[U-Boot] [PATCH v2] arc: significant cache rework
[1] Align cache management functions to those in Linux kernel. I.e.: a) Use the same functions for all cache ops (D$ Inv/Flush) b) Split cache ops in 3 sub-functions: "before", "lineloop" and "after". That way we may re-use "before" and "after" functions for region and full cache ops.
[2] Implement full-functional L2 (SLC) management. Before SLC was simply disabled early on boot. If SLC exists corresponding ops are run on cache flush/invalidate.
[3] Disable/enable corresponding caches early on boot. So if U-Boot is configured to use caches they will be used at all times (this is useful in particular for speed-up of relocation).
Signed-off-by: Alexey Brodkin abrodkin@synopsys.com --- Compared to v1: * Remove explicit selection of L2CACHE on/off in Kconfig, check this in runtime and use L2 ops only when L2 is detected. This allows run the same executable on HW with and without L2 cache. --- arch/arc/include/asm/arcregs.h | 5 +- arch/arc/include/asm/cache.h | 7 +- arch/arc/lib/cache.c | 375 ++++++++++++++++++++++++++++------------- arch/arc/lib/cpu.c | 2 + arch/arc/lib/init_helpers.c | 10 +- arch/arc/lib/start.S | 46 ++++- 6 files changed, 300 insertions(+), 145 deletions(-)
diff --git a/arch/arc/include/asm/arcregs.h b/arch/arc/include/asm/arcregs.h index 0e11dcc..667f218 100644 --- a/arch/arc/include/asm/arcregs.h +++ b/arch/arc/include/asm/arcregs.h @@ -47,9 +47,12 @@ #endif #define ARC_BCR_DC_BUILD 0x72 #define ARC_BCR_SLC 0xce -#define ARC_AUX_SLC_CONTROL 0x903 +#define ARC_AUX_SLC_CONFIG 0x901 +#define ARC_AUX_SLC_CTRL 0x903 #define ARC_AUX_SLC_FLUSH 0x904 #define ARC_AUX_SLC_INVALIDATE 0x905 +#define ARC_AUX_SLC_IVDL 0x910 +#define ARC_AUX_SLC_FLDL 0x912
#ifndef __ASSEMBLY__ /* Accessors for auxiliary registers */ diff --git a/arch/arc/include/asm/cache.h b/arch/arc/include/asm/cache.h index 0b3ebd9..432606a 100644 --- a/arch/arc/include/asm/cache.h +++ b/arch/arc/include/asm/cache.h @@ -29,12 +29,7 @@
-#ifdef CONFIG_ISA_ARCV2 -void slc_enable(void); -void slc_disable(void); -void slc_flush(void); -void slc_invalidate(void); -#endif +void cache_init(void);
#endif /* __ASSEMBLY__ */
diff --git a/arch/arc/lib/cache.c b/arch/arc/lib/cache.c index e369e5a..ed8e8e7 100644 --- a/arch/arc/lib/cache.c +++ b/arch/arc/lib/cache.c @@ -5,9 +5,13 @@ */
#include <config.h> +#include <linux/compiler.h> +#include <linux/kernel.h> #include <asm/arcregs.h> #include <asm/cache.h>
+#define CACHE_LINE_MASK (~(CONFIG_SYS_CACHELINE_SIZE - 1)) + /* Bit values in IC_CTRL */ #define IC_CTRL_CACHE_DISABLE (1 << 0)
@@ -18,60 +22,186 @@ #define CACHE_VER_NUM_MASK 0xF #define SLC_CTRL_SB (1 << 2)
