[GIT PULL] clock changes for u-boot/master
The following changes since commit 3ac22891cfc0dc6d8eec25d2b0fbdd2eb8f3d3ed:
Merge tag 'u-boot-imx-20231214' of https://gitlab.denx.de/u-boot/custodians/u-boot-imx (2023-12-15 08:22:31 -0500)
https://source.denx.de/u-boot/custodians/u-boot-clk.git tags/clk-2024.01-rc5
for you to fetch changes up to 97d65b32d76cb3b8297cd8aa2c1f0caab5ab6c57:
test: dm: clk_ccf: fix building error (2023-12-15 15:30:12 -0500)
---------------------------------------------------------------- clock changes for u-boot/master
This has some clock fixes which should go in before the release. It's a bit late in the cycle, but most of these have tests to go along with them.
Signed-off-by: Sean Anderson seanga2@gmail.com
---------------------------------------------------------------- Igor Prusov (2): clk: Check that composite clock's div has set_rate() dm: test: clk: Add test for ccf clk_set_rate()
Yang Xiwen (4): clk: check parent_name in clk_register to avoid confusing log_error() output clk: get correct ops for clk_enable() and clk_disable() test: dm: clk_ccf: test ccf_clk_ops test: dm: clk_ccf: fix building error
arch/sandbox/dts/test.dts | 4 +++- arch/sandbox/include/asm/clk.h | 1 + drivers/clk/clk-composite.c | 2 +- drivers/clk/clk-uclass.c | 2 ++ drivers/clk/clk.c | 18 ++++++++++-------- drivers/clk/clk_sandbox_ccf.c | 1 + drivers/clk/clk_sandbox_test.c | 1 + test/dm/clk_ccf.c | 22 ++++++++++++++++++++-- 8 files changed, 39 insertions(+), 12 deletions(-)
Sean Anderson
