Re: [U-Boot] [PULL] u-boot-usb/master
Dear Marek,
In message 201207191452.53818.marex@denx.de you wrote:
please apply this into the current release. I'm hereby commiting seppuku.
PLEASE send such pull reqeusts to the mailing list, so everybody can see it.
The following changes since commit 66714b1a6df0a5a9f1656a6d4e6eea3c7ecdf7ae:
Merge branch 'next' of git://git.denx.de/u-boot-video (2012-07-18 10:47:03 +0200)
git://git.denx.de/u-boot-usb.git master
for you to fetch changes up to 1b4bd0e66cd3b5124669c78bc968510b1040e9d9:
usb_storage: fix ehci driver max transfer size (2012-07-18 14:46:19 +0200)
Ilya Yanok (6): ehci-hcd: program asynclistaddr before every transfer ehci-hcd: fix external buffer cache handling usb: pass cache-aligned buffer to usb_get_descriptor() usb: check return value of submit_{control, bulk}_msg ehci-hcd: change debug() to printf() in case of errors smsc95xx: align buffers to cache line size
Marek Vasut (1): common.h: Introduce DEFINE_CACHE_ALIGN_BUFFER
Stefan Herbrechtsmeier (1): usb_storage: fix ehci driver max transfer size
Tom Rini (2): ehci-omap: Do not call dcache_off from omap_ehci_hcd_init ehci-hcd.c, musb_core, usb.h: Add USB_DMA_MINALIGN define for cache alignment
common/usb.c | 12 ++++++++---- common/usb_storage.c | 37 +++++++++++++++++++---------------- drivers/usb/eth/smsc95xx.c | 13 +++++++++---- drivers/usb/host/ehci-hcd.c | 96 ++++++++++++++++++++++++++++++++++++++++++++++++------------------------------------------- drivers/usb/host/ehci-omap.c | 1 - drivers/usb/musb/musb_core.h | 2 +- include/common.h | 21 +++++++++++++++++--- include/usb.h | 10 ++++++++++ 8 files changed, 117 insertions(+), 75 deletions(-)
Applied, thanks.
On Fri, Jul 20, 2012 at 2:19 AM, Wolfgang Denk wd@denx.de wrote:
Dear Marek,
Applied, thanks.
I think this merge is causing issues. Resetting to the previous merge (ad8439d Merge branch 'sf' of git://git.denx.de/u-boot-blackfin) and the issues go away.
-M
Generating include/generated/asm-offsets.h bootm.c:329:16: error: expected ')' before '__attribute__' bootm.c:329:25: error: expected identifier or '(' before ')' token bootm.c:59:13: warning: 'boot_jump_linux' defined but not used bootm.c:177:13: warning: 'boot_prep_linux' defined but not used bootm.c:249:12: warning: 'boot_body_linux' defined but not used make[2]: *** [bootm.o] Error 1 make[2]: *** Waiting for unfinished jobs.... fm.c: In function 'fm_init_common': /local/home/mattsm/git/u-boot/include/common.h:344:12: sorry, unimplemented: inlining failed in call to 'setenv': function body not available fm.c:420:8: sorry, unimplemented: called from here make[2]: *** [fm.o] Error 1 make[2]: *** Waiting for unfinished jobs.... make[1]: *** [arch/powerpc/lib/libpowerpc.o] Error 2 make[1]: *** Waiting for unfinished jobs.... make[1]: *** [drivers/net/fm/libfm.o] Error 2 bootp.c: In function 'DhcpHandler': /local/home/mattsm/git/u-boot/include/common.h:344:12: sorry, unimplemented: inlining failed in call to 'setenv': function body not available bootp.c:119:9: sorry, unimplemented: called from here make[2]: *** [bootp.o] Error 1 make[2]: *** Waiting for unfinished jobs.... net.c: In function 'NetLoop': /local/home/mattsm/git/u-boot/include/common.h:344:12: sorry, unimplemented: inlining failed in call to 'setenv': function body not available net.c:516:11: sorry, unimplemented: called from here /local/home/mattsm/git/u-boot/include/common.h:344:12: sorry, unimplemented: inlining failed in call to 'setenv': function body not available net.c:519:11: sorry, unimplemented: called from here make[2]: *** [net.o] Error 1 make[1]: *** [net/libnet.o] Error 2 cmd_net.c: In function 'netboot_common': /local/home/mattsm/git/u-boot/include/common.h:344:12: sorry, unimplemented: inlining failed in call to 'setenv': function body not available cmd_net.c:138:10: sorry, unimplemented: called from here
-M
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de Substitute "damn" every time you're inclined to write "very"; your editor will delete it and the writing will be just as it should be. - Mark Twain _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Dear McClintock Matthew-B29882,
-M
What compiler and what board did you test this with?
Best regards, Marek Vasut
-M
P4080DS with:
gcc version 4.5.1 (Sourcery G++ Lite 2010.09-55)
-M
Best regards, Marek Vasut _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
On Fri, Jul 20, 2012 at 10:59 PM, McClintock Matthew-B29882 < B29882@freescale.com> wrote:
-M
including <linux/compiler.h> breaks __attribute__((noinline)) (has to be changed to noinline). I believe it's enough to fix this file and remove #define noinline from lib/vsprintf.c
Regards, Ilya.
Dear Ilya Yanok,
-M
It isn't, but there's a patch that changes __aligned to __attribute__((aligned(...))); and removes compiler.h
Regards, Ilya.
Ilya Yanok