+#define OP_INV 0x1 +#define OP_FLUSH 0x2 +#define OP_INV_IC 0x3 + +#ifdef CONFIG_ISA_ARCV2 +/* + * By default that variable will fall into .bss section. + * But .bss section is not relocated and so it will be initilized before + * relocation but will be used after being zeroed. + */ +int slc_line_sz __section(".data"); +int slc_exists __section(".data"); + +static unsigned int __before_slc_op(const int op) +{ + unsigned int reg = reg; + + if (op == OP_INV) { + /* + * IM is set by default and implies Flush-n-inv + * Clear it here for vanilla inv + */ + reg = read_aux_reg(ARC_AUX_SLC_CTRL); + write_aux_reg(ARC_AUX_SLC_CTRL, reg & ~DC_CTRL_INV_MODE_FLUSH); + } + + return reg; +} + +static void __after_slc_op(const int op, unsigned int reg) +{ + if (op & OP_FLUSH) /* flush / flush-n-inv both wait */ + while (read_aux_reg(ARC_AUX_SLC_CTRL) & + DC_CTRL_FLUSH_STATUS) + ; + + /* Switch back to default Invalidate mode */ + if (op == OP_INV) + write_aux_reg(ARC_AUX_SLC_CTRL, reg | DC_CTRL_INV_MODE_FLUSH); +} + +static inline void __slc_line_loop(unsigned long paddr, unsigned long sz, + const int op) +{ + unsigned int aux_cmd; + int num_lines; + +#define SLC_LINE_MASK (~(slc_line_sz - 1)) + + aux_cmd = op & OP_INV ? ARC_AUX_SLC_IVDL : ARC_AUX_SLC_FLDL; + + sz += paddr & ~SLC_LINE_MASK; + paddr &= SLC_LINE_MASK; + + num_lines = DIV_ROUND_UP(sz, slc_line_sz); + + while (num_lines-- > 0) { + write_aux_reg(aux_cmd, paddr); + paddr += slc_line_sz; + } +} + +static inline void __slc_entire_op(const int cacheop) +{ + int aux; + unsigned int ctrl_reg = __before_slc_op(cacheop); + + if (cacheop & OP_INV) /* Inv or flush-n-inv use same cmd reg */ + aux = ARC_AUX_SLC_INVALIDATE; + else + aux = ARC_AUX_SLC_FLUSH; + + write_aux_reg(aux, 0x1); + + __after_slc_op(cacheop, ctrl_reg); +} + +static inline void __slc_line_op(unsigned long paddr, unsigned long sz, + const int cacheop) +{ + unsigned int ctrl_reg = __before_slc_op(cacheop); + __slc_line_loop(paddr, sz, cacheop); + __after_slc_op(cacheop, ctrl_reg); +} +#else +#define __slc_entire_op(cacheop) +#define __slc_line_op(paddr, sz, cacheop) +#endif + +static inline int icache_exists(void) +{ + /* Check if Instruction Cache is available */ + if (read_aux_reg(ARC_BCR_IC_BUILD) & CACHE_VER_NUM_MASK) + return 1; + else + return 0; +} + +static inline int dcache_exists(void) +{ + /* Check if Data Cache is available */ + if (read_aux_reg(ARC_BCR_DC_BUILD) & CACHE_VER_NUM_MASK) + return 1; + else + return 0; +} + +void cache_init(void) +{ +#ifdef CONFIG_ISA_ARCV2 + /* Check if System-Level Cache (SLC) is available */ + if (read_aux_reg(ARC_BCR_SLC) & CACHE_VER_NUM_MASK) { +#define LSIZE_OFFSET 4 +#define LSIZE_MASK 3 + if (read_aux_reg(ARC_AUX_SLC_CONFIG) & + (LSIZE_MASK << LSIZE_OFFSET)) + slc_line_sz = 64; + else + slc_line_sz = 128; + slc_exists = 1; + } else { + slc_exists = 0; + } +#endif +} + int icache_status(void) { - /* If no cache in CPU exit immediately */ - if (!(read_aux_reg(ARC_BCR_IC_BUILD) & CACHE_VER_NUM_MASK)) + if (!icache_exists()) return 0;
