT0 = IOMUX_PAD(0x06E4, 0x02FC, 0, 0x0000, 0, 0), + MX6_PAD_SD2_DAT0__AUDMUX_AUD4_RXD = IOMUX_PAD(0x06E4, 0x02FC, 3, 0x0798, 1, 0), + MX6_PAD_SD2_DAT0__KPP_ROW_7 = IOMUX_PAD(0x06E4, 0x02FC, 4, 0x08D4, 2, 0), + MX6_PAD_SD2_DAT0__GPIO_1_15 = IOMUX_PAD(0x06E4, 0x02FC, 5, 0x0000, 0, 0), + MX6_PAD_SD2_DAT0__DCIC2_DCIC_OUT = IOMUX_PAD(0x06E4, 0x02FC, 6, 0x0000, 0, 0), + MX6_PAD_SD2_DAT0__ANATOP_ANATOP_TESTO_2 = IOMUX_PAD(0x06E4, 0x02FC, 7, 0x0000, 0, 0), + MX6_PAD_SD2_DAT1__USDHC2_DAT1 = IOMUX_PAD(0x06E8, 0x0300, 0, 0x0000, 0, 0), + MX6_PAD_SD2_DAT1__WEIM_WEIM_CS_2 = IOMUX_PAD(0x06E8, 0x0300, 2, 0x0000, 0, 0), + MX6_PAD_SD2_DAT1__AUDMUX_AUD4_TXFS = IOMUX_PAD(0x06E8, 0x0300, 3, 0x07AC, 1, 0), + MX6_PAD_SD2_DAT1__KPP_COL_7 = IOMUX_PAD(0x06E8, 0x0300, 4, 0x08C8, 2, 0), + MX6_PAD_SD2_DAT1__GPIO_1_14 = IOMUX_PAD(0x06E8, 0x0300, 5, 0x0000, 0, 0), + MX6_PAD_SD2_DAT1__CCM_WAIT = IOMUX_PAD(0x06E8, 0x0300, 6, 0x0000, 0, 0), + MX6_PAD_SD2_DAT1__ANATOP_ANATOP_TESTO_0 = IOMUX_PAD(0x06E8, 0x0300, 7, 0x0000, 0, 0), + MX6_PAD_SD2_DAT2__USDHC2_DAT2 = IOMUX_PAD(0x06EC, 0x0304, 0, 0x0000, 0, 0), + MX6_PAD_SD2_DAT2__WEIM_WEIM_CS_3 = IOMUX_PAD(0x06EC, 0x0304, 2, 0x0000, 0, 0), + MX6_PAD_SD2_DAT2__AUDMUX_AUD4_TXD = IOMUX_PAD(0x06EC, 0x0304, 3, 0x079C, 1, 0), + MX6_PAD_SD2_DAT2__KPP_ROW_6 = IOMUX_PAD(0x06EC, 0x0304, 4, 0x08D0, 2, 0), + MX6_PAD_SD2_DAT2__GPIO_1_13 = IOMUX_PAD(0x06EC, 0x0304, 5, 0x0000, 0, 0), + MX6_PAD_SD2_DAT2__CCM_STOP = IOMUX_PAD(0x06EC, 0x0304, 6, 0x0000, 0, 0), + MX6_PAD_SD2_DAT2__ANATOP_ANATOP_TESTO_1 = IOMUX_PAD(0x06EC, 0x0304, 7, 0x0000, 0, 0), + MX6_PAD_SD2_DAT3__USDHC2_DAT3 = IOMUX_PAD(0x06F0, 0x0308, 0, 0x0000, 0, 0), + MX6_PAD_SD2_DAT3__KPP_COL_6 = IOMUX_PAD(0x06F0, 0x0308, 2, 0x08C4, 2, 0), + MX6_PAD_SD2_DAT3__AUDMUX_AUD4_TXC = IOMUX_PAD(0x06F0, 0x0308, 3, 0x07A8, 1, 0), + MX6_PAD_SD2_DAT3__PCIE_CTRL_DIAG_STATUS_BUS_MUX_11 = IOMUX_PAD(0x06F0, 0x0308, 4, 0x0000, 0, 0), + MX6_PAD_SD2_DAT3__GPIO_1_12 = IOMUX_PAD(0x06F0, 0x0308, 5, 0x0000, 0, 0), + MX6_PAD_SD2_DAT3__SJC_DONE = IOMUX_PAD(0x06F0, 0x0308, 6, 0x0000, 0, 0), + MX6_PAD_SD2_DAT3__ANATOP_ANATOP_TESTO_3 = IOMUX_PAD(0x06F0, 0x0308, 7, 0x0000, 0, 0), MX6_PAD_SD3_CLK__USDHC3_CLK = IOMUX_PAD(0x06F4, 0x030C, 0, 0x0934, 1, 0), + MX6_PAD_SD3_CLK__UART2_CTS = IOMUX_PAD(0x06F4, 0x030C, 1, 0x0000, 0, 0), + MX6_PAD_SD3_CLK__UART2_RTS = IOMUX_PAD(0x06F4, 0x030C, 1, 0x0900, 2, 0), + MX6_PAD_SD3_CLK__CAN1_RXCAN = IOMUX_PAD(0x06F4, 0x030C, 2, 0x07C8, 2, 0), + MX6_PAD_SD3_CLK__USBOH3_UH3_DFD_OUT_5 = IOMUX_PAD(0x06F4, 0x030C, 3, 0x0000, 0, 0), + MX6_PAD_SD3_CLK__USBOH3_UH2_DFD_OUT_5 = IOMUX_PAD(0x06F4, 0x030C, 4, 0x0000, 0, 0), + MX6_PAD_SD3_CLK__GPIO_7_3 = IOMUX_PAD(0x06F4, 0x030C, 5, 0x0000, 0, 