[U-Boot] [PATCH v4 2/8] mips: implement to access the KSEG0/1 memory range in map_physmem
U-boot just use the no MMU virtual address segment(KSEG0/1), this patch enable access the uncached memory range(KSEG1) by flag "MAP_NOCACHE", other flag for KSEG0 access.
Signed-off-by: Wills Wang wills.wang@live.com ---
Changes in v4: None Changes in v3: None Changes in v2: None
arch/mips/include/asm/io.h | 7 +++++-- 1 file changed, 5 insertions(+), 2 deletions(-)
diff --git a/arch/mips/include/asm/io.h b/arch/mips/include/asm/io.h index a7ab087..943053d 100644 --- a/arch/mips/include/asm/io.h +++ b/arch/mips/include/asm/io.h @@ -485,7 +485,7 @@ static inline void sync(void) * that can be used to access the memory range with the caching * properties specified by "flags". */ -#define MAP_NOCACHE (0) +#define MAP_NOCACHE (1) #define MAP_WRCOMBINE (0) #define MAP_WRBACK (0) #define MAP_WRTHROUGH (0) @@ -493,7 +493,10 @@ static inline void sync(void) static inline void * map_physmem(phys_addr_t paddr, unsigned long len, unsigned long flags) { - return (void *)paddr; + if (flags) + return (void *)KSEG1ADDR(paddr); + else + return (void *)KSEG0ADDR(paddr); }
- that can be used to access the memory range with the caching
- properties specified by "flags".
I _think_ this is something someone familiar with mips has to review, since I think this has a potential to break a lot of machines.
- if (flags)
- else
Best regards, Marek Vasut
Wills Wang
