[U-Boot-Users] Resend: The dreaded embedded environment - linker barf!
Greetings
Well what a suprise!! I've been struck by the environment mapping yet again!.
If I change my memory map for 'top' booting I *should* just need to set the TEXT_BASE address to threequarters up my 4M flash device (so it starts at 0xfff00000), set the CFG_MONITOR_BASE to the same and leave CFG_FLASH_BASE where it is along with all other address config items.
Unfortunately the linker barfs on the embedded environment value which is defined as an offset into the image (well, actually the flash according to the code). Setting it as CFG_ENV_OFFSET or CFG_ENV_ADDR makes no difference (so I can't put it at the start of the flash outside the image either).
The error message from the linker is: u-boot.lds:132 invalid assignment to location counter - the line number refering to the line after the closing brace for the whole file which doesn't help much!!
It looks as though the CFG_FLASH_BASE define is being used inappropriately where CFG_MONITOR_BASE would be a more sensible value (for example to see if the environment is embedded should depend on where in flash that u-boot image is, not where the flash starts!!)
Any ideas appreciated!
Dear Robin,
What do you mean with "should" here? Is this what you think should happen? Maybe your expectations do not match the reality given by the current implementation / configuration.
These defines are used all fine, as long as your configuration makes sense (as demonstrated by the 100+ existing board configurations).
Try to understand what the image should look like, where the environment is located, and which #defines are used to configure the environment to that location.
Robin Gilks
