[U-Boot] [PATCH] driver/mtd/spi: Default page size Spansion flash "S25FS512S" is 256b
Signed-off-by: Ashish Kumar Ashish.Kumar@nxp.com --- drivers/mtd/spi/spi_flash.c | 11 ++++++----- 1 file changed, 6 insertions(+), 5 deletions(-)
diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index 3d24a08..ce420cb 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -1046,14 +1046,15 @@ int spi_flash_scan(struct spi_flash *flash) flash->shift = (flash->dual_flash & SF_DUAL_PARALLEL_FLASH) ? 1 : 0; flash->page_size = info->page_size; /* - * The Spansion S25FL032P and S25FL064P have 256b pages, yet use the - * 0x4d00 Extended JEDEC code. The rest of the Spansion flashes with - * the 0x4d00 Extended JEDEC code have 512b pages. All of the others - * have 256b pages. + * The Spansion S25FS512S, S25FL032P and S25FL064P have 256b pages, + * yet use the 0x4d00 Extended JEDEC code. The rest of the Spansion + * flashes with the 0x4d00 Extended JEDEC code have 512b pages. + * All of the others have 256b pages. */ if (JEDEC_EXT(info) == 0x4d00) { if ((JEDEC_ID(info) != 0x0215) && - (JEDEC_ID(info) != 0x0216)) + (JEDEC_ID(info) != 0x0216) && + (JEDEC_ID(info) != 0x0220)) flash->page_size = 512; } flash->page_size <<= flash->shift;
* have 256b pages.
0220 is JEDEC ID for S25FS512S which is 512 is it? commit message says 256b?
-----Original Message----- From: Jagan Teki [mailto:jagannadh.teki@gmail.com] Sent: Wednesday, May 9, 2018 4:44 PM To: Ashish Kumar ashish.kumar@nxp.com Cc: U-Boot Mailing List u-boot@lists.denx.de Subject: Re: [U-Boot] [PATCH] driver/mtd/spi: Default page size Spansion flash "S25FS512S" is 256b
* have 256b pages.
Yes, 0220 is for S25FS512S. The loops says all JEDEC EXT starting 0x4d00 is 512b, except 215,216 and 220.
Regards Ashish
* have 256b pages.
Added proper commit message and
Applied to u-boot-spi/master
Ashish Kumar
Ashish Kumar
Jagan Teki
