[U-Boot] [PATCH v3 02/28] sf: probe: Add new spi_flash_probe support
Added new spi_flash_probe support, currently added N25Q* flash part attributes support.
Updated the sector_size attributes as per the flash parts. Looks fine for with this sector_size for computing the size of flash.
Defined CONFIG_SPI_FLASH_LEGACY for old probing style which is available on spi_flash_probe_legacy.c, this will removed soon once all flashes are supported in new spi_flash_probe.
Signed-off-by: Jagannadha Sutradharudu Teki jaganna@xilinx.com --- Changes for v3: - Fix warning issue. Changes for v2: - Removed CONFIG_SPI_FLASH_NEW, add CONFIG_SPI_FLASH_LEGACY - Enable CONFIG_SPI_FLASH_STMICRO in spi_flash_params table - Updated few structure members
drivers/mtd/spi/Makefile | 1 + drivers/mtd/spi/spi_flash_probe.c | 229 ++++++++++++------------- drivers/mtd/spi/spi_flash_probe_legacy.c | 276 +++++++++++++++++++++++++++++++ 3 files changed, 385 insertions(+), 121 deletions(-) create mode 100644 drivers/mtd/spi/spi_flash_probe_legacy.c
diff --git a/drivers/mtd/spi/Makefile b/drivers/mtd/spi/Makefile index 193cb5d..dde2691 100644 --- a/drivers/mtd/spi/Makefile +++ b/drivers/mtd/spi/Makefile @@ -14,6 +14,7 @@ COBJS-$(CONFIG_SPL_SPI_LOAD) += spi_spl_load.o COBJS-$(CONFIG_SPL_SPI_BOOT) += fsl_espi_spl.o endif
+COBJS-$(CONFIG_SPI_FLASH_LEGACY) += spi_flash_probe_legacy.o spi_flash_ops.o spi_flash.o COBJS-$(CONFIG_SPI_FLASH) += spi_flash_probe.o spi_flash_ops.o spi_flash.o COBJS-$(CONFIG_SPI_FLASH_ATMEL) += atmel.o COBJS-$(CONFIG_SPI_FLASH_EON) += eon.o diff --git a/drivers/mtd/spi/spi_flash_probe.c b/drivers/mtd/spi/spi_flash_probe.c index 32ec578..620e41b 100644 --- a/drivers/mtd/spi/spi_flash_probe.c +++ b/drivers/mtd/spi/spi_flash_probe.c @@ -18,6 +18,98 @@
DECLARE_GLOBAL_DATA_PTR;
+/* + * struct spi_flash_params - SPI/QSPI flash device params structure + * + * @name: Device name ([MANUFLETTER][DEVTYPE][DENSITY][EXTRAINFO]) + * @jedec: Device jedec ID (0x[1byte_manuf_id][2byte_dev_id]) + * @ext_jedec: Device ext_jedec ID + * @sector_size: Sector size of this device + * @nr_sectors: No.of sectors on this device + */ +struct spi_flash_params { + const char *name; + u32 jedec; + u16 ext_jedec; + u32 sector_size; + u32 nr_sectors; +}; + +static const struct spi_flash_params spi_flash_params_table[] = { +#ifdef CONFIG_SPI_FLASH_STMICRO /* STMICRO */ + {"N25Q32", 0x20ba16, 0x0, 64 * 1024, 64}, + {"N25Q32A", 0x20bb16, 0x0, 64 * 1024, 64}, + {"N25Q64", 0x20ba17, 0x0, 64 * 1024, 128}, + {"N25Q64A", 0x20bb17, 0x0, 64 * 1024, 128}, + {"N25Q128", 0x20ba18, 0x0, 64 * 1024, 256}, + {"N25Q128A", 0x20bb18, 0x0, 64 * 1024, 256}, + {"N25Q256", 0x20ba19, 0x0, 64 * 1024, 512}, + {"N25Q256A", 0x20bb19, 0x0, 64 * 1024, 512}, + {"N25Q512", 0x20ba20, 0x0, 64 * 1024, 1024}, + {"N25Q512A", 0x20bb20, 0x0, 64 * 1024, 1024}, + {"N25Q1024", 0x20ba21, 0x0, 64 * 1024, 2048}, + {"N25Q1024A", 0x20bb21, 0x0, 64 * 1024, 2048}, +#endif + /* + * TODO: + * ATMEL + * EON + * GIGADEVICE + * MACRONIX + * RAMTRON + * SPANSION + * SST + * STMICRO (M25*) + * WINBOND + */ +}; + +struct spi_flash *spi_flash_validate_ids(struct spi_slave *spi, u8 *idcode) +{ + const struct spi_flash_params *params; + struct spi_flash *flash; + int i; + u16 jedec = idcode[1] << 8 | idcode[2]; + + /* Get the flash id (jedec = manuf_id + dev_id) */ + for (i = 0; i < ARRAY_SIZE(spi_flash_params_table); i++) { + params = &spi_flash_params_table[i]; + if ((params->jedec >> 16) == idcode[0]) { + if ((params->jedec & 0xFFFF) == jedec) + break; + } + } + + if (i == ARRAY_SIZE(spi_flash_params_table)) { + printf("SF: Unsupported flash ID: manuf %02x, jedec %04x\n", + idcode[0], jedec); + return NULL; + } + + flash = malloc(sizeof(*flash)); + if (!flash) { + debug("SF: Failed to allocate spi_flash\n"); + return NULL; + } + memset(flash, '\0', sizeof(*flash)); + + flash->spi = spi; + flash->name = params->name; + flash->poll_cmd = CMD_READ_STATUS; + + /* Assign spi_flash ops */ + flash->write = spi_flash_cmd_write_multi; + flash->erase = spi_flash_cmd_erase; + flash->read = spi_flash_cmd_read_fast; + + /* Compute the flash size */ + flash->page_size = 256; + flash->sector_size = params->sector_size; + flash->size = flash->sector_size * params->nr_sectors; + + return flash; +} + #ifdef CONFIG_SPI_FLASH_BAR int spi_flash_bank_config(struct spi_flash *flash, u8 idcode0) { @@ -84,89 +176,22 @@ int spi_flash_decode_fdt(const void *blob, struct spi_flash *flash) } #endif /* CONFIG_OF_CONTROL */
-/* - * The following table holds all device probe functions - * - * shift: number of continuation bytes before the ID - * idcode: the expected IDCODE or 0xff for non JEDEC devices - * probe: the function to call - * - * Non JEDEC devices should be ordered in the table such that - * the probe functions with best detection algorithms come first. - * - * Several matching entries are permitted, they will be tried - * in sequence until a probe function returns non NULL. - * - * IDCODE_CONT_LEN may be redefined if a device needs to declare a - * larger "shift" value. IDCODE_PART_LEN generally shouldn't be - * changed. This is the max number of bytes probe functions may - * examine when looking up part-specific identification info. - * - * Probe functions will be given the idcode buffer starting at their - * manu id byte (the "idcode" in the table below). In other words, - * all of the continuation bytes will be skipped (the "shift" below). - */ -#define IDCODE_CONT_LEN 0 -#define IDCODE_PART_LEN 5 -static const struct { - const u8 shift; - const u8 idcode; - struct spi_flash *(*probe) (struct spi_slave *spi, u8 *idcode); -} flashes[] = { - /* Keep it sorted by define name */ -#ifdef CONFIG_SPI_FLASH_ATMEL - { 0, 0x1f, spi_flash_probe_atmel, }, -#endif -#ifdef CONFIG_SPI_FLASH_EON - { 0, 0x1c, spi_flash_probe_eon, }, -#endif -#ifdef CONFIG_SPI_FLASH_GIGADEVICE - { 0, 0xc8, spi_flash_probe_gigadevice, }, -#endif -#ifdef CONFIG_SPI_FLASH_MACRONIX - { 0, 0xc2, spi_flash_probe_macronix, }, -#endif -#ifdef CONFIG_SPI_FLASH_SPANSION - { 0, 0x01, spi_flash_probe_spansion, }, -#endif -#ifdef CONFIG_SPI_FLASH_SST - { 0, 0xbf, spi_flash_probe_sst, }, -#endif -#ifdef CONFIG_SPI_FLASH_STMICRO - { 0, 0x20, spi_flash_probe_stmicro, }, -#endif -#ifdef CONFIG_SPI_FLASH_WINBOND - { 0, 0xef, spi_flash_probe_winbond, }, -#endif -#ifdef CONFIG_SPI_FRAM_RAMTRON - { 6, 0xc2, spi_fram_probe_ramtron, }, -# undef IDCODE_CONT_LEN -# define IDCODE_CONT_LEN 6 -#endif - /* Keep it sorted by best detection */ -#ifdef CONFIG_SPI_FLASH_STMICRO - { 0, 0xff, spi_flash_probe_stmicro, }, -#endif -#ifdef CONFIG_SPI_FRAM_RAMTRON_NON_JEDEC - { 0, 0xff, spi_fram_probe_ramtron, }, -#endif -}; -#define IDCODE_LEN (IDCODE_CONT_LEN + IDCODE_PART_LEN) - struct spi_flash *spi_flash_probe(unsigned int bus, unsigned int cs, unsigned int max_hz, unsigned int spi_mode) { struct spi_slave *spi; struct spi_flash *flash = NULL; - int ret, i, shift; - u8 idcode[IDCODE_LEN], *idp; + u8 idcode[5], *idp; + int ret;
