[U-Boot] [PATCH v5] pico-imx7d: Increase the CONFIG_ENV_OFFSET size
U-Boot binary has grown in such a way that it goes beyond the reserved area for the environment variables.
Running "saveenv" causes U-Boot to hang because of this overlap.
Fix this problem by increasing the CONFIG_ENV_OFFSET size.
Also, in order to prevent this same problem to happen again in the future, use CONFIG_BOARD_SIZE_LIMIT, which will detect the overlap in build-time.
CONFIG_BOARD_SIZE_LIMIT is CONFIG_ENV_OFFSET - 69 kB, as u-boot.img is flashed into the 69 kB offset.
Signed-off-by: Fabio Estevam festevam@gmail.com --- Changes since v4: - Use math expressions for better readability
Hi Stefano,
This one depends on Wolfgang's v2 patch: https://lists.denx.de/pipermail/u-boot/2018-December/351138.html
include/configs/pico-imx7d.h | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/include/configs/pico-imx7d.h b/include/configs/pico-imx7d.h index 2bc42a0..333c0b4 100644 --- a/include/configs/pico-imx7d.h +++ b/include/configs/pico-imx7d.h @@ -134,7 +134,8 @@ /* FLASH and environment organization */ #define CONFIG_ENV_SIZE SZ_8K
-#define CONFIG_ENV_OFFSET (8 * SZ_64K) +#define CONFIG_ENV_OFFSET (768 * 1024) +#define CONFIG_BOARD_SIZE_LIMIT ((768 - 69) * 1024) #define CONFIG_SYS_FSL_USDHC_NUM 2
#define CONFIG_SYS_MMC_ENV_DEV 0
Hi Fabio,
Changes since v4:
Hi Stefano,
Yes, I see the long thread with Wolfgang. IMHO it is better I apply both of them to u-boot.imx, even if Wolfgang's is quite "shared" (he patches /Makefile, too).
Regards, Stefano
Fabio Estevam
Stefano Babic
