[U-Boot-Users] [PATCH] lib_ppc: Revert "Make MPC83xx one step closer to full relocation."
This reverts commit 70431e8a7393b6b793f77957f95b999fc9a269b8 which has proven problematic getting right from the start at least on 83xx and 4xx.
Signed-off-by: Kim Phillips kim.phillips@freescale.com --- cpu/mpc83xx/start.S | 11 ++++------- lib_ppc/board.c | 1 - 2 files changed, 4 insertions(+), 8 deletions(-)
diff --git a/cpu/mpc83xx/start.S b/cpu/mpc83xx/start.S index fdf9d35..309eb30 100644 --- a/cpu/mpc83xx/start.S +++ b/cpu/mpc83xx/start.S @@ -172,11 +172,8 @@ boot_warm: /* time t 5 */ /* there and deflate the flash size back to minimal size */ /*------------------------------------------------------------*/ bl map_flash_by_law1 - - GET_GOT /* initialize GOT access */ - lwz r4, GOT(_start) - addi r4, r4, -EXC_OFF_SYS_RESET - + lis r4, (CFG_MONITOR_BASE)@h + ori r4, r4, (CFG_MONITOR_BASE)@l addi r5, r4, in_flash - _start + EXC_OFF_SYS_RESET mtlr r5 blr @@ -875,8 +872,8 @@ relocate_code: mr r10, r5 /* Save copy of Destination Address */
mr r3, r5 /* Destination Address */ - lwz r4, GOT(_start) - addi r4, r4, -EXC_OFF_SYS_RESET + lis r4, CFG_MONITOR_BASE@h /* Source Address */ + ori r4, r4, CFG_MONITOR_BASE@l lwz r5, GOT(__init_end) sub r5, r5, r4 li r6, CFG_CACHELINE_SIZE /* Cache Line Size */ diff --git a/lib_ppc/board.c b/lib_ppc/board.c index b2bc4eb..1b8a872 100644 --- a/lib_ppc/board.c +++ b/lib_ppc/board.c @@ -124,7 +124,6 @@ DECLARE_GLOBAL_DATA_PTR; #define CFG_MEM_TOP_HIDE 0 #endif
-extern ulong _start; extern ulong __init_end; extern ulong _end; ulong monitor_flash_len;
Applied, thanks.
Kim Phillips
