[U-Boot] [PATCH v2] patman: add support for omitting bouncing addresses
Add support for reading a list of bouncing addresses from a in-tree file (doc/bounces) and from the ~/.patman config file. These addresses are stripped from the Cc list.
Signed-off-by: Chris Packham judge.packham@gmail.com --- This version supports an in-tree doc/bounces file as well as a section in the .patman config file. A slight annoyance is the config file parser expects key: value pairs whereas the bounces file is just a flat list. I started looking a modeling this after the aliases but then I actually thought that if we do want to tag someone as a bouncing address we probably want to be explicit about it.
Changes in v2: - better integration with existing configuration - documentation
doc/bounces | 3 +++ tools/patman/README | 12 ++++++++++++ tools/patman/series.py | 2 ++ tools/patman/settings.py | 18 ++++++++++++++++++ 4 files changed, 35 insertions(+) create mode 100644 doc/bounces
diff --git a/doc/bounces b/doc/bounces new file mode 100644 index 000000000000..d1c5f0d246eb --- /dev/null +++ b/doc/bounces @@ -0,0 +1,3 @@ +# List of addresses picked up by patman/get_maintainer.pl that are known to +# bounce. Addresses are listed one per line and need to match the author +# information recorded in git. diff --git a/tools/patman/README b/tools/patman/README index e36857dedea1..8582ed6ba12c 100644 --- a/tools/patman/README +++ b/tools/patman/README @@ -84,6 +84,18 @@ Aliases are recursive. The checkpatch.pl in the U-Boot tools/ subdirectory will be located and used. Failing that you can put it into your path or ~/bin/checkpatch.pl
+If you want to avoid sending patches to email addresses that are picked up +by patman but are known to bounce you can add a [bounces] section to your +.patman file. Unlike the [alias] section these are simple key: value pairs +that are not recursive. + +>>> + +[bounces] +gonefishing: Fred Bloggs f.bloggs@napier.net + +<<< +
If you want to change the defaults for patman's command-line arguments, you can add a [settings] section to your .patman file. This can be used diff --git a/tools/patman/series.py b/tools/patman/series.py index d3947a7c2ac5..ddc0993d9eac 100644 --- a/tools/patman/series.py +++ b/tools/patman/series.py @@ -10,6 +10,7 @@ import os
import get_maintainer import gitutil +import settings import terminal
# Series-xxx tags that we understand @@ -233,6 +234,7 @@ class Series(dict): cc += add_maintainers elif add_maintainers: cc += get_maintainer.GetMaintainer(commit.patch) + cc = set(cc) - set(settings.bounces) cc = [m.encode('utf-8') if type(m) != str else m for m in cc] all_ccs += cc print(commit.patch, ', '.join(set(cc)), file=fd) diff --git a/tools/patman/settings.py b/tools/patman/settings.py index 5f207f5ef1c4..d735ff9ba3c6 100644 --- a/tools/patman/settings.py +++ b/tools/patman/settings.py @@ -269,6 +269,19 @@ def _ReadAliasFile(fname): if bad_line: print(bad_line)
+def _ReadBouncesFile(fname): + """Read in the bounces file if it exists + + Args: + fname: Filename to read. + """ + if os.path.exists(fname): + with open(fname) as fd: + for line in fd: + if line.startswith('#'): + continue + bounces.add(line.strip()) + def Setup(parser, project_name, config_fname=''): """Set up the settings module by reading config files.
@@ -293,10 +306,15 @@ def Setup(parser, project_name, config_fname=''): for name, value in config.items('alias'): alias[name] = value.split(',')
+ _ReadBouncesFile('doc/bounces') + for name, value in config.items('bounces'): + bounces.add(value) + _UpdateDefaults(parser, config)
# These are the aliases we understand, indexed by alias. Each member is a list. alias = {} +bounces = set()
if __name__ == "__main__": import doctest
Hi Chris,
Changes in v2:
- documentation
Can you please arrange for it to print out the email addresses that are skipped? I think it might be very confusing if someone tries to send to an address and it does not work.
- """Read in the bounces file if it exists
- Args:
- if os.path.exists(fname):
for line in fd:
continue
- _ReadBouncesFile('doc/bounces')
- for name, value in config.items('bounces'):
bounces.add(value)
- _UpdateDefaults(parser, config)
if __name__ == "__main__": import doctest -- 2.14.1
Chris Packham
