[U-Boot-Users] Ping command problem
Hi All,
I am using u-Boot with Lite5200 board for my project. I enabled "ping" command in u-Boot, but it is not working, giving Timeout error. But tftp is working fine.
I don't find any hardware or network problem, because I am able to ping other machines from "DEBUG" monitor program shipped with Lite5200.
The "PingHandler" function returns error , because the return value of "NetReadIP" function and the value of NetPingIP variable doesn't match. I have tracked the pkt structure assigned to volatile IP_t *ip . The value of ip_p(protocol), ip_src(Source IP address) , ip_dst( Destination IP address) are keep on changing.
Is the problem because the pkt value has been corrupted ? Can any one suggest me the solution to fix this problem?
Thanks & Regards,
P.Prakash
DISCLAIMER: -----------------------------------------------------------------------------------------------------------------------
The contents of this e-mail and any attachment(s) are confidential and intended for the named recipient(s) only. It shall not attach any liability on the originator or HCL or its affiliates. Any views or opinions presented in this email are solely those of the author and may not necessarily reflect the opinions of HCL or its affiliates. Any form of reproduction, dissemination, copying, disclosure, modification, distribution and / or publication of this message without the prior written consent of the author of this e-mail is strictly prohibited. If you have received this email in error please delete it and notify the sender immediately. Before opening any mail and attachments please check them for viruses and defect.
Prakash Palanisamy, TLS-Chennai
