[PATCH 1/1] cmd: simplify command efidebug
Currently we have subcommands 'efidebug dh' which shows protocols per handle and 'efidebug devices' which shows the device path. None shows which U-Boot device matches the handle.
Change 'efidebug dh' to show the device path and the U-Boot device if any is associated with the handle.
Remove 'efidebug devices'.
Old output of 'efidebug dh':
Handle Protocols ================ ==================== 000000001b22e690 Device Path, Block IO 000000001b22e800 Device Path, Block IO, system, Simple File System
New output of 'efidebug dh':
000000001b22e690 (host0) /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b)/VenHw(bbe4e671-5773-4ea1-9aab-3a7dbf40c482,00) Block IO
000000001b22e800 (host0:1) /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b)/VenHw(bbe4e671-5773-4ea1-9aab-3a7dbf40c482,00)/HD(1,GPT,7e5c17c5-3f5f-49d0-ae96-511b21d7f273,0x800,0x3f7df) Block IO system Simple File System
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- cmd/efidebug.c | 102 ++++++++----------------------------------------- 1 file changed, 15 insertions(+), 87 deletions(-)
diff --git a/cmd/efidebug.c b/cmd/efidebug.c index 84e6ff5565..76a6b4d8eb 100644 --- a/cmd/efidebug.c +++ b/cmd/efidebug.c @@ -8,6 +8,7 @@ #include <charset.h> #include <common.h> #include <command.h> +#include <dm/device.h> #include <efi_dt_fixup.h> #include <efi_load_initrd.h> #include <efi_loader.h> @@ -344,79 +345,11 @@ static int do_efi_capsule(struct cmd_tbl *cmdtp, int flag, } #endif /* CONFIG_EFI_HAVE_CAPSULE_SUPPORT */
-/** - * efi_get_device_path_text() - get device path text - * - * Return the text representation of the device path of a handle. - * - * @handle: handle of UEFI device - * Return: - * Pointer to the device path text or NULL. - * The caller is responsible for calling FreePool(). - */ -static u16 *efi_get_device_path_text(efi_handle_t handle) -{ - struct efi_handler *handler; - efi_status_t ret; - - ret = efi_search_protocol(handle, &efi_guid_device_path, &handler); - if (ret == EFI_SUCCESS && handler->protocol_interface) { - struct efi_device_path *dp = handler->protocol_interface; - - return efi_dp_str(dp); - } else { - return NULL; - } -} - #define EFI_HANDLE_WIDTH ((int)sizeof(efi_handle_t) * 2)
static const char spc[] = " "; static const char sep[] = "================";
-/** - * do_efi_show_devices() - show UEFI devices - * - * @cmdtp: Command table - * @flag: Command flag - * @argc: Number of arguments - * @argv: Argument array - * Return: CMD_RET_SUCCESS on success, CMD_RET_RET_FAILURE on failure - * - * Implement efidebug "devices" sub-command. - * Show all UEFI devices and their information. - */ -static int do_efi_show_devices(struct cmd_tbl *cmdtp, int flag, - int argc, char *const argv[]) -{ - efi_handle_t *handles; - efi_uintn_t num, i; - u16 *dev_path_text; - efi_status_t ret; - - ret = EFI_CALL(efi_locate_handle_buffer(ALL_HANDLES, NULL, NULL, - &num, &handles)); - if (ret != EFI_SUCCESS) - return CMD_RET_FAILURE; - - if (!num) - return CMD_RET_SUCCESS; - - printf("Device%.*s Device Path\n", EFI_HANDLE_WIDTH - 6, spc); - printf("%.*s ====================\n", EFI_HANDLE_WIDTH, sep); - for (i = 0; i < num; i++) { - dev_path_text = efi_get_device_path_text(handles[i]); - if (dev_path_text) { - printf("%p %ls\n", handles[i], dev_path_text); - efi_free_pool(dev_path_text); - } - } - - efi_free_pool(handles); - - return CMD_RET_SUCCESS; -} - /** * efi_get_driver_handle_info() - get information of UEFI driver * @@ -535,26 +468,25 @@ static int do_efi_show_handles(struct cmd_tbl *cmdtp, int flag, if (!num) return CMD_RET_SUCCESS;
- printf("Handle%.*s Protocols\n", EFI_HANDLE_WIDTH - 6, spc); - printf("%.*s ====================\n", EFI_HANDLE_WIDTH, sep); for (i = 0; i < num; i++) { - printf("%p", handles[i]); + struct efi_handler *handler; + + printf("\n%p", handles[i]); + if (handles[i]->dev) + printf(" (%s)", handles[i]->dev->name); + printf("\n"); + /* Print device path */ + ret = efi_search_protocol(handles[i], &efi_guid_device_path, + &handler); + if (ret == EFI_SUCCESS) + printf(" %pD\n", handler->protocol_interface); ret = EFI_CALL(BS->protocols_per_handle(handles[i], &guid, &count)); - if (ret || !count) { - putc('\n'); - continue; - } - + /* Print other protocols */ for (j = 0; j < count; j++) { - if (j) - printf(", "); - else - putc(' '); - - printf("%pUs", guid[j]); + if (guidcmp(guid[j], &efi_guid_device_path)) + printf(" %pUs\n", guid[j]); } - putc('\n'); }