- return (read_aux_reg(ARC_AUX_IC_CTRL) & IC_CTRL_CACHE_DISABLE) != - IC_CTRL_CACHE_DISABLE; + if (read_aux_reg(ARC_AUX_IC_CTRL) & IC_CTRL_CACHE_DISABLE) + return 0; + else + return 1; }
void icache_enable(void) { - /* If no cache in CPU exit immediately */ - if (!(read_aux_reg(ARC_BCR_IC_BUILD) & CACHE_VER_NUM_MASK)) - return; - - write_aux_reg(ARC_AUX_IC_CTRL, read_aux_reg(ARC_AUX_IC_CTRL) & - ~IC_CTRL_CACHE_DISABLE); + if (icache_exists()) + write_aux_reg(ARC_AUX_IC_CTRL, read_aux_reg(ARC_AUX_IC_CTRL) & + ~IC_CTRL_CACHE_DISABLE); }
void icache_disable(void) { - /* If no cache in CPU exit immediately */ - if (!(read_aux_reg(ARC_BCR_IC_BUILD) & CACHE_VER_NUM_MASK)) - return; - - write_aux_reg(ARC_AUX_IC_CTRL, read_aux_reg(ARC_AUX_IC_CTRL) | - IC_CTRL_CACHE_DISABLE); + if (icache_exists()) + write_aux_reg(ARC_AUX_IC_CTRL, read_aux_reg(ARC_AUX_IC_CTRL) | + IC_CTRL_CACHE_DISABLE); }
+#ifndef CONFIG_SYS_DCACHE_OFF void invalidate_icache_all(void) { - /* If no cache in CPU exit immediately */ - if (!(read_aux_reg(ARC_BCR_IC_BUILD) & CACHE_VER_NUM_MASK)) - return; - /* Any write to IC_IVIC register triggers invalidation of entire I$ */ - write_aux_reg(ARC_AUX_IC_IVIC, 1); + if (icache_status()) { + write_aux_reg(ARC_AUX_IC_IVIC, 1); + read_aux_reg(ARC_AUX_IC_CTRL); /* blocks */ + } } +#else +void invalidate_icache_all(void) +{ +} +#endif
int dcache_status(void) { - /* If no cache in CPU exit immediately */ - if (!(read_aux_reg(ARC_BCR_DC_BUILD) & CACHE_VER_NUM_MASK)) + if (!dcache_exists()) return 0;
- return (read_aux_reg(ARC_AUX_DC_CTRL) & DC_CTRL_CACHE_DISABLE) != - DC_CTRL_CACHE_DISABLE; + if (read_aux_reg(ARC_AUX_DC_CTRL) & DC_CTRL_CACHE_DISABLE) + return 0; + else + return 1; }
void dcache_enable(void) { - /* If no cache in CPU exit immediately */ - if (!(read_aux_reg(ARC_BCR_DC_BUILD) & CACHE_VER_NUM_MASK)) + if (!dcache_exists()) return;
write_aux_reg(ARC_AUX_DC_CTRL, read_aux_reg(ARC_AUX_DC_CTRL) & @@ -80,139 +210,144 @@ void dcache_enable(void)
void dcache_disable(void) { - /* If no cache in CPU exit immediately */ - if (!(read_aux_reg(ARC_BCR_DC_BUILD) & CACHE_VER_NUM_MASK)) + if (!dcache_exists()) return;
write_aux_reg(ARC_AUX_DC_CTRL, read_aux_reg(ARC_AUX_DC_CTRL) | DC_CTRL_CACHE_DISABLE); }
