[U-Boot] [PATCH 2/3] net: sh-eth: add support for SH7753 instead of SH7752
SH7753 has two fast ethernet controllers and two gigabit ethernet controllers. It is similar to SH7757.
This patch changes the support for SH7752 to SH7753.
Signed-off-by: Yoshihiro Shimoda yoshihiro.shimoda.uh@renesas.com --- drivers/net/sh_eth.h | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/drivers/net/sh_eth.h b/drivers/net/sh_eth.h index 8aa7109..579b8ac 100644 --- a/drivers/net/sh_eth.h +++ b/drivers/net/sh_eth.h @@ -287,7 +287,7 @@ static const u16 sh_eth_offset_fast_sh4[SH_ETH_MAX_REGISTER_OFFSET] = { #if defined(CONFIG_CPU_SH7763) || defined(CONFIG_CPU_SH7734) #define SH_ETH_TYPE_GETHER #define BASE_IO_ADDR 0xfee00000 -#elif defined(CONFIG_CPU_SH7757) || defined(CONFIG_CPU_SH7752) +#elif defined(CONFIG_CPU_SH7757) || defined(CONFIG_CPU_SH7753) #if defined(CONFIG_SH_ETHER_USE_GETHER) #define SH_ETH_TYPE_GETHER #define BASE_IO_ADDR 0xfee00000
Shimoda, Yoshihiro
