[U-Boot] [PATCH 0/2] board: ti: am57xx: Add DT support for BeagleBoard-X15 revC
Now that we have synced DTS from Latest Linux kernel, add dt support for BeagleBoard-X15 revC. Board detection support is already added for this board.
Lokesh Vutla (2): board: ti: am57xx: Add dt support for BeagleBoard-X15 revC env: ti: boot: Select dtb name for X15 revC
arch/arm/dts/Makefile | 1 + board/ti/am57xx/board.c | 3 +++ configs/am57xx_evm_defconfig | 2 +- configs/am57xx_hs_evm_defconfig | 2 +- include/environment/ti/boot.h | 2 ++ 5 files changed, 8 insertions(+), 2 deletions(-)
Add support for selecting proper dtb for am57xx BeagleBoard X15 revC u-boot from FIT
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- arch/arm/dts/Makefile | 1 + board/ti/am57xx/board.c | 3 +++ configs/am57xx_evm_defconfig | 2 +- configs/am57xx_hs_evm_defconfig | 2 +- 4 files changed, 6 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index f1dbdce9be..174c1c3f11 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -178,6 +178,7 @@ dtb-$(CONFIG_TARGET_DRA7XX_EVM) += dra72-evm.dtb dra7-evm.dtb \ dra72-evm-revc.dtb dra71-evm.dtb dra76-evm.dtb dtb-$(CONFIG_TARGET_AM57XX_EVM) += am57xx-beagle-x15.dtb \ am57xx-beagle-x15-revb1.dtb \ + am57xx-beagle-x15-revc.dtb \ am572x-idk.dtb \ am571x-idk.dtb dtb-$(CONFIG_TARGET_STV0991) += stv0991.dtb diff --git a/board/ti/am57xx/board.c b/board/ti/am57xx/board.c index 3d15cb1dbf..f79aefd400 100644 --- a/board/ti/am57xx/board.c +++ b/board/ti/am57xx/board.c @@ -1063,6 +1063,9 @@ int board_fit_config_name_match(const char *name) if (board_is_x15_revb1()) { if (!strcmp(name, "am57xx-beagle-x15-revb1")) return 0; + } else if (board_is_x15_revc()) { + if (!strcmp(name, "am57xx-beagle-x15-revc")) + return 0; } else if (!strcmp(name, "am57xx-beagle-x15")) { return 0; } diff --git a/configs/am57xx_evm_defconfig b/configs/am57xx_evm_defconfig index 11be1ad27f..f3fcda7b61 100644 --- a/configs/am57xx_evm_defconfig +++ b/configs/am57xx_evm_defconfig @@ -40,7 +40,7 @@ CONFIG_CMD_SPL=y CONFIG_ISO_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y -CONFIG_OF_LIST="am57xx-beagle-x15 am57xx-beagle-x15-revb1 am572x-idk am571x-idk" +CONFIG_OF_LIST="am57xx-beagle-x15 am57xx-beagle-x15-revb1 am57xx-beagle-x15-revc am572x-idk am571x-idk" CONFIG_DM=y CONFIG_SPL_DM=y # CONFIG_BLK is not set diff --git a/configs/am57xx_hs_evm_defconfig b/configs/am57xx_hs_evm_defconfig index 91baa2b53e..d322c37326 100644 --- a/configs/am57xx_hs_evm_defconfig +++ b/configs/am57xx_hs_evm_defconfig @@ -43,7 +43,7 @@ CONFIG_FASTBOOT_FLASH_MMC_DEV=1 CONFIG_ISO_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y -CONFIG_OF_LIST="am57xx-beagle-x15 am57xx-beagle-x15-revb1 am572x-idk am571x-idk" +CONFIG_OF_LIST="am57xx-beagle-x15 am57xx-beagle-x15-revb1 am57xx-beagle-x15-revc am572x-idk am571x-idk" CONFIG_DM=y CONFIG_SPL_DM=y # CONFIG_BLK is not set
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com Reviewed-by: Tom Rini trini@konsulko.com
am57xx-beagle-x15-revc.dts isn't included, what series brings that in? Thanks!
it's pretty small, so got buried in:
"arm: dts: dra7: sync DT with latest Linux"
https://patchwork.ozlabs.org/patch/803942/
Regards,
Select dtb name for am57xx BeagleBoard-X15 revC
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- include/environment/ti/boot.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/include/environment/ti/boot.h b/include/environment/ti/boot.h index 01f7f7a300..dabfb37204 100644 --- a/include/environment/ti/boot.h +++ b/include/environment/ti/boot.h @@ -50,6 +50,8 @@ "setenv fdtfile am57xx-beagle-x15.dtb; fi;" \ "if test $board_name = beagle_x15_revb1; then " \ "setenv fdtfile am57xx-beagle-x15-revb1.dtb; fi;" \ + "if test $board_name = beagle_x15_revc; then " \ + "setenv fdtfile am57xx-beagle-x15-revc.dtb; fi;" \ "if test $board_name = am572x_idk; then " \ "setenv fdtfile am572x-idk.dtb; fi;" \ "if test $board_name = am57xx_evm; then " \
Reviewed-by: Łukasz Majewski lukma@denx.de
Lokesh Vutla
Robert Nelson
Łukasz Majewski
