[U-Boot-Users] Linux kernel hang (infinite loop)
Hello all,
I'm using U-boot to bring up a custom 440gp-based board. We are able to transfer the kernel image (uImage) to the target board's memory and jump to it. But, the kernel seems to hang after that.
We have verified that the board info struct and the clock frequencies are ok. We also have a BDI2000 hardware debugger with us, but we are unable to set any breakpoints using this (both using telnet or using gdb). However, I can use the telnet interface and single-step the 440gp after it seems to hang. I found that 440gp is infinitely looping through the "DataTLBError" routine.
It is unclear to me what might have caused this in the first place. Has anyone seen this behaviour before?
We are currently working on getting breakpoints to work using the BDI2000.
Any help is greatly appreciated.
Regards, G.Sibi
Hello,
Did you try looking at the logbuffer:
http://www.denx.de/wiki/DULG/LinuxPostMortemAnalysis
I assume that you have a linux port for your "custom" board and are *not* using the linux kernel image for some other 440 board, right?
What is BREAKMODE set to in your BDI2000 config file? Try using "HARD".
Best regards, Stefan
In message 513a5e60607171652v7391e6afn58e4c55a17fcf059@mail.gmail.com you wrote:
And what has this to do with U-Boot?
You're off topic here.
Hi guys,
I am now working on ELDK4.1+u-boot.1.3.1 in my Ubuntu linux, however I encounter a weird problem when I tried to compile u-boot each time with command: make distclean;make B2_config;make clean;make (see log)
But I can compile with command: make distclean;make B2_config;make clean;make;make (see log)
Why I can't compile u-boot in the first time? while I can compile it in the second time.
log as below: denny@ubuntu:/arm44b0/u-boot-1.3.1$ make clean;make find /arm44b0/u-boot-1.3.1 -type f \ ( -name 'core' -o -name '*.bak' -o -name '*~' \ -o -name '*.o' -o -name '*.a' ) -print \ | xargs rm -f rm -f examples/hello_world examples/timer \ examples/eepro100_eeprom examples/sched \ examples/mem_to_mem_idma2intr examples/82559_eeprom \ examples/smc91111_eeprom examples/interrupt \ examples/test_burst rm -f tools/img2srec tools/mkimage tools/envcrc \ tools/gen_eth_addr tools/ubsha1 rm -f tools/mpc86x_clk tools/ncb rm -f tools/easylogo/easylogo tools/bmp_logo rm -f tools/gdb/astest tools/gdb/gdbcont tools/gdb/gdbsend rm -f tools/env/fw_printenv tools/env/fw_setenv rm -f board/cray/L1/bootscript.c board/cray/L1/bootscript.image rm -f board/netstar/eeprom board/netstar/crcek board/netstar/crcit rm -f board/netstar/*.srec board/netstar/*.bin rm -f board/trab/trab_fkt board/voiceblue/eeprom rm -f board/integratorap/u-boot.lds board/integratorcp/u-boot.lds rm -f board/bf533-ezkit/u-boot.lds board/bf533-stamp/u-boot.lds rm -f