[U-Boot] [PATCH] spl: Change printf to puts for "Unsupported boot-device"
Microblaze currently doesn't use printf in SPL. So this one line was the only reference to it and resulted in the printf functionality to be pulled in. Exceeding the 4k size limit. Lets change the printf back to puts so that Microblaze is fixed again. The only drawback is that the detected boot-device number will not be printed. But this message alone should be helpful enough to get an idea where the boot process is broken.
Signed-off-by: Stefan Roese sr@denx.de Cc: Tom Rini trini@ti.com Cc: Michal Simek michal.simek@xilinx.com --- common/spl/spl.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/spl/spl.c b/common/spl/spl.c index 1826c47..daaeb50 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -231,7 +231,7 @@ void board_init_r(gd_t *dummy1, ulong dummy2) #endif default: #if defined(CONFIG_SPL_SERIAL_SUPPORT) && defined(CONFIG_SPL_LIBCOMMON_SUPPORT) - printf("SPL: Unsupported Boot Device %d\n", boot_device); + puts("SPL: Unsupported Boot Device!\n"); #endif hang(); }
Since we have a debug() higher up that will print out what the value is, I'm OK with this and I'll apply shortly, thanks!
Works for me. Acked-by: Michal Simek michal.simek@xilinx.com
Thanks, Michal
Signed-off-by: Stefan Roese sr@denx.de Cc: Tom Rini trini@ti.com Cc: Michal Simek michal.simek@xilinx.com Acked-by: Michal Simek michal.simek@xilinx.com
Michal Simek
Stefan Roese
