[U-Boot] Getting Exception Error while running u-boot from Context-RAM
I am using u-boot as Bootloader for my PPC440 core based hardware board.
I am trying to run the u-boot code from Context RAM (Size 4 MB) instead of DDR and I am successful in it.
But I am observing a machine check exception error while doing board hard reset (by pressing the reset key on board).
When I do the Core reset or Chip reset using BDI3000 debugger, I am not getting any exception error.
But when I press the reset key on board, I am getting an machine check exception error and my board reboots always and continue to generate the exception error.
One thing I noted that, when I shutdown the board system and again restarts the board, then everything is fine and this time I am not getting the exception error.
I am little bit confused because of this abnormal behavior. I believe this issue might be relevant with memory allocation.
I am getting error after this statement mem_malloc_init (), in lib_ppc/board.c file
Code snippet (lib_ppc/board.c) | |
asm ("sync ; isync");
/* initialize malloc() area */
*mem_malloc_init ();*
malloc_bin_reloc ();
#if !defined(CONFIG_SYS_NO_FLASH) puts ("FLASH: "); | |
If anyone has faced this kind of problem earlier, please share your experience.
Thanks & Regards,
Prakash
Hi All,
Can I expect a reply from seniors who might have faced this kind of issue?
If anyone have faced this kind of issue earlier. Please reply.
Thanks in advance.
Regards, Prakash
On Tue, May 25, 2010 at 12:45 PM, prakash bedge <praka sh.bedge@gmail.com> wrote:
asm ("sync ; isync"); /* initialize malloc() area */ *mem_malloc_init ();* malloc_bin_reloc ();
Thanks & Regards,
Prakash
prakash bedge