board/bf537-stamp/u-boot.lds board/bf561-ezkit/u-boot.lds rm -f include/bmp_logo.h rm -f nand_spl/u-boot-spl nand_spl/u-boot-spl.map for dir in tools examples ; do make -C $dir _depend ; done make[1]: Entering directory `/arm44b0/u-boot-1.3.1/tools' make[1]: Nothing to be done for `_depend'. make[1]: Leaving directory `/arm44b0/u-boot-1.3.1/tools' make[1]: Entering directory `/arm44b0/u-boot-1.3.1/examples' make[1]: Nothing to be done for `_depend'. make[1]: Leaving directory `/arm44b0/u-boot-1.3.1/examples' make -C tools all make[1]: Entering directory `/arm44b0/u-boot-1.3.1/tools' gcc -Wall -pedantic -idirafter /arm44b0/u-boot-1.3.1/include -idirafter /arm44b0/u-boot-1.3.1/include2 -idirafter /arm44b0/u-boot-1.3.1/include -DTEXT_BASE=0x0C100000 -DUSE_HOSTCC -O -c -o img2srec.o img2srec.c gcc -Wall -pedantic -idirafter /arm44b0/u-boot-1.3.1/include -idirafter /arm44b0/u-boot-1.3.1/include2 -idirafter /arm44b0/u-boot-1.3.1/include -DTEXT_BASE=0x0C100000 -DUSE_HOSTCC -O -o img2srec img2srec.o strip img2srec gcc -g -Wall -pedantic -idirafter /arm44b0/u-boot-1.3.1/include -idirafter /arm44b0/u-boot-1.3.1/include2 -idirafter /arm44b0/u-boot-1.3.1/include -DTEXT_BASE=0x0C100000 -DUSE_HOSTCC -O -c -o mkimage.o mkimage.c gcc -g -Wall -pedantic -idirafter /arm44b0/u-boot-1.3.1/include -idirafter /arm44b0/u-boot-1.3.1/include2 -idirafter /arm44b0/u-boot-1.3.1/include -DTEXT_BASE=0x0C100000 -DUSE_HOSTCC -O -c -o crc32.o crc32.c gcc -g -Wall -pedantic -idirafter /arm44b0/u-boot-1.3.1/include -idirafter /arm44b0/u-boot-1.3.1/include2 -idirafter /arm44b0/u-boot-1.3.1/include -DTEXT_BASE=0x0C100000 -DUSE_HOSTCC -O -c -o sha1.o sha1.c sha1.c: In function 'sha1_update': sha1.c:245: warning: implicit declaration of function 'memcpy' sha1.c:245: warning: incompatible implicit declaration of built-in function 'memcpy' sha1.c:259: warning: incompatible implicit declaration of built-in function 'memcpy' sha1.c: In function 'sha1_hmac': sha1.c:323: warning: implicit declaration of function 'memset' sha1.c:323: warning: incompatible implicit declaration of built-in function 'memset' gcc -Wall -pedantic -idirafter /arm44b0/u-boot-1.3.1/include -idirafter /arm44b0/u-boot-1.3.1/include2 -idirafter /arm44b0/u-boot-1.3.1/include -DTEXT_BASE=0x0C100000 -DUSE_HOSTCC -O -o mkimage mkimage.o crc32.o sha1.o strip mkimage gcc -g -Wall -pedantic -idirafter /arm44b0/u-boot-1.3.1/include -idirafter /arm44b0/u-boot-1.3.1/include2 -idirafter /arm44b0/u-boot-1.3.1/include -DTEXT_BASE=0x0C100000 -DUSE_HOSTCC -O -c -o envcrc.o envcrc.c gcc -g -idirafter /arm44b0/u-boot-1.3.1/include -idirafter /arm44b0/u-boot-1.3.1/include2 -idirafter /arm44b0/u-boot-1.3.1/include -DTEXT_BASE=0x0C100000 -DUSE_HOSTCC -c -o environment.o environment.c gcc -Wall -pedantic -idirafter /arm44b0/u-boot-1.3.1/include -idirafter /arm44b0/u-boot-1.3.1/include2 -idirafter /arm44b0/u-boot-1.3.1/include -DTEXT_BASE=0x0C100000 -DUSE_HOSTCC -O -o envcrc envcrc.o crc32.o environment.o sha1.o gcc -g -Wall -pedantic -idirafter /arm44b0/u-boot-1.3.1/include -idirafter /arm44b0/u-boot-1.3.1/include2 -idirafter /arm44b0/u-boot-1.3.1/include -DTEXT_BASE=0x0C100000 -DUSE_HOSTCC -O -c -o ubsha1.o ubsha1.c gcc -Wall -pedantic -idirafter /arm44b0/u-boot-1.3.1/include -idirafter /arm44b0/u-boot-1.3.1/include2 -idirafter /arm44b0/u-boot-1.3.1/include -DTEXT_BASE=0x0C100000 -DUSE_HOSTCC -O -o ubsha1 ubsha1.o sha1.o gcc -g -Wall -pedantic -idirafter /arm44b0/u-boot-1.3.1/include -idirafter /arm44b0/u-boot-1.3.1/include2 -idirafter /arm44b0/u-boot-1.3.1/include -DTEXT_BASE=0x0C100000 -DUSE_HOSTCC -O -c -o gen_eth_addr.o gen_eth_addr.c gcc -Wall -pedantic -idirafter /arm44b0/u-boot-1.3.1/include -idirafter /arm44b0/u-boot-1.3.1/include2 -idirafter /arm44b0/u-boot-1.3.1/include -DTEXT_BASE=0x0C100000 -DUSE_HOSTCC -O -o gen_eth_addr gen_eth_addr.o strip gen_eth_addr gcc -Wall -pedantic -idirafter /arm44b0/u-boot-1.3.1/include -idirafter /arm44b0/u-boot-1.3.1/include2 -idirafter /arm44b0/u-boot-1.3.1/include -DTEXT_BASE=0x0C100000 -DUSE_HOSTCC -O -c -o bmp_logo.o bmp_logo.c gcc -Wall -pedantic -idirafter /arm44b0/u-boot-1.3.1/include -idirafter /arm44b0/u-boot-1.3.1/include2 -idirafter /arm44b0/u-boot-1.3.1/include -DTEXT_BASE=0x0C100000 -DUSE_HOSTCC -O -o bmp_logo bmp_logo.o strip bmp_logo /bmp_logo logos/denx.bmp >/arm44b0/u-boot-1.3.1/include/bmp_logo.h /bmp_logo: 1: Syntax error: word unexpected (expecting ")") make[1]: *** [/arm44b0/u-boot-1.3.1/include/bmp_logo.h] Error 2 make[1]: Leaving directory `/arm44b0/u-boot-1.3.1/tools' make: *** [tools] Error 2 denny@ubuntu:/arm44b0/u-boot-1.3.1$ make for dir in tools examples ; do make -C $dir _depend ; done make[1]: Entering directory `/arm44b0/u-boot-1.3.1/tools' make[1]: Nothing to be done for `_depend'. make[1]: Leaving directory `/arm44b0/u-boot-1.3.1/tools' make[1]: Entering directory `/arm44b0/u-boot-1.3.1/examples' make[1]: Nothing to be done for `_depend'. make[1]: Leaving directory `/arm44b0/u-boot-1.3.1/examples' make -C tools all make[1]: Entering directory `/arm44b0/u-boot-1.3.1/tools' make[1]: Leaving directory `/arm44b0/u-boot-1.3.1/tools' make -C examples all make[1]: Entering directory `/arm44b0/u-boot-1.3.1/examples' arm-linux-gcc -g -Os -fno-strict-aliasing -fno-common -ffixed-r8 -msoft-float -D__KERNEL__ -DTEXT_BASE=0x0C100000 -I/arm44b0/u-boot-1.3.1/include -fno-builtin -ffreestanding -nostdinc -isystem /arm44b0/eldk/usr/bin/../lib/gcc/arm-linux/4.0.0/include -pipe -DCONFIG_ARM -D__ARM__ -march=armv4 -mtune=arm7tdmi -msoft-float -mabi=apcs-gnu -Uarm -Wall -Wstrict-prototypes -c -o hello_world.o