[U-Boot] [PATCH 0/4] Add Rock960 and Ficus 96Board support
This patchset adds support for Rock960 and Ficus 96Boards from Vamrs. Since both boards share most of the configurations, a common Rock960 family support is added with common support and the actual boards are based on this.
The previous version of the patchseries were adding Rock960 [1] and Ficus [2] board support individually, but this series fuses them together based on the common board support as per Linux kernel.
[1] https://patchwork.ozlabs.org/cover/963239/ [2] https://lists.denx.de/pipermail/u-boot/2018-August/339059.html
This patchseries has been tested on Rock960 v1.2 board and expecting Ezequiel to do the testing for Ficus.
PS: I have explicitly removed the previous Ack's for the Ficus board since there has been a heavy modification done on these patches.
Thanks, Mani
Manivannan Sadhasivam (4): arm: dts: rockchip: add some common pin-settings to rk3399 rockchip: rk3399: Add common Rock960 family from Vamrs rockchip: rk3399: Add Rock960 CE board support rockchip: rk3399: Add Ficus EE board support
arch/arm/dts/Makefile | 2 + arch/arm/dts/rk3399-ficus.dts | 78 + arch/arm/dts/rk3399-rock960.dts | 45 + arch/arm/dts/rk3399-rock960.dtsi | 506 ++++++ .../arm/dts/rk3399-sdram-lpddr3-2GB-1600.dtsi | 1536 +++++++++++++++++ arch/arm/dts/rk3399.dtsi | 55 +- arch/arm/mach-rockchip/rk3399/Kconfig | 26 + board/vamrs/rock960_rk3399/Kconfig | 15 + board/vamrs/rock960_rk3399/MAINTAINERS | 6 + board/vamrs/rock960_rk3399/Makefile | 6 + board/vamrs/rock960_rk3399/README | 151 ++ board/vamrs/rock960_rk3399/rock960-rk3399.c | 50 + configs/ficus-rk3399_defconfig | 71 + configs/rock960-rk3399_defconfig | 62 + include/configs/rock960_rk3399.h | 15 + 15 files changed, 2618 insertions(+), 6 deletions(-) create mode 100644 arch/arm/dts/rk3399-ficus.dts create mode 100644 arch/arm/dts/rk3399-rock960.dts create mode 100644 arch/arm/dts/rk3399-rock960.dtsi create mode 100644 arch/arm/dts/rk3399-sdram-lpddr3-2GB-1600.dtsi create mode 100644 board/vamrs/rock960_rk3399/Kconfig create mode 100644 board/vamrs/rock960_rk3399/MAINTAINERS create mode 100644 board/vamrs/rock960_rk3399/Makefile create mode 100644 board/vamrs/rock960_rk3399/README create mode 100644 board/vamrs/rock960_rk3399/rock960-rk3399.c create mode 100644 configs/ficus-rk3399_defconfig create mode 100644 configs/rock960-rk3399_defconfig create mode 100644 include/configs/rock960_rk3399.h
Those pins would be used by many boards.
Commit grabbed from Linux:
commit b41023282d07b61a53e2c9b9508912b1e7ce7b4f Author: Randy Li ayaka@soulik.info Date: Thu Jun 21 21:32:10 2018 +0800
arm64: dts: rockchip: add some common pin-settings to rk3399
Signed-off-by: Randy Li ayaka@soulik.info Signed-off-by: Heiko Stuebner heiko@sntech.de
Acked-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com Signed-off-by: Randy Li ayaka@soulik.info Signed-off-by: Heiko Stuebner heiko@sntech.de Signed-off-by: Ezequiel Garcia ezequiel@collabora.com --- arch/arm/dts/rk3399.dtsi | 55 +++++++++++++++++++++++++++++++++++----- 1 file changed, 49 insertions(+), 6 deletions(-)
diff --git a/arch/arm/dts/rk3399.dtsi b/arch/arm/dts/rk3399.dtsi index 83c257b1228..8349451b03d 100644 --- a/arch/arm/dts/rk3399.dtsi +++ b/arch/arm/dts/rk3399.dtsi @@ -1602,19 +1602,49 @@ drive-strength = <12>; };
+ pcfg_pull_none_13ma: pcfg-pull-none-13ma { + bias-disable; + drive-strength = <13>; + }; + + pcfg_pull_none_18ma: pcfg-pull-none-18ma { + bias-disable; + drive-strength = <18>; + }; + + pcfg_pull_none_20ma: pcfg-pull-none-20ma { + bias-disable; + drive-strength = <20>; + }; + + pcfg_pull_up_2ma: pcfg-pull-up-2ma { + bias-pull-up; + drive-strength = <2>; + }; + pcfg_pull_up_8ma: pcfg-pull-up-8ma { bias-pull-up; drive-strength = <8>; };
+ pcfg_pull_up_18ma: pcfg-pull-up-18ma { + bias-pull-up; + drive-strength = <18>; + }; + + pcfg_pull_up_20ma: pcfg-pull-up-20ma { + bias-pull-up; + drive-strength = <20>; + }; + pcfg_pull_down_4ma: pcfg-pull-down-4ma { bias-pull-down; drive-strength = <4>; };
- pcfg_pull_up_2ma: pcfg-pull-up-2ma { - bias-pull-up; - drive-strength = <2>; + pcfg_pull_down_8ma: pcfg-pull-down-8ma { + bias-pull-down; + drive-strength = <8>; };
pcfg_pull_down_12ma: pcfg-pull-down-12ma { @@ -1622,9 +1652,22 @@ drive-strength = <12>; };
- pcfg_pull_none_13ma: pcfg-pull-none-13ma { - bias-disable; - drive-strength = <13>; + pcfg_pull_down_18ma: pcfg-pull-down-18ma { + bias-pull-down; + drive-strength = <18>; + }; + + pcfg_pull_down_20ma: pcfg-pull-down-20ma { + bias-pull-down; + drive-strength = <20>; + }; + + pcfg_output_high: pcfg-output-high { + output-high; + }; + + pcfg_output_low: pcfg-output-low { + output-low; };
clock {
On 19 September 2018 at 16:58, Manivannan Sadhasivam manivannan.sadhasivam@linaro.org wrote:
arm64: dts: rockchip: add some common pin-settings to rk3399 Those pins would be used by many boards. Signed-off-by: Randy Li <ayaka@soulik.info> Signed-off-by: Heiko Stuebner <heiko@sntech.de>
bias-disable;
bias-disable;
bias-disable;
bias-pull-up;
bias-pull-up;
bias-pull-up;
bias-pull-up;
bias-pull-down;
drive-strength = <8>; }; pcfg_pull_down_12ma: pcfg-pull-down-12ma {
bias-disable;
bias-pull-down;
bias-pull-down;
output-high;
output-low; }; clock {
-- 2.17.1
Rock960 is a family of boards based on Rockchip RK3399 SoC from Vamrs. It consists of Rock960 (Consumer Edition) and Ficus (Enterprise Edition) 96Boards.
