[U-Boot] [GIT PULL] Pull request: u-boot-imx
Hi Albert,
my new pull request. Take care that I drop patches for the MX53 LOCO board as discussed on the mailing list (they were part of last pull request, commit 96c1b214b47416ae07aac267e45a600cc9567eed in uboot-arm). This pull is against u-boot tree, as after dropping the patches I rebased on it.
The following changes since commit 735eb0f0e66b544b1dfaf6c43ce6e4bd9ae64b5e:
tools/env: fix redundant env flag comparison (2011-04-21 00:25:08 +0200)
are available in the git repository at: git://www.denx.de/git/u-boot-imx.git master
Fabio Estevam (5): mx25: Make the UART port number explicit in its setup function ARM: mx31: Print the silicon version MX31: Introduce get_reset_cause() MX31: mx31pdk: Make the board name simpler. ARM: MX31: Fix file name label
Jason Liu (1): MX5: factor out boot cause funciton to common code
Liu Hui-R64343 (2): MX53: drop config.mk from mx53evk MX5: Enable flat-device-tree support on mx51/53 evk board
Stefano Babic (6): Makefile: change rule to build IMX image MX51: drop config.mk from mx51evk MX31: add support for MX31 watchdog MX31: qong: add watchdog IMX: MX31: Cleanup include files and drop nasty #ifdef in drivers MX31: drop warnings in get_cpu_rev
Makefile | 2 +- arch/arm/cpu/arm1136/mx31/devices.c | 4 +- arch/arm/cpu/arm1136/mx31/generic.c | 59 +++++++++++++++++++- arch/arm/cpu/arm1136/mx31/timer.c | 40 +++++++++++++- arch/arm/cpu/arm926ejs/mx25/generic.c | 2 +- arch/arm/cpu/armv7/mx5/soc.c | 28 +++++++++ arch/arm/include/asm/arch-mx31/{mx31.h => clock.h} | 6 +- .../asm/arch-mx31/{mx31-regs.h => imx-regs.h} | 41 +++++++++++++- board/davedenx/qong/fpga.c | 4 +- board/davedenx/qong/lowlevel_init.S | 2 +- board/davedenx/qong/qong.c | 16 +++++- board/freescale/mx31ads/lowlevel_init.S | 2 +- board/freescale/mx31ads/mx31ads.c | 4 +- board/freescale/mx31pdk/lowlevel_init.S | 2 +- board/freescale/mx31pdk/mx31pdk.c | 6 +- board/freescale/mx51evk/config.mk | 25 -------- board/freescale/mx53evk/config.mk | 24 -------- board/imx31_phycore/imx31_phycore.c | 4 +- board/imx31_phycore/lowlevel_init.S | 2 +- board/karo/tx25/tx25.c | 4 +- board/logicpd/imx31_litekit/imx31_litekit.c | 4 +- board/logicpd/imx31_litekit/lowlevel_init.S | 2 +- boards.cfg | 4 +- drivers/gpio/mxc_gpio.c | 5 -- drivers/i2c/mxc_i2c.c | 7 +-- drivers/serial/serial_mxc.c | 4 - drivers/spi/mxc_spi.c | 9 +-- drivers/usb/host/ehci-mxc.c | 2 +- drivers/video/mx3fb.c | 6 +- include/configs/imx31_litekit.h | 2 +- include/configs/mx31ads.h | 2 +- include/configs/mx31pdk.h | 2 +- include/configs/mx51evk.h | 5 ++ include/configs/mx53evk.h | 3 + include/configs/qong.h | 3 +- nand_spl/nand_boot_fsl_nfc.c | 4 - 36 files changed, 221 insertions(+), 120 deletions(-) rename arch/arm/include/asm/arch-mx31/{mx31.h => clock.h} (92%) rename arch/arm/include/asm/arch-mx31/{mx31-regs.h => imx-regs.h} (97%) delete mode 100644 board/freescale/mx51evk/config.mk delete mode 100644 board/freescale/mx53evk/config.mk
Le 22/04/2011 14:50, Stefano Babic a écrit :
Hi Albert,
This is causing a forced rebase on u-boot-arm/master of course.