hello_world.c arm-linux-gcc -g -Os -fno-strict-aliasing -fno-common -ffixed-r8 -msoft-float -D__KERNEL__ -DTEXT_BASE=0x0C100000 -I/arm44b0/u-boot-1.3.1/include -fno-builtin -ffreestanding -nostdinc -isystem /arm44b0/eldk/usr/bin/../lib/gcc/arm-linux/4.0.0/include -pipe -DCONFIG_ARM -D__ARM__ -march=armv4 -mtune=arm7tdmi -msoft-float -mabi=apcs-gnu -Uarm -Wall -Wstrict-prototypes -c -o stubs.o stubs.c arm-linux-ar crv libstubs.a stubs.o a - stubs.o arm-linux-ld -g -Ttext 0xc100000 \ -o hello_world -e hello_world hello_world.o libstubs.a \ -L/arm44b0/eldk/usr/bin/../lib/gcc/arm-linux/4.0.0 -lgcc arm-linux-objcopy -O srec hello_world hello_world.srec 2>/dev/null arm-linux-objcopy -O binary hello_world hello_world.bin 2>/dev/null make[1]: Leaving directory `/arm44b0/u-boot-1.3.1/examples' make -C cpu/s3c44b0 start.o make[1]: Entering directory `/arm44b0/u-boot-1.3.1/cpu/s3c44b0' arm-linux-gcc -D__ASSEMBLY__ -g -Os -fno-strict-aliasing -fno-common -ffixed-r8 -msoft-float -D__KERNEL__ -DTEXT_BASE=0x0C100000 -I/arm44b0/u-boot-1.3.1/include -fno-builtin -ffreestanding -nostdinc -isystem /arm44b0/eldk/usr/bin/../lib/gcc/arm-linux/4.0.0/include -pipe -DCONFIG_ARM -D__ARM__ -march=armv4 -mtune=arm7tdmi -msoft-float -mabi=apcs-gnu -Uarm -c -o start.o start.S make[1]: Leaving directory `/arm44b0/u-boot-1.3.1/cpu/s3c44b0' make -C lib_generic/ make[1]: Entering directory `/arm44b0/u-boot-1.3.1/lib_generic' arm-linux-gcc -g -Os -fno-strict-aliasing -fno-common -ffixed-r8 -msoft-float -D__KERNEL__ -DTEXT_BASE=0x0C100000 -I/arm44b0/u-boot-1.3.1/include -fno-builtin -ffreestanding -nostdinc -isystem /arm44b0/eldk/usr/bin/../lib/gcc/arm-linux/4.0.0/include -pipe -DCONFIG_ARM -D__ARM__ -march=armv4 -mtune=arm7tdmi -msoft-float -mabi=apcs-gnu -Uarm -Wall -Wstrict-prototypes -c -o bzlib.o bzlib.c arm-linux-gcc -g -Os -fno-strict-aliasing -fno-common -ffixed-r8 -msoft-float -D__KERNEL__ -DTEXT_BASE=0x0C100000 -I/arm44b0/u-boot-1.3.1/include -fno-builtin -ffreestanding -nostdinc -isystem /arm44b0/eldk/usr/bin/../lib/gcc/arm-linux/4.0.0/include -pipe -DCONFIG_ARM -D__ARM__ -march=armv4 -mtune=arm7tdmi -msoft-float -mabi=apcs-gnu -Uarm -Wall -Wstrict-prototypes -c -o bzlib_crctable.o bzlib_crctable.c arm-linux-gcc -g -Os -fno-strict-aliasing -fno-common -ffixed-r8 -msoft-float -D__KERNEL__ -DTEXT_BASE=0x0C100000 -I/arm44b0/u-boot-1.3.1/include -fno-builtin -ffreestanding -nostdinc -isystem /arm44b0/eldk/usr/bin/../lib/gcc/arm-linux/4.0.0/include -pipe -DCONFIG_ARM -D__ARM__ -march=armv4 -mtune=arm7tdmi -msoft-float -mabi=apcs-gnu -Uarm -Wall -Wstrict-prototypes -c -o bzlib_decompress.o bzlib_decompress.c arm-linux-gcc -g -Os -fno-strict-aliasing -fno-common -ffixed-r8 -msoft-float -D__KERNEL__ -DTEXT_BASE=0x0C100000 -I/arm44b0/u-boot-1.3.1/include -fno-builtin -ffreestanding -nostdinc -isystem /arm44b0/eldk/usr/bin/../lib/gcc/arm-linux/4.0.0/include -pipe -DCONFIG_ARM -D__ARM__ -march=armv4 -mtune=arm7tdmi -msoft-float -mabi=apcs-gnu -Uarm -Wall -Wstrict-prototypes -c -o bzlib_randtable.o bzlib_randtable.c arm-linux-gcc -g -Os -fno-strict-aliasing -fno-common -ffixed-r8 -msoft-float -D__KERNEL__ -DTEXT_BASE=0x0C100000 -I/arm44b0/u-boot-1.3.1/include -fno-builtin -ffreestanding -nostdinc -isystem /arm44b0/eldk/usr/bin/../lib/gcc/arm-linux/4.0.0/include -pipe -DCONFIG_ARM -D__ARM__ -march=armv4 -mtune=arm7tdmi -msoft-float -mabi=apcs-gnu -Uarm -Wall -Wstrict-prototypes -c -o bzlib_huffman.o bzlib_huffman.c arm-linux-gcc -g -Os -fno-strict-aliasing -fno-common -ffixed-r8 -msoft-float -D__KERNEL__ -DTEXT_BASE=0x0C100000 -I/arm44b0/u-boot-1.3.1/include -fno-builtin -ffreestanding -nostdinc -isystem /arm44b0/eldk/usr/bin/../lib/gcc/arm-linux/4.0.0/include -pipe -DCONFIG_ARM -D__ARM__ -march=armv4 -mtune=arm7tdmi -msoft-float -mabi=apcs-gnu -Uarm -Wall -Wstrict-prototypes -c -o crc32.o crc32.c arm-linux-gcc -g -Os -fno-strict-aliasing -fno-common -ffixed-r8 -msoft-float -D__KERNEL__ -DTEXT_BASE=0x0C100000 -I/arm44b0/u-boot-1.3.1/include -fno-builtin -ffreestanding -nostdinc -isystem /arm44b0/eldk/usr/bin/../lib/gcc/arm-linux/4.0.0/include -pipe -DCONFIG_ARM -D__ARM__ -march=armv4 -mtune=arm7tdmi -msoft-float -mabi=apcs-gnu -Uarm -Wall -Wstrict-prototypes -c -o ctype.o ctype.c arm-linux-gcc -g -Os -fno-strict-aliasing -fno-common -ffixed-r8 -msoft-float -D__KERNEL__ -DTEXT_BASE=0x0C100000 -I/arm44b0/u-boot-1.3.1/include -fno-builtin -ffreestanding -nostdinc -isystem /arm44b0/eldk/usr/bin/../lib/gcc/arm-linux/4.0.0/include -pipe -DCONFIG_ARM -D__ARM__ -march=armv4 -mtune=arm7tdmi -msoft-float -mabi=apcs-gnu -Uarm -Wall -Wstrict-prototypes -c -o display_options.o display_options.c arm-linux-gcc -g -Os -fno-stri .....
,Regards - Denny
Hi guys,
,Regards - Denny
In message 567567.751661198636698510.JavaMail.coremail@bj163app54.163.com you wrote:
What has the subject line to do with the content of this message? Please make sure to read http://www.catb.org/%7eesr/faqs/smart-questions.html
Works fine for me (on a Fedora 7 system)...
Either your source tree has been modified / corrupted, or your "Make" tool is somehow broken - or you did not literally copy the build log.
When I see a "strip bmp_logo" command as above, the next command should be "./bmp_logo logos/denx.bmp >...".
You should fix this problem, then the other one goes away, too.
------=_Part_200280_30735470.1198636698508 Content-Type: text/html; charset=gbk Content-Transfer-Encoding: quoted-printable
And STOP posting HTML here!
Thanks for the quick response.
I can't open this link.
Is it relevant to the linux system, I am now use the ubuntu7.10.
