[U-Boot] [PATCH] board: ge: bx50v3: Use pwm for display backlight
Setup the LCD backlight brightness control pin to use PWM
Signed-off-by: Akshay Bhat akshay.bhat@timesys.com Cc: Stefano Babic sbabic@denx.de --- board/ge/bx50v3/bx50v3.c | 11 +++++++++++ include/configs/ge_bx50v3.h | 3 +++ 2 files changed, 14 insertions(+)
diff --git a/board/ge/bx50v3/bx50v3.c b/board/ge/bx50v3/bx50v3.c index cf2cd1a..8e55acf 100644 --- a/board/ge/bx50v3/bx50v3.c +++ b/board/ge/bx50v3/bx50v3.c @@ -25,6 +25,7 @@ #include <asm/io.h> #include <asm/arch/sys_proto.h> #include <i2c.h> +#include <pwm.h> DECLARE_GLOBAL_DATA_PTR;
#define UART_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ @@ -324,6 +325,8 @@ static iomux_v3_cfg_t const backlight_pads[] = { /* Backlight enable for LVDS display */ MX6_PAD_GPIO_0__GPIO1_IO00 | MUX_PAD_CTRL(NO_PAD_CTRL), #define LVDS_BACKLIGHT_GP IMX_GPIO_NR(1, 0) + /* backlight PWM brightness control */ + MX6_PAD_SD1_DAT3__PWM1_OUT | MUX_PAD_CTRL(NO_PAD_CTRL), };
static void do_enable_hdmi(struct display_info_t const *dev) @@ -676,9 +679,17 @@ int board_late_init(void) * as per specifications from CHI MEI */ mdelay(250);
+ /* enable backlight PWM 1 */ + pwm_init(0, 0, 0); + + /* duty cycle 5000000ns, period: 5000000ns */ + pwm_config(0, 5000000, 5000000); + /* Backlight Power */ gpio_direction_output(LVDS_BACKLIGHT_GP, 1);
+ pwm_enable(0); + return 0; }
diff --git a/include/configs/ge_bx50v3.h b/include/configs/ge_bx50v3.h index 6fa4a9a..e37cd33 100644 --- a/include/configs/ge_bx50v3.h +++ b/include/configs/ge_bx50v3.h @@ -327,6 +327,9 @@ #define CONFIG_IMX_HDMI #define CONFIG_IMX_VIDEO_SKIP
+#define CONFIG_PWM_IMX +#define CONFIG_IMX6_PWM_PER_CLK 66000000 + #undef CONFIG_CMD_PCI #ifdef CONFIG_CMD_PCI #define CONFIG_PCI
Hi Stefano,
Can this be applied if there are no review comments?
Thanks, Akshay
pwm_init(0, 0, 0);
pwm_enable(0);
#define CONFIG_PCI
2.7.3
Hi Akshay,
On 06/04/2016 16:39, Akshay Bhat wrote:
On Tue, Mar 15, 2016 at 2:24 PM, Akshay Bhat <akshay.bhat@timesys.com mailto:akshay.bhat@timesys.com> wrote:
Setup the LCD backlight brightness control pin to use PWM Signed-off-by: Akshay Bhat <akshay.bhat@timesys.com <mailto:akshay.bhat@timesys.com>> Cc: Stefano Babic <sbabic@denx.de <mailto:sbabic@denx.de>> ---
Hi Stefano,
This is straightforward and can be applied - but I am afraid you need this just if "Update display setup" is applied.
I have some minor changes to ask for that, I am sending my review.
Best regards, Stefano
Thanks, Akshay
board/ge/bx50v3/bx50v3.c | 11 +++++++++++ include/configs/ge_bx50v3.h | 3 +++ 2 files changed, 14 insertions(+) diff --git a/board/ge/bx50v3/bx50v3.c b/board/ge/bx50v3/bx50v3.c index cf2cd1a..8e55acf 100644 --- a/board/ge/bx50v3/bx50v3.c +++ b/board/ge/bx50v3/bx50v3.c @@ -25,6 +25,7 @@ #include <asm/io.h> #include <asm/arch/sys_proto.h> #include <i2c.h> +#include <pwm.h> DECLARE_GLOBAL_DATA_PTR; #define UART_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ @@ -324,6 +325,8 @@ static iomux_v3_cfg_t const backlight_pads[] = { /* Backlight enable for LVDS display */ MX6_PAD_GPIO_0__GPIO1_IO00 | MUX_PAD_CTRL(NO_PAD_CTRL), #define LVDS_BACKLIGHT_GP IMX_GPIO_NR(1, 0) + /* backlight PWM brightness control */ + MX6_PAD_SD1_DAT3__PWM1_OUT | MUX_PAD_CTRL(NO_PAD_CTRL), }; static void do_enable_hdmi(struct display_info_t const *dev) @@ -676,9 +679,17 @@ int board_late_init(void) * as per specifications from CHI MEI */ mdelay(250); + /* enable backlight PWM 1 */ + pwm_init(0, 0, 0); + + /* duty cycle 5000000ns, period: 5000000ns */ + pwm_config(0, 5000000, 5000000); + /* Backlight Power */ gpio_direction_output(LVDS_BACKLIGHT_GP, 1); + pwm_enable(0); + return 0; } diff --git a/include/configs/ge_bx50v3.h b/include/configs/ge_bx50v3.h index 6fa4a9a..e37cd33 100644 --- a/include/configs/ge_bx50v3.h +++ b/include/configs/ge_bx50v3.h @@ -327,6 +327,9 @@ #define CONFIG_IMX_HDMI #define CONFIG_IMX_VIDEO_SKIP +#define CONFIG_PWM_IMX +#define CONFIG_IMX6_PWM_PER_CLK 66000000 + #undef CONFIG_CMD_PCI #ifdef CONFIG_CMD_PCI #define CONFIG_PCI -- 2.7.3
Akshay Bhat
Stefano Babic