Below are some of the key differences between both Rock960 and Ficus boards:
1. Different host enable GPIO for USB 2. Different power and reset GPIO for PCI-E 3. No Ethernet port on Rock960
The common board support will be utilized by both boards. The device tree has been organized in such a way that only the properties which differ between both boards are placed in the board specific dts and the reset of the nodes are placed in common dtsi file.
Signed-off-by: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org [Added instructions for SD card boot] Signed-off-by: Ezequiel Garcia ezequiel@collabora.com --- arch/arm/dts/rk3399-rock960.dtsi | 506 ++++++++++++++++++++ arch/arm/mach-rockchip/rk3399/Kconfig | 26 + board/vamrs/rock960_rk3399/Kconfig | 15 + board/vamrs/rock960_rk3399/MAINTAINERS | 6 + board/vamrs/rock960_rk3399/Makefile | 6 + board/vamrs/rock960_rk3399/README | 151 ++++++ board/vamrs/rock960_rk3399/rock960-rk3399.c | 50 ++ include/configs/rock960_rk3399.h | 15 + 8 files changed, 775 insertions(+) create mode 100644 arch/arm/dts/rk3399-rock960.dtsi create mode 100644 board/vamrs/rock960_rk3399/Kconfig create mode 100644 board/vamrs/rock960_rk3399/MAINTAINERS create mode 100644 board/vamrs/rock960_rk3399/Makefile create mode 100644 board/vamrs/rock960_rk3399/README create mode 100644 board/vamrs/rock960_rk3399/rock960-rk3399.c create mode 100644 include/configs/rock960_rk3399.h
diff --git a/arch/arm/dts/rk3399-rock960.dtsi b/arch/arm/dts/rk3399-rock960.dtsi new file mode 100644 index 00000000000..51644d6d02d --- /dev/null +++ b/arch/arm/dts/rk3399-rock960.dtsi @@ -0,0 +1,506 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2018 Linaro Ltd. + */ + +#include <dt-bindings/pwm/pwm.h> +#include <dt-bindings/pinctrl/rockchip.h> +#include "rk3399.dtsi" + +/ { + vcc1v8_s0: vcc1v8-s0 { + compatible = "regulator-fixed"; + regulator-name = "vcc1v8_s0"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + }; + + vcc_sys: vcc-sys { + compatible = "regulator-fixed"; + regulator-name = "vcc_sys"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + }; + + vcc3v3_sys: vcc3v3-sys { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3_sys"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + vin-supply = <&vcc_sys>; + }; + + vcc3v3_pcie: vcc3v3-pcie-regulator { + compatible = "regulator-fixed"; + enable-active-high; + pinctrl-names = "default"; + pinctrl-0 = <&pcie_drv>; + regulator-boot-on; + regulator-name = "vcc3v3_pcie"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vcc3v3_sys>; + }; + + vcc5v0_host: vcc5v0-host-regulator { + compatible = "regulator-fixed"; + enable-active-high; + pinctrl-names = "default"; + pinctrl-0 = <&host_vbus_drv>; + regulator-name = "vcc5v0_host"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + vin-supply = <&vcc_sys>; + }; + + vdd_log: vdd-log { + compatible = "pwm-regulator"; + pwms = <&pwm2 0 25000 0>; + regulator-name = "vdd_log"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1400000>; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vcc_sys>; + }; + +}; + +&cpu_l0 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_l1 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_l2 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_l3 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_b0 { + cpu-supply = <&vdd_cpu_b>; +}; + +&cpu_b1 { + cpu-supply = <&vdd_cpu_b>; +}; + +&emmc_phy { + status = "okay"; +}; + +&hdmi { + status = "okay"; +}; + +&i2c0 { + clock-frequency = <400000>; + i2c-scl-rising-time-ns = <168>; + i2c-scl-falling-time-ns = <4>; + status = "okay"; + + vdd_cpu_b: regulator@40 { + compatible = "silergy,syr827"; + reg = <0x40>; + fcs,suspend-voltage-selector = <1>; + regulator-name = "vdd_cpu_b"; + regulator-min-microvolt = <712500>; + regulator-max-microvolt = <1500000>; + regulator-ramp-delay = <1000>; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vcc_sys>; + status = "okay"; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_gpu: regulator@41 { + compatible = "silergy,syr828"; + reg = <0x41>; + fcs,suspend-voltage-selector = <1>; + regulator-name = "vdd_gpu"; + regulator-min-microvolt = <712500>; + regulator-max-microvolt = <1500000>; + regulator-ramp-delay = <1000>; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vcc_sys>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + rk808: pmic@1b { + compatible = "rockchip,rk808"; + reg = <0x1b>; + interrupt-parent = <&gpio1>; + interrupts = <21 IRQ_TYPE_LEVEL_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&pmic_int_l>; + rockchip,system-power-controller; + wakeup-source; + #clock-cells = <1>; + clock-output-names = "xin32k", "rk808-clkout2"; + + vcc1-supply = <&vcc_sys>; + vcc2-supply = <&vcc_sys>; + vcc3-supply = <&vcc_sys>; + vcc4-supply = <&vcc_sys>; + vcc6-supply = <&vcc_sys>; + vcc7-supply = <&vcc_sys>; + vcc8-supply = <&vcc3v3_sys>; + vcc9-supply = <&vcc_sys>; + vcc10-supply = <&vcc_sys>; + vcc11-supply = <&vcc_sys>; + vcc12-supply = <&vcc3v3_sys>; + vddio-supply = <&vcc_1v8>; + + regulators { + vdd_center: DCDC_REG1 { + regulator-name = "vdd_center"; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <1350000>; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_cpu_l: DCDC_REG2 { + regulator-name = "vdd_cpu_l"; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <1350000>; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_ddr: DCDC_REG3 { + regulator-name = "vcc_ddr"; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc_1v8: DCDC_REG4 { + regulator-name = "vcc_1v8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcc1v8_dvp: LDO_REG1 { + regulator-name = "vcc1v8_dvp"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcca1v8_hdmi: LDO_REG2 { + regulator-name = "vcca1v8_hdmi"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcca_1v8: LDO_REG3 { + regulator-name = "vcca_1v8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcc_sd: LDO_REG4 { + regulator-name = "vcc_sd"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vcc3v0_sd: LDO_REG5 { + regulator-name = "vcc3v0_sd"; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3000000>; + }; + }; + + vcc_1v5: LDO_REG6 { + regulator-name = "vcc_1v5"; + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <1500000>; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1500000>; + }; + }; + + vcca0v9_hdmi: LDO_REG7 { + regulator-name = "vcca0v9_hdmi"; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <900000>; + }; + }; + + vcc_3v0: LDO_REG8 { + regulator-name = "vcc_3v0"; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3000000>; + }; + }; + + vcc3v3_s3: SWITCH_REG1 { + regulator-name = "vcc3v3_s3"; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc3v3_s0: SWITCH_REG2 { + regulator-name = "vcc3v3_s0"; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + }; + }; +}; + +&i2c1 { + status = "okay"; +}; + +&i2c2 { + status = "okay"; +}; + +&i2c3 { + status = "okay"; +}; + +&i2c4 { + status = "okay"; +}; + +&io_domains { + bt656-supply = <&vcc1v8_s0>; /* bt656_gpio2ab_ms */ + audio-supply = <&vcc1v8_s0>; /* audio_gpio3d4a_ms */ + sdmmc-supply = <&vcc_sd>; /* sdmmc_gpio4b_ms */ + gpio1830-supply = <&vcc_3v0>; /* gpio1833_gpio4cd_ms */ + status = "okay"; +}; + +&pcie_phy { + status = "okay"; +}; + +&pcie0 { + num-lanes = <4>; + pinctrl-names = "default"; + pinctrl-0 = <&pcie_clkreqn_cpm>; + vpcie3v3-supply = <&vcc3v3_pcie>; + status = "okay"; +}; + +&pmu_io_domains { + pmu1830-supply = <&vcc_1v8>; + status = "okay"; +}; + +&pinctrl { + sdmmc { + sdmmc_bus1: sdmmc-bus1 { + rockchip,pins = + <4 8 RK_FUNC_1 &pcfg_pull_up_8ma>; + }; + + sdmmc_bus4: sdmmc-bus4 { + rockchip,pins = + <4 8 RK_FUNC_1 &pcfg_pull_up_8ma>, + <4 9 RK_FUNC_1 &pcfg_pull_up_8ma>, + <4 10 RK_FUNC_1 &pcfg_pull_up_8ma>, + <4 11 RK_FUNC_1 &pcfg_pull_up_8ma>; + }; + + sdmmc_clk: sdmmc-clk { + rockchip,pins = + <4 12 RK_FUNC_1 &pcfg_pull_none_18ma>; + }; + + sdmmc_cmd: sdmmc-cmd { + rockchip,pins = + <4 13 RK_FUNC_1 &pcfg_pull_up_8ma>; + }; + }; + + pmic { + pmic_int_l: pmic-int-l { + rockchip,pins = + <1 21 RK_FUNC_GPIO &pcfg_pull_up>; + }; + + vsel1_gpio: vsel1-gpio { + rockchip,pins = + <1 17 RK_FUNC_GPIO &pcfg_pull_down>; + }; + + vsel2_gpio: vsel2-gpio { + rockchip,pins = + <1 14 RK_FUNC_GPIO &pcfg_pull_down>; + }; + }; +}; + +&pwm2 { + status = "okay"; +}; + +&pwm3 { + status = "okay"; +}; + +&sdhci { + bus-width = <8>; + mmc-hs400-1_8v; + mmc-hs400-enhanced-strobe; + non-removable; + status = "okay"; +}; + +&sdmmc { + bus-width = <4>; + cap-mmc-highspeed; + cap-sd-highspeed; + clock-frequency = <100000000>; + clock-freq-min-max = <100000 100000000>; + cd-gpios = <&gpio0 7 GPIO_ACTIVE_LOW>; + disable-wp; + sd-uhs-sdr104; + vqmmc-supply = <&vcc_sd>; + card-detect-delay = <800>; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd &sdmmc_bus4>; + status = "okay"; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_xfer &uart0_cts>; + status = "okay"; +}; + +&uart2 { + status = "okay"; +}; + +&u2phy0 { + status = "okay"; +}; + +&u2phy1 { + status = "okay"; +}; + +&u2phy0_host { + phy-supply = <&vcc5v0_host>; + status = "okay"; +}; + +&u2phy1_host { + phy-supply = <&vcc5v0_host>; + status = "okay"; +}; + +&u2phy0_otg { + status = "okay"; +}; + +&u2phy1_otg { + status = "okay"; +}; + +&usb_host0_ehci { + status = "okay"; +}; + +&usb_host0_ohci { + status = "okay"; +}; + +&usb_host1_ehci { + status = "okay"; +}; + +&usb_host1_ohci { + status = "okay"; +}; + +&vopb { + status = "okay"; +}; + +&vopl { + status = "okay"; +}; diff --git a/arch/arm/mach-rockchip/rk3399/Kconfig b/arch/arm/mach-rockchip/rk3399/Kconfig index 415466a49bb..8f18e33c76f 100644 --- a/arch/arm/mach-rockchip/rk3399/Kconfig +++ b/arch/arm/mach-rockchip/rk3399/Kconfig @@ -28,6 +28,31 @@ config TARGET_PUMA_RK3399 * HDMI, eDP, MIPI-DSI, MIPI-DSI/CSI and MIPI-CSI * SPI, I2C, I2S, UART, GPIO, ...