Maybe it is due to the IE decode issue, in fact they are:
I am curious to see it use 'GCC' to compile my 'tools' in the first time, while use my cross compiler 'arm-linux-gcc' to compile 'tools' in the second time, even if I set the the 'GCC' to a symbol link to my cross compiler, the problem still exists. log: denny@ubuntu:~$ echo $PATH /arm44b0/eldk/usr/arm-linux/bin:/arm44b0/eldk/bin:/arm44b0/eldk/usr/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games denny@ubuntu:~$ gcc -v Reading specs from /arm44b0/eldk/usr/bin/../lib/gcc/arm-linux/4.0.0/specs Target: arm-linux Configured with: /opt/eldk/build/arm-2007-01-22-uclibc/work/usr/src/denx/BUILD/crosstool-0.35/build/gcc-4.0.0-uclibc-0.9.27-eldk/arm-linux/gcc-4.0.0/configure --target=arm-linux --host=i686-host_pc-linux-gnu --prefix=/var/tmp/eldk.aLIfDn/usr/crosstool/gcc-4.0.0-uclibc-0.9.27-eldk/arm-linux --with-headers=/var/tmp/eldk.aLIfDn/usr/crosstool/gcc-4.0.0-uclibc-0.9.27-eldk/arm-linux/arm-linux/include --with-local-prefix=/var/tmp/eldk.aLIfDn/usr/crosstool/gcc-4.0.0-uclibc-0.9.27-eldk/arm-linux/arm-linux --disable-nls --enable-threads=posix --enable-symvers=gnu --enable-languages=c,c++ --enable-shared --enable-c99 --enable-long-long --disable-__cxa_atexit Thread model: posix gcc version 4.0.0 (DENX ELDK 4.1 4.0.0) denny@ubuntu:~$ echo $CROSS_COMPILE arm-linux- denny@ubuntu:~$ arm-linux-gcc -v Reading specs from /arm44b0/eldk/usr/bin/../lib/gcc/arm-linux/4.0.0/specs Target: arm-linux Configured with: /opt/eldk/build/arm-2007-01-22-uclibc/work/usr/src/denx/BUILD/crosstool-0.35/build/gcc-4.0.0-uclibc-0.9.27-eldk/arm-linux/gcc-4.0.0/configure --target=arm-linux --host=i686-host_pc-linux-gnu --prefix=/var/tmp/eldk.aLIfDn/usr/crosstool/gcc-4.0.0-uclibc-0.9.27-eldk/arm-linux --with-headers=/var/tmp/eldk.aLIfDn/usr/crosstool/gcc-4.0.0-uclibc-0.9.27-eldk/arm-linux/arm-linux/include --with-local-prefix=/var/tmp/eldk.aLIfDn/usr/crosstool/gcc-4.0.0-uclibc-0.9.27-eldk/arm-linux/arm-linux --disable-nls --enable-threads=posix --enable-symvers=gnu --enable-languages=c,c++ --enable-shared --enable-c99 --enable-long-long --disable-__cxa_atexit Thread model: posix gcc version 4.0.0 (DENX ELDK 4.1 4.0.0) denny@ubuntu:~$
I tried many ways to kill these HTML, but seems take no effect, now I changed the decode in my IE, hopeful this will work.
,Thanks - Denny
-------- this is the end of my mail --------------------
In message 1392658266.70941198718213247.JavaMail.coremail@bj163app103.163.com you wrote:
Why not? You may have to install a web browser, of course...
It should work on Ubuntu, too.
What is the "IE decode issue" ?? Please make sure to use a clean, unmodified source tree.
Don't mess around with your tools like that.
No, it did not work.
------=_Part_19157_587839438.1198718213246 Content-Type: text/html; charset=gbk Content-Transfer-Encoding: quoted-printable
Please STOP this!
See http://expita.com/nomime.html for detailed instructions.
Hi Folks,
I encounter may mess message when compile u-boot-1.3.1, is this due to the gcc version of my ubuntun7.1.0? is there anyone even encounter this issue?