-void flush_dcache_all(void) -{ - /* If no cache in CPU exit immediately */ - if (!(read_aux_reg(ARC_BCR_DC_BUILD) & CACHE_VER_NUM_MASK)) - return; - - /* Do flush of entire cache */ - write_aux_reg(ARC_AUX_DC_FLSH, 1); - - /* Wait flush end */ - while (read_aux_reg(ARC_AUX_DC_CTRL) & DC_CTRL_FLUSH_STATUS) - ; -} - #ifndef CONFIG_SYS_DCACHE_OFF -static void dcache_flush_line(unsigned addr) +/* + * Common Helper for Line Operations on {I,D}-Cache + */ +static inline void __cache_line_loop(unsigned long paddr, unsigned long sz, + const int cacheop) { + unsigned int aux_cmd; #if (CONFIG_ARC_MMU_VER == 3) - write_aux_reg(ARC_AUX_DC_PTAG, addr); + unsigned int aux_tag; #endif - write_aux_reg(ARC_AUX_DC_FLDL, addr); + int num_lines;
- /* Wait flush end */ - while (read_aux_reg(ARC_AUX_DC_CTRL) & DC_CTRL_FLUSH_STATUS) - ; - -#ifndef CONFIG_SYS_ICACHE_OFF - /* - * Invalidate I$ for addresses range just flushed from D$. - * If we try to execute data flushed above it will be valid/correct - */ + if (cacheop == OP_INV_IC) { + aux_cmd = ARC_AUX_IC_IVIL; #if (CONFIG_ARC_MMU_VER == 3) - write_aux_reg(ARC_AUX_IC_PTAG, addr); + aux_tag = ARC_AUX_IC_PTAG; #endif - write_aux_reg(ARC_AUX_IC_IVIL, addr); -#endif /* CONFIG_SYS_ICACHE_OFF */ -} -#endif /* CONFIG_SYS_DCACHE_OFF */ - -void flush_dcache_range(unsigned long start, unsigned long end) -{ -#ifndef CONFIG_SYS_DCACHE_OFF - unsigned int addr; + } else { + /* d$ cmd: INV (discard or wback-n-discard) OR FLUSH (wback) */ + aux_cmd = cacheop & OP_INV ? ARC_AUX_DC_IVDL : ARC_AUX_DC_FLDL; +#if (CONFIG_ARC_MMU_VER == 3) + aux_tag = ARC_AUX_DC_PTAG; +#endif + }
- start = start & (~(CONFIG_SYS_CACHELINE_SIZE - 1)); - end = end & (~(CONFIG_SYS_CACHELINE_SIZE - 1)); + sz += paddr & ~CACHE_LINE_MASK; + paddr &= CACHE_LINE_MASK;
- for (addr = start; addr <= end; addr += CONFIG_SYS_CACHELINE_SIZE) - dcache_flush_line(addr); -#endif /* CONFIG_SYS_DCACHE_OFF */ -} + num_lines = DIV_ROUND_UP(sz, CONFIG_SYS_CACHELINE_SIZE);
-void invalidate_dcache_range(unsigned long start, unsigned long end) -{ -#ifndef CONFIG_SYS_DCACHE_OFF - unsigned int addr; - - start = start & (~(CONFIG_SYS_CACHELINE_SIZE - 1)); - end = end & (~(CONFIG_SYS_CACHELINE_SIZE - 1)); - - for (addr = start; addr <= end; addr += CONFIG_SYS_CACHELINE_SIZE) { + while (num_lines-- > 0) { #if (CONFIG_ARC_MMU_VER == 3) - write_aux_reg(ARC_AUX_DC_PTAG, addr); + write_aux_reg(aux_tag, paddr); #endif - write_aux_reg(ARC_AUX_DC_IVDL, addr); + write_aux_reg(aux_cmd, paddr); + paddr += CONFIG_SYS_CACHELINE_SIZE; } -#endif /* CONFIG_SYS_DCACHE_OFF */ }
-void invalidate_dcache_all(void) +static unsigned int __before_dc_op(const int op) { - /* If no cache in CPU exit immediately */ - if (!(read_aux_reg(ARC_BCR_DC_BUILD) & CACHE_VER_NUM_MASK)) - return; + unsigned int reg; + + if (op == OP_INV) { + /* + * IM is set by default and implies Flush-n-inv + * Clear it here for vanilla inv + */ + reg = read_aux_reg(ARC_AUX_DC_CTRL); + write_aux_reg(ARC_AUX_DC_CTRL, reg & ~DC_CTRL_INV_MODE_FLUSH); + }
