[U-Boot] please pull u-boot-samsung master
Dear Tom,
The following changes since commit 1606b34aa50804227806971dbb6b82ea0bf81f55:
Merge branch 'master' of git://git.denx.de/u-boot-fsl-qoriq (2015-02-25 18:14:18 -0500)
http://git.denx.de/u-boot-samsung
for you to fetch changes up to 306f527eff269e48a98c9d83016df6d6877dbb6a:
Exynos: Fix L2 cache timings on Exynos5420 and Exynos5800 (2015-02-28 18:03:46 +0900)
---------------------------------------------------------------- Akshay Saraswat (9): Exynos542x: Config: Add various configs Exynos542x: CPU: Power down all secondary cores Exynos542x: Add workaround for ARM errata 798870 Exynos542x: Add workaround for ARM errata 799270 Exynos542x: Add workaround for exynos iROM errata Exynos542x: cache: Disable clean/evict push to external Exynos542x: add L2 control register configuration Exynos542x: Fix secondary core booting for thumb Exynos542x: Make A7s boot with thumb-mode U-Boot on warm reset
Doug Anderson (1): Exynos: Fix L2 cache timings on Exynos5420 and Exynos5800
arch/arm/cpu/armv7/exynos/Makefile | 2 + arch/arm/cpu/armv7/exynos/common_setup.h | 62 ++++++++++++ arch/arm/cpu/armv7/exynos/exynos5_setup.h | 3 + arch/arm/cpu/armv7/exynos/lowlevel_init.c | 147 +++++++++++++++++++++++++++++ arch/arm/cpu/armv7/exynos/sec_boot.S | 128 +++++++++++++++++++++++++ arch/arm/cpu/armv7/exynos/soc.c | 35 ------- arch/arm/include/asm/arch-exynos/cpu.h | 5 + arch/arm/include/asm/arch-exynos/system.h | 88 +++++++++++++++++ arch/arm/include/asm/armv7.h | 44 +++++++++ include/configs/exynos5420-common.h | 16 ++++ 10 files changed, 495 insertions(+), 35 deletions(-) create mode 100644 arch/arm/cpu/armv7/exynos/sec_boot.S
Minkyu Kang