denny@ubuntu:/arm44b0/u-boot-1.3.1$ arm-linux-gcc -v Reading specs from /arm44b0/eldk/usr/bin/../lib/gcc/arm-linux/4.0.0/specs Target: arm-linux Configured with: /opt/eldk/build/arm-2007-01-22-uclibc/work/usr/src/denx/BUILD/crosstool-0.35/build/gcc-4.0.0-uclibc-0.9.27-eldk/arm-linux/gcc-4.0.0/configure --target=arm-linux --host=i686-host_pc-linux-gnu --prefix=/var/tmp/eldk.aLIfDn/usr/crosstool/gcc-4.0.0-uclibc-0.9.27-eldk/arm-linux --with-headers=/var/tmp/eldk.aLIfDn/usr/crosstool/gcc-4.0.0-uclibc-0.9.27-eldk/arm-linux/arm-linux/include --with-local-prefix=/var/tmp/eldk.aLIfDn/usr/crosstool/gcc-4.0.0-uclibc-0.9.27-eldk/arm-linux/arm-linux --disable-nls --enable-threads=posix --enable-symvers=gnu --enable-languages=c,c++ --enable-shared --enable-c99 --enable-long-long --disable-__cxa_atexit Thread model: posix gcc version 4.0.0 (DENX ELDK 4.1 4.0.0) denny@ubuntu:/arm44b0/u-boot-1.3.1$ gcc -v Using built-in specs. Target: i486-linux-gnu Configured with: ../src/configure -v --enable-languages=c,c++,fortran,objc,obj-c++,treelang --prefix=/usr --enable-shared --with-system-zlib --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --enable-nls --with-gxx-include-dir=/usr/include/c++/4.1.3 --program-suffix=-4.1 --enable-__cxa_atexit --enable-clocale=gnu --enable-libstdcxx-debug --enable-mpfr --enable-checking=release i486-linux-gnu Thread model: posix gcc version 4.1.3 20070929 (prerelease) (Ubuntu 4.1.2-16ubuntu2) denny@ubuntu:/arm44b0/u-boot-1.3.1$ make for dir in tools examples ; do make -C $dir _depend ; done make[1]: Entering directory `/arm44b0/u-boot-1.3.1/tools' make[1]: Nothing to be done for `_depend'. make[1]: Leaving directory `/arm44b0/u-boot-1.3.1/tools' make[1]: Entering directory `/arm44b0/u-boot-1.3.1/examples' make[1]: Nothing to be done for `_depend'. make[1]: Leaving directory `/arm44b0/u-boot-1.3.1/examples' make -C tools all make[1]: Entering directory `/arm44b0/u-boot-1.3.1/tools' gcc -Wall -pedantic -idirafter /arm44b0/u-boot-1.3.1/include -idirafter /arm44b0/u-boot-1.3.1/include2 -idirafter /arm44b0/u-boot-1.3.1/include -DTEXT_BASE=0x0C100000 -DUSE_HOSTCC -O -c -o img2srec.o img2srec.c In file included from img2srec.c:57: /usr/local/include/stdlib.h:296: error: expected 鈥?鈥?or 鈥?鈥?before 鈥榹鈥?token /usr/local/include/stdlib.h:302: error: expected 鈥?鈥?or 鈥?鈥?before 鈥榹鈥?token /usr/local/include/stdlib.h:308: error: expected 鈥?鈥?or 鈥?鈥?before 鈥榹鈥?token /usr/local/include/stdlib.h:329: error: expected 鈥?鈥?or 鈥?鈥?before 鈥榹鈥?token /usr/local/include/stdlib.h:335: error: expected 鈥?鈥?or 鈥?鈥?before 鈥榹鈥?token /usr/local/include/stdlib.h:344: error: expected 鈥?鈥?or 鈥?鈥?before 鈥榹鈥?token /usr/local/include/stdlib.h:350: error: expected 鈥?鈥?or 鈥?鈥?before 鈥榹鈥?token /usr/local/include/stdlib.h:357: error: expected 鈥?鈥?or 鈥?鈥?before 鈥榹鈥?token /usr/local/include/stdlib.h:362: error: expected 鈥?鈥?or 鈥?鈥?before 鈥榹鈥?token /usr/local/include/stdlib.h:367: error: expected 鈥?鈥?or 鈥?鈥?before 鈥榹鈥?token /usr/local/include/stdlib.h:374: error: expected 鈥?鈥?or 鈥?鈥?before 鈥榹鈥?token In file included from img2srec.c:58: /usr/local/include/ctype.h:170: error: expected 鈥?鈥?or 鈥?鈥?before 鈥榹鈥?token /usr/local/include/ctype.h:176: error: expected 鈥?鈥?or 鈥?鈥?before 鈥榹鈥?token make[1]: *** [img2srec.o] Error 1 make[1]: Leaving directory `/arm44b0/u-boot-1.3.1/tools' make: *** [tools] Error 2 denny@ubuntu:/arm44b0/u-boot-1.3.1$
,Thanks - Denny
In message 10584250.108351198896195167.JavaMail.coremail@bj163app65.163.com you wrote:
I don't know what sort of native gcc you have installed in your system, but it looks pretty strange to me...