- /* Write 1 to DC_IVDC register triggers invalidation of entire D$ */ - write_aux_reg(ARC_AUX_DC_IVDC, 1); + return reg; }
-void flush_cache(unsigned long start, unsigned long size) +static void __after_dc_op(const int op, unsigned int reg) { - flush_dcache_range(start, start + size); + if (op & OP_FLUSH) /* flush / flush-n-inv both wait */ + while (read_aux_reg(ARC_AUX_DC_CTRL) & DC_CTRL_FLUSH_STATUS) + ; + + /* Switch back to default Invalidate mode */ + if (op == OP_INV) + write_aux_reg(ARC_AUX_DC_CTRL, reg | DC_CTRL_INV_MODE_FLUSH); }
-#ifdef CONFIG_ISA_ARCV2 -void slc_enable(void) +static inline void __dc_entire_op(const int cacheop) { - /* If SLC ver = 0, no SLC present in CPU */ - if (!(read_aux_reg(ARC_BCR_SLC) & 0xff)) - return; + int aux; + unsigned int ctrl_reg = __before_dc_op(cacheop);
- write_aux_reg(ARC_AUX_SLC_CONTROL, - read_aux_reg(ARC_AUX_SLC_CONTROL) & ~1); -} + if (cacheop & OP_INV) /* Inv or flush-n-inv use same cmd reg */ + aux = ARC_AUX_DC_IVDC; + else + aux = ARC_AUX_DC_FLSH;
-void slc_disable(void) -{ - /* If SLC ver = 0, no SLC present in CPU */ - if (!(read_aux_reg(ARC_BCR_SLC) & 0xff)) - return; + write_aux_reg(aux, 0x1);
- write_aux_reg(ARC_AUX_SLC_CONTROL, - read_aux_reg(ARC_AUX_SLC_CONTROL) | 1); + __after_dc_op(cacheop, ctrl_reg); }
-void slc_flush(void) +static inline void __dc_line_op(unsigned long paddr, unsigned long sz, + const int cacheop) { - /* If SLC ver = 0, no SLC present in CPU */ - if (!(read_aux_reg(ARC_BCR_SLC) & 0xff)) - return; + unsigned int ctrl_reg = __before_dc_op(cacheop); + __cache_line_loop(paddr, sz, cacheop); + __after_dc_op(cacheop, ctrl_reg); +} +#else +#define __dc_entire_op(cacheop) +#define __dc_line_op(paddr, sz, cacheop) +#endif /* !CONFIG_SYS_DCACHE_OFF */
- write_aux_reg(ARC_AUX_SLC_FLUSH, 1); +void invalidate_dcache_range(unsigned long start, unsigned long end) +{ + __dc_line_op(start, end - start, OP_INV); +#ifdef CONFIG_ISA_ARCV2 + if (slc_exists) + __slc_line_op(start, end - start, OP_INV); +#endif +}
- /* Wait flush end */ - while (read_aux_reg(ARC_AUX_SLC_CONTROL) & SLC_CTRL_SB) - ; +void flush_dcache_range(unsigned long start, unsigned long end) +{ + __dc_line_op(start, end - start, OP_FLUSH); +#ifdef CONFIG_ISA_ARCV2 + if (slc_exists) + __slc_line_op(start, end - start, OP_FLUSH); +#endif }
-void slc_invalidate(void) +void flush_cache(unsigned long start, unsigned long size) { - /* If SLC ver = 0, no SLC present in CPU */ - if (!(read_aux_reg(ARC_BCR_SLC) & 0xff)) - return; + flush_dcache_range(start, start + size); +}
- write_aux_reg(ARC_AUX_SLC_INVALIDATE, 1); +void invalidate_dcache_all(void) +{ + __dc_entire_op(OP_INV); +#ifdef CONFIG_ISA_ARCV2 + if (slc_exists) + __slc_entire_op(OP_INV); +#endif }