+ /* Setup spi_slave */ spi = spi_setup_slave(bus, cs, max_hz, spi_mode); if (!spi) { printf("SF: Failed to set up slave\n"); return NULL; }
+ /* Claim spi bus */ ret = spi_claim_bus(spi); if (ret) { debug("SF: Failed to claim SPI bus: %d\n", ret); @@ -175,45 +200,33 @@ struct spi_flash *spi_flash_probe(unsigned int bus, unsigned int cs,
/* Read the ID codes */ ret = spi_flash_cmd(spi, CMD_READ_ID, idcode, sizeof(idcode)); - if (ret) + if (ret) { + printf("SF: Failed to get idcodes\n"); goto err_read_id; + }
#ifdef DEBUG printf("SF: Got idcodes\n"); print_buffer(0, idcode, 1, sizeof(idcode), 0); #endif
- /* count the number of continuation bytes */ - for (shift = 0, idp = idcode; - shift < IDCODE_CONT_LEN && *idp == 0x7f; - ++shift, ++idp) - continue; - - /* search the table for matches in shift and id */ - for (i = 0; i < ARRAY_SIZE(flashes); ++i) - if (flashes[i].shift == shift && flashes[i].idcode == *idp) { - /* we have a match, call probe */ - flash = flashes[i].probe(spi, idp); - if (flash) - break; - } - - if (!flash) { - printf("SF: Unsupported manufacturer %02x\n", *idp); - goto err_manufacturer_probe; - } + /* Validate ID's from flash dev table */ + idp = idcode; + flash = spi_flash_validate_ids(spi, idp); + if (!flash) + goto err_read_id;
#ifdef CONFIG_SPI_FLASH_BAR - /* Configure the BAR - disover bank cmds and read current bank */ + /* Configure the BAR - discover bank cmds and read current bank */ ret = spi_flash_bank_config(flash, *idp); if (ret < 0) - goto err_manufacturer_probe; + goto err_read_id; #endif
#ifdef CONFIG_OF_CONTROL if (spi_flash_decode_fdt(gd->fdt_blob, flash)) { debug("SF: FDT decode error\n"); - goto err_manufacturer_probe; + goto err_read_id; } #endif #ifndef CONFIG_SPL_BUILD @@ -231,11 +244,11 @@ struct spi_flash *spi_flash_probe(unsigned int bus, unsigned int cs, } #endif
+ /* Release spi bus */ spi_release_bus(spi);
return flash;
-err_manufacturer_probe: err_read_id: spi_release_bus(spi); err_claim_bus: @@ -243,32 +256,6 @@ err_claim_bus: return NULL; }
-void *spi_flash_do_alloc(int offset, int size, struct spi_slave *spi, - const char *name) -{ - struct spi_flash *flash; - void *ptr; - - ptr = malloc(size); - if (!ptr) { - debug("SF: Failed to allocate memory\n"); - return NULL; - } - memset(ptr, '\0', size); - flash = (struct spi_flash *)(ptr + offset); - - /* Set up some basic fields - caller will sort out sizes */ - flash->spi = spi; - flash->name = name; - flash->poll_cmd = CMD_READ_STATUS; - - flash->read = spi_flash_cmd_read_fast; - flash->write = spi_flash_cmd_write_multi; - flash->erase = spi_flash_cmd_erase; - - return flash; -} - void spi_flash_free(struct spi_flash *flash) { spi_free_slave(flash->spi); diff --git a/drivers/mtd/spi/spi_flash_probe_legacy.c b/drivers/mtd/spi/spi_flash_probe_legacy.c new file mode 100644 index 0000000..32ec578 --- /dev/null +++ b/drivers/mtd/spi/spi_flash_probe_legacy.c @@ -0,0 +1,276 @@ +/* + * SPI flash probing + * + * Copyright (C) 2008 Atmel Corporation + * Copyright (C) 2010 Reinhard Meyer, EMK Elektronik + * Copyright (C) 2013 Jagannadha Sutradharudu Teki, Xilinx Inc. + * + * Licensed under the GPL-2 or