+config TARGET_ROCK960_RK3399 + bool "Vamrs Limited Rock960 board family" + help + Support for Rock960 board family by Vamrs Limited. This board + family consists of Rock960 (Consumer Edition) and Ficus + (Enterprise Edition) 96Boards. + + Common features implemented on both boards: + * Rockchip RK3399 SoC (2xCortex A72, 4xCortex A53, ARM Mali T860MP4) + * 16/32GB eMMC, uSD slot + * HDMI/DP/MIPI + * 20-pin low speed and 40-pin high speed expanders, 6 LED, 3 buttons + + Additional features of Rock960: + * 2GiB/4GiB LPDDR3 RAM + * 1x USB 3.0 type A, 1x USB 2.0 type A (host mode only), + 1x USB 3.0 type C OTG + + Additional features of Ficus: + * 2GiB/4GiB DDR3 RAM + * Ethernet + * Dual SATA + * 2x USB 3.0 type A, 2x USB 2.0 type A (host mode only), + 1x USB 3.0 type C OTG + endchoice
config SYS_SOC @@ -38,5 +63,6 @@ config SYS_MALLOC_F_LEN
source "board/rockchip/evb_rk3399/Kconfig" source "board/theobroma-systems/puma_rk3399/Kconfig" +source "board/vamrs/rock960_rk3399/Kconfig"
endif diff --git a/board/vamrs/rock960_rk3399/Kconfig b/board/vamrs/rock960_rk3399/Kconfig new file mode 100644 index 00000000000..cacc53f3780 --- /dev/null +++ b/board/vamrs/rock960_rk3399/Kconfig @@ -0,0 +1,15 @@ +if TARGET_ROCK960_RK3399 + +config SYS_BOARD + default "rock960_rk3399" + +config SYS_VENDOR + default "vamrs" + +config SYS_CONFIG_NAME + default "rock960_rk3399" + +config BOARD_SPECIFIC_OPTIONS # dummy + def_bool y + +endif diff --git a/board/vamrs/rock960_rk3399/MAINTAINERS b/board/vamrs/rock960_rk3399/MAINTAINERS new file mode 100644 index 00000000000..9f3fe75f4fb --- /dev/null +++ b/board/vamrs/rock960_rk3399/MAINTAINERS @@ -0,0 +1,6 @@ +ROCK960-RK3399 +M: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org +S: Maintained +F: board/rockchip/rock960_rk3399 +F: include/configs/rock960_rk3399.h +F: configs/rock960-rk3399_defconfig diff --git a/board/vamrs/rock960_rk3399/Makefile b/board/vamrs/rock960_rk3399/Makefile new file mode 100644 index 00000000000..6c3e475b3a8 --- /dev/null +++ b/board/vamrs/rock960_rk3399/Makefile @@ -0,0 +1,6 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2018 Manivannan Sadhasivam manivannan.sadhasivam@linaro.org +# + +obj-y += rock960-rk3399.o diff --git a/board/vamrs/rock960_rk3399/README b/board/vamrs/rock960_rk3399/README new file mode 100644 index 00000000000..f3389520b08 --- /dev/null +++ b/board/vamrs/rock960_rk3399/README @@ -0,0 +1,151 @@ +Contents +======== + +1. Introduction +2. Get the Source and prebuild binary +3. Compile the U-Boot +4. Compile the rkdeveloptool +5. Package the image + 5.1. Package the image for U-Boot SPL(option 1) + 5.2. Package the image for Rockchip miniloader(option 2) +6. Bootloader storage options +7. Flash the image to eMMC + 7.1. Flash the image with U-Boot SPL(option 1) + 7.2. Flash the image with Rockchip miniloader(option 2) +8. Create a bootable SD/MMC +9. And that is it + +Introduction +============ + +Rock960 board family consists of Rock960 (Consumer Edition) and +Ficus (Enterprise Edition) 96Boards featuring Rockchip RK3399 SoC. + +Common features implemented on both boards: + * CPU: ARMv8 64bit Big-Little architecture, + * Big: dual-core Cortex-A72 + * Little: quad-core Cortex-A53 + * IRAM: 200KB + * eMMC: 16/32GB eMMC 5.1 + * PMU: RK808 + * SD/MMC + * Display: HDMI/DP/MIPI + * Low Speed Expansion Connector + * High Speed Expansion Connector + +Additional features of Rock960: + * DRAM: 2GB/4GB LPDDR3 @ 1866MHz + * 1x USB 3.0 type A, 1x USB 2.0 type A (host mode only), + 1x USB 3.0 type C OTG + +Additional features of Ficus: + * DRAM: 2GB/4GB DDR3 @ 1600MHz + * Ethernet + * 2x USB 3.0 type A, 2x USB 2.0 type A (host mode only), + 1x USB 3.0 type C OTG + +Here is the step-by-step to boot to U-Boot on Rock960 boards. + +Get the Source and prebuild binary +================================== + + > git clone https://github.com/96rocks/rkbin.git + > git clone https://github.com/rockchip-linux/rkdeveloptool.git + +Compile the U-Boot +================== + + > cd ../u-boot + > export ARCH=arm64 + > export CROSS_COMPILE=aarch64-linux-gnu- + > make rock960-rk3399_defconfig + > make + > make u-boot.itb + +Compile the rkdeveloptool +========================= + +Follow instructions in latest README + > cd ../rkdeveloptool + > autoreconf -i + > ./configure + > make + > sudo make install + +Package the image +================= + +Package the image for U-Boot SPL(option 1) +-------------------------------- + > cd .. + > tools/mkimage -n rk3399 -T rksd -d spl/u-boot-spl.bin idbspl.img + + Get idbspl.img in this step. + +Package the image for Rockchip miniloader(option 2) +------------------------------------------ + > cd ../rkbin + > ./tools/loaderimage --pack --uboot u-boot/u-boot-dtb.bin uboot.img 0x200000 + + > ../u-boot/tools/mkimage -n rk3399 -T rksd -d rk3399_ddr_933MHz_v1.08.bin idbloader.img + > cat ./rk33/rk3399_miniloader_v1.06.bin >> idbloader.img + + Get uboot.img and idbloader.img in this step. + +Bootloader storage options +========================== + +There are a few different storage options for the bootloader. +This document explores two of these: eMMC and removable SD/MMC. + +Flash the image to eMMC +======================= + +Flash the image with U-Boot SPL(option 1) +------------------------------- +Power on(or reset with RESET KEY) with MASKROM KEY preesed, and then: + > rkdeveloptool db rkbin/rk33/rk3399_loader_v1.08.106.bin + > rkdeveloptool wl 64 u-boot/idbspl.img + > rkdeveloptool wl 0x4000 u-boot/u-boot.itb + > rkdeveloptool rd + +Flash the image with Rockchip miniloader(option 2) +---------------------------------------- +Power on(or reset with RESET KEY) with MASKROM KEY preesed, and then: + > rkdeveloptool db rkbin/rk33/rk3399_loader_v1.08.106.bin + > rkdeveloptool wl 0x40 idbloader.img + > rkdeveloptool wl 0x4000 uboot.img + > rkdeveloptool wl 0x6000 ./img/rk3399/trust.img + > rkdeveloptool rd + +Create a bootable SD/MMC +======================== + +The idbspl.img contains the first stage, and the u-boot.img the second stage. +As explained in the Rockchip partition table reference [1], the first stage +(aka loader1) start sector is 64, and the second stage start sector is 16384. + +Each sector is 512 bytes, which means the first stage offset is 32 KiB, +and the second stage offset is 8 MiB. + +Note: the second stage location is actually not as per the spec, +but defined by the SPL. Mainline SPL defines an 8 MiB offset for the second +stage. + +Assuming the SD card is exposed by device /dev/mmcblk0, the commands +to write the two stages are: + + > dd if=idbspl.img of=/dev/mmcblk0 bs=1k seek=32 + > dd if=u-boot.itb of=/dev/mmcblk0 bs=1k seek=8192 + +Setting up the kernel and rootfs is beyond the scope of this document. + +And that is it +============== + +You should be able to get U-Boot log in console/UART2(baurdrate 1500000) + +For more detail, please reference [2]. + +[1] http://opensource.rock-chips.com/wiki_Partitions +[2] http://opensource.rock-chips.com/wiki_Boot_option diff --git a/board/vamrs/rock960_rk3399/rock960-rk3399.c b/board/vamrs/rock960_rk3399/rock960-rk3399.c new file mode 100644 index 00000000000..d3775b22191 --- /dev/null +++ b/board/vamrs/rock960_rk3399/rock960-rk3399.c @@ -0,0 +1,50 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 Manivannan Sadhasivam manivannan.sadhasivam@linaro.org + */ + +#include <common.h> +#include <dm.h> +#include <dm/pinctrl.h> +#include <dm/uclass-internal.h> +#include <asm/arch/periph.h> +#include <power/regulator.h> +#include <spl.h> + +int board_init(void) +{ + int ret; + + ret = regulators_enable_boot_on(false); + if (ret) + debug("%s: Cannot enable boot on regulator\n", __func__); + + return 0; +} + +void spl_board_init(void) +{ + struct udevice *pinctrl; + int ret; + + ret = uclass_get_device(UCLASS_PINCTRL, 0, &pinctrl); + if (ret) { + debug("%s: Cannot find pinctrl device\n", __func__); + goto err; + } + + /* Enable debug UART */ + ret = pinctrl_request_noflags(pinctrl, PERIPH_ID_UART_DBG); + if (ret) { + debug("%s: Failed to set up console UART\n", __func__); + goto err; + } + + preloader_console_init(); + return; +err: + printf("%s: Error %d\n", __func__, ret); + + /* No way to report error here */ + hang(); +} diff --git a/include/configs/rock960_rk3399.h b/include/configs/rock960_rk3399.h new file mode 100644 index 00000000000..746d24cbff5 --- /dev/null +++ b/include/configs/rock960_rk3399.h @@ -0,0 +1,15 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2018 Manivannan Sadhasivam manivannan.sadhasivam@linaro.org + */ + +#ifndef __ROCK960_RK3399_H +#define __ROCK960_RK3399_H + +#include <configs/rk3399_common.h> + +#define CONFIG_SYS_MMC_ENV_DEV 1 + +#define SDRAM_BANK_SIZE (2UL << 30) + +#endif
Add board support for Rock960 CE board from Vamrs. This board utilizes common Rock960 family support.