Is this the gcc that comes with Ubuntu, or something you compiled yourself?
This looks good to me, but...
In file included from img2srec.c:57: /usr/local/include/stdlib.h:296: error: expected â?â?or â?â?before â{â?token
... I have not the slightest idea why your compiler might have the funny idea to pull in files from /usr/local/include ?
And obviously these header files are broken, too.
------=_Part_28757_21520426.1198896195166 Content-Type: text/html; charset=gbk Content-Transfer-Encoding: quoted-printable
Stop posting HTML, please.
Hi Folks, Now I used a programm named "Flash Programmer 2.24", I want to convert the u-boot image to s19 file format, but how?
denny@ubuntu:/arm44b0/u-boot-1.3.1$ gcc -v Using built-in specs. Target: i486-linux-gnu Configured with: ../src/configure -v --enable-languages=c,c++,fortran,objc,obj-c++,treelang --prefix=/usr --enable-shared --with-system-zlib --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --enable-nls --with-gxx-include-dir=/usr/include/c++/4.2 --program-suffix=-4.2 --enable-clocale=gnu --enable-libstdcxx-debug --enable-mpfr --enable-targets=all --enable-checking=release --build=i486-linux-gnu --host=i486-linux-gnu --target=i486-linux-gnu Thread model: posix gcc version 4.2.1 (Ubuntu 4.2.1-5ubuntu4) denny@ubuntu:/arm44b0/u-boot-1.3.1$ arm-linux-gcc -v Reading specs from /opt/eldk41/usr/bin/../lib/gcc/arm-linux/4.0.0/specs Target: arm-linux Configured with: /opt/eldk/build/arm-2007-01-22-uclibc/work/usr/src/denx/BUILD/crosstool-0.35/build/gcc-4.0.0-uclibc-0.9.27-eldk/arm-linux/gcc-4.0.0/configure --target=arm-linux --host=i686-host_pc-linux-gnu --prefix=/var/tmp/eldk.aLIfDn/usr/crosstool/gcc-4.0.0-uclibc-0.9.27-eldk/arm-linux --with-headers=/var/tmp/eldk.aLIfDn/usr/crosstool/gcc-4.0.0-uclibc-0.9.27-eldk/arm-linux/arm-linux/include --with-local-prefix=/var/tmp/eldk.aLIfDn/usr/crosstool/gcc-4.0.0-uclibc-0.9.27-eldk/arm-linux/arm-linux --disable-nls --enable-threads=posix --enable-symvers=gnu --enable-languages=c,c++ --enable-shared --enable-c99 --enable-long-long --disable-__cxa_atexit Thread model: posix gcc version 4.0.0 (DENX ELDK 4.1 4.0.0) denny@ubuntu:/arm44b0/u-boot-1.3.1$ cd tools/ denny@ubuntu:/arm44b0/u-boot-1.3.1/tools$ ls bddb crc32.o envcrc.o gen_eth_addr.c img2srec.o mkimage scripts ubsha1.c bmp_logo easylogo environment.c gen_eth_addr.o inca-swap-bytes.c mkimage.c setlocalversion ubsha1.o bmp_logo.c env environment.o img2brec.sh logos mkimage.o sha1.c updater bmp_logo.o envcrc gdb img2srec Makefile mpc86x_clk.c sha1.o crc32.c envcrc.c gen_eth_addr img2srec.c Makefile.win32 ncb.c ubsha1 denny@ubuntu:/arm44b0/u-boot-1.3.1/tools$ ./img2srec ../u-boot.bin *** illegal file format denny@ubuntu:/arm44b0/u-boot-1.3.1/tools$
,Thanks - Denny
In message 29490644.438341199249680797.JavaMail.coremail@bj163app28.163.com you wrote:
Type:
make u-boot.srec
You must have done something wrong here. Check your PATH settings (post your PATH and CROSS_COMPILE settings if you can't fix it).
------=_Part_114564_4799237.1199249680770 Content-Type: text/html; charset=gbk Content-Transfer-Encoding: quoted-printable
And do not post HTML!
jxnuxdy
Stefan Roese
