[U-Boot] [PATCH v2] spi: fsl_qspi: Add controller busy check before new spi operation
It is recommended to check either controller is free to take new spi action. The IP_ACC and AHB_ACC bits indicates that the controller is busy in IP or AHB mode respectively. And the BUSY bit indicates that controller is currently busy handling a transaction to an external flash device
Signed-off-by: Suresh Gupta suresh.gupta@nxp.com --- Changes in v2:
- Add wait_for_bit instead of while - move the busy check code to fsl_qspi_claim_bus form qspi_xfer
drivers/spi/fsl_qspi.c | 28 +++++++++++++++++++++++++++- drivers/spi/fsl_qspi.h | 4 ++++ 2 files changed, 31 insertions(+), 1 deletion(-)
diff --git a/drivers/spi/fsl_qspi.c b/drivers/spi/fsl_qspi.c index 1dfa89a..ed23aac 100644 --- a/drivers/spi/fsl_qspi.c +++ b/drivers/spi/fsl_qspi.c @@ -14,6 +14,7 @@ #include <dm.h> #include <errno.h> #include <watchdog.h> +#include <wait_bit.h> #include "fsl_qspi.h"
DECLARE_GLOBAL_DATA_PTR; @@ -991,7 +992,7 @@ static int fsl_qspi_probe(struct udevice *bus) struct fsl_qspi_platdata *plat = dev_get_platdata(bus); struct fsl_qspi_priv *priv = dev_get_priv(bus); struct dm_spi_bus *dm_spi_bus; - int i; + int i, ret;
dm_spi_bus = bus->uclass_priv;
@@ -1011,6 +1012,18 @@ static int fsl_qspi_probe(struct udevice *bus) priv->flash_num = plat->flash_num; priv->num_chipselect = plat->num_chipselect;
+ /* make sure controller is not busy anywhere */ + ret = wait_for_bit(__func__, &priv->regs->sr, + QSPI_SR_BUSY_MASK | + QSPI_SR_AHB_ACC_MASK | + QSPI_SR_IP_ACC_MASK, + false, 1000, false); + + if (ret) { + printf("ERROR : The controller is busy\n"); + return -EBUSY; + } + mcr_val = qspi_read32(priv->flags, &priv->regs->mcr); qspi_write32(priv->flags, &priv->regs->mcr, QSPI_MCR_RESERVED_MASK | QSPI_MCR_MDIS_MASK | @@ -1156,10 +1169,23 @@ static int fsl_qspi_claim_bus(struct udevice *dev) struct fsl_qspi_priv *priv; struct udevice *bus; struct dm_spi_slave_platdata *slave_plat = dev_get_parent_platdata(dev); + int ret;
bus = dev->parent; priv = dev_get_priv(bus);
+ /* make sure controller is not busy anywhere */ + ret = wait_for_bit(__func__, &priv->regs->sr, + QSPI_SR_BUSY_MASK | + QSPI_SR_AHB_ACC_MASK | + QSPI_SR_IP_ACC_MASK, + false, 1000, false); + + if (ret) { + printf("ERROR : The controller is busy\n"); + return -EBUSY; + } + priv->cur_amba_base = priv->amba_base[slave_plat->cs];
qspi_module_disable(priv, 0); diff --git a/drivers/spi/fsl_qspi.h b/drivers/spi/fsl_qspi.h index 6cb3610..e468eb2 100644 --- a/drivers/spi/fsl_qspi.h +++ b/drivers/spi/fsl_qspi.h @@ -105,6 +105,10 @@ struct fsl_qspi_regs { #define QSPI_RBCT_RXBRD_SHIFT 8 #define QSPI_RBCT_RXBRD_USEIPS (1 << QSPI_RBCT_RXBRD_SHIFT)
+#define QSPI_SR_AHB_ACC_SHIFT 2 +#define QSPI_SR_AHB_ACC_MASK (1 << QSPI_SR_AHB_ACC_SHIFT) +#define QSPI_SR_IP_ACC_SHIFT 1 +#define QSPI_SR_IP_ACC_MASK (1 << QSPI_SR_IP_ACC_SHIFT) #define QSPI_SR_BUSY_SHIFT 0 #define QSPI_SR_BUSY_MASK (1 << QSPI_SR_BUSY_SHIFT)
Changes in v2:
int i;
int i, ret; dm_spi_bus = bus->uclass_priv;
I think in previous version, this code not added in probe is it? is this because probe doing mcr and other reg operations?
QSPI_SR_BUSY_MASK |
if (ret) {
return -EBUSY;
Better to drop printf or use debug and wait_for_bit usually return -ETIMEDOUT or -EINTR on failure so just return ret.
thanks!
-----Original Message----- From: Jagan Teki [mailto:jagannadh.teki@gmail.com] Sent: Tuesday, August 29, 2017 11:08 PM To: Suresh Gupta suresh.gupta@nxp.com Cc: u-boot@lists.denx.de; York Sun york.sun@nxp.com Subject: Re: [PATCH v2] spi: fsl_qspi: Add controller busy check before new spi operation
Changes in v2:
int i;
The probe function changes the LUTs, change AHB configuration and change the endianness. So, changing above setting when the controller is busy in some AHB access will affect the running access.
QSPI_SR_BUSY_MASK |
if (ret) {
return -EBUSY;
The error above is trivial and after this error, the sf commands do not work. And if we hide the message under debug, normal user will not understand the issue. As per me this should be printf, what you say?
Ok, I will make changes in next patch
thanks!
Jagan Teki Free Software Engineer | www.openedev.com U-Boot, Linux | Upstream Maintainer Hyderabad, India.
Changes in v2:
int i;
QSPI_SR_BUSY_MASK |
if (ret) {
return -EBUSY;
sf return error code, can't user understand based on that? idea is to avoid printf's in platform driver.
thanks!
Jagan Teki
Suresh Gupta