-#endif /* CONFIG_ISA_ARCV2 */ +void flush_dcache_all(void) +{ + __dc_entire_op(OP_FLUSH); +#ifdef CONFIG_ISA_ARCV2 + if (slc_exists) + __slc_entire_op(OP_FLUSH); +#endif +} diff --git a/arch/arc/lib/cpu.c b/arch/arc/lib/cpu.c index 3c930bc..4e4dd74 100644 --- a/arch/arc/lib/cpu.c +++ b/arch/arc/lib/cpu.c @@ -23,6 +23,8 @@ int arch_cpu_init(void) gd->cpu_clk = CONFIG_SYS_CLK_FREQ; gd->ram_size = CONFIG_SYS_SDRAM_SIZE;
+ cache_init(); + return 0; }
diff --git a/arch/arc/lib/init_helpers.c b/arch/arc/lib/init_helpers.c index 25690ee..dbc8d68 100644 --- a/arch/arc/lib/init_helpers.c +++ b/arch/arc/lib/init_helpers.c @@ -10,16 +10,8 @@ DECLARE_GLOBAL_DATA_PTR;
int init_cache_f_r(void) { -#ifndef CONFIG_SYS_ICACHE_OFF - icache_enable(); - /* Make sure no stale entries persist from before we disabled cache */ - invalidate_icache_all(); -#endif - #ifndef CONFIG_SYS_DCACHE_OFF - dcache_enable(); - /* Make sure no stale entries persist from before we disabled cache */ - invalidate_dcache_all(); + flush_dcache_all(); #endif return 0; } diff --git a/arch/arc/lib/start.S b/arch/arc/lib/start.S index e1ef19c..26a5934 100644 --- a/arch/arc/lib/start.S +++ b/arch/arc/lib/start.S @@ -13,18 +13,46 @@ ENTRY(_start) /* Setup interrupt vector base that matches "__text_start" */ sr __ivt_start, [ARC_AUX_INTR_VEC_BASE]
- /* Setup stack- and frame-pointers */ - mov %sp, CONFIG_SYS_INIT_SP_ADDR - mov %fp, %sp + ; Disable/enable I-cache according to configuration + lr r5, [ARC_BCR_IC_BUILD] + breq r5, 0, 1f ; I$ doesn't exist + lr r5, [ARC_AUX_IC_CTRL] +#ifndef CONFIG_SYS_ICACHE_OFF + bclr r5, r5, 0 ; 0 - Enable, 1 is Disable +#else + bset r5, r5, 0 ; I$ exists, but is not used +#endif + sr r5, [ARC_AUX_IC_CTRL] + +1: + ; Disable/enable D-cache according to configuration + lr r5, [ARC_BCR_DC_BUILD] + breq r5, 0, 1f ; D$ doesn't exist + lr r5, [ARC_AUX_DC_CTRL] + bclr r5, r5, 6 ; Invalidate (discard w/o wback) +#ifndef CONFIG_SYS_DCACHE_OFF + bclr r5, r5, 0 ; Enable (+Inv) +#else + bset r5, r5, 0 ; Disable (+Inv) +#endif + sr r5, [ARC_AUX_DC_CTRL]
- /* Unconditionally disable caches */ +1: #ifdef CONFIG_ISA_ARCV2 - bl slc_flush - bl slc_disable + ; Disable System-Level Cache (SLC) + lr r5, [ARC_BCR_SLC] + breq r5, 0, 1f ; SLC doesn't exist + lr r5, [ARC_AUX_SLC_CTRL] + bclr r5, r5, 6 ; Invalidate (discard w/o wback) + bclr r5, r5, 0 ; Enable (+Inv) + sr r5, [ARC_AUX_SLC_CTRL] + +1: #endif - bl flush_dcache_all - bl dcache_disable - bl icache_disable + + /* Setup stack- and frame-pointers */ + mov %sp, CONFIG_SYS_INIT_SP_ADDR + mov %fp, %sp
/* Allocate and zero GD, update SP */ mov %r0, %sp
Compared to v1:
- Remove explicit selection of L2CACHE on/off in Kconfig, check this
Applied, thanks.
-Alexey
Alexey Brodkin
