[U-Boot] [PATCH] travis-ci: Switch to building QEMU
First, there are a number of features in newer QEMU that will allow us to test a wider range of platforms, so we want to use at least v2.8.0. Second, making use of a PPA for QEMU fails from time to time. So we change to checking out and building a copy of QEMU when we know that we are going to use test.py and need QEMU to be installed. This adds around 4 minutes per test.py job that we run.
Signed-off-by: Tom Rini trini@konsulko.com --- .travis.yml | 26 +++++++++++++++++++------- 1 file changed, 19 insertions(+), 7 deletions(-)
diff --git a/.travis.yml b/.travis.yml index 79bc24263abd..31fe27467184 100644 --- a/.travis.yml +++ b/.travis.yml @@ -10,8 +10,6 @@ language: c
addons: apt: - sources: - - sourceline: 'ppa:gns3/qemu' packages: - cppcheck - sloccount @@ -21,10 +19,6 @@ addons: - libsdl1.2-dev - python - python-virtualenv - - qemu-system-arm - - qemu-system-mips - - qemu-system-ppc - - qemu-system-x86 - gcc-powerpc-linux-gnu - gcc-arm-linux-gnueabihf - gcc-aarch64-linux-gnu @@ -54,7 +48,7 @@ install:
env: global: - - PATH=/tmp/dtc:/tmp/uboot-test-hooks/bin:$PATH + - PATH=/tmp/dtc:/tmp/qemu-install/bin:/tmp/uboot-test-hooks/bin:$PATH - PYTHONPATH=/tmp/uboot-test-hooks/py/travis-ci - BUILD_DIR=build - HOSTCC="cc" @@ -74,6 +68,15 @@ before_script: echo -e "\n[toolchain-prefix]\nx86 = ${HOME}/.buildman-toolchains/gcc-4.9.0-nolibc/x86_64-linux/bin/x86_64-linux-" >> ~/.buildman; fi - if [[ "${TOOLCHAIN}" == *xtensa* ]]; then ./tools/buildman/buildman --fetch-arch xtensa ; fi + - if [[ "${QEMU_TARGET}" != "" ]]; then + git clone git://git.qemu.org/qemu.git /tmp/qemu; + pushd /tmp/qemu; + git submodule update --init dtc && + git checkout v2.8.0-rc3 && + ./configure --prefix=/tmp/qemu-install --target-list=${QEMU_TARGET} && + make -j4 all install; + popd; + fi
script: # Comments must be outside the command strings below, or the Travis parser @@ -140,43 +143,52 @@ matrix: - env: - TEST_PY_BD="vexpress_ca15_tc2" TEST_PY_ID="--id qemu" + QEMU_TARGET="arm-softmmu" BUILDMAN="^vexpress_ca15_tc2$" - env: - TEST_PY_BD="vexpress_ca9x4" TEST_PY_ID="--id qemu" + QEMU_TARGET="arm-softmmu" BUILDMAN="^vexpress_ca9x4$" - env: - TEST_PY_BD="integratorcp_cm926ejs" TEST_PY_TEST_SPEC="not sleep" TEST_PY_ID="--id qemu" + QEMU_TARGET="arm-softmmu" BUILDMAN="^integratorcp_cm926ejs$" - env: - TEST_PY_BD="qemu_mips" TEST_PY_TEST_SPEC="not sleep" + QEMU_TARGET="mips-softmmu" BUILDMAN="^qemu_mips$" TOOLCHAIN="mips" - env: - TEST_PY_BD="qemu_mipsel" TEST_PY_TEST_SPEC="not sleep" + QEMU_TARGET="mipsel-softmmu" BUILDMAN="^qemu_mipsel$" TOOLCHAIN="mips" - env: - TEST_PY_BD="qemu_mips64" TEST_PY_TEST_SPEC="not sleep" + QEMU_TARGET="mips64-softmmu" BUILDMAN="^qemu_mips64$" TOOLCHAIN="mips" - env: - TEST_PY_BD="qemu_mips64el" TEST_PY_TEST_SPEC="not sleep" + QEMU_TARGET="mips64el-softmmu" BUILDMAN="^qemu_mips64el$" TOOLCHAIN="mips" - env: - TEST_PY_BD="qemu-ppce500" TEST_PY_TEST_SPEC="not sleep" + QEMU_TARGET="ppc-softmmu" BUILDMAN="^qemu-ppce500$" - env: - TEST_PY_BD="qemu-x86" TEST_PY_TEST_SPEC="not sleep" + QEMU_TARGET="i386-softmmu" BUILDMAN="^qemu-x86$" TOOLCHAIN="x86_64" BUILD_ROM="yes"
Am 07.12.2016 um 17:20 schrieb Tom Rini:
addons: apt:
- sources:
packages:
- cppcheck
- sloccount
- qemu-system-arm
- qemu-system-mips
- qemu-system-ppc
- qemu-system-x86
env: global:
- BUILD_DIR=build
- HOSTCC="cc"
pushd /tmp/qemu;
you could speed up git clone:
git clone --depth 1 --single-branch --branch v2.8.0-rc3 git://git.qemu.org/qemu.git /tmp/qemu pushd /tmp/qemu git submodule update --init --recommend-shallow --reference /tmp/dtc dtc
Because we already cloned dtc in the install steps, we could use it as reference repository.
BTW: you should consider adding "--single-branch --branch master" to the other clone tasks too.
popd;
- fi
- env:
- env:
- env:
- env:
- env:
- env:
- env:
- env:
addons: apt:
- sources:
packages:
- cppcheck
- sloccount
- qemu-system-arm
- qemu-system-mips
- qemu-system-ppc
- qemu-system-x86
env: global:
- BUILD_DIR=build
- HOSTCC="cc"
pushd /tmp/qemu;
I might do this in a follow up but this is an area where we're talking about seconds of time vs making things start to be harder to read. Thanks!
Daniel Schwierzeck