0), + MX6_PAD_SD3_CLK__MIPI_CORE_DPHY_TEST_IN_17 = IOMUX_PAD(0x06F4, 0x030C, 6, 0x0000, 0, 0), + MX6_PAD_SD3_CLK__ANATOP_ANATOP_TESTO_14 = IOMUX_PAD(0x06F4, 0x030C, 7, 0x0000, 0, 0), MX6_PAD_SD3_CMD__USDHC3_CMD = IOMUX_PAD(0x06F8, 0x0310, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0), + MX6_PAD_SD3_CMD__UART2_CTS = IOMUX_PAD(0x06F8, 0x0310, 1, 0x0000, 0, 0), + MX6_PAD_SD3_CMD__UART2_RTS = IOMUX_PAD(0x06F8, 0x0310, 1, 0x0900, 3, 0), + MX6_PAD_SD3_CMD__CAN1_TXCAN = IOMUX_PAD(0x06F8, 0x0310, 2, 0x0000, 0, 0), + MX6_PAD_SD3_CMD__USBOH3_UH3_DFD_OUT_4 = IOMUX_PAD(0x06F8, 0x0310, 3, 0x0000, 0, 0), + MX6_PAD_SD3_CMD__USBOH3_UH2_DFD_OUT_4 = IOMUX_PAD(0x06F8, 0x0310, 4, 0x0000, 0, 0), + MX6_PAD_SD3_CMD__GPIO_7_2 = IOMUX_PAD(0x06F8, 0x0310, 5, 0x0000, 0, 0), + MX6_PAD_SD3_CMD__MIPI_CORE_DPHY_TEST_IN_16 = IOMUX_PAD(0x06F8, 0x0310, 6, 0x0000, 0, 0), + MX6_PAD_SD3_CMD__ANATOP_ANATOP_TESTO_13 = IOMUX_PAD(0x06F8, 0x0310, 7, 0x0000, 0, 0), MX6_PAD_SD3_DAT0__USDHC3_DAT0 = IOMUX_PAD(0x06FC, 0x0314, 0, 0x0000, 0, 0), + MX6_PAD_SD3_DAT0__UART1_CTS = IOMUX_PAD(0x06FC, 0x0314, 1, 0x0000, 0, 0), + MX6_PAD_SD3_DAT0__UART1_RTS = IOMUX_PAD(0x06FC, 0x0314, 1, 0x08F8, 2, 0), + MX6_PAD_SD3_DAT0__CAN2_TXCAN = IOMUX_PAD(0x06FC, 0x0314, 2, 0x0000, 0, 0), + MX6_PAD_SD3_DAT0__USBOH3_UH3_DFD_OUT_6 = IOMUX_PAD(0x06FC, 0x0314, 3, 0x0000, 0, 0), + MX6_PAD_SD3_DAT0__USBOH3_UH2_DFD_OUT_6 = IOMUX_PAD(0x06FC, 0x0314, 4, 0x0000, 0, 0), + MX6_PAD_SD3_DAT0__GPIO_7_4 = IOMUX_PAD(0x06FC, 0x0314, 5, 0x0000, 0, 0), + MX6_PAD_SD3_DAT0__MIPI_CORE_DPHY_TEST_IN_18 = IOMUX_PAD(0x06FC, 0x0314, 6, 0x0000, 0, 0), + MX6_PAD_SD3_DAT0__ANATOP_ANATOP_TESTO_15 = IOMUX_PAD(0x06FC, 0x0314, 7, 0x0000, 0, 0), MX6_PAD_SD3_DAT1__USDHC3_DAT1 = IOMUX_PAD(0x0700, 0x0318, 0, 0x0000, 0, 0), + MX6_PAD_SD3_DAT1__UART1_CTS = IOMUX_PAD(0x0700, 0x0318, 1, 0x0000, 0, 0), + MX6_PAD_SD3_DAT1__UART1_RTS = IOMUX_PAD(0x0700, 0x0318, 1, 0x08F8, 3, 0), + MX6_PAD_SD3_DAT1__CAN2_RXCAN = IOMUX_PAD(0x0700, 0x0318, 2, 0x07CC, 1, 0), + MX6_PAD_SD3_DAT1__USBOH3_UH3_DFD_OUT_7 = IOMUX_PAD(0x0700, 0x0318, 3, 0x0000, 0, 0), + MX6_PAD_SD3_DAT1__USBOH3_UH2_DFD_OUT_7 = IOMUX_PAD(0x0700, 0x0318, 4, 0x0000, 0, 0), + MX6_PAD_SD3_DAT1__GPIO_7_5 = IOMUX_PAD(0x0700, 0x0318, 5, 0x0000, 0, 0), + MX6_PAD_SD3_DAT1__MIPI_CORE_DPHY_TEST_IN_19 = IOMUX_PAD(0x0700, 0x0318, 6, 0x0000, 0, 0), + MX6_PAD_SD3_DAT1__ANATOP_ANATOP_TESTI_0 = IOMUX_PAD(0x0700, 0x0318, 7, 0x0000, 0, 0), MX6_PAD_SD3_DAT2__USDHC3_DAT2 = IOMUX_PAD(0x0704, 0x031C, 0, 0x0000, 0, 0), + MX6_PAD_SD3_DAT2__PCIE_CTRL_DIAG_STATUS_BUS_MUX_28 = IOMUX_PAD(0x0704, 0x031C, 2, 0x0000, 0, 0), + MX6_PAD_SD3_DAT2__USBOH3_UH3_DFD_OUT_8 = IOMUX_PAD(0x0704, 0x031C, 3, 0x0000, 0, 