[PATCH 1/1] efi_selftest: use GUID to find ESP in dtbdump
If dtbdump.efi is loaded from memory when calling LoadImage the loaded image protocol will not indicate the partition from where it was loaded. In this case use the EFI system partition for the 'load' and 'save' commands.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_selftest/dtbdump.c | 85 +++++++++++++++++++++++--------------- 1 file changed, 52 insertions(+), 33 deletions(-)
diff --git a/lib/efi_selftest/dtbdump.c b/lib/efi_selftest/dtbdump.c index 953b264d9d..38ab9f8bf0 100644 --- a/lib/efi_selftest/dtbdump.c +++ b/lib/efi_selftest/dtbdump.c @@ -9,6 +9,7 @@ #include <common.h> #include <efi_api.h> #include <efi_dt_fixup.h> +#include <part.h>
#define BUFFER_SIZE 64 #define ESC 0x17 @@ -27,6 +28,7 @@ static efi_handle_t handle; static struct efi_system_table *systable; static const efi_guid_t efi_dt_fixup_protocol_guid = EFI_DT_FIXUP_PROTOCOL_GUID; static const efi_guid_t efi_file_info_guid = EFI_FILE_INFO_GUID; +static const efi_guid_t efi_system_partition_guid = PARTITION_SYSTEM_GUID;
/** * print() - print string @@ -230,6 +232,52 @@ void do_help(void) error(L"exit - exit the shell\r\n"); }
+/** + * open_file_system() - open simple file system protocol + * + * file_system: interface of the simple file system protocol + * Return: status code + */ +static efi_status_t +open_file_system(struct efi_simple_file_system_protocol **file_system) +{ + struct efi_loaded_image *loaded_image; + efi_status_t ret; + efi_handle_t *handle_buffer = NULL; + efi_uintn_t count; + + ret = bs->open_protocol(handle, &loaded_image_guid, + (void **)&loaded_image, NULL, NULL, + EFI_OPEN_PROTOCOL_GET_PROTOCOL); + if (ret != EFI_SUCCESS) { + error(L"Loaded image protocol not found\r\n"); + return ret; + } + + /* Open the simple file system protocol on the same partition */ + ret = bs->open_protocol(loaded_image->device_handle, + &guid_simple_file_system_protocol, + (void **)file_system, NULL, NULL, + EFI_OPEN_PROTOCOL_GET_PROTOCOL); + if (ret == EFI_SUCCESS) + return ret; + + /* Open the simple file system protocol on the UEFI system partition */ + ret = bs->locate_handle_buffer(BY_PROTOCOL, &efi_system_partition_guid, + NULL, &count, &handle_buffer); + if (ret == EFI_SUCCESS && handle_buffer) + ret = bs->open_protocol(handle_buffer[0], + &guid_simple_file_system_protocol, + (void **)file_system, NULL, NULL, + EFI_OPEN_PROTOCOL_GET_PROTOCOL); + if (ret != EFI_SUCCESS) + error(L"Failed to open simple file system protocol\r\n"); + if (handle) + bs->free_pool(handle_buffer); + + return ret; +} + /** * do_load() - load and install device-tree * @@ -239,7 +287,6 @@ void do_help(void) efi_status_t do_load(u16 *filename) { struct efi_dt_fixup_protocol *dt_fixup_prot; - struct efi_loaded_image *loaded_image; struct efi_simple_file_system_protocol *file_system; struct efi_file_handle *root = NULL, *file = NULL; u64 addr = 0; @@ -258,22 +305,9 @@ efi_status_t do_load(u16 *filename)
filename = skip_whitespace(filename);
- ret = bs->open_protocol(handle, &loaded_image_guid, - (void **)&loaded_image, NULL, NULL, - EFI_OPEN_PROTOCOL_GET_PROTOCOL); - if (ret != EFI_SUCCESS) { - error(L"Loaded image protocol not found\r\n"); - return ret; - } - /* Open the simple file system protocol */ - ret = bs->open_protocol(loaded_image->device_handle, - &guid_simple_file_system_protocol, - (void **)&file_system, NULL, NULL, - EFI_OPEN_PROTOCOL_GET_PROTOCOL); - if (ret != EFI_SUCCESS) { - error(L"Failed to open simple file system protocol\r\n"); + ret = open_file_system(&file_system); + if (ret != EFI_SUCCESS) goto out; - }
/* Open volume */ ret = file_system->open_volume(file_system, &root); @@ -389,7 +423,6 @@ out: */ efi_status_t do_save(u16 *filename) { - struct efi_loaded_image *loaded_image; struct efi_simple_file_system_protocol *file_system; efi_uintn_t dtb_size; struct efi_file_handle *root, *file; @@ -409,23 +442,9 @@ efi_status_t do_save(u16 *filename)
- ret = bs->open_protocol(handle, &loaded_image_guid, - (void **)&loaded_image, NULL, NULL, - EFI_OPEN_PROTOCOL_GET_PROTOCOL); - if (ret != EFI_SUCCESS) { - error(L"Loaded image protocol not found\r\n"); - return ret; - } - - /* Open the simple file system protocol */ - ret = bs->open_protocol(loaded_image->device_handle, - &guid_simple_file_system_protocol, - (void **)&file_system, NULL, NULL, - EFI_OPEN_PROTOCOL_GET_PROTOCOL); - if (ret != EFI_SUCCESS) { - error(L"Failed to open simple file system protocol\r\n"); + ret = open_file_system(&file_system); + if (ret != EFI_SUCCESS) return ret; - }
/* Open volume */ ret = file_system->open_volume(file_system, &root); -- 2.30.0