efi_free_pool(handles); @@ -1539,8 +1471,6 @@ static struct cmd_tbl cmd_efidebug_sub[] = { U_BOOT_CMD_MKENT(capsule, CONFIG_SYS_MAXARGS, 1, do_efi_capsule, "", ""), #endif - U_BOOT_CMD_MKENT(devices, CONFIG_SYS_MAXARGS, 1, do_efi_show_devices, - "", ""), U_BOOT_CMD_MKENT(drivers, CONFIG_SYS_MAXARGS, 1, do_efi_show_drivers, "", ""), U_BOOT_CMD_MKENT(dh, CONFIG_SYS_MAXARGS, 1, do_efi_show_handles, @@ -1630,8 +1560,6 @@ static char efidebug_help_text[] = #endif "\n" #endif - "efidebug devices\n" - " - show UEFI devices\n" "efidebug drivers\n" " - show UEFI drivers\n" "efidebug dh\n"
Heinrich,
If you know how a device path display format is constructed, you can identify it. For instance, /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ -> efi_root /VenHw(bbe4e671-5773-4ea1-9aab-3a7dbf40c482,00) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ -> host 0 /HD(1,GPT,7e5c17c5-3f5f-49d0-ae96-511b21d7f273,0x800,0x3f7df) ^ -> partition 1
There is a good reason for two separate subcommands. While "dh" shows all the handles which currently exist on the system, "devices" shows only ones with device path protocol. The number of handles can possibly be huge (try "dh" on EDK2). For those who are interested in what devices are connected at some point, "devices" subcommand is still useful.
The problem is not "devices" subcommand itself, but the display format of device path. UEFI spec says, in "10.6 EFI Device Path Display Format Overview", "This section describes the recommended conversion between an EFI Device ^^^^^^^^^^^ Path Protocol and text."
So if there is more readable/understandable format, we may want to use it for U-Boot UEFI (at least, as an alternate option of format). Say, /VenHw(root)/VenHw(host, 0)/HD(1,GPT,....) I believe that it is simple and unambiguous.
So please don't remove "devices". Instead, I recommend that the same change be applied to this subcommand, displaying both formats at "devices".
-Takahiro Akashi
000000001b22e690 (host0) /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b)/VenHw(bbe4e671-5773-4ea1-9aab-3a7dbf40c482,00) Block IO 000000001b22e800 (host0:1) /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b)/VenHw(bbe4e671-5773-4ea1-9aab-3a7dbf40c482,00)/HD(1,GPT,7e5c17c5-3f5f-49d0-ae96-511b21d7f273,0x800,0x3f7df) Block IO system Simple File System
- efi_get_device_path_text() - get device path text
- Return the text representation of the device path of a handle.
- @handle: handle of UEFI device
- Return:
- Pointer to the device path text or NULL.
- The caller is responsible for calling FreePool().
- efi_status_t ret;
- } else {
return NULL;
- do_efi_show_devices() - show UEFI devices
- @cmdtp: Command table
- @flag: Command flag
- @argc: Number of arguments
- @argv: Argument array
- Return: CMD_RET_SUCCESS on success, CMD_RET_RET_FAILURE on failure
- Implement efidebug "devices" sub-command.
- Show all UEFI devices and their information.
- efi_status_t ret;
&num, &handles));
- if (!num)
- efi_get_driver_handle_info() - get information of UEFI driver
printf("\n");
&handler);
ret = EFI_CALL(BS->protocols_per_handle(handles[i], &guid, &count));printf(" %pD\n", handler->protocol_interface);
putc('\n');
continue;
for (j = 0; j < count; j++) {/* Print other protocols */
if (j)
printf(", ");
else
putc(' ');
}printf(" %pUs\n", guid[j]);
putc('\n');
U_BOOT_CMD_MKENT(drivers, CONFIG_SYS_MAXARGS, 1, do_efi_show_drivers, "", ""), U_BOOT_CMD_MKENT(dh, CONFIG_SYS_MAXARGS, 1, do_efi_show_handles,"", ""),
-- 2.37.2
On 10/5/22 02:23, AKASHI Takahiro wrote:
Heinrich,
We only have to care about the low number of EFI handles in U-Boot which is block devices + 5.