0), + MX6_PAD_SD3_DAT2__USBOH3_UH2_DFD_OUT_8 = IOMUX_PAD(0x0704, 0x031C, 4, 0x0000, 0, 0), + MX6_PAD_SD3_DAT2__GPIO_7_6 = IOMUX_PAD(0x0704, 0x031C, 5, 0x0000, 0, 0), + MX6_PAD_SD3_DAT2__MIPI_CORE_DPHY_TEST_IN_20 = IOMUX_PAD(0x0704, 0x031C, 6, 0x0000, 0, 0), + MX6_PAD_SD3_DAT2__ANATOP_ANATOP_TESTI_1 = IOMUX_PAD(0x0704, 0x031C, 7, 0x0000, 0, 0), MX6_PAD_SD3_DAT3__USDHC3_DAT3 = IOMUX_PAD(0x0708, 0x0320, 0, 0x0000, 0, 0), + MX6_PAD_SD3_DAT3__UART3_CTS = IOMUX_PAD(0x0708, 0x0320, 1, 0x0000, 0, 0), + MX6_PAD_SD3_DAT3__UART3_RTS = IOMUX_PAD(0x0708, 0x0320, 1, 0x0908, 4, 0), + MX6_PAD_SD3_DAT3__PCIE_CTRL_DIAG_STATUS_BUS_MUX_29 = IOMUX_PAD(0x0708, 0x0320, 2, 0x0000, 0, 0), + MX6_PAD_SD3_DAT3__USBOH3_UH3_DFD_OUT_9 = IOMUX_PAD(0x0708, 0x0320, 3, 0x0000, 0, 0), + MX6_PAD_SD3_DAT3__USBOH3_UH2_DFD_OUT_9 = IOMUX_PAD(0x0708, 0x0320, 4, 0x0000, 0, 0), + MX6_PAD_SD3_DAT3__GPIO_7_7 = IOMUX_PAD(0x0708, 0x0320, 5, 0x0000, 0, 0), + MX6_PAD_SD3_DAT3__MIPI_CORE_DPHY_TEST_IN_21 = IOMUX_PAD(0x0708, 0x0320, 6, 0x0000, 0, 0), + MX6_PAD_SD3_DAT3__ANATOP_ANATOP_TESTI_2 = IOMUX_PAD(0x0708, 0x0320, 7, 0x0000, 0, 0), + MX6_PAD_SD3_DAT4__USDHC3_DAT4 = IOMUX_PAD(0x070C, 0x0324, 0, 0x0000, 0, 0), + MX6_PAD_SD3_DAT4__UART2_TXD = IOMUX_PAD(0x070C, 0x0324, 1, 0x0000, 0, 0), + MX6_PAD_SD3_DAT4__UART2_RXD = IOMUX_PAD(0x070C, 0x0324, 1, 0x0904, 4, 0), + MX6_PAD_SD3_DAT4__PCIE_CTRL_DIAG_STATUS_BUS_MUX_27 = IOMUX_PAD(0x070C, 0x0324, 2, 0x0000, 0, 0), + MX6_PAD_SD3_DAT4__USBOH3_UH3_DFD_OUT_3 = IOMUX_PAD(0x070C, 0x0324, 3, 0x0000, 0, 0), + MX6_PAD_SD3_DAT4__USBOH3_UH2_DFD_OUT_3 = IOMUX_PAD(0x070C, 0x0324, 4, 0x0000, 0, 0), + MX6_PAD_SD3_DAT4__GPIO_7_1 = IOMUX_PAD(0x070C, 0x0324, 5, 0x0000, 0, 0), + MX6_PAD_SD3_DAT4__MIPI_CORE_DPHY_TEST_IN_15 = IOMUX_PAD(0x070C, 0x0324, 6, 0x0000, 0, 0), + MX6_PAD_SD3_DAT4__ANATOP_ANATOP_TESTO_12 = IOMUX_PAD(0x070C, 0x0324, 7, 0x0000, 0, 0), + MX6_PAD_SD3_DAT5__USDHC3_DAT5 = IOMUX_PAD(0x0710, 0x0328, 0, 0x0000, 0, 0), + MX6_PAD_SD3_DAT5__UART2_TXD = IOMUX_PAD(0x0710, 0x0328, 1, 0x0000, 0, 0), + MX6_PAD_SD3_DAT5__UART2_RXD = IOMUX_PAD(0x0710, 0x0328, 1, 0x0904, 5, 0), + MX6_PAD_SD3_DAT5__PCIE_CTRL_DIAG_STATUS_BUS_MUX_26 = IOMUX_PAD(0x0710, 0x0328, 2, 0x0000, 0, 0), + MX6_PAD_SD3_DAT5__USBOH3_UH3_DFD_OUT_2 = IOMUX_PAD(0x0710, 0x0328, 3, 0x0000, 0, 0), + MX6_PAD_SD3_DAT5__USBOH3_UH2_DFD_OUT_2 = IOMUX_PAD(0x0710, 0x0328, 4, 0x0000, 0, 0), MX6_PAD_SD3_DAT5__GPIO_7_0 = IOMUX_PAD(0x0710, 0x0328, 5, 0x0000, 0, 0), + MX6_PAD_SD3_DAT5__MIPI_CORE_DPHY_TEST_IN_14 = IOMUX_PAD(0x0710, 0x0328, 6, 0x0000, 0, 0), + MX6_PAD_SD3_DAT5__ANATOP_ANATOP_TESTO_11 = IOMUX_PAD(0x0710, 0x0328, 7, 0x0000, 0, 0), + MX6_PAD_SD3_DAT6__USDHC3_DAT6 = IOMUX_PAD(0x0714, 0x032C, 0, 0x0000, 0, 