[PATCH v1] android_ab: don't ignore ab_control_store return code
ab_control_store() can return an error if writing to disk fails. In this case, we have to pass the error code to the caller.
Signed-off-by: Alexey Romanov avromanov@salutedevices.com --- boot/android_ab.c | 18 ++++++++++++++++-- 1 file changed, 16 insertions(+), 2 deletions(-)
diff --git a/boot/android_ab.c b/boot/android_ab.c index 73b55c196c..5a3152dd53 100644 --- a/boot/android_ab.c +++ b/boot/android_ab.c @@ -337,7 +337,15 @@ int ab_select_slot(struct blk_desc *dev_desc, struct disk_partition *part_info,
if (store_needed) { abc->crc32_le = ab_control_compute_crc(abc); - ab_control_store(dev_desc, part_info, abc, 0); + ret = ab_control_store(dev_desc, part_info, abc, 0); + if (ret < 0) { +#if ANDROID_AB_BACKUP_OFFSET + free(backup_abc); +#endif + free(abc); + log_err("ANDROID: failed to store boot control block: %d\n", ret); + return ret; + } }
#if ANDROID_AB_BACKUP_OFFSET @@ -346,8 +354,14 @@ int ab_select_slot(struct blk_desc *dev_desc, struct disk_partition *part_info, * to the backup offset */ if (memcmp(backup_abc, abc, sizeof(*abc)) != 0) { - ab_control_store(dev_desc, part_info, abc, + ret = ab_control_store(dev_desc, part_info, abc, ANDROID_AB_BACKUP_OFFSET); + if (ret < 0) { + free(backup_abc); + free(abc); + log_err("ANDROID: failed to store boot control block: %d\n", ret); + return ret; + } } free(backup_abc); #endif
Hello!
Really sorry for the noise, but please, take a look at my patch :)
if (ret < 0) {
free(backup_abc);
free(abc);
return ret;
if (ret < 0) {
free(backup_abc);
free(abc);
return ret;
} free(backup_abc);}
#endif
2.39.2
Hi Alexey,
Thank you for your patch.
I'm looping in the Android AB reviewers and maintainers (Sam and Igor).
They were not automatically add due to a stale MAINTAINERS entry[1]
[1] https://lore.kernel.org/all/20231220-maintainers-fix-ab-v1-1-dd16fc5285ed@ba...
On Tue, Nov 28, 2023 at 14:26, Alexey Romanov avromanov@salutedevices.com wrote:
if (ret < 0) {
free(backup_abc);
free(abc);
There is no point in logging here, because ab_control_store() already logs:
ret = blk_dwrite(dev_desc, part_info->start + abc_offset, abc_blocks, abc); if (IS_ERR_VALUE(ret)) { log_err("ANDROID: Could not write back the misc partition\n"); return -EIO; }
return ret;
if (ret < 0) {
free(backup_abc);
free(abc);
Same here
With that addressed:
Reviewed-by: Mattijs Korpershoek mkorpershoek@baylibre.com
return ret;
#endif
2.39.2
Alexey Romanov
Mattijs Korpershoek