Following peripherals are tested and known to work: * USB 2.0 * MMC
This commit also adds DDR configuration for LPDDR3-2GiB-1866MHz.
Signed-off-by: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org --- arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3399-rock960.dts | 45 + .../arm/dts/rk3399-sdram-lpddr3-2GB-1600.dtsi | 1536 +++++++++++++++++ configs/rock960-rk3399_defconfig | 62 + 4 files changed, 1644 insertions(+) create mode 100644 arch/arm/dts/rk3399-rock960.dts create mode 100644 arch/arm/dts/rk3399-sdram-lpddr3-2GB-1600.dtsi create mode 100644 configs/rock960-rk3399_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index ebfa2272627..9b891826b73 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -51,6 +51,7 @@ dtb-$(CONFIG_ARCH_ROCKCHIP) += \ rk3399-puma-ddr1333.dtb \ rk3399-puma-ddr1600.dtb \ rk3399-puma-ddr1866.dtb \ + rk3399-rock960.dtb \ rv1108-evb.dtb dtb-$(CONFIG_ARCH_MESON) += \ meson-gxbb-nanopi-k2.dtb \ diff --git a/arch/arm/dts/rk3399-rock960.dts b/arch/arm/dts/rk3399-rock960.dts new file mode 100644 index 00000000000..25c58b42611 --- /dev/null +++ b/arch/arm/dts/rk3399-rock960.dts @@ -0,0 +1,45 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 Manivannan Sadhasivam manivannan.sadhasivam@linaro.org + */ + +/dts-v1/; +#include "rk3399-rock960.dtsi" +#include "rk3399-sdram-lpddr3-2GB-1600.dtsi" + +/ { + model = "96boards Rock960"; + compatible = "vamrs,rock960", "rockchip,rk3399"; + + chosen { + stdout-path = "serial2:1500000n8"; + }; +}; + +&pcie0 { + ep-gpios = <&gpio2 RK_PA2 GPIO_ACTIVE_HIGH>; +}; + +&pinctrl { + pcie { + pcie_drv: pcie-drv { + rockchip,pins = + <2 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + usb2 { + host_vbus_drv: host-vbus-drv { + rockchip,pins = + <4 RK_PD1 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; + +&vcc3v3_pcie { + gpio = <&gpio2 5 GPIO_ACTIVE_HIGH>; +}; + +&vcc5v0_host { + gpio = <&gpio4 25 GPIO_ACTIVE_HIGH>; +}; diff --git a/arch/arm/dts/rk3399-sdram-lpddr3-2GB-1600.dtsi b/arch/arm/dts/rk3399-sdram-lpddr3-2GB-1600.dtsi new file mode 100644 index 00000000000..d14e833d228 --- /dev/null +++ b/arch/arm/dts/rk3399-sdram-lpddr3-2GB-1600.dtsi @@ -0,0 +1,1536 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2016 Rockchip Electronics Co., Ltd + * (C) Copyright 2018 Manivannan Sadhasivam manivannan.sadhasivam@linaro.org + */ + +&dmc { + rockchip,sdram-params = < + 0x1 + 0xa + 0x3 + 0x2 + 0x2 + 0x0 + 0xf + 0xf + 1 + 0x1d191519 + 0x14040808 + 0x00000002 + 0x00006226 + 0x00000054 + 0x00000000 + 0x1 + 0xa + 0x3 + 0x2 + 0x2 + 0x0 + 0xf + 0xf + 1 + 0x1d191519 + 0x14040808 + 0x00000002 + 0x00006226 + 0x00000054 + 0x00000000 + 800 + 6 + 2 + 9 + 1 + 0x00000700 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000050 + 0x00027100 + 0x00000320 + 0x00001f40 + 0x00000050 + 0x00027100 + 0x00000320 + 0x00001f40 + 0x00000050 + 0x00027100 + 0x00000320 + 0x01001f40 + 0x00000000 + 0x00000101 + 0x00020100 + 0x000000a0 + 0x00000190 + 0x00000000 + 0x06180000 + 0x00061800 + 0x04000618 + 0x33080004 + 0x280f0622 + 0x22330800 + 0x00280f06 + 0x06223308 + 0x0600280f + 0x00000a0a + 0x0600dac0 + 0x0a0a060c + 0x0600dac0 + 0x0a0a060c + 0x0600dac0 + 0x0203000c + 0x0f0c0f00 + 0x040c0f0c + 0x14000a0a + 0x03030a0a + 0x00010003 + 0x031b1b1b + 0x00111111 + 0x00000000 + 0x03010000 + 0x0c2800a8 + 0x0c2800a8 + 0x0c2800a8 + 0x00000000 + 0x00060006 + 0x00140006 + 0x00140014 + 0x000f0f0f + 0x00000000 + 0x00000000 + 0x00000000 + 0x00b00000 + 0x00b000b0 + 0x00b000b0 + 0x000000b0 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000301 + 0x00000001 + 0x00000000 + 0x00000000 + 0x01000000 + 0x80104002 + 0x00040003 + 0x00040005 + 0x00030000 + 0x00050004 + 0x00000004 + 0x00040003 + 0x00040005 + 0x30a00000 + 0x00001850 + 0x185030a0 + 0x30a00000 + 0x00001850 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x02020200 + 0x00020202 + 0x00030200 + 0x00040700 + 0x00000302 + 0x02000407 + 0x00000003 + 0x00030f04 + 0x00070004 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00010000 + 0x20040020 + 0x00200400 + 0x01000400 + 0x00000b80 + 0x00000000 + 0x00000001 + 0x00000002 + 0x0000000e + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00a00000 + 0x00c80050 + 0x00c80000 + 0x005000a0 + 0x000000c8 + 0x00a000c8 + 0x00c80050 + 0x00c80000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00430000 + 0x0000001a + 0x001a0043 + 0x00430000 + 0x0000001a + 0x00010001 + 0x07000001 + 0x00000707 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00430000 + 0x0000001a + 0x001a0043 + 0x00430000 + 0x0000001a + 0x00010001 + 0x07000001 + 0x00000707 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x01000000 + 0x00000000 + 0x00000000 + 0x18151100 + 0x0000000c + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00032003 + 0x00480120 + 0x00000000 + 0x01200320 + 0x00000048 + 0x00032000 + 0x00480120 + 0x00000000 + 0x00280000 + 0x00280028 + 0x01010100 + 0x01000202 + 0x0a000002 + 0x01000f0f + 0x00000000 + 0x00000000 + 0x00010003 + 0x00000c03 + 0x00000100 + 0x00010000 + 0x01000000 + 0x00010000 + 0x00000001 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00010000 + 0x03030301 + 0x01010808 + 0x03030001 + 0x0a0a0a03 + 0x02080808 + 0x02050103 + 0x02050103 + 0x00050103 + 0x00020202 + 0x05020500 + 0x00020502 + 0x00000000 + 0x00000000 + 0x0d000001 + 0x00010028 + 0x00010000 + 0x00000003 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00010100 + 0x01000000 + 0x00000001 + 0x00000303 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x000556aa + 0x000aaaaa + 0x000aa955 + 0x00055555 + 0x000b3133 + 0x0004cd33 + 0x0004cecc + 0x000b32cc + 0x00010300 + 0x03000100 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00ffff00 + 0x1e1e0000 + 0x0800001e + 0x00001850 + 0x00000200 + 0x00000200 + 0x00000200 + 0x00000200 + 0x00001850 + 0x0000f320 + 0x1850050a + 0x00000200 + 0x00000200 + 0x00000200 + 0x00000200 + 0x00001850 + 0x0000f320 + 0x1850050a + 0x00000200 + 0x00000200 + 0x00000200 + 0x00000200 + 0x00001850 + 0x0000f320 + 0x0202050a + 0x03030202 + 0x00000018 + 0x00000000 + 0x00000000 + 0x00001403 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00030000 + 0x000e0020 + 0x000e0020 + 0x000e0020 + 0x00000000 + 0x00000000 + 0x01000000 + 0x00070007 + 0x00050007 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x01000101 + 0x01010101 + 0x01000101 + 0x01000100 + 0x00010001 + 0x00010002 + 0x00020100 + 0x00000002 + 0x00000700 + 0x00000000 + 0x000030a0 + 0x00001850 + 0x000030a0 + 0x00001850 + 0x000030a0 + 0x18501850 + 0x00000200 + 0x00000200 + 0x00000200 + 0x00000200 + 0x00001850 + 0x00000200 + 0x00000200 + 0x00000200 + 0x00000200 + 0x00001850 + 0x00000200 + 0x00000200 + 0x00000200 + 0x00000200 + 0x00010000 + 0x00000007 + 0x81000001 + 0x0f0003f0 + 0x3fffffff + 0x0f0000a0 + 0x377ff000 + 0x0f000020 + 0x377ff000 + 0x0f000030 + 0x377ff000 + 0x0f0000b0 + 0x377ff000 + 0x0f000100 + 0x377ff000 + 0x0f000110 + 0x377ff000 + 0x0f000010 + 0x377ff000 + 0x03000101 + 0x042e2e2e + 0x06180006 + 0x00061800 + 0x00000018 + 0x0c2800a8 + 0x0c2800a8 + 0x0c2800a8 + 0x00000500 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x04040000 + 0x0d000004 + 0x00000128 + 0x00000000 + 0x00030003 + 0x00000018 + 0x00000000 + 0x00000000 + 0x03060002 + 0x03010301 + 0x01080801 + 0x04020201 + 0x01080804 + 0x00000000 + 0x03030000 + 0x0a0a0a03 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00030300 + 0x00000014 + 0x00000000 + 0x01010300 + 0x00000000 + 0x00000000 + 0x01000000 + 0x00000101 + 0x55555a5a + 0x55555a5a + 0x55555a5a + 0x55555a5a + 0x0a0a0001 + 0x0505000a + 0x00000005 + 0x00000100 + 0x00030000 + 0x17030000 + 0x000e0020 + 0x000e0020 + 0x000e0020 + 0x00000000 + 0x00000000 + 0x00000100 + 0x140a0000 + 0x000a030a + 0x03000a03 + 0x010a000a + 0x00000100 + 0x01000000 + 0x00000000 + 0x00000100 + 0x1e1a0000 + 0x10010204 + 0x07070705 + 0x20000202 + 0x00201000 + 0x00201000 + 0x04041000 + 0x10100100 + 0x00010110 + 0x004b004a + 0x1a030000 + 0x0102041e + 0x34000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00004300 + 0x0001001a + 0x004d4d07 + 0x001a0043 + 0x4d070001 + 0x0000434d + 0x0001001a + 0x004d4d07 + 0x001a0043 + 0x4d070001 + 0x0000434d + 0x0001001a + 0x004d4d07 + 0x001a0043 + 0x4d070001 + 0x0043004d + 0x0001001a + 0x004d4d07 + 0x001a0043 + 0x4d070001 + 0x0000434d + 0x0001001a + 0x004d4d07 + 0x001a0043 + 0x4d070001 + 0x0000434d + 0x0001001a + 0x004d4d07 + 0x001a0043 + 0x4d070001 + 0x0100004d + 0x00c800c8 + 0x060400c8 + 0x0c060f11 + 0x2200d890 + 0x0a0c2005 + 0x0f11060a + 0x00000c06 + 0x2200d890 + 0x0a0c2005 + 0x0f11060a + 0x00000c06 + 0x2200d890 + 0x0a0c2005 + 0x0200020a + 0x02000200 + 0x02000200 + 0x02000200 + 0x02000200 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x01000300 + 0x00185000 + 0x0000f320 + 0x00001850 + 0x0000f320 + 0x00001850 + 0x0000f320 + 0x08000000 + 0x00000100 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000002 + 0x76543210 + 0x0004c008 + 0x000000b3 + 0x00000000 + 0x00000000 + 0x00010000 + 0x01665555 + 0x00665555 + 0x00010f00 + 0x05010200 + 0x00000003 + 0x001700c0 + 0x00cc0101 + 0x00030066 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x04080000 + 0x04080400 + 0x08000000 + 0x0c00c007 + 0x00000100 + 0x00000100 + 0x55555555 + 0xaaaaaaaa + 0x55555555 + 0xaaaaaaaa + 0x00005555 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00200000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x02700270 + 0x02700270 + 0x02700270 + 0x02700270 + 0x00000270 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00800000 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00b30080 + 0x00000003 + 0x00000000 + 0x00020000 + 0x00000200 + 0x00000000 + 0x51315152 + 0xc0013150 + 0x020000c0 + 0x00100001 + 0x07054208 + 0x000f0c18 + 0x01000140 + 0x00000c20 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x76543210 + 0x0004c008 + 0x000000b3 + 0x00000000 + 0x00000000 + 0x00010000 + 0x01665555 + 0x00665555 + 0x00010f00 + 0x05010200 + 0x00000003 + 0x001700c0 + 0x00cc0101 + 0x00030066 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x04080000 + 0x04080400 + 0x08000000 + 0x0c00c007 + 0x00000100 + 0x00000100 + 0x55555555 + 0xaaaaaaaa + 0x55555555 + 0xaaaaaaaa + 0x00005555 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00200000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x02700270 + 0x02700270 + 0x02700270 + 0x02700270 + 0x00000270 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00800000 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00b30080 + 0x00000003 + 0x00000000 + 0x00020000 + 0x00000200 + 0x00000000 + 0x51315152 + 0xc0013150 + 0x020000c0 + 0x00100001 + 0x07054208 + 0x000f0c18 + 0x01000140 + 0x00000c20 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x76543210 + 0x0004c008 + 0x000000b3 + 0x00000000 + 0x00000000 + 0x00010000 + 0x01665555 + 0x00665555 + 0x00010f00 + 0x05010200 + 0x00000003 + 0x001700c0 + 0x00cc0101 + 0x00030066 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x04080000 + 0x04080400 + 0x08000000 + 0x0c00c007 + 0x00000100 + 0x00000100 + 0x55555555 + 0xaaaaaaaa + 0x55555555 + 0xaaaaaaaa + 0x00005555 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00200000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x02700270 + 0x02700270 + 0x02700270 + 0x02700270 + 0x00000270 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00800000 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00b30080 + 0x00000003 + 0x00000000 + 0x00020000 + 0x00000200 + 0x00000000 + 0x51315152 + 0xc0013150 + 0x020000c0 + 0x00100001 + 0x07054208 + 0x000f0c18 + 0x01000140 + 0x00000c20 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x76543210 + 0x0004c008 + 0x000000b3 + 0x00000000 + 0x00000000 + 0x00010000 + 0x01665555 + 0x00665555 + 0x00010f00 + 0x05010200 + 0x00000003 + 0x001700c0 + 0x00cc0101 + 0x00030066 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x04080000 + 0x04080400 + 0x08000000 + 0x0c00c007 + 0x00000100 + 0x00000100 + 0x55555555 + 0xaaaaaaaa + 0x55555555 + 0xaaaaaaaa + 0x00005555 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00200000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x02700270 + 0x02700270 + 0x02700270 + 0x02700270 + 0x00000270 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00800000 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00b30080 + 0x00000003 + 0x00000000 + 0x00020000 + 0x00000200 + 0x00000000 + 0x51315152 + 0xc0013150 + 0x020000c0 + 0x00100001 + 0x07054208 + 0x000f0c18 + 0x01000140 + 0x00000c20 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00800000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000001 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00400320 + 0x00000040 + 0x00806420 + 0x00917531 + 0x00806420 + 0x01917531 + 0x00020003 + 0x00000000 + 0x00000000 + 0x00000000 + 0x000556aa + 0x000aaaaa + 0x000aa955 + 0x00055555 + 0x000b3133 + 0x0004cd33 + 0x0004cecc + 0x000b32cc + 0x0a418820 + 0x103f0000 + 0x0000003f + 0x00038055 + 0x03800380 + 0x03800380 + 0x00000380 + 0x42080010 + 0x00000003 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00800000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000001 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00400320 + 0x00000040 + 0x00008eca + 0x00009fdb + 0x00008eca + 0x01009fdb + 0x00020003 + 0x00000000 + 0x00000000 + 0x00000000 + 0x000556aa + 0x000aaaaa + 0x000aa955 + 0x00055555 + 0x000b3133 + 0x0004cd33 + 0x0004cecc + 0x000b32cc + 0x0004a0e6 + 0x080f0000 + 0x0000000f + 0x00038055 + 0x03800380 + 0x03800380 + 0x00000380 + 0x42080010 + 0x00000003 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00800000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000001 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00400320 + 0x00000040 + 0x00008eca + 0x00009fdb + 0x00008eca + 0x01009fdb + 0x00020003 + 0x00000000 + 0x00000000 + 0x00000000 + 0x000556aa + 0x000aaaaa + 0x000aa955 + 0x00055555 + 0x000b3133 + 0x0004cd33 + 0x0004cecc + 0x000b32cc + 0x1ee6b16a + 0x10000000 + 0x00000000 + 0x00038055 + 0x03800380 + 0x03800380 + 0x00000380 + 0x42080010 + 0x00000003 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000001 + 0x00000000 + 0x01000005 + 0x04000f00 + 0x00020040 + 0x00020055 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000050 + 0x00000000 + 0x00010100 + 0x00000601 + 0x00000000 + 0x00006400 + 0x01221102 + 0x00000000 + 0x00051f00 + 0x051f051f + 0x051f051f + 0x00030003 + 0x03000300 + 0x00000300 + 0x01221102 + 0x00000000 + 0x00000000 + 0x03020000 + 0x00000001 + 0x00000011 + 0x00000011 + 0x00000400 + 0x00000000 + 0x00000011 + 0x00000011 + 0x00004410 + 0x00004410 + 0x00004410 + 0x00004410 + 0x00004410 + 0x00000011 + 0x00004410 + 0x00000011 + 0x00004410 + 0x00000011 + 0x00004410 + 0x00000000 + 0x00000000 + 0x00000000 + 0x04000000 + 0x00000000 + 0x00000000 + 0x00000508 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0xe4000000 + 0x00000000 + 0x00000000 + 0x01010000 + 0x00000000 + >; +}; diff --git a/configs/rock960-rk3399_defconfig b/configs/rock960-rk3399_defconfig new file mode 100644 index 00000000000..998c7a4b707 --- /dev/null +++ b/configs/rock960-rk3399_defconfig @@ -0,0 +1,62 @@ +CONFIG_ARM=y +CONFIG_ARCH_ROCKCHIP=y +CONFIG_SYS_TEXT_BASE=0x00200000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x4000 +CONFIG_ROCKCHIP_RK3399=y +CONFIG_ROCKCHIP_SPL_RESERVE_IRAM=0x4000 +CONFIG_TARGET_ROCK960_RK3399=y +CONFIG_DEBUG_UART_BASE=0xFF1A0000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_BAUDRATE=1500000 +CONFIG_SPL_STACK_R_ADDR=0x80000 +CONFIG_DEFAULT_DEVICE_TREE="rk3399-rock960" +CONFIG_DEBUG_UART=y +CONFIG_FIT=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-rockchip/make_fit_atf.py" +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-rock960.dtb" +CONFIG_SYS_PROMPT="rock960 => " +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_STACK_R=y +CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x4000 +CONFIG_SPL_ATF=y +CONFIG_SPL_ATF_NO_PLATFORM_PARAM=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GPT=y +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TIME=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_SPL_OF_PLATDATA=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_REGMAP=y +CONFIG_SPL_REGMAP=y +CONFIG_SYSCON=y +CONFIG_SPL_SYSCON=y +CONFIG_CLK=y +CONFIG_SPL_CLK=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MMC_DW=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_ROCKCHIP_RK3399=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_RK8XX=y +CONFIG_REGULATOR_PWM=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_RAM=y +CONFIG_SPL_RAM=y +CONFIG_SYSRESET=y +CONFIG_USE_TINY_PRINTF=y +CONFIG_ERRNO_STR=y
Add board support for Ficus EE board from Vamrs. This board utilizes common Rock960 family support.