0), + MX6_PAD_SD3_DAT6__UART1_TXD = IOMUX_PAD(0x0714, 0x032C, 1, 0x0000, 0, 0), MX6_PAD_SD3_DAT6__UART1_RXD = IOMUX_PAD(0x0714, 0x032C, 1, 0x08FC, 2, 0), + MX6_PAD_SD3_DAT6__PCIE_CTRL_DIAG_STATUS_BUS_MUX_25 = IOMUX_PAD(0x0714, 0x032C, 2, 0x0000, 0, 0), + MX6_PAD_SD3_DAT6__USBOH3_UH3_DFD_OUT_1 = IOMUX_PAD(0x0714, 0x032C, 3, 0x0000, 0, 0), + MX6_PAD_SD3_DAT6__USBOH3_UH2_DFD_OUT_1 = IOMUX_PAD(0x0714, 0x032C, 4, 0x0000, 0, 0), + MX6_PAD_SD3_DAT6__GPIO_6_18 = IOMUX_PAD(0x0714, 0x032C, 5, 0x0000, 0, 0), + MX6_PAD_SD3_DAT6__MIPI_CORE_DPHY_TEST_IN_13 = IOMUX_PAD(0x0714, 0x032C, 6, 0x0000, 0, 0), + MX6_PAD_SD3_DAT6__ANATOP_ANATOP_TESTO_10 = IOMUX_PAD(0x0714, 0x032C, 7, 0x0000, 0, 0), + MX6_PAD_SD3_DAT7__USDHC3_DAT7 = IOMUX_PAD(0x0718, 0x0330, 0, 0x0000, 0, 0), MX6_PAD_SD3_DAT7__UART1_TXD = IOMUX_PAD(0x0718, 0x0330, 1, 0x0000, 0, 0), + MX6_PAD_SD3_DAT7__UART1_RXD = IOMUX_PAD(0x0718, 0x0330, 1, 0x08FC, 3, 0), + MX6_PAD_SD3_DAT7__PCIE_CTRL_DIAG_STATUS_BUS_MUX_24 = IOMUX_PAD(0x0718, 0x0330, 2, 0x0000, 0, 0), + MX6_PAD_SD3_DAT7__USBOH3_UH3_DFD_OUT_0 = IOMUX_PAD(0x0718, 0x0330, 3, 0x0000, 0, 0), + MX6_PAD_SD3_DAT7__USBOH3_UH2_DFD_OUT_0 = IOMUX_PAD(0x0718, 0x0330, 4, 0x0000, 0, 0), + MX6_PAD_SD3_DAT7__GPIO_6_17 = IOMUX_PAD(0x0718, 0x0330, 5, 0x0000, 0, 0), + MX6_PAD_SD3_DAT7__MIPI_CORE_DPHY_TEST_IN_12 = IOMUX_PAD(0x0718, 0x0330, 6, 0x0000, 0, 0), + MX6_PAD_SD3_DAT7__ANATOP_USBPHY2_TSTO_PLL_CLK20DIV = IOMUX_PAD(0x0718, 0x0330, 7, 0x0000, 0, 0), + MX6_PAD_SD3_RST__USDHC3_RST = IOMUX_PAD(0x071C, 0x0334, 0, 0x0000, 0, 0), + MX6_PAD_SD3_RST__UART3_CTS = IOMUX_PAD(0x071C, 0x0334, 1, 0x0000, 0, 0), + MX6_PAD_SD3_RST__UART3_RTS = IOMUX_PAD(0x071C, 0x0334, 1, 0x0908, 5, 0), + MX6_PAD_SD3_RST__PCIE_CTRL_DIAG_STATUS_BUS_MUX_30 = IOMUX_PAD(0x071C, 0x0334, 2, 0x0000, 0, 0), + MX6_PAD_SD3_RST__USBOH3_UH3_DFD_OUT_10 = IOMUX_PAD(0x071C, 0x0334, 3, 0x0000, 0, 0), + MX6_PAD_SD3_RST__USBOH3_UH2_DFD_OUT_10 = IOMUX_PAD(0x071C, 0x0334, 4, 0x0000, 0, 0), + MX6_PAD_SD3_RST__GPIO_7_8 = IOMUX_PAD(0x071C, 0x0334, 5, 0x0000, 0, 0), + MX6_PAD_SD3_RST__MIPI_CORE_DPHY_TEST_IN_22 = IOMUX_PAD(0x071C, 0x0334, 6, 0x0000, 0, 0), + MX6_PAD_SD3_RST__ANATOP_ANATOP_TESTI_3 = IOMUX_PAD(0x071C, 0x0334, 7, 0x0000, 0, 0), MX6_PAD_SD4_CLK__USDHC4_CLK = IOMUX_PAD(0x0720, 0x0338, 0, 0x0938, 1, 0), + MX6_PAD_SD4_CLK__RAWNAND_WRN = IOMUX_PAD(0x0720, 0x0338, 1, 0x0000, 0, 0), + MX6_PAD_SD4_CLK__UART3_TXD = IOMUX_PAD(0x0720, 0x0338, 2, 0x0000, 0, 0), + MX6_PAD_SD4_CLK__UART3_RXD = IOMUX_PAD(0x0720, 0x0338, 2, 0x090C, 2, 0), + MX6_PAD_SD4_CLK__PCIE_CTRL_DIAG_STATUS_BUS_MUX_6 = IOMUX_PAD(0x0720, 0x0338, 4, 0x0000, 0, 0), + MX6_PAD_SD4_CLK__GPIO_7_10 = IOMUX_PAD(0x0720, 0x0338, 5, 0x0000, 0, 0), MX6_PAD_SD4_CMD__USDHC4_CMD = IOMUX_PAD(0x0724, 0x033C, 0 | IOMUX_CONFIG_SION, 0x0000, 0, 0), + MX6_PAD_SD4_CMD__RAWNAND_RDN = IOMUX_PAD(0x0724, 0x033C, 1, 0x0000, 0, 0), + MX6_PAD_SD4_CMD__UART3_TXD = IOMUX_PAD(0x0724, 0x033C, 2, 0x0000, 0, 0), + MX6_PAD_SD4_CMD__UART3_RXD = IOMUX_PAD(0x0724, 0x033C, 2, 0x090C, 3, 0), + MX6_PAD_SD4_CMD__PCIE_CTRL_DIAG_STATUS_BUS_MUX_5 = IOMUX_PAD(0x0724, 0x033C, 4, 0x0000, 0, 0), + MX6_PAD_SD4_CMD__GPIO_7_9 = IOMUX_PAD(0x0724, 0x033C, 5, 0x0000, 0, 0), + MX6_PAD_SD4_DAT0__RAWNAND_D8 = IOMUX_PAD(0x0728, 0x0340, 0, 0x0000, 0, 0), MX6_PAD_SD4_DAT0__USDHC4_DAT0 = IOMUX_PAD(0x0728, 0x0340, 1, 0x0000, 0, 0), + MX6_PAD_SD4_DAT0__RAWNAND_DQS = IOMUX_PAD(0x0728, 0x0340, 2, 0x0000, 0, 0), + MX6_PAD_SD4_DAT0__USBOH3_UH2_DFD_OUT_24 = IOMUX_PAD(0x0728, 0x0340, 3, 0x0000, 0, 0), + MX6_PAD_SD4_DAT0__USBOH3_UH3_DFD_OUT_24 = IOMUX_PAD(0x0728, 0x0340, 4, 0x0000, 0, 0), + MX6_PAD_SD4_DAT0__GPIO_2_8 = IOMUX_PAD(0x0728, 0x0340, 5, 0x0000, 0, 0), + MX6_PAD_SD4_DAT0__IPU1_IPU_DIAG_BUS_8 = IOMUX_PAD(0x0728, 0x0340, 6, 0x0000, 0, 0), + MX6_PAD_SD4_DAT1__RAWNAND_D9 = IOMUX_PAD(0x072C, 0x0344, 0, 0x0000, 0, 0), MX6_PAD_SD4_DAT1__USDHC4_DAT1 = IOMUX_PAD(0x072C, 0x0344, 1, 0x0000, 0, 0), + MX6_PAD_SD4_DAT1__PWM3_PWMO = IOMUX_PAD(0x072C, 0x0344, 2, 0x0000, 0, 0), + MX6_PAD_SD4_DAT1__USBOH3_UH2_DFD_OUT_25 = IOMUX_PAD(0x072C, 0x0344, 3, 0x0000, 0, 0), + MX6_PAD_SD4_DAT1__USBOH3_UH3_DFD_OUT_25 = IOMUX_PAD(0x072C, 0x0344, 4, 0x0000, 0, 0), + MX6_PAD_SD4_DAT1__GPIO_2_9 = IOMUX_PAD(0x072C, 0x0344, 5, 0x0000, 0, 0), + MX6_PAD_SD4_DAT1__IPU1_IPU_DIAG_BUS_9 = IOMUX_PAD(0x072C, 0x0344, 6, 0x0000, 0, 0), + MX6_PAD_SD4_DAT2__RAWNAND_D10 = IOMUX_PAD(0x0730, 0x0348, 0, 0x0000, 0, 0), MX6_PAD_SD4_DAT2__USDHC4_DAT2 = IOMUX_PAD(0x0730, 0x0348, 1, 0x0000, 0, 0), + MX6_PAD_SD4_DAT2__PWM4_PWMO = IOMUX_PAD(0x0730, 0x0348, 2, 0x0000, 0, 0), + MX6_PAD_SD4_DAT2__USBOH3_UH2_DFD_OUT_26 = IOMUX_PAD(0x0730, 0x0348, 3, 0x0000, 0, 0), + MX6_PAD_SD4_DAT2__USBOH3_UH3_DFD_OUT_26 = IOMUX_PAD(0x0730, 0x0348, 4, 0x0000, 0, 0), + MX6_PAD_SD4_DAT2__GPIO_2_10 = IOMUX_PAD(0x0730, 0x0348, 5, 0x0000, 0, 0), + MX6_PAD_SD4_DAT2__IPU1_IPU_DIAG_BUS_10 = IOMUX_PAD(0x0730, 0x0348, 6, 0x0000, 0, 0), + MX6_PAD_SD4_DAT3__RAWNAND_D11 = IOMUX_PAD(0x0734, 0x034C, 0, 0x0000, 0, 0), MX6_PAD_SD4_DAT3__USDHC4_DAT3 = IOMUX_PAD(0x0734, 0x034C, 1, 0x0000, 0, 0), + MX6_PAD_SD4_DAT3__USBOH3_UH2_DFD_OUT_27 = IOMUX_PAD(0x0734, 0x034C, 3, 0x0000, 0, 0), + MX6_PAD_SD4_DAT3__USBOH3_UH3_DFD_OUT_27 = IOMUX_PAD(0x0734, 0x034C, 4, 0x0000, 0, 0), + MX6_PAD_SD4_DAT3__GPIO_2_11 = IOMUX_PAD(0x0734, 0x034C, 5, 0x0000, 0, 0), + MX6_PAD_SD4_DAT3__IPU1_IPU_DIAG_BUS_11 = IOMUX_PAD(0x0734, 0x034C, 6, 0x0000, 0, 0), + MX6_PAD_SD4_DAT4__RAWNAND_D12 = IOMUX_PAD(0x0738, 0x0350, 0, 0x0000, 0, 0), + MX6_PAD_SD4_DAT4__USDHC4_DAT4 = IOMUX_PAD(0x0738, 0x0350, 1, 0x0000, 0, 0), + MX6_PAD_SD4_DAT4__UART2_TXD = IOMUX_PAD(0x0738, 0x0350, 2, 0x0000, 0, 0), + MX6_PAD_SD4_DAT4__UART2_RXD = IOMUX_PAD(0x0738, 0x0350, 2, 0x0904, 6, 0), + MX6_PAD_SD4_DAT4__USBOH3_UH2_DFD_OUT_28 = IOMUX_PAD(0x0738, 0x0350, 3, 0x0000, 0, 0), + MX6_PAD_SD4_DAT4__USBOH3_UH3_DFD_OUT_28 = IOMUX_PAD(0x0738, 0x0350, 4, 0x0000, 0, 0), + MX6_PAD_SD4_DAT4__GPIO_2_12 = IOMUX_PAD(0x0738, 0x0350, 5, 0x0000, 0, 0), + MX6_PAD_SD4_DAT4__IPU1_IPU_DIAG_BUS_12 = IOMUX_PAD(0x0738, 0x0350, 6, 0x0000, 0, 0), + MX6_PAD_SD4_DAT5__RAWNAND_D13 = IOMUX_PAD(0x073C, 0x0354, 0, 0x0000, 0, 0), + MX6_PAD_SD4_DAT5__USDHC4_DAT5 = IOMUX_PAD(0x073C, 0x0354, 1, 0x0000, 0, 0), + MX6_PAD_SD4_DAT5__UART2_CTS = IOMUX_PAD(0x073C, 0x0354, 2, 0x0000, 0, 0), + MX6_PAD_SD4_DAT5__UART2_RTS = IOMUX_PAD(0x073C, 0x0354, 2, 0x0900, 4, 0), + MX6_PAD_SD4_DAT5__USBOH3_UH2_DFD_OUT_29 = IOMUX_PAD(0x073C, 0x0354, 3, 0x0000, 0, 0), + MX6_PAD_SD4_DAT5__USBOH3_UH3_DFD_OUT_29 = IOMUX_PAD(0x073C, 0x0354, 4, 0x0000, 0, 0), + MX6_PAD_SD4_DAT5__GPIO_2_13 = IOMUX_PAD(0x073C, 0x0354, 5, 0x0000, 0, 0), + MX6_PAD_SD4_DAT5__IPU1_IPU_DIAG_BUS_13 = IOMUX_PAD(0x073C, 0x0354, 6, 0x0000, 0, 0), + MX6_PAD_SD4_DAT6__RAWNAND_D14 = IOMUX_PAD(0x0740, 0x0358, 0, 0x0000, 0, 0), + MX6_PAD_SD4_DAT6__USDHC4_DAT6 = IOMUX_PAD(0x0740, 0x0358, 1, 0x0000, 0, 0), + MX6_PAD_SD4_DAT6__UART2_CTS = IOMUX_PAD(0x0740, 0x0358, 2, 0x0000, 0, 0), + MX6_PAD_SD4_DAT6__UART2_RTS = IOMUX_PAD(0x0740, 0x0358, 2, 0x0900, 5, 0), + MX6_PAD_SD4_DAT6__USBOH3_UH2_DFD_OUT_30 = IOMUX_PAD(0x0740, 0x0358, 3, 0x0000, 0, 0), + MX6_PAD_SD4_DAT6__USBOH3_UH3_DFD_OUT_30 = IOMUX_PAD(0x0740, 0x0358, 4, 0x0000, 0, 0), + MX6_PAD_SD4_DAT6__GPIO_2_14 = IOMUX_PAD(0x0740, 0x0358, 5, 0x0000, 0, 0), + MX6_PAD_SD4_DAT6__IPU1_IPU_DIAG_BUS_14 = IOMUX_PAD(0x0740, 0x0358, 6, 0x0000, 0, 0), + MX6_PAD_SD4_DAT7__RAWNAND_D15 = IOMUX_PAD(0x0744, 0x035C, 0, 0x0000, 0, 0), + MX6_PAD_SD4_DAT7__USDHC4_DAT7 = IOMUX_PAD(0x0744, 0x035C, 1, 0x0000, 0, 0), + MX6_PAD_SD4_DAT7__UART2_TXD = IOMUX_PAD(0x0744, 0x035C, 2, 0x0000, 0, 0), + MX6_PAD_SD4_DAT7__UART2_RXD = IOMUX_PAD(0x0744, 0x035C, 2, 0x0904, 7, 0), + MX6_PAD_SD4_DAT7__USBOH3_UH2_DFD_OUT_31 = IOMUX_PAD(0x0744, 0x035C, 3, 0x0000, 0, 0), + MX6_PAD_SD4_DAT7__USBOH3_UH3_DFD_OUT_31 = IOMUX_PAD(0x0744, 0x035C, 4, 0x0000, 0, 0), + MX6_PAD_SD4_DAT7__GPIO_2_15 = IOMUX_PAD(0x0744, 0x035C, 5, 0x0000, 0, 0), + MX6_PAD_SD4_DAT7__IPU1_IPU_DIAG_BUS_15 = IOMUX_PAD(0x0744, 0x035C, 6, 0x0000, 0, 0), }; #endif /* __ASM_ARCH_MX6_MX6DL_PINS_H__ */