later. + */ + +#include <common.h> +#include <fdtdec.h> +#include <malloc.h> +#include <spi.h> +#include <spi_flash.h> + +#include "spi_flash_internal.h" + +DECLARE_GLOBAL_DATA_PTR; + +#ifdef CONFIG_SPI_FLASH_BAR +int spi_flash_bank_config(struct spi_flash *flash, u8 idcode0) +{ + u8 cmd; + u8 curr_bank = 0; + + /* discover bank cmds */ + switch (idcode0) { + case SPI_FLASH_SPANSION_IDCODE0: + flash->bank_read_cmd = CMD_BANKADDR_BRRD; + flash->bank_write_cmd = CMD_BANKADDR_BRWR; + break; + case SPI_FLASH_STMICRO_IDCODE0: + case SPI_FLASH_WINBOND_IDCODE0: + flash->bank_read_cmd = CMD_EXTNADDR_RDEAR; + flash->bank_write_cmd = CMD_EXTNADDR_WREAR; + break; + default: + printf("SF: Unsupported bank commands %02x\n", idcode0); + return -1; + } + + /* read the bank reg - on which bank the flash is in currently */ + cmd = flash->bank_read_cmd; + if (flash->size > SPI_FLASH_16MB_BOUN) { + if (spi_flash_read_common(flash, &cmd, 1, &curr_bank, 1)) { + debug("SF: fail to read bank addr register\n"); + return -1; + } + flash->bank_curr = curr_bank; + } else { + flash->bank_curr = curr_bank; + } + + return 0; +} +#endif + +#ifdef CONFIG_OF_CONTROL +int spi_flash_decode_fdt(const void *blob, struct spi_flash *flash) +{ + fdt_addr_t addr; + fdt_size_t size; + int node; + + /* If there is no node, do nothing */ + node = fdtdec_next_compatible(blob, 0, COMPAT_GENERIC_SPI_FLASH); + if (node < 0) + return 0; + + addr = fdtdec_get_addr_size(blob, node, "memory-map", &size); + if (addr == FDT_ADDR_T_NONE) { + debug("%s: Cannot decode address\n", __func__); + return 0; + } + + if (flash->size != size) { + debug("%s: Memory map must cover entire device\n", __func__); + return -1; + } + flash->memory_map = (void *)addr; + + return 0; +} +#endif /* CONFIG_OF_CONTROL */ + +/* + * The following table holds all device probe functions + * + * shift: number of continuation bytes before the ID + * idcode: the expected IDCODE or 0xff for non JEDEC devices + * probe: the function to call + * + * Non JEDEC devices should be ordered in the table such that + * the probe functions with best detection algorithms come first. + * + * Several matching entries are permitted, they will be tried + * in sequence until a probe function returns non NULL. + * + * IDCODE_CONT_LEN may be redefined if a device needs to declare a + * larger "shift" value. IDCODE_PART_LEN generally shouldn't be + * changed. This is the max number of bytes probe functions may + * examine when looking up part-specific identification info. + * + * Probe functions will be given the idcode buffer starting at their + * manu id byte (the "idcode" in the table below). In other words, + * all of the continuation bytes will be skipped (the "shift" below). + */ +#define IDCODE_CONT_LEN 0 +#define IDCODE_PART_LEN 5 +static const struct { + const u8 shift; + const u8 idcode; + struct spi_flash *(*probe) (struct spi_slave *spi, u8 *idcode); +} flashes[] = { + /* Keep it sorted by define name */ +#ifdef CONFIG_SPI_FLASH_ATMEL + { 0, 0x1f, spi_flash_probe_atmel, }, +#endif +#ifdef CONFIG_SPI_FLASH_EON + { 0, 0x1c, spi_flash_probe_eon, }, +#endif +#ifdef CONFIG_SPI_FLASH_GIGADEVICE + { 0, 0xc8, spi_flash_probe_gigadevice, }, +#endif +#ifdef CONFIG_SPI_FLASH_MACRONIX + { 0, 0xc2, spi_flash_probe_macronix, }, +#endif +#ifdef CONFIG_SPI_FLASH_SPANSION + { 0, 0x01, spi_flash_probe_spansion, }, +#endif +#ifdef CONFIG_SPI_FLASH_SST + { 0, 0xbf, spi_flash_probe_sst, }, +#endif +#ifdef CONFIG_SPI_FLASH_STMICRO + { 0, 0x20, spi_flash_probe_stmicro, }, +#endif +#ifdef CONFIG_SPI_FLASH_WINBOND + { 0, 0xef, spi_flash_probe_winbond, }, +#endif +#ifdef CONFIG_SPI_FRAM_RAMTRON + { 6, 0xc2, spi_fram_probe_ramtron, }, +# undef IDCODE_CONT_LEN +# define IDCODE_CONT_LEN 6 +#endif + /* Keep it sorted by best detection */ +#ifdef CONFIG_SPI_FLASH_STMICRO + { 0, 0xff, spi_flash_probe_stmicro, }, +#endif +#ifdef CONFIG_SPI_FRAM_RAMTRON_NON_JEDEC + { 0, 0xff, spi_fram_probe_ramtron, }, +#endif +}; +#define IDCODE_LEN (IDCODE_CONT_LEN + IDCODE_PART_LEN) + +struct spi_flash *spi_flash_probe(unsigned int bus, unsigned int cs, + unsigned int max_hz, unsigned int spi_mode) +{ + struct spi_slave *spi; + struct spi_flash *flash = NULL; + int ret, i, shift; + u8 idcode[IDCODE_LEN], *idp; + + spi = spi_setup_slave(bus, cs, max_hz, spi_mode); + if (!spi) { + printf("SF: Failed to set up slave\n"); + return NULL; + } + + ret = spi_claim_bus(spi); + if (ret) { + debug("SF: Failed to claim SPI bus: %d\n", ret); + goto err_claim_bus; + } + + /* Read the ID codes */ + ret = spi_flash_cmd(spi, CMD_READ_ID, idcode, sizeof(idcode)); + if (ret) + goto err_read_id; + +#ifdef DEBUG + printf("SF: Got idcodes\n"); + print_buffer(0, idcode, 1, sizeof(idcode), 0); +#endif + + /* count the number of continuation bytes */ + for (shift = 0, idp = idcode; + shift < IDCODE_CONT_LEN && *idp == 0x7f; + ++shift, ++idp) + continue; + + /* search the table for matches in shift and id */ + for (i = 0; i < ARRAY_SIZE(flashes); ++i) + if (flashes[i].shift == shift && flashes[i].idcode == *idp) { + /* we have a match, call probe */ + flash = flashes[i].probe(spi, idp); + if (flash) + break; + } + + if (!flash) { + printf("SF: Unsupported manufacturer %02x\n", *idp); + goto err_manufacturer_probe; + } + +#ifdef CONFIG_SPI_FLASH_BAR + /* Configure the BAR - disover bank cmds and read current bank */ + ret = spi_flash_bank_config(flash, *idp); + if (ret < 0) + goto err_manufacturer_probe; +#endif + +#ifdef CONFIG_OF_CONTROL + if (spi_flash_decode_fdt(gd->fdt_blob, flash)) { + debug("SF: FDT decode error\n"); + goto err_manufacturer_probe; + } +#endif +#ifndef CONFIG_SPL_BUILD + printf("SF: Detected %s with page size ", flash->name); + print_size(flash->sector_size, ", total "); + print_size(flash->size, ""); + if (flash->memory_map) + printf(", mapped at %p", flash->memory_map); + puts("\n"); +#endif +#ifndef CONFIG_SPI_FLASH_BAR + if (flash->size > SPI_FLASH_16MB_BOUN) { + puts("SF: Warning - Only lower 16MiB accessible,"); + puts(" Full access #define CONFIG_SPI_FLASH_BAR\n"); + } +#endif + + spi_release_bus(spi); + + return flash; + +err_manufacturer_probe: +err_read_id: + spi_release_bus(spi); +err_claim_bus: + spi_free_slave(spi); + return NULL; +} + +void *spi_flash_do_alloc(int offset, int size, struct spi_slave *spi, + const char *name) +{ + struct spi_flash *flash; + void *ptr; + + ptr = malloc(size); + if (!ptr) { + debug("SF: Failed to allocate memory\n"); + return NULL; + } + memset(ptr, '\0', size); + flash = (struct spi_flash *)(ptr + offset); + + /* Set up some basic fields - caller will sort out sizes */ + flash->spi = spi; + flash->name = name; + flash->poll_cmd = CMD_READ_STATUS; + + flash->read = spi_flash_cmd_read_fast; + flash->write = spi_flash_cmd_write_multi; + flash->erase = spi_flash_cmd_erase; + + return flash; +} + +void spi_flash_free(struct spi_flash *flash) +{ + spi_free_slave(flash->spi); + free(flash); +}