ARM Custodians who already had a pull request acknowledged please check that I have not accidentally dropped any of the commits you had requested a pull for. Currently, above u-boot/master I have the following:
Albert ARIBAUD (1): Replace obsolete e-mail address
Alexander Holler (4): omap3_beagle: enable the use of a plain text file OMAP3: Change some USB related MUX values OMAP3: Add support for DPLL5 (usbhost) omap3_beagle: enable EHCI and USB storage.
Enric Balletbo i Serra (2): ARM: OMAP3: Revamp IGEP v2 default ARM: OMAP3: Revamp IGEP module default configuration
Eric Cooper (1): ARM: fix stack pointer adjustment in board_init_f()
Fabio Estevam (6): mx25: Make the UART port number explicit in its setup function ARM: mx31: Print the silicon version MX31: Introduce get_reset_cause() MX31: mx31pdk: Make the board name simpler. ARM: MX31: Fix file name label MX25: tx25: Add _end section on nand_spl
Igor Grinberg (9): OMAP3: CM-T35: Move DECLARE_GLOBAL_DATA_PTR to file scope OMAP3: CM-T35: update config OMAP3: CM-T35: update board files header information OMAP3: CM-T35: update MAINTAINERS file OMAP3: CM-T35: add MMC1 pinmux OMAP3: CM-T35: fix mmc OMAP3: CM-T35: remove redundand i2c initialization OMAP3: CM-T35: enable the green LED OMAP3: CM-T35: Add support for CM-T3730
Jason Kridner (2): Add 'led' command BeagleBoard: Added LED driver
Koen Kooi (2): OMAP3: BeagleBoard: add xM rev B to ID table OMAP3: BeagleBoard: add more expansionboard IDs
Lei Wen (6): pxa: move i2c driver to the common place mv_i2c: fix timeout value to be consistent with comments mv_i2c: use structure to replace the direclty define I2C: add i2c support for Pantheon platform I2C: mv_i2c: add multi bus support I2C: add i2c support for Armada100 platform
Luca Ceresoli (4): ARMV7: OMAP3: Fix preprocessor check for CONFIG_OMAP34XX ARMV7: OMAP3: Add GPMC_CONFIGx register value definitions ARMV7: OMAP3: Cleanup extern variables in mem.c ARMV7: OMAP3: Add support for Comelit DIG297 board
Macpaul Lin (4): ftpmu010: fix relocation and enhance features ftpmu010.h: add asm support used by lowlevel_init fttmr010: move fttmr010 header to include/faraday a320evb: fix include path of timer fttmr010
Matt Waddel (1): ARMV7: Vexpress: Remove config.mk
Matthias Weisser (1): arm: Use optimized memcpy and memset from linux
Minkyu Kang (1): Don't grab memory for LCD if FB address is defined
Po-Yu Chuang (2): power: ftpmu010: move drivers/power/ftpmu010.h to include/faraday arm: a320: use new ftpmu010 API
Rogan Dawes (1): Orion5x: Correct DRAM bank detection
Srinath (1): ARMV7: AM3517/05: Add support for CraneBoard.
Stefano Babic (7): Makefile: change rule to build IMX image MX51: drop config.mk from mx51evk MX31: add support for MX31 watchdog MX31: qong: add watchdog IMX: MX31: Cleanup include files and drop nasty #ifdef in drivers MX31: drop warnings in get_cpu_rev MX31: mx31pdk: fix nand_spl
Steve Kipisz (1): OMAP3: BeagleBoard: Enable pullups on i2c2.
Sughosh Ganu (1): Fix the issue of _end symbol not being found while building
Tom Warren (4): arm: Tegra2: add support for A9 CPU init arm: Tegra2: Add missing PLLX init arm: Tegra2: GPIO: Add basic GPIO definitions arm: Tegra2: Move clk/mux init to board_early_init_f, add GPIO init
Amicalement,
Albert ARIBAUD
Stefano Babic
