[U-Boot] [PATCH] usb: Fix error handling in musb_hcd.c
The wait_until_[rx|tx]ep_ready functions return a u8 to indicate success containing the value 0, 1 or -1. This patch changes the return type to an int to accommodate the negative return values.
These functions are used in the file using calls such as if (!wait_until... Where a -1 is returned it is mishandled and treated as success instead of a CRC error. This patch addresses this.
Cc: Marek Vasut marex@denx.de Cc: Tom Rini trini@ti.com Signed-off-by: Andrew Murray amurray@embedded-bits.co.uk --- drivers/usb/musb/musb_hcd.c | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/drivers/usb/musb/musb_hcd.c b/drivers/usb/musb/musb_hcd.c index ae39c4a..708fa12 100644 --- a/drivers/usb/musb/musb_hcd.c +++ b/drivers/usb/musb/musb_hcd.c @@ -267,7 +267,7 @@ static int wait_until_ep0_ready(struct usb_device *dev, u32 bit_mask) /* * waits until tx ep is ready. Returns 1 when ep is ready and 0 on error. */ -static u8 wait_until_txep_ready(struct usb_device *dev, u8 ep) +static int wait_until_txep_ready(struct usb_device *dev, u8 ep) { u16 csr; int timeout = CONFIG_MUSB_TIMEOUT; @@ -299,7 +299,7 @@ static u8 wait_until_txep_ready(struct usb_device *dev, u8 ep) /* * waits until rx ep is ready. Returns 1 when ep is ready and 0 on error. */ -static u8 wait_until_rxep_ready(struct usb_device *dev, u8 ep) +static int wait_until_rxep_ready(struct usb_device *dev, u8 ep) { u16 csr; int timeout = CONFIG_MUSB_TIMEOUT; @@ -1018,7 +1018,7 @@ int submit_bulk_msg(struct usb_device *dev, unsigned long pipe, writew(csr | MUSB_TXCSR_TXPKTRDY, &musbr->txcsr);
/* Wait until the TxPktRdy bit is cleared */ - if (!wait_until_txep_ready(dev, MUSB_BULK_EP)) { + if (wait_until_txep_ready(dev, MUSB_BULK_EP) != 1) { readw(&musbr->txcsr); usb_settoggle(dev, ep, dir_out, (csr >> MUSB_TXCSR_H_DATATOGGLE_SHIFT) & 1); @@ -1053,7 +1053,7 @@ int submit_bulk_msg(struct usb_device *dev, unsigned long pipe, writew(csr | MUSB_RXCSR_H_REQPKT, &musbr->rxcsr);
/* Wait until the RxPktRdy bit is set */ - if (!wait_until_rxep_ready(dev, MUSB_BULK_EP)) { + if (wait_until_rxep_ready(dev, MUSB_BULK_EP) != 1) { csr = readw(&musbr->rxcsr); usb_settoggle(dev, ep, dir_out, (csr >> MUSB_S_RXCSR_H_DATATOGGLE) & 1); @@ -1226,7 +1226,7 @@ int submit_int_msg(struct usb_device *dev, unsigned long pipe, writew(csr | MUSB_RXCSR_H_REQPKT, &musbr->rxcsr);
/* Wait until the RxPktRdy bit is set */ - if (!wait_until_rxep_ready(dev, MUSB_INTR_EP)) { + if (wait_until_rxep_ready(dev, MUSB_INTR_EP) != 1) { csr = readw(&musbr->rxcsr); usb_settoggle(dev, ep, dir_out, (csr >> MUSB_S_RXCSR_H_DATATOGGLE) & 1);
Dear Andrew Murray,
Acked-by: Marek Vasut marex@denx.de
Tom, feel free to pick this up if it's ok on this omap hardware.
Best regards, Marek Vasut
Andrew Murray