On Sun, Sep 15, 2013 at 12:15 PM, Jagannadha Sutradharudu Teki < jagannadha.sutradharudu-teki@xilinx.com> wrote:
- The following table holds all device probe functions
- shift: number of continuation bytes before the ID
- idcode: the expected IDCODE or 0xff for non JEDEC devices
- probe: the function to call
- Non JEDEC devices should be ordered in the table such that
- the probe functions with best detection algorithms come first.
- Several matching entries are permitted, they will be tried
- in sequence until a probe function returns non NULL.
- IDCODE_CONT_LEN may be redefined if a device needs to declare a
- larger "shift" value. IDCODE_PART_LEN generally shouldn't be
- changed. This is the max number of bytes probe functions may
- examine when looking up part-specific identification info.
- Probe functions will be given the idcode buffer starting at their
- manu id byte (the "idcode" in the table below). In other words,
- all of the continuation bytes will be skipped (the "shift" below).
const u8 shift;
const u8 idcode;
+} flashes[] = {
Do you think it is worth using a linker list for this?
const u8 shift;
const u8 idcode;
+} flashes[] = {
I didn't understand what do you means by this? Can you please elaborate.
Hi Jagan,
const u8 shift;
const u8 idcode;
+} flashes[] = {
I mean that you could use the features of linker_lists.h - for example to define macros to declare each driver, and then have this file look through the available drivers.
U_BOOT_CMD() does this - see do_help() for how the list is scanned.
It's just an idea, perhaps for the future.
Hi Jagannadha,
Jagannadha Sutradharudu Teki jagannadha.sutradharudu-teki@xilinx.com writes:
I've given your series another try on Cubox. It looks better this time (e.g. the probe issue is gone), but there are still a couple of issues. I'm going to reply to each of the affected patches (2, 7, 14) individually so it shows up properly in Patchwork.
This patch causes a major regression and thus breaks bisectability. It rips out support for all SPI flash chips except for STMICRO ones, unless CONFIG_SPI_FLASH_LEGACY is defined. However, CONFIG_SPI_FLASH_LEGACY doesn't get defined anywhere.
A better approach would be to make the new code opt-in rather than opt-out, and selecting it automatically for CONFIG_SPI_FLASH_<vendor> as support for each vendor is added.
PS: What's the etiquette for the CC list of replies to patches? Keep all original recipients CC'ed? Or should I have dropped the chip vendor contacts for this reply?
Sascha
On Sun, Sep 22, 2013 at 12:21 AM, Sascha Silbe t-uboot@infra-silbe.de wrote:
Hi Jagannadha,
Ok.
I think for better bisect-ability, I will keep the old probe as spi_flash_probe_legacy.c which is defined in CONFIG_SPI_FLASH and new anyway spi_flash-probe.c which will defined in CONFIG_SPI_FLASH once all flash probes are merged.
I think it could be a better idea, let me know if you have any comments.
Yes, you could add CCed one on reply, i think it's better to know the flash vendors to know how u-boot is supporting sf. My intention of doing this, if any flash vendor is interesting about these features in u-boot and they might do a test on their hw.
Jagan Teki
Sascha Silbe