The SabreSD platform is available with i.MX6Q or i.MX6DL. This patch adds the support of the i.MX6DL. The config file and the board directory are renamed to remove the reference to the MX6Q.
Signed-off-by: Pierre Aubert p.aubert@staubli.com CC: Stefano Babic sbabic@denx.de --- Changes in v2: - update MAINTAINERS - code cleanup - remove the Soc type from the board name
MAINTAINERS | 2 +- .../freescale/{mx6qsabresd => mx6sabresd}/Makefile | 2 +- .../mx6qsabresd.c => mx6sabresd/mx6sabresd.c} | 7 ++----- boards.cfg | 5 +++-- include/configs/mx6qsabreauto.h | 2 +- .../{mx6qsabre_common.h => mx6sabre_common.h} | 1 - include/configs/{mx6qsabresd.h => mx6sabresd.h} | 2 +- 7 files changed, 9 insertions(+), 12 deletions(-) rename board/freescale/{mx6qsabresd => mx6sabresd}/Makefile (98%) rename board/freescale/{mx6qsabresd/mx6qsabresd.c => mx6sabresd/mx6sabresd.c} (98%) rename include/configs/{mx6qsabre_common.h => mx6sabre_common.h} (99%) rename include/configs/{mx6qsabresd.h => mx6sabresd.h} (97%)
diff --git a/MAINTAINERS b/MAINTAINERS index 643a5ac..50ca73c 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -661,7 +661,7 @@ Fabio Estevam fabio.estevam@freescale.com mx31pdk i.MX31 mx53ard i.MX53 mx53smd i.MX53 - mx6qsabresd i.MX6Q + mx6sabresd i.MX6Q/DL mx6qsabreauto i.MX6Q wandboard i.MX6DL/S
diff --git a/board/freescale/mx6qsabresd/Makefile b/board/freescale/mx6sabresd/Makefile similarity index 98% rename from board/freescale/mx6qsabresd/Makefile rename to board/freescale/mx6sabresd/Makefile index 5693772..ff3c94b 100644 --- a/board/freescale/mx6qsabresd/Makefile +++ b/board/freescale/mx6sabresd/Makefile @@ -23,7 +23,7 @@ include $(TOPDIR)/config.mk
LIB = $(obj)lib$(BOARD).o
-COBJS := mx6qsabresd.o +COBJS := mx6sabresd.o
SRCS := $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) diff --git a/board/freescale/mx6qsabresd/mx6qsabresd.c b/board/freescale/mx6sabresd/mx6sabresd.c similarity index 98% rename from board/freescale/mx6qsabresd/mx6qsabresd.c rename to board/freescale/mx6sabresd/mx6sabresd.c index 0d7cb9e..1b6805b 100644 --- a/board/freescale/mx6qsabresd/mx6qsabresd.c +++ b/board/freescale/mx6sabresd/mx6sabresd.c @@ -17,12 +17,10 @@ * GNU General Public License for more details. */
-#include <common.h> -#include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/imx-regs.h> #include <asm/arch/iomux.h> -#include <asm/arch/mx6q_pins.h> +#include <asm/arch/mx6-pins.h> #include <asm/errno.h> #include <asm/gpio.h> #include <asm/imx-common/iomux-v3.h> @@ -291,7 +289,6 @@ int board_late_init(void)