Following peripherals are tested and known to work: * Gigabit Ethernet * USB 2.0 * MMC
Signed-off-by: Ezequiel Garcia ezequiel@collabora.com [Reworked based on common Rock960 family support] Signed-off-by: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org --- arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3399-ficus.dts | 78 ++++++++++++++++++++++++++++++++++ configs/ficus-rk3399_defconfig | 71 +++++++++++++++++++++++++++++++ 3 files changed, 150 insertions(+) create mode 100644 arch/arm/dts/rk3399-ficus.dts create mode 100644 configs/ficus-rk3399_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 9b891826b73..e2bd9822aa2 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -42,6 +42,7 @@ dtb-$(CONFIG_ARCH_ROCKCHIP) += \ rk3288-veyron-minnie.dtb \ rk3288-vyasa.dtb \ rk3328-evb.dtb \ + rk3399-ficus.dtb \ rk3368-lion.dtb \ rk3368-sheep.dtb \ rk3368-geekbox.dtb \ diff --git a/arch/arm/dts/rk3399-ficus.dts b/arch/arm/dts/rk3399-ficus.dts new file mode 100644 index 00000000000..de934cd61ab --- /dev/null +++ b/arch/arm/dts/rk3399-ficus.dts @@ -0,0 +1,78 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2018 Collabora Ltd. + * Copyright (c) 2018 Fuzhou Rockchip Electronics Co., Ltd. + * + * Schematics available at https://dl.vamrs.com/products/ficus/docs/hw + */ + +/dts-v1/; +#include "rk3399-rock960.dtsi" +#include "rk3399-sdram-lpddr3-4GB-1600.dtsi" + +/ { + model = "96boards RK3399 Ficus"; + compatible = "vamrs,ficus", "rockchip,rk3399"; + + chosen { + stdout-path = "serial2:1500000n8"; + }; + + clkin_gmac: external-gmac-clock { + compatible = "fixed-clock"; + clock-frequency = <125000000>; + clock-output-names = "clkin_gmac"; + #clock-cells = <0>; + }; +}; + +&gmac { + assigned-clocks = <&cru SCLK_RMII_SRC>; + assigned-clock-parents = <&clkin_gmac>; + clock_in_out = "input"; + phy-supply = <&vcc3v3_sys>; + phy-mode = "rgmii"; + pinctrl-names = "default"; + pinctrl-0 = <&rgmii_pins>; + snps,reset-gpio = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>; + snps,reset-active-low; + snps,reset-delays-us = <0 10000 50000>; + tx_delay = <0x28>; + rx_delay = <0x11>; + status = "okay"; +}; + +&pcie0 { + ep-gpios = <&gpio4 RK_PD4 GPIO_ACTIVE_HIGH>; +}; + +&pinctrl { + gmac { + rgmii_sleep_pins: rgmii-sleep-pins { + rockchip,pins = + <3 15 RK_FUNC_GPIO &pcfg_output_low>; + }; + }; + + pcie { + pcie_drv: pcie-drv { + rockchip,pins = + <1 24 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + usb2 { + host_vbus_drv: host-vbus-drv { + rockchip,pins = + <4 27 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; + +&vcc3v3_pcie { + gpio = <&gpio1 24 GPIO_ACTIVE_HIGH>; +}; + +&vcc5v0_host { + gpio = <&gpio4 27 GPIO_ACTIVE_HIGH>; +}; diff --git a/configs/ficus-rk3399_defconfig b/configs/ficus-rk3399_defconfig new file mode 100644 index 00000000000..e890bc25238 --- /dev/null +++ b/configs/ficus-rk3399_defconfig @@ -0,0 +1,71 @@ +CONFIG_ARM=y +CONFIG_ARCH_ROCKCHIP=y +CONFIG_SYS_TEXT_BASE=0x00200000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x4000 +CONFIG_ROCKCHIP_RK3399=y +CONFIG_TARGET_ROCK960_RK3399=y +CONFIG_ROCKCHIP_SPL_RESERVE_IRAM=0x4000 +CONFIG_DEBUG_UART_BASE=0xFF1A0000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SPL_STACK_R_ADDR=0x80000 +CONFIG_DEFAULT_DEVICE_TREE="rk3399-ficus" +CONFIG_DEBUG_UART=y +CONFIG_FIT=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-rockchip/make_fit_atf.py" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_STACK_R=y +CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x4000 +CONFIG_SPL_ATF=y +CONFIG_SPL_ATF_NO_PLATFORM_PARAM=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GPT=y +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TIME=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_ENV_IS_IN_MMC=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_REGMAP=y +CONFIG_SPL_REGMAP=y +CONFIG_SYSCON=y +CONFIG_SPL_SYSCON=y +CONFIG_CLK=y +CONFIG_SPL_CLK=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_DM_ETH=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_RGMII=y +CONFIG_GMAC_ROCKCHIP=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_ROCKCHIP_RK3399=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_RK8XX=y +CONFIG_REGULATOR_PWM=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_RAM=y +CONFIG_SPL_RAM=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_STORAGE=y +CONFIG_USE_TINY_PRINTF=y +CONFIG_ERRNO_STR=y