Having to look up information in two separate commands instead of one place is inconvenient.
The output of efidebug devices does not contain any information which will not be shown by modified efidebug dh command. So the devices command becomes superfluous.
This might be implemented subject to the DisplayOnly argument of EFI_DEVICE_PATH_TO_TEXT_PROTOCOL.ConvertDevicePathToText() in a separate patch.
It would require adding the GUIDs to list_guid[] in lib/uuid.c and switching between '%pUl' and '%pUs' in efi_convert_device_node_to_text.
There is no benefit in having two sub-commands showing the same information. Instead we should reduce the code size.
Best regards
Heinrich
-Takahiro Akashi
- Return:
- efi_status_t ret;
- } else {
return NULL;
- efi_status_t ret;
&num, &handles));
- if (!num)
printf("\n");
&handler);
putc('\n');
continue;
if (j)
printf(", ");
else
putc(' ');
putc('\n');
-- 2.37.2
Heinrich,
Who knows the future.
I don't think so. I sometimes felt comfortable only with the output from "devices" in my past development.
That is why I suggested the same change be applied to "devices" because such information is only meaningful for device paths.
-Takahiro Akashi
Best regards
Heinrich
-Takahiro Akashi
diff --git a/cmd/efidebug.c b/cmd/efidebug.c index 84e6ff5565..76a6b4d8eb 100644 --- a/cmd/efidebug.c +++ b/cmd/efidebug.c @@ -8,6 +8,7 @@ #include <charset.h> #include <common.h> #include <command.h> +#include <dm/device.h> #include <efi_dt_fixup.h> #include <efi_load_initrd.h> #include <efi_loader.h> @@ -344,79 +345,11 @@ static int do_efi_capsule(struct cmd_tbl *cmdtp, int flag, } #endif /* CONFIG_EFI_HAVE_CAPSULE_SUPPORT */ -/**
- Return:
- efi_status_t ret;
- } else {
return NULL;
- #define EFI_HANDLE_WIDTH ((int)sizeof(efi_handle_t) * 2) static const char spc[] = " "; static const char sep[] = "================";
- efi_status_t ret;
&num, &handles));
- if (!num)
printf("\n");
&handler);
putc('\n');
continue;
if (j)
printf(", ");
else
putc(' ');
} efi_free_pool(handles);putc('\n');
-- 2.37.2
Heinrich,
Best regards
Heinrich
-Takahiro Akashi
- Return:
- efi_status_t ret;
- } else {
return NULL;
- efi_status_t ret;
&num, &handles));
- if (!num)
printf("\n");
&handler);
putc('\n');
continue;
if (j)
printf(", ");
else
putc(' ');
-- 2.37.2
FWIW the clean does make sense to me. First of all displaying handles + device is more convenient and it's going to become even more important as the EFI<->DM integration moves on. Not to mention that efidebug is a misnomer (now) it is used for *configuring* boot options. We should try to make the command as lightweight as possible, since people are literally expected to include it in their binary if they want to boot via EFI
Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org
Regards /Ilias
Heinrich,
Best regards
Heinrich
-Takahiro Akashi
- Return:
- efi_status_t ret;
- } else {
return NULL;
- efi_status_t ret;
&num, &handles));
- if (!num)
printf("\n");
&handler);
putc('\n');
continue;
if (j)
printf(", ");
else
putc(' ');
-- 2.37.2
It's not true.
From the beginning, it was seen as a "debugging" tool.
In fact, when I implemented it at the first time, I named it efishell and later proposed alternative names, efiutil and even eficonfig(!) but all were rejected by then-maintainer simply because he saw the command to be a debugging tool. This positioning has not been changed since then.
I believe that Kojima-san's eficonfig can fill the requirements as we all expect.
-Takahiro Akashi
Regards /Ilias
Akashi-san
"\n"
#endif
-- 2.37.2
It's not true. From the beginning, it was seen as a "debugging" tool. In fact, when I implemented it at the first time, I named it efishell and later proposed alternative names, efiutil and even eficonfig(!) but all were rejected by then-maintainer simply because he saw the command to be a debugging tool.
That's why I said *now*. It was a debugging tool way back. Right now we use it to configure the efibootmgr and that's why I proposed splitting efidebug and and 'efi' command way back.
Not really. What about CI tools that rely on the cmd line to test the efibootmgr? We should force all of them to convert to a CI testing that can interpret menus?
Cheers /Ilias
-Takahiro Akashi
Regards /Ilias
AKASHI Takahiro
Ilias Apalodimas