int checkboard(void) { - puts("Board: MX6Q-SabreSD\n"); - + puts("Board: MX6-SabreSD\n"); return 0; } diff --git a/boards.cfg b/boards.cfg index 31483d6..427cb11 100644 --- a/boards.cfg +++ b/boards.cfg @@ -256,9 +256,10 @@ mx53smd arm armv7 mx53smd freesca ima3-mx53 arm armv7 ima3-mx53 esg mx5 ima3-mx53:IMX_CONFIG=board/esg/ima3-mx53/imximage.cfg vision2 arm armv7 vision2 ttcontrol mx5 vision2:IMX_CONFIG=board/ttcontrol/vision2/imximage_hynix.cfg mx6qarm2 arm armv7 mx6qarm2 freescale mx6 mx6qarm2:IMX_CONFIG=board/freescale/mx6qarm2/imximage.cfg -mx6qsabreauto arm armv7 mx6qsabreauto freescale mx6 mx6qsabreauto:IMX_CONFIG=board/freescale/mx6qsabreauto/imximage.cfg +mx6qsabreauto arm armv7 mx6qsabreauto freescale mx6 mx6qsabreauto:IMX_CONFIG=board/freescale/mx6qsabreauto/imximage.cfg,MX6Q mx6qsabrelite arm armv7 mx6qsabrelite freescale mx6 mx6qsabrelite:IMX_CONFIG=board/freescale/imx/ddr/mx6q_4x_mt41j128.cfg -mx6qsabresd arm armv7 mx6qsabresd freescale mx6 mx6qsabresd:IMX_CONFIG=board/freescale/imx/ddr/mx6q_4x_mt41j128.cfg +mx6qsabresd arm armv7 mx6sabresd freescale mx6 mx6sabresd:IMX_CONFIG=board/freescale/imx/ddr/mx6q_4x_mt41j128.cfg,MX6Q +mx6dlsabresd arm armv7 mx6sabresd freescale mx6 mx6sabresd:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl.cfg,MX6DL eco5pk arm armv7 eco5pk 8dtech omap3 nitrogen6dl arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl.cfg,MX6DL,DDR_MB=1024 nitrogen6dl2g arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl2g.cfg,MX6DL,DDR_MB=2048 diff --git a/include/configs/mx6qsabreauto.h b/include/configs/mx6qsabreauto.h index 1583c11..099839a 100644 --- a/include/configs/mx6qsabreauto.h +++ b/include/configs/mx6qsabreauto.h @@ -30,7 +30,7 @@ #define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) #define CONFIG_MXC_USB_FLAGS 0
-#include "mx6qsabre_common.h" +#include "mx6sabre_common.h"
#define CONFIG_SYS_FSL_USDHC_NUM 2 #if defined(CONFIG_ENV_IS_IN_MMC) diff --git a/include/configs/mx6qsabre_common.h b/include/configs/mx6sabre_common.h similarity index 99% rename from include/configs/mx6qsabre_common.h rename to include/configs/mx6sabre_common.h index f5f115f..203158d 100644 --- a/include/configs/mx6qsabre_common.h +++ b/include/configs/mx6sabre_common.h @@ -18,7 +18,6 @@ #define __MX6QSABRE_COMMON_CONFIG_H
#define CONFIG_MX6 -#define CONFIG_MX6Q
#include "mx6_common.h"
diff --git a/include/configs/mx6qsabresd.h b/include/configs/mx6sabresd.h similarity index 97% rename from include/configs/mx6qsabresd.h rename to include/configs/mx6sabresd.h index 3b8d752..e7facd3 100644 --- a/include/configs/mx6qsabresd.h +++ b/include/configs/mx6sabresd.h @@ -24,7 +24,7 @@ #define CONFIG_DEFAULT_FDT_FILE "imx6q-sabresd.dtb" #define PHYS_SDRAM_SIZE (1u * 1024 * 1024 * 1024)
#define CONFIG_SYS_FSL_USDHC_NUM 3 #if defined(CONFIG_ENV_IS_IN_MMC)
participants (6)
Eric Bénard
Fabio Estevam
Pierre AUBERT
Pierre Aubert
Stefano Babic